Sensebender Micro
  • @tbowmo Thanks. No worries the electronic won't touch the salt or water. The salt/water is just within the same closed container to bring the enclosed air to exactly 75.3% rel hum (at 25C).
    I followed this howto: But there are many other similar ones.
    http://www.kingofthehouse.com/hygrometer/
  • @nivoc I setup several sensebenders on battery last summer and noticed they were a few % below two dht22 I had been running for months. I did the saturated salt test on three sensebenders with one dht22 and one mechanical hygrometer and the sensebenders all read 74-75% while the DHT and hygrometer read 78-80%. Not a perfect test and i dont know which devices were correct but one thing I noticed was the sensebenders consistently provided the same result across different devices. Relative humidity is relative.
  • @Dwalt
    Thanks for the info. I'm currently opening the box every several hours to test the salt soup. My room has something between 50 and 60 rel. (so below 75). And every time I open the box this (see pic). It drops and goes back up to 82 or 83. Than it stabilizes there over the next couple hours. There are two sensbenders in the box - thats what the two line are. And yes they are remarkable equal. But it always goes to 82 - i would hope for 75. But I will repeat this procedure until it starts to stabilizes after every opening a little bit below the value that was there before the opening. Because if that happens i am below the dry point and than I will test in a room with humidity higher than 80 and test if soup can do the same into the other direction and holds it stable for many openings. THAN i know that the salt is performing is job correctly and know that the test is good and the senbender is wrong 🙂 or hopefully I learn the opposite.
    upload-555b12a4-6bc0-4e07-acf7-976c4122e6d6
  • Yes it looks like that the sensors are 8% off. I tested the other way around >opening at ~100rel and closing and same + exactly back to 82/83 and it should be 75% :-).
    upload-e6c04b83-54d0-4e1e-aef3-a36b72c760d5
  • In the new year I will test with "Magnesium chloride". It brings the rel humitity to exactly 32% - I will report how that goes 🙂
    If the Si7021 is exposed to high humidity for a prolonged period, the RH% measurement will shift upwards, according to the datasheet, page 15, section 4.3
    Extract from Datasheet:
    4.3. Prolonged Exposure to High Humidity
    Prolonged exposure to high humidity will result in a gradual upward drift of the RH reading. The shift in sensor
    reading resulting from this drift will generally disappear slowly under normal ambient conditions. The amount of
    shift is proportional to the magnitude of relative humidity and the length of exposure. In the case of lengthy
    exposure to high humidity, some of the resulting shift may persist indefinitely under typical conditions. It is generally
    possible to substantially reverse this affect by baking the device (see Section “4.6. Bake/Hydrate Procedure” ).
    @petoulachi said:
    BTW, what is the F() function ? instead of Serial.print("Sensebender Micro FW "); why using Serial.print(F("Sensebender Micro FW ")); ?
    It's a way to save some RAM. A simple string constant like "Hello" takes up 6 bytes of RAM and also 6 bytes of Flash (program) memory (6 bytes includes a single "hidden" byte of binary zero as an end-of-text marker). At startup and before your code executes, that bit of program memory is copied to RAM. The F() thing is a "macro" which causes the compiler save only the 6 bytes of Flash (no Ram used). The print function can (through C++ typing) fetch those 6 bytes from Flash at runtime for printing. If you have long or many text constants in your program, this can add up to some useful savings,when you only have 2K of RAM.
    See the "F() Macro" on this page: https://www.arduino.cc/en/Reference/PROGMEM
  • @tbowmo Good hint. But it is happening to all three sensbeners for at least one month now. (different orders). I now got 4 more so I will test again soon.
    Over xmas I tested also with magnesium chloride hexahydrate. magnesium chloride hexahydrate produces exactly 33%rel.
    All 3 sensbenders report exactly 39% or 40%. So they are also here 7% off. But almost the same value and very reproducible - so thats great!
    upload-6b1782fc-cf3e-45b8-ad15-890b7eef84a0
  • @tbowmo I'm now almost sure that my test-setup has no faults very reproducable and read many articles - I plan to verify my findings with someone who has a professional calibrated device.
    I saw in a museum nearby that they have professional calibrated devices 🙂
    upload-4464b273-5525-48b2-a940-10826e61f030
    So I will test against those 🙂
    @nivoc
    Have you tried to "bake" your sensebenders, in case they have been exposed to high humidity for a longer time?
    They are, as far as I know, produced in a part of China, which are known to have very high humidity. (been traveling there a lot some years ago)
    @nivoc
    I can confirm your results: I am running two different sensors in the same room next to each other. The sensebender is always above the dht-22. Right now it is
    52% to 47.8% rel. humidity, while the temperature is 17.8 to 17.9 (which is nearly equal).
  • @tbowmo No I haven't baked yet. I will try that but not in the next two weeks. But I will report back.
  • But I tested tonight with distilled water - so should be exactly 100%. And again (I didn't know that thats possible) I got 104 and 107% so slightly above (still increasing). Thats great b/c that means all values are about 7-8% too high.
    At 33% the reading was about 40%
    At 75% the reading was about 83%
    At 100% the reading was about 106%
    So reading minus 8% gives a pretty accurate result. In the next few days i will test 3 more sensbender.
    Distilled Water (100% expected):
    upload-c0364fcd-876d-4701-a3ec-b0c55efc04a6
  • Read the spec for the humidity sensor used in the sensebender (Si7021 integrated humidity / temperature sensor.)
    Precision Relative Humidity Sensor: ± 3% RH (max), 0–80% RH
    To my reading this is actually 6% wrong reading to one of the sides - so when you are measuring yours to be 8% off, is caused that you are using the device outside of humidity range 100% and max is 80%
    Link to spec:
    https://www.silabs.com/Support Documents/TechnicalDocs/Si7021-A20.pdf
    What I want you to know, if your device is reading within 6 % of the value - it's still reading correct. and when you compare ex DHT22 that device also have some reading variation error. Do not expect to get 100% perfect value for 2 devices...
  • @bjacobse Yes and no 🙂
    Yes 100% is outside of the spec.
    And no. 33% with Magnesium Chloride Hexahydrate is inside the spec and I get 40% instead of 33-34%.
    Max off should be 3% above or? Means 37% - but fair enough. Should be ok for household use.
    I hope the Temp measurements are not off by that much.
    i don't need .00001 accuracy or anything. but i feel a big difference between 70 and 72 in my house.
  • @mvader
    Spec is: High Accuracy Temperature Sensor ±0.4 °C (max), –10 to 85 °C
    So the temp accuracy is quite good
  • @nivoc
    Yes you are right, +-3 from your humidity solution on 33%, then the reading could be in the interval 33-3=30% or up to 33+3=36% and should not show 40%
    did you get same false readings from other sensebender humidity sensors?
  • @bjacobse Yes I have 3 sensbener running from 2 different orders. All 3 are very near by each other. So at 33% they all read something near to 40%.
    I have 4 more sensbenders to build. However I continue to test tonight with a Boveda-Pack that claims to bring the hum in a containter to exactly 69%. I did 4 test's so far and also used different technics. So i get more and more confident.
    But the very good thing is - it looks every reproducible. So the value may be off but reproducable accurate off by about 8%. When I completed my test it will be very easy to correct it within the software.
  • @mvader I haven't made any very accurate temp testings. But the readings are exactly the same than other non-sensbender devices in my home. I started researching the humidity b/c I had different readings between different devices.
    Temp looks fine to me.
