NodeManager: plugin for a rapid development of battery-powered sensors
  • Thanks for the reply.
    I have no idea about the platform.txt file so I will wait to see if someone much smarter than me can figure it out 🙂
    If it helps, I am using the Arduino IDE V.1.81, compiling with a custom atmega328p board running at 8MHz with BOD disabled.
    Ben
    Oh I see, when you have custom hardware sometimes you have different options set for the compiler, this is why with the default settings works here. Nevertheless it is an easy fix on my side, just wait for v1.3 to be out very soon and it should compile without issues.
    Hi, I've updated NodeManager to its 1.3 version. This should also solve your issue @Ben-Coton. Short changelog:
    • Added support for BME280 temperature/humudity/pressure sensor
    • Added option to measure battery level via a pin in addition to internal Vcc
    • Added example sketches to the documentation
    • Fixed a few bugs
    Code and updated documentation (now with with four comprehensive examples including the full sketches at the end) on https://github.com/mysensors/NodeManager
  • @user2684 , Thanks for the new version.
    Are you planning to include Virtual Button and IOExpander(MCP23017) support too? Thst would really help especially adding consistent child-ids for the expander pins, just like multiple temp sensors on the SPI bus...
    @vikasjee I'm very open to whatever can make the life of an average user easier, so far I've just pitched what were common requirements for me as a new user but I'm sure there is a lot more that I'm missing. Give me some more info or pointers regarding Virtual Button and IOExpander and how you are using it right now, I couldn't find much here on the forum and my knowledge is limited and I'll look into it for sure!
  • A long time reader and "lurker" here, but just registered today to thank @user2684 for this contribution to MYS Community! In my opinion NodeManager is really a great addition to MYS!
  • I just started playing with this and must say FANTASTIC! This makes things almost too simple.
    I found a few small things´(bugs?)
    • You refer to the sourforge page for the latest releases (nit pick)
    • Baud in the config.h is default set to 9800, shouldn't this be 9600? However, setting it to whatever doesn't help, only 4800 outputs anything, this could be something on my setup as well ...
    Again, thanks!
    It sounds absolutely terrific ! 👍
    Thank you very much !
    @Efflon thanks for reporting these two issues, I'll track them down with https://github.com/mysensors/NodeManager/issues/34 and https://github.com/mysensors/NodeManager/issues/33 and fix asap!
    Thank you all for your comments!
  • @user2684 Excellent!
    A question, I'm doing a simple door sensor
      nodeManager.setBatteryMin(1.8);
      nodeManager.setBatteryMax(3.2);
      nodeManager.setBatteryReportCycles(1);
      int door = nodeManager.registerSensor(SENSOR_DOOR,3);
      ((SensorDoor*)nodeManager.get(door))->setDebounce(500);
      nodeManager.setSleep(SLEEP,1,HOURS);
    Now, the node is constantly sending. It seems as if every wake-up triggers a sending, and a wakeup from the debounce sleep, then battery reporting etc.. Removing the debounce helps and lets the node sleep.
    AWAKE
    SEND D=0 I=200 C=1 T=48 S=AWAKE I=0 F=0.00
    BATT V=3.16 P=97
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.16
    SWITCH I=1 P=3 V=0
    SEND D=0 I=1 C=1 T=16 S= N=0 F=0.00
    SLEEP 60s
    SEND D=0 I=200 C=1 T=48 S=SLEEPING I=0 F=0.00
    [here i "open" the door]
    WAKE P=3, M=1
    AWAKE
    BATT V=3.16 P=97
    SWITCH I=1 P=3 V=1
    SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
    SLEEP 60s
    [just a second wait]
    WAKE P=3, M=1
    AWAKE
    BATT V=3.16 P=97
    SWITCH I=1 P=3 V=1
    SLEEP 60s
    [repeated until closing "door"]
    Edit:
    I changed the sleep to a wait and now the behavior is correct (this line).
    // what do to during loop
    void SensorSwitch::onLoop() {
      // wait to ensure the the input is not floating
      if (_debounce > 0) wait(_debounce);
      // read the value of the pin
      int value = digitalRead(_pin);
    MY I=8 M=1
    SEND D=0 I=200 C=0 T=48 S=STARTED I=0 F=0.00
    SWITCH I=1 P=3 V=0
    SEND D=0 I=1 C=0 T=16 S= N=0 F=0.00
    SLEEP 60s
    [open]
    WAKE P=3, M=1
    AWAKE
    BATT V=3.16 P=97
    SWITCH I=1 P=3 V=1
    SLEEP 60s
    [close]
    WAKE P=3, M=1
    AWAKE
    BATT V=3.16 P=97
    SWITCH I=1 P=3 V=0
    SLEEP 60s
    Thanks for the hit @Efflon! I accidentally fixed that sleep() in the v1.4 dev branch this afternoon because of another issue. Is everything else now behaving correctly?
