nRF5 action!
  • I was playing with sleep tonight and found the following problem.
    when using sleep as below it always returns a figure 252 ms bigger than the sleep figure.
    ie sleep 10000 always returns 10251
    ie sleep 3000 always returns 3251.
    I know the nrf51822 has a 32khz rtc so why is this?
      oldmillis = hwMillis();
      hwSleep(10000);
      newmillis = hwMillis();
      Serial.println(newmillis - oldmillis);
  • Seems it may have something to do with this in the code.
    // Calculate sleep time
    		// 8 Hz -> max 582.542 hours sleep.
    		MY_HW_RTC->PRESCALER = 4095;
    		// Set compare register to 1/125ms + 2 to garantee event triggering
    		MY_HW_RTC->CC[0] = (ms / 125) + 2;```
  • MY_HW_RTC->CC[0] = (ms / 125) + 2;
    It seems the +2 above is adding 250ms.
    Why is it done like this???
    What more can be done to reduce current consumption on an nRF52832 when the MySensors "sleep" function is being used with RTC wakeup. I've measured a 300mv drop on a 10F capacitor over a 12 hour time period. Of that 300mv, perhaps 20mv was lost due to self-discharge of the supercap. So, that still leaves 280mv of loss due to the nRF52832 . That is too high a rate of loss.
  • @NeverDie
    Seeing Your sketch would help?
    A minimum of two ticks are required to be sure the CC[0] is triggered.
    What accuracy is your requirement? I can add more code here to dynamical change the pre scaler plus a check if ms/125>=2
  • @d00616
    My initial thoughts were how the nrf51822 could be used for energy meters (counting pulses and the gap between them),But unlike the arduino's which can not run timers when in sleep mode,The nrf5 can of course do this.
    So the nrf5 would be able to report watts and usage while still using sleep mode.
    But seeing the inaccuracy of the timer has put the brakes on that.
    Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
  • Just wondering what the prescaler etc would have to be set to for ms accuracy and how long before overflow.(aint got my maths head on today)๐Ÿ˜Š
    Wh = 0.5 * 10F * 280mV = 0.392 Wh = 0.0326667 W
    I=0.0326667/2.56V = 12.76mA
    Looks like the node is most time fully active.
    @d00616
    If you have the idea to store the results into the EEPROM like storage the nRF5, then read the hints about this: https://github.com/d00616/arduino-NVM/#nvramh
    The virtual EEPROM, the radio or debugging output are adding latency to the main loop. You will see more timing errors in long term run when you trust the sleep() time.
    The nRF5 can help you to count without adding latency by the cpu. You can use a timer in counter mode which TASK_COUNT and TASKS_CAPTURE[0] are triggered by PPI. Then you can compare the hwMillis() with the last seen CC[0] content and do precise calculation of events.
    With nRF52 there is an unused RTC wich can trigger TASKS_CAPTURE[0] at a specific time. One RTC is used for millis() in arduino-nrf5 and one RTC is used for sleep.
    I will change this.
    @rmtucker
    Here it is, though it's rather messy. Nonetheless, all it does is measure the supercap and solar panel voltages, send them, then sleep for 12 hours. Then repeats:
    // nrf51_client.pde
    // -*- mode: C++ -*-
    // Example sketch showing how to create a simple messageing client
    // with the RH_NRF51 class. RH_NRF51 class does not provide for addressing or
    // reliability, so you should only use RH_NRF51 if you do not need the higher
    // level messaging abilities.
    // It is designed to work with the other example nrf51_server.
    // Tested on RedBearLabs nRF51822 and BLE Nano kit, built with Arduino 1.6.4.
    // See http://redbearlab.com/getting-started-nrf51822/
    // for how to set up your Arduino build environment
    // Also tested with Sparkfun nRF52832 breakout board, witth Arduino 1.6.13 and
    // Sparkfun nRF52 boards manager 0.2.3
    #include <RH_NRF51.h>
    unsigned long SLEEP_TIME = 43200000; // 12 hour sleep time between measurements (in milliseconds)
    //unsigned long SLEEP_TIME = 3600000; // 1 hour sleep time between measurements (in milliseconds)
    //unsigned long SLEEP_TIME = 300000; // 5 minute sleep time between measurements (in milliseconds)
    //unsigned long SLEEP_TIME = 1000; // 1 second sleep time between measurements (in milliseconds)
    #define SUPERCAP_PIN A2  //input pin for reading the supercap's voltage
    #define SOLAR_PANEL_PIN A4  //input pin for reading the solar panel's voltage
    #define LDO_ENABLE_PIN 8  //D8 (P0.19) is output pin for enabling (HIGH) or disabling (LOW) the LDO
    #define NUM_MEASUREMENTS_TO_AVERAGE 3  //number of measurements to collect and then average
    #define MAX_MEASUREMENTS 10 //Maximum number of voltage measurements before returning a result.