  • What is the current consumption of the Sensebender during sleep and active modes?
    Tony
    @tcontrada
    there are some measurements in the old design thread here http://forum.mysensors.org/topic/510/minimal-design-thoughts
  • Hi. What case you all using for the sensebender ?Any good idea.
  • 3_1456326631089_IMG_20160224_150344.jpg 2_1456326631089_IMG_20160224_150314.jpg 1_1456326631089_IMG_20160224_150303.jpg 0_1456326631088_IMG_20160224_150237.jpg
    @filipq
    Where did you find that box?
  • @tbowmo
    Got it from http://cpc.farnell.com/1/1/57932-evatron-pp42m-case-sensor-ivory-71x71x27mm.html.
    Not the cheapest, but definitely worth the money as it is very good quality. There are other colours available (white and black) https://www.jprelec.co.uk/store.asp/c=552/Gas-Sensor-Case
    @tbowmo: I have some of these too, it's nice box. i got these from tme. cheaper 🙂
    http://www.tme.eu/fr/details/box-sens-white/boitiers-dappar-dalarme-et-de-capt/supertronic/
  • Hello @tbowmo
    Doesn't the atmega328 has only 2 pins which are D2 and D3 from external interrupts ?
    I am wondering why do we waste the usage of D2 since the IRQ pin is not used in the library ?
    @ahmedadelhosni because it is not in use by the library <yet>. Would be a shame if the library some day gets updated with support for a radio that can enter low power sleep and still wake when needed.
    @ahmedadelhosni
    What @Anticimex said.. And at the time when I created the sensebender, I didn't know that the interrupt wasn't used (I was relatively new to the project) so I thought that we had to have it connected..
    It is used by the RF69, right @tbowmo? (when using adapter plate...)
  • @Anticimex @tbowmo This a valid point which I thought of but I needed two interrupt pins. As far as I knew from fast searching is that external interrupts which react to CHANGE in pin state are only valid for pins 2 and 3. Correct ?
    Maybe there is another solution which I missed.
    @hek
    Yes, that's right, RFM69 is using interrupts.. (and rfm69 is possible on the sensebender using for example this pcb)
    And with a scalpel and a soldering iron you should be able to use both interrupts by disconnecting the one reserved for nrf24. Of course that would disable the use for rfm69 om that board.
  • @Anticimex Yeah I could just connect my device to the atmega pin directly as I can see/find any pin header to route the interrupt pin 2. They are all used.
    Thanks guys.
    I just received two sensebenders. I'm really impressed by the great engineering behind the board. I can't wait to heat up my soldering iron. I love them!
  • I just received two Sensebenders, but have problems getting the device to consume little power. I get totally different values as displayed above.
    #include <LowPower.h>
    #include "RF24.h"
    RF24 radio(9, 10);
        delay(8000);
    @user2334 I don't think the LowPower library shuts off the radio. Use MySensor's sleep function instead.
  • A general question regarding these types of boards that are generally designed to be used on battery power. Is there a reason to not power the ATSH204A and Si7021 from AVR pins? The pins can source far more than what these devices can sink (even when using the heating on the Si7021), and it would allow squeezing a tiny bit more out of the battery life by selectively powering down the devices.
    Eg., if I'm not using the ATSHA204A at all, I can save 150nA continuous current. The power saving from disabling the Si7021 is less at about 60nA, so that might just be eaten up by having to wait up to 80ms before a full conversion.
    I'm aware that we're talking about saving a tiny ~200nA here, but over the span of two years that adds up to about 350mAh.
    So what I'm wondering is simply, is there a technical reason saying that this really isn't a Good Idea (tm)? Should I avoid doing so if I design my own similar device?
    I second that question. I was just thinking about a similar idea.
    @ximinez @LastSamurai
    That is indeed a good question. The straight answer is that I didn't think about that when I designed the board.
    In theory you could also power the radio from a digital pin on the avr, and power that down completely.
    BTW. If you turn on the heating element in the si7021 at full power, I think the power drain exceeds what the avr can deliver on a digital pin. But one could just avoid that.
    I have been thinking about this as well. But I discarded parts of the idea because I needed the IO for other stuff (MYSX in my case). Instead I designed a switched rail where one could attach sensor power sinks. It's not io powered but it is io controlled.
    Though I did not attach the si or atsha to this switch function as I decided to make it an optional feature but wanted to make sure authentication and temp/hum would always be available.
  • That is indeed a good question. The straight answer is that I didn't think about that when I designed the board.
    Oh, I thought it was a design decision 🙂
    I've been wondering about the radio in particular. Does the radio keep any state locally, and will it have to be reinitialized upon powerup?
    The heating element eats a measly 3.1mA according to the datasheet, so even that would be well within the limits for a single in on a 328p.
    Now, I don't have Eagle installed on this laptop, and my bandwidth is limited right now. Is there a picture of the PCB traces available? Wondering if atleast some of this can be hacked on by cutting traces.
    @ximinez
    Nope, there are only the eagle design files.. (Or gerbers, you could use a gerber viewer)
    I have 4 sensors operating for almost a year on two AA batteries, they all report around 73% battery left. So in my opinion, it's not that necessary to do extra optimization on the power drain..
  • @tbowmo
    While 73% after one year is good, it doesn't mean that it can't get better. The ATSHA204a and Si7021 draw about 350mAh from the battery over two years from idling alone. The NRF24L01+ draws around 1500mAh.
    Remember, you will never get close to emptying out the battery before the voltage drops below working voltage. Using alkaline batteries, you'll get around 2000mAh before the batteries reach 2v (which, if you're using battery voltage as a pure percentage, is 66%), at which point the voltage curve drops sharply - and your sensors die. The radio and sensors have drawn more than 900mAh from your battery during the year you have run the device (and that's just idling) - close to half your battery life.
    Assuming your battery percentage is correct, and you started at 100% one year ago, I'm betting your sensors will die sometime during this summer. While you may think that extra optimization isn't worth it, I do. The nanoAmp draws may not seem like much, but drawn out on a timescale like this, it is a major power draw.
    @ximinez That depend on how you define battery percentage. I have chosen to adjust my measurements to let 0% mean when voltage drops below the highest requirements of the onboard devices. Since that particular device will fail when voltage goes lower, it serves no purpose to provide a false battery percentage. 0% is when the node no longer operates according to specs. But this is of course hw/sketch-dependent.
  • @Anticimex The point still stands however. The discharge graph is far from linear, and your sensors and radio have already drawn close to half of your battery life by idling alone. A colleague of mine has had to replace the batteries in his two sensors already.
    @ximinez I do not recall sharing my statistics, so I assume you refer to @tbowmo's stats?
  • @Anticimex Ah, yes. sed /your/@tbowmo's/g. I blame lack of caffeine.
    @ximinez makes sense. I'm sure you can cut down on power consumption by cutting power to those peripherals. I do not know how signing would be affected by this though, as I have not tested it with switching the atsha on and off between calls. I would like to hear from you on that topic if you choose to try it though 🙂
  • Ok, I've been looking at the image and my spare sensor. It looks like:
    Power to the NRF can be cut between C3 and VCC pin.
    ATSHA204a power can be cut on the trace that goes from the atsha and beneath the flash.
    Si7021 power can be cut at the trace that goes from C4.
    I just might have to dig out my scalpel and iron for this. If the components magically work without any extra initialization on powerup, modifying the code looks easy.
