Mysensors Gateway on OrangePi (Zero) (opi)
  • Code Contributor
    @Tag Maybe this one can help too:
    http://orange314.com/WiringOP
  • Code Contributor
    @Tag also, please don't set the interrupt pin for now.
  • Code Contributor
    @Tag I found more information on the wiki page about the gpio pins:
    http://linux-sunxi.org/GPIO
    It seems that there is a calculation to be made to know which number to use 😱
  • @marceloaqno
    Hi!!, many thanks for the info!! really helpful!
    Made some progress. first I created this table based on this page: http://linux-sunxi.org/GPIO
    Pin - Num - Name - Calculated value A=1 ((1-1)*32 + Pin)
    CE / 22 / PA02 / 2
    SCK / 23 / PA14 / 14
    MISO / 21 / PA16 / 16
    CSN / 24 / PA13 / 13
    MOSI / 19 / PA15 / 15
    Now it is important that you know which kernel is used on your systems the 4.x architecture is different compared to the 3.x arch...
    If the 4.x kernel is used you need to use the calculated value for the GPIO pin numbering, i could not test that since I am using the 3.x kernel, so this is what i did:
    1. load the GPIO kernel module:
    modprobe gpio-sunxi
    1. Create the GPIO device files since these were not available on my system by default.
    for A in 1 2 3 4 5 6 7 8 9 10 11 12; do echo "$A" > /sys/class/gpio/export ; done
    This created the following entries in /sys/class/gpio
    root@orangepizero:~/marceloaqno-spidev/bin# ls -l /sys/class/gpio
    total 0
    --w------- 1 root root 4096 Jan  8 07:39 export
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio1 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio1
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio11 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio11
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio12 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio12
    lrwxrwxrwx 1 root root    0 Jan  8 07:32 gpio13 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio13
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio2 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio2
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio3 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio3
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio4 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio4
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio5 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio5
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio6 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio6
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio7 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio7
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio8 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio8
    lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio9 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio9
    lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip0 -> ../../devices/platform/sunxi-pinctrl/gpio/gpiochip0
    --w------- 1 root root 4096 Jan  1  1970 unexport
    Modified mysgw.cpp to use:
    #define MY_RF24_CE_PIN 2
    #define MY_RF24_CS_PIN 13
    And did a clean build:
    make clean
    ./configure
    make
    Now some thing has changed! 🙂
    root@orangepizero:~/marceloaqno-spidev/bin# ./mysgw -d
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    Will do some more testing with an LED today see if the GPIO pin numbering that was created is okay,
    will keep you posted!:
  • @marceloaqno
    Did some testing,
    Setup the GPIO pins:
    modprobe gpio-sunxi
    for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
    done
    (The device files that are created by the commands above do not survive a reboot, so remember to execute the above commands after each reboot!)
    Hooked up an led between ground and i.e. pin 22, this pin is linked to GPIO2
    Then:
    echo out > /sys/class/gpio/gpio2/direction
    echo 1 > /sys/class/gpio/gpio2/value
    echo 0 > /sys/class/gpio/gpio2/value
    And eureka!! Led went on and off 😄
    Did this for all GPIO ports used by mysgw, below is the verified pin / GPIO table
    Pin#  -  GPIO / NRF24
    22 - GPIO2   / CE
    23 - GPIO14  / SCK
    21 - GPIO16  / MISO
    24 - GPIO13  / CSN
    19 - GPIO15  / MOSI
    Tested all pins and led went on and off on all
    How i connected the radio: https://www.mysensors.org/build/raspberry (see the Pi1 part)
    How to setup GPIO: http://linux-sunxi.org/GPIO (3.x kernel part, and added pin 13/14/15/16)
    Pinout for the OPI Zero: https://i1.wp.com/oshlab.com/wp-content/uploads/2016/11/Orange-Pi-Zero-Pinout-banner2.jpg?fit=1200%2C628&ssl=1 (carefully look at the pin numbering!)
