💬 Aeos : a NRF52 versatile, up to 9in1, device
  • Hero Member
    Looks great! By when do you expect it will be ready to try and no longer a work-in-progress? Hours, days, weeks, months, or years?
  • Hardware Contributor
    @NeverDie
    thx!
    i think a few weeks max, not month 😉
    the time for getting the new revision (4layers custom IFA), so i can compare them. But so far so good 🙂 working fine, can't wait to get the the new rev.
    In the mean time, i'll also ask for a pcba quotation in case, for 1) basic circuit board only 2) Enhanced with sensors.
    Now, you know our current favorite setup..Halo, Aeos, a bit of rfm.. + a few others goodies..
  • @scalz Wow, that looks really exciting. I guess this explains why you have been so quite, you have been very busy.
    @alexsh1
    no i'm using Raytac MDBT42Q for proto and rev1. And the rev2 (lol), no module, it is directly using the ic.
    To clarify a bit why there are two revisions, i prefer to be transparent 😉 And i'm interested in your feedbacks!
    I won't talk about the prototype which has no sensors onboard. I designed revision 1, because i wanted to have sensors onboard and to have choice during assembly.
    I was curious to know the range of these modules. Made two different boards to compare layout. Followed the guidelines, tried to optimize gnd plane etc..
    Simple test was :
    • chip antenna not big range. Interesting i could cover almost the house, but at some spots i lost a few packets. not enough acceptable for me, or that depends when I would place it.
      Ok let's verify what i'm thinking.
      Unsoldered the chip antenna, and soldered a 31mm monopole antenna in place. Even if it wouldn't get so well tuned because of the hack, bingo, i almost doubled my range.
      Grrr, but the board is sexy like that. Ok, why leaving it then 🙂
    • So i designed revision 2, for a better RF version. But it's a different layout, with more pinouts. I don't think that will be a problem on my side to use an adapter 1.27mm to 2.54 for reprogramming etc.. especially when there will be some OTA feature
    Both boards have their pros and cons, so i keep both, that will depend on my usecases.
  • @scalz OK, I'll just want to see the V.2 in this case
  • Hero Member
    What I especially like is the small size: 33x33mm. By comparison, Nordic's 52 Thingy is ginormous.
    Do OTA sketch uploads work? That would be another very nice asset for anyone who wants to play around with it.
    Wow again, this will make a pretty impressive platform for multi sensors and/or for advanced sensors. Microphone is a great addition for that with the processing power available.
    You should make a Bluetooth version of that with a half baked smartphone app, with good marketing on kickstarter you can get rich 😄
    As you are usually obsessed with the extra uA to trim, I'm a bit surprised with your choice of hall sensor, did you miss the TI DRV5032 ? It costs peanuts and uses just 1/3 of the current compared to the Honeywell you have chosen.
    @NeverDie
    same here 🙂
    OTA, with ble or not, in MySensors is not done yet. But i'm not playing alone with Aeos 😉
    @Nca78
    thx! Yep, that would be a lot of fun! don't tempt me too much with things like that! For the moment project is in progress, let's see if i feel there are interests, and if my RF board will be ok too but i have good hope. Of course, i'll do a simple mobile app for fun, asap!
    Lol, you got me! I missed this nice TI ref, you're right, thx 👍 They are same footprints, so not a problem.
    Also, with Aeos main board or the extension, it is possible to use a reed switch instead, and get no power consumption in both states (i've another project, and proto is working ok, will show this soon!, ).
    @scalz yes I have done the thing with the normally opened + normally closed switch for my entry door and after over 1 year voltage drop is only minimal on a Chinese CR2032. But I'm not a huge fan a the reed switch as they break too easily especially the NO+NC versions with 2 pins on the same side.
    For the hall switch it seems it's new, Honeywell has to update it's docs about having the lowest power consumption 😄
    @Nca78
    i agree. reed switch need some care during assembly 😉 that's why i added hall effect.
    yep, honeywell aren't the lowest power consumption anymore, 1.8 still not so bad. Hopefully, the better TI sensor is footprint compatible. Just need to order some.
  • Hero Member
    As a future challenge for somebody, do you think a feature reduced version could be size reduced to a 23x23mm PCB? That's the size of the am612 PIR lens, and it would be a lot of fun to have a functioning wireless PIR sensor that's at the limit of super tiny.
  • Hero Member
    Looks as though 23mmx24.5mm, not 23mmx23mm, might (?) be the limit on PCB size because of the bore-holes for attaching the PIR lens.
    @NeverDie
    hehe 🙂
    For PIR and battery, i have a preference for the bigger CR2450.
    I will use CR2032 for simple low power sensors everywhere i need variants of them, and they will all look the same shape.
    Then, I had to choose a coincell holder. regarding thickness, and size etc.
    And the most important point for the board : the antenna.