    I'll report back with my findings
    @ximinez
    For my battery reporting, I have set 1.9V as 0%, 3.3V is 100%..
    While you're at it, also power down the external flash, as it might also contribute a bit..
  • Well that went south pretty fast. Was wondering why my sensebender was acting up. Took a while to see that I had plugged in an ESP8266 module instead of one of my NRF24 modules. Those modules look far too much alike 😡
    Serial output now looks like this: "Sånsebåndåò Micro FW 1.3" with random characters corrupted. I think I've killed it 😉
    I can still flash firmware to it via serial, so it's not completely dead.
    I can however confirm that both the SHA204A and SI7021 self-tests OK being powered on in-sketch:
    (Flash seems to randomly fail or test OK, not sure why yet)
    þSånseâånder Micòo F× 1.3 - TesôÍoäe
    Tåstiîg påòipheraló!
    -> ÓÉ7021 : ok!
    -> Æìasè : æailed!
    -> SÈA204 : Ïk (seòéal : 01234ÂBAÅ259E8AÄÅE)
    Tåót fiîésheä
    ----> Óelftest æaiìåä!
    @ximinez If possible, try to check if signing and verification of signatures work as well. I have tried to implement the use of the ATSHA to be atomic in nature, but it could be that some state is retained which is cleared on power down which might break the calculations.
  • What is the easiest and fastest way to sign and verify? I don't have a gateway set up quite yet.
    (And, is any part of setting this up dependent on serial integrity? If so I might have to adjust baud quite a bit)
    @ximinez Well, without a gw the only option is to use node peer to peer transmissons to test signing. How to do it is described in the signing documentation, assuming you use development branch, you can see here. For master, look here.
  • I have an Uno with an ethernet shield and nrf24 hooked up, so I will have to get around to write a sketch for that purpose.
    But to get signing to work, I'll have to personalize the atsha? That sketch doesn't compile for me.
    Yes, you have to personalize it. What is failing? I don't have an Uno myself, but according to Jenkins the personalizer compiles ok for Uno on both master and development. You don't have any local changes?
  • The personalization fails to compile for my sensebender micro. There's a few undeclared:
    Personalizer:225: error: 'EEPROM_SIGNING_SOFT_HMAC_KEY_ADDRESS' was not declared in this scope
    Personalizer:225: error: 'hwReadConfigBlock' was not declared in this scope
    Personalizer:236: error: 'EEPROM_SIGNING_SOFT_SERIAL_ADDRESS' was not declared in this scope
    Personalizer:247: error: 'EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS' was not declared in this scope
    Personalizer:697: error: 'hwMillis' was not declared in this scope
    I'm trying to compile this against master however. Do I have to have dev branch to compile that sketch?
  • Fails with the same errors on Uno for me.
    @ximinez and you are certain you have no local changes to the code? Jenkins builds both master and development branches every night for both the SenseBender and the uno and it builds all examples, including the personalizer without issues.
  • Pretty sure.
    I'll wipe my library dir and redownload master.
    If memory serves me, some of the errors you get seem to originate from code on development branch. The eeprom addresses are to my knowledge not yet available on master.
  • Ok, moved from master to dev. Sketch compiled. Not quite the output I expected however.
    EEPROM configuration:
    SOFT_SERIAL | FFFFFFFFFFFFFFFFFF
    AES_KEY | FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    @ximinez it is the output I expected. You have gone for soft signing, and you see the reset values of the eeprom. You need to pick atsha settings. The link I gave you gives the exact settings to personalize both for software and atsha backends.
  • Got it now 🙂
    I had two different sketches and had edited the wrong one. Now I have actual values.
    Is there an example GW sketch that I can load quickly to my Uno/W5100 shield/NRF24?
    I'm rusty on the gateways. But on development branch, configuring signing is easier than on master branch. My link gives the details on signing configuration for both nodes and gateways with examples.
  • Yeah, I'm struggling a bit with those instructions. I've set up my gateway with soft signing, and got sane values written to EEPROM.
    Now, do I need any of the three values to personalize the sensebender?
    SOFT_HMAC_KEY?
    @ximinez the SenseBender you have patched/cut needs atsha personalization, so no SOFT anything. But you need to have the same hmac key stored on the atsha on the SenseBender as you have picked as soft hmac key in eeprom of your gateway (the node you have personalized for soft signing).
  • @Anticimex Yeah, that's what I asked 😉
    I get:
    Writing key to slot 0...
    Data lock failed. Response: D3
    @ximinez locking data is a very bad idea. It will prevent you from changing the hmac key. You only need to (and should) lock configuration. Only lock data if you really know what you are doing.
  • Writing key to slot 0...
    Data not locked. Define LOCK_DATA to lock for real.
    Configuration is LOCKED
    Data is UNLOCKED
    @ximinez looks good. You should be done with personalization. Remember to require signatures from the SenseBender in addition to "enabling" it. You can also require signature on the GW, thus forcing all communications between them to be signed. The serial console will reveal how it goes. You can enable verbose debug (MY_DEBUG_VERBOSE_SIGNING) for the signing if you want more details on the signing parts.
  • I have the sensor sketch mostly done, but I'll have to do some soldering again tomorrow. It looks like D7 got burnt when I plugged in my ESP8266, giving ~0,5v out on that pin. Will have to work around that:
    Sôártinç óensor (RÎONA-, 2.0.0-beta)
    Raäio init æáiìåd. Ãèeck wiring.
    When that is OK, I'll look at the GW sketch.
    Sounds good. Bedtime here too.
  • D3, D4 and D7 are all funky, and do not give ~3v when set high. So I'm back to the radio being on all the time.
    D5 and D6 mysteriously work just fine.
    Radio is now OK, but the sensebender reboots before it gets to setup().
    Stárting óensor (ÒÎONA-, 2.0.0-beôá)
    Ráäio init suããessæuì.
    æéîä parenô
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,óô=bc:
    [reboot and repeat]
    @ximinez
    Sounds like it's on its way to the "other side"..
  • Yup. Setting up my other sensebender as a proper signing sensor and my uno as a gateway. This will have to wait until I get a couple more working sensors.
  • Ok. I set up my GW, and set up my healthy sensebender as an outdoor sensor. The zombie sensor is now a working indoor sensor.
    I have enabled signing and set up whitelisting, but enabling signing debugging makes the sketch oversize, so I can't actually check if signing works - but atleast now I have two sensors.
    Domoticz up
    You will still be notified without verbose logging. And if you have enabled and require signing, you won't get any data if something fails (assuming signing is properly activated).
    #include "RF24.h"
    RF24 radio(9, 10);
        delay(8000);
    As a follow-up to my previous posting, I can confirm, that using original nRF24-modules (best source seems to be https://www.itead.cc/nrf24l01-module.html), I get 0,023mA (=23µA) with nrf24 attached during sleep mode (no difference between the libraries JeeLib->Sleepy::loseSomeTime or LowPower->LowPower.powerDown).
    It is quite interesting, that so many nRF24 Modules (bought from eBay, from Amazon UK) are clones with higher power consumption. Some of them use 3mA, some have electrical short, ...
  • @Anticimex I've set MY_SIGNING_SOFT, MY_SIGNING_REQUEST_SIGNATURES and MY_SIGNING_NODE_WHITELIST on the GW, and reenabled (normal) debug but not signing debug since that is too big.
    With those enabled, if the sending node does not sign, I should not get this?
    0;255;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:6.3
    0;255;3;0;9;read: 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:59
    @ximinez The GW will only require signatures from a node that in turn require signatures.
