    @Anticimex wanna beta-test? 😉
    @tekka for sure 🙂
  • @tekka - i do 🙂 i use it every day
    @cdr said:
    I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
    I think I am running into the same thing. How did you fix this? I have many nodes so switching back to 76 is not a good option for me.
    You can edit myconfig.h and have te recompile after change.
    @cdr I've never recompiled a bootloader before but when I did some searching it seems that I need the .c file to do this. Maybe I'm missing something and I can recompile the .hex? How did you end up doing it? Thanks!
    I did some more testing and my issue definitely appears to be a result of changing the channel in MyConfig.h. I just built a serial gateway with channel 76 selected and everything worked perfectly. The only problem is I have over 20 nodes located throughout my house so re-uploading the code so they use that channel is not something I'd like to do if I can avoid it. Does anyone know how I can recompile the bootloader so I can change the channel?
    I tried the files @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7 but it did not work.
  • in firmware_config.csv file what is the first column "type" for? And where do I get "type" codes?
    @niccodemi type can be any numeric value used to identify a specific firmware type - this value (together with FW version and the FW CRC) is used to automatically update the nodes.
  • @petewill did you have any success finding out how to change default channel?
  • I recently switch to RFM69 and I know it's not yet compatible with MYSBootloader. But I can't find information about RFM69 and dualoptiboot support for OTA in MYSController (without a sensebender). Is it possible ? I have to make special config ? Thank !
    @Fabien DualOptiboot is completely radio agnostic. You should not need any custom config to use OTA with DualOptiboot and rfm69. You do need an external flash on your board though.
  • @Anticimex ok but in MYSController is there a way in the GUI for setting the bootloader (DualOptiboot or MYSBootloader) or is ti automatic. I ask this because you have to tell MYSBootloader your are running SenseBender (DualOptiboot).
    @Fabien yes, select "sensebender"...this will do the trick
  • Thank you @tekka I don't test your new bootloader beacuse I think you don't have RFM69 version (perhaps in th future ?)
    @Fabien perhaps, will have to get some RFM69 hardware first...
    Sorry, don't know how I missed this. No, I haven't. I got sidetracked (kids) and I haven't had a chance to work on it further.
    @niccodemi I just was able to upload the bootloader using the files provided by @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7. The difference is I used a USBASP (V2.0) instead of an UNO. It worked the first time uploading the blink sketch!! It was a pain getting the USBASP to work on Windows 8.1 but after I got the driver installed (and the wiring connections correct) it worked great. I haven't uploaded any sensor sketches yet but hopefully I'll have time to play with it soon.
  • @petewill thanks, I tried ch77 and it works great.
  • Hi, download link for MYSController is broken. Error on attempt to download. thank you
    @balloonguy Not on my side. Please try again.
  • @tekka thanks for the quick response - i have tried the {http://goo.gl/9DCWNo} with no luck, all i get is a "this page is not available" message. I have tried with different browsers and different pc's - still the same response.
    BTW- Merry Christmas.
  • @balloonguy just tried this link. Everything is working, MYSController.zip file with md5 checksum dfe98f9e7ed6e1c3d5c418a862c23ee0 is downloaded.
  • Hi @tekka
    When editing/adding items to the firmware_config.csv file, what should go in the types column? Could you please explain it?
    The type field is intended for defining a FW type, e.g. a node with a DHT humidity/temperature sensor may be FW type 1, whereas a node with a different sensor FW type 2 and so on...
  • Now that I have sensors that have the correct bootloader I have been able to upload firmware a few times. But now that I have made changed to the sketch and copied the new hex file over I even bumped the version tag in the file. I can't get it to flash. Nothing I do makes it upload the new code? Thoughts?
  • @p0lar are you still able to remotely reboot node?
    @p0lar Please provide MYSController log with DEBUG enabled for further troubleshooting.
  • Yes I can reboot the node. trying to upload dallastemp to it.
    MySensors_20160102-104854.log
    @p0lar I do not see any DEBUG nor bootloader messages. Can you update the GW sketch with DEBUG enabled? Also, what bootloader did you flash?
  • Its turned on in MySensors.h and reuploaded
    MyConfig.h
  • But i dont see anything. UNO ethernet GW with SoftSPI enabled
  • Bootloader on the sensors is the one from your firmware directory. on the GW its the standard arduino one... do I need yours on the GW?
    @p0lar No, GW should have normal (i.e. Arduino) bootloader. However, without DEBUG output it's gonna be hard to diagnose what's wrong - can you double-check your settings and re-upload the GW sketch just to be on the safe side.
    Also, I'd like to see the log during a manual reset (not remote reboot) of your node.
  • Thanks. Ill check that when I get back into town end of this week.
  • Hi @tekka,
    tried now some evenings to change node-id / clear the eeprom. No luck. FW update works always. After reading the bootloader code I expected myscontroller to send a invalid fwrequestresponse packet with special crc for the bootloader commands. Never showed up in the log.
    Myscontroller .282 on Win xp and msbootloader 1.1 on nano. 47uF on nrf. No transmission errors.
    Any ideas where to look next ? Maybe .278 will do the trick ?
    Thanks for your efforts ,
    stebra
    @stebra please post the myscontroller log with gw DEBUG enabled that shows OTA update and ID reassign request.
  • MySensors_20160110-115615_stebra.log
    hi tekka,
    here is the log. Contains:
    [2016-01-10 12:02:26.390 Info] INFO *** Logging START *** // stebra : succesful reboot of node 6 via myscontroller
    [2016-01-10 12:02:59.000 Info] INFO *** Logging START *** // stebra : succesful FW update of node 6 via myscontroller
    [2016-01-10 12:05:35.109 Info] INFO *** Logging START *** // stebra : ID reassign attempt of node 6 to node 12 via myscontroller
    [2016-01-10 12:05:48.328 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
    [2016-01-10 12:06:37.437 Info] INFO *** Logging START *** // stebra: Clear eeprom attempt on node 6
    [2016-01-10 12:06:44.812 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
    thank you for having a look..
    and also a ss for another reassign attempt node 6--> 12.
