CNC PCB milling
    Well, humbug! I'm all out. Maybe tomorrow I'll buy the red threadlocker, which is even stronger.
    @rmtucker Which g-code sender is it that you like best?
  • @neverdie, or anyone else that can answer this with some logic, just because the topic came up. Why does Loctite red come in a blue container and loctite blue come in a red container?
    Made in China?
    Probably historical reasons.
  • @yveaux LOL
    Probably a committee decision. Half liked red, and the other half liked blue. They were deadlocked, and this was their compromise decision. 😆
  • @neverdie for the touch sensing you should use A5 connector from the headers, connecting it to the actual tool (bit), then a gnd (header's bottom row) connecting to the pcb's surface.
    for the tool connection I use crocodile clamps.
    screws: you did not fasten them enough. at the beginning I also missed some endpoints, but since I put the cnc together, I had no issue with any of my screws.
  • @andrew for first go for a single touch probing instead of a whole autoleveling session.
    just for testing purposes, start the touch probing from a higher position and touch the gnd wire directly to the spindle's tool to see whether it stops or not. if not, you should stop it manually from the gui, otherwise it could break the tool.
    if everything works well (so you proved that you connections to the pins and the belonging settings are ok), then you can run the simple touch probes or the autoleveling as well.
    Is anyone using a threadlocker on the set screws to keep this from happening?
    For one that will probably buy the same CNC could you document how you solve this with a picture?
    I am not using a g-code sender,i am using mach3.
    But i have just started playing with grbl and bCNC seems to do most things.
  • @neverdie one more think I forgot to mention: after I assembled the cnc, I used a little wd40 across each axis and moved each from one end to another. it helped for smooth and "barrier-free" movements.
    Does using A5 somehow automagically just work, or does it require additional software configuration?
    @sundberg84 said in CNC PCB milling:
    OK, here is what I'm doing in pictures. I'm applying blue 242 Loctite:
    to the threads of the 4 set screws on the coupler:
    That should keep them from loosening up after they are screwed into position. Note, you have at most 10 minutes of working time before it sets.
    I applied it to the motor set screws first and let it set:
    Note: I used rare earth magnets to help secure the set screw to the allen wrench. That insures that the set screw doesn't drop off and disappear somewhere on the floor. Works great.
    The couplers are made from anodized aluminum, so I'm not sure how well the loctite will work on them. However, I think it will still work, as the set screws themselves are steel.
    I found an intro to bCNC:
    Shapeoko 3 bCNC Beginner Tutorial – 08:40
    — BluegrassRC
    It looks easy and intuitive, so I'll probably go with that.
    As usual, it's the software that has the best tutorial that wins.
  • @neverdie I used to use nail varnish on threads as it was just as effective, even though it annoyed the partner whose nail varnish it was. It is not the bond between the metals which is that important, it is adding resistance between the threads to prevent unscrewing, were it to completely bond, you would shear the bolt before it was removed, which is a whole lot of trouble....
    Does nail varnish cure anaerobically in the presence of metal ions? That seems to be much of the theory behind thread lockers.
    I thought nail varnish cured by evaporation.
    In any case, I wiped off the excess loctite, because it might never dry (or, at least, take a long while to do so).
    I think the loctite is likely to work, since Andrew had success without anything but torquing it down hard. On the other hand, maybe his is threaded differently than what came in my kit.
    it should work by default
  • @neverdie Torquing down correctly normally prevents threads unwinding, but have seen bolts come loose with vibration on occasion. Only ever used loctite or equivalent on cylinder head bolts, particularly alloy heads, it never actually sets solid and is oil etc resistant.
    Although lacquer or plastic paints do harden, as a plastic filler between the threads, it increases contact friction, yet will shear to permit removal of the bolt when necessary. Typical threads do not fully engage metal to metal, the clearance is essential to allow the nut to be run on the bolt.
    Loctite is fine if you have it already, nail varnish works fine for me in non oily scenarios.
    I've retried it now, and so far it's not coming lose. 🙂
    I added some machine oil on the rods and screws, and that seems to have helped. Before that, there were some areas where the screw rod on the y-axis was binding, but not now.
    Are you guys running bCNC under Linux? Because installing it under Windows is proving to be challenging....
  • @neverdie yep, I've a linux vm for flatcam and bcnc.
  • @neverdie
    Linux for me too.Never used windows in years☺
    Here's the machine oil I'm using. As you can tell from the manufacturer, it's meant for sewing machines and similar:
    Well, now that I found this pulldown in Chilipeppr, I might stick with it a while longer:
    The strange thing is that the Chilipeppr demo seems to mill at z=0.000. So, if I were to try to etch the pattern for real, I would have to "zero" z at an actual z value of, say, z=-0.5 or something (whatever depth I wanted it to etch at).
