Sensebender Micro
    @ServiceXp @tbowmo - Agree not worth bothering for $4
    Ive ordered 4 units in 2nd batch...
  • Ps. Main page at http://www.mysensors.org/hardware/micro still says preorder but when clicking through imall has in stock.
  • I ordered another couple a few days ago.
    @shabba
    We don't get notifications from itead, when they change the status in their shop.. So we have to check it ourself..
  • update: I got my 3 pcb from pre-order today (germany) and it works fine - really great design! πŸ‘
    @tbowmo I wanna say Thank You again. I really love how small this sensor is. You did a great job!!!!
  • I have mine up and running @tbowmo this is great thank you also.
    Now to learn how to graph my results.
  • I have mine up and running and MYScontroller sees them.
    i'm trying to send and OTA to these devices. but it doesn't seem to be working.
    @hek can you confirm these came with the correct bootloader to do this? i thought i read in the start of the thread it would.
    when i try to send a OTA nothing happens.
    anyone have this working that can comment on what needs to be done to get it working?
    @mvader
    The OTA->flash requires sketches running library code from the development branch (which it isn't currently). The boards comes preloaded with the correct bootloader that supports moving firmware from flash->program memory at boot-time.
    But something must load the flash over-the-air also. This requires that you:
    • Compile the sketch using the dev-branch
    • Enable MY_OTA_FRIMWARE_FEATURE in MyConfig.h
    • Keep node awake
    • Call gw.process() in loop-section (which handles the fw-update-commands in the background and resets node when a new firmware has been uploaded).
    Now that I have received my board I can actually test this code I wrote a while back:). I hope it won't bee too many bugs in it.
    But note that the default temp/hum sketch on these boards sleeps most of the time it wouldn't hear the fw-update requests anyway. It would probably be better to use this feature on boards that always is awake.
    For more information on what is actually happening in gw-process you can look at the code that was added in this push:
    https://github.com/mysensors/Arduino/commit/3a59929b8ed8e1fca9876031264db5d6626876ff
    thanks for the info. I was hoping i wouldn't have to connect up my programmer.. oh well.
  • I guess these can't be programmed, if my programmer doesn't have a DTR line?
    was hoping OTA would work πŸ™‚
    I'll order a new programmer any way, but if there is any other way let me know.
    I tried starting it in test mode. but that didn't work
    @mvader
    It's using a standard ftdi header, as used in the arduino mini pro.
    About the testmode, you should hold A0 to GND, while applying power to the unit. Then it starts spewing data to the serial port.
  • Just recieve my 5 sensbender today. Workin fine after some problem with nrf24L01 and Arduino uno (+3.3V doesn't work)
    It's almost too easy to setup a sensor network (for temperature and humidity) now.
    solder a socket for the NRF module, a battery holder. Plug in the NRF module, put batteries in, and you have a sensor online. (I have 3 sensebenders from tiead online at the moment, together with 2 prototypes). Need to get some more battery holders, before I can make more sensors now.
    I agree! I ordered 4 from the second ITead batch (I let others get their hands on the first batch because I already had a couple OSHPark deployed) and had the first sensor up and running in no time! Great job and contribution to the MySensor's community! πŸ‘ πŸ‘ πŸ‘
    @blacey
    Thanks.. It's actually kind of fun, when I see that things I have created, actually brings value to other people.. Always been a driving force for me (no matter what I have had my hands in, whether it's software of various types,VHF radios for ships, mobile phones, bluetooth headsets, or sensor modules πŸ™‚ )
  • @tbowmo said:
    @mvader
    I had meant that i put it in test mode to try and program it.
    getting it in test mode worked. i could see the led blinking.
    however when i gave up and put the radio back on and turn it on, i guess it had actually taken my upload.
    it was reporting in F now.
    so i know the DTR does the auto reset, i guess upload works, but no reset and/or completed msg in the IDE.
    i ordered a new programmer anyway with DTR.
    I've received some boards and all working good.
