💬 JMP Arduino Pro Mini Multisensor Board v2.1
Could you please add some details on all those solder pads and why you choose that GPIO layout? Also it could be beneficial to have like a sma connector for rfm69 antenna
Please follow the rules for the CERN license. You have no license files and changelogs attached to your design as required.
If you have any questions, read here: https://forum.mysensors.org/topic/3096/open-hardware-licensing/
@Anticimex, sorry I will provide the correct files as soon as possibile! thanks
This post is deleted!
@gohan I will add dome details as soon as possible; about the SMA connector it's too big (7.9mm diameter) for this board.
New version 2.1 with EEPROM and signing IC!
@jumping nice, but you are still missing CERN documentation
@anticimex You are too fast
Now the CERN files are uploaded!!
💬 NodeManager
OpenHardware.io • 23 Mar 2017, 22:45 • openhardware.io 26 May 2019, 18:10 -
💬 MySensors Nrf24/RFM Serial/Ethernet GW Shield (for Uno)
OpenHardware.io • 6 May 2019, 12:53 • openhardware.io 14 Jan 2021, 22:54 -
💬 MySensors Battery node 2xAAA for SI/BME/SHT
OpenHardware.io • 19 Apr 2020, 12:11 • openhardware.io 19 Apr 2020, 12:11 -
💬 Utilipi Mini
OpenHardware.io • 12 Aug 2019, 08:05 • openhardware.io 12 Aug 2019, 08:05 -
Node to node comunication with optional controller
Development • 20 Mar 2017, 06:53 • Doomic 24 Mar 2017, 10:17 -
Video - "Getting Started with the nRF24L01 Transceiver"
Hardware • 18 Feb 2015, 09:16 • jocke4u 18 Feb 2015, 09:16 -
💬 Uniflächentaster PCB
OpenHardware.io • 2 Jul 2017, 12:52 • openhardware.io 2 Jan 2018, 16:56 -
💬 Aeos : a NRF52 versatile, up to 9in1, device
OpenHardware.io • 28 Jun 2017, 22:24 • openhardware.io 13 Apr 2020, 14:05