    // Singleton instance of the radio driver
    RH_NRF51 nrf51;
    uint8_t data[10];
    uint16_t batteryVoltage() {
      uint16_t lastRawVoltage, newRawVoltage;
      //uint16_t counter=0;
      //lastRawVoltage = hwCPUVoltage();  //throw away the first voltage measurement
      newRawVoltage = hwCPUVoltage();
      return newRawVoltage;
    uint16_t readRawVoltageOnPin(uint8_t thePin) {
      uint16_t counter=0;
      lastRawVoltage = analogRead(thePin);
      newRawVoltage = analogRead(thePin);
      while (((newRawVoltage != lastRawVoltage)) && (counter<MAX_MEASUREMENTS)) {  //measure until two consecutive measurements match
        lastRawVoltage=newRawVoltage;
        newRawVoltage=analogRead(thePin);
        counter++;
      uint32_t sumOfMeasurements=0;
      for (int i=0;i<NUM_MEASUREMENTS_TO_AVERAGE;i++) {
        sumOfMeasurements=sumOfMeasurements+analogRead(thePin);
      return (sumOfMeasurements/NUM_MEASUREMENTS_TO_AVERAGE);
    void myBaro()
      uint32_t superCapVoltage=0;
      uint32_t solarPanelVoltage=0;
      uint32_t superCapRawVoltage=0;
      uint32_t solarPanelRawVoltage=0;
      digitalWrite(LDO_ENABLE_PIN, LOW);  //disconnect solar panel
      superCapRawVoltage = readRawVoltageOnPin(SUPERCAP_PIN);
      superCapVoltage = (3048*(((superCapRawVoltage)*3127)/4095))/1591;
      //Serial.print("SuperCap voltage=");
      //Serial.println(superCapVoltage);
      //send(msg1_S_BARO_P.set(superCapVoltage));  //superCap's raw voltage
    //  wait(500);
    //  wait(500);
      //delayMicroseconds(1000);  //wait for voltage to adjust after LDO disabled.  Necessary???
      solarPanelRawVoltage=readRawVoltageOnPin(SOLAR_PANEL_PIN);
      digitalWrite(LDO_ENABLE_PIN, HIGH);  //re-connect solar panel
      solarPanelVoltage=(5500*(((solarPanelRawVoltage)*3181)/4095))/1289;
      //Serial.print("Solar Panel Voltage=");
      //Serial.println(solarPanelVoltage);
      //superCapVoltage=1234;
      data[0]= (superCapVoltage/1000)+'0';
      data[1]= ((superCapVoltage%1000)/100)+'0';
      data[2]= ((superCapVoltage%100)/10)+'0';
      data[3]= (superCapVoltage%10)+'0';
      data[4]=',';
      data[5]= (solarPanelVoltage/1000)+'0';
      data[6]= ((solarPanelVoltage%1000)/100)+'0';
      data[7]= ((solarPanelVoltage%100)/10)+'0';
      data[8]= (solarPanelVoltage%10)+'0';
      data[9]='\0';
      nrf51.send(data, sizeof(data));
      nrf51.waitPacketSent();
      pinMode(LDO_ENABLE_PIN, OUTPUT);  // Enable/Disable pin for the LDO
      digitalWrite(LDO_ENABLE_PIN, HIGH);  //enable the LDO.
      analogReadResolution(12);  //use 12-bit ADC resolution
      pinMode(SUPERCAP_PIN,INPUT);  //Supercap voltage measurement pin
      pinMode(SOLAR_PANEL_PIN,INPUT);  //Solar panel voltage measurement pin
      //delay(1000); // Wait for serial port etc to be ready
      Serial.begin(250000);
      //while (!Serial)
        ; // wait for serial port to connect.
      if (!nrf51.init())
        Serial.println("init failed");
      // Defaults after init are 2.402 GHz (channel 123), 2Mbps, 0dBm
      if (!nrf51.setChannel(123))
        Serial.println("setChannel failed");
      if (!nrf51.setRF(RH_NRF51::DataRate2Mbps, RH_NRF51::TransmitPower4dBm))
        Serial.println("setRF failed");
      // AES encryption can be enabled by setting the same key in the sender and receiver
    //  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
    //                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
    //  nrf51.setEncryptionKey(key);
    //  nrf51.printRegisters();
      Serial.println("Setup of nr51 client completed.");
      Serial.println("Sending to nrf51_server...");
      Serial.flush();
    uint32_t sentCounter=0;
    uint32_t replyCounter=0;
      //uint16_t theBatteryVoltage;
      //theBatteryVoltage=batteryVoltage();
     // Serial.print("Battery voltage = ");
      //Serial.print(theBatteryVoltage);
      //Serial.println(" millivolts.");
      // Send a message to nrf51_server
      //uint8_t data[] = "Hello World!";
      data[0]= (theBatteryVoltage/1000)+'0';
      data[1]= ((theBatteryVoltage%1000)/100)+'0';
      data[2]= ((theBatteryVoltage%100)/10)+'0';
      data[3]= (theBatteryVoltage%10)+'0';
      data[4]='\0';
      sentCounter++;
      myBaro();
      // Now wait for a reply
      uint8_t buf[RH_NRF51_MAX_MESSAGE_LEN];
      uint8_t len = sizeof(buf);
      if (nrf51.waitAvailableTimeout(500))
        // Should be a reply message for us now
        if (nrf51.recv(buf, &len))
          Serial.print("got reply: ");
          Serial.println((char*)buf);
          replyCounter++;
          Serial.println("recv failed");
        Serial.println("No reply, is nrf51_server running?");
      Serial.print("sentCounter=");
      Serial.print(sentCounter);
      Serial.print(", replyCounter=");
      Serial.println(replyCounter);
      Serial.flush();
      sleep(SLEEP_TIME); // Sleeps for 12 hours in deep sleep
    Using Termite to timestamp the output received, what I got was:
    2017/08/25 17:04:13: got request: 2684,0085
    2017/08/26 05:04:12: got request: 2396,0076
    You can ignore the solar panel measurements, because I disconnected it so as to not interfere.