    Maybe it is usefull, I rebuild mysgw with NRF24 radio debugging enabled, this is the output I get:
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: RF24:write register, reg=0, value=14
    mysgw: RF24:write register, reg=3, value=3
    mysgw: RF24:write register, reg=4, value=95
    mysgw: RF24:write register, reg=5, value=76
    mysgw: RF24:write register, reg=6, value=39
    mysgw: RF24:write register, reg=16, value=115
    mysgw: RF24:write register, reg=29, value=6
    mysgw: RF24:read register, reg=6, value=0
    mysgw: RF24:read register, reg=5, value=0
    mysgw: !RF24:INIT:SANCHK FAIL
    mysgw: TSM:FAIL:PDT
    mysgw: RF24:write register, reg=0, value=12
    mysgw: RF24:PD
    ^Cmysgw: Received SIGINT
    keeps looping, until ctrl-c is given.
    CE / 22 / PA02 / 482
    SCK / 23 / PA14 / 494
    MISO / 21 / PA16 / 496
    CSN / 24 / PA13 / 493
    MOSI / 19 / PA15 / 495
    Are you sure this is correct?
    The formula is: (position of letter in alphabet - 1) * 32 + pin number
    For PA02 for instance the correct value is:
    PA02 = (1 - 1) * 32 + 02 = 2
    Actually you don't need to use the formula at all with the PA ports, all you have to do is use the trailing number.
  • @mihai.aldea
    You are right, took the letter P, which is 16.... but is should have been A.... (for the 4.x kernel)
    Updated the table!,
    Thx!!
  • i have problem in build gateway on orangepi one
    root@OrangePI:~/marceloaqno-spidev# make
    Makefile:16: Makefile.inc: No such file or directory
    [Running configure]
    [OK] Finished.
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
    g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
    drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
    drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
       (void)read (fd, &c, 1) ;
    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
    In file included from ./MySensors.h:294:0,
                     from examples_linux/mysgw.cpp:74:
    ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
      hwDigitalWrite(MY_RF24_CS_PIN, level);
    ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
      hwDigitalWrite(MY_RF24_CE_PIN, level);
    ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
      hwPinMode(MY_RF24_CE_PIN,OUTPUT);
    ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
      hwPinMode(MY_RF24_CS_PIN,OUTPUT);
    ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
     LOCAL void RF24_csn(const bool level)
    ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
     LOCAL void RF24_ce(const bool level)
    ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
    ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
      RF24_csn(LOW);
    ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
      RF24_csn(HIGH);
    ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
    ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
      RF24_ce(HIGH);
    ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
    ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
      RF24_ce(LOW);
    ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
    ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
      RF24_ce(LOW);
    ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
    ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
      RF24_ce(HIGH);
    ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
      RF24_ce(LOW);
    ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
    ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
      RF24_ce(LOW);
    ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
      RF24_csn(HIGH);
    Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
    i want build a gateway with orangepi one with channel 0 . what am i do ? thank you
  • Code Contributor
    @Reza You need to run:
    modprobe gpio-sunxi
    so that /sys/class/gpio/export is created.
  • Code Contributor
    @Tag Does the TMRh20 works in the way your radio is currently connected?
  • @marceloaqno
    The library compiled, but unfortunately i cannot get the examples for linux working.
    need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
    Maybe someone following this thread who has experince with this lib?
    if there is any progress from my side will keep you posted...