    I have a concern regarding battery level reports when operating with interrupts: right now I do not distinguish between a cycle because a full sleep has completed from a cycle interrupted by an interrupt like in this case. This may cause a lot more battery reports, depending on how often the sensor triggers. To avoid this unexpected behavior, in the dev branch the default behavior is now the opposite: waking up from an interrupt does not count as a cycle. The drawback though is that if the sensor triggers continuously, it will never report the battery to the controller since unable to complete a full sleeping cycle. This is why I've added the following so allow the user to pick up the policy he likes the most:
    // If true, wake up by an interrupt counts as a valid cycle for battery reports otherwise only uninterrupted sleep cycles would contribute (default: false)
    void setBatteryReportWithInterrupt(bool value);
    In case you want to give this a try, the dev branch is available at https://github.com/mysensors/NodeManager/tree/v1.4-dev. You just need to replace the existing NodeManager.cpp and NodeManager.h files, you can keep both your sketch and your config.h.
  • @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
    This is tricky. Myself uses the battery report as a heartbeat on top of checking the battery level, thus I only need the info once or twice a day. Not sending on wake-up is good since it will preserve battery. I guess a combination the right sleeping time and cycle count could end up quite ok. For a front door sensor, 4h sleep and 2 cycle count would report battery level after the night and then maybe one more time, max 3 times per day, which is more than enough. I'll test the dev branch after some sleep 😄
    Btw, great work!! and yes, using wait works just fine, no other issues so far.
  • Hello everyone, you can send commands to the node by domoticz even if the node is in sleep forever? Or the node must always have a sleep delay?
  • @mar.conte if it's sleeping, it will not receive anything until wake-up. If you change the sleep mode to wait,
    nodeManager.setSleepMode(WAIT);
    [or]
    nodeManager.setSleep(WAIT,1,HOURS);
    the sensor will be awake all the time (and drain your battery).
    @Efflon glad to see you found out the right balance for you needs. Based on what you are saying I probably want change the default value of setBatteryReportWithInterrupt() back to true, in this way the new version will present the same behavior as the old one but can be changed at any time by the user. Of course if anybody has a different view, please let me know.
    @Efflon @mar-conte, if the sensor is powered by batteries, I'll leverage smart sleep which NodeManager is using by default. Smart sleep is btw the reason why I moved into MySensors: since all of my sensors are battery powered, I needed a way to send commands also in this situation.
    There is no overhead for the sensor in terms of code (it just needs to wake up periodically to receive commands) and on the controller side the implementation is very simple: once the controller knows the node is a sleeping one, it will queue the commands and send them once the node is awake next (when using smart sleep, a heartbeat is reported once the node is awake and just before going to sleep again).
    I'm using this since a while for my boiler controller without issue: the node controls a (latching) relay and goes through a 5 minutes sleeping cycle with the controller (I'm using my https://www.mysensors.org/controller/myhouse) queuing the on/off command. This will introduce a little delay (1-5 minutes in my case) but can be adapted with a shorter/longer sleeping cycle.
  • @user2684
    a really interesting project, however I would use NodeManager to query each time the battery status of my pir sensor; I would like to know how I can send from domoticz commands to query my node !! thank you
    what's the point of querying node for battery status? Just put in the code to report it when battery level changes.
    @mar.conte if you want to query the battery level on-demand, you can by sending to NodeManager's service child id (by default 200) a REQ V_CUSTOM message with BATTERY as a payload.Of course the node must be awake to respond or the controller must support smart sleep. Or as @gohan says, just have the node reporting the battery level
  • @user2684
    Tanks i try and report you
    By
    first of all, thanks to user2684 for his great job.
    I wonder if it would possible adding a feature in nodeManager, where after a wake up from interrupt, only the onLoop method of the sensor attached to that pin is executed. onLoop of sensors not attached to interrupt are executed only after a full sleep cycle. (of course, this requires that after a wakeup from interrupt, the node come to sleep only for (sleepTime - elapsedTimeBeforeWakeup) )
    In my case, I have a sketch for a node with a temperature and door sensor. Temperature is sent each 60 minutes, while door status only on interrupt.
    @rhaymo you're right, combining sensors waking up from an interrupt and sensors reporting periodically does not work properly with NodeManager right now. I've opened this enhancement request: https://github.com/mysensors/NodeManager/issues/41.
