@yveaux said in Ikea Molgan Hack:
@magpern the instructions on openhardware.io state that the Molgan must be battery powered while programming:
Well, then I can confirm that you don't have to power the Molgan from batteries just for programming. Burning the bootloader works fine with just power from the ISP port and programming it through FTDI works fine if power comes from the FTDI.
What I found wierd is that the atmega328 had power, the radio had power, it wrote debug messages to the FTDI - when powered through the FTDI, it send radio messages etc, but it just did not receive messages.
Messages where not received until I supplied power to the + / - pads (battery pads).
I did read the instructions on openhardware.io, but I didn't follow then to the t.
@chbla said in Multiple uses battery RFM69 node:
Can anyone suggest a source for the parts? Are there any sources that you can upload the files by any chance?
If you mean can you upload a BOM to a company and then it generates a basket of the items, then i know that farnell and maybe digikey do this. But i only use this feature that is built into EAGLE pcb designer, so i'm not sure if they support it directly on their websites, might be worth a look.
http://www.farnell.com/
http://www.digikey.co.uk
@ozrex,
I don't want to assume your knowledge level. However the truth is that you will probably need to put together different bits and pieces from various threads in order to come up with your own custom solution (the A/C interface (IR) part, the battery part, etc...).
Maybe it is worth it to create your own new thread, or maybe you want to keep researching / trying on your own a little longer first. The latter is admirable, and is the way I usually do it, too. Some times to a fault in my own case. Don't suffer along in silence if you are struggling to find the information, make a thread instead. If it becomes too difficult you may give up. We all need some small successes along the way to keep motivated and keep it fun.
Probably best to create a new thread (I don't want to derail this one too much) but something you might want to look into is OpenMQTTGateway. I use it for my 433mhz, but it also supports RF, BLE, LoRa (and perhaps others in future) all on the same gateway! To me that was the way to go... And so far has been flawless for me.
I am non technical but I have 8 wirsbo stats in my house. One of them is faulty and the unit is now obsolete. Is it possible to purchase one of these pcbs and use it to replace the one in the faulty stat ?
Richard
@sundberg84
I also on my last work removed the LG33, it's faster
Well this most likely have been provided as info, but else it's here:
Remember to burn new OPTIBOOT 8MHz into the Arduino Pro Mini
and then I also use avrdude with a usbtinyISP to set the fuse to not check battery voltage monitoring, this is done after I have flashed this with Arduino IDE
avrdude -c usbtiny -p m328p -U efuse:w:0x07:m```