    On the bright side, it woke up and reported within 1 second of when it was supposed to, after a 12 hour sleep.
    RadioHead sets the radio into the Idle state. The radio isn't powered off. There is no call in RadioHead to power off the radio.
  • @NeverDie
    So your sketch only wakes up every 12hours.
    What current is it drawing using the radiohead library vs mysensors for an equivalent 12 hour sleep because in past discussions with you i remember you saying 5-6uA while sleeping,is this still correct?
    I dont see much advantage to the radiohead library if only sending at 12hour intervals.
    The 6ua was measured with it in deep sleep, where it relied on an external interrupt to wakeup. This measurement was intended to see what it would be if it woke-up using the RTC. So, the 12 hour interval is artificial, for measurement purposes.
    @d00616
    I had wrongly assumed that the "sleep(...)" command would sleep the radio. Thanks for pointing out my error. How/when is it that Mysensors puts the radio to sleep? Does it just happen automatically at the end of every sending/receiving?
    We are both not 100% correct ๐Ÿ˜‰ The hwSleep() function doesn't disable the radio, but the sleep() function does it, when MY_SENSOR_NETWORK is defined.
    After Sleep transportReInitialise() is called. Then you have to initialize RadioHead again.
    So, even with RAM retention active while sleeping, each time the radio is awoken, it needs to be re-initialized?
    The Radio has to be initialized after power down. This doesn't depend on RAM retention.
    According to Table 39 of the mRF52832 datasheet, there is only one radio state resembling sleep, and that is the DISABLED radio state where "No operations are going on inside the radio and the power consumption is at a minimum."
    Apparently the radio is disabled through register TASKS_DISABLE, offset 0x010, Disable RADIO, as indicated by Table 41 register overview.
    But how exactly does one read or write to these registers? It looks like a quite different arrangement than writing to registers for an nRF24 or an RFM69 or a LoRa chip.
    You have to include nrf.h. To disable the radio, you can do this:
    https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/Radio_ESB.cpp#L264
    If your transmitting power is 0dbm, then "TX only run current PRF = 0dBm" with 11.6 mA is near the calculated current, when the radio stays in TX mode after sending the data.
    @d00616
    Will this block of code guarantee that the radio is disabled?
      Serial.println("Testing whether radio is disabled...");
      Serial.print("NRF_RADIO->EVENTS_DISABLED=");
      Serial.println(NRF_RADIO->EVENTS_DISABLED);
      while (!(NRF_RADIO->EVENTS_DISABLED)) {
        NRF_RADIO->TASKS_DISABLE = 1;  //sleep the radio
      Serial.println("Radio disabled.");
    This one is better:
    if (NRF_RADIO->STATE != RADIO_STATE_STATE_Disabled) {
    The sleep() function is now more precise for sleeping <512s:
    https://github.com/mysensors/MySensors/pull/909
    The PR is waiting for merge.
    @d00616
    That works. Thanks!
    What's the best way to awaken the radio after sleeping it though? I've tried:
        NRF_RADIO->TASKS_START  = 1;  //awaken the radio
    and
        NRF_RADIO->TASKS_TXEN  = 1;  //awaken the radio
    and neither seems to have an effect. The radio stays disabled.
    This depends on the implementation. Sorry, at the moment I have not time to look into the RadioHead code in that detail. You can try to initialize the library again.