    It may be not trivial to implement so it will not be part of the next release which is almost ready but I'll work on it just after since looks like a key requirement for many projects.
  • @user2684 Great plugin, thanks. Please: consider adding support for a more than one DS18B20 devices and fixed mapping sensor_id <-> DS18B20 id.
  • Hi User2684,
    As promised i took NodeManager for a spin. It functions well but i have an issue with powering a DHT22 from the digital pins. It just does not show any temp/hum. If i use the power from the battery it functions well.
    Any clue what this could be?
    I used setPowerPins6,7,10000 to be sure the DHT22 has enough time to start up. If i use my multimeter between pins 6,7 i see the voltage going to 3.something volts and to 0 when the 10000 miliseconds are gone.
    My config is as following;
    // before
    void before() {
      Serial.begin(MY_BAUD_RATE);
       * Register below your sensors
      nodeManager.setSleep(SLEEP,1,MINUTES);
    nodeManager.registerSensor(SENSOR_DHT22,3);
    nodeManager.setPowerPins(6,7,10000);
       * Register above your sensors
      nodeManager.before();
  • @Robbie_ I've NOT checked anything but I think that probably better:
    1. power up DHT
    2. wait a little to "dht startup"
    3. register sensor
  • @bilbolodz
    So like this?
  • @Robbie_ said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Try this:
    wait(10000);
    nodeManager.registerSensor(SENSOR_DHT22,3);```
  • @bilbolodz said in NodeManager: plugin for a rapid development of battery-powered sensors:
    wait(10000);
    Thanks for the fast reply! Still the same issue;
    14258 TSF:MSG:SEND,100-100-0-0,s=200,c=1,t=48,pt=0,l=7,sg=0,ft=0,st=OK:STARTED
    14395 MCO:BGN:INIT OK,TSP=1
    ON P=7
    14426 MCO:SLP:MS=10000,SMS=0,I1=255,M1=255,I2=255,M2=255
    14493 MCO:SLP:TPD
    14512 MCO:SLP:WUP=-1
    DHT I=1 T=nan
    OFF P=7
    SLEEP 60s
    @bilbolodz multiple DS18B20 are supported indeed, when you register a DS18B20 sensor and provide the pin where multiple devices are attached, NodeManager will go through all of them (by calling getDeviceCount() of DallasTemperature) and will register each of them with a different child id. Is this what you were looking for?
    Hi, @Robbie_ the order doesn't matter since all of this is happening inside before(), NodeManager just keeps track of all your settings without doing anything at that stage.
    Your configuration looks correct to me, the DHT sensor attached to pin 3, pin 6 playing the role of ground, pin 7 the role of vcc and waiting for 10 seconds after powering on, before actually reading the value from the sensor. The log also tells the same story, pin 7 is turned on, then 10s of sleep and then the "nan" read which I cannot really understand (the code is very simple, just executes a digitalWrite(_vcc_pin, HIGH) at that stage).
    Would you please ensure pin 7 is HIGH during the 10s sleep?
    Not sure if it matters (and those more expert than me with a DHT sensor can confirm) but I've noticed that I call dht.begin() only once (during before()) and during loop() I just call readTemperature(). Does powering off the sensor have an impact on this? e.g. should I call begin() before every read?
    I think you need to call the begin if you power off the sensor
    Multiple sensors: great but for me important thing is "fixed" matching exact DS18B20 to particular child id. I'm going to monitor may two function water boiler and check input/output temperature. In case when one of the DS disappear (because of many reasons) after next nodemanager device startup assigning sensors to child id will change and it will be a great problem. That's why I'm asking for exact assigning DS id - child id. Is it clear now?
    Thanks @gohan. @Robbie_ if you can then try copying that "_dht->begin();" you have in line 576 of NodeManager.cpp also at the beginning of "SensorDHT::onLoop()" which is just below we can see if this can help (unfortunately I don't have anymore a DHT sensor to test by myself).
    Another try would be to disable both MySensors and NodeManager debug: I've seen strange behaviors happening when approaching the dynamic memory limit (including this) and since objects are allocated dynamically, it could be the case (this issue is partially mitigated in the dev branch)
    @bilbolodz I understand what you are saying. I've opened this: https://github.com/mysensors/NodeManager/issues/42. I did not consider this use case before because according to DallasTemperature documentation the attached sensors are always returned in the same order but you're right, if one of the sensor for any reason is not detected, it will mess up your logic. Thanks for reporting it.
  • @user2684 Great, so I'm waiting for version 1.4. Any ideas about timeline?
