Which are the *best* NRF24L01+ modules?
    @Fabien
    Gotta love their product description...
    "The main advantage of it is cheap."
  • @hek : Yes but I havn't notable difference with the one from itead ! And you know it is clone.
    @NeverDie : The first 2 chip from Itead : 1443IA , not a dot but a square and too small to see if there is a hole inside the +. I think i don't investigate more with others sketch because with my dupont cable error rate can increase a lot when just touching a cable.
    I just setup a Iboard with PA+LNA from electrodragon and all my sensebender with clone from electrodragon too, and everything is working fine, up 20 meters without any problems.
    For security I will change my NRF with the ones from Itead and will keep my PA+LNA for milight gateway emulation.
    Move your test nodes further apart, and keep increasing the distance until you start losing a higher percentage of packets. Most likely, as the separation distance and/or RF impairments increase, at some point one module or the other is going to perform much better than the other--that is unless they're using the same type of NRF chip. At least to date that's been my experience with the very few datapoints I've collected so far.
    @NeverDie If/when you get contact with nordic rep, it would be great if they can provide a sketch that does the testing. they probably have one...
    What kind of testing?
    1. Authentic module testing (they might be reluctant to give something like this as it can probably be used to make the copies closer to the original - but worth the try)
    2. QA testing - packet drop, etc at different speeds
    @Moshe-Livne said:
    OK. I haven't yet been contacted by Nordic, and I don't know how that conversation will unfold. If there' is room for Q&A, then I'll be sure to ask them your questions as well as relay their answers back to you.
  • @NeverDie
    NORDIC has on their Website the option to raise questions (MyPage) which are handled by their Tech Support Team. Normally they reply fast.
    @GIEL said:
    Thanks! I tried it just now, so hopefully I will get a response soon.
    Today I ordered some RFM69's. Unit cost is higher, but shipping cost is so much lower that the total cost is actually lower. If they test out better, then I may just go that route instead. In fact, if they test out better. then is there any reason to prefer the NRF24L01+?
    I received the NRF24L01+'s that are on the red PCB's (above), and when I saw they were using the now notorious 1242AF chips, I had little hope. However, I tested them at 1mbps over the same challenge distance as the others, and so far they're doing very well: I transmitted over 200,000 packets, and there were only 0.03% lost packets. Average round trip time was 2.2ms.
    As before, I'm using the RFToys to do the testing. The modules seem more finicky about their orientation than others that I've tested, and moving things just a little can make for much, much worse results.
    I bought them from MDFly on ebay.
    I received more blob modules, and they continue to impress. me. I sent 160,000 packets, and there's only .22% packets lost with an average roundtrip time of 2.2ms. Also, the module doesn't seem particularly sensitive as to its orientation. For that reason, I like them more than the red modules.
    I did some current consumption testing on my modules and the results were quite surprising.
    What should happen is that the current consumption rises during transmission, then stays high until transmission is finished.
    Most modules however show very deep spikes in current consumption during transmission.
    This behavior does not seem to be chip related, more module related (the green ones perform best in this respect).
    It could be caused by the board layout and/or components used.
    My HF knowledge is very limited, so maybe anyone of you have any ideas?
    I don't know HF, but....
    How many bytes in your "transmission" versus how many bytes in your packet data payload? i.e. I wonder if each of your spikes simply correspond to different packets.
    If that's not it, you should compare your measurements to what this guy measured:
    https://www.youtube.com/watch?v=MvjpmsH2wKI
    as it seems he did some careful measurements.
    I received and tested these 10 pin modules from Alice on ebay:
    I hooked them up to Arduino Uno's using 10 pin adapters, also from Alice on Ebay.
    Results are interesting:
    1.21% packet loss over 580,000 packets sent. Average round trip was 1.52ms. The lowest roundTrip time recorded was 0.872ms. These times are a lot lower than on any other modules I've tested.
    As with the red modules, results are sensitive to the antenna orientation .
  • I bought some modules from gc_supermarket which had "antenna symbol" on one side and pinout markings, marked "GOOD QUALITY". Reality was all thrown into a single antistat bag, no markings at all and crap transmissions. I confronted them (after ebay feedback timeout had passed), and they replied "We may send you another 10pcs" two weeks ago. Waiting to receive them.
    I got a batch from ITEAD, with good packaging (individual box+antistat+foam) and the two I've tested so far are surely the best I've had. I can place sensors in my car on the driveway, signal getting into the house (passing through large parts of the engine, metal sheets, thick house walls, inner walls, ...).
    Can you provide a link to the modules you purchased from gc_supermarket? I just want to make sure I don't order precisely the same thing. I haven't tried their blob modules yet, and was literally just about to place an order.
    Did you get your ITEAD modules from the factory or from one of their distributors? I wish I had your good fortune regarding the ITEAD modules. I believe you, but the ones I have from their distributor just don't test out well.
    In fact, for me personally I've concluded that the blob modules work the best. Great range, low packet loss, and no finicky antenna orientation to consider. It turns out they're also among the least expensive modules, but that's just a nice bonus, not my primary consideration. The downside is that they're definitely not genuine NRF24L01+'s, and so I worry there might be some subtle code incompatibility that will someday bite me.
    Anyhow, I'm tired of testing NRF24L01+'s from different vendors, and that's what I'm going with. I have some RFM69HW's on order. If they turn out to be a lot better, then I''ll probably standardize on them, and all this will be moot.
    Wow, what a mess to sort out.
    A given module may have
    • genuine Nordic nRF24L01+
    • genuine Nordic nRF24L01 (no ESB, no 250Kbps) - possibly marked as +
    • quality clone of either, possibly even out-performing Nordic in some way
      (some have higher RF power output)
    • clone with inverted OTA ack bit (ESB OK between same, incompatible with Nordic)
    • clone with reduced sensitivity and/or increased power usage
    • any of the above with missing passive components compared to Nordic reference design
    Meanwhile:
    • We cannot count on visual inspection (Nordic is fabless, some genuine chips may differ over time) or date codes.