    I'd like to upload a new sketch to the Sensebender Micro board and I'm attempting to do this via the FTDI FT232RL USB to TTL serial converter adapter that I purchased here (http://www.ebay.co.uk/itm/221552218333).
    Could someone kindly confirm the pin to pin mapping between the FTDI board and the Senseboard Micro as when I attempt to upload I receive the message:
       Programmer Type : butterfly
             Description     : Atmel AppNote AVR109 Boot Loader
    Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
    I'm using Arduino 1.6.5 running on Windows 8.1 (inside parallels on a Mac).
    Any ideas?
    Thank you
    Nutz
    @nutcracker
    I usually use the GND pin as a guide.
    What happens if you run Arduino IDE directly in your native OS?
  • Thanks @hek. I've had to run Arduino on Windows before because of compatibility issues with certain chip sets on Arduino boards and I didn't fancy running unsigned drivers on my Mac to resolve... I'm able to upload sketches to other boards with no issues.
    That said, I've updated Arduino to 1.6.5 on my Mac and have attempted to upload the default Sensebendermicro.ino sketch to the micro with a similar error:
    Arduino: 1.6.5 (Mac OS X), Board: "Arduino Micro"
    Sketch uses 26,414 bytes (92%) of program storage space. Maximum is 28,672 bytes.
    Global variables use 799 bytes (31%) of dynamic memory, leaving 1,761 bytes for local variables. Maximum is 2,560 bytes.
    Found programmer: Id = "οΏ½dοΏ½οΏ½bοΏ½"; type = F
        Software Version = οΏ½.οΏ½; Hardware Version = οΏ½.οΏ½
    avrdude: error: buffered memory access not supported. Maybe it isn't
    a butterfly/AVR109 but a AVR910 device?
    With verbose output enabled:
             User configuration file is "/Users/nutcracker/.avrduderc"
             Using Port                    : /dev/cu.usbserial-A50285BI
             Using Programmer              : avr109
             Overriding Baud Rate          : 57600
             AVR Part                      : ATmega32U4
             BS2                           : PA0
               eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
               lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
    Nutz
    @nutcracker said:
    Maybe it isn't
    Is your programmer setting in Arduino IDE set to "USBasp"?
  • Hi @hek, I've never had to change the programmer setting before... I've changed it to USBasp and re-uploaded but same error. I've always used the menu options Sketch=>Upload to upload a sketch to the board. Should I be using Sketch=>Upload via programmer for this micro board ? If so, that fails too but something to do with it not being able to find the USB device.
             Using Programmer              : usbasp
    avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
    avrdude done.  Thank you.
    Nutz
    Hmm. I think I understand what the problem is now. You've selected the "Arduino Micro" board. Not our "MySensors/Sensebender Micro" .
    Did you follow the instructions here?
    http://www.mysensors.org/hardware/micro-ide-setup
  • Thanks @hek, I also realised my mistake once I retraced my steps...I hadn't scrolled down fully on that screenshot that shows the Sensebender Micro board... I think what through me is that screenshot also shows a "dot" against another board - the Arduino Micro board...and I was selecting that... duh! (may be worth changing the screenshot? ;))
    Anyway, thanks for your help...sketch uploaded perfectly after that!
             Programmer Type : Arduino
             Description     : Arduino
             Hardware Version: 3
             Firmware Version: 5.0
             Vtarget         : 0.3 V
             Varef           : 0.3 V
             Oscillator      : 28.800 kHz
             SCK period      : 3.3 us
    avrdude: reading input file "/var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex"
    avrdude: writing flash (23678 bytes):
    Writing | ################################################## | 100% 8.84s
    avrdude: 23678 bytes of flash written
    avrdude: verifying flash memory against /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
    avrdude: load data flash data from input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
    avrdude: input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex contains 23678 bytes
    Reading | ################################################## | 100% 9.94s
    avrdude: verifying ...
    avrdude: 23678 bytes of flash verified
    Cheers!
    Nutz
    Ah... there is a dot in the menu-image. Will update it. Thanks.
    @hek Interesting.. I didn't know this.. I used the standard Pro Mini 3v3 and it worked...????
