  3. MySensors gateway running as a service
gateway
4 Posts 2 Posters 1.3k Views 2 Watching
  • OldSurferDudeO
    OldSurferDudeO
    OldSurferDude
    I have an RPi Zerwo 2w that I am running headless. It is running the minimal version of RaspberryPi OS (no GUI). I can run MySensors Gateway (mysgw) in a ssh sesstion. I would like to run mysgw as a service.
    Granted, I would get no output, but it is running well.
    Well, community, have you ever done this?
    mfalkviddM OldSurferDudeO 2 Replies Last reply
    • OldSurferDudeO OldSurferDude
      @OldSurferDude everyone who has run make install has it running as a service. See the Install section at https://web.archive.org/web/20220306231732/https://www.mysensors.org/build/raspberry
      https://github.com/mysensors/MySensors/pull/1421 adds support for more than one gateway on the same machine. You’ll need to configure them to use different eeprom files though, see my note in the PR.
      OldSurferDudeO 1 Reply Last reply
        OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        I think I got it working.
        note: I use UNAME here. Usually its pi
        create directory ~/.config
        create the file ~/.config/autostart.sh with the contents:
        # must use full path because at this point in the
        #   process, the user is not logged in
        # log the time of boot
        date -R >/home/UNAME/lastboot
        # wait a little bit to ensure network is up
        sleep 5
        # Start the gateway
        # pipe stdout and stderr to the null file so that loose characters are not flying about
        # end with an & to the boot to complete and let the gateway run
        /home/UNAME/MySensors/bin/mysgw >>/dev/null 2>>/dev/null &
        make this file executable
        sudo chmod +x ~/.config/autostart.sh
        Get the autostart program to run at boot by modifying
        #!/bin/sh -e
        # rc.local
        # This script is executed at the end of each multiuser runlevel.
        # Make sure that the script will "exit 0" on success or any other
        # value on error.
        # In order to enable or disable this script just change the execution
        # bits.
        # By default this script does nothing.
        # Print the IP address
        _IP=$(hostname -I) || true
        if [ "$_IP" ]; then
          printf "My IP address is %s\n" "$_IP"
        fi
        # add this line
        # ampersand is very important!
        /home/UNAME/.config/autostart.sh &
        exit 0
        ensure that rc.local is executable
        sudo chmod +x /etc/rc.local
          OldSurferDudeO
          OldSurferDudeO
          OldSurferDude
          @mfalkvidd
          Thanks, I didn't see that!
          OSD