    • We do not know of register tests to distinguish differences (except L01 vs L01+)
    • The inverted NoAck bit could be easily tested OTA using ESB mode to a known-good module.
    The packet loss testing may have value, but it can be tricky. NeverDie says " The modules seem more finicky about their orientation than others that I've tested, and moving things just a little can make for much, much worse results."
    That makes comparison difficult - is a given module better/worse than another, or was it it moved "just a little"? There's also the issue of intermittant interference in a crowded band.
    The idea of having "screwed down" test positions as someone suggested is making a lot of sense. Maybe.
    I'm wondering about the blobs that worked better than genuine/iTead nRF24L01+ (@1Mhz), is that because they are the higher powered clones? What's the power supply drain during transmit, compared to genuine?
    The RFM69 family is a good alternative for most sensors, where lower data rates and (regulatory) lower duty cycles of 433/868/915 MHz bands are usually OK. If we want the higher data rates of GFSK at 2.4GHz, maybe the RFM73 is more consistent (fewer if any clones)?
    I wonder about that as well. For instance, the Si24R1 supposedly has a max transmit power of 7dB, which is well above the maximum of 0dB for a true NRF24L01+.
    Unfortunately, I'm not presently setup to measure that, so I don't know the answer. However, the range and performance is simply so much better that I'm guessing that might be the reason for it. And if that is the reason, then great: I can dial back the Tx power when it's not needed, but it's there when it is needed.
    However, I doubt it's the whole story. I also tried some high power modules with PA + LNA that I got from IC Station. These are the same modules that got top rank by a guy who reviewed a whole bunch of modules:
    https://www.youtube.com/watch?v=gtM832Z0ujE
    Guess what? They don't perform as well as the blob modules! At least not in my indoor test setup environment. They cost a lot more too than the blob modules. It's difficult to fathom.
    The packet loss info could be useful.
    The Round Trip Time (RTT) testing would seem to make sense only if using ESB with ack and auto-retry is enabled, and there are errors which require one or more retries. Without retry, the packet should either be received in a fixed amount of time, or not received; the nRF24L01+ doesn't "think it over" for a while before deciding on weak packets. So it's just a disguised packet loss test, but harder to interpret.
    If we want to test link quality, I think packet loss without retries is a the measurement.
    And there should often be different packet losses with short and long packets. Long packets are more likely to get corrupted and lost (failing the CRC test).
    @NeverDie So you've received two orders of blob modules which work well, from different sources?
    Where did you order them from? I'm interested.
    @GIEL said:
    It worked! I provided them with photos of the chips from the Itead modules. Here is their reply:
    We are not aware of any fake chips with these markings as of today, but if you want us to investigate further we need samples here for x-ray.
    It is also possible that the modules has not been properly tuned (e.g. matching network and antenna) during development of the module. You will need access to a spectrum and network analyzer for proper measurement.
    Best regards,
    Kenneth"
    I need to move on. It is not worth my time to pursue this further.
    @NeverDie oh come on! Do it! Do it! 😄
    I originally received two modules from: http://rayshobby.net/rftoy/ when I purchased my RFToy.
    I received 10 from http://www.ebay.com/itm/301378218320, of which I've tested two, and they seem the same.
    These I haven't tried: http://www.ebay.com/itm/301402792434 but looking at the photos they look the same to me.
    So, for the NRF24L01+, if you can call it that, this "blob module" is my final choice. In my rough-and-ready testing, it stood out from the rest. If you decide to get it, I'd be curious if you, or anyone, can figure out what it actually is. It can't do 250Kbps. I anticipate I would run it at 1Mbps only.
    If it weren't for the RFM69HW, I would buy more. I'm waiting to see whether I like it more.
    Looking at the datasheet for the RFM69, I notice the maximum datarate is 300kbps. So, at least on paper, I get the impression the NRF24L01+ wins on power efficiency, but the RFM69 can offer greater range. Is that right? Is that the main tradeoff between the two?
    The RFM69x operates in one of three smaller frequency bands (ie: fewer available frequencies): 433MHz, 868 MHz (Europe), 915 MHz (US).
    While there are supposed to be scores of independent channels for the nRF24 on the wider 2.4GHz band, there isn't as much room on the lower frequency bands. So 300 KBps is more of a theoretical limit; mostly the RFM69 is used for lower bit rates than that, with correspondingly lower bandwidth - and thus higher range! Unlike the nRF, you can trade off bit rate & bandwidth vs range (at any given power).
    For most sensor networks, I think the RFM69 will have plenty of data bandwidth and better range (at say 56Kbps or so). For a good example, see the JeeNodes (which used the RFM12B but are migrating to the RFM69x which fits the same niche but is a better chip). JeeNodes fit a niche very similar to MySensors in that there are distributed sensor nodes communicating with a central hub, with some of the sensor nodes sleeping most of the time to save battery power. (JeeNodes are not as well integrated into common Home Automation systems, but we are now talking more about hardware and protocols).
    I also use the nRF for holiday lighting control, which is more bandwidth hungry. For that the higher speeds are required. In this case a master is blasting data as fast as it can to one or more slaves; the slaves don't need to respond much, and if they do they can be polled with the Master so the master doesn't broadcast at the same time. (If using nRF for MySensors too, obviously they need to be on different channels).
    There is some usefulness to me in using nRF24L01+ for both, so the same node hardware can potentially be re-purposed; it's only a firmware (and channel) change to switch between these networks. But I'm rethinking this and wondering about switching sensors to the RFM68x.
    I'm not sure about power efficiency. An analysis will depend on how often the node needs to be powered up and for how long, as well as the sleep current. JeeNodes are also pretty careful about power.