    FIRMWARE_CONFIG_REQUEST is not answered from myscontroller. therefore no reassign of node id.
  • Maybe I should open a new topic for this, but I cannot flash bootloader, I always get
    Arduino: 1.6.7 (Windows 10), Board: "ATmega328 internal 8Mhz with MYSBootloader"
    ***failed;
    avrdude: verification error, first mismatch at byte 0x0000
    0x3f != 0xff
    Here is the verbose message
    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0xFF:m
    avrdude: verifying ...
    avrdude done.  Thank you.
             Programmer Type : STK500
             Hardware Version: 2
             Firmware Version: 1.18
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
    avrdude: erasing chip
    avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
    avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
    avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
    avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes
    Writing |  ***failed;
    avrdude: verifying lock memory against 0xFF:
    avrdude: load data lock data from input file 0xFF:
             0x3f != 0xff
    I get same message with both 3.3v and 5v pro mini that is linked in the store.
    I am using Funduino uno as a ips, and I can flash blink f.eks. using uno as isp, but I cannot flash bootloader. This is the step 6 from the instructions that is failing. Any ideas how to fix this? I would really like OTA as my network is slowly growing.
    Thanks for any tips!
  • I think I have flashed MYSBootloader finaly, after ~6hours of trying and reading (persistent guy 🙂 )
    The instructions are for the older version I guess, right board should be copied from MYSController/bootloader/boards.txt, not from this topic post#75. Now I am trying to figure how to flash the sketch, but I guess that is explained somewhere on the topic
  • Just one more question, I didn't find it answered on the topic (maybe too tired), but:
    I have existing network with ethernet gateway and some nodes, and all is working fine. To make it OTA update-able, I need to
    1. i upload ethernet gateway to the Arduino Nano, then flash MYSBootloader on it,
    2. upload some sketch (which?) on Arduino Mini nodes, and then flash MYSBootloader on it, and then I can program it OTA?
    3. Or something else?
    Or did I miss the point completely? 😞
  • so from what I know.
    you DONT need the MYSBootloader on the gateway. just normal arduino bootloader. you DO need the MYSBootloader on ALL the sensors you with to connect to your gateway.
    Do the MYSBootloader first then use this tool to upload the firmware to your sensors OTA
    @dakipro I use the settings mentioned in #75 in Atmel studio, however, AVRDUDE does not support the upper two bits of the lock fuse (therefore the error message 0xFF!=0x3F). Changing the lock bits to 0x3F should do the job.
    And yes, as @p0lar pointed out, only the nodes and not the gateway should have MYSBootloader.
  • HMM i cant build a DEBUG version of the ethernet gateway... even when I try to define it and print hello world it wont... weird.. any ideas?
  • Aha, I get it now. Then I just flash MYSBootloader on the sensor, and attach the radio and it will automatically connect to the gateway (it has some sort of sketch/communication with MySensors built in)? And then I use the MYSController to upload my sketch as described?
    Or how do I upload a initial sketch if I cannot use arduino anymore?
    Btw, I love MYSController, i use it all the time in development as it shows all that is going on with the sensors, thank you very much for developing it!
  • correct. you build the .hex file in arduino studio or whatever and copy it to the MY gui firmware folder and edit the csv file and then reload.
    http://forum.mysensors.org/topic/1066/bootloader/8
    This should help
  • I thinking I am build a DEBUG version of the GW code. but I dont think the logging is working in the app with my eth GW. am I mising something?
    So. when I build a DEBUG version of the GW code I get this in the serial console hex size=29k so its bigger.
    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:71.6
    1;1;1;0;0;71.6
    0;0;3;0;9;read: 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
    2;1;1;0;16;0
    the NON DEBUG I get this. hex size = 26k
    1;1;1;0;0;69.8
    1;0;1;0;1;35.0
    1;1;1;0;0;71.6
    1;0;1;0;1;36.0
    1;1;1;0;0;73.4
    1;0;1;0;1;37.0
    2;1;1;0;16;0
    1;1;1;0;0;71.6
    2;1;1;0;16;0
    that looks good 🙂
  • Still nothing in the MySensors Debug tab... and only the NON debug info in the log files. maybe this is a ethernet GW issue? So I get debug info in the Arduino Serial monitor but no debug via TCP?
    [GENERAL]
    VERSION=0.1.2.282
    [COMMUNICATION]
    COM=COM1
    SPEED=4
    IP=10.1.1.200
    PORT=5003
    TCPACTIVE=1
    [STATUS]
    LOGGING=1
    DEBUGGING=1
    SENDMSG=1
    LOGPARSE=1
    AUTOFW=0
    AUTOID=1
    UTCTIME=0
    CLOSECONFIRM=0
    FILTERLOG=1
    SAVENODES=1
    METRICSYSTEM=0
  • @tekka : I tested the ID reassign by hardcoding the functionality in the serial gw sketch. Reboot node 6, wait for FW_CONFIG_REQUEST, answer with FW_CONFIG_RESPONSE.
    Works as expected & described in the MYSBootloader code. Please give me some hint why MYSController does not send the FW_CONFIG_RESPONSE packet with the bootloader commands after the reboot.
    I trigger the reassign via the node´s context menu in the gui, MYSBootloader Commands --> reassign ID. Anything wrong with that ?
    Maybe someone else has an idea what is happening/not happening ? @tekka could you find something in the log file?
    Thanks a lot...
  • Has anyone tested successfully reassigning the node-id with MYSBootloader 1.1 and MYSController 1.2.282 ? Would give me some new motivation to hear it's possible and has been done before. At the very moment I m at a dead end.