    Is that normal?
    Anyhow, I've been through multiple trial iterations with no bit installed and with the spindle disabled, and during all that the X and Y couplers have not come loose. So, I think that the Locktite has lived up to its name and solved the problem I was having earlier. 🙂
    Is that normal?
    yes, the chilipeppr demo works like this. but keep in mind, that for "real" isolation milling, the milling depth which you used during the g code generation will be calculate from the relative z zero, so in that case you really have to set z0 to the pcb surface.
    Disaster. Out of the blue, it suddenly just stopped working. Now I can't get it to spin the spindle or move in any x, y, or z direction. Gcode appears to be sent to it, and it does respond to me if I send it a '$" through the Chilipeppr console window. Just no movement whatsoever.
    I removed the heatsinks, as a possible culprit, but still no go.
    Suggestions on how to diagnose it?
    I found the problem: bad power supply brick. It is supplying no voltage at all. 😞
    The power brick that came as part of the kit says it is rated at 24v dc 5.62amp. Is that enough, or should I get something that can do more amps?
  • @neverdie oh 😞 if you have a chance to power the cnc from a variable current power supply, then check the current it drains by starting from low to higher current. if it eats lot, maybe there is a short somewhere. you could also try to open the power supply and find a fuse.
    good luck!
  • @neverdie I've a PS with the same parameters. it is enough.
    I don't have much optimism that the cheap-ass power supply that came with the kit can be repaired (well, not by me anyway).
    I ordered a 6amp one as a replacement, just to have a little more headroom:
    https://www.amazon.com/gp/product/B01AJQ9G2C/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    It may turn out to be cheap-ass also, but I can get it tomorrow, so I'm rolling the dice.
    If that burns out too, then there's this one, which looks more beefy and would be my first choice, but will take a week to receive it:
    https://www.amazon.com/gp/product/B01J19G00E/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Dang. I cancelled the order, as I'm not sure whether its 5.5mmx2.1mm barrel jack will fit or whether a 5.5mm x2.5mm is required.
    Looks as though the barrel on the woodpeck is 2.5mm inside diameter....
    Powering it from a variable power supply, it apparently works. Here's the etching on a piece of plywood:
    I watched the current being drawn, and it appeared to always be below 1 amp. The variable power supply can supply up to 5 amps, so no problem there as far as I can see.
    The etching that it did was a bit weird: deep cuts in the inside diameter of the P's, but only faint cuts just outside. The R was barely even touched at all. The surface doesn't feel sufficiently non-flat to account for that.
    Ideas as to what's going wrong there?
    Here is a contextual photo:
    The clamps are holding the board very securely.
    After thinking about it, my hypothesis is that the feedrate is too high. I have it set to 1 in ChilliPeppr. I think maybe it comes down rapidly to the programmed height, but if it meets resistance then it skips some motor steps. Since it's open loop, it doesn't know. Then it dwells at that depth until it picks up the bit and relocates. I'll try a slower feedrate and see if it makes a difference.
    Maybe the bit is too dull as well. It's one of the freebies that came with the kit.
    Also, what is the preferred way to tighten the ER11 chuck? So far, I did it just by hand, which seems to have been good enough. However, maybe a better practice is to give it a 1/4 turn further tightening using wrenches after that? How are others here approaching that?
  • @neverdie for er11 fastening you should use two wrenches.
    if you loose steps during the milling, then with the given feed rate / depth / spindle speed combination the cnc / spindle / steppers are not powerful enough.
    if you wood milling depth is not constant then:
    • the wood is not flat
    • the cnc bad is not flat
    • the cnc x axis is not horizontal
    my availability for the next couple of days will be quite limited, so I wish you good luck for experiencing the router and for the first PCBs!
    Also, what is the preferred way to tighten the ER11 chuck? So far, I did it just by hand, which seems to have been good enough. However, maybe a better way is to give it a 1/4 turn further tightening using wrenches after that? How are others here approaching that?
    +1 for the wrench, mostly because of vibrations that could unscrew it. No need to pull a muscle on it as it is tapered and has big contact surface
  • @neverdie If it is anyway similar to a Router, it should have a locking pin to hold the spindle, or a second nut against which you tighten the collet. Do not overtighten, just enough to bite the shaft, otherwise you either damage the shaft or more seriously shatter the collet, it should be just enough to be a firm clamp to ensure grip, the collet will do the rest.