  • If you used this wiring scheme:
    nRF24L01 | Orange Pi
    _________|________________
    VCC      | VCC3V3-EXT
    GND      | GND
    CSN      | SPI0_CS0 (SPI-CE0)
    CE       | PA7 (IO-7)
    MOSI     | SPI0_MOSI (SPI-MOSI)
    SCK      | SPI0_CLK (SPI-CLK)
    MISO     | SPI0_MISO (SPI-MISO)
    Then you should initialize the radio with:
    RF24 radio(7,0);
    Worked for me:
    root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
    RF24/examples/GettingStarted/
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
    RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
    TX_ADDR		 = 0x65646f4e32
    RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
    EN_AA		 = 0x3f
    EN_RXADDR	 = 0x02
    RF_CH		 = 0x4c
    RF_SETUP	 = 0x07
    CONFIG		 = 0x0e
    DYNPD/FEATURE	 = 0x00 0x00
    Data Rate	 = 1MBPS
    Model		 = nRF24L01+
    CRC Length	 = 16 bits
    PA Power	 = PA_MAX
     ************ Role Setup ***********
    Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
  • Code Contributor
    @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
    #define MY_RF24_CE_PIN 7
    #define MY_RF24_CS_PIN 0
  • @mihai.aldea
    Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
    Expansion Port
    The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
    2x13 Header
    1	3.3V	           2	5V
    3	TWI0_SDA / PA12	   4	5V
    5	TWI0_SCK / PA11	   6	GND
    7	PWM1 / PA06	       8	UART1_TX / PG06
    9	GND	               10	UART1_RX / PG07
    11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
    13	UART2_TX / PA00	   14	GND
    15	UART2_CTS / PA03   16	TWI1-SDA / PA19
    17	3.3V	           18	TWI1-SCK / PA18
    19	SPI1_MOSI / PA15   20	GND
    21	SPI1_MISO / PA16   22	UART2_RTS / PA02
    23	SPI1_CLK / PA14    24	SPI1_CS / PA13
    25	GND	               26	SIM_DET/PA_EINT10 / PA10
    From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
    If i look at /dev I only see spi0, which is most probably used for the onboard flash...
    root@orangepizero:/# ll /dev | grep -i spi
    crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
    So now i need to figure out a way to get SPI1 up and running
  • @marceloaqno Here's the output:
    ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                     from ./MySensors.h:294,
                     from examples_linux/mysgw.cpp:77:
    compilation terminated.
  • @Tag Use this info:
    http://linux-sunxi.org/Sunxi-tools
    To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
    If you haven't done this before, it's quite simple.
    apt-get install sunxi-tools
    cd ~
    bin2fex /boot/script.bin > script.fex
    Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
    Then
    fex2bin script.fex > /boot/script.bin
    Reboot, then you should have the SPI1 active.
  • @marceloaqno
    i have error yet
    orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
  • @mihai.aldea
    Yep already found it 🙂 problem was the old version of the tools, it was not able to decompile the script.bin file...
    [update]
    • modified the script file,
    • changed spi_used = 1
    • compiled back and rebooted
    just 1 device file in called spidev0.0 no new device files are created..... 😞
    dmesg output:
    [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
    [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
    [    0.815569] spi spi0: master is unqueued, this is deprecated
    [    0.816776] spi spi1: master is unqueued, this is deprecated
    Thx, will keep you posted!
  • Code Contributor
    @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
    @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
    Here it is
    root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
    [OK] Finished.
    root@opi-pc-1:~/rf24opi/MySensors# make
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
    In file included from examples_linux/mysgw.cpp:77:0:
  • Code Contributor
    @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
    rm -rf marceloaqno-spidev
    git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
    cd marceloaqno-spidev
    git checkout spidev
    ./configure
    make
  • @marceloaqno
    i have not any folder "gpio" in class folder .
    what am i do ? 😞
    can you create a new topic with all steps after full fix on orange pi ?
    thank you. i follow this topic
  • @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
    root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
    Cloning into 'marceloaqno-spidev'...
    fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
    Anyway, I found another way:
    git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
    cd marceloaqno-spidev/
    git pull origin spidev
    ./configure
    make
    This time it compiled successfuly, but when I fired up mysgw all I got was:
    with no other output.
    Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
    For reference here's the gpio readall on my OPi PC:
     +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
     | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
     |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
     |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
     |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
     |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
     |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
     |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
     |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
     |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
     |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
     |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
     |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
     |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
     |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
     |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
     |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
     |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
     |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
     |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
     |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
     |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
     +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
  • @mihai.aldea
    Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
    Look at mine:
    root@orangepizero:~# gpio readall
     |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
     |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
     |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
     |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
     |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
     |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
     |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
     |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
    It is the same... and shows 40 pins while the OPI Zero only has 26.......
    There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
  • @marceloaqno: are you planning to create a pull request? also, like @Reza suggested i think it would be smart to gather all information somehwhere, unfortunately mysensors does not seem to have a wiki. can we write an article somehow? i could take care of that.
  • Code Contributor
    @mihai.aldea sorry about the github link mistake.
    @pansen Yes, I will.
    Is the orientation of the pins correct in the image?
  • @marceloaqno
    Nope pinout is reversed!,
    The link below shows the correct one!
    https://oshlab.com/orange-pi-zero-pinout/
  • Code Contributor
    @Tag Oops, did I get it right this time (I reuploaded the image)?
  • @marceloaqno
    Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... 😞 )
    Used the follwing to for the radio:
    RF24 radio(2,0);
    Output from gettingstarted:
    root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
    STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
    RX_ADDR_P0-1     = 0x0000000000 0xff00000000
    RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
    TX_ADDR          = 0xffffffffff
    RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
    EN_AA            = 0xff
    EN_RXADDR        = 0xff
    RF_CH            = 0xbc
    RF_SETUP         = 0xff
    CONFIG           = 0xff
    DYNPD/FEATURE    = 0xff 0xff
    Data Rate        = 1MBPS
    Model            = nRF24L01
    PA Power         = PA_MAX
  • Code Contributor
    @Tag Could you fill this table with your current setup?
    nRF24L01 | OrangePi  | OrangePi
             | phyPin    | GPIO
    _________|_______________________
    VCC      | 3V3-PWR   | 3V3-PWR
    GND      | GND       | GND
    CSN      |           |
    CE       |           |
    MOSI     | 19        | 15
    SCK      | 23        | 14
    MISO     | 21        | 16
  • @marceloaqno
    Sure here it is,
             | phyPin    | GPIO
    GND      | GND       | GND
    CSN      | 24        | 13
    CE       | 22        | 2
    MOSI     | 19        | 15
    SCK      | 23        | 14
    MISO     | 21        | 16
    Radio seems to be recognised, still need to test data transfer...
  • Code Contributor
    I created the draft for the official article: https://www.mysensors.org/build/orange
    @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
  • @marceloaqno
    @mfalkvidd @Tag @pansen @Reza @mihai.aldea @hausinger
    Wooow woow woow !!!
    Only few days "off" and the problem to make work Mysensors on OPI are solved.
    So many many thanks to all people here that have been involved to make that OPI good little boards can work with Mysensors.
    This is the proof that when good people join can reach the most difficult achievements and all humanity can benefit.
    Awesome work !
    Regards
  • @marceloaqno
    Great work!!! the GPIO part most probably needs some additions for OPI zero on the topic of the spidev1.0 driver and the GPIO pins, send it to you once i got everything documented.
    Really many thanks for your hard work here!!
  • @marceloaqno
    thank you. but i have error:
    root@OrangePI:~# ls /sys/class/gpio/export
    ls: cannot access /sys/class/gpio/export: No such file or directory
    root@OrangePI:~# modprobe gpio-sunxi
    in class folder i dont have gpio folder (i use a orangepi one with ubuntu os )
    i
  • @Reza
    You need to create the files after each boot.
    After the modprobe, Issue this command:
    sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
    This will get you the files.
