My Slim 2AA Battery Node
  • @m26872 said in My Slim 2AA Battery Node:
    @siod
    Gateway issue? Other sensors working or all down at same time? Do you have a sniffer or listen-only gateway, or heartbeat LED attached to each sensor?
    What's the purpose of the delay(1000)? It usually safer to use wait() or sleep() and perhaps also to deal with the interrupt results first. You could also try level interrupt instead of "change". You're not using indefinite sleep so it shouldn't be a problem, but try anyway..
    @m26872
    Gateway seems to work fine as the 3rd and still working sensor is still communicating. Also the freezed sensors start communicating after I restarted the sensor, not the GW. So I don´t see a problem with the GW.
    "Do you have a sniffer or listen-only gateway" -sorry, don´t know what this is o0 !?
    I have not attached a heartbeat LED yet, but that´s sth. I could do as a next step...
    The delay (1000) was initially planned to settle the sensors a bit and gie me abetter Battery reading, but as it is not working as it was intended I will delete it in a future update...
    You could also try level interrupt instead of "change" -again, I don´t know what you are talking about here, hope you can help me out.
    Thanks so far!!
    @siod said in My Slim 2AA Battery Node:
    I meant the https://www.mysensors.org/controller/sniffer, but I think it's easier to equip sensors with Radio Traffic LEDs and/or your own heartbeat/error LEDs.
    I suggest you start with deleting or replacing this delay. It could be it.
    I think you had pull-up inputs. Then it's just to replace the CHANGE with LOW in your call to sleep().
    Thanks so far!!
    My personal troubleshooting method in cases like these (and too many others) is just exhaustive use of the good old substitution method. Hw, Sw, entire systems or whatever you can do. 😬
  • deleted - it´s working now, I must have made a mistake... 😊
    edit:
    one strange thing: The sensor should report every 15 minutes (900000 milisecs), but it reports only every 18 minutes. Don´t know why.
  • Hello everybody,
    I´m struggeling with getting the https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
    to work.
    The node registers with the GW, but doesnt submit the tripped reading.
    Not even a permanent on or something. Just nothing. So i dont know how to troubleshoot here.
    The PIR HC-SR505 is functional. I tested it with a testscript on a UNO.
    And the 2AA Slimnode is functional as well. When using the node as a binary switch it works perfectly fine,
    Just the combination 2AA Slimnode and HC-SR505 doesnt work.
    Anybody has an idea ?
    Thanks in advance Komaandy
    Did you check the serial output if you get debug messages?
    @Komaandy please don't double post. Please continue in the other thread
  • Does anybody has a idea why my nodes keep freezing ?
    I build like 5 identical nodes with a PIR and after working fine for a couple of hours at least half of them freeze.
    There is one particular node that is working for 4 days now straight, but all the others are frozen meanwhile.
    I have no idea where to start troubleshooting, as they are all the same ( capacitory, resistors,radios,Atmega328p,batteries,solder,radio,sketch)
    and are all basically within the same radius placed around the gateway. I have other "not battery Slim Nodes" and they never freeze, though running the same sketch.
    Please i need some tips
    Regards
    Komaandy
    @Komaandy - did you try the hardware without the PIR?
  • Do you mean running the node without the PIR ?
    I thought about, I guess i will test it.
    You think the PIR freezes the node ?
    @Komaandy - Yes and Yes 🙂
    Its a good way to debug, remove not crucial stuff to see if it works... one by one and you will figure it out.
    The PIR (depending on which one and what kind of power you are using) might be the problem but hard to say without knowing your setup.
    @AWI said in My Slim 2AA Battery Node:
    @Komaandy and @sundberg84 Once again; Please continue in the other thread! Especially since @Komaandy now confirmed that it is this far NOT a generic Slim Node issue. Also, I haven't got any feedback on my reply there, but I assume it didn't work?
  • Hi @Komaandy ,
    unfortunately I must report that I made the same expiriences you made. I am running 5 "My SLim 2AA Battery Node" Sensors from which only 2 really work. The others keep freezing after an hour, a day, are sometimes after a few days. I have still no idea why this is happening, but because of this I stopped building more of the "My SLim 2AA Battery Node" sensors, which is very sad, because it´s an ingeniuous design.
    I am using MQTT and therefore I installed NRF24L01 modules. Some of them are really weak, so I thought that´s the problem: The node does not freeze, it´s just the NRF24L01 that is not sending any info anymore. So I attached a LED to my node to see if it is still alive. Whenever I opened a window the LED must lid. So when I did not got any info from the node I checked if the node is still operational by opening a window and there I noticed when the LED did not lid, that the node was completely frozen. So It was not a wireless connection problem, but the NRF24L01 of course could still be the problem.
    A lot of my investigastions was about figuring out what is happening when entering the sleep mode, because I thought (and still believe) the node is just not waking up from sleep anymore. Unluckily I still did not find a solution.
    Anywhere you said that the none battery driven nodes are working flawlessly, that´s another point I was thinking about. I have one MQTT Arduino Nano device in the basement which is directly powered over USB and I never had problems with it, also the MQTT / NRF24L01 range is awesome.
    But I have no oscillator or anything to check if it a power problem with the "My Slim 2AA Battery Node".
    Maybe you´ll find a solution for your problems which could help me, too. I´m looking forward hearing from you.
    @siod Thanks for your report. Could you please share some more info. Hw/sw versions, nRF-batches, sensors, configs/settings, sketches etc. @Komaandy could only confirm issues with a PIR eqiupped node, but you have a door-switch so I guess it's a potential generic problem then. Let's hope for other reports as to help us narrow down the search.
    I have not yet migrated to MySensors 2.x 😳 , but it's hopefully coming soon. My Slim Nodes from the start of this thread (~ 10 pcs) are still in flawless production.
    @m26872 - I made myself a slim node with a light sensor and a uv-sensor last weekend. Its running latest dev branch and has been working flawless atleast 1 week now.