    If it is not working for you, I would also appreciate your feedback.
    @tekka
    Is the (dev branch) MQTTClientGateway supported by MYSController?
    I'm in the process of moving from Vera and Ethernet GW, to Openhab with MQTTClient gateway and would love to have the OTA functionality your bootloader and controller provides. I looked at this a while back, but ran out of time to play!
    So yeah.. Can MYSController talk with the MQTTClientGateway ( over Ethernet) ?
    Cheers,
    Greg
    In answer to my own question... No..it doesnt seem to.. ;-(
    I tried with the IP address of my MQTT client gateway board, and port 5003 ( same port that works for my 1.4 Ethernet GW )
    It says it connects, but no data flows in....
    @tekka @hek - Is it unlikely that the MQTTClient Gateway will be usable with MYSController??
    If not, would this work?
    Have two networks -
    1 for MYSController to perform OTA's using a serial gateway on the PC we typically do sketch changes on.
    2 for normal MySensors operation. When you want to invoke an update, you could send a I_REBOOT command ( MQTT message in my case), which would reboot the node and if i understand correctly, look for an update on the other network channel.
    I guess you would loose all the other functionility of MYSController, but at least we could do OTA.
    Cheers,
    Greg
    @stebra The log looks normal - is the node directly communicating with the gw or via a repeater? Does the clearEEPROM option work?
    @gregl MYSController is currently not supporting MQTT, I'll add it to my feature request w/o ETA.
  • @tekka
    No repeater, clear eeprom via MYSController gui does not work. Clear eeprom via sketch works, node gets new id after reboot.
    My assumption is that MYSController does not respond to the FW_CONFIG_REQU after reboot.
  • @tekka You might not have to. I've been working on Node-Red as a controller and more.
    With my kit, you need Node-Red, node-red-contrib-mysensors , Mosquitto, and some of my flows which I have available ( http://forum.mysensors.org/topic/2802/flow-to-turn-serialgateway-into-mqtt-serialgateway ).
    And it makes this:
    http://forum.mysensors.org/topic/2815/flow-to-turn-serialgateway-with-mqtt-flow-to-ethernetgateway
    The only flaw is that when you first connect MYSController, you need to send a junk topic so that MYSController can receive data. It's a bug/peculiarity with Node-Red, but honestly not a big deal. I'm also working on how to fix even that.
  • @tekka
    Can you verify it works for you? Do you see any response packets with the bl commands in your log?
    First time i try OTA. Everything went well until fw update (Pro mini). It sends/recieve like 20-30 packages, and then ends. I need to reconnect Myscontroller and it will start to flow again. I can see there is requests from node on gw led, but nothing comes through in Myscontroller (.282). Using 2.0b ethernet gw. Its just like either GW stops sending to Myscontroller or Myscontroller doesnt accept it. Also getting in domoticz that "MySensors: Connection reset!" Do i need to disconnect Domoticz while I do updates?
    Any clues?
    Edit: Sorry, jepp - needs to disconnect Domoticz and it works... I bet its those new gateway pings from Domoticz killing it.
    A quick one: How long does the OTA takes for Blink sketch?
    I press update FW, it start rolling and the node changes status from "fw updating" to "booting" but then goes back to fw updating... have been going like this for a long time now (1000 packages sent/recieved).
    Also - is it possible to upload via fdti with MYSBootloader or you need to use OTA?
    Edit: somethings is not right, its rebooting or starting over again:
    2016-01-16 21:09:41	RX	14;255;4;0;2;0A0001002F00
    2016-01-16 21:09:43	TX	14;255;4;0;3;0A0001002F008083E1EBF0E0808184608083E0EBF0E0
    2016-01-16 21:09:43	RX	14;255;4;0;2;0A0001002F00
    2016-01-16 21:09:45	DEBUG	Undefined firmware/type for node=14
    2016-01-16 21:09:45	INFO	BL version=257
    2016-01-16 21:09:45	INFO	Send FW info to node 14: type=A, version=1, blocks=0x0048, CRC=0xD098
    2016-01-16 21:09:45	TX	14;0;4;0;1;0A000100480098D0
    2016-01-16 21:09:45	RX	14;255;4;0;0;FFFFFFFFFFFFFFFF0101
    2016-01-16 21:09:46	DEBUG	FW update started, node id = 14
    2016-01-16 21:09:46	TX	14;255;4;0;3;0A0001004700E1F30E940000F9CF0895F894FFCFFFFF
    2016-01-16 21:09:46	RX	14;255;4;0;2;0A0001004700
    2016-01-16 21:09:47	TX	14;255;4;0;3;0A0001004700E1F30E940000F9CF0895F894FFCFFFFF
    2016-01-16 21:09:47	RX	14;255;4;0;2;0A0001004700
    2016-01-16 21:09:48	TX	14;255;4;0;3;0A00010046002C020E947000C0E0D0E00E948B002097
  • @tekka
    Fortunately a helpful guy gave me your bootloader 1.3 beta, which fixes the problem with nonworking bootloader commands. It seems I was not the first one asking you...
    For all others trying the bootloader commands in bootloader 1.1 : this does not work at all, and you are only wasting your time.
    I would really appreciate if the code for bl 1.3 was on github also. I do not mind if its beta only...