  • @user2684 This is exactly i had mentioned in my requirement for IOExpanded pins attached to any sensor or virtual buttons... getting the same child_id everytime. Hope its clear now...
  • @user2684 Thanks for your reply. Ive tested the following;
    i editted the NodeManager.cpp and added _dht->begin(); to the beginning of "SensorDHT::onLoop()"
    I also disabled both debug, still the same issue.
    In your other post you mentioned "Would you please ensure pin 7 is HIGH during the 10s sleep?"
    My log looks as following;
    PWR G=6 V=7
    REG I=1 P=3 P=6 T=0
    REG I=2 P=3 P=7 T=1
    NodeManager v1.30
    INT1 M=255
    INT2 M=255
    RADIO OK
    PRES I=200, T=23
    PRES I=201, T=30
    BATT V=3.26 P=94
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.26
    PRES I=1 T=6
    PRES I=2 T=7
    READY
    MY I=100 M=1
    ON P=7
    DHT I=1 T=nan
    OFF P=7
    SLEEP 60s
    AWAKE
    ON P=7
    DHT I=1 T=nan
    OFF P=7
    SLEEP 60s
    Where do you want me to messure if the pin is on?
    AWAKE
    ON P=7
    DHT I=1 T=nan
    <------------------------ I messured here and the voltage is 3.something volts
    OFF P=7
    SLEEP 60s
    <--------------------------- HERE?
    use a multimeter and check if pin 7 during the startup of the arduino and see if you get 5v out for 10 seconds
    @bilbolodz v1.4 is actually ready, just want to see if the DHT issue discussed here requires a code fix or not before releasing but it is already available in the dev branch (https://github.com/mysensors/NodeManager/tree/8280de908929a117287a70e73cd047f50ab9a5bb). Let me explain the way I have implemented it because may look cumbersome but I didn't want to make exceptions and have a sensor configured in a different way the all the others.
    First of all, for any sensor, the child id can be manually assigned by providing a third argument to registerSensor(), e.g. to assign child id 5:
    nodeManager.registerSensor(SENSOR_THERMISTOR,A1,5);
    This was available also in v1.3 but not very clear from the docs. Of course this approach does not work when you have multiple DS18B20 sensors attached since they are all configured with a single line.
    So I have implemented a renameSensor() function which basically assign a different child id, e.g. to give the sensor with child id 1 the child id 5:
    nodeManager.renameSensor(1,5);
    This is available for all the sensors. So in the case of multiple DS18B20 you need to register them all in the usual way ( registerSensor(SENSOR_DS18B20,pin)) then assign the child id you like just after so in case one is lost, you still have a static mapping. The alternative would have been to provide a special registerSensor only for DS18B20 which I don't like that much. Any other better alternative of course is more than welcome!
    Btw, I have also added for DS18B20 getDeviceAddress() - in case you want to assign the child id based on the device address, getResolution() and setResolution()
    @Robbie_ even if unfortunately I do not have a spare DHT sensor to test right now, I did some tests with other sensors trying to understand the issue. My educated guess it that the problem is related to the fact that setPowerPins() set both ground and vcc but initialize both to LOW. This means that when you register the sensor (and the DHT library is initialized), the sensor is off. This behavior will be changed in v1.4 (vcc wil be set to high). What you can do with the version you are currently running is to call nodeManager.powerOn() just after the call to setPowerPins() and before registering the sensor so to keep the power on.
    If this does not work, try calling nodeManager.setAutoPowerPins(false) after setPowerPins(): this prevent nodeManager to turn the power off which is not what you want but can help in isolating the issue.
  • Hello, good work !!! I'll be trying your extension very soon....
    Quick question: is it compatible with ATMEGA chips flashed with MYSBootloader pre-1.3a ?
    @luizrrocha I did not test it by myself but the bootloader used should have no impact on the code (unless you need to call different/specific functions with that bootloader but I guess this is not the case).
  • @user2684 Ive tested this morning a DHT22 without resistor between VIN & DATA, now it works correct. I reverted the changes back and just use the default code (1.3), everything keeps functioning. I don't understand why it works but hey, i got data! 🙂
    Somehow the following issue pops up with domoticz (also before the DHT22 was working), im not sure if anybody can help me here with it, else il open a threat at the domoticz forum. As soon ase NodeManager presents itself (via ESP8266 WiFi Gateway // MyS v2.1.0) to domoticz, domoticz goes offline. Does somebody else had the same experiance?
  • @Robbie_ Narrowed down the issue with domoticz, if i #define SERVICE_MESSAGES 1 in config.h domoticz crashes, if i put it back to 0 it stays online.