  • @m26872 First of all: I already got so much help and I am very grateful for that, awesome community!
    I don´t think I will ever find the problem with those sensors and because of the lack of time I have (familiy, work...) I think looking for the problem would take longer than just build a new sensor. And that´s what I will do next: I will just build another node, one step after the other and so I can validate if it maybe is a hardware problem or a code problem. BTW my whole sketch is just a few posts above this one...
    So I will come back after I started over...
  • @m26872
    Hi there,
    im still into troubleshooting, and what i did last was create a "mock up temperatursensor slim node " with this sketch
    , so its really only the node and batteries. But it still freezes 😞
    Hardware i use is :
    -Atmega328p 1Mhz bootloader. // Burnt the bootloader with one Arduino UNO as master and another Arduino UNO on which I replaced the Atmega328p as slave // Arduino as ISP // with the latest Arduino IDE (1.8.2)
    • after burning the bootloader on the bare ATMEGA´s i assemble them on the node and transfer the sketch via FTDI232
    Furthermore i use
    -generic Capacitors and restistors ( specs from your BOM)
    • Kuman nRF24L01 batches ( bought like 30 in a bulk once, but other "nonslimnodes" are working)
      -fresh batteries
    Any help is very aprreciated 🙂 🙂
    * MockMySensors
    #define MY_NODE_ID 123
    #define RADIO_TX_LED_PIN    13  // the PCB, on board LED
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    #define SKETCH_VERSION "v0.5"
    // Define Sensors ids
       S_SCENE_CONTROLLER
    // one at a time.
    #define ID_S_TEMP              7
    //#define ID_S_BARO              9
    //// Lib 1.5 sensors
    //#define ID_S_SPRINKLER         29
    // Global Vars
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    bool metric = true;
    long randNumber;
    #ifdef ID_S_ARMED
    bool isArmed;
    #ifdef ID_S_LIGHT
    bool isLightOn=0;
    #ifdef ID_S_DIMMER
    int dimmerVal=100;
    #ifdef ID_S_COVER
    #ifdef ID_S_TEMP
    #ifdef ID_S_HUM
    #ifdef ID_S_BARO
    MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
    #ifdef ID_S_WIND
    #ifdef ID_S_RAIN
    #ifdef ID_S_UV
    #ifdef ID_S_WEIGHT
    #ifdef ID_S_POWER
    #ifdef ID_S_HEATER
    float heater_setpoint=21.5;
    //  float heater_temp=23.5;
    //  bool heater_status=false;
    #ifdef ID_S_DISTANCE
    #ifdef ID_S_LIGHT_LEVEL
    #ifdef ID_S_LOCK
    bool isLocked = 0;
    #ifdef ID_S_IR
    long irVal = 0;
    #ifdef ID_S_WATER
    #ifdef ID_S_AIR_QUALITY
    #ifdef ID_S_DUST
    #ifdef ID_S_SCENE_CONTROLLER
    char *scenes[] = {
       (char *)"Good Morning",
       (char *)"Clean Up!",
       (char *)"All Lights Off",
       (char *)"Music On/Off"
    int sceneVal=0;
    int sceneValPrevious=0;
    #ifdef ID_S_RGB_LIGHT
    String rgbState="000000";
    //RGB light V_RGB, V_WATT
    #ifdef ID_S_RGBW_LIGHT
    String rgbwState="00000000";
    #ifdef ID_S_COLOR_SENSOR
    //Color sensor	V_RGB
    #ifdef ID_S_HVAC
    //Thermostat/HVAC device
    // NOT IMPLEMENTED YET
    #ifdef ID_S_MULTIMETER
    // V_VOLTAGE	38	Voltage level
    // V_CURRENT	39	Current level
    #ifdef ID_S_SPRINKLER
    #ifdef ID_S_WATER_LEAK
    #ifdef ID_S_SOUND
    #ifdef ID_S_VIBRATION
    #ifdef ID_S_MOISTURE
    #ifdef ID_S_CUSTOM
       // Random SEED
       randomSeed(analogRead(0));
       wait(LONG_WAIT);
       Serial.println("GW Started");
       Serial.print(SKETCH_NAME);
       wait(LONG_WAIT);
       Serial.print("Get Config: ");
       wait(LONG_WAIT);
       // Init Armed
    #ifdef ID_S_ARMED
       isArmed = true;
    #ifdef ID_S_DOOR
       Serial.println("  S_DOOR");
       wait(SHORT_WAIT);
    #ifdef ID_S_MOTION
       Serial.println("  S_MOTION");
       wait(SHORT_WAIT);
    #ifdef ID_S_SMOKE
       Serial.println("  S_SMOKE");
       wait(SHORT_WAIT);
    #ifdef ID_S_LIGHT
       Serial.println("  S_LIGHT");
       wait(SHORT_WAIT);
    #ifdef ID_S_DIMMER
       Serial.println("  S_DIMMER");