  • Received my Micros today. Luckily there was no custom and a lot of pins to solder. Can't wait to solder them on wednesday on work and test them.
    Is there any instruction how to solder everything? On which side the radio module needs to be soldered.
    @gloob
    This might help you out πŸ™‚
  • I hope this question has not been answered already and I did not miss the answer. I was thinking about connecting a motion sensor to this and was hoping that one of the digital pins supports an interrupt. Is there an interrupt available?
    @gbfromhb
    I'm planning to do the same thing.
    i ordered my 5v step up regulators to support the PIR sensor.
    although I hope adding the motion isnt going to kill the batteries.
  • @mvader
  • @Hek
    Thanks, I saw the D3, but I'm new enough to this adventure that I was not sure if I should have assumed that it also had an interrupt like all the other boards.
    @gbfromhb
    I tried to keep the naming, and pins on the atmega, the same as an ordinary arduino πŸ™‚
  • @gbfromhb said:
    @mvader
    wow.. nice.. thanks for the info! I will give this a go asap.
    I have one more question. Is it possible to power the micro from the ftdi pins? I would like to use jumper wires.
    @gloob
    Yes it's possible to power it from the FTDI pins, if you want to..
  • Are there any recommendations for a low power temperature, humidity sensor regarding the update cycle.
    Currently I plan to wake up the sensor each 10 minutes instead of each 1 minute to update the values. This should increase the duration of the battery. A complete update of all values if performed each 30 minutes as usual.
    I would probably choose 5 minutes interval instead.. I have updated the sensebendermicro sketch tonight (just waiting for @hek to approve it). so it holds of on the transmissions a bit. Now the temperature needs to change more than 0.5 degrees from the previous transmitted value. OR
    humidity needs to change more than 0.5, measured with a moving average. OR
    30 minutes since last transmission.
  • I found that when I power the micro from 2 batteries I get the following error:
    T: 23.21
    H: 50
    send: 104-104-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:23.2
    send: 104-104-0-0 s=2,c=1,t=1,pt=2,l=2,st=fail:50
    This does not happen when I power it from the FTDI programmer.
    Does anybody have any ideas?
    The batteries have a voltage of 3.25V
    I did not have this issues with my arduino nano sensors. and i did use the same radio modules.
    When I check the modules they seem to be real nrf24l01+ modules:
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
    RX_ADDR_P2-5	x00 = 0xc3 0xc4 0xc5 0xc6
    TX_ADDR		 = 0xe7e7e7e7e7
    RX_PW_P0-6	x00 = 0x00 0x20 0x00 0x00 0x00 0x00
    EN_AA		 = 0x3f
    EN_RXADDR	x00 = 0x03
    RF_CH		 = 0x4c
    RF_SETUP	x00 = 0x07
    CONFIG		 = 0x0f
    DYNPD/FEATURE	x00 = 0x00 0x00
    Data Rate	 = 1MBPS
    Model		 = nRF24L01+
    CRC Length	 = 16 bits
    PA Power	 = PA_HIGH
  • I have a batch of 5 sensebender and actually I build 3 and one of them doesn't work properly. Lot of st:fail when I put my finger on the board it works better so I try to make all solder one more time but it's not ok. I try with few radios and same radios work well on the others sensbender.
    Any idea or way to exchange with Itead ?
    @Fabien
    Where exactly do you put your finger on it, in order to get it working?
    @gloob
    It's the same power rail (FTDI, and the battery connector). What do you supply the board with, thru the FTDI header?
  • @tbowmo difficult to answer this question. It seems to be on Atmega but after trying to resold it's not better. I resol capacitors, resistors ... I don't know what to do now ...
    @Fabien
    Did you also resolder the atmega itself?
    Could you try and measure supply current it uses?
  • current when powering on : 20 mA and during sleeping about 20uA (not very accurate).
    @Fabien
    Have you tried to add an extra capacitor to the NRF module, on the one that's bad? (Could be your finger adds a bit more capacitance, I know it's a wild guess but just trying to think out loud)
  • Ok but wich value ? I just finish to solder my 4th sensebender and ok too.