    @NeverDie Here is a snippet to dump all registers, hope it's help to analyze whats going wrong with RadioHead:
    Serial.print("NRF_RADIO->EVENTS_READY  ");
    Serial.println(NRF_RADIO->EVENTS_READY, HEX);
    Serial.print("NRF_RADIO->EVENTS_ADDRESS  ");
    Serial.println(NRF_RADIO->EVENTS_ADDRESS, HEX);
    Serial.print("NRF_RADIO->EVENTS_PAYLOAD  ");
    Serial.println(NRF_RADIO->EVENTS_PAYLOAD, HEX);
    Serial.print("NRF_RADIO->EVENTS_END  ");
    Serial.println(NRF_RADIO->EVENTS_END, HEX);
    Serial.print("NRF_RADIO->EVENTS_DISABLED  ");
    Serial.println(NRF_RADIO->EVENTS_DISABLED, HEX);
    Serial.print("NRF_RADIO->EVENTS_DEVMATCH  ");
    Serial.println(NRF_RADIO->EVENTS_DEVMATCH, HEX);
    Serial.print("NRF_RADIO->EVENTS_DEVMISS  ");
    Serial.println(NRF_RADIO->EVENTS_DEVMISS, HEX);
    Serial.print("NRF_RADIO->EVENTS_RSSIEND  ");
    Serial.println(NRF_RADIO->EVENTS_RSSIEND, HEX);
    Serial.print("NRF_RADIO->EVENTS_BCMATCH  ");
    Serial.println(NRF_RADIO->EVENTS_BCMATCH, HEX);
    Serial.print("NRF_RADIO->CRCSTATUS  ");
    Serial.println(NRF_RADIO->CRCSTATUS, HEX);
    Serial.print("NRF_RADIO->RXMATCH  ");
    Serial.println(NRF_RADIO->RXMATCH, HEX);
    Serial.print("NRF_RADIO->RXCRC  ");
    Serial.println(NRF_RADIO->RXCRC, HEX);
    Serial.print("NRF_RADIO->DAI  ");
    Serial.println(NRF_RADIO->DAI, HEX);
    Serial.print("NRF_RADIO->PACKETPTR  ");
    Serial.println(NRF_RADIO->PACKETPTR, HEX);
    Serial.print("NRF_RADIO->FREQUENCY  ");
    Serial.println(NRF_RADIO->FREQUENCY, HEX);
    Serial.print("NRF_RADIO->TXPOWER  ");
    Serial.println(NRF_RADIO->TXPOWER, HEX);
    Serial.print("NRF_RADIO->MODE  ");
    Serial.println(NRF_RADIO->MODE, HEX);
    Serial.print("NRF_RADIO->PCNF0  ");
    Serial.println(NRF_RADIO->PCNF0, HEX);
    Serial.print("NRF_RADIO->PCNF1  ");
    Serial.println(NRF_RADIO->PCNF1, HEX);
    Serial.print("NRF_RADIO->BASE0  ");
    Serial.println(NRF_RADIO->BASE0, HEX);
    Serial.print("NRF_RADIO->BASE1  ");
    Serial.println(NRF_RADIO->BASE1, HEX);
    Serial.print("NRF_RADIO->PREFIX0  ");
    Serial.println(NRF_RADIO->PREFIX0, HEX);
    Serial.print("NRF_RADIO->PREFIX1  ");
    Serial.println(NRF_RADIO->PREFIX1, HEX);
    Serial.print("NRF_RADIO->TXADDRESS  ");
    Serial.println(NRF_RADIO->TXADDRESS, HEX);
    Serial.print("NRF_RADIO->RXADDRESSES  ");
    Serial.println(NRF_RADIO->RXADDRESSES, HEX);
    Serial.print("NRF_RADIO->CRCCNF  ");
    Serial.println(NRF_RADIO->CRCCNF, HEX);
    Serial.print("NRF_RADIO->SHORTS  ");
    Serial.println(NRF_RADIO->SHORTS, HEX);
    @d00616
    I did a bit more poking around, and I've confirmed that there's no need to re-enable the radio before transmitting. Apparently doing the transmission and returning to disabled mode happens automatically. In fact, I think this is the expected behavior, as indicated by Figure 35 of the datasheet.
    So, under this theory, the only time when the radio is not disabled is when it is actively transmitting or receiving. There's no need to manually disable it, because that appears to happen automatically anyway.
    So, to move forward with this, I took a super-stripped down nRF52832, and loaded it with a super stripped down sketch that never initializes the radio and pretty much just jumps directly into a long RTC 12 hour slumber using the MySensors sleep routine. Measuring the current drawn while in that slumber using a uCurrent Gold, I'm reading about 9.3ua. So, to confirm that, I'm running the same stripped down setup from a 10F supercap, and I'll see at what rate the supercap voltage drops with time, and whether that appears to agree or not with these initial measurements.
    Hopefully the current draw will remain low, and there will be no surprises. In that case, I'll add stuff back in until I find the culprit that was previously causing the higher current draw.
  • @NeverDie
    I can not understand why you are drawing 9.4uA in the first place?.
    My nrf51822 seems to consistently only draw 4-5uA with no strip down of software when in mysensors sleep mode.
    Fair enough i have not got your measurement equipment but i don,t see it being that far away.