    @Robbie_ glad to see it is working now! It has been still a good excuse for me to review and correct the logic of the power pins. Regarding SERVICE_MESSAGES, NodeManager sends a set of V_CUSTOM, SET messages from its service child id 200. When starts, it sends a STARTED payload , when going to sleep SLEEPING and when out of sleep AWAKE. I'm not familiar with domoticz but the service child id is presented correctly as S_CUSTOM, maybe the controller does not expect or handle a string payload. However, if you disable SERVICE_MESSAGES, this has no impact on the way NodeManager works, it just does not send those messages but if you are not using them, you are ready to go.
    In future versions I should probably even disable SERVICE_MESSAGES by default also because I expect it costs in terms of battery to send string payloads...
    Hi, v1.4 is out and available at https://github.com/mysensors/NodeManager:
    • Added support for ML8511 UV intensity sensor
    • Added support for MQ air quality sensor
    • Added ability to manually assign a child id to a sensor
    • Ensured compatibility for non-sleeping nodes
    • Ability to control if waking up from an interrupt counts for a battery level report
    • When power pins are set the sensor is powered on just after
    • Service messages are disabled by default
    • Bug fixes
    Full changelog at https://github.com/mysensors/NodeManager/milestone/4?closed=1
    I am trying to sketch a simple PIR motion as an example the official NodeManager but does not appear to me the pir of domoticz
    DOMOTICZ OUTPUT
    1	S_TEMP		#1. V_TEMP (56.5)	true	1200	2017-04-09 12:11:15
    200	S_CUSTOM			true	1200	2017-04-09 11:34:45
    201	S_MULTIMETER			true	1200	2017-04-09 12:11:15
    255	S_ARDUINO_NODE	2.1.1```
    SKETCH
    NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
    NodeManager includes the following main components:
    - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
    - Power manager: allows powering on your sensors only while the node is awake
    - Battery manager: provides common functionalities to read and report the battery level
    - Remote configuration: allows configuring remotely the node without the need to have physical access to it
    - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
    Documentation available on: https://mynodemanager.sourceforge.io
    // load user settings
    #include "config.h"
    // load MySensors library
    // load NodeManager library
    #include "NodeManager.h"
    // create a NodeManager instance
    NodeManager nodeManager;
    // before
    void before() {
      nodeManager.setSleep(SLEEP,60,MINUTES);
      nodeManager.registerSensor(SENSOR_MOTION,3);
    // presentation
    	sendSketchInfo(SKETCH_NAME,SKETCH_VERSION);
      nodeManager.presentation();
    // setup
      nodeManager.setup();
    // loop
      nodeManager.loop();
    // receive
      nodeManager.receive(message);
    Thanks for support but actually in case of multiple DS18B20 your "general solution" is not very useful..... It require manual checking ID (first it IDs need to bs stored in EEPROM) renaming child id sensor in case of change and so on. In my private opinion it could be better add special registerSensor() function which takes pin and DS18B20 ID and register sensor (or not). Please consider these.
    @mar.conte please include node log and gateway log when node tries to connect
  • Needles to say and re-say this is really a much needed plugin for us beginners!
    Made a bunch of battery operating nodes with only DHT22 and all are working flawlessly.
    Today I tried making a node using a DS18B20 and DHT22. DS18B20 connected to digital pin 3 and DHT22 to digital pin 4. Both sensors have 10K resistors between their vcc and data lines (tried without resistors but none of the sensors worked).
    Sketch compiles and uploads fine to a Arduino Pro Mini 328 3.3v 8MHz. It also connects to the gateway, but I run into some problems;
    The first one being that watching from the serial debug, the node strarts up, connects to the gateway, reports some data and then hangs. No more activity from the node watching on the serial debug.
    The second one is that the node never sleeps - Activity led on Arduino Pro Mini remains lit.
    The last one is that DS18B20 reports the Temp to the gateway but DHT22 reports only Temp and not the Humidity. Tried changing pins for the sensors, but the same.