  • root@OrangePI:~# git clone https://github.com/marceloaqno/MySensors.git orangepi               Cloning into 'orangepi'...
    remote: Counting objects: 13858, done.
    remote: Compressing objects: 100% (50/50), done.
    remote: Total 13858 (delta 17), reused 0 (delta 0), pack-reused 13808
    Receiving objects: 100% (13858/13858), 9.68 MiB | 79.00 KiB/s, done.
    Resolving deltas: 100% (8304/8304), done.
    Checking connectivity... done.
    root@OrangePI:~# cd orangepi/
    root@OrangePI:~/orangepi# git pull origin spidev
    From https://github.com/marceloaqno/MySensors
     * branch            spidev     -> FETCH_HEAD
    Updating 570b607..63e1a81
    Fast-forward
     Makefile                                          |  16 +++
     MyConfig.h                                        |   4 +
     MySensors.h                                       |   2 +-
     configure                                         |  79 ++++++++++---
     core/MyHwLinuxGeneric.cpp                         |  17 +++
     core/MyHwLinuxGeneric.h                           |  12 +-
     core/MyHwRPi.cpp                                  |   1 +
     core/MyHwRPi.h                                    |  28 -----
     core/MyMainLinux.cpp                              |  30 ++---
     drivers/{RPi => BCM}/SPI.cpp                      |  10 +-
     drivers/{RPi => BCM}/SPI.h                        | 116 ++++++++++++-------
     drivers/{RPi => BCM}/Wire.cpp                     |   0
     drivers/{RPi => BCM}/Wire.h                       |   1 +
     drivers/Linux/Arduino.h                           |  22 +++-
     drivers/Linux/GPIO.cpp                            | 119 ++++++++++++++++++++
     drivers/Linux/GPIO.h                              |  47 ++++++++
     drivers/Linux/Stream.h                            |   1 +
     drivers/Linux/compatibility.cpp                   |  11 +-
     drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} | 144 +++++-------------------
     drivers/Linux/interrupt.h                         |  45 ++++++++
     drivers/RF24/RF24.cpp                             |   4 +-
     drivers/RF24/RF24.h                               |   2 +-
     drivers/RPi/RPi.cpp                               |  59 ++++++++++
     drivers/RPi/RPi.h                                 |  22 ++++
     drivers/RPi/piHiPri.c                             |  49 --------
     drivers/RPi/rpi_util.h                            |  76 -------------
     drivers/RPi/wiring.cpp                            |  72 ++++++++++++
     drivers/RPi/wiring.h                              |  24 ++++
     drivers/SPIDEV/SPI.cpp                            | 223 +++++++++++++++++++++++++++++++++++++
     drivers/SPIDEV/SPI.h                              | 178 +++++++++++++++++++++++++++++
     30 files changed, 1054 insertions(+), 360 deletions(-)
     rename drivers/{RPi => BCM}/SPI.cpp (100%)
     rename drivers/{RPi => BCM}/SPI.h (62%)
     rename drivers/{RPi => BCM}/Wire.cpp (100%)
     rename drivers/{RPi => BCM}/Wire.h (99%)
     create mode 100644 drivers/Linux/GPIO.cpp
     create mode 100644 drivers/Linux/GPIO.h
     rename drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} (63%)
     create mode 100644 drivers/Linux/interrupt.h
     create mode 100644 drivers/RPi/RPi.cpp
     create mode 100644 drivers/RPi/RPi.h
     delete mode 100644 drivers/RPi/piHiPri.c
     delete mode 100644 drivers/RPi/rpi_util.h
     create mode 100644 drivers/RPi/wiring.cpp
     create mode 100644 drivers/RPi/wiring.h
     create mode 100644 drivers/SPIDEV/SPI.cpp
     create mode 100644 drivers/SPIDEV/SPI.h
    root@OrangePI:~/orangepi# ./configure
    [OK] Finished.
    root@OrangePI:~/orangepi# make
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
    g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
      RF24_csn(LOW);
      RF24_csn(HIGH);
      RF24_ce(HIGH);
      RF24_ce(LOW);
      RF24_ce(LOW);
      RF24_ce(HIGH);
      RF24_ce(LOW);
      RF24_ce(LOW);
      RF24_csn(HIGH);
    root@OrangePI:~/orangepi#```
  • @Tag
    root@OrangePI:~/orangepi# sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
    -bash: syntax error near unexpected token `do'
    root@OrangePI:~/orangepi# ```
    orangepi one have 40 pins
  • Code Contributor
    @Reza Is there /sys/class/gpio/export file on your OPi?
