  2. Bug Reports
  3. ESP8266MQTTClientGateway
mqttgatewayesp8266
8 Posts 3 Posters 4.3k Views 3 Watching
  • M Offline
    M Offline
    mbj
    I am not sure this is a bug or an intentional change of the MQTT message structure.
    The version 1.5 Gateway has the code:
    inline MyMessage& build (MyMessage &msg, uint8_t destination, uint8_t sensor, uint8_t command, uint8_t type, bool enableAck) {
    while the ESP8266MQTTClientGateway uses:
           snprintf_P(_fmtBuffer, MY_GATEWAY_MAX_SEND_LENGTH, PSTR(MY_MQTT_PUBLISH_TOPIC_PREFIX "/%d/%d/%d/%d/%d"), message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type);
    The disadvantage is of course that when upgrading to the ESP8266MQTTClientGateway a lot of coded definitions in for example Openhab have to be changed (I have no experience of how other controllers will handle this).
    Y 1 Reply Last reply
    • M mbj
      Y Offline
      Y Offline
      This is the build-method used to create a message to be sent over the MySensors network, while this
      is the creation of the format string to convert a message to MQTT topic...
      Two different things.
      What is your real issue?
      • Y Yveaux
        M Offline
        M Offline
        mbj
        @Yveaux Thank's for a quick reply. The current message (1.5) shows up with type (like V_TEMP) in third position in the received message at the Openhab end. Item def thus is something like MyMQtt/24/1/V_TEMP:state:default.
        The received message from new version as sniffed by a MQTT.fx client is MyMQTT/24/1/1/0/V_TEMP which thus means a rewrite of all definitions in Openhab.
        • M mbj
          Y Offline
          Y Offline
          @mbj Ok, got it.
          Maybe @hek can explain why the format changed.
          • hekH Offline
            hekH Offline
            It was due to space requirement (all V-types had to be stored as strings) and maintenance reasons (no changes needs to be done in the MQTT driver when adding a new V-types). Also the "new" topic follows the serial protocol (including internal commands) which should make it easier for controller developers to support both MQTT and serial protocol.
              M Offline
              M Offline
              mbj
              @hek Thank's for the info. I have missed any discussions about the change but as I am sure I am not the only one please add some text about the new format as a comment to the sketch whenever convenient. Might save some calls for support :-)
              • hekH Offline
                hekH Offline
                It has been posted here:
                http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway
                  M Offline
                  M Offline
                  mbj
                  @hek That was very visible, please excuse my ignorance. Even though I have looked at this page I managed to leave the change unnoticed.
