@Michael-Link I have been out of touch with MySensors for some time now and looking to slowly get back into it. I created this and a few other boards back in 2018 All of the GERBER files for this are in the "Design Files" tab. Those you should be able to send to JLC PCB or one of the other fab houses and have some made. This was designed to be used with 2 other boards that I designed. There was the processor board and the power supply board. The processor board was designed in a way that I could use a couple different switch boards. This one and a universal multi-switch board that had multiple configurations. If you look here you will see my other boards.
I want to build this project. But I don't need to power it by batteries. Has anyone the circuit diagram (in FrizIng?)
I have also the problem, that I can't see, on the breadboard picture of this project where the red wire from the battery ends after the connection to the Arduino?
Does it go to the FET and the R7?
Can anyone help me?