       wait(SHORT_WAIT);
    #ifdef ID_S_COVER
       Serial.println("  S_COVER");
       wait(SHORT_WAIT);
    #ifdef ID_S_TEMP
       Serial.println("  S_TEMP");
       wait(SHORT_WAIT);
    #ifdef ID_S_HUM
       Serial.println("  S_HUM");
       wait(SHORT_WAIT);
    #ifdef ID_S_BARO
       Serial.println("  S_BARO");
       present(ID_S_BARO,S_BARO," Air pressure");
       wait(SHORT_WAIT);
    #ifdef ID_S_WIND
       Serial.println("  S_WIND");
       wait(SHORT_WAIT);
    #ifdef ID_S_RAIN
       Serial.println("  S_RAIN");
       wait(SHORT_WAIT);
    #ifdef ID_S_UV
       Serial.println("  S_UV");
       wait(SHORT_WAIT);
    #ifdef ID_S_WEIGHT
       Serial.println("  S_WEIGHT");
       wait(SHORT_WAIT);
    #ifdef ID_S_POWER
       Serial.println("  S_POWER");
       wait(SHORT_WAIT);
    #ifdef ID_S_HEATER
       Serial.println("  S_HEATER");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_LOCK
       Serial.println("  S_LOCK");
       wait(SHORT_WAIT);
    #ifdef ID_S_IR
       Serial.println("  S_IR");
       wait(SHORT_WAIT);
    #ifdef ID_S_WATER
       Serial.println("  S_WATER");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_DUST
       Serial.println("  S_DUST");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_HVAC
       Serial.println("  HVAC");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_SOUND
       wait(SHORT_WAIT);
    #ifdef ID_S_CUSTOM
       Serial.println("  S_CUSTOM");
       wait(SHORT_WAIT);
       Serial.println("");
       Serial.println("");
       Serial.println("");
       randNumber=random(0,101);
       Serial.println(randNumber);
       // Send fake battery level
       sendBatteryLevel(randNumber);
       wait(LONG_WAIT);
       // Request time
       requestTime();
       wait(LONG_WAIT);
       //Read Sensors
    #ifdef ID_S_DOOR
       door();
    #ifdef ID_S_MOTION
       motion();
    #ifdef ID_S_SMOKE
       smoke();
    #ifdef ID_S_LIGHT
       light();
    #ifdef ID_S_DIMMER
       dimmer();
    #ifdef ID_S_COVER
       cover();
    #ifdef ID_S_TEMP
       temp();
    #ifdef ID_S_HUM
       hum();
    #ifdef ID_S_BARO
       baro();
    #ifdef ID_S_WIND
       wind();
    #ifdef ID_S_RAIN
       rain();
    #ifdef ID_S_UV
       uv();
    #ifdef ID_S_WEIGHT
       weight();
    #ifdef ID_S_POWER
       power();
    #ifdef ID_S_HEATER
       heater();
       distance();
       light_level();
    #ifdef ID_S_LOCK
       lock();
    #ifdef ID_S_IR
       ir();
    #ifdef ID_S_WATER
       water();
       air();
    #ifdef ID_S_DUST
       dust();
       scene();
       rgbLight();
       rgbwLight();
       color();
    #ifdef ID_S_HVAC
       hvac();
       multimeter();
    #ifdef ID_S_SOUND
       moisture();
    #ifdef ID_S_CUSTOM
       custom();
       wait(SHORT_WAIT);
    //void door(){}
    #ifdef ID_S_DOOR
    void door()
       Serial.print("Door is: " );
       if (randNumber <= 50) {
       	Serial.println("Open");
       	Serial.println("Closed");
    #ifdef ID_S_ARMED
       Serial.print("System is: " );
    #ifdef ID_S_MOTION
    void motion()
       Serial.print("Motion is: " );
       	Serial.println("Active");
       	send(msg_S_MOTION_T.set(1));
       	Serial.println("Quiet");
       	send(msg_S_MOTION_T.set(0));
    #ifdef ID_S_ARMED
    #ifdef ID_S_SMOKE
    void smoke()
       Serial.print("Smoke is: " );
       	send(msg_S_SMOKE_T.set(1));
       	send(msg_S_SMOKE_T.set(0));
    #ifdef ID_S_ARMED
    #ifdef ID_S_LIGHT
    void light()
       Serial.print("Light is: " );
    #ifdef ID_S_DIMMER
    void dimmer()
       Serial.println(dimmerVal);
    #ifdef ID_S_COVER
    void cover()
       Serial.print("Cover is : " );
       if (coverState == 1) {
       	Serial.println("Opening");
       	send(msg_S_COVER_U.set(1));
       	Serial.println("Closing");
       	send(msg_S_COVER_D.set(0));
       	Serial.println("Idle");
       	send(msg_S_COVER_S.set(-1));
    #ifdef ID_S_TEMP
    void temp()
    #ifdef ID_S_HUM
    void hum()
    #ifdef ID_S_BARO
    void baro()
       long pressure = map(randNumber,1,100,870,1086);// hPa?