    Below the working debug output for a reassign nodeid 8 --> nodeid 88
    16.01.2016 23:06:46	RX	8;255;3;0;9;0108A000B9F7FFFEDA7221F0001E950F09
    16.01.2016 23:06:48	RX	0;0;3;0;9;read: 8-8-0 s=255,c=4,t=0,pt=6,l=10,sg=0:1E00010048047AA801
    16.01.2016 23:06:48	INFO	BL version=259
    16.01.2016 23:06:48	INFO	Executing bootloader command section
    16.01.2016 23:06:48	TX	8;255;4;0;1;0200580000007ADA
    16.01.2016 23:06:48	RX	8;255;4;0;0;1E00010048047AA80103
    16.01.2016 23:06:48	RX	0;0;3;0;9;send: 0-0-8-8 s=255,c=4,t=1,pt=6,l=8,sg=0,st=ok:02005800000
    16.01.2016 23:06:48	RX	0;0;3;0;9;read: 88-88-255 s=255,c=3,t=7,pt=1,l=1,sg=0:0
    @stebra The 1.3 is a closed beta and is not supposed to be distributed (ping @niccodemi). It is not supported in any terms nor should it be used in a productive environment, the compatibility to any library version is not guaranteed.
    Currently, there is ongoing work for MYSBootloader 2.0 and the ETA is tbd, same for the code.
    @sundberg84 Please upload MYSController log with DEBUG enabled.
  • Hello @tekka,
    is the feature 'save nodes' supposed to be working or WIP? With every start of MYSController I get a blank page and have to wait for every sensor to appear. At the moment that's not a big problem for me because of only 3 sensors, but already got a doubled ID once because new sensor requested an ID before the old #1 was recognized.
    Thanks a lot for your work with the controller, it's great.
  • @tekka
    Hi, just found this so downloaded and installed. Went to config to see what was there and selected TCP/IP tab to turn it off as it is not on a network and I only need Serial. The thing locks up and crashes and I have to use Task Manager to end it.
    Is there some way to start it without it trying to access 192.168.0.5?
    @NotTooTechy try setting
    TCPACTIVE=0
    in MYSController.ini
  • Hello everyone,
    I am new to the forum, I really appreciate your community.
    I embarked on the adventure of MySensors and naturally, I leaned on OTA. To do so, I followed your tutorial but I have a problem when sending the FW on the node.
    My setup:
    • 1 Arduino Mega with nRF24L01+ which I use serial gateway
    • 1 Arduino mini pro 3.3 volts for 8 mhz node (single sketch that sends a random data every 5 seconds)
    • Arduino IDE 1.6.7
    • MySensors libraries 1.5.3
    • MYSController_0_1_2_282
    The mini pro flashed with the bootloader (MYSBootloader 1.1), I can detect through MYSController application where it is named "Booting: 65 ... - 65 ...", I right click on it and send the skit "blink" .
    Sometimes I manage to push the "blink" directly and other times must be repeated 2-3 times (that's a lot of times, I grant you ). What is troubling is that at that time, I see the LED 13 of the mini pro flashed at a steady pace, but in MYSController, it is always named "booting ..." and to name the sketch "null".
    Afterwards, when I try to put my sketch, it loads but still in a loop with an error when it reaches 100% "FW update on the failed node = 1" and then starts again at 0% and so on.
    I hope you will refer me.
    Thank you.
  • @tekka
    Using the SerialGateway:
    Is there a tutorial at all for using this? I can figure out a lot of stuff, but...
    Is it possible to assign the ID to a new node? I want to group Nodes numerically as in Area-1: = 10,11,12 then Area-2: = 20,21,22,23 etc
    How?
  • Tutorial would be awesome 🙂
    I have a specific case that fails uploading sketch to 3.3v pro mini. I have a combined sketch which works fine if uploaded to 3.3v via cable, sketch also uploads fine OTA on 5v pro mini. When I try to upload sketch to 3.3v it fails eventually. If I upload "blink" from MysController, it uploads and works fine.
    I am suspecting that i am not flashing bootloader properly maybe. This is my boards.txt
    proMYSBL.name=ATmega328 16Mhz MYSBootloader
    proMYSBL.upload.tool=avrdude
    proMYSBL.upload.speed=115200
    proMYSBL.build.mcu=atmega328p
    proMYSBL.build.board=AVR_UNO
    proMYSBL.build.core=arduino
    proMYSBL8.upload.tool=avrdude
    proMYSBL8.upload.speed=57600
    proMYSBL8.build.board=AVR_UNO
    proMYSBL8.build.core=arduino
    I can burn 5v bootloader with both "boards" from ArduinoIDE using Uno as ISP. And on two 5v I have, OTA works great, it is just 3.3v with larger sketch (sketch is combination of several sensors) that eventually gives
    14.02.2016 18.00.53	TX	1;255;4;0;3;C900FFFF72057500000101010101731B731B01000000
    14.02.2016 18.00.53	RX	1;255;4;0;2;C900FFFF7205
    14.02.2016 18.01.27	ERROR	FW upload failed for node=1
    14.02.2016 18.01.27	INFO	BL version=257
    14.02.2016 18.01.27	INFO	Send FW info to node 1: type=C9, version=FFFF, blocks=0x0580, CRC=0x6F0D
    14.02.2016 18.01.27	TX	1;0;4;0;1;C900FFFF80050D6F
    14.02.2016 18.01.27	RX	1;255;4;0;0;0A0001004800FFFF0101
    14.02.2016 18.01.27	DEBUG	FW update started, node id = 1
    14.02.2016 18.01.27	TX	1;255;4;0;3;C900FFFF7F05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    14.02.2016 18.01.27	RX	1;255;4;0;2;C900FFFF7F05
    14.02.2016 18.01.57	ERROR	FW upload failed for node=1
    14.02.2016 18.01.57	INFO	BL version=257
    14.02.2016 18.01.57	INFO	Send FW info to node 1: type=C9, version=FFFF, blocks=0x0580, CRC=0x6F0D
    14.02.2016 18.01.57	TX	1;0;4;0;1;C900FFFF80050D6F
    14.02.2016 18.01.57	RX	1;255;4;0;0;0A0001004800FFFF0101
    14.02.2016 18.01.57	DEBUG	FW update started, node id = 1
    14.02.2016 18.01.57	TX	1;255;4;0;3;C900FFFF7F05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    14.02.2016 18.01.57	RX	1;255;4;0;2;C900FFFF7F05
    14.02.2016 18.01.57	TX	1;255;4;0;3;C900FFFF7E05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    This is the "universal" sketch I am trying to upload, it is a combination of few sensors
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    // #define MY_DEBUG
    //#define MY_RADIO_NRF24
    //Hum
    //temp
    //lux
    #include <BH1750.h>
    #include <Vcc.h>                                    // library for internal reference Vcc reading
    // Reference values for ADC and Battery measurements
    const float VccMin          = 1.0*2.5 ;             // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
    const float VccMax          = 1.0*3.0 ;             // Maximum expected Vcc level, in Volts.