    Does the failed messages reach their destination (gateway in your case)? As you might know it is the ack that never reaches the sensbender node which could be a result of power issues on the gateway side.
  • no, message are not recieve. I find someting :
    When I touch the NRF24 antenna (just a little it sifficient), it works. fine.
    Strange, same radio on other sensebender doesn't need this and other radio on this sensebender need to bo "touch".
    I try with 10uF additionnal on NRF but no change ...
    Do you use a socket or is the NRF module directly soldered onto the sensbender?
    (a bad connection in socket could be a problem... and when you press NRF module it has connection again)
  • Yes it's directly sold (and very hard to change with metallised hole). I will give a last try with another radio ...
  • Ok end of story ... sensebender card is dead ! 2 metallized hole were destroy by solder/unsoldering NRF modules.
    Hope my last Sensebender will work. And if there is a batch with light version I will reuse T/H sensor
  • @Fabien it seems that you have the same problem as me. I ordered a new set of radio modules to test if it is the fault of the radios. I will give feedback here about my progress.
    I aleady tried to add capacitors on the radio module but this did not help.
    There is also no difference if I power the micro from the FTDI or the battery connector.
    @Fabien
    Unfortunately I don't think there will be a light edition coming out at the moment. Currently the savings is way too small (I'm estimating a savings of 4-5$ compared to the full sensebender edition).
  • @gloob it's not a radio problem. Same radio works on the others boards.
    @hek I will try to repair the board ...
  • looking for some help programming this thing.
    I had a pl2303 usb programmer, but it had no DTR, so i orders a new usb programmer
    this one is a cp2102 with a DTR line.
    but still the same problem. it never uploads the code.
    i have the right board, processor and port chosen.
    i have tried all the programmers in the IDE but none work.
    it just says "uploading" and then eventually errors out.
    any suggestions?
    EDIT: nm i read something about switching tx and rx and i figured what the heck and surprise it worked..
    sketch uploaded..
  • Hi @tbowmo
    Thanks for bringing this great project to the community.
    I'm trying to understand the sensebender's power profile, especially the sleep current.
    I have previously done some measurements with the atmega328p (pro mini) + NRF. In addition to that I have also looked at the datasheets for the other components on the sensebender.
    It seems the theoretical low sleep current consumption is something like this:
    * nrf24l01+    900nA
    * atmega328p     5uA (with WD)
    * si7021        60nA
    * atsha204      30nA
    * at23df512c   300nA
      =  Total     6.3uA
    The SBMicro seems to draw ~50uA in sleep mode with the default configuration.
    I managed to put the flash memory into "ultra deep sleep"(*), causing the total consumption to drop to ~27uA. So there is still around 20uA that is not accounted for.
    I've also tried putting the atsha204 into sleep, but that did not make any difference (also confirmed by the specs).
    Are there some other settings/sleep modes that have not been enabled yet? What about the atmega itself?
    Do any of you have the a sensebender prototype with separate components, and can test sleep current by removing components one
    by one? (Before I start cutting traces on my own sensebenders in order to zero in on the target component).
    Is there something I'm missing?
    Datasheets:
    ATSHA204
    AT25DF512C
    Si7021 A20
    (*) in setup(): flash.initialize(); flash.ultra_deep_sleep() <- From datasheet
    @tlund
    Interesting figures.. are you sure that you've got a genuine nrf24 chip on the radio? Could be a fake with higher power consumption.
  • @tbowmo
    My NRF's are the same $1 nrf's listed in the mysensors store, so probably fake. But I have still measured them to draw ~900nA in powerDown.
    But I think I have found the culprint now. It seems the extra 20uA is caused by Arduino 1.6.5 (it may be that my installation is faulty).
    My test setup:
    • pro mini
    • nrf
    • a simple sketch that does gw.sleep(60s)
    1st test: sketch compiled & uploaded via Arduino 1.0.5-r2: 6uA
    2nd test: sketch compiled & uploaded via Arduino 1.6.5: 24uA
    @tlund
    Hmm could it be some optimization that causes the atmega to not go into deepest sleep mode?
