I apologize for the questions and how simple they may be, as Im new to this community but very intrigued with the creativity and endless possibilities.
Hi @blackchart,
Unfortunately, all devices are sold out. Further production is possible only when ordering more than 10 devices (in this case, I also can modify the device to suit your needs).
My current roller roller Shutter switch are two pushed buttons up and down. No stop button. When release the push button up or down, the shutter will stop. WIll it be compatible with this board or will i have to change the buttons ?
Ok, finally I found the Problem.
I changed the prescaler value of Timer0 becuase I needed a higher PWM Frequenciy.
Unfortuneatly this also affects the millis() function that is used in gw.wait.
It turns out taht with the changed TImer 0 Prescaler 1ms was not 1ms anymore but less. So the gw.wait(750) where only 750ms/64 which is not enough for DS18S20 conversion to take place.
I liked domoticz (was very easy to set up and use). Together with dzVents scripting wasn't that difficult either. But I also had some problem with it lately, so I was actually thinking about switching to openhab (2).