    Connection logs (from the serial interface) are as follows:
    REG I=1 P=3 P=6 T=0
    REG I=2 P=4 P=6 T=0
    REG I=3 P=4 P=7 T=1
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    RADIO OK
    PRES I=200, T=23
    PRES I=201, T=30
    BATT V=3.44 P=100
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.44
    PRES I=1 T=6
    PRES I=2 T=6
    PRES I=3 T=7
    READY
    MY I=199 M=1
    DS18B20 I=1 T=47.75
    SEND D=0 I=1 C=0 T=0 S= N=0 F=47.75
    DHT I=2 T=25.00
    SEND D=0 I=2 C=0 T=0 S= N=0 F=25.00
    And the sketch I use is as follows:
    Documentation available on: https://github.com/mysensors/NodeManager
    #include "config.h"
    // before
    void before() {
        nodeManager.setBatteryMin(2.0);
        nodeManager.setBatteryMax(3.3);
        nodeManager.setSleep(SLEEP,60,SECONDS);
        nodeManager.registerSensor(SENSOR_DS18B20,3);
        nodeManager.registerSensor(SENSOR_DHT22,4);
    // presentation
    // setup
    // loop
      nodeManager.loop();
    // receive
    Also on config.h I have enabled DS18B20 and DHT22 modules.
    Really, any help would be welcome!
    Thanks all in advance!
  • @gohan
    node
    40 MCO:BGN:BFR
    REG I=1 P=3 P=6 T=0
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    59 TSM:INIT
    135 TSF:WUR:MS=0
    155 TSM:INIT:TSP OK
    176 TSM:INIT:STATID=100
    202 TSF:SID:OK,ID=100
    225 TSM:FPAR
    370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2301 TSF:MSG:FPAR OK,ID=0,D=1
    2447 TSM:FPAR:OK
    2463 TSM:ID
    2478 TSM:ID:OK
    2492 TSM:UPL
    2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    3737 TSF:MSG:PONG RECV,HP=1
    3768 TSM:UPL:OK
    3784 TSM:READY:ID=100,PAR=0,DIS=1
    3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
    4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
    6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
    6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
    RADIO OK
    PRES I=200, T=23
    7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
    PRES I=201, T=30
    7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
    BATT V=3.25 P=93
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
    7469 !MCO:SND:NODE NOT REG
    7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
    PRES I=1 T=6
    7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
    READY
    7868 MCO:REG:REQ
    7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    9078 MCO:PIM:NODE REG=1
    9105 MCO:BGN:STP
    MY I=100 M=1
    9123 MCO:BGN:INIT OK,TSP=1
    THER I=1 V=354.00 T=40.05
     M=1
    SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
    9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
    SLEEP 3600s
    9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
    9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
    9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    9666 !TSF:MSG:LEN,0!=8
    10108 MCO:SLP:TPD```
    Gateway
    0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
    I think relay is the pir sensor you are looking for.
    @mar.conte your configuration looks correct, SENSOR_MOTION is what you want to use indeed. However, the logs are saying NodeManager is presenting the sensor as S_TEMP so the issue is on NodeManager's side also because looks like SensorThermistor has been instantiated but if I look at the code, there is no way this should happen.I'll try to setup something similar to see if I can reproduce the behavior. Very stupid question: are you sure you have uploaded successfully that sketch and it is not an old one? I really cannot explain it otherwise at a first look...
    @bilbolodz having a special registerSensor() for DS18B20 is for sure feasible but I'll leave it as the last option. Are you sure you need to store something in the eeprom? The way I imaged it was something like this, all within the sketch:
    • register the DS18B20 sensors with one line. registerSensor() returns the child id of the last sensor so I know how many have been detected.
    • cycle through the DS18B20 sensors found with getSensor(index)
    • for each sensor, call of getDeviceAddress(), if the address equals to a hard-coded address, renameSensor() to a fixed id.
    In this way the same device address will always get the same child id and if a sensor will be unavailable, it will not mess up the other child IDs. Is this something which can be done or am I missing something? Far from saying it is elegant of course...
    Of course that it's solution but hardcoding addresses into sketch as you said "it's far from elegant"..... The good idea (in my opinion) is to put addresses into array stored in eeprom. The ideal solution would be to have possibility put addresses into eeprom by mysensors controller 😉
    @BeniK said in NodeManager: plugin for a rapid development of battery-powered sensors:
    PRES I=1 T=6
    PRES I=2 T=6
    PRES I=3 T=7
    Hi, the sensors are all presented correctly, child id 1 is type temperature (6, the DS18B20), child id 2 is type temperature (6, the DHT22), child id 3 is type humidity (7, the DHT22).
    What it looks like from the logs is that it hangs after sending out the temperature of child id 2, never get to child id 3 so never goes to sleep.
    I wonder if having both DHT and DS18B20 together would consume too much memory causing the sketch to halt. When you compile it, what is the percentage of program storage space and dynamic memory used? For those sensors the objects are allocated dynamically so when getting closer to the memory limit strange behaviors can happen.
    Try also disabling NodeManager's debug (#define DEBUG 0) and all the other modules you are not using (e.g. MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT, etc.). All of this should help saving additional memory. Then check on your controller if you get the humidity as well and if the node goes to sleep.