    The data sheets seem to point to under 5uA.
    Yes, it is puzzling. I don't have a good answer as to why it measures so high. Maybe the crystal oscillator? What else is there that might be causing it?
    After this initial run completes, I'll try reprogramming it to use the internal resonnator instead and see if that makes any difference.
    Indeed, reprogramming the Ebyte nRF52832 to use the internal oscillator dropped the sleep current consumption down to 5.4ua. ๐Ÿ™‚
    I wonder whether physically removing the crystal oscillator would result in additional savings, or if that's as low as it goes?
    I also wonder whether the datasheet cheats a bit by not counting the current consumed by the external crystal oscillator when that's being used? Otherwise, I don't see how Nordic can claim a <2ua sleep current for the nRF52832.
  • @NeverDie
    Stranger still my 4-5uA is using the external crystal??.
    I have to amend what I just said, because I took a measurement short-cut that in retrospect I shouldn't have: namely, I did the measurements on two different modules.
    I went back and changed the 5.4ua module using the RC internal oscillator to use the external crystal oscillator, and it measures about the same.
    So... The difference I was reading was a difference in the way the two modules measure. I'm not sure why one reads higher than the other, except perhaps that I didn't clean the solder flux off the higher reading module, and I did clean off the solder flux on the lower reading module.
    I'll try cleaning the solder flux off the higher reading module and see if that drops the current consumed.
    I cleaned off the solder flux and... no real difference. Go figure. Maybe it's just random variation among the Ebyte Modules? I guess I'll have to wire up more of them and see how they all compare.
    @NeverDie did you select the option with internal crystal ? 1s accuracy after 12h like you said before sounds more like a precise external crystal than an internal one.
    Up until today I was using just the external crystal on the Ebyte nRF52832's. It was only for comparison purposes of current consumption that today I switched to the internal resonator. It's about the same current consumption. Maybe if I now remove the external crystal, it will save some current? I just don't know.
    While developing the nRF5 port, I had no chance to measure the current of the nRF52 accurate. With my original nRF51 dev kit I I have a sleeping current matching the data sheet.
    Now I can measure currents in the ยตA range. With all nRF52 I have, I measured sleeping currents around 10ยตA. This is to much. We have to see 2-3ยตA. I have no original nRF52832 dev kit to compare. The reason of this sleeping current can be either an error in the layout or there is a component which is not required in active state while sleeping.
    At the moment I have no time to analyse this. There is a bug in the radio code, which I have to fix. When transport debug is disabled no packages are received. In my opinion this has more priority.
    @NeverDie Just my two cents. Leakage current through non ideal capacitors can be 1-10uA.
    It turns out that the culprit was the mere act of using pinmode to designate a pin as an input pin, even if it's not connected to anything. Then, during sleep, the current consumption is an order of magnitude higher. This is quite different behavior than on, say, an Arduino pro mini, where the input pins are high impedance and there's neglible current draw.
    Not sure what to do about it though. Any ideas?
    The same sort of thing happens if pinmode is used to designate a pin as an output pin--again, even if nothing is connected to it.
    This is a potential show stopper. This module is useless to me if I can't connect it to anything.
    As a workaround, is there some way to designate a pin as undefined again after having used pinmode to define it as either an input pin or an output pin?
    Well, setting the pinmode to OUTPUT and then digitalwriting it to LOW seems to help considerably--at least when it's not connected to anything.
    [Edit: Setting it to HIGH also helps similarly.]
    Anyhow, I'm relieved that the radio isn't the source of these power drain problems. This pinmode stuff is a bummer, but it looks like I can at least partially work around it.
    Thank's. I check this after I fixed the Radio.
    Actually, I have this board running. I measure a voltage of 0.13mV=6,6ยตA at the shunt with a simple sleep sketch. When I switch two pins into INPUT_PULLUP, then I measure 0.15mV==7,5ยตA.
    When I switch on the LED then I measure 12.75mV == 0,6375mA, One pin in OUTPUT_H1H0 mode. With LED off I measure 0.15mV==7,5ยตA.
    My MCU is nRF52832 QFAAB0 1615AX
    P.S.: I have no documentation about the board. When I measure the boards current, then I have an shunt factor of 22,5. I think calculating with 20 is ok.
    in that case, you need to set it as a floating input i think, like it's generally at reset.
    In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
    This should do the job..
    Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers.
    Ok. I have measured my Ebyte with the same sketch and in the ยตA range of my VC165 multimeter. Sleep current is 9.9ยตA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82โ‚ฌ)
    Should I add a DISCONNECTED mode to hwPinMode()?
    Sleep current is 9.9ยตA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode....
    Ah, maybe that's part of the difference. I was doing just:
    pinMode(ALPHA_PIN, INPUT)
    pinMode(BETA_PIN, OUTPUT)
    because that's how I would have done it on an Arduino. Should we instead always use INPUT_PULLUP and OUTPUT_H0H1 instead?