    It is the sg-flag that indicate if a message is signed, in your case, both messages are unsigned.
    If you only have node->gw communication, both gw and node has to require signatures for you to see signed messages.
    If you have gw->node communication, it is enough that the node require signatures, the gw will then sign them, no matter if the gw require signatures or not.
  • 0;255;3;0;9;read: 3-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
    0;255;3;0;9;read: 3-3-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:57ACB4BD46843BFCC7ABA693CC5AA527F7724531F525338E8A
    0;255;3;0;9;read: 3-3-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
    I feel more secure now 😛
    @ximinez Hm, good, but I still see no signed message. But at least a nonce was sent
  • @Anticimex Sensor values are getting through though. And signing is requested on both ends (for one sensor so far). I can't see any other #defines that should be set to enable signing. I get the same result on both the zombie sensor and the unmodded one.
    I get three "sign fail" (showing up as verify fail on gw) before the sketch reaches setup(), where the ATSHA gets powered up. I will need to power the ATSHA somewhere in the mysensors library. However, once setup() is reached, the ATSHA seems to handle powering down and up just fine.
    I can however say that it the Si7021 doesn't like being powered off and back on again after sleep. That causes the MCU to reset.
    @ximinez Ah, yes, on development branch the signing backend clear the sign flag when it verifies the message. so it will always show as 0 without verbose signing debug enabled.
    I know there have been discussions about a "pre setup" to be used for early sketch init. You probably want to power the atsha for early handshaking as well to get the sketch name and such to propagate properly. @hek perhaps has the latest on such features.
  • I've built a nicer-looking serial gateway instead of the rather large ethernet gateway. I thought that would basically be a "slot-in" as long as I personalize the GW it with the same SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY as the original GW. Are there more steps that need to be taken to get the sensors to connect?
    Serial Gateway
  • No matter what I do now, this is what I get:
    send: 2-2-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
    sign fail
    send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:26.0
    send: 2-2-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=fail:
    sign fail
    send: 2-2-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=fail:34
    send: 2-2-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
    sign fail
    You must not use the same serial across nodes. Serial have to be unique. HMAC have to be identical.
  • Yes, I know serial must be unique. Serials go in the whitelist for the corresponding node ID. It turned out to be the NRF24L01+-modules with antennas. Replaced it with a regular module and it worked fine.
    (Which is strange, because one of those modules worked fine on the ethernet gw. It doesn't eat that much power does it?)
    @ximinez The signing failing is due to messages not arriving (st=fail). So it is not signing that is your problem here.
    However, with signing, messages are now "full size" which strains the RF link so if it is "weak" fewer messages get through if they are "longer". I suspect that is the problem here. Basically the usual stuff; adding caps, using a dedicated regulator and so on...
  • Looks like it works now, but what's the deal with the initial failed signs? Look at http://pastebin.ca/3585005 (GW side) and http://pastebin.ca/3585014 (Sensor side. Not the same powerup). It starts by failing a lot, then after a while everything looks OK.
    @ximinez difficult to say. Maybe a long stabilization period for the regulator. You could try to add a delay in early init in the library to see if it makes a difference.
    @Anticimex and again, it is not failed signature errors per se. It is st=fail (transmission errors) that cause the signing backend to timeout. So it is not the performance of the atsha (or sw) that cause the issue here, it is the radio.
  • @tbowmo said:
    @ximinez
    I forgot about the flash. That would require bootloader support though? Or is the OTA done by jumping to the bootloader while running, keeping pin states?
    I'm waiting for some SOIC breakouts in the mail. When I get them, I'll scavenge the ATSHA and flash module from my zombie sensor and build my own sensebender with blackjack and hookers.
    @ximinez
    Yes.. bootloader should probably by modified, if you decide to switch off the flash as well..
  • I did update the Arduino IDE and now I don't see the Sensebender Micro in the device list.
    I'm using 1.6.5 and did copy the content to the boards.txt.
    Is there something else I have to do?
    # See: http://code.google.com/p/arduino/wiki/Platforms
    menu.cpu=Processor
    yun.name=Arduino Yún
    yun.upload.via_ssh=true
    yun.vid.0=0x2341
    yun.pid.0=0x0041
    yun.vid.1=0x2341
    yun.pid.1=0x8041
    yun.vid.2=0x2A03
    yun.pid.2=0x0041
    yun.vid.3=0x2A03
    yun.pid.3=0x8041
    yun.upload.tool=avrdude
    yun.upload.protocol=avr109
    yun.upload.maximum_size=28672
    yun.upload.maximum_data_size=2560
    yun.upload.speed=57600
    yun.upload.disable_flushing=true
    yun.upload.use_1200bps_touch=true
    yun.upload.wait_for_upload_port=true
    yun.bootloader.tool=avrdude
    yun.bootloader.low_fuses=0xff
    yun.bootloader.high_fuses=0xd8
    yun.bootloader.extended_fuses=0xfb
    yun.bootloader.file=caterina/Caterina-Yun.hex
    yun.bootloader.unlock_bits=0x3F
    yun.bootloader.lock_bits=0x2F
    yun.build.mcu=atmega32u4
    yun.build.f_cpu=16000000L
    yun.build.vid=0x2341
    yun.build.pid=0x8041
    yun.build.usb_product="Arduino Yun"
    yun.build.board=AVR_YUN
    yun.build.core=arduino
    yun.build.variant=yun
    yun.build.extra_flags={build.usb_flags}
    uno.name=Arduino/Genuino Uno
    uno.vid.0=0x2341
    uno.pid.0=0x0043
    uno.vid.1=0x2341
    uno.pid.1=0x0001
    uno.vid.2=0x2A03
    uno.pid.2=0x0043
    uno.vid.3=0x2341
    uno.pid.3=0x0243
    uno.upload.tool=avrdude
    uno.upload.protocol=arduino
    uno.upload.maximum_size=32256