    Not a user of these CNCs but I would guess the same principles apply... Just my 2c...
    @andrew
    Have a Merry Christmas!
    Also, I'm not going to dwell on etching wood . It was just my first attempt at etching anything, and I thought wood might be a little softer.
    I suppose the next step is to have a go at auto-leveling on a PCB rather than perfect the machine's etching of plywood. Indeed, PCB's may turn out to be easier, as the resistance to downward motion (especially after auto-levelling) should be more uniform.
    Meh, I think I know what happened now. If the z-axis ever skips a step in downward motion--for whatever reason--then the rest of the etching is screwed from that point forward, because the higher height then becomes the new "zero" for the entire remainder of the etching since the depth control is completely open loop. So, the first spot in the sequence that isn't at proper depth would be where the error occurred, creating a persistence of the error from that point forward in the etching sequence.
  • @neverdie If the material is parallel to the cutting plane, the cut depth should be constant. Might I suggest doing same experiment using auto-level.... Wood is easier on the bits, plywood less so but still less abrasive than FR4...
    Is there an auto-level that works on wood? I thought it assumed a conductive surface, like on a blank copper PCB, to facilitate the auto-leveling mapping process, so that it knows when contact is made and therefore the height at each touch point.
  • @neverdie Tinfoil?
  • @neverdie I should explain my thinking... I do not think your wood experiment made sense. You assume your sensors and the wood are parallel, this need not be true. Plywood is generally less than 0.3mm out of true, even if you could zero the 4 corners with foil or similar it would give you a plane on which to see if the original trial was misleading.
    @neverdie Tinfoil?
    You get an A+ for creative thinking. I suppose extra wide foil tape might work.
  • @neverdie I was thinking kitchen foil pressed flat as possible to the block surface, whatever works...
    This is a good video for how to auto level in ChiliPeppr:
    Auto-Level a PCB in ChiliPeppr – 21:33
    — John Lauer
    So, with that as inspiration, I plan to connect the probe to A5 on the woodpecker, and the PCB surface to GND. He soldered his ground wire to the PCB, so I guess I'll do the same, at least for now.
    I'll use tape to secure the PCB to the sacrificial board underneath.
    I've confirmed that A5 and GND work correctly for the auto-leveling.
    However, Chillipeppr strangely defaults to probe a much larger area than is needed for auto-leveling, so I need to figure out how to reduce the upper and right-hand boundaries of the probing area:
    Otherwise, it runs the risk of not even hitting the PCB if it gets too far out.
    Nailed it!
    Well, further progress will have to wait until I can move the CNC to the garage or outdoors, so that I don't fill the house with toxic fiberglass particles (Thank you @executivul for pointing that out, and sorry I butchered your name earlier. I didn't mean to.)
  • @neverdie no problem, I got used to it since I'm using such a weird nickname, the good part is it's always free to register on any forum so all I have to remember is the pass.
    I'm really excited about wet milling, it's freezing down here and not having to have windows open for the modded vacuum cleaner it's a treat. The trick is to use a solution with higher surface tension then water, but not too thick or it will gather around the mill as a small tornado and start splashing everywhere. You can use soap, shampoo, dishwash, carwash, etc. Start at 1:1 water mix and add more water if it tends to gather around the spinning bit. It's better to pour it slowly on the board and spread with your finger (use a syringe) than to spray it as not to make foam. Also try using a clear shampoo to better see what's milling below the liquid. A piece of flat plastic, acrylic, lexan, plexiglas, whatever, doublesided taped to the wood spoilboard is a must unless you leave a large margin between the actual milling and pcb edge liquid will spill and will swell the wood. Have a roll of paper sheets nearby and a garbage bag open. Always use glasses when operating the machine. I made a "fence" out of some polycarbonate sheet to contain any eventual splashes which occur mostly when drilling through the board, normal engraving behaves and doesn't splash at all.
    Given that the goal is to get 6mil isolatioin routing, what cutting depth should I set in flatcam? 0.05mm?
  • @neverdie I have been kind of following this topic, but don't have a CNC mill, but wouldn't the thickness of the copper clad on the board be your depth?
    Makes sense to me. Well, doing that it would be 0.01mm. But since this isn't a perfect process, it likely needs some added depth to guarantee it's removed. The effective tool width gets wider the deeper you cut, so in some sense I suppose there's that as an added constraint on how deep you can cut before it becomes more than 6 mil isolation. We could try to arrive at an answer analytically from first principles only, but I thought it might be easier to just ask what depth others who are doing this successfully are using.