    They are sounding potentially attractive. Here is some of what I am wondering.
    1. Do they take more power when transmitting? When receiving? (Should be fairly easy to test) When sleeping? (Harder, needs micropower sensor)
    2. Do they test (via registers) as nRF24L01 or nRF24L01+? And in particular, do they implement all the plus features (like ESB mode) other than the missing 250 Kbps data rate?
    3. Are they compatible over the air with the Nordic chips (at 1Mbps/2Mbps)? In general, and in terms of using ESB mode. At least one clone/derivative chip got the NoAck bit (as sent over the air) reversed from Nordic, due to an error in the Nordic datasheet. (We don't see that in the registers, it only shows up in the OTA packet).
    It would be good to be compatible with Nordic (and good clones), so that (1) we can swap in/out with other nRF chips we already have or purchase in the future and (2) in particular we can use the higher powered LNA+PA+antenna versions for a gateway or hub, which are not available in blob form AFAIK.
    Do you have any answers to any of these yet? Anybody else? If they have ESB and are compatible OTA with Nordic, I think they are very attractive; the power usage is a secondary concern, and only for some nodes.
    I don't at present know any of those answers. However, I am interested in power consumed. Also, at present I'm less concerned about interoperability than I am about range and not having to aim the antenna so precisely.
    @Zeph said:
    @Zeph: Regarding #2: What is ESB mode? To what degree does the mysensors code rely on those things being true? i.e. do certain clone/fake chips "break" the mysensors code, or do they just run less efficiently?
    So far I haven't noticed incompatibility between the blob modules and other modules. I haven't extensively tested, though, so it's more of a casual observation. The data seems to get through. That said, I'm going to use only blob modules, so it's a moot issue to me. If it were a concern for you, they're cheap enough you could probably just replace whatever modules you have with blob modules, and then those potential issues disappear. Ironically, the only way to be certain all your modules are of the same type may be to use blob modules! Otherwise, as you outlined earlier, it's really hard to know what chip you actually have on any given module. I have less confidence in how randomly different chips might interoperate than when chps are all of one type, whatever that may be.
    I'm going to switchover from using Mirf (which got me started) to the same library mySensors uses :tmrh20. Then I'll be better able to run more detailed tests that are directly relevant. Either before or after that I'll try to measure power consumption, especially transmit power.
    Got the microscope today. This is a closeup of the genuine NRF-chip.
  • Hi everyone!
    I bought some NRF24L01+ that have the Range Extension chip RFaxis RFX2401C
    I'm curious to see how they perform 🙂
    And for that I'm thinking in rewriting the RFToy Sender/Receiver examples with the MySensor libraries.
    This will allow me to learn about the MySensor libraries and also to test the "performance" of the RF modules with different configurations.
    What do you think? Let me know if you're interested in such code.
    Regards
    @Daniel-Oliveira said:
    Hi everyone!
    Regards
    Yes, definitely! I'll also be very interested to hear about the performance of your range extended modules.
    I took a quick stab just now at using a Dave Jones uCurrent and an oscilliscope to measure the current on an NRF24L01+, but there was too much noise. I suspect long wires are contributing to the problem. I'm inclined to think some kind of onboard measurement by the arduino itself is the way to go, as then the wire lengths are short. Not sure how other people are rigging to do it, but so far measuring NRF power consumption seems a lot easier said than done.
    @NeverDie just some tips when measuring small currents:
    • use a stable power supply (e.g lab supply). Don't power from you pc or cheap switching powersupply.
    • twist the leads to the current.
    • use your scope to filter noise or add a lowpass filter using a capicitor+resistor on the signal going from the ucurrent to your scope
    Thanks! Those are useful suggestions on how to proceed.
    On my first attempt last night I used an Arduino Uno to drive the NRF24L01+. I eventually noticed that even without plugging the USB cable into my computer that the USB cable was a big source of noise when plugged into the Uno. When I did plug the USB cable into my computer, the noise got much worse. So, the USB cable has got to go.
    New plan for the second attempt::
    • Use an RFToy, instead of Uno, because it's a more compact way to plug-in the NRF24L01+ without having wires dangling all over, and because it can run off a coin cell battery, again without wires.
    • Plug the NRF24L01+ into "tall" female header pins, and then plug those into the usual 2x4 header on the RFToy. Why? Because the leg of the tall VCC header pin I'm going to snip and (hopefully) replace with a 1 ohm sense resister. With luck there will be enough room on either side of the inline sense resister to connect up the oscilloscope and thereby do measurements without introducing long wires that might pick up noise.
    BTW, I notice ManiacBug measures transmitter current with just a $50 multimeter and setting "endless trasmitter" mode. https://maniacbug.wordpress.com/2011/10/19/sensor-node/
    Not sure how accurate that is though.
    Lastly, I notice these "Noise Cancelling Techniques" from an Attiny datasheet, regtarding ADC measurements:
    "Digital circuitry inside and outside the device generates EMI which might affect the accuracy of
    analog measurements. When conversion accuracy is critical, the noise level can be reduced by
    applying the following techniques:
    • Keep analog signal paths as short as possible.
    • Make sure analog tracks run over the analog ground plane.
    • Keep analog tracks well away from high-speed switching digital tracks.
    • If any port pin is used as a digital output, it mustn’t switch while a conversion is in progress.
    • Place bypass capacitors as close to VCC and GND pins as possible."
    @NeverDie said:
    @Zeph said:
    Enhanced ShockBurst, which is a mode added to the plus version by Nordic (nRF24L01+). Many of the clones and derivatives have it, some may not. It adds automatic ack and retry, and perhaps other features.
    @hek is ESB mode still used in MySensors?
    Have you found compatible blob modules with external antennas and/or LNA+PA (Low Noise Amplifier + Power Amplifier)?
    Until a new blob module type shows up.