    uno.upload.maximum_data_size=2048
    uno.upload.speed=115200
    uno.bootloader.tool=avrdude
    uno.bootloader.low_fuses=0xFF
    uno.bootloader.high_fuses=0xDE
    uno.bootloader.extended_fuses=0x05
    uno.bootloader.unlock_bits=0x3F
    uno.bootloader.lock_bits=0x0F
    uno.bootloader.file=optiboot/optiboot_atmega328.hex
    uno.build.mcu=atmega328p
    uno.build.f_cpu=16000000L
    uno.build.board=AVR_UNO
    uno.build.core=arduino
    uno.build.variant=standard
    diecimila.name=Arduino Duemilanove or Diecimila
    diecimila.upload.tool=avrdude
    diecimila.upload.protocol=arduino
    diecimila.bootloader.tool=avrdude
    diecimila.bootloader.low_fuses=0xFF
    diecimila.bootloader.unlock_bits=0x3F
    diecimila.bootloader.lock_bits=0x0F
    diecimila.build.f_cpu=16000000L
    diecimila.build.board=AVR_DUEMILANOVE
    diecimila.build.core=arduino
    diecimila.build.variant=standard
    ## Arduino Duemilanove or Diecimila w/ ATmega328
    diecimila.menu.cpu.atmega328=ATmega328
    diecimila.menu.cpu.atmega328.upload.maximum_size=30720
    diecimila.menu.cpu.atmega328.upload.maximum_data_size=2048
    diecimila.menu.cpu.atmega328.upload.speed=57600
    diecimila.menu.cpu.atmega328.bootloader.high_fuses=0xDA
    diecimila.menu.cpu.atmega328.bootloader.extended_fuses=0x05
    diecimila.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
    diecimila.menu.cpu.atmega328.build.mcu=atmega328p
    ## Arduino Duemilanove or Diecimila w/ ATmega168
    diecimila.menu.cpu.atmega168=ATmega168
    diecimila.menu.cpu.atmega168.upload.maximum_size=14336
    diecimila.menu.cpu.atmega168.upload.maximum_data_size=1024
    diecimila.menu.cpu.atmega168.upload.speed=19200
    diecimila.menu.cpu.atmega168.bootloader.high_fuses=0xdd
    diecimila.menu.cpu.atmega168.bootloader.extended_fuses=0x00
    diecimila.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
    diecimila.menu.cpu.atmega168.build.mcu=atmega168
    nano.name=Arduino Nano
    nano.upload.tool=avrdude
    nano.upload.protocol=arduino
    nano.bootloader.tool=avrdude
    nano.build.f_cpu=16000000L
    nano.build.board=AVR_NANO
    nano.build.core=arduino
    ## Arduino Nano w/ ATmega328
    nano.menu.cpu.atmega328=ATmega328
    nano.menu.cpu.atmega328.upload.maximum_size=30720
    nano.menu.cpu.atmega328.upload.maximum_data_size=2048
    nano.menu.cpu.atmega328.upload.speed=57600
    nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
    nano.menu.cpu.atmega328.bootloader.extended_fuses=0x05
    nano.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
    nano.menu.cpu.atmega328.build.mcu=atmega328p
    ## Arduino Nano w/ ATmega168
    nano.menu.cpu.atmega168=ATmega168
    nano.menu.cpu.atmega168.upload.maximum_size=14336
    nano.menu.cpu.atmega168.upload.maximum_data_size=1024
    nano.menu.cpu.atmega168.upload.speed=19200
    nano.menu.cpu.atmega168.bootloader.low_fuses=0xff
    nano.menu.cpu.atmega168.bootloader.high_fuses=0xdd
    nano.menu.cpu.atmega168.bootloader.extended_fuses=0x00
    nano.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
    nano.menu.cpu.atmega168.build.mcu=atmega168
    mega.name=Arduino/Genuino Mega or Mega 2560
    mega.vid.0=0x2341
    mega.pid.0=0x0010
    mega.vid.1=0x2341
    mega.pid.1=0x0042
    mega.vid.2=0x2A03
    mega.pid.2=0x0010
    mega.vid.3=0x2A03
    mega.pid.3=0x0042
    mega.vid.4=0x2341
    mega.pid.4=0x0210
    mega.vid.5=0x2341
    mega.pid.5=0x0242
    mega.upload.tool=avrdude
    mega.upload.maximum_data_size=8192
    mega.bootloader.tool=avrdude
    mega.bootloader.low_fuses=0xFF
    mega.bootloader.unlock_bits=0x3F
    mega.bootloader.lock_bits=0x0F
    mega.build.f_cpu=16000000L
    mega.build.core=arduino
    mega.build.variant=mega
    # default board may be overridden by the cpu menu
    mega.build.board=AVR_MEGA2560
    ## Arduino/Genuino Mega w/ ATmega2560
    mega.menu.cpu.atmega2560=ATmega2560 (Mega 2560)
    mega.menu.cpu.atmega2560.upload.protocol=wiring
    mega.menu.cpu.atmega2560.upload.maximum_size=253952
    mega.menu.cpu.atmega2560.upload.speed=115200
    mega.menu.cpu.atmega2560.bootloader.high_fuses=0xD8
    mega.menu.cpu.atmega2560.bootloader.extended_fuses=0xFD
    mega.menu.cpu.atmega2560.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
    mega.menu.cpu.atmega2560.build.mcu=atmega2560
    mega.menu.cpu.atmega2560.build.board=AVR_MEGA2560
    ## Arduino Mega w/ ATmega1280
    mega.menu.cpu.atmega1280=ATmega1280
    mega.menu.cpu.atmega1280.upload.protocol=arduino
    mega.menu.cpu.atmega1280.upload.maximum_size=126976
    mega.menu.cpu.atmega1280.upload.speed=57600
    mega.menu.cpu.atmega1280.bootloader.high_fuses=0xDA
    mega.menu.cpu.atmega1280.bootloader.extended_fuses=0xF5
    mega.menu.cpu.atmega1280.bootloader.file=atmega/ATmegaBOOT_168_atmega1280.hex
    mega.menu.cpu.atmega1280.build.mcu=atmega1280
    mega.menu.cpu.atmega1280.build.board=AVR_MEGA
    megaADK.name=Arduino Mega ADK
    megaADK.vid.0=0x2341
    megaADK.pid.0=0x003f
    megaADK.vid.1=0x2341
    megaADK.pid.1=0x0044
    megaADK.vid.2=0x2A03
    megaADK.pid.2=0x003f
    megaADK.vid.3=0x2A03
    megaADK.pid.3=0x0044
    megaADK.upload.tool=avrdude
    megaADK.upload.protocol=wiring
    megaADK.upload.maximum_size=253952
    megaADK.upload.maximum_data_size=8192
    megaADK.upload.speed=115200
    megaADK.bootloader.tool=avrdude
    megaADK.bootloader.low_fuses=0xFF
    megaADK.bootloader.high_fuses=0xD8
    megaADK.bootloader.extended_fuses=0xFD
    megaADK.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
    megaADK.bootloader.unlock_bits=0x3F
    megaADK.bootloader.lock_bits=0x0F
    megaADK.build.mcu=atmega2560
    megaADK.build.f_cpu=16000000L
    megaADK.build.board=AVR_ADK
    megaADK.build.core=arduino
    megaADK.build.variant=mega
    leonardo.name=Arduino Leonardo
    leonardo.vid.0=0x2341
    leonardo.pid.0=0x0036
    leonardo.vid.1=0x2341
    leonardo.pid.1=0x8036
    leonardo.vid.2=0x2A03
    leonardo.pid.2=0x0036
    leonardo.vid.3=0x2A03
    leonardo.pid.3=0x8036
    leonardo.upload.tool=avrdude
    leonardo.upload.protocol=avr109
    leonardo.upload.maximum_size=28672
    leonardo.upload.maximum_data_size=2560
    leonardo.upload.speed=57600
    leonardo.upload.disable_flushing=true
    leonardo.upload.use_1200bps_touch=true
    leonardo.upload.wait_for_upload_port=true