       int forecast = map(randNumber,1,100,0,5);
       Serial.print("Atmosferic Pressure is: " );
       Serial.println(pressure);
       send(msg_S_BARO_P.set(pressure));
       Serial.print("Weather forecast: " );
       send(msg_S_BARO_F.set(weather[forecast]));
    #ifdef ID_S_WIND
    void wind()
    #ifdef ID_S_RAIN
    void rain()
    #ifdef ID_S_UV
    void uv()
    #ifdef ID_S_WEIGHT
    void weight()
       Serial.print("Weight is: " );
    #ifdef ID_S_POWER
    void power()
       Serial.print("Watt is: " );
       Serial.print("KWH is: " );
    #ifdef ID_S_HEATER
    void heater()
       //  String heatState="Off";
    void distance()
    void light_level()
    #ifdef ID_S_LOCK
    void lock()
       Serial.print("Lock is: " );
    #ifdef ID_S_IR
    void ir()
       Serial.println(irVal);
       send(msg_S_IR_S.set(irVal));
       send(msg_S_IR_R.set(irVal));
    #ifdef ID_S_WATER
    void water()
    void air()
    #ifdef ID_S_DUST
    void dust()
    void scene()
       Serial.print("Scene is: " );
       	sceneValPrevious=sceneVal;
    void rgbLight()
       Serial.println(rgbState);
    void rgbwLight()
       Serial.println(rgbwState);
    void color()
       String colorState;
       Serial.println(colorState);
    #ifdef ID_S_HVAC
    void hvac()
       Serial.println(hvac_Speed);
    void multimeter()
       Serial.println(impedance);
       Serial.println(volt);
       Serial.println(amps);
    #ifdef ID_S_SOUND
    void moisture()
    #ifdef ID_S_CUSTOM
    void custom()
       switch (message.type) {
    #ifdef ID_S_ARMED
       case V_ARMED:
       	isArmed = message.getBool();
    #ifdef ID_S_DOOR
       	door();//temp ack for door
    #ifdef ID_S_MOTION
       	motion();//temp ack
    #ifdef ID_S_SMOKE
       	smoke();//temp ack
       case V_STATUS: // V_LIGHT:
    #ifdef ID_S_LIGHT
       		light(); // temp ack
       	//    #ifdef ID_S_HEATER
       	//    #endif
    #ifdef ID_S_DIMMER
       case V_DIMMER:
       	dimmerVal= message.getInt();
       	dimmer();// temp ack
    #ifdef ID_S_COVER
       case V_UP:
       	coverState=1;
       	Serial.println("V_UP");
       	cover(); // temp ack
       case V_DOWN:
       	coverState=-1;
       	Serial.println("V_DOWN");
       	cover(); //temp ack
       case V_STOP:
       	coverState=0;
       	Serial.println("V_STOP");
       	cover(); //temp ack
       case V_HVAC_SETPOINT_HEAT:
    #ifdef ID_S_HEATER
       		heater();//temp ack
    #ifdef ID_S_HVAC
       		hvac();//temp ack
       case V_HVAC_FLOW_STATE:
    #ifdef ID_S_HEATER
       		heater();//temp ack
    #ifdef ID_S_HVAC
       		hvac();//temp ack
    #ifdef ID_S_LOCK
       case V_LOCK_STATUS:
       	lock(); //temp ack
    #ifdef ID_S_IR
       case V_IR_SEND:
       	irVal = message.getLong();
       	ir(); // temp ack
       case V_IR_RECEIVE:
       	ir(); // temp ack
       case V_SCENE_ON:
       	sceneVal = message.getInt();
       	Serial.println(" On");
       	scene();// temp ack
       case V_SCENE_OFF:
       	Serial.println(" Off");
       	scene();// temp ack
       case V_RGB:
       	rgbState=message.getString();
       	rgbLight(); // temp ack
       case V_RGBW:
       	rgbwLight();
    #ifdef ID_S_HVAC
       //  hvac_SetPointHeat
       //  hvac_SetPointCool
       //  hvac_FlowState
       //  hvac_FlowMode
       //  hvac_Speed
       case V_HVAC_SETPOINT_COOL:
       	hvac();//temp ack
       case V_HVAC_FLOW_MODE:
       	hvac();//temp ack
       case V_HVAC_SPEED:
       	hvac();//temp ack
       default:
       	Serial.println(message.type);
    can you try to add the watchdog timers and see what happens? Try using a different bootloader? Different power source or using a small booster or an additional AA battery and a LDO. I am just throwing ideas and see what you can do with the stuff you may have at home.
  • @gohan said in My Slim 2AA Battery Node:
    LDO
    @gohan
    Hi, i added a WDT now into the MotionSensorSketch.
    Well at least i guess i did. I just read about it , never used it before. Does the 1Mhz Optiboot boatloaders support this ?
    Unfortunalty I didnt recieve my 3,3V boosters yet and i dont have LDO´s around.
    Concerning the bootloaders. Do you have a suggestion which one to use ? As I read that sticking to 1Mhz is important when using only 2AA batteries because of instability when voltage goes belowe certian values.
    Obviously i could use more batteries, but then i cant supply the nRF2401 from the board right ?
    // Enable debug prints
    #define MY_NODE_ID 40
    #include <avr/wdt.h>
    // Initialize motion message
    	wdt_enable(WDTO_2S);
    	sendSketchInfo("Motion Sensor", "AndyWasHere");
    	present(CHILD_ID, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    	Serial.println(tripped);
     wdt_reset();
    Actually you would have to put wdt_enable(WDTO_8S); right after Loop() and wdt_disable(); before calling the sleep (this is what I copied from another sketch). The wdt_reset you cold use in the middle of the loop in case you have a function that could take long time to execute and it may trigger the WD timer so you can reset the timer (you can play with the length of the timer according to your needs)
  • @gohan
    maybe like this ?
    wdt_disable();
    that's what I found. You could also use wdt_enable(WDTO_2S) I think. I haven't done any test yet on this.
    @Komaandy Try to remove all your Serial.print.
    1. Has anyone used NRF24L01+ + PA + LNA on these modules ?
    2. Any reason why it shouldnt work out of the box ( does AA batteries give enough power to drive them on LOW settings? )
    3. What type of battery monitoring is recommended on these ones? The resistance or the library way?
    I just got 90 PCBs, beautiful, fast shipping ( i think under 2 weeks to Norway ) and looks well made.
    I'll drop one in each beehive I have ( 7 ) and see how long they last
  • So, it seems i made some progress.
    After changing to the @GertSanders bootloader ( https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62) all the PIR nodes seem to be stable.
    Wish me luck 🙂
    @Komaandy Yes, using 8MHz instead of 1MHz is perhaps a good idea. Stable enough at room temperature, well proven and will e.g. solve a "Serial.print()" interrupt loop issue. Just remember that you'll lose ~25uA if you'll leave BOD enabled.
    No, on ATMega328 MySensors disables BOD before going to sleep.
    So extra consumption from BOD will only exist when node is active and in that case it's negligible.
    @Nca78 Ok. Thanks. Since ever, or only from 2.x ?
    @m26872 no idea I started MySensors with 2.x 😛
  • Update : Day 3 and still all PIR nodes are working 😉
    I´m using the given sketch here.
  • Still up and running stable.
    8Mhz Bootloader did the trick for me 🙂
    @Komaandy Nice! Thumbs up for 8MHz (and your "dark-style Fhem" - same as I use) 👍
  • @m26872
    thanks again for this great idea and that you developed these fine boards !
    And by the way...