  • @marceloaqno
    no i have not folder "gpio" in my orangepi
  • @marceloaqno It still doesn't work on my OPi Zero 😕
    root@opi-zero-1:~/orangepi# bin/mysgw -d
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:FAIL:PDT
    I do have the /sys/class/gpio/export and I ran for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
    For the record, here's my OS:
    BOARD=orangepizero
    BOARD_NAME="Orange Pi Zero"
    VERSION=5.24
    LINUXFAMILY=sun8i
    BRANCH=default
    ARCH=arm
    PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
    NAME="Debian GNU/Linux"
    VERSION_ID="8"
    VERSION="8 (jessie)"
    ID=debian
    HOME_URL="http://www.debian.org/"
    SUPPORT_URL="http://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
  • Code Contributor
    @mihai.aldea The gateway does the exporting when needed, you don't need to run:
    Could you send the output of this command?
    ls -lah /dev/spidev*
  • @marceloaqno
    Still issues here:
    root@orangepizero:~/orangepi/bin# ll /dev/spi*
    crw------- 1 root root 153, 0 Jan  9 22:51 /dev/spidev0.0
    crw------- 1 root root 153, 1 Jan  9 22:51 /dev/spidev1.0
    Then:
    ./configure --spi-spidev-device=/dev/spidev1.0
    added to examples_linux/mysgw.cpp
    end enabled radio debugging:
    output:
    root@orangepizero:~/orangepi/bin# ./mysgw -d
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: RF24:read register, reg=6, value=39
    mysgw: RF24:read register, reg=5, value=76
    mysgw: RF24:write register, reg=2, value=2
    mysgw: RF24:write register, reg=1, value=0
    mysgw: RF24:write register, reg=28, value=3
    mysgw: RF24:flushRX
    mysgw: RF24:flushTX
    mysgw: RF24:write register, reg=7, value=112
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: RF24:write register, reg=2, value=3
    mysgw: RF24:write register, reg=1, value=1
    mysgw: RF24:STRT LIS
    mysgw: RF24:write register, reg=0, value=15
    mysgw: RF24:write register, reg=10, value=0
    mysgw: MCO:REG:NOT NEEDED
    mysgw: RF24:read register, reg=23, value=17
    Illegal instruction
    Almost there?
  • @marceloaqno
    in "orangepi one"(ubuntu os) there is not gpio folder in sys/class. but i think after run "modprobe gpio-sunxi" built a folder that name is "gpio_sw" and in this folder there are this files: normal_led,pa3,pa6,pa8 and 9,10,13,14,15,21 ,...
  • @Reza Is it too complicated to switch to Debian?
    you told me i change my os ? to armbian ?
  • @Reza
    More info on armbian.com
    I use the debian jessie, works like a charm!
  • @Reza I wouldn't even dream of not using Armbian on OrangePi and NanoPi. Compared to Raspbian it's years ahead in terms of optimization and tidyness. Armbian is the reason I'm avoiding RPi when possible. So go ahead and install a proper OS for your OPi. Not sure if Xenial or Debian, maybe we should wait for @marceloaqno to respond to my comment with the running OS.
  • @Tag
    i worked with armbiam before. but my question is with armbian my problem is resolve ?
  • That I can not say.
    ok i change my os and test again. thank you
  • I confirm it's not working on the OPi PC where TMRh20 works.
    Got it spot on!! looks great!