    leonardo.bootloader.tool=avrdude
    leonardo.bootloader.low_fuses=0xff
    leonardo.bootloader.high_fuses=0xd8
    leonardo.bootloader.extended_fuses=0xcb
    leonardo.bootloader.file=caterina/Caterina-Leonardo.hex
    leonardo.bootloader.unlock_bits=0x3F
    leonardo.bootloader.lock_bits=0x2F
    leonardo.build.mcu=atmega32u4
    leonardo.build.f_cpu=16000000L
    leonardo.build.vid=0x2341
    leonardo.build.pid=0x8036
    leonardo.build.usb_product="Arduino Leonardo"
    leonardo.build.board=AVR_LEONARDO
    leonardo.build.core=arduino
    leonardo.build.variant=leonardo
    leonardo.build.extra_flags={build.usb_flags}
    micro.name=Arduino/Genuino Micro
    micro.vid.0=0x2341
    micro.pid.0=0x0037
    micro.vid.1=0x2341
    micro.pid.1=0x8037
    micro.vid.2=0x2A03
    micro.pid.2=0x0037
    micro.vid.3=0x2A03
    micro.pid.3=0x8037
    micro.vid.4=0x2341
    micro.pid.4=0x0237
    # If the board is a 2341:0237 use 2341:8237 for build and set
    # other parameters as well
    micro.vid.4.build.vid=0x2341
    micro.vid.4.build.pid=0x8237
    micro.vid.4.build.usb_product="Genuino Micro"
    micro.vid.4.bootloader.file=caterina/Caterina-Genuino-Micro.hex
    micro.vid.5=0x2341
    micro.pid.5=0x8237
    # If the board is a 2341:8237 use 2341:8237 for build and set
    # other paramters as well
    micro.vid.5.build.vid=0x2341
    micro.vid.5.build.pid=0x8237
    micro.vid.5.build.usb_product="Genuino Micro"
    micro.vid.5.bootloader.file=caterina/Caterina-Genuino-Micro.hex
    micro.upload.tool=avrdude
    micro.upload.protocol=avr109
    micro.upload.maximum_size=28672
    micro.upload.maximum_data_size=2560
    micro.upload.speed=57600
    micro.upload.disable_flushing=true
    micro.upload.use_1200bps_touch=true
    micro.upload.wait_for_upload_port=true
    micro.bootloader.tool=avrdude
    micro.bootloader.low_fuses=0xff
    micro.bootloader.high_fuses=0xd8
    micro.bootloader.extended_fuses=0xcb
    micro.bootloader.file=caterina/Caterina-Micro.hex
    micro.bootloader.unlock_bits=0x3F
    micro.bootloader.lock_bits=0x2F
    micro.build.mcu=atmega32u4
    micro.build.f_cpu=16000000L
    micro.build.vid=0x2341
    micro.build.pid=0x8037
    micro.build.usb_product="Arduino Micro"
    micro.build.board=AVR_MICRO
    micro.build.core=arduino
    micro.build.variant=micro
    micro.build.extra_flags={build.usb_flags}
    esplora.name=Arduino Esplora
    esplora.vid.0=0x2341
    esplora.pid.0=0x003C
    esplora.vid.1=0x2341
    esplora.pid.1=0x803C
    esplora.vid.2=0x2A03
    esplora.pid.2=0x003C
    esplora.vid.3=0x2A03
    esplora.pid.3=0x803C
    esplora.upload.tool=avrdude
    esplora.upload.protocol=avr109
    esplora.upload.maximum_size=28672
    esplora.upload.maximum_data_size=2560
    esplora.upload.speed=57600
    esplora.upload.disable_flushing=true
    esplora.upload.use_1200bps_touch=true
    esplora.upload.wait_for_upload_port=true
    esplora.bootloader.tool=avrdude
    esplora.bootloader.low_fuses=0xff
    esplora.bootloader.high_fuses=0xd8
    esplora.bootloader.extended_fuses=0xcb
    esplora.bootloader.file=caterina/Caterina-Esplora.hex
    esplora.bootloader.unlock_bits=0x3F
    esplora.bootloader.lock_bits=0x2F
    esplora.build.mcu=atmega32u4
    esplora.build.f_cpu=16000000L
    esplora.build.vid=0x2341
    esplora.build.pid=0x803c
    esplora.build.usb_product="Arduino Esplora"
    esplora.build.board=AVR_ESPLORA
    esplora.build.core=arduino
    esplora.build.variant=leonardo
    esplora.build.extra_flags={build.usb_flags}
    mini.name=Arduino Mini
    mini.upload.tool=avrdude
    mini.upload.protocol=arduino
    mini.bootloader.tool=avrdude
    mini.bootloader.low_fuses=0xff
    mini.bootloader.unlock_bits=0x3F
    mini.bootloader.lock_bits=0x0F
    mini.build.f_cpu=16000000L
    mini.build.board=AVR_MINI
    mini.build.core=arduino
    mini.build.variant=eightanaloginputs
    ## Arduino Mini w/ ATmega328
    mini.menu.cpu.atmega328=ATmega328
    mini.menu.cpu.atmega328.upload.maximum_size=28672
    mini.menu.cpu.atmega328.upload.maximum_data_size=2048
    mini.menu.cpu.atmega328.upload.speed=115200
    mini.menu.cpu.atmega328.bootloader.high_fuses=0xd8
    mini.menu.cpu.atmega328.bootloader.extended_fuses=0x05
    mini.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328-Mini.hex
    mini.menu.cpu.atmega328.build.mcu=atmega328p
    ## Arduino Mini w/ ATmega168
    mini.menu.cpu.atmega168=ATmega168
    mini.menu.cpu.atmega168.upload.maximum_size=14336
    mini.menu.cpu.atmega168.upload.maximum_data_size=1024
    mini.menu.cpu.atmega168.upload.speed=19200
    mini.menu.cpu.atmega168.bootloader.high_fuses=0xdd
    mini.menu.cpu.atmega168.bootloader.extended_fuses=0x00
    mini.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
    mini.menu.cpu.atmega168.build.mcu=atmega168
    ethernet.name=Arduino Ethernet
    ethernet.upload.tool=avrdude
    ethernet.upload.protocol=arduino
    ethernet.upload.maximum_size=32256
    ethernet.upload.maximum_data_size=2048
    ethernet.upload.speed=115200
    ethernet.bootloader.tool=avrdude
    ethernet.bootloader.low_fuses=0xff
    ethernet.bootloader.high_fuses=0xde
    ethernet.bootloader.extended_fuses=0x05
    ethernet.bootloader.file=optiboot/optiboot_atmega328.hex
    ethernet.bootloader.unlock_bits=0x3F
    ethernet.bootloader.lock_bits=0x0F
    ethernet.build.variant=ethernet
    ethernet.build.mcu=atmega328p
    ethernet.build.f_cpu=16000000L
    ethernet.build.board=AVR_ETHERNET
    ethernet.build.core=arduino
    fio.name=Arduino Fio
    fio.upload.tool=avrdude
    fio.upload.protocol=arduino
    fio.upload.maximum_size=30720
    fio.upload.maximum_data_size=2048
    fio.upload.speed=57600
    fio.bootloader.tool=avrdude
    fio.bootloader.low_fuses=0xFF
    fio.bootloader.high_fuses=0xDA
    fio.bootloader.extended_fuses=0x05
    fio.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
    fio.bootloader.unlock_bits=0x3F
    fio.bootloader.lock_bits=0x0F
    fio.build.mcu=atmega328p
    fio.build.f_cpu=8000000L
    fio.build.board=AVR_FIO
    fio.build.core=arduino
    fio.build.variant=eightanaloginputs
    bt.name=Arduino BT
    bt.upload.tool=avrdude
    bt.upload.protocol=arduino
    bt.upload.speed=19200
    bt.upload.disable_flushing=true
    bt.bootloader.tool=avrdude
    bt.bootloader.low_fuses=0xff
    bt.bootloader.unlock_bits=0x3F