    People here and elsewhere have had a lot of success in interoperation. However, that could be becoming more difficult, if too many fake chips get on the market.
    BTW - I consider an openly described "nRF24L01+ compatible" chip to be a "derivative" if it openly modifies or extends the Nordic functions, a "clone" if it attempts to exactly mimic the Nordic chips. A "fake" is mislabeled and deceptive rather than being openly described as not Nordic.
    Good idea. I think TMRH20 has the best RF24 fork, and I've contributed slightly to it in its early days.
    I look forward to your measurements. For battery operation with long sleep periods, the sleep current is also important.
    If your module has higher RF transmit power (as I suspect), it might also be interesting to see what the current drain is when you drop the power a notch (ie: bring it closer to the Nordic part's RF output). The ideal might be if it can be run at about the same RF power as Nordic with similar PS current, OR could be boosted for more RF power at the cost of more PS current.
    Bu the way, you might have a version which can boost its power still further. For example, the Si24R01 has a default boost of about 2-3 dBm over the Nordic, but can be set for 7 dBm! See https://github.com/solarkennedy/equail/tree/master/Libraries/RF24
    Since transmit power is likely over 10mA you may be able to measure that without a MicroPower device. But you'll need such a device to measure sleep currents.
    Interesting idea. I don't recollect seeing any LNA+PA modules with blobs on them, but then again I haven't tried looking for such a thing. At least so far the simple blob module appears to have all the range I need.
    Good point. Noise might present a problem with measuring it, but I'll make an attempt. Perhaps a regular multimeter would be good enough for that, since (presumably) it would average any spikes? The result might be higher than the true number, and so be a worst case number. That's possibly OK though: if it turns out the worst case number is acceptable, then all is good.
    Excellent! In that case, do you happen to know off the top of your head: what's the simplest method or function call in TMRH20 for putting the NRF24L01+ to sleep? If I don't have to research that, I can jump ahead to taking a measurement of it sleeping, as per the above.
    http://tmrh20.github.io/RF24/classRF24.html#aa0a51923a09ba4f3478aba9be0f8a6a1
    You are going to need your Davy Jones uCurrent to measure sleeping current!
    So, here are the current measurements on the blob module. I used a 1 ohm sense resister, so 1mv=1ma.
    I wrote a short script to transmit a packet once every 10 milliseconds:
    Now I'll zoom in progressively so you can see for yourself what the current is:
    Doing this measurement is the first time I've ever used an oscilliscope (a Rigole 1054Z). Because the lines are kinda thick (noise, I guess), what would you say the current draw is during a transmission?
    In this case, there is no echo receiver, and so whatever gets sent isn't received by anything.
    Here is the simple test jig that I made, using a 1 ohm resistor:
    Here it is mounted on the RFToy:
    Here is how I hooked up the oscilloscope probe:
    For comparison, here are the measurements taken on an ITEAD module:
    So, purely eyeballing it, I'd say the Itead uses about, what, 13ma? The blob module is using maybe 20ma. Perhaps that difference in transmitter current, at least in part, explains the range difference that I observed.
    For further comparison, here are the measurements taken on the red module from earlier in the thread:
    Again, just eyeballing it, that looks like, what, maybe 23ma? Acually more than the blob module, it would seem.
    @NeverDIe Very intersting measurements dude!
    I have a gut feeling for some time that accurately measuring the transmission/reception current of a chip could be used to distinguish fake from real (and of course xray/boiling acid, which is impossible to do for the average consumer).
    Both the width and level of the current spikes are different for each module.
    Could you post the sketch used for measurement somewhere, so I can repeat your measurements?
    I have some 100% genuine Nordic modules, which can be used for reference.
    Here it is:
     nRF24Sender Demo for RFToy
     This demo shows how to use RFToy to make a
     wireless temperature sensor. This is the
     sender module which transmits the current
     temperature value to a receiver module. The
     demo uses the Mirf library.
     This demo uses a 100K resistor and 100K
     thermistor to form a simple temperature
     sensor. Pin A1 is used to read the value.
     The connection is:
     VCC->100K->A1->thermistor->GND
     Written by Jonathan Goldin @ Rayshobby LLC
     Nov 2014
     For details, visit http://rayshobby.net/rftoy
    #include <Mirf.h>
    #include <nRF24L01.h>
    #include <MirfHardwareSpiDriver.h>
    #include <U8glib.h>
    U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);	// I2C / TWI
    void setup(){
       Set ce and csn pins
      Mirf.cePin = 17;
      Mirf.csnPin = 16;
      Mirf.spi = &MirfHardwareSpi;
      Mirf.init();
       * Configure reciving address.
      Mirf.setRADDR((byte *)"clie1");
       * Set the payload length to sizeof(unsigned long) the
       * return type of millis().
       * NB: payload on client and server must be the same.
      //Mirf.payload = sizeof(long);
       * Write channel and payload config then power up reciver.
       * To change channel:
       * Mirf.channel = 10;
       * NB: Make sure channel is legal in your area.
        // we use channel 90 as it is outside of WLAN bands
      // or channels used by wireless surveillance cameras
      //Mirf.channel = 90;
      Mirf.config();
      //This register value is not remembered between power cycles.
      //It defaults to 0x0F.
      //It should be initialized each time if different than 0x0F.
      Mirf.configRegister(RF_SETUP,0x07); //0x0F is 2mbps, max Tx power
                                          //0x07 is 1mbps, max Tx power
                                          //0x2F is 250kbps, max Tx power.
