💬 simple MySensors MultiSensor Board
Hi, i printed ur boards, its cool thank you :-). However i'm having some trouble getting the radio working properly.
It only works good when i touch the antenna..Im not using the ceramic 0.1uf cap. and the 10k resistor..
is the 0.1uf cap. needed for the radio to work stable?And yes, im using the 4.7 - 47uF Capacitor (Elko)
Thanks again, every cool board
I always suggest to use caps wherever you power the board, because it "levels" or "balances" the current so it has more "stability". The resistor connected to reset is always needed as "pull-up", without that, the processor will either reboot or be unstable.
Hi, I placed an order with allpcb, but during review there was error no noc drill file, can samobody help me to generate them from brd file or is the file missing? Thanx for good board!
@terxw all files from https://www.openhardware.io/view/562/simple-MySensors-MultiSensor-Board were sufficient, when I ordered my boards at allpcb. But you can create them with eagle on your own.
Hi!
I have the same problem as terxw. allpcb.com is missing the "NC drill date". Unfortunately I am not able to create this on my own. Can anybody upload this file?
Port MySensors to PIC32 microcontrollers (ChipKIT)
OpenHardware.io • 22 Feb 2016, 23:07 • openhardware.io 22 Feb 2016, 23:24 -
💬 NRF24 to RFM69 adapter
OpenHardware.io • 15 Jul 2018, 13:18 • openhardware.io 17 Jul 2018, 05:51 -
MySensors Port to MSP430 / Energia
OpenHardware.io • 25 Mar 2016, 08:16 • openhardware.io 25 Mar 2016, 08:36 -
RFSensor
OpenHardware.io • 25 Feb 2016, 21:50 • openhardware.io 18 Dec 2016, 07:54 -
Network Gateway with Sensors/Actuators
My Project • 20 Jan 2015, 14:31 • lunarok 20 Jan 2015, 14:31 -
💬 NModule
OpenHardware.io • 23 May 2017, 14:38 • openhardware.io 10 May 2020, 05:43 -
pressure sensor MPS20N0040D
My Project • 18 Aug 2020, 14:04 • Sameh Bouhafs 18 Aug 2020, 21:15 -
💬 Temperature-Humidity-Pressure Sensor
OpenHardware.io • 11 Jan 2019, 07:19 • openhardware.io 14 Jan 2019, 13:25