    bt.bootloader.lock_bits=0x0F
    bt.build.f_cpu=16000000L
    bt.build.board=AVR_BT
    bt.build.core=arduino
    bt.build.variant=eightanaloginputs
    ## Arduino BT w/ ATmega328
    bt.menu.cpu.atmega328=ATmega328
    bt.menu.cpu.atmega328.upload.maximum_size=28672
    bt.menu.cpu.atmega328.upload.maximum_data_size=2048
    bt.menu.cpu.atmega328.bootloader.high_fuses=0xd8
    bt.menu.cpu.atmega328.bootloader.extended_fuses=0x05
    bt.menu.cpu.atmega328.bootloader.file=bt/ATmegaBOOT_168_atmega328_bt.hex
    bt.menu.cpu.atmega328.build.mcu=atmega328p
    ## Arduino BT w/ ATmega168
    bt.menu.cpu.atmega168=ATmega168
    bt.menu.cpu.atmega168.upload.maximum_size=14336
    bt.menu.cpu.atmega168.upload.maximum_data_size=1024
    bt.menu.cpu.atmega168.bootloader.high_fuses=0xdd
    bt.menu.cpu.atmega168.bootloader.extended_fuses=0x00
    bt.menu.cpu.atmega168.bootloader.file=bt/ATmegaBOOT_168.hex
    bt.menu.cpu.atmega168.build.mcu=atmega168
    LilyPadUSB.name=LilyPad Arduino USB
    LilyPadUSB.vid.0=0x1B4F
    LilyPadUSB.pid.0=0x9207
    LilyPadUSB.vid.1=0x1B4F
    LilyPadUSB.pid.1=0x9208
    LilyPadUSB.upload.tool=avrdude
    LilyPadUSB.upload.protocol=avr109
    LilyPadUSB.upload.maximum_size=28672
    LilyPadUSB.upload.maximum_data_size=2560
    LilyPadUSB.upload.speed=57600
    LilyPadUSB.upload.disable_flushing=true
    LilyPadUSB.upload.use_1200bps_touch=true
    LilyPadUSB.upload.wait_for_upload_port=true
    LilyPadUSB.bootloader.tool=avrdude
    LilyPadUSB.bootloader.low_fuses=0xff
    LilyPadUSB.bootloader.high_fuses=0xd8
    LilyPadUSB.bootloader.extended_fuses=0xce
    LilyPadUSB.bootloader.file=caterina-LilyPadUSB/Caterina-LilyPadUSB.hex
    LilyPadUSB.bootloader.unlock_bits=0x3F
    LilyPadUSB.bootloader.lock_bits=0x2F
    LilyPadUSB.build.mcu=atmega32u4
    LilyPadUSB.build.f_cpu=8000000L
    LilyPadUSB.build.vid=0x1B4F
    LilyPadUSB.build.pid=0x9208
    LilyPadUSB.build.usb_product="LilyPad USB"
    LilyPadUSB.build.board=AVR_LILYPAD_USB
    LilyPadUSB.build.core=arduino
    LilyPadUSB.build.variant=leonardo
    LilyPadUSB.build.extra_flags={build.usb_flags}
    lilypad.name=LilyPad Arduino
    lilypad.upload.tool=avrdude
    lilypad.upload.protocol=arduino
    lilypad.bootloader.tool=avrdude
    lilypad.bootloader.unlock_bits=0x3F
    lilypad.bootloader.lock_bits=0x0F
    lilypad.build.f_cpu=8000000L
    lilypad.build.board=AVR_LILYPAD
    lilypad.build.core=arduino
    lilypad.build.variant=standard
    ## LilyPad Arduino w/ ATmega328
    lilypad.menu.cpu.atmega328=ATmega328
    lilypad.menu.cpu.atmega328.upload.maximum_size=30720
    lilypad.menu.cpu.atmega328.upload.maximum_data_size=2048
    lilypad.menu.cpu.atmega328.upload.speed=57600
    lilypad.menu.cpu.atmega328.bootloader.low_fuses=0xFF
    lilypad.menu.cpu.atmega328.bootloader.high_fuses=0xDA
    lilypad.menu.cpu.atmega328.bootloader.extended_fuses=0x05
    lilypad.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
    lilypad.menu.cpu.atmega328.build.mcu=atmega328p
    ## LilyPad Arduino w/ ATmega168
    lilypad.menu.cpu.atmega168=ATmega168
    lilypad.menu.cpu.atmega168.upload.maximum_size=14336
    lilypad.menu.cpu.atmega168.upload.maximum_data_size=1024
    lilypad.menu.cpu.atmega168.upload.speed=19200
    lilypad.menu.cpu.atmega168.bootloader.low_fuses=0xe2
    lilypad.menu.cpu.atmega168.bootloader.high_fuses=0xdd
    lilypad.menu.cpu.atmega168.bootloader.extended_fuses=0x00
    lilypad.menu.cpu.atmega168.bootloader.file=lilypad/LilyPadBOOT_168.hex
    lilypad.menu.cpu.atmega168.build.mcu=atmega168
    pro.name=Arduino Pro or Pro Mini
    pro.upload.tool=avrdude
    pro.upload.protocol=arduino
    pro.bootloader.tool=avrdude
    pro.bootloader.unlock_bits=0x3F
    pro.bootloader.lock_bits=0x0F
    pro.build.board=AVR_PRO
    pro.build.core=arduino
    pro.build.variant=eightanaloginputs
    ## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328
    pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)
    pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720
    pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
    pro.menu.cpu.16MHzatmega328.upload.speed=57600
    pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
    pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
    pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x05
    pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
    pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p
    pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
    ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
    pro.menu.cpu.8MHzatmega328=ATmega328 (3.3V, 8 MHz)
    pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720
    pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
    pro.menu.cpu.8MHzatmega328.upload.speed=57600
    pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
    pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
    pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x05
    pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
    pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p
    pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
    ## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168
    pro.menu.cpu.16MHzatmega168=ATmega168 (5V, 16 MHz)
    pro.menu.cpu.16MHzatmega168.upload.maximum_size=14336
    pro.menu.cpu.16MHzatmega168.upload.maximum_data_size=1024
    pro.menu.cpu.16MHzatmega168.upload.speed=19200
    pro.menu.cpu.16MHzatmega168.bootloader.low_fuses=0xff
    pro.menu.cpu.16MHzatmega168.bootloader.high_fuses=0xdd
    pro.menu.cpu.16MHzatmega168.bootloader.extended_fuses=0x00
    pro.menu.cpu.16MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
    pro.menu.cpu.16MHzatmega168.build.mcu=atmega168
    pro.menu.cpu.16MHzatmega168.build.f_cpu=16000000L
    ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega168
    pro.menu.cpu.8MHzatmega168=ATmega168 (3.3V, 8 MHz)
    pro.menu.cpu.8MHzatmega168.upload.maximum_size=14336
    pro.menu.cpu.8MHzatmega168.upload.maximum_data_size=1024
    pro.menu.cpu.8MHzatmega168.upload.speed=19200
    pro.menu.cpu.8MHzatmega168.bootloader.low_fuses=0xc6
    pro.menu.cpu.8MHzatmega168.bootloader.high_fuses=0xdd
    pro.menu.cpu.8MHzatmega168.bootloader.extended_fuses=0x00
    pro.menu.cpu.8MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