      Serial.println("OTA datarate set to  1Mbps.  Transmit Power set to Maximum.");
      // Read and print RF_SETUP
     byte rf_setup = 0;
     Mirf.readRegister( RF_SETUP, &rf_setup, sizeof(rf_setup) );
     Serial.print( "rf_setup = " );
     Serial.println( rf_setup, BIN );
      // OLED
      u8g.firstPage();
      do{
        uint8_t h;
        u8g.setFont(u8g_font_10x20);
        u8g.setFontRefHeightText();
        u8g.setFontPosTop();
        h = u8g.getFontAscent()-u8g.getFontDescent();
        u8g.drawStr(29,(u8g.getHeight()-h)/2,"Tx Sender");
      while(u8g.nextPage());
      Mirf.setTADDR((byte *)"serv1");
      Serial.write("Sending...\r\n");
      delay(200);
    } // End of *Setup*
    long temp;
      int temp1;
      int temp2;
      long timeTxSent;
      long timeRxReceived;
      long roundTrip;
      byte age1=52;
      byte age2=11;
      long txCounter=0;
      long matchCount=0;
      long differentCount=0;
      long lostCount=0;
      long cumulativeRoundTrip=0;
      long averageRoundTrip=0;
      boolean packetLost=false;
      float packetErrorRate=0;  //no errors yet, and maybe there never will be.
      float lostPacketRate=0;  //no packets lost yet.
      const int statusFrequency=500;  //How many iterations of main loop before printing status info.
      long minRoundTrip=9999; //value will be driven down when program runs
      long maxRoundTrip=0;  //value will be driven up when program runs
    void loop(){
      txCounter++;
      temp = txCounter;  //getTemp(resistance);
      timeTxSent=micros();
      Mirf.send((byte *)&temp);
      while(Mirf.isSending()){
      while ((micros() - timeTxSent) < 10000) {  //send at intervals of 10 milliseconds = 10,000 microseconds.
    }  //End of main loop.
    By the way, an RFToy is, from an IDE perspective, basically an 8Mhz Pro Mini.
    @NeverDie Thanks, but it has quite some dependencies: Mirf, MirfHardwareSpiDriver & u8glib... I guess I have to strip it first.
    Furthermore, which nrf24 library did you use? The one from tmrh20?
    Mirf is the nrf24 library. It's what the RFToy example used, so I started with it, because it "just worked" out of the box. It just happens to be as far as I've gotten so far. I haven't yet converted to tmrh20, which would look more familiar to you.
    The start loop is just a left-over from when I was doing echo testing. I removed the OLED for this test because it was a potential source of interference, so any code related to that could be deleted. Obviously, most of the global variables aren't needed either. As far as transmitting once every 10ms, all the action happens in the main loop, which is pretty simple. It's all fairly basic, because up until I actually did it, I wasn't sure I could even get a sufficiently noiseless signal to measure. Luckily, running the RFtoy on a coincell, and because it's compact and without dangling wires, made that possible.
    So, in terms of which library to install, at the moment the easiest would be to load the RFToy library.
    Or you can wait until I convert over to tmrh20, and then you can follow along that way. I'll need to do that to do the sleep measurement, and because TMRH20 is currently the leading library to use--at least that's what ManiacBug seems to think.
    Or, if you already know tmrh20, you could code it yourself. The pseudo-code is quite simple:
    1. Note the time in microseconds.
    2. Send a packet with a 4 byte data payload (i.e. a LONG)
    3. Wait until the current time exceeds the time in step 1 by at least 10,000 microseconds.
    4. Goto Step 1
    What I don't know are the defaults for ACK's and # of retries, if any, in Mirf and in TMRH20. Aside from that possible difference, I would imagine the current draws are going to be the same in either library, wouldn't you?
    Perhaps the cleanest thing would be to skip the libraries entirely and do it all purely by register manipulations. That'd probably be a diversion from where I want to go, but maybe not a huge diversion. After all, how hard could it be? Since the guys doing the mysensors library for the attiny85 appear to be stuck, I may eventually have to do it that way if I want to use an attiny85 (which I do).
    @NeverDIe I committed a small sketch + NRF24 library which should essentially do the same as your sketch.
    Please find it at https://github.com/Yveaux/NRF24_CurrentFingerprint.
    I verified its behavior using the NRF24 sniffer:
    upload-c8184e00-67be-43e9-af4c-43242e39b830
    Maybe we could compare register settings to be absolutely sure settings are identical:
    upload-1418cfa7-5a26-40ff-9531-7221378b1875
    Maybe you can repeat one of your measurements with this sketch, just to make sure we're measuring in the same way?
    Currently I'm having a hard time measuring the actual current during transmit. I've not been able to get the individual spikes on the scope, not by using a uCurrent nor a single 1ohms resistor.
    This is a uCurrent plot, set at 1mV/uA:
    upload-2a6efb00-7e6a-462f-b3ce-f3a179b80ae6
    That boils down to 1.3mA peak during transmission... That can't be right?!
    Small update: using a 10ohms resitor, the current profile looks like:
    upload-fe4a379b-9a19-4e5d-ba78-086f1906e86b
    10mV/mA, so my module peaks at 11.7 mA. This module contains a 100% genuine Nordic nRF24L01+.
    A module containing a proven fake nRF24L01+ (marked 1242AF), reveals following current profile:
    upload-916e4d87-e4f8-4262-bef9-fd82dbfbca1d
    This one peaks at 19.8mA !!
    Register settings and on-air packets are identical.
    For completenes my measurement setup:
    • Lab supply, which powers USB isolator
    • USB isolator between PC & Arduino (otherwise ground-loops mess things up when using a USB scope on the same PC)
    • 10 ohms resistor
    upload-3ba85b97-4e4a-40af-86f6-00f38b5d545b
    That's great!
    The red module I tested (above) also used 1242AF. So, asuming the NRF chip in the Itead is genuine (which seems increasingly likely), then proportionately speaking, we're getting similar measurements.
    Aside from the Picoscope, what is your test setup? You don't seem to be experiencing the fat scope lines that I am. Where is the NRF module in your photo? Is it being levitated by the wires in the photo? I'm surprised the wires don't seem to be picking up noise.
    @NeverDie I added it to my previous post.