    //const float VccMin        = 2.0*0.6 ;             // Minimum expected Vcc level, in Volts. for 2xAA Alkaline.
    //const float VccMax        = 2.0*1.5 ;             // Maximum expected Vcc level, in Volts.for 2xAA Alkaline.
    const float VccCorrection   = 3.30/3.42 ;           // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);                             // instantiate internal voltage measurement lib
    const float tempThreshold		= 0.02 ;               // send only if change > treshold (Celcius)
    const float humThreshold		= 0.05 ;               // send only if change > treshold (% RG)
    const float voltageThreshold	= 0.01 ;               // send only if change > treshold (Volt)
    const float luxThreshold		= 1 ;               // send only if change > treshold (Lux)
    const int heartbeat		= 60 ;                          // heartbeat every hour (x times SLEEP_TIME)
    unsigned long lastHeartbeat = 0 ;
    float lastHumidity		= 0 ;
    float lastTemperature	= 0 ;
    float lastVoltage		= 0 ;
    boolean lastTripped		= false ;
    // flags to indicate if transmission is needed, heartbeat and/or changes > treshold
    boolean txHumidity		= true ;                         // flags to indicate if transmit is needed (time & change driven)
    boolean txTemperature	= true ;
    boolean txLux			= true ;
    boolean txVoltage		= true ;
    boolean txTripped		= true ;
    unsigned long SLEEP_TIME = 30000; 			// Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR		3   	// The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2 	// Usually the interrupt = pin -2 (on uno/nano anyway)
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4      	//Humidity
    #define CHILD_ID_PIR    			1		// Id of the PIR sensor child
    #define CHILD_ID_HUM 				2		//Id of the HUMIDITY sensor child
    #define CHILD_ID_TEMP 				3		//Id of the TEMPERATURE sensor child
    #define CHILD_ID_LIGHT 				4		//lux sensor
    #define VOLTAGE_CHILD_ID			7		//battery level
    DHT dht;
    boolean metric = true;
    BH1750 lightSensor;
    // Initialize motion message
    MyMessage msgMotion(CHILD_ID_PIR, V_TRIPPED);
    //Initialize temp and hum message
    //Battery Voltage
    MyMessage msgVolt(VOLTAGE_CHILD_ID, V_VOLTAGE);  // Node voltage
    // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
    // If your controller supports the new V_LEVEL variable, use this instead for
    // transmitting LUX light level.
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux;
    	analogReference(INTERNAL);                      // use the 1.1 V internal reference for voltage measurement
    	gw.begin(NULL, 104); //message callback thing, nodeid
    	lightSensor.begin();
    	gw.sendSketchInfo("MotHumTemLuxBat", "1.0");
    	gw.present(CHILD_ID_PIR, S_MOTION);
    	gw.present(VOLTAGE_CHILD_ID, S_MULTIMETER);
    	//delay(dht.getMinimumSamplingPeriod()); // will this inrerrupt with the motion sensor?
    	// TEMPerature and HUMIdity
    	// first read all sensors before possible transmission (save battery)
    	readTempHum();
      	//PIR
      	//Serial.println(tripped);
      	gw.send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
    	readLux();
    	// LUX
    	// read battery Voltage
    	float voltage = vcc.Read_Volts() ;
    	if ( abs(voltage - lastVoltage) >= voltageThreshold ){ // update only if threshold exceeded
    		lastVoltage = voltage ;
    		txVoltage = true ;
    	sendSensors();
    	//over the air updates, after send and before sleep just listen to messages
    	gw.wait(200);
      	// Sleep until interrupt comes in on motion sensor. Send update every  minute.
      	gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    void readLux(void){
    	//Serial.println(lux);
    	if (lux != lastlux) {
    		if ( abs(lux  - lastlux) >= luxThreshold ){   // update only if threshold exceeded
    			lastlux = lux ;
    			txLux = true ;
    void readTempHum(void)
        // SHT2x sensor
        float temperature = dht.getTemperature();            // save battery by sending changes only & reading SHT first (>50ms)
    	Serial.print("temp: ");
    	Serial.println(humidity);
    	//if (isnan(temperature)) {
    	//	Serial.println("Failed reading temperature from DHT");
    	//} else if (temperature != lastTemperature) {
    		if ( abs(humidity  - lastHumidity) >= humThreshold ){   // update only if threshold exceeded
    			lastHumidity = humidity ;
    			txHumidity = true ;
    		if ( abs(temperature - lastTemperature) >= tempThreshold ){
    			lastTemperature = temperature ;
    		// Serial.print("SHT_ temp: ");
    //		// Serial.print(temperatureSHT);
    //		 Serial.print(" SHT_ hum: ");
    //		 Serial.println(humidity);
    // send to gateway depending on tx.. settings
    void sendSensors()
    	lastHeartbeat++ ;											// update Heartbeatcount every call
    	if ( lastHeartbeat > heartbeat) {							// if heartbeat update all sensors & battery status
    		txTemperature = txHumidity = txVoltage = txLux = true ;
    		gw.sendBatteryLevel(vcc.Read_Perc(VccMin, VccMax, true));
    		lastHeartbeat = 0 ;
    	if (txTemperature){
    		gw.send(msgTemp.set(lastTemperature, 2));		// Send in deg C
    		txTemperature = false ;
    	if (txLux){
    		gw.send(msgLight.set(lastlux));								// Send in Lux
    		txLux = false ;
    	if (txHumidity){
    		gw.send(msgHum.set(lastHumidity, 1));				// Send in %RH
    		txHumidity = false ;
    	if (txVoltage){
    		gw.send(msgVolt.set(lastVoltage,2));					//send battery in Volt
    		txVoltage = false ;
    	if (txTripped){
    		gw.send(msgMotion.set(lastTripped?"1":"0"));			// Send tripped value to gw
    		txTripped = false ;
    I am using the latest stable version of mysensors on both gateway and when compiling the sketches.