  • @neverdie See what depth you need to go with that bit to get 6 mil routing, and that will be your max. I would think that would be more than 0.01mm, but I haven't seen your bit, so I don't know.
  • @neverdie you should use one depth, regardless of the trace width. for me 0.05mm worked, see my shared settings above. you should decide the isolation width, this is the main property for the given config, but you should stick for one milling depth only. if the requires isolation width is bigger than the tool width at a given depth, then it will use multiple rounds to reach the given width, but still, with one milling depth.
    I'm stuck. I converted my gerber to gcode using flatcam, and imported it into Chilipeppr:
    On the one hand, it seems to have gotten the dimensioning right, as indicated by the Y1.48in and X1.43in. However, the grid that it's showing is out of sync with that. Each square on the grid is 5mm. It's as though Chilipeppr thinks the entire design fits easily inside a 5mm square, and so when I attempt to do the autoleveling, it comes out completely wrong.
    you can mark the zero point in the pcb designer tool before you export the gergbel, or in flatcam, during the post processing. if you do not define it, then maybe the given zero point could have some "offset" to the effective design. it is not problem, but it could make your life easier if your zero is e.g. at the pcb's corner.
    if you don't want to update the files, then in chilipeppr you can update the probe area to not start from 0,0 but from a given offset.
    Thanks! I don't know why, but somehow that fixed the problem:
    I found these copper clad boards that seem to be made out of bakelite (?) rather than fiberglass. So, hopefully not the same level of toxic dust concern as with FR4's.
    I double sided taped the non-copper side:
    and soldered a ground wire on the copper clad side:
    Now I'm ready for autoleveling and then my first PCB etch.
    Here are the results of the autoleveling:
    For some reason it's hard to read some of the numbers.
  • @neverdie It looks like everything in the top right corner is above the level bed surface. which puts it above the grid that is shown. Looks like the bed is tilted.
    @dbemowsk Fortunately the auto-leveling should render it a moot issue.
    LOL, except that unfortunately it did not:
    OK, my bad. I hadn't sent the auto-leveled g-code to the workspace (I had thought this would be done automatically, but no), so this picture shows what would happen without auto-leveling.
    I've made the change and am now re-running the job with the auto-leveled g-code.
  • @neverdie Looks about on par with your final matrix, only it is following the grid and not the auto leveling values.
    So, I re-ran the job over the same area with the g-code modified by auto-leveling, and this time I got a better result:
    So, now I'll try it on a fresh area of the PCB, after doing a new auto-leveling.
    Judging from the looks of the photo directly above though, it looks like quite a bit of copper wasn't removed where it needed to be. I'm guessing I will need to:
    1. etch to a deeper depth; and/or,
    2. use a finer mesh for auto-leveling; and/or
    3. ???
  • Etch 0.1mm. The groove between tracks also helps with soldering. I currently use 0.1mm and even 0.15 when in a hurry.
  • @neverdie
    The last photo looks like the tip is missing from the cutter?
    @rmtucker Good catch! Here it is in contrast to a new one:
    I'll replace it with the new one.
  • @neverdie
    Just for future reference i would use a duff cutter for autolevelling then change to a good cutter to cut the job after resetting the z0.
    It is so easy to smash the front of an engraving cutter when using this method for autolevelling as the machine takes a little time to stop after touching the pcb.
    Just my advice anyway☺
    What's a "duff cutter"? Did you mean "dull cutter"?
  • @neverdie
    Yes sorry a used one😉
    @rmtucker Thanks! Makes sense to me. I'll do it that way.
    Argh. I ran the job, and the first cut went great. All subsequent cuts though didn't penetrate the surface:
    Afterward, when I checked the zero on z, I found that it was off by 0.049. That explains it, since the cut-depth was 0.05.
    I'll re-zero and try running the same job again.
    That made a much better result:
    It corresponds to this as the actual PCB:
    However, what's telling is that it obliterated the traces on either side of a 6 mil separation:
    This is how it should look instead:
    So, what happened?
    My current hypothesis: the first cutting sheared 0.049mm off the tip of the blade, making it wider than it should be. Then, after re-zeroing, the wider blade cut too wide as it cut the traces for the solder jumper.
    Is that reasonable, or is there a better hypothesis?
    If it's true, then what do I do about it? Perhaps use a higher quality bit than the freebie that came with the kit?
    Actually, I'm not even sure what the dimensions were on the freebie. It wasn't labeled. Perhaps it was too wide to begin with.
    Well, to explore this more, I think I'll create a test board consisting purely of a few solder jumpers. That way I can put the focus directly on the 6 mil issue and won't be wasting time on etching that's unrelated to that.