    Overview of whole setup:
    upload-f518c490-0a0f-4376-899d-14af8966192a
    I never had issues with the wires picking up noise; at least not enough to distort communication. They're approx. 20cm long.
    One more:
    upload-972e72b1-ed33-4440-8f4f-602ac91263bf
    Module with nRF marked 1322DQ, supposedly genuine.
    Also 11.2mA
    Tried it with another, random 1242AF, which gave 21.4mA
    Exactly which USB isolator are you using? Sounds like I should get myself a couple in case I ever need to do this again.
    @NeverDie A Chinese clone of this circuit: https://www.circuitsathome.com/measurements/usb-isolator
    The power socket is used to power the isolated USB side.
    Beware this isolator ca only handle FullSpeed (12MBit/s), so not USB 2.0 HighSpeed (480MBit/s).
    This prevents me from isolating my USB scope with it...
    Your setup roughly resembles my first attempt, where I was also using an Uno. However, I was overwhelmed with noise, which made me try the RFToy. I wasn't using isolators, though. I'm glad you got yours working, because it means that just about anyone with isolators and a scope can maybe do this test for themselves. As illustrated by you, the setup if pretty easy to follow. Good job!
    P.S. Does using ribbon cable, as you are doing, rather than individual Dupont wires (as I did when I tried using the Uno) also help with controlling noise?
    Interestingly, the USB cable that came with my Rigol has big ferrite cores on both ends of it. So, that probably helps as well.
    Actually, you could just power that arduino using a battery. Right? Having the isolator is nice, in that you can monitor what's happening, but not strictly necessary.
    So, really, I guess anyone with an o-scope can do this test, which is great!
    @NeverDie correct!
    With some simple hardware the uno could measure the current by itself and determine the maximum current used!
    This has potential!
    @Yveaux said:
    @NeverDie correct!
    This has potential!
    Which hardware would that be?
    It turns out my scope can do better than I thought. Here's the blob module again, but this time at 5mv/div.
    So, I may be able to use an even smaller resistor, because now I can go down to 1mv/div, whereas before it seemed it wouldn't let me go lower than 10mv/div. Hopefully that will help improve my measurement accuracy.
    @NeverDie shunt resistor & opamp. Not sure about the sampling speed of the AtMega yet. Have to dive into its data sheet first....
    @NeverDie transmission takes 233us in my measurements. What's the hdiv on your scope? 500/200us?
    Which chip? The 1242AF (presumed fake), or the one that might be genuine (the one on the Itead module)?
    @NeverDie any chip. Transmission time is identical every time.
    @Yveaux said:
    @NeverDie any chip. Transmission time if identical every time.
    Here's my best picture of the start of the transmission cycle for the blob module. I'm not sure where to call the actual start of it though, but we need to agree on that if we're going to compare numbers without pictures.
    It's labeled on the upper bar (just to the right of the red "STOP") 50us/div
    I modified the resister to be 1/2ohm, so now the vertical is 4ma/div, because it's 2mv/div vertical. Make sense?
    @NeverDie your horizontal scale is very different from what I measure.
    The initial low-level part in the last scope picture shows only part of what you identify as transmission time, while it already lasts roughy 250us. That's more than the whole transmission time I measure!
    We're definitely measuring differently.
    Quickly off my head: a single message is 14 bytes long (see the sniffer capture above). At 1mbit this will take 14*8/1mbit=112 us. Add some time for startup, preamble, shutdown etc. and I think total time will be in the order of 233us, as I measured.
    Could you try running the sketch I put on github to compare things? Probably you will only have to change cs/ss pins to run it (I stick to the default mysensors connections)
    It will also toggle a digital output on pin 3 before/after transmission which you can put on the scope together with the current measured, to have a reference when actual transmission takes place.
    Tonight (in 12 hours or so) I can do some more measurements if necessary.
    I just now noticed where you put your markers on your o-scope plot. There are two voltage increases, the second settles out higher than the first, and it looks like you're counting both. I would guess transmission doesn't really start until the higher voltage is reached, though, wouldn't you? That also is a better match to your 112us number. Perhaps the lower voltage corresponds to loading the buffer or something like that that doesn't need the higher transmit power.
    If you don't mind my asking, why the interest in the transmission length? Doesn't it have to be pretty similar from one type of chip to another, or else they won't interoperate?
    I think that's probably what's happening. I'm running on an 8Mhz Pro Mini (effectively), and you're running on a 16Mhz Uno. So, your first hump takes about half the time mine does ( is that right?), whereas both our second humps should take about the same amount of time. Ahhhhh..., except they don't. Your second hump appears to take longer than my blob module's second hump does. Mine is about 100us, and yours is about 150us? Is that what interests you?
    We would expect the data transmission per se to include a fixed prefix byte, 5 bytes of address, 9 bits of control, 4 bytes of payload, and 2 bytes of CRC (I think). 105 bits = 105uS. (I'm not sure where the 14 bytes in the calculation @Yveaux presented comes from. Either the nRF sends a 16 bit control but only documents 9 bits of it, or the nRF actually sends 9 bits but some software translates the 9th bit into a second byte for analysis purposes)
    Before that there's something like 130 uS to power up and stabilize. And there could be additional time gaps before or after the data per se.
    And of course before all that, there is the time to load the data and commands via SPI; power might potentially rise during that, I suppose.
    Only the time to load commands and data would seem to care whether the uC is running at 8 or 16 MHz. The 105 uS data time should be the same, if they are OTA compatible. The 130 uS power up and stabilizing time could vary between chip designs.
    Any way to see if the fake chip is one of those transmitting with more RF power output? (If it wastes more power doing the same job, not good. If it has the ability to run at higher power but can also be reduced to sip more carefully, that could be a win).
    I look forward to your further testing. Maybe worth checking how much supply current is saved in the other transmit power settings.
