  3. Humidity / Temperature Sensor
dht22temphumidity
11 Posts 7 Posters 11.2k Views 5 Watching
  • T
    TimO
    I've build a sensor to measure humidity and temperature in my living room. It is now working for about 7 weeks.
    The sensor consists of the following components:
    • DHT22 Hum/Temp Sensor
    • MCP 1702 LDO Regulator (3.3V)
    • Atmega328P-PU PDIP-28
    • holder for batteries (4 x AAA)
    • NRF24L01+
    Here are the schematics:
    And here is a screenshot from my OpenHab-View:
    (I'm logging the last update to ensure the sensor is still alive)
    The DHT22 needs at least 3 V to operate stable, so I thought about using a booster or a regulator and took the regulator.
    Currently I'm using rechargeable AAA, which will be switched soon, as the sensor is working fine. The Voltage has dropped 0,1 V (from 5.3V to 5.2V) in 7 weeks and the AAAs were only precharged. My multimeter is able to measure the current, but in case of this sensor it is to low, I need a better multimeter.
    The Atmega328p is running with 8 MHz internal clock and brown out detection is disabled.
    Finally the sketch:
    https://codebender.cc/sketch:67176
    • D
      D
      doesel33
      A little mistake in your schematic: R2 must be 4,7k!
      • T
        TimO
        @doesel33: You're right, thanks!
        • gaduG
          gaduG
          gadu
          Cool!
          Perhaps a noob question, but how do you program the Atmega?
          • daulagariD
            daulagariD
            daulagari
            Why would you switch the batteries?
            5.2V / 4 = 1,3V so still quite full.
            These batteries are low-leakage batteries so provided the initial charge is fine and current consumption the lifespan should be good and at least 50% of that of good alkaline batteries
            • T
              TimO
              @gadu I'm using a MySmartUSB MK3.
              @daulagari I'm using rechargeable ones as long as I'm not sure how good my device is working.
              • Ivan ZI
                Ivan ZI
                Ivan Z
                wrote on last edited by Ivan Z
                I power DHT22 from arduino pin. It help make economy battery. When controller sleep, power pin set to low.
                If using 3.3 power - no needed R2
                If you use CR123A accomulator. You will not need Regulator and the device will be smaller
                • T
                  TimO
                  Does the DHT22 work with 3v? I thought it needs at least 3.3v. I will test that!
                  • MagiskeM
                    MagiskeM
                    Magiske
                    wrote on last edited by Magiske
                    Can't remember the specs. "Normally" 3.3v is something like 3.0-3.6v..
                    Just did the google thingy.. 3v-5v:)
                    • Ivan ZI
                      Ivan ZI
                      Ivan Z
                      My devices
                      • GizMoCuzG
                        GizMoCuzG
                        GizMoCuz
                        I think the comment in the routine
                        void measureBattery() {
                        // R1 = 1MOhm, R2 = 220 kOhm
                        Should be
                        // R3 = 1MOhm, R2 = 220 kOhm
                        (R3)
                        Is it possible to add (comment out) some lines how to calculate the battery percentage and send this via gw.sendBatteryLevel (batteryPcnt)
                        Great sketch!