    If someone can test this on 3.3v or can look at the code and perhaps figure out what could be the problem, I would really appreciate it.
    Keep up the great work guys, I am loving the mysensors&co projects!
    I'm having some issues with the MYSBootloader, I've uploaded a sketch perfectly with the ISP connection after burning the fuses and bootloader, all using the Arduino IDE. Now when i come to update the sketch using FTDI I can't upload due to a error of:
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0a
    I'm assuming the timing in my fuses have been incorrectly set. Could anyone shine some light onto this?
    The settings i used were L:0xE2 H:0xD8 E:0x06. The boards.txt reflects this too, its also set to 8Mhz, with a baud rate of 57600.
  • Sorry, just getting around to try to get MYSController setup and I can't seem to get it sorted out to connect to my serial GW that is attached to my VeraLite.
    Here is what I have done to try to get connected:
    1. ssh into Vera and enter this command.
    ser2net -C 5003:raw:0:/dev/ttyACM0:115200
    I also tried
    ser2net -C 5003:raw:0:/dev/ttyUSB0:115200
    Next I launch MYSController on my PC and in the config window under TCP/IP tab set the IP to the IP of Vera and port to 5003.
    Hit connect and I get the following....
    2/17/2016 13:04:54	INFO	Connected to 192.168.0.108:5003
    2/17/2016 13:04:54	INFO	Unknown message, Msg=
    Port already in use by another process, dc=1
    2/17/2016 13:04:54	RX
    For those of you have have done this before...any suggestion?
    I think you are supposed to be uploading the sketches OTA and they won't upload via USB anymore (unless I missed an update, which is possible).
    @petewill - You are correct regarding no usb/ftdi uploads. Everything has to be done OTA. I'm using a standard arduino bootloader at the moment, attempting to troubleshoot ftdi with that :).
    @samuel235 are you using a Windows PC to upload your sketches? FTDI recently released drivers that stops FTDI clones from working with the new drivers. This happened to me and my errors looked very similar. The solution for me was to uninstall the drivers and re-install the older ones. I got the info from this post: http://www.eevblog.com/forum/microcontrollers/ftdi-gate-2-0/msg854401/#msg854401
    Also, I had to log in to my computer as an admin to make all these changes. For some reason using a standard account then typing in an admin password at the UAC prompt did not help. Maybe it was a coincidence but tried many times and only after doing it in admin context did I get it to work. Also, make sure you turn off Windows update for drivers. Let me know if you get stuck and I'll do my best to help.
    @petewill - I am using a windows system. I was reading about this new driver release the other day and didn't think anything of it. I didn't realize that it could apply to myself when I was reading it.
    Just out of curiosity, what does your FTDI converter come under in device manager, i always thought it was supposed to be a USB device, mine comes directly under Ports (COM & LPT). I know its obviously a port, I just for some reason thought it should be under Universal Serial Bus controller?
    Just to let you know, windows hasn't automatically updated my drivers. I'm still on the search for an older version.
    @samuel235 I changed the view like this:
    0_1456012839470_upload-8e46b7f5-cc01-4f76-b951-46f0a30beebd
    Then it shows like this:
    0_1456012880471_upload-37f9b436-520e-4991-936e-b01e68f34510
    I am using version 2.8.30.0 and I downloaded them from the FTDI site.
    @petewill, what device/converter are you using for FTDI uploads?
    @samuel235 I'm using a Windows 8.1 PC with the Arduino 1.6.6 IDE. My FTDI adapter looks like this:
    0_1456151337110_upload-dda1de06-e927-4025-9882-0e1f86920e4f
    @petewill - Right okay, well my adapter is slightly different in the sense that it is all in one with a USB 2.0 adapter on the end of the board rather than a USB MiniB that you run a cable to the USB port on the PC. But apart from that the chip on-board is pretty much standard i think, from what i have found out on the internet anyway. Just for reference, this is what mine is http://www.ebay.co.uk/itm/161791651010?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT.
    However, when purchasing some Arduino Mini Pros, i have gotten another. http://www.ebay.co.uk/itm/161795041342?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT. We will see if they're both the same functionality when it arrives.
    @samuel235 A quick way to test if it's your adapter or the drivers is to plug it in to a Mac or a Linux computer and try to upload from there.
    @petewill - As soon as my Mini Pros arrive I will start to troubleshoot this with more depth. Thank you 🙂
  • @Anticimex Can you please share the Nodes Code?
    @vikasjee not straight away as it contain pushbullet secrets so I need to launder it a bit first. And I have also changed it around in quite a bit and have added some experimental debugging facilities that don't really work so are you sure you still want it? 🙂 if it is the multi controller support you are after it should still be a valid reference.