    PIR isn't a wearable (i exagerate, but wearable meaning short range), or a simple sensor reporting x min.
    Which antenna vs range ? Also, the clearance of the antenna (nothing under it..). GND plane size..
    So the coincell holder and the antenna requirements almost fix the pcb size.
    I could choose a smaller but less efficient antenna, which would need more tuning, or could be prone to detuning regarding different enclosure and usecases. That could reduce the board size of a few mm.
    Instead i've decided to bet on a more efficient antenna, so less debug (only have a spectrum analyzer..).
    I thought : aestetically or discretion, of course I didn't want 40x40 board, but does it really matter to me if my board is 25x30 or 33x33 ?? Am i doing the contest of the smallest wearable PIR ? 🙂
    (saying this because, indeed, i previously designed a smaller board for PIR, but chip antenna, smd PIR+dedicated lens=more expensive, and there wasn't pinheaders, just programming pads. less versatile. Whereas, I can hack Aeos and extend it).
    That plus some others variables, made me choose for this shape..
  • Hero Member
    @scalz
    There is, of course, no single perfect solution for everything. Once you start pushing the limits, the trade-offs start to become more apparent.
    That's what makes this an interesting hobby! 🙂
    One could possibly cheat the coincell holder issue by using a tabbed coincell. That may or may or be a desirable trade-off, depending on your goal, but it might free up some real-estate. Maybe if the antenna could somehow be pasted onto or formed into the enclosure box, maybe that would work too. Just trying to figure out if there might be any ways around the obstacles you've noted above.
  • Contest Winner
    @scalz said in 💬 Aeos : a NRF52 versatile, up to 9in1, device:
    Great device. The next generation nRF5 has a USB serial device included. When you add D+ and D- to the USB Board/Main Board interface the next nRF5 can act as Gateway. -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52840.ps/usbd.html?cp=2_0_0_50#concept_usb_fp
    Do you have used an simple wire or something else?
    @d00616
    thx! Yep, i've noticed the usb feature too, and i'm waiting for a better availability 😉 (i've already designed a test dongle for fun, not ordered the pcb yet)
    regarding my simple test with chip antenna modules, yes i've used a simple wire, the same i use with my rfm69 : one 0.57mm solid core, and 31mm length for nrf. (diameter of the solid core shouldn't matter a lot i think). I have good hope to get an even better range with the pcb antenna. I'll keep you informed of course 🙂
  • Hero Member
    @scalz Will your Aeos be communicating with another NRF52? Do you already have code for that? Or will it be connecting with a phone over bluetooth, which is what I'm just now discovering is what most of the existing demo code for the NRF52 seems to focus on.
    @NeverDie
    yes sure. For example, in Mysensors, I have now 4x nrf52 nodes (aeos and other custom boards) talking to esp32+nrf24 gw.
    So, NRF52 <-> NRF52 and NRF52 <-> NRF24 are working well, and you can simply use Mysensors examples and set the defines, that's all, nothing more to do, it's transparent. Thx to the Mysensors NRF52 ESB port, pretty cool.
    For bluetooth, I've started to take a look for a simple BLE phone app too, for fun. That said with BLE available, we could get nice features in Mysensors..
    Finally, little sidenote about my simple range tests. They were quick, not in ideal conditions, but gave me an indication.
    I have tested BLE and Mysensors modes. Power supply for the node was 2x fresh AAA battery:
    • as a BLE beacon, and was checking the rssi with a phone app. Not a precise test as rssi is not linear.
    • with Mysensors. A simple counter was sent to the gw and i was looking for missing packet.
    I'll do more tests of course because some variables can change the results (like if it is in enclosure depending of wire antenna or not, orientation ..). For example, I will check pcb antennas by testing communication between two identical nodes.
  • Contest Winner
    @scalz Have you checked if there is a difference in range between NRF5_1MBPS and NRF5_BLE_1MBPS data rate?
  • @scalz 👍 Thumbs up for a 2450! You have it on your other sensor and I'm using it for PIR is makes sense. 2032 is fine for a long sleeping sensor, but PIR will drain it very quickly.
    @d00616 no. that was just a quick test during euphoria 😊 but that's an interesting point i need to add on my ToTest 👍
  • Contest Winner
    Congratulations. Very nice concept. But I understand nothing about the range. Is it comparable with nrf24 or is it by a decade more? 🙂
    @Koresh
    thx. I'm not sure about what you don't understand 🙂
    If you're wondering about nrf24 vs nrf52 range, i've not tested this, i'll do that as soon as i get my custom antenna version of the board.
    Because comparing a nrf24 module with pcb antenna Vs nrf52 with a chip antenna or an untuned wire antenna isn't a valid test, I think.
  • Contest Winner
    @scalz OK, waiting your results. For now I've just found some information about tx power:
    nrf24: nominal - 0dbm, max - +4dbm
    nrf51: nominal - 4dbm, max - +6dbm
    Not very high power 😞
    @scalz have you seen this module ?