  • @NeverDie
    Should be
    According to NRF5 platform
    Thanks! Somehow didn't remember that.
    So, as suggested by @scalz what is some example code that can be used to "disconnect" the pin later?
  • @NeverDie
    He has not added that facility yet,i think he asked you if you wanted it adding to the code?
    Definitely!
    for unused pins, it should be floating, not pullup. set the pin register you need to 0x02.
    Something like that
    NRF_GPIO->PIN_CNF[ulPin] = 0x02;
    that will put pin in same state like it's on reset. Everything disabled/default, floating, with disconnect bit set.
    (see datasheet gpio).
    make sense to have it for input too.. i agree :simple_smile:
    Maybe add:
    OUTPUT_D0D1 -> Disconnected 0, Disconnected 1
    or similar to your list as another easy way to effectuate the disconnect?
    It finally makes sense now as to why there were all those "disconnected" choices among the various OUTPUT options. In my case, for controlling whether the solar panel is connected or disconnected, choosing OUTPUT_S0D1 works perfectly. ๐Ÿ™‚
    So, I suppose another way to disconnect an input pin would be to redefine it as an OUTPUT pin with a disconnect state, and then immediately put it into the disconnected state.
    Hmm just tried the latest commit and it is giving me 306ms for sleep(10000).
    Something not quite right.
    @rmtucker
    How are you measuring how long it's sleeping?
    @rmtucker
    Just using hwMillis() before and after sleep and subtracting one from the other.
    It was just reading + 250ms until @d00616 commited some changes a few hours ago.
  • something wrong in here:-
    // Calculate sleep time and prescaler
    		if (ms<512000) {
    			// prescaler 0, 30.517 ฮผs resolution -> max 512 s sleep
    			MY_HW_RTC->PRESCALER =  0;
    			// Set compare register to 1/30.517 ยตs to garantee event triggering
    			// A minimum of 2 ticks must be guaranteed
    			// (1000/32768)<<12 == 125
    			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);
    			MY_HW_RTC->CC[0] = max((ms / 125), 2);
    @rmtucker
    I thought so. The point being: doesn't millis stop when you're deep sleeping? Well, at least on an Arduino it does. Not sure what it does on the nRF5.
  • @NeverDie
    No the nrf5 has a rtc.(Real time Counter)
    It can even keep time while sleeping.(just found this out myself!).
    That is a great leap forward on the arduino.
  • Try it just print the time out then put it to sleep for a minute then print the time out again.
  • The problem must be this line but i don't speak nrf5.๐Ÿ˜ฆ
    			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);```
  • The only other thing it could be is the deletion of this line in the commit.
    nrf5_rtc_event_triggered = false
  • @d00616
    Should be:-
    MY_HW_RTC->CC[0] = max(((ms << 12) / 125), 2));
  • @d00616
    Just checked and it now returns 10002 for a sleep(10000).
    Much better after the above alteration.
    Epilog: I made the changes so that just prior to taking a measurement the sense pin is hwPinMode'd to an input pin, and then immediately after the measurement I disconnect it. Seems to be working, and without the usurious power drain I was experiencing previously. ๐Ÿ™‚
    Good news
    So what is the current usage now when sleeping?
    Good news
    About 6ua on this particular Ebyte nRF52832. I'm pretty sure it would be higher on my other Ebyte nRF52832, though I haven't measured it again. Haven't tested any additional ones as of yet.
    @rmtucker very nice work, thanks for locating the problem.
    It occurs because 12/125 will be evaluated before the bit shift. http://en.cppreference.com/w/c/language/operator_precedence for details.
    Should be:-
    Thank you. This was the result of merging some commits. I haven't seen I reversed that change. I had tested the code before merging some commits into one.
    Actually I check the result of sleep(511999) and sleep(512001). When it's finished I fix that in MySensors.
    What's the best name for this mode? DISCONNECTED or INPUT_DISCONNECTED. I prefer the first variant.
    I have to play a little bit with the port modes. Maybe it saves some current when the serial port pins are put into the disconnected mode while sleeping.
    Is fixed in development branch.
    https://github.com/mysensors/MySensors/pull/917
    agree too for the first one should be enough :simple_smile:
    yes, for lower power consumption, better disconnect pins which are not needed.
    it's the same for a simple 328p though (setting the right pin states).
    As a follow-up to rmtucker's line of inquiry, what is currently the shortest deep sleep that's supported? Is it one millisecond, or something else?
  • @NeverDie
    Theoretically it is 2 clock ticks at 32768khz so 0.000061035secs i think.
    But how long it takes to go into sleep mode and come out of sleep mode i am not sure.
    But of course the sleep function only allows millis.
    Why do you need this type of short sleeps?
    Sleep is for battery powered devices. A device that wakes up more than 1000 times in the second might be hard to drive with a battery.
    This is correct.