    Maybe someone should have a look at the assembler output from a build with both versions of arduino
  • I'm back with bad news ... My 5th sensebender have a lot of st:fail like the first one. But now I know why !
    There is only one same things between the two board which fails : The FTDI connector. It's 90Β° connector and pins are just below the antenna. And I think tunning is not ok.
    So, when I go to work I try to remove the FTDI connector and see if connection is better !
    @Fabien
    That ftdi connector could have some effect on the antenna. I specifically made the area below the antenna empty, so that it wouldn't make any problems with the antenna.
  • So now the good news. I "repair" my 1st SenseBender (only two wire but one on the ATMega) and it works (with the same radio wich failed). I remove the FTDI header and everythings is ok. So now I'm sure the problem is the FTDI header near the antenna. And be carefull, we can have the same problem with battery for example. I suppose minimal distance is about 3.2 cm (lambda/4).
    But now I have a question : How can I update sketch without header (0Β° header doesn't fit in case). OTA ? Is ther a tutorial for OTA update with out of the box SenseBenderMicro ?
    Thank for your help !
  • I have the FTDI headers on the opposite site and I also get this transmission errors.
    I ordered a new batch of NRF24L01+ modules and will check if the problem still exists.
  • I have my FTDI headers on the other side as well and have no transmission errors.
    I am using genuine NRF+ radios though.
    could be the fakes causing a problem
    I have a male connector on my FTDI thingie, so I just put it in the mounting holes on the micro, and hold it to one of the sides, so it makes contact.
  • @tbowmo
    I tried uploading the sensebender sketch using 1.0.5-r2 with board config "pro mini 328 3.3V 8MHz". The si7021 doesn't work in this configuration, but I managed to get a sleep current of ~6.8uA
    I can provide the binary output from the two IDE versions if someone can give me an indication where to find the build binaries.
    @tlund
    I think it's better if we can get the intermediate asm file from the compiler chain. Will look at it tomorrow evening (I have closed my computer down for the evening today)
  • @gbfromhb said:
    @mvader
    I just wanted to follow up and say thanks for the link/info
    i was able to get that working.
    surprised that they just don't offer a 3v pin.. it works great the way that link shows
    Thanks again!
  • Has anybody built a box for the standard Sensebender Micro with 2 AA batteries yet.
    I would like to get the .stl files if so
    Thanks Doug
    Thanks Doug
    Hi Doug,
    @ServiceXP has posted this one: http://forum.mysensors.org/topic/1566/mysensors-sensebender-micro-3dp-case
    Al
  • Has anyone been able to "Include" it to VERA UI7, My Sensebender borad is working fine according to the output from the Arduino terminal window - it request a node id, but will not "include". I'm using the default code already installed in Sensebender Micro board.
    /Kurt
    Yes, it works in UI7. Are you using the correct Vera-branch?
  • If somebody is looking for some Sensebenders. They are in sale currently for only 14$
    http://imall.itead.cc/mysensors-micro.html
    Edit:
    I thought I had paid 17$ but they were initially sold for 14$. Sorry.
  • I just order 4 new sensebender, NRF24L01+ (normal and PA+LNA), and Iboard for the gateway. Shiiping is quite expensive (about 31 $)
    @Fabien
    Did you choose DHL as shipping option?
  • I just tried to order something from them and for some reason DHL is now the only available ( US ) shipping option, and it's quite expensive. The sensorbenders I ordered last month were ~$6 shipping, the other components I looked at today via DHL (similar size) were $46, so might be worth holding off a bit until they restore the air-mail option.
    $46 in shipping is a bit hefty. I'll check what's up with their air mail shipping.
  • @hek I have seen it happen once before with them -- wait a few hours, or at most a day and it'll be corrected if history repeats...
  • My last order have cheap shipping costs. But this time I buy lot of things, and shipping price is probably higher du to the weight.
    @gloob You fell for the oldest marketing trick in the world. I also missed a heartbeat when pressing on the clearance banner and seeing sensebender there!!!