    As you are using fhem as well...
    How do you manage to reset the tripped "1" in Fhem ?
    I just added a delay and a gw.send"0" to your sketch :), but using fhem would be more sophisticated actually ...
    @Komaandy said in My Slim 2AA Battery Node:
    I don't. I just use the last trip time as it's state and then notify (e.g. light or push message) on trip. I think it should be very simple to make a notify with a timer "at" to reset it after a while, if you wish.
  • just want to mention that I am using successfully the same Bootloader @Komaandy is using for about 2 weeks now. So it seems like my problems with freezing nodes are depending on a bad or too slow bootloader...
  • All of the ducting near me is a bit too slim to fit sensors based on this, so I decided to design and print a case instead.
    Does the trick nicely, and I also chose to use proper AA battery clips to retain a good connection, as the cable-tie battery assembly wasn't holding well for me!
    On the Thingiverse page I have a link to the original OnShape doc.
    https://www.thingiverse.com/thing:2418194
    Thoughts, suggestions, etc will be much appreciated!
  • Hi
    Did anyone make DHT 22 slim node with MySensors 2.0? I created one Node from modified MySenors 2 example...But I get a feeling that it is freezing sometimes (but then again comes back to life).
    @Oliviakrk the dht22 needs at least 3.3V to function properly. See the datasheet.
    @Oliviakrk - I did a test (which works pretty ok) with a DC/DC step up booster attached to D3 -> Vin. This way I could turn the booster on/off with HIGH/LOW from the sketch. This provided 3.3v to my sensors just fine and has been working for a while now. I dont know what will happen when the voltage drops though.
  • @sundberg84 Thanks. Will try.
    Thank you for all the hard work put into this project. I have built a few door sensor nodes and have some issues. At first I had pull-ups connected as shown in previous pictures but at a logic 1, when there should have been 3.3V there was only roughly half, 1.7V. I am no expert but I take it there has to be a current leak through the D3 pin for this to happen. I have this on all my nodes. I have tried different code but still the same. When I remove the external pull-up the node works properly but instead the batteries run out in a week or so. Have I made a mistake soldering these and maybe shorted something? I have looked at them closely but can't see anything wrong.
    Does anyone else have this problem? Any tips?
    Did you actually check if there is continuity between the pins you said? Do you have a photo of your nodes?
  • If I disconnect the battery, there is continuity between D3 and VCC with a resistance of around 20 kOhm. So when the door sensor is shut (no resistance), I connect GND through 20 kOhm to VCC. The current should be 0,165 mA. Too high by reading previous posts but still much less than what I get if I measure. Then I get roughly 18 mA! (Far from a Fluke though but has proven reliable before). Am I misunderstanding things?
    I have tried different nodes and sketches with pull-ups both enabled and disabled but I doesn't seem to matter. I have tried different radio modules but still the same, unless I use the bigger! antenna-version. Then the current goes up to 24-25 mA.
    I have done/am doing something really wrong although they seem to work just fine. Tomorrow I will try more radio modules to see if I can find any difference.
    3_1504391407612_IMG_4745.jpeg 2_1504391407612_IMG_4748.jpeg 1_1504391407612_IMG_4747.jpeg 0_1504391407611_IMG_4746.jpeg
    @masfak97 It's not clear to me whether you've tried to run it a as pure Arduino, without radio module and without MySensors library in your sketch? (I see that you haven't the serial/FTDI pins soldered - do you use ICSP, pogo-pins or whatever to upload and debug?)
  • I have thought about running it as a pure arduino and to use the debug function, but can't quite get the FTDI to work. I have used this before to upload code to arduino pros. I have a previous node that has all the pins soldered but simply won't be recognized with the USB FTDI. I have also tried switching USB-FTDI but still no luck. Is the FTDI supposed to work if all the pins are there?
    I have also bought a USBtinyISP but haven't read up on how to use it.
    Currently I install a first boot loader with Nick Gammons sketch running on a UNO connected to a breadboard and the 328. After that has been installed, I install the 8 MHz boot loader by Gert Sanders (thank you of it) and finally upload the code using "Upload using programmer". I currently have no way of reading the serial debug from the node.
    I checked the node without the nrf but still power-hungry in the mA.
    I think you should focus on getting these basic Arduino functions working so you're in control of what's going on. Note that I recently added a few updates to the first post of this thread (under The uC - Software). Read the tutorials and use 8MHz internal clock.
    When you get everything running, test your door switch again with a simple Arduino sketch.
  • @m26872
    UPDATE 2: There have been reported issues with MySensors 2.x freezing on SlimNodes running at 1MHz, which I've confirmed. Recommended solution when using MyS 2.x, is to use 8MHz (internal) instead.
    This I can confirm - running at 1 MHz introduced some real oddities with latest MySensors library. Not sure what changed but my nodes definitely freaked out. Will try switching to 8 MHz - hopefully before Irma whacks us here.
  • @wergeld
    Same confirmation from my side; 1mhz boot loader doesn't work; dht22 with step up connected does always give NAN. Switching to 8mhz boot loader did the trick.
    //@2.2.0-beta
    @kotzer Thanks for sharing. But (AFAIK) the Arduino DHT22 library has never worked at all at 1MHz. And since dht22 doesn't support <3V there's no need for 1MHz anyway.
  • @m26872
    Maybe offtopic, sry, but:
    I have Step up at dht22, so it has 3,3v to operate..
    But I am in wrong topic, it should be your first 2aa sensor ( https://forum.mysensors.org/topic/486/my-2aa-battery-sensor )
    This is what I built, and with 1mhz it doesn't work (tried with step up 3,3v and without) this wasted me many hours, because I wanted to save energy as much possible 😉 with 8mhz its operating well.