    It's simple to evaluate with micros() before and after a sleep().
    I haven't yet upgraded to the current version, so maybe this is moot (?), but the following code in a loop:
      digitalWrite(TEST_PIN,HIGH);
      sleep(100); // Sleeps for 100ms
      digitalWrite(TEST_PIN,LOW);
    holds the TEST_PIN first HIGH for 250ms and then LOW for 250ms. That means 150ms of sleep overhead, which seems like a lot.
    I measured the length of time the TEST_PIN is HIGH or LOW using an oscilloscope. Ran it on an Ebyte nRF52832.
    Nevermind. I just now upgraded to the current versions, and it seems to be fixed.
    So, with the current libraries and an Ebyte nRF52832 that's using its external crystal oscillator, I'm now measuring the sleep overhead as being 260us. I expect that may be even less if using the internal 32768Hz resonator.
    I tried measuring the sleep overhead with the Ebyte nRF52832 running on its internal resonator, and surprisingly it wasn't that much faster: it appears to be about 220us.
    Here's the test script:
    #define TEST_PIN 19  // (P0.19)
      hwPinMode(TEST_PIN, OUTPUT_H0H1);
      digitalWrite(TEST_PIN, LOW);
      sleep(1); // Sleeps for 1ms
    Here's the scope capture:
    Of course, this assumes (?) that the mcu sleeps for exactly 1ms, and during the extra 220us it is either ramping down or ramping up.
    BTW, I don't anticipate sleeping for a mere 1ms at a time. However, to get a good measurement of the overhead using the oscilliscope I had to set the sleep period that low.
    I can, however, well imagine having a use for sleep periods lasting 100ms.
    Anyhow, it's not academic, as the plan is to approximate the "listen-mode" of an RFM69, but using the nRF52832. For that to be power efficient, I need the mcu to wake-up and fall-asleep very, very fast. For comparison, an atmega328p can wake-up in 3.8usec.
    On page of the nRF52832 datasheet, it advertises:
    Fast wake-up using 64 MHz internal oscillator
    However, I'm not sure how to set that up. There's no menu check-box for that on the Arduino IDE tools menu like there is for the 32768Hz internal resonator. On the other hand, I'm not sure that it matters, because apparently the 64Mhz external crystal, which is what's slowing down the wake-up, is required to operate the radio.
    Here's the current drain through a 1-ohm resistor:
    i.e. 1mv=1ma.
    As you can see, there's a rather long tail before it finally falls asleep.
    Here is the same, but superimposed onto the TEST_PIN capture:
    Good news. It appears that DCDC is already implemented on the Ebyte nRF52832 and working automatically!
    Just for grins, I decided to measure the Tx time and current draw from sending a 13 byte payload in a packet, and I was happily surprised to see how low the current draw was:
    The yellow trace marks the start and stop of the packet transmission process from a software point of view, but the blue trace measures the current (as before 1mv=1ma). As you can see, the transmission current never seems to rise above 2.5ma. The only (?) explanation I can think of is that DCDC must be working. Right? Tx power is set to be 4dbm.
    It would be great if someone else would confirm/refute the measurement.
    I don't think it's possible, from the datasheet peak current is 7.7mA at +4dB with DCDC enabled with 3V power supply.
    Current gain from 3V=>1.7V DCDC conversion is already included in this measurement so you should not be able to go lower.
    How did you make your measurement across the resistor ?
    @Nca78
    You're right. It didn't ring true, so I setup some different capture hardware, and this time the image is a lot crisper:
    This time I powered it from a 3.3v supercap and with the 1 ohm resistor soldered securely onto a PCB, with the o-scope leads on either side of it.
    So, sadly, it doesn't look DCDC after all, because on this capture the peak is exceeding 20ma. ๐Ÿ˜ž
    It's interesting how lengthy (and energy intensive) the phase is that's just prior to the transmission itself. I presume that's mainly just the PLL coming up to speed? It looks as though the actual current expended in the prelude exceeds that of the actual Tx proper!
    I'm guessing that in the earlier scope capture, the probe must have slipped into 10x mode, because the shape is similar, just proportionately reduced by roughly that factor.
    BTW, I assembled my third board now, and it sleeps at about 9.9ua. The first one sleeps at about 6ua, and the second at about 9ua. It would be interesting to know why the first board is so much less, but it seems that about 9-10ua is the more typical number. That also seems to agree with @d00616 's measurements.
    Interestingly enough, you can put the radio into receive mode and then sleep the mcu with the radio still in receive mode. Here's a screenshot of current consumption while receiving, where I alternate between leaving the mcu active or sleeping it (each for duration of 500ms). In-between, I sleep everything (both radio and mcu) for 1 second:
    Here's the mode that I'm most interested in: Putting the radio into Rx for about 1ms per 100ms interval to listen for remote commands. The rest of the time everthing (both radio and mcu) are in deep sleep waiting for the RTC to wake them up.