    PCB antenna + IPEX, and with 52832 we're sure it's not a clone...
    At this price I can directly dump my atsamds and nrf modules 😮
    http://www.ebay.com/itm/nRF52832-E73-2G4M04S-Low-Power-2-4GHz-SMD-Wireless-Module-with-PCB-IPX-Antenna-/192237288810
  • Hero Member
    @Nca78
    It's very nice that they offer up the info needed to create the land pattern. That info seems absent from quite a number of the aliexpress modules.
    @Koresh
    Yes, still an interesting improvement 🙂 And i have powerful multirf boards too so..
    Well i think you know it, but range is not so easy to compare, that depends on a lot of factors like datarate, ant, enclosure etc..
    @Nca78
    yep, saw it too. I don't think they're selling clones, they looks nice 😉
    Module is too big regarding my board and all what's embedded. I also wanted a stronger antenna.
    This kind of meandered antenna, often the same for wire antenna though, may be prone to some detuning (regarding enclosure, environment etc.) and loosing some efficiency etc. So maybe not the full range, can be a lot less, depends (100m for this module in datasheet).
    But yes i agree with you 🙂 328p too limited, obsolete imho, "end" of nrf24 lol, and atsam is nice depending on the usecase. Personal view of course!
    But I think I'm still about to make one last 328 board to make a really small and low power sensor.
    Would you share eagle and schematic files for your prototype with the module ? I have ordered modules from EByte and I'd like some inspiration to prepare a first test board 😄
  • Hero Member
    @Nca78
    Thanks for posting that. I just now ordered some. However, they may not arrive until September! Yowza. That means their shipping container is practically a time capsule.
    @NeverDie great ! Don't thank me I'm pretty sure I'll benefit a lot from your testing on that module 🙂
  • Hero Member
    @Nca78
    One quick thing: I've started a PCB layout for this module. From the looks of the pictures on the e-bay listing, I'm assuming pins 0, 1, 2, 42, and 43 are all Ground.
    Is that your interpretation also?
    @NeverDie said in 💬 Aeos : a NRF52 versatile, up to 9in1, device:
    @Nca78
    It's what's written in the datasheet 😉
    0_1499826898882_E73-2G4M04S_Datasheet_EN_v1.1.pdf
  • Mod
    @Nca78 now you're cheating 😉
    @NeverDie hmm.. guys could you open a new topic regarding your nrf52 module please?
    (as i'm not planning to use it for Aeos, cost almost the same for me to use the IC, and i can do more compact stuff)
    Else that will be a mess here 😉 Thx!
    @Nca78 will upload some sch, was busy..
    Here a very simple rfm69 extension for Aeos, when i need more range:
    And a simple pcb for quick reprogramming the first time (as the next times it will be through OTA).
    And a simple pcb for quick reprogramming the first time (as the next times it's through OTA).
    OTA ? Is a bootloader already made ? 😮
    @Nca78
    There are some stuff already existing though.
    You can take a look at Adafruit nrf52 board, they have a bootloader for BLE, and their sch can also help you to understand how the above module is working in case.
    Regarding Mysensors OTA etc, stay tuned..
  • Contest Winner
    It would be nice if you can enable OTA. The DFU bootloader is placed at the top of Flash. This region conflicts with the NVM driver. You have to move the used Flash region.
    The bootloader is documented at http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.1.0/lib_bootloader_modules.html
    At the moment I have no time to work on an bootloader. If you want to discuss things you can contact me.
    Here is a pic of Aeos rev 1.0. (the revision with 4layers and custom antenna for better perf, but not tuned yet).
    Working well though 🙂
    With a simple adapter to my segger OB for programming it, or ftdi and some IOs. (actually playing a bit with ble for a change). Need to print a box!
  • Hero Member
    I hope we'll see the Aeos soon. It should help stimulate interest in the nRF52832.
    @NeverDie
    thx for reminding me 🙂 it's still working well.. but been distracted. Sorry for those who are waiting. I needed to have some fun with my HA setup.
    i'll do my best to sort all my stuff 😉
  • Would you be able to post the files for this project now?
  • @scalz
    Great project! When can we expect the project files to be available?
  • @scalz just found this project. It looks amazing!
    Is there anything we can do to support the progress?
    thx for interests. I'll release this project and a few others maybe, at same time as my Halo gateway. to make a prez if possible. asap.
  • Sounds good to me! Thanks a lot for your effort!
  • Hi guys! Also interested. Please let me know if I can help. Or as soon as you have some first run I'm willing to buy some. Thanks
  • This project is impressive, I really like it. Pity it is so silent about it. After all this work, are you not willing to finish it?
  • @scalz May I request you to share your code for it please. Thanks
11.4k
112.7k