    How did you reduce the noise so much in your later scope captures?
    http://www.eevblog.com/forum/testgear/how-do-i-get-1mvdiv-on-the-1054z-i'm-only-getting-10mvdiv/
    Also,
    https://www.youtube.com/watch?v=DMXiD3dKYJc
    How's that for timely?
    Suggestion: for the clone/fake chips, could you test whether they have the SI24R01 power control?
    That is, set bit 1 of register 6 and see if they draw even more current. That should set the SI24R01 - or perhaps a derivative or clone of it - from 2-3 dBm to 7 dBm, which will probably mean using more supply current when the bit is 1 than when it's 0.
    See the (currently) last couple of links in the OP of the fakes thread.
    You might also see if the second register bank can be selected (ACTIVATE+0x53) and read. See http://sigrok.org/wiki/Protocol_decoder:Nrf24l01#Variants_and_clones_of_the_chip from the penultimate link on the fakes thread.
    If it has a second register bank then it's probably a BK24* series or a clone/derivative thereof. (Note that the contents of that second bank seem to be undocumented, at least in English). This niche is apparently popular enough that there are second level derivatives - for example advertised as being BK24* compatible which is in turn nRF24 compatible with extensions!
    I did catch a reference somewhere that implied there was a real RSSI in the second register bank in some derivative; that could be handy if true.
    There's a reference at that same link to the Nordic nRF24L01 (no plus) needing an ACTIVATE+0x73 command to enable certain features that are automatically available in the nRF24l01+.
    This is not something I am aware of. I wonder if some features like ESB can be enabled on the non-plus version? Anyway, if so, this might also be a test which helps sort out clones - if they look like a non-plus derivative, do they respond to ACTIVATE+0x73? (the linked source does not suggest that 250 Kbps mode is one of the features which could be activated)
    @Zeph: I'll may attempt those things tonight, though I'll be giving priority to moving over to TBRH20 first, as it will be better for comparisons if we minimize platform differences, as well as run the same library.
    I agree that using the same library is good for cross comparison among multiple experimenters.
    However, if it turns out that the power profile differs between libraries, on the same hardware sending the same packet, that would be worth some investigation as well to understand why (and perhaps learn how to optimize power). Yeah, that's a different question than detecting variants and understanding their advantages/disadvantages, but the same measurement hardware can be used.
    I was wondering if a small cap across your sense resistor might smooth the traces a bit, and still tell us what we want to know - which is about average power, on a multi-microsecond timescale.
  • Using a non-scientific method; looking at the angle of battery discharge graphs over a week, I've noticed that the modules I got from ITEAD are draining batteries at about half the rate compared to an unknown (but probably fake) pretty good module.
    ITEAD module; slightly under 1% per day
    "other modules"; about 2% per day
    This is when measuring and transmitting DHT21 data every minute.
    Sounds plausible. What cap value would you suggest? I pretty much skipped over learning analog electronics and haven't yet found the time to backfill that gap in my knowledge.
    I've been collecting on eevblog and elsewhere some seemingly good on-point advice about how to improve my scope captures in this situation. I'll probably learn one technique at a time, as time permits, and phase it in gradually.
    I don't really know what a good value would be. Since it's across a 1 ohm resistor (in one case), and you probably want an RC time in the vicinity of microseconds, I'd start with around 1 uF and move up or down from there based on the scope trace. You may be able to just clamp the (short) leads of a cap to your probes to get a look, before soldering.
    And I'll be interested in what other tips you collect that are useful.
    Good information. Hopefully, the scope will help sort out whether that faster drain is mostly during transmit/receive activity, or mostly during the idle time, or both.
    Sounds good. We'll solve for the cap value using empiricism. 😄
    Also, I want to start measuring sleep current soon, because it may prove decisive as to whether a module must be rejected from further consideration because of its potential impact on battery life. Stric's data suggests there are significant differences to be found there. I suspect saving power is one of the harder engineering challenges--or, if not, at least an area where clones may get sloppy--and it might serve as a good separator.
    Agreed. If the module takes more power during transmit because it's putting out more RF, we might be able to back it off by using less than the maximum power settings, or use it in applications where it more rarely transmits.
    But if it uses too much sleep current, it's a bad option for battery power.
    Exactly! You said it better than I did.
    @NeverDie It should be possible to get some better (noiseless) measurements on the rigol scope.... at least if I look at what HARI is measuring on the ESP8266 current...
    I hooked up the uCurrent inline with the Itead NRF24L01+ module, measured using a Fluke 87V multimeter, and I got these measurements:
    Powered Down (Sleep): 0.6uA
    Standby: 22.6uA
    I'm satisfied that these are within error tolerances for the expected results.
    Prior to that, I tested the blob module and seemed to get bizarre results. I'm going to go back and re-test now that I'm reasonably confident the test setup and measurements are working right.
    I'm using an Arduino Uno. This was the test code I used:
    /* Adapted by NeverDie on 8/11/2015 to facilitate uCurrent measurements.
     Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
     TMRh20 2014 - Updates to the library allow sleeping both in TX and RX modes:
          TX Mode: The radio can be powered down (.9uA current) and the Arduino slept using the watchdog timer
          RX Mode: The radio can be left in standby mode (22uA current) and the Arduino slept using an interrupt pin
     * Example RF Radio Ping Pair which Sleeps between Sends
     * This is an example of how to use the RF24 class to create a battery-
     * efficient system.  It is just like the GettingStarted_CallResponse example, but the
     * ping node powers down the radio and sleeps the MCU after every
     * ping/pong cycle, and the receiver sleeps between payloads.
     * Write this sketch to two different nodes,
     * connect the role_pin to ground on one.  The ping node sends the current
     * time to the pong node, which responds by sending the value back.  The ping
     * node can then see how long the whole cycle took.
