  3. [SOLVED] s17021 vs HTU21
temperature
9 Posts 3 Posters 1.9k Views 2 Watching
  • 4
    4994james
    I have had plenty of success with s17021 sensors and the mysensors library in the past however I have recently purchased some more boards for what I thought was a reasonable deal from Amazon. This is exactly what I have.
    The issue I have is that none of them work. When it gets to Begin() it just stops. It doesn't return at all so doesn't issue a "sensor not detected" which is what I would expect if not connected. I hooked up my logic analyser trace and can see the initial command but nothing comes back.
    I can see the basic chip is different to the ones to the boards I have used previously so assume there is some software incompatibility. However I have looked at the data sheet and it is a I2C component and seems to have identical addresses and commands as the si7021. Have I just got a load of defective items or should I be using different software?
    YveauxY 1 Reply Last reply
      Maybe try an i2c scanner to see if the datasheet has got the address wrong? https://playground.arduino.cc/Main/I2cScanner/
      4 1 Reply Last reply
      • 4 4994james
        YveauxY
        YveauxY
        @4994james How do you connect the board? Do you have the I2C pull-up resistors mounted?
          4994james
          @mfalkvidd Hi. Thank you. Most useful. Just tried and it reports:
          I2C Scanner
          Scanning...
          I2C device found at address 0x40 !
          done
          So seems to be the same as si7021 and correct. Will respond to @Yveaux with more details as still not working with si7021 library.
          • YveauxY Yveaux
            4994james
            @Yveaux
            Many thanks for your response.
            I think the board has onboard pull up resistors, But to eliminate doubt I added 2 1k pull ups to sda and scl. This is the debug output when i use a sparkfun si7021 board (also with same pull ups - though not needed for this board for sure):
            setup!10446 MCO:BGN:INIT OK,TSP=1
            Temp 18.83C	Hum 50.94
            and this is a screenshot of the trace on sda and scl:
            E3 is temp command.
            followed by
            Temp reading and another (not shown) set of commands and humidity reading.
            However with the HTU21D the sketch hangs here:
            setup!10397 MCO:BGN:INIT OK,TSP=1
            i get the same first command trace as you would expect (same library) but no response from the board.
            • 4 4994james
              @Yveaux
              E3 is temp command.
              followed by
              YveauxY
              YveauxY
              @4994james as you own the tools to monitor the i2c traffic, what is going on with the htu on the bus during initialization?
              • YveauxY Yveaux
                4994james
                @Yveaux
                This is what I see on trigger. this is identical when HTU21 and Si7021 boards are connected.
                • 4 4994james
                  @Yveaux
                  4994james
                  @4994james
                  Hi. I have been reading https://forum.mysensors.org/topic/476/htu21d-humidity-temperature-sensor/8 and have now got this working using the adafruit htu21d library. Not sure what the difference is but there obviously is something. I also confirm that the board works without external pull up resistors. Thanks for you help.
                  This is my new (working) code:
                   * Version 1.0: Andrew Sutcliffe
                   * sensor using a HTU21DF Sensor.
                   * Connect Vin to 3-5VDC
                   * Connect GND to ground
                   * Connect SCL to I2C clock pin (A5 on UNO)
                   * Connect SDA to I2C data pin (A4 on UNO)
                  // Enable debug prints
                  //#define MY_RADIO_NRF24
                  #define MY_RS485
                  // Define this to enables DE-pin management on defined pin
                  #define MY_RS485_DE_PIN 2
                  // Set RS485 baud rate to use
                  #define MY_RS485_BAUD_RATE 9600
                  #include <Wire.h>
                  #include "Adafruit_HTU21DF.h"
                  Adafruit_HTU21DF htu = Adafruit_HTU21DF();
                  #define SENSOR_TEMP_OFFSET 0
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  #define MY_NODE_ID 104
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  bool metric = true;
                    sendSketchInfo("HTU21DF-TemperatureAndHumidity", "1.0");
                    present(CHILD_ID_HUM, S_HUM);
                    Serial.begin(115200);
                    Serial.println("HTU21D-F test");
                    if (!htu.begin()) {
                      Serial.println("Couldn't find sensor!");
                      while (1);
                  void loop(){
                    // Get temperature from HTU21DF library
                    float temperature = (htu.readTemperature());
                   if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
                      lastTemp = temperature;
                      // Reset no updates counter
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      Serial.print("T: ");
                      Serial.println(temperature);
                    else {
                      nNoUpdatesTemp++;
                    // Get humidity from HTU21DF library
                    float humidity = (htu.readHumidity());
                    if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      Serial.print("H: ");
                      Serial.println(humidity);
                    else {
                      nNoUpdatesHum++;
                    sleep(UPDATE_INTERVAL);
                  • 4 4994james
                    @4994james
                    #define MY_RS485
                    #include <Wire.h>
                    float lastTemp;
                    float lastHum;
                    bool metric = true;
                      if (!htu.begin()) {
                        while (1);
                    void loop(){
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                      else {
                        nNoUpdatesTemp++;
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                      else {
                        nNoUpdatesHum++;
                    YveauxY
                    YveauxY
                    @4994james great to hear you solved it, and thanks for reporting back!