    pro.menu.cpu.8MHzatmega168.build.mcu=atmega168
    pro.menu.cpu.8MHzatmega168.build.f_cpu=8000000L
    atmegang.name=Arduino NG or older
    atmegang.upload.tool=avrdude
    atmegang.upload.protocol=arduino
    atmegang.upload.speed=19200
    atmegang.bootloader.tool=avrdude
    atmegang.bootloader.unlock_bits=0x3F
    atmegang.bootloader.lock_bits=0x0F
    atmegang.build.mcu=atmegang
    atmegang.build.f_cpu=16000000L
    atmegang.build.board=AVR_NG
    atmegang.build.core=arduino
    atmegang.build.variant=standard
    ## Arduino NG or older w/ ATmega168
    atmegang.menu.cpu.atmega168=ATmega168
    atmegang.menu.cpu.atmega168.upload.maximum_size=14336
    atmegang.menu.cpu.atmega168.upload.maximum_data_size=1024
    atmegang.menu.cpu.atmega168.bootloader.low_fuses=0xff
    atmegang.menu.cpu.atmega168.bootloader.high_fuses=0xdd
    atmegang.menu.cpu.atmega168.bootloader.extended_fuses=0x00
    atmegang.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
    atmegang.menu.cpu.atmega168.build.mcu=atmega168
    ## Arduino NG or older w/ ATmega8
    atmegang.menu.cpu.atmega8=ATmega8
    atmegang.menu.cpu.atmega8.upload.maximum_size=7168
    atmegang.menu.cpu.atmega8.upload.maximum_data_size=1024
    atmegang.menu.cpu.atmega8.bootloader.low_fuses=0xdf
    atmegang.menu.cpu.atmega8.bootloader.high_fuses=0xca
    atmegang.menu.cpu.atmega8.bootloader.file=atmega8/ATmegaBOOT-prod-firmware-2009-11-07.hex
    atmegang.menu.cpu.atmega8.build.mcu=atmega8
    robotControl.name=Arduino Robot Control
    robotControl.vid.0=0x2341
    robotControl.pid.0=0x0038
    robotControl.vid.1=0x2341
    robotControl.pid.1=0x8038
    robotControl.vid.2=0x2A03
    robotControl.pid.2=0x0038
    robotControl.vid.3=0x2A03
    robotControl.pid.3=0x8038
    robotControl.upload.tool=avrdude
    robotControl.upload.protocol=avr109
    robotControl.upload.maximum_size=28672
    robotControl.upload.maximum_data_size=2560
    robotControl.upload.speed=57600
    robotControl.upload.disable_flushing=true
    robotControl.upload.use_1200bps_touch=true
    robotControl.upload.wait_for_upload_port=true
    robotControl.bootloader.tool=avrdude
    robotControl.bootloader.low_fuses=0xff
    robotControl.bootloader.high_fuses=0xd8
    robotControl.bootloader.extended_fuses=0xcb
    robotControl.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Control.hex
    robotControl.bootloader.unlock_bits=0x3F
    robotControl.bootloader.lock_bits=0x2F
    robotControl.build.mcu=atmega32u4
    robotControl.build.f_cpu=16000000L
    robotControl.build.vid=0x2341
    robotControl.build.pid=0x8038
    robotControl.build.usb_product="Robot Control"
    robotControl.build.board=AVR_ROBOT_CONTROL
    robotControl.build.core=arduino
    robotControl.build.variant=robot_control
    robotControl.build.extra_flags={build.usb_flags}
    robotMotor.name=Arduino Robot Motor
    robotMotor.vid.0=0x2341
    robotMotor.pid.0=0x0039
    robotMotor.vid.1=0x2341
    robotMotor.pid.1=0x8039
    robotMotor.vid.2=0x2A03
    robotMotor.pid.2=0x0039
    robotMotor.vid.3=0x2A03
    robotMotor.pid.3=0x8039
    robotMotor.upload.tool=avrdude
    robotMotor.upload.protocol=avr109
    robotMotor.upload.maximum_size=28672
    robotMotor.upload.maximum_data_size=2560
    robotMotor.upload.speed=57600
    robotMotor.upload.disable_flushing=true
    robotMotor.upload.use_1200bps_touch=true
    robotMotor.upload.wait_for_upload_port=true
    robotMotor.bootloader.tool=avrdude
    robotMotor.bootloader.low_fuses=0xff
    robotMotor.bootloader.high_fuses=0xd8
    robotMotor.bootloader.extended_fuses=0xcb
    robotMotor.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Motor.hex
    robotMotor.bootloader.unlock_bits=0x3F
    robotMotor.bootloader.lock_bits=0x2F
    robotMotor.build.mcu=atmega32u4
    robotMotor.build.f_cpu=16000000L
    robotMotor.build.vid=0x2341
    robotMotor.build.pid=0x8039
    robotMotor.build.usb_product="Robot Motor"
    robotMotor.build.board=AVR_ROBOT_MOTOR
    robotMotor.build.core=arduino
    robotMotor.build.variant=robot_motor
    robotMotor.build.extra_flags={build.usb_flags}
    gemma.vid.0=0x2341
    gemma.pid.0=0x0c9f
    gemma.name=Arduino Gemma
    gemma.bootloader.low_fuses=0xF1
    gemma.bootloader.high_fuses=0xD5
    gemma.bootloader.extended_fuses=0xFE
    gemma.bootloader.tool=avrdude
    gemma.bootloader.lock_bits=
    gemma.bootloader.unlock_bits=
    gemma.bootloader.file=gemma/gemma_v1.hex
    gemma.build.mcu=attiny85
    gemma.build.f_cpu=8000000L
    gemma.build.core=arduino
    gemma.build.variant=gemma
    gemma.build.board=AVR_GEMMA
    gemma.upload.tool=avrdude
    gemma.upload.maximum_size=5310
    menu.cpu=Processor
    ## Sensebender Micro
    MysensorsMicro.name=Sensebender Micro
    MysensorsMicro.upload.tool=arduino:avrdude
    MysensorsMicro.upload.protocol=arduino
    MysensorsMicro.upload.maximum_size=30720
    MysensorsMicro.upload.maximum_data_size=2048
    MysensorsMicro.upload.speed=57600
    MysensorsMicro.bootloader.tool=arduino:avrdude
    MysensorsMicro.bootloader.unlock_bits=0x3F
    MysensorsMicro.bootloader.lock_bits=0x0F
    MysensorsMicro.bootloader.low_fuses=0xE2
    MysensorsMicro.bootloader.high_fuses=0xD2
    MysensorsMicro.bootloader.extended_fuses=0x06
    MysensorsMicro.bootloader.file=DualOptiboot/optiboot_atmega328_pro_8MHz.hex
    MysensorsMicro.build.board=AVR_MICRO8
    MysensorsMicro.build.core=arduino:arduino
    MysensorsMicro.build.variant=micro
    MysensorsMicro.build.mcu=atmega328p
    #MysensorsMicro.build.f_cpu=8000000L
    MysensorsMicro.menu.cpu.8Mhz=Atmega328 8Mhz
    MysensorsMicro.menu.cpu.8Mhz.build.f_cpu=8000000L
    MysensorsMicro.menu.cpu.1Mhz=Atmega328 1Mhz
    MysensorsMicro.menu.cpu.1Mhz.build.f_cpu=1000000L
    I'm using a Mac if it is important.
  • Is it possible to use the ftdi or isp vcc / gnd to connect a pir ?
    or do i need to source separate power and gnd for pir ?
    @gloob
    Maybe a little late, but the Sensebender is now available to be downloaded directly in the IDE using board manager.
    https://github.com/mysensors/ArduinoBoards
    @alexeinz
    You can use the same power/ground plane (and any of the digital inputs). Also note that the pir might need to be modified to handle 3v3.
    https://forum.mysensors.org/topic/1088/battery-powered-pir
  • 163
18