    Here is my current nodeconfig:
    [{"id":"c1f1131a.3e0ef","type":"subflow","name":"Manual preprocessor","info":"Processes manual specific input","in":[{"x":50,"y":30,"wires":[{"id":"b73bbc01.48c44"}]}],"out":[{"x":264,"y":30,"wires":[{"id":"b73bbc01.48c44","port":0}]}]},{"id":"b73bbc01.48c44","type":"change","z":"c1f1131a.3e0ef","name":"Topic=Manual","rules":[{"t":"set","p":"topic","to":"Manual"}],"action":"","property":"","from":"","to":"","reg":false,"x":156,"y":30,"wires":[[]]},{"id":"c542f76c.3abd08","type":"subflow","name":"Vera postprocessor","info":"Processes Vera specific output","in":[{"x":50,"y":30,"wires":[]}],"out":[{"x":160,"y":30,"wires":[{"id":"c542f76c.3abd08","port":0}]}]},{"id":"c1bbb0ac.3e445","type":"subflow","name":"MYS postprocessor","info":"Processes MYSController specific output","in":[{"x":50,"y":30,"wires":[]}],"out":[{"x":160,"y":30,"wires":[{"id":"c1bbb0ac.3e445","port":0}]}]},{"id":"56bd1bfc.a942e4","type":"subflow","name":"MyC postprocessor","info":"Processes MyController specific output","in":[{"x":50,"y":30,"wires":[]}],"out":[{"x":160,"y":30,"wires":[{"id":"56bd1bfc.a942e4","port":0}]}]},{"id":"6bb8370.f9447c8","type":"subflow","name":"MyC preprocessor","info":"Processes MyController specific input","in":[{"x":50,"y":30,"wires":[{"id":"287b2c2e.d784d4"}]}],"out":[{"x":330,"y":30,"wires":[{"id":"287b2c2e.d784d4","port":0}]}]},{"id":"287b2c2e.d784d4","type":"change","z":"6bb8370.f9447c8","name":"Topic=MyController","rules":[{"t":"set","p":"topic","to":"MyController"}],"action":"","property":"","from":"","to":"","reg":false,"x":184,"y":30,"wires":[[]]},{"id":"9a01ec1d.65fe1","type":"subflow","name":"MYS preprocessor","info":"Processes MYSController specific input","in":[{"x":50,"y":30,"wires":[{"id":"ab4674a4.54b988"}]}],"out":[{"x":320,"y":30,"wires":[{"id":"ab4674a4.54b988","port":0}]}]},{"id":"ab4674a4.54b988","type":"change","z":"9a01ec1d.65fe1","name":"Topic=MYSController","rules":[{"t":"set","p":"topic","to":"MYSController"}],"action":"","property":"","from":"","to":"","reg":false,"x":183,"y":30,"wires":[[]]},{"id":"fb0fe50f.04f018","type":"subflow","name":"Vera preprocessor","info":"Processes Vera specific input","in":[{"x":54,"y":36,"wires":[{"id":"fb4a1920.04b5e8"}]}],"out":[{"x":288,"y":36,"wires":[{"id":"fb4a1920.04b5e8","port":0}]}]},{"id":"fb4a1920.04b5e8","type":"change","z":"fb0fe50f.04f018","name":"Topic=Vera","rules":[{"t":"set","p":"topic","to":"Vera"}],"action":"","property":"","from":"","to":"","reg":false,"x":158,"y":36,"wires":[[]]},{"id":"87ad6845.785298","type":"subflow","name":"MYS dbg mgt","info":"","in":[{"x":25,"y":28,"wires":[{"id":"a5f38922.5a0c78"}]}],"out":[{"x":787,"y":25,"wires":[{"id":"87b5da5b.784a28","port":0}]},{"x":615,"y":70,"wires":[{"id":"c58c8cac.3a737","port":0}]}]},{"id":"7d24de87.82db2","type":"function","z":"87ad6845.785298","name":"Debug from Data from Ping","func":"if (msg.messageType == 3 && msg.subType == 9) {\n   return [ msg, null, null ];\n} else if (msg.messageType == 3 && msg.subType == 18) {\n   return [ null,  null, msg ];\n} else {\n   return [ null, msg, null ];\n}\n","outputs":"3","noerr":0,"x":302,"y":28.5,"wires":[["a49c42e6.5b63c"],["a49c42e6.5b63c","c58c8cac.3a737"],["c58c8cac.3a737"]]},{"id":"a5f38922.5a0c78","type":"mysdecenc","z":"87ad6845.785298","name":"Decode","x":117,"y":28,"wires":[["7d24de87.82db2"]]},{"id":"c58c8cac.3a737","type":"mysdecenc","z":"87ad6845.785298","name":"Encode","x":520,"y":71,"wires":[[]]},{"id":"a49c42e6.5b63c","type":"mysdecenc","z":"87ad6845.785298","name":"Encode","x":523,"y":25,"wires":[["87b5da5b.784a28"]]},{"id":"87b5da5b.784a28","type":"mysdebug","z":"87ad6845.785298","name":"Debug decorate","x":671,"y":26,"wires":[[]]},{"id":"a2721ec7.5d8de","type":"pushbullet-config","z":"","name":"somename"},{"id":"8160ff88.7e9f","type":"subflow","name":"MYS Pushbullet publisher","info":"","in":[{"x":68,"y":79,"wires":[{"id":"108590a6.ef7a6f"}]}],"out":[]},{"id":"e2dea93.f1d2158","type":"pushbullet","z":"8160ff88.7e9f","config":"a2721ec7.5d8de","pushtype":"note","title":"Lock status","chan":"noneofyourbusiness","name":"Lock