    #include <avr/sleep.h>
    #include <avr/power.h>
    #include "nRF24L01.h"
    #include "RF24.h"
    #include "printf.h"
    // Set up nRF24L01 radio on SPI bus plus pins 7 & 8
    RF24 radio(7,8);
    // sets the role of this unit in hardware.  Connect to GND to be the 'pong' receiver
    // Leave open to be the 'ping' transmitter
    const int role_pin = 5;
    const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };   // Radio pipe addresses for the 2 nodes to communicate.
    // Role management
    // Set up role.  This sketch uses the same software for all the nodes
    // in this system.  Doing so greatly simplifies testing.  The hardware itself specifies
    // which node it is.
    // The various roles supported by this sketch
    typedef enum { role_ping_out = 1, role_pong_back } role_e;
    // The debug-friendly names of those roles
    const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
    // The role of the current running sketch
    role_e role;
    void setup(){
      // set up the role pin
      pinMode(role_pin, INPUT);
      digitalWrite(role_pin,HIGH);
      delay(20); // Just to get a solid reading on the role pin
      // read the address pin, establish our role
      if ( digitalRead(role_pin) )
        role = role_ping_out;
        role = role_pong_back;
      Serial.begin(57600);
      printf_begin();
      printf("\n\rRF24/examples/pingpair_sleepy/\n\r");
      printf("ROLE: %s\n\r",role_friendly_name[role]);
      radio.begin();
      // Open pipes to other nodes for communication
      // This simple sketch opens two pipes for these two nodes to communicate
      // back and forth.
      // Open 'our' pipe for writing
      // Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
      if ( role == role_ping_out ) {
        radio.openWritingPipe(pipes[0]);
        radio.openReadingPipe(1,pipes[1]);
        radio.openWritingPipe(pipes[1]);
        radio.openReadingPipe(1,pipes[0]);
      // Dump the configuration of the rf unit for debugging
      radio.printDetails();
    void loop(){
      radio.powerDown();              // NOTE: The radio MUST be powered back up again manually
      delay(5000);
      radio.powerUp();                // Power up the radio after sleeping
      delay(5000);
    Yup, same as before. The measurements on the blob module are:
    -43.3ua and -42.8ua.
    I'm not sure which is standby current and which is sleep current. I definitely was not expecting a negative current. There's not much difference in magnitude between the two currents.
    So, I tried it on a different blob module:
    -43.5ua and -42.9ua.
    Essentially the same results.
    Truly bizarre. What's going on? I'm powering the Uno through a roughly 9V battery pack of Eneloop batteries via its barrel jack, as with the earlier measurement of the Itead module, whose measurements not only met expected value, but they were positive currents, not negative ones.
    Here's the red module:
    Powered Down (Sleep): 1.6uA
    Standby: 13.9uA
    Here's an Addicore module from Amazon:
    Powered Down (Sleep): 1.8uA
    Standyby: 16.3uA
    It's a very simple test. I'd say anyone can do these measurements, provided they have a good way to measure microamps.
    So the blob module is so good that it is charging your batteries 😉
    I'm measuring the current between the Uno 3.3 Female header pin and the Vcc pin on the RF module.
    Now talking seriously, maybe the some current is leaking through the other pins (MISO, CE, CS, etc), from arduino to radio? That would could an negative VCC flow I think...
    It must be that. I wonder how it would measure if I were to use 3.3v on the datapins rather than the 5v the Uno uses.
    In theory it would require a logic level converter
    But for sure the atmega is tolerant between 3.3V and 5V. And probably the converter would introduce an error in the u-measurement, I guess.
    I plugged a blob module into the RFToy, which is effectively an 8Mhz Mini Pro running at 3.3v, and used a jig similar to the one before (just no resistor) to route the module Vcc current into the uCurrent.
    This time it is powered through the USB port, and the voltage is downshifted from there.
    New measurements for the blob module:
    Powered Down (Sleep): 3.3uA
    Standby: 67.2uA
    For comparison, I plugged the Itead module (Nordic tracecode 1301CL) into the same apparatus, and this time I got
    Standby: 22.8uA
    which, within measurement error, I would call the same as when it was hooked up to the Uno.
    @Zeph: For the NRF24L01+ modules, I now have good enough current measurements that I wanted to get, so I'll be holding off on doing further measurements, at least for now. I want to try the RFM69HW for comparison, but that is outside the scope of this thread.
    BTW, using just my Fluke 87V multimeter set on the uA setting, the measurements I get are:
    Fluke 87V Itead Module Measurements:
    Powered Down(Sleep): 0.5uA
    Standby: 22.5uA
    and
    Fluke 87V Blob Module Meaasurements:
    Powwred Down(Sleep): 3.0uA
    Standby: 56uA
    and
    Fluke 87V Addicore module from Amazon Measurements:
    Powered Down: 1.2uA
    Standby: 18.2uA
    So, although a bit different than the uCurrent measurements, they seem good enough for separating out the fakes that I have from the genuine article (which at this point the evidence suggests is what the chip in the Itead module is).
    So, good news! Maybe all you need is a DMM with decent uA measurements. If I'd had this information at the very beginning of this thread, it would have saved me a lot of frustration and doubt. Now everyone can be empowered. 😄 The next time you buy modules, you can now easily test them right away and send them back if they're fake! 😄 😄 😄
    I told you in the fifth post 👊 😉
    @hek said:
    Where exactly did you read it anyway?
    Just a lucky guess.
    @hek said:
    Just a lucky guess.
    What??? You were BS'ing me about reading it? 👊 😲
    @hek said:
    You should also compare the power consumption. From what I have read the genuine Nordic module has much better characteristics.
    @NeverDie said:
    You were BS'ing me then?
    Hmm.. no.. but I cannot for my mind recollect where I could have read it. So it might just have been a creation of my (weird) mind. 🙂
    All's well that ends well. 😄
  • 87
  • 7
  • 6