    Greets from Germany
    @kotzer Infact I'm actually making a few of my first model too rigth now. I had components left over and despite everyones criticism against the dht22, I find it working very well as long as you deal with the failed readings in the sketch. And, the battery life time was pretty good too. Greets. 👍
  • @m26872 I finally got to try your suggestions and loaded the Blink-sketch to my nodes. The power consumtion is then cut to ~4mA. Scrolling back through the forum, I copied the sketch from a user with low power consumption and - Finally - I get an idle comsumtion of 1,9 uA! Connecting the FTDI I can also debug and check for proper function.
    I do have another problem I haven't managed to solve; With an UNO and a breadboard I can easily load the bootloader using Nick Gammons sketch and then the sketch with the UNO as ISP. Using the FTDI I can read the serial stream without any problem but I can't seem to load any bootloader or sketches! I keep getting a sync error. I understand the principle of DTR going low and that the capacitor between DTR and reset and the resistor between +5 and reset will make the LOW into a low-pulse and then back to high. With the FTDI I can program a Pro Mini without any problems but it fails constantly with the nodes.
    I have no scope so I can't visualize the signal but with the meter I can see that the voltage on the reset is ~3,3v, the resistance between +5 and reset is 10 kOhm and the capacitor reads 83 uF although branded 100uF.
    I use Gert Sanders versions of Optiboot at 8Mhz and the one with 38400 NO LED (Thank you for that). I have tried several FTDIs and nodes, checked all connetions, tried to control the reset manually using a breadboard but can't get it to work. I have tried the FTDI at 5v instead (no nRF connected) and tried different boards and speeds. I have tried 1 MHz, 16Mhz.
    Is it possible that 83 uF is too small? Any other tips? When building more nodes it would be great to be able to program them without dismantling.
    @masfak97 Have you selected the right board in Arduino IDE? (Installed MiniCore in Board Manager?) Have you tried to use baud 9600 (with corresponding bootloader of course) ?
    I doubt that 83uF is too small.
  • @m26872 Thank you for your suggestions. I have now tried them (and many more) but still can't it to work. It's really not a big problem since I can program them using an Uno as ISP instead but it's really annoying that I can't get it to work.
    I have checked my chips, they are all at mega328P-PU and I have tried many of them with the same result. I have soldered many nodes, thinking that I didn't make the solder connect through the holes but without any luck. I have tried different sockets to make the connections better and I have traced the entire node without finding any broken connections.
    To get the sketch loaded I use Nick Gammons board_programmer with an Uno and use the LilyPad boot loader which enables the internal 8 MHz (Using pin 9 as clock instead of an external crystal). After that I program the Uno with ArduinoISP, set the programmer to Arduino as ISP and upload the sketch with "Burn with programmer" command.
    I have switched USB-cable, USB outlet on the mac, breadboards, dupont cables, capacitors (different ceramic but all show too little capacitance), Atmegas and FTDI programmers. I have tried all combinations with 3.3 and 5 v without any luck. Programming Arduino Pros with the FTDI works fine.
    I have tried the Mincore and Gert Sanders OptiBoot. I have tried to manually reset the chip connecting the reset pin to ground briefly when programming. I have tried lowering the baud rate to 9600. I have tried to load the Uno bootloader together with a 16 MHz crystal and 2 x 22pf capacitors and then the FTDI. I have tried larger electrolytic capacitors.
    Last week, when mimicking the slim node on a breadboard, I managed to get the FTDI to work a few times but can't really say exactly what I did. Now I can't get it to work anymore.
    All in all I have spent many hours trying to figure this out but without any luck. My nodes look just like the ones I see in your pictures.
    Could it be that the internal 8 Mhz is too unstable to work?
    Capacitors being too small? I've seen some reporting that they succeeded with larger...
    Bad connection somewhere > momentary voltage drop?
    Cheap FTDIs?
    Mac USB-power maxing out?
    Bad atmegas?
    Please help me solve this annoying problem.
    @masfak97 Wow. You work hard. Of course we must help you. I'm not familiar with your programming method. So that would be my quick wild first guess. I can't read that you've verified the fuse settings? Have tried different startup times e.g?
    Do I understand correctly if you're able to send and recieve commands to the Atmega with your FTDI after it is programmed ?
  • Hi. I have a problem with my slim node with the sketch "temperature"
    with the slim pcb node and a DS18B20 in domoticz it does well the node presentation but neither the S_TEMP child arrives nor does it get any temperature afterwards of course.
    but if I mount the same sketch in an arduino nano and with power to 5v it works perfectly.
    please help
    @Mikepara Please elaborate and post your code. Tell us also about power supply, fuse settings (clock speed) and your troubleshooting steps. See debug-faq-and-how-ask-for-help.
  • sorry. the sketch is the "temperature" of library and the bootloader configuration is:
    arduino ide 1.8.5 and usbasp, record the minicore bootloader on atmega328P, clock 8mhz internal, compiler LTO disabled, variant 328P, BOD disabled.
    thanks
  • Hi All,
    This Topic is a little old but hopefully still active. I am using the battery Duracell CR123 because it is small and fits in my case. Would this be an ok choice or does someone has other recommendations?
    Thanks for feedback.
    Marcel
    Look also at AAA/AA size LiFePO4 as it will need just one cell instead of 2 as the normal alkaline/nimh ones
    Maybe a silly question, but where did you get the library for the Vcc.h ?
     #include <Vcc.h>
    compilation terminated.
    exit status 1
    Error compiling for board ATmega328.
    I couldn't find any VCC in the MySensors library set and also doing a search for vcc in the Arduino Library Manager I can't find it either...
    [EDIT] : Found it in other thread. Leaving here for reference: https://github.com/Yveaux/arduino_vcc
    LiFePO4
  • I have 29 panels of the latest version of the PCB. It's more than I can use. Please PM me if you are interested in them.