    Doing just a single solder jumper, with the same bit, and autoleveling every 1mm, the result is:
    which is pretty close, actually. Looks like maybe the bit is a little too wide, or else there's runout which is making it appear wider than it actually is.
    I'll try it with a fresh bit next and see if it improves.
    Well, that went horribly:
    and I have no idea why:
    I tried again with the same bit, after removing and re-inserting it. Got a better result this time:
    Unless someone has suggestions on how to tweak this, I think that may represent approximately the best this CNC can do.
    In truth, though, I think it may be a flawed gcode algorithm:
    Instead of two separate cutting passes through the center section, one would do, and would produce a better result.
    How to tweak flatcam to do that? I probably haven't configured flatcam correctly. i.e. user error.
    Maybe this is where your problem lies.
    How did you write the g-code without knowing?
    Too many variables here wich could give you these results.
    The bigger tracks,Are they measuring the correct width with a vernier after you have cut them?
    I assumed the width on the freebies was 0.1mm, because that's what was advertised on Jack's posting for the machine. However, I don't know how to verify that, so the uncertainty comes in whether Jack actually delivered what was advertised or slipped in something else. I chose to give Jack the benefit of the doubt.
    If I were to enter a wider tool diameter of 0.155mm (instead of 0.1mm) into flatcam, I think I can coax flatcam into generating better g-code for this situation. I'll do that and then post the results.
    @neverdie have you verified isolation between the parts? The cut is good?
    No improvement really:
    I think this means that the effective cutting width is actually greater than that, either from the bit itself or from runout or from who knows what else.
    Probably nothing I can do about runout, except buy a different/better motor.
    I'll have to wait for the etching bits from Aliexpress to try what is maybe (?) a proper 0.1mm etching bit. Like I say, I have no way of judging whether the freebies that came with the kit really are that or not, as I have nothing to compare.
    By the way, my reason for picking the 0.155mm tool width in flat cam is that it produces this g-code path, which should have preserved more of the copper pad where it was being obliterated:
  • Yes you can. Get the gcode I've posted above, adjust for your feedrate, autolevel it in cp and give it a go. Really curious about the results.
    @mfalkvidd said in CNC PCB milling:
    Good question. I have doubts about how well I could measure it using calipers. However, maybe if I put the board onto a flatbed optical scanner, which would have a known DPI, I could measure the actual cut width with reasonable accuracy. I haven't done that yet, though.
  • @NeverDie Using traces one next to other at known distance you can determine the exact width of the engraving for a wanted depth of cut. I know you don't want to mess with gcode, but it's simpler than you think. Please look at the code: you have init (g92 for setting zero, g21 for mm, etc) you set the feedrate in mm/sec, you have a few movements (g0) a "dwell" to pierce the copper for 0.5seconds (g4) then some cutting moves (g1) all have absolute cartesian coordinates. Eg you're at (0,0) then g1 x0y10 means travel at (0,10) move only the y axis 10mm to the back of the machine, g1 x0.1y10 means move 0.1mm to the right, etc.
    You have the whole script posted above, set your feedrate the same as you set in flatcam, and set the depth in the first z-0.1mm line, maybe you want 0.05mm for eg. After editing the file run it in cp with autoleveling and post the results.
    @mfalkvidd
    Oh, sorry, I realize now you were asking something else. No, I haven't verified that yet. This is all just early attempts. Good question though.
    OK, I think I see what you mean. In other words, when the two cuts just barely bleed into one another, then one can deduce the width of the cut as being the absolute width between the absolute coordinates of the lines it's trying to cut. Makes sense. I'll give it a try. Thanks for the suggestion. 🙂
    Good news. I just received my model 2 bits from Aliexpress. Model 2 is 20 degrees with a 0.1mm tip. I compare it here to the freebie bits from Jack:
    Model 2 is on the right, and Jack is on the left. Looks like the angle is wider on Jack, which I presume (?) means that the tip is wider than 0.1mm.
    Well, I thought the model 20 would do better, but it actually did worse:
    It does seem to cut smoother lines though.
    I also received model 6, which is the variety pack that includes a 10 degree bit with a 0.1mm angle. Should I give it a try? I've read that they're prone to create flying shrapnel. Anyone here have experience with them? If it doesn't blow up, it might be just the ticket for doing this cut.
    I just now tried the Model 10:
    Rougher edges, but it didn't decimate the pads as badly as the model 20.
    @neverdie sorry for being unclear. I was thinking of just using a multimeter in continuity mode to verify that there is no connection between parts that should have no connection.
  • 20
  • 14