    @Moshe-Livne @gloob
    The sensebender is shown under the "new stuff" banner πŸ™‚
    (At least in the email I got from Itead :))
    @tbowmo or @hek: Could you point me to the right Mysensors bootloader directory please? Is it this one https://github.com/mysensors/Arduino/tree/master/MYSBootloader ? I think yes, but I have seen others links, so I am not sure. I would like to add and test some ulpnode functionalities and would like to start with the right bootloader.
    @scalz
    for the sensebender, we are using DualOptiboot, as we have an external flash onboard, that we can use for OTA firmware updates (it requires dev branch of mysensors though..)
    @tbowmo: thank you for your reply. So what is the difference between your link and the one I posted just before (I have not checked yet) ? So, for the moment there is no Mysensors bootloader for stable, isnt it? I just need to add some pin toggle to make some tests (enable dc booster on my board, tune clock, and keep the ota stuff...) and wanted to stick to the stable branch but no problem I will move to dev branch, I think it is time πŸ˜ƒ .
    I don't remember who wanted to use ws2812 in bootloader (maybe it is you?) but there is an implementation in ulpnode bootloader if you are interested : https://github.com/hallard/Arduino-Boards/tree/master/1.0.0/bootloaders/ULPoptiboot
    @scalz
    It's two different bootloaders. the one you have linked to is handling the radio in the bootloader, and can reprogram itself OTA without an external flash attached.
    The one I have linked to, is using an external flash (on the sensebender) and by loading the external flash with a new sketch, it will cause the bootloader to load the content of the external flash, into the internal flash. The same concept is used in LowPowerLabs moteino boards.
    In order to use dualoptiboot, your sketch needs to support the external flash, and write the firmware it receives OTA to it. This functionality is only available in the dev branch as of now. I don't know if @hek has tested it yet? (I have been busy with a lot of other things lately so haven't got around to test it here..)
    @tbowmo:it is clear to me now. I will dig in.
    Thank you for your valuable help.
  • I try to make OTA update for sensebender using 1.5 branch sketch on the sensebender (sensebender github sketch from 1.5 branch) and MYSController but it doesn't work. Any idea ?
    @Fabien
    Have you enabled spi flash, and Ota functions in the constructors for mysensors?
    @Fabien MYSController is currently not supporting Sensebender board OTA - however, WIP and beta will be released soon. stay tuned πŸ™‚
    @tekka
    Have you had the chance to get a sensebender board? As I still haven't verified the library code it probably could contain unverified features (== bug). Send me a ping on hangout if you need a board to test on. We should probably combine our effort.
    My last days of vacation has been filled with (family) activities. On my shortlist is the thermostat/HVAC device support (still a bit messy but I hope to get the devices from dev-branch into master together with the hvac thingies). Ping @pjr, @stephenmhall .
    http://forum.mysensors.org/topic/1337/request-new-sensor-type-thermostatically-controlled-switch/7
  • @hek
    I have used the one mentioned here: http://www.mysensors.org/controller/vera
    Still cant include, but I have had these problems before with e.g. a relay or motion sensor - but after several tries it include a appear in the user interface.
    But perhaps the software installed on the board does not use the same frequency as default Sensornet lib's are using?
    /Kurt
  • Thank you @tekka and @tbowmo. I don't change the constructors and if MYS doesn't support OTA, it can't work. I will upload a modified version tonight to be ready when MYSConrtoller will support sensebender.
    I have to upload new sketch with 1.5 branch on gateway too ?
  • Today I received a new batch of radio modules and all problems with transmission fails is gone.
    @gloob can you share where you got the good nrf from?
  • @Moshe-Livne just FYI - i ordered all my NRF's from the same place i ordered the sensebender boards from.
    and they were all legit NRF's came in their own boxes and have worked great.
    http://imall.itead.cc/wireless/im120606002.html
    My Sensebender has been running for a month now with 2xAA with the default sketch (which have improved a bit since then). Battery level has dropped 5%.
    We've had a few hot days (inside the house) during the summer (Deg C).
  • 347