  • As information for everyone, I suggest that if you get sockets for the ATMEGA, that you get
    these: alt text
    rather than these: alt text
    The reason being that the former have a much wider gap in the middle than the later. Because of that, the .1 puff #104 monolithic multilayer 5.08mm pitch capacitors called for in the BOM fit nicely. If you use the later ones, you will need to remove material from the socket to fit them.
  • I just made a new case for a LiFePO4 magnetic sensor implementation of this. Thanks for the excellent work on this handy node design!
    https://www.thingiverse.com/thing:3034907!
    a picture
    With 2 mini solar panels on the sides and an harvesting circuit, you could run it indefinitely 😁
  • Good evening!
    I had a bit of a break from this forum (approx 3-4 years...) And just got back into it . I managed to put a bootloader into my 328p-pu chip
    can anyone just confirm if it is OK to use this bootloader with the version 2.0 board here.
    I understand that it should run at 8Mhz to be stable . so I assumed I could use the bootloader that comes with Arduino IDE ?
    I flashed this one onto the chip at the moment and will start to solder some of my boards soon. but would like to be sure that it is correct before I go too far 😃
    atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
    atmega328bb.upload.tool=arduino:avrdude
    atmega328bb.upload.protocol=arduino
    atmega328bb.upload.maximum_size=30720
    atmega328bb.upload.speed=57600
    atmega328bb.bootloader.low_fuses=0xE2
    atmega328bb.bootloader.high_fuses=0xDA
    atmega328bb.bootloader.extended_fuses=0x05
    #atmega328bb.bootloader.path=arduino:atmega
    atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
    atmega328bb.bootloader.unlock_bits=0x3F
    atmega328bb.bootloader.lock_bits=0x0F
    atmega328bb.bootloader.tool=arduino:avrdude
    atmega328bb.build.mcu=atmega328p
    atmega328bb.build.f_cpu=8000000L
    atmega328bb.build.core=arduino:arduino
    atmega328bb.build.variant=arduino:standard
    @badmannen Welcome back. The good news is that there's now a mysensors bootloader, which is even better because it allows over-the-air firmware updates for the atmega328p: https://www.mysensors.org/about/fota
  • Daaaaang ... it is a good time to be alive and come back to this I see 😃 ... thanks a million to you guys that made that one .. that certainly makes changes a whole lot less painful!
  • @neverdie Alright , that took me a couple of days of fighting with Arduino/Linux/windows/drivers/bootloaders etc etc etc but I got it all running with my updated gateway+repeater-node + mailbox-node. did not try the update function yet but surely it should work. just need one or two more repeater-nodes since I have way to thick cement walls here for this signal.
  • OK I had some fun the last couple of days and actually got something done =D !
    Managed to update my gateway and repeater-nodes to latest version and boot-loaded all nodes and future nodes so they are FOTA enabled .
    So far I managed to assemble 3 nodes and after a bit of swearing and soldering and de-soldering and re-soldering I got:
    1 - DHT11 TEMP / HUM node, on Battery (Slim 2AA) - surprisingly accurate actually
    2 - DOOR-SWITCH - on Battery (Slim 2AA) - to be used in my mailbox, got the idea from someone here in the forums, so thank you, I don´t remember who it was since I probably read a million posts by now =D
    3 - a 220V Relay switch, with the PA LN radio, and works as repeater ( runs on a NANO )
    just wanted to say a huge thanks to the MySensors group and all people here on the forum for helping me get started (Had a little break for a couple of years 😃
    Let us know when you get it to FOTA update.
  • @neverdie
    Just tried it by mounting an "empty" 328P in the node just with the
    fuses set to:
    0xE2
    0xDA
    0xFE
    and with the MYSBootloader .
    Amazing ! . worked at the first try! (this time around =D )
    ( tried and failed a couple of times earlier, but I know I burned 0xFD instead of 0xFE so set the BOD to the wrong value, and that does not work )
  • @neverdie Actually... I run into another problem ..
    After I make a FOTA and upload a sketch . it runs as it should, no problem.
    But if I try to update it again , it never tries to upload the sketch to the node.
    The only thing I could find that was clever to do to make it work ok with a battery node was to use smartSleep();
    which I do ... is there anything else in the code that needs to be present ?
    Hopefully someone who knows can chime in.
  • @neverdie OK, that person who knows something is now ME ! =D ... RTFM ... as always , it worked strangely enough to update ONCE with some slightly wrong Fuses set... reloaded the bootloader with soem correct fuses agian .. ( hopefully alst time .. and VOILA! now it works to update the node multiple times .. yeaa.
    What were the winning fuse settings that you finally settled on using? Trust me, a year from now you won't remember, and you'll be glad you posted it.
  • OK MY solution was actually the fuses that I said earlier . but confused myself by changing them back and forth a couple of times and downgraded Arduino to the previous version etc.
    So the fuses for my barebone 328P are:
    proMYSBL8.bootloader.extended_fuses=0xFE
    the biggest issue I had was probably with ARduino IDE .. that one I enver manged to set the fuses ( I read somewhere it should.. but maybe I´m wrong) . Anyway it works when I set the fuses and upload it with AVRDUDESS.
    (note: hello me 1 year into the future, just do what I say ! )
  • I just add another note to myself ( And anyone else that lost their hair wondering why the bootloader was lost....)
    DO NOT UPLOAD SKETCH ONLY WITH USBASP ... it deletes the bootloader .
    yes I know it is mentioned on the foru m.. just found it .. but I mention it again...
  • @badmannen
    and here is a good simple explanation of the fuses
    http://www.martyncurrey.com/category/atmega/
    FYI: If you run the ceramic resonator at 8mhz, with the zero wake up fuse setting, you can wake the atmega328p up in less than 4usec. This is a huge power savings compared to all other options.
  • @neverdie aa thanks for the info. Might be useful for some other nodes I will do.
    @badmannen You're welcome. I even measured it on an oscope just to be sure, so I'm certain it is true.
  • This style?