  • @user2684 Hi and thank you for the prompt response!
    The % of memory used is 83% of program storage space and 63% of dynamic memory.
    Sketch uses 25580 bytes (83%) of program storage space. Maximum is 30720 bytes.
    Global variables use 1307 bytes (63%) of dynamic memory, leaving 741 bytes for local variables. Maximum is 2048 bytes.
    Heading right now to try to compile without the non-needed modules and try again.
    Ok got it, just wanted to be sure that what I had in mind, despite being awful, was kind of feasible. Now let me try to understand better what you have in mind: you store in eeprom the the addresses, then call registerSensor() and the for DS18B20, it will retrieve from there the addresses and do the mapping automatically instead of being you doing in the sketch what I listed before. Is it correct? If so, despite some obvious complexity, does not require a special registerSensor() (which would be great).
    As a side note, having the controller storing something into the EEPROM is not something extremely difficult to implement, I can add an additional V_CUSTOM message so achieve this since I can imagine may be helpful for this and other use cases (https://github.com/mysensors/NodeManager/issues/53)
  • @user2684 Yes, that could be nice solution.
    Cool, I'll track it down (https://github.com/mysensors/NodeManager/issues/54) so you can see when I'll get into it.
  • @user2684 You were right! Definately a memory problem. Disabled the non-needed modules and everything is working as it should!
    REG I=1 P=3 P=6 T=0
    REG I=2 P=4 P=6 T=0
    REG I=3 P=4 P=7 T=1
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    RADIO OK
    PRES I=200, T=23
    PRES I=201, T=30
    BATT V=3.44 P=100
    PRES I=1 T=6
    PRES I=2 T=6
    PRES I=3 T=7
    READY
    MY I=199 M=1
    DS18B20 I=1 T=44.19
    SEND D=0 I=1 C=0 T=0 S= N=0 F=44.19
    DHT I=2 T=24.40
    SEND D=0 I=2 C=0 T=0 S= N=0 F=24.40
    DHT I=3 H=35.50
    SEND D=0 I=3 C=0 T=1 S= N=0 F=35.50
    SLEEP 60s
    Many many many THANKS for the help!
  • @user2684 By the way I am alsy trying to implement the forecasting algorithm for BME280 sensor (from here) into the BME280 section of NodeManager.cpp and Nodemanager.h but until now no joy. Maybe I am trying to do something complicated for me as a beginner into this, but I always like to learn by trial and error. Any advice you could give me to be able to implement the forecasting algorithm?
    Great! I feel like there are a lot of optimizations that can be done to prevent this and other weird behaviors (tracked already with https://github.com/mysensors/NodeManager/issues/28).
    I'd need a real programmer's review sooner or later because I'm sure the way I am e.g. comparing and manipulating strings are far from being efficient...
    Great idea! I wonder if the issue you are facing is due to different libraries being used (I'm using Adafruit's library, not the one from MySensors examples folder, not sure if they are different). I'll give it a try as well (https://github.com/mysensors/NodeManager/issues/56), but please let me know if you'll find the way to have it working and I'll make it part of the main code base.
  • @user2684
    all ok now is s_motion but is ever tripped high!!!why?
    @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Default behavior is triggering on RISING but this can be changed with setMode() and setInitial(). Also ensure you are using pin 3 on a pro mini to have a valid interrupt. What is the behavior you are experiencing?
  • @user2684
    for istance Sensorswitch what is code?
  • @user2684
    it's ok this code?
    SensorSwitch swiTch(1,3);
    // before
    void before() {
    swiTch.setMode(0);
    swiTch.setInitial(0);
    swiTch.setTriggerTime(4000);
      nodeManager.registerSensor(SENSOR_MOTION,3);```
    @mar.conte sorry I'm not sure I have understood what you want to achieve. Do you have a motion sensor which is HIGH by default and when triggers goes LOW? Is this what you need?
  • @user2684
    Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
    Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
  • @user2684
    @gohan
    node
    40 MCO:BGN:BFR
    REG I=1 P=3 P=6 T=0
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    59 TSM:INIT
    135 TSF:WUR:MS=0
    155 TSM:INIT:TSP OK
    225 TSM:FPAR
    2447 TSM:FPAR:OK
    2463 TSM:ID
    2478 TSM:ID:OK
    2492 TSM:UPL
    3768 TSM:UPL:OK
    RADIO OK
    PRES I=200, T=23
    PRES I=201, T=30
    BATT V=3.25 P=93
    PRES I=1 T=6
    READY
    7868 MCO:REG:REQ
    9105 MCO:BGN:STP
    MY I=100 M=1
     M=1
    SLEEP 3600s
    Gateway
    @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
  • @user2684
    hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
    smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
    The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
  • @user2684
    Yes trig again!!!