    Here's a close-up of the current drawn during that roughly 1ms interval:
    I ran this just now, and my solar setup can easily handle this load during the daytime, even from deep indoors far from the windows. This was the scenario that really stressed the RFM69+atmega328p combo when I tried doing it using the RFM69's listen mode. I'll see tonight how the 10F supercap handles the load without any solar assist. ๐Ÿ™‚
    Because of the nRF52839's 2Mbps datarate, I can probably cut the listen window down substantially from 1ms to much less (much less than would be possible with an RFM69, due to its maximum of 300kbps datarate), but for ease of programming I'm starting with this.
    When you take a look into the PPI section, you are able to let the CPU sleep until a radio packet is received. With PPI, the listen mode can be activated and deactivated without CPU interaction.
    The nRF5 MCUs are able to to a lot of things without waking up the CPU. That's a really cool feature.
    Sounds like it has potential. Any demo code for this? The datasheet seems a bit sketchy.
    These are some snippets of the radio code. There are fully useable PPI and some predefined. For fully useable PPI into the EEP register, you put the address of an EVENT register and in the TEP register, you put the pointer to an TASK register.
       /** Configure PPI (Programmable peripheral interconnect) */
        // Start timer on END event
        NRF_PPI->CH[NRF5_ESB_PPI_TIMER_START].EEP = (uint32_t)&NRF_RADIO->EVENTS_END;
        NRF_PPI->CH[NRF5_ESB_PPI_TIMER_START].TEP = (uint32_t)&NRF5_RADIO_TIMER->TASKS_START;
        // Disable Radio after CC[0]
        NRF_PPI->CH[NRF5_ESB_PPI_TIMER_RADIO_DISABLE].EEP = (uint32_t)&NRF5_RADIO_TIMER->EVENTS_COMPARE[0];
        NRF_PPI->CH[NRF5_ESB_PPI_TIMER_RADIO_DISABLE].TEP = (uint32_t)&NRF_RADIO->TASKS_DISABLE;
        // Set PPI
         NRF_PPI->CHENSET = NRF5_ESB_PPI_BITS;
      // Clear PPI
        NRF_PPI->CHENCLR = NRF5_ESB_PPI_BITS;
    Then you have to enable or disable the register. It could be necessary to reset the events. You can use the NRF_RESET_EVENT macro to do this job.
     NRF_RESET_EVENT(NRF5_RADIO_TIMER->EVENTS_COMPARE[0]);
    I have a brute force version of "listen mode" working using just the libraries, but I have to re-initialize the radio after each cycle because it appears to lose its settings every time I sleep it.
    Anyway, finding a way to add DCDC mode to these modules will probably have the biggest near-term impact on current consumption. That said, I'm sure plenty of energy savings can also be found by honing the code.
    Actually, even just sleeping the MCU with a simple command like:
    sleep(100);
    is apparently enough to require a re-init of the radio afterward. Not sure why that would be.
    Comparing Figures 169 and 170 in the nRF52832 datasheet, it looks as though simply adding two inductors in series between DCC and DEC4 should be all that's needed to provide the needed hardware support for DC/DC. Looks as though the 10uH inductor also needs to be able to support a minimum of 50ma, according to the BOM (Table 145).
    So, is it as simple as that together with enabling register DCDCEN? Or, is there anything more to it?
    Yes. This is like that. I use 2 inductors (better) in serie. Why more complicated ๐Ÿ˜‰
    sleep(100);
    sleep() deinitializes the transport with transportDisable(). This results in power down the radio.
    At the moment I review the ESB code. I think the nRF5 is 12-13ยตs after an nRF24 in RX mode and 432ยตs before an nRF24 in TX. This can result in unstable connections when debug messages are disabled.
    Sort-of working. Here's a screen shot with the DC/DC modification. Compare to the earlier one above:
    Probably non-optimal placement of the inductors: between the DCC and DEC4 pins on my breakout board for the nRF52832.
    This is reason enough to do an new version of the breakout for the Ebyte module to improve the inductor positioning.
    Here's the enable code:
    If it's this easy, I'm just surprised that the module makers haven't included it. The difference in build cost is de minimus, but the difference in delivered value is huge.
    Also, it sounds like I'll have to write a variant of sleep that sleeps just the MPU while leaving the radio in receive mode. That's an easy win to improve the current consumption.
    Good news! I went back and re-rechecked using an un-modified Ebyte module, and, indeed, this time I'm sure that the DCDC inductors are already on it! What follows is the proof. Here is the current drawn when the above DCDCEN is enabled on an unmodified Ebyte module:
    Now, here is the current drawn with the exact same script on the exact same unmodified Ebyte module, but with the DCDCEN line of code commented out:
    QED.
    As you can see, the savings in current consumption are considerable with the DCDC enabled!
    [Edit: although looking at it again, the timescale seems way off. Argh. Something still isn't right.]
  • 44
  • 29