    € 1,09 8%OFF | 20pcs Ceramic Resonators ZTT 4M 6M 8M 10M 12M 16M 4/6/8/10/12/16MHZ DIP-3 Crystal Frequency Element
    https://s.click.aliexpress.com/e/mRfXWk8Nd
    @badmannen no. It's built in. You already have it.
  • @neverdie aa ok sorry got confused there for a second. I'm running the internal, so I guess I will pop them off again now then and burn that fuse for a quicker startup 👍🏻
    @badmannen yes, it must be the internal resonator.
  • Hello, will there be a good soul that will help improve the program? I know what the error is but I have no idea how to correct it.
      interruptReturn = sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, ONE_DAY_SLEEP_TIME);
    when i change
    PRIMARY_BUTTON_PIN
    the interruptReturn = 1, but when i change
    the interruptReturn = 0.
    My question is how can i chane it to send 1 and 1 by both contactrons.
    Full code:
    #define MY_NODE_ID 100
    #define MY_PARENT_NODE_ID 0
    #include "Vcc.h"
    #define SKETCH_NAME "WindowSlimSensor2pcs_smallR"
    #define PRIMARY_CHILD_ID 1
    #define PRIMARY_BUTTON_PIN 2
    #define SECONDARY_CHILD_ID 2
    #define SECONDARY_BUTTON_PIN 3
    #define BATTERY_REPORT_DAY 2   // Desired heartbeat interval when inactive. Maximum heartbeat/report interval is equal to this due to the dayCounter.
    #define BATTERY_REPORT_BY_IRT_CYCLE 10  // Adjust this according to usage frequency.
    #define ONE_DAY_SLEEP_TIME 86400000
    //#define BATTERY 3
    //MyMessage msg3(BATTERY, V_CUSTOM);
    int dayCounter = 0;
    int irtCounter = 0;
    bool interruptReturn=false;
    const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
    const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
    const float VccCorrection = 3.43 / 3.455;  // Measured Vcc by multimeter divided by reported Vcc
    const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
    Vcc vcc(VccCorrection);
    //Vcc vcc;
    #ifdef MY_DEBUG
    void before(){
        Serial.begin(9600);
          //EXTERNAL pull-ups
        digitalWrite(PRIMARY_BUTTON_PIN, LOW);
        digitalWrite(SECONDARY_BUTTON_PIN, LOW);
        sendSketchInfo(SKETCH_NAME, __DATE__);
        present(PRIMARY_CHILD_ID, S_DOOR, "Lewe Okno");
        present(SECONDARY_CHILD_ID, S_DOOR, "Prawe Okno");
      //  present(BATTERY, S_CUSTOM);
        uint8_t reedState;
        uint8_t reedState2;
        static uint8_t lastReedState = 2;
        static uint8_t lastReedState2 = 2;
        sleep(5); // Short delay to allow buttons to properly settle
        reedState = digitalRead(PRIMARY_BUTTON_PIN);
        reedState2 = digitalRead(SECONDARY_BUTTON_PIN);
      if (!interruptReturn) { // Woke up by timer (or first run)
        dayCounter++;
        if (dayCounter >= BATTERY_REPORT_DAY) {
              dayCounter = 0;
              sendBatteryReport();
      else {    // Woke up by pin change
                irtCounter++;
            sleep(5);
          if (reedState != lastReedState) {
            send(msg.set(reedState==HIGH ? 1 : 0));
            lastReedState = reedState;
          if (reedState2 != lastReedState2) {
            send(msg2.set(reedState2==HIGH ? 1 : 0));
            lastReedState2 = reedState2;
          if (irtCounter>=BATTERY_REPORT_BY_IRT_CYCLE) {
            irtCounter=0;
      // Sleep until something happens with the sensor,   or one sleep_time has passed since last awake.
    void sendBatteryReport() {
              uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
    Welcome to the forum @Grzegorz-B
    Change
    to
    uint8_t interruptReturn= INTERRUPT_NOT_DEFINED;
    and
    to
    if (interruptReturn== MY_WAKE_UP_BY_TIMER) { // Woke up by timer (or first run)
    Documentation for the sleep function is available at https://www.mysensors.org/download/sensor_api_20#sleeping
  • @mfalkvidd Thanks! now its works like a charm 😄
    Has anybody succeeded Inn creating an rfm69 version of this?
  • I built a Temp/Hum sensor using Slim Node few years back on Mys 1.5x and it was working for so long without any issues. Now I am trying to upgrade it to Mys 2.2x. I successfully loaded the bootloader on a new ATMEGA 328P-PU. Bootloader I used is minicore as recommended by @m26872 in his original post. I used the "Arduino as ISP" method to load the bootloader as explained in this tutorial How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5.
    Here are the settings I used in my Arduino IDE when loading the bootloader,
    • internal clock 8 Mhz ( again based on the recommendation from the original post)
    • BOD disabled
    • Compiler LTO disabled
    • Variant "328P/328PA"
    Bootloader Settings
    Now I am trying to upload the temperature/Hum Sketch using FTDI cable with the jumper set at 3.3v, I am getting the "stk500_recv(): programmer is not responding" error. Here is how I am connecting from FTDI to Slimnode and the same configuration has worked originally when I built the node but now it is failing.
    Could some experts in this forum please help me to bring my node back to work?
    Sorry about the long post. Appreciate your help.
  • @kiesel do you mean a copy of the same project or something that does a similar job using an RFM69?
    this is an awesome project and after waiting for weeks to get all parts, I finally started building.
    The problem I am facing is that it seems that I cannot get the board working if I use such a 8-pin connector socket. I am generally OK with NOT using such a socket for sensors that "go into production" but for some sensors where space is not an issue or for boards which I want to use for testing different NRF24s etc, I would like to make the socket work.
    Does anybody have any tipps on how to make the radio reliably work with a socket? That would be awesome!
  • 29
  • 90
