  3. 3 Switch Pins but 1 Not Updating Vera
pro minipinsswitches
6 Posts 4 Posters 3.1k Views 2 Watching
  • S
    smokey1300
    Having trouble getting the Pro-mini Arduino pins to update my Veralite. As you see the send looks like it should be updating but nothing or maybe I am missing something. In my sketch I am using pins 3,4,5 and pins 3 and 5 are updating fine. I'm running MySensors Plugin V1.4 and API v1.5 and UI7.
    #include <Bounce2.h>
    #define NUMBER_OF_SWITCHES 3
    #define RADIO_ID 88
    Bounce debouncer[NUMBER_OF_SWITCHES];
    int oldValue[NUMBER_OF_SWITCHES];
    byte switchPin[NUMBER_OF_SWITCHES] = {3,4,5}; //<<<<<<<<<<< set your switch pins here
    MyMessage msg(RADIO_ID,V_TRIPPED);
      gw.begin(NULL, RADIO_ID, false);
        gw.sendSketchInfo("Garage Node", "1.2c");
      for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
        pinMode(switchPin[i],INPUT_PULLUP);
        debouncer[i] = Bounce();
        debouncer[i].attach(switchPin[i]);
        debouncer[i].interval(5);
        gw.present(i, S_DOOR);
        gw.wait(250);
        debouncer[i].update();
        int value = debouncer[i].read();
        if (value != oldValue[i])
          gw.wait(250);
          gw.send(msg.setSensor(i).set(value==LOW ? true : false),false);
        oldValue[i] = value;
    • S smokey1300
      #define RADIO_ID 88
          gw.wait(250);
            gw.wait(250);
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @smokey1300
      Have you tried using external pullup resistors instead of the internal?
      S 1 Reply Last reply
        @smokey1300
        smokey1300
        wrote on last edited by smokey1300
        @BulldogLowell Thanks I will try that in the future it's a bit hard SMD resistors.
        If you see the last line on the serial monitor it looks to me it appears to be sending the data...right?
          Yes, looks like it is transmitting.
          How SHOULD the visual feedback for door sensor in UI7 behave?
          • A
            A
            akbooer
            wrote on last edited by akbooer
            It should have red bars above the icon.
            • A akbooer
              smokey1300
              @akbooer Yes this is what I was seeing on UI7 but nothing on sensor pin for sensor door 1. I was powering it from my USB but I changed it to board(MYS11) power 5v and now it sends the data.
              This is good now but now I see delays and some times 2 sensors report both on but only 1 is grounded. I'm not sure if that has to do with debounce timers perhaps?