    Yes trig again!!!
    Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
  • @user2684
    NODE OUTPUT
    40 MCO:BGN:BFR
    REG I=1 P=3 P=1 T=16
    NodeManager v1.4
    INT1 M=3
    INT2 M=255
    59 TSM:INIT
    135 TSF:WUR:MS=0
    153 TSM:INIT:TSP OK
    200 TSF:SID:OK,ID=100
    223 TSM:FPAR
    368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    698 TSF:MSG:FPAR OK,ID=0,D=1
    2445 TSM:FPAR:OK
    2461 TSM:ID
    2476 TSM:ID:OK
    2490 TSM:UPL
    2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2693 TSF:MSG:PONG RECV,HP=1
    2721 TSM:UPL:OK
    2738 TSM:READY:ID=100,PAR=0,DIS=1
    2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
    5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
    5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
    RADIO OK
    PRES I=200, T=23
    5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
    PRES I=201, T=30
    5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
    BATT V=3.21 P=86
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
    6072 !MCO:SND:NODE NOT REG
    6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
    PRES I=1 T=1
    6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
    READY
    6445 MCO:REG:REQ
    6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    6678 MCO:PIM:NODE REG=1
    6705 MCO:BGN:STP
    MY I=100 M=1
    6723 MCO:BGN:INIT OK,TSP=1
    SWITCH I=1 P=3 V=1
    SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
    6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    SLEEP 3600s
    6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
    7684 MCO:SLP:TPD
    7700 MCO:SLP:WUP=1
    WAKE P=3, M=3
    AWAKE
    SWITCH I=1 P=3 V=1
    7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
    SLEEP 3600s
    7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
    8667 MCO:SLP:TPD
    8683 MCO:SLP:WUP=1
    WAKE P=3, M=3
    AWAKE
    SWITCH I=1 P=3 V=1
    8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
    SLEEP 3600s
    8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
    9562 MCO:SLP:TPD
    9578 MCO:SLP:WUP=1
    WAKE P=3, M=3
    AWAKE
    SWITCH I=1 P=3 V=1
    9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    SLEEP 3600s
    9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
    10541 MCO:SLP:TPD
    Tanks
    @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
    Now, if I look at the digital read of the pin waking up the board (V=):
    SWITCH I=1 P=3 V=1
    This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
  • @user2684
    ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
  • I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
    If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
    nodeManager.setBatteryInternalVcc(false);
    nodeManager.setBatteryPin(A0);
    You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
  • @user2684
    THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
    TANKS
    TANKS
    If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
    nodeManager.setBatteryMin(2.7);
    nodeManager.setBatteryMax(3.6);
    So the percentage will be calculated between the two values.
  • @user2684
    Much easy INFINITE THANKS AND CONGRATULATIONS
  • @user2684
    Solved
    I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
    thanks for the support
    This is my reprap printed house for my project
    @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
  • I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
  • Can I suggest updated sourceforge to say that the code has been moved to github, and leaving little else there? That way it's easier to update everything in the same place. I was browsing on sourceforge for a while and wondering "Why isn't this on github instead?" It wasn't even until I came back and started skimming this thread that I realized it was moved to github.
    So you are saying when the node wakes up not from the pir interrupt at the end of the sleeping cycle to report battery level, is it also reporting a V_TRIPPED with payload 0? Thanks
    @JonnyDev13 said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Good advice thanks! I've changed the website link on Sourceforge as well as added a note in the description and redirected the "Support" link.
  • @user2684
    Yes of course but payload =1 pir movimento detect
    What's the problem if it reports no motion?
  • @user2684 Looks great!
  • @gohan
    The problem is that motion report whenever sleep goes to wake to send me the battery status every 60 minutes ,then every 60 minutes sends me battery status and motion pir
    Ok, but is it causing any problem?
  • @gohan
    Definitely, if I put a pir sensor to monitor a security access I will never know if I had an intrusion if I have a false alarm
    if it reports "no motion" it is not a false alarm. The important thing is it must report when there is "motion"
    @gohan said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Agree with what @gohan says. But I'll look into this anyway @mar-conte, reporting no motion when waking up should not happen even if it is a minor issue (https://github.com/mysensors/NodeManager/issues/71). What should not happen at all is reporting motion (payload 1) but as far as I've understood this is the case.
  • 16