  • i have problem with compile source domoticz(i must use source domoticz for my changes) in armbian, so i have to use ubuntu.
    @marceloaqno can you help me to run mysensors gateway in orangepi one (ubuntu os).thank you
  • Hi All,
    I put together the steps to get MySensors running on the OrangePi Zero:
    Take note of the SPI part, 1 typo and you will not see /dev/spidev1.0
    sudo apt-get update
    sudo apt-get install sunxi-tools
    • How to add /dev/spidev1.0 (which is required since /dev/spidev0.0 is used for the onboard NAND flash)
    cd /boot
    bin2fex /boot/script.bin /root/myscript.txt
    Now edit /root/myscript.bin and add/change the following so it looks exactly like the part below:
    [spi0]
    spi_used = 1
    spi_cs_bitmap = 1
    spi_mosi = port:PC00<3><default><default><default>
    spi_miso = port:PC01<3><default><default><default>
    spi_sclk = port:PC02<3><default><default><default>
    spi_cs0 = port:PC03<3><1><default><default>
    [spi1]
    spi_used = 1
    spi_cs_bitmap = 1
    spi_cs0 = port:PA13<2><1><default><default>
    spi_sclk = port:PA14<2><default><default><default>
    spi_mosi = port:PA15<2><default><default><default>
    spi_miso = port:PA16<2><default><default><default>
    [spi_devices]
    spi_dev_num = 2
    [spi_board0]
    modalias = "spidev"
    max_speed_hz = 33000000
    bus_num = 0
    chip_select = 0
    mode = 0
    full_duplex = 1
    manual_cs = 0
    [spi_board1]
    modalias = "spidev"
    bus_num = 1
    chip_select = 0
    mode = 0
    full_duplex = 1
    manual_cs = 0
    • Then recompile the script file:
    fex2bin /root/myscript.txt /boot/script.bin
    Reboot the system
    reboot
    2 device files should exist now:
    root@orangepizero:~# ls -l /dev/spi*
    crw------- 1 root root 153, 0 Jan 11 16:31 /dev/spidev0.0
    crw------- 1 root root 153, 1 Jan 11 16:31 /dev/spidev1.0
    Load the gpio module
    modprobe gpio-sunxi
    To load the module gpio-sunxi automagically load at boot time, add gpio-sunxi to /etc/modules
    echo gpio-sunxi >> /etc/modules
    • Now it is time to install the GW.
    cd /root
    cd orangepi/
    make
    Working like a charm!
    If you tested "/bin/mysgw -d" and all works as expected, make the installation permanent:
    make install
    Additional
    If you want to read data into a controller using a device file (i.e Mycontroller) use the build string below
     ./configure --spi-spidev-device=/dev/spidev1.0  --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
    Hope this helps!! have fun!!
  • Code Contributor
    @Tag great! Thanks for the detailed explanation 👏
    I will add to the instructions page
  • out of curiousity: this all relates to 3.x kernel in armbian right? which has proprietary stuff in there?
    i read somewhere that mainline 4.10 SPI is "work in progress"
  • @pansen
    Yes correct, for OPI Zero only ARMbian 3.x is available as a download image.
    I used the debian jessie one
  • Code Contributor
    Instructions page updated, let me know if there is any mistake.
  • @marceloaqno
    looks great!! thx!!👍
  • Excellent work !!! It finally works, I believe the slight mistake was with the damn SPI device ID. Now that I've enabled /dev/spidev1.0 everything works perfect. Really nice job and awesome commitment to showing people that it's time for them to pull their heads out of their a.... and spend less for way more awesome boards because let's face it, RPi has the greatest community support but it's a nothing more than an expensive closed source crappy board.
  • @mihai.aldea
    Great!!, found out the SPI0 is used for the NAND flash, once you add SPI1 to the script.bin, also the need board paragraph with bus 1 needs to be added otherwise it will not work.... anyway great you got mysensors up and running!!
    About the RPI, i like both boards, and in my opinion the enormous success of the RPI is responsible, for the large collection of OPI boards that is available these days 😉
  • There are few who know that lots of asian compaines were producing SBC's long before RPi ever existed. RPi has to take credit for the SBC boom, but the connaisseurs will always prefer a top notch SBC that costs less than half of an RPi and is piled with features. Take the OPi Zero for instance, it's way smaller than RPi 3, has half the RAM and doesn't have Bluetooth. But you can buy 4 OPi Zeros with the money you'd spend on an RPi 3.
    Anyway it's an endless debate here, I'm just glad I could help a bit bringing this to life, even though you and @marceloaqno did the heavy lifting.
    Thank you for the hard work guys, I have a fresh orange pi zero and I will install armbian and try this hack as soon as possible. Looks like a great way to have an ultra compact&cheap controller + gateway system !
  • Code Contributor
    Support for OrangePi is now part of the official MySensors development repository.
    In the official version, it is necessary to define the CE and CS pins, as the default ones will not work. This will change in the future, but more work needs to be done to better detect the different types of Orange Pi and other H3 soc boards.
    For now, if you have set your system in the same way as the wiring instructions, use:
    ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
  • @marceloaqno
    Thank you for your hard work and continued support on this!!
  • @mihai.aldea
    It's working on my OPi One with Armbian. MySensors and TMRh20 works!
    Only in ./MySensors: bin
    Only in ./MySensors: build
    diff -ruBdX ex ./_MySensors/drivers/RF24/RF24.cpp ./MySensors/drivers/RF24/RF24.cpp
    --- ./_MySensors/drivers/RF24/RF24.cpp<>2017-01-28 10:24:03.557215399 +0200
    +++ ./MySensors/drivers/RF24/RF24.cpp<->2017-01-28 10:58:51.757543157 +0200
    @@ -29,7 +29,7 @@
     LOCAL RF24_receiveCallbackType RF24_receiveCallback = NULL;
    -#ifdef LINUX_SPI_BCM
    +#if defined (LINUX_SPI_BCM) || (LINUX_SPI_SPIDEV)
     uint8_t spi_rxbuff[32+1] ; //SPI receive buffer (payload max 32 bytes)
     uint8_t spi_txbuff[32+1] ; //SPI transmit buffer (payload max 32 bytes + 1 byte for the command)
    @@ -56,7 +56,7 @@
     <----->RF24_csn(LOW);
     <----->// timing
     <----->delayMicroseconds(10);
     <----->uint8_t * prx = spi_rxbuff;
     <----->uint8_t * ptx = spi_txbuff;
     <----->uint8_t size = len + 1; // Add register value to transmit buffer
    diff -ruBdX ex ./_MySensors/Makefile.inc ./MySensors/Makefile.inc
    --- ./_MySensors/Makefile.inc<->2017-01-28 10:49:53.990638008 +0200
    +++ ./MySensors/Makefile.inc<-->2017-01-28 11:12:57.601198157 +0200
    @@ -1,5 +1,5 @@
     SOC=H3
    -CPPFLAGS=-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV.
    +CPPFLAGS=-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DLINUX_SPI_SPIDEV -DMY_RF24_CE_PIN=7 -DSPI_S
     LDFLAGS=-pthread.
     PREFIX=/usr/local
     CC=gcc
  • Hi all
    I want to give feedback here.
    Today i tried to build a orange pi gateway with a connected usb - rs485 converter on it. And what should I say - It worked without problems. Many thanks to you all 🙂
    Great
  • Hi to all, I don't know if this is the right thread, but I'm trying to use an odroid c1 as a gateway. I'm posting here because I think you all could help me.
    The original thread I have done is this one
    https://forum.mysensors.org/topic/6083/odroid-c1-as-getaway
    Feel free to go over there and give me advises.