status","x":1042,"y":1072,"wires":[]},{"id":"69c63289.9639cc","type":"function","z":"8160ff88.7e9f","name":"Format","func":"if (msg.payload == 1) {\n    msg.payload = \"Locked\";\n} else {\n    msg.payload = \"Unlocked\";\n}\nreturn msg;\n","outputs":1,"noerr":0,"x":905,"y":1072,"wires":[["e2dea93.f1d2158"]]},{"id":"9afa4e84.6505b","type":"switch","z":"8160ff88.7e9f","name":"Message type","property":"messageType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"else"}],"checkall":"true","outputs":5,"x":417,"y":129,"wires":[["a1c9e060.5e362"],["7ee958f8.8116a8"],["7ee958f8.8116a8"],["6aa07c4a.955f84"],[]]},{"id":"108590a6.ef7a6f","type":"mysdecenc","z":"8160ff88.7e9f","name":"MySensors decode","x":198,"y":79,"wires":[["9afa4e84.6505b"]]},{"id":"a1c9e060.5e362","type":"switch","z":"8160ff88.7e9f","name":"PresentationSubtype","property":"subType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"},{"t":"eq","v":"5"},{"t":"eq","v":"6"},{"t":"eq","v":"7"},{"t":"eq","v":"8"},{"t":"eq","v":"9"},{"t":"eq","v":"10"},{"t":"eq","v":"11"},{"t":"eq","v":"12"},{"t":"eq","v":"13"},{"t":"eq","v":"14"},{"t":"eq","v":"15"},{"t":"eq","v":"16"},{"t":"eq","v":"17"},{"t":"eq","v":"18"},{"t":"eq","v":"19"},{"t":"eq","v":"20"},{"t":"eq","v":"21"},{"t":"eq","v":"22"},{"t":"eq","v":"23"},{"t":"eq","v":"24"},{"t":"eq","v":"25"},{"t":"eq","v":"26"},{"t":"eq","v":"27"},{"t":"eq","v":"28"},{"t":"eq","v":"29"},{"t":"eq","v":"30"},{"t":"eq","v":"31"},{"t":"eq","v":"32"},{"t":"eq","v":"33"},{"t":"eq","v":"34"},{"t":"else"}],"checkall":"true","outputs":36,"x":723,"y":275,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[]]},{"id":"7ee958f8.8116a8","type":"switch","z":"8160ff88.7e9f","name":"SetReqSubtype","property":"subType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"},{"t":"eq","v":"5"},{"t":"eq","v":"6"},{"t":"eq","v":"7"},{"t":"eq","v":"8"},{"t":"eq","v":"9"},{"t":"eq","v":"10"},{"t":"eq","v":"11"},{"t":"eq","v":"12"},{"t":"eq","v":"13"},{"t":"eq","v":"14"},{"t":"eq","v":"15"},{"t":"eq","v":"16"},{"t":"eq","v":"17"},{"t":"eq","v":"18"},{"t":"eq","v":"19"},{"t":"eq","v":"20"},{"t":"eq","v":"21"},{"t":"eq","v":"22"},{"t":"eq","v":"23"},{"t":"eq","v":"24"},{"t":"eq","v":"25"},{"t":"eq","v":"26"},{"t":"eq","v":"27"},{"t":"eq","v":"28"},{"t":"eq","v":"29"},{"t":"eq","v":"30"},{"t":"eq","v":"31"},{"t":"eq","v":"32"},{"t":"eq","v":"33"},{"t":"eq","v":"34"},{"t":"eq","v":"35"},{"t":"eq","v":"36"},{"t":"eq","v":"37"},{"t":"eq","v":"38"},{"t":"eq","v":"39"},{"t":"eq","v":"40"},{"t":"eq","v":"41"},{"t":"eq","v":"42"},{"t":"eq","v":"43"},{"t":"eq","v":"44"},{"t":"eq","v":"45"},{"t":"else"}],"checkall":"true","outputs":47,"x":740,"y":903,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],["69c63289.9639cc"],[],[],[],[],[],[],[],[],[],[]]},{"id":"6aa07c4a.955f84","type":"switch","z":"8160ff88.7e9f","name":"InternalSubtype","property":"subType","rules":[{"t":"eq","v":"0"},{"t":"eq","v":"1"},{"t":"eq","v":"2"},{"t":"eq","v":"3"},{"t":"eq","v":"4"},{"t":"eq","v":"5"},{"t":"eq","v":"6"},{"t":"eq","v":"7"},{"t":"eq","v":"8"},{"t":"eq","v":"9"},{"t":"eq","v":"10"},{"t":"eq","v":"11"},{"t":"eq","v":"12"},{"t":"eq","v":"13"},{"t":"eq","v":"14"},{"t":"eq","v":"15"},{"t":"eq","v":"16"},{"t":"else"}],"checkall":"true","outputs":18,"x":739,"y":1397,"wires":[[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[],[]]},{"id":"8f98bd26.70674","type":"subflow","name":"DOM postprocessor","info":"Processes Domoticz specific output","in":[{"x":33,"y":143,"wires":[{"id":"699b5758.9664a8"}]}],"out":[{"x":951,"y":150,"wires":[{"id":"78766dd2.878994","port":0}]}]},{"id":"699b5758.9664a8","type":"mysdecenc","z":"8f98bd26.70674","name":"","x":139,"y":143,"wires":[["1ecc685.fe13398"]]},{"id":"1ecc685.fe13398","type":"switch","z":"8f98bd26.70674","name":"Type is SET?","property":"messageType","rules":[{"t":"eq","v":"1"},{"t":"else"}],"checkall":"true","outputs":2,"x":289,"y":143,"wires":[["73b9b1e.f8c465"],["78766dd2.878994"]]},{"id":"78766dd2.878994","type":"mysdecenc","z":"8f98bd26.70674","name":"","x":846,"y":150,"wires":[[]]},{"id":"73b9b1e.f8c465","type":"switch","z":"8f98bd26.70674","name":"Is V_LOCK_STATUS?","property":"subType","rules":[{"t":"eq","v":"36"},{"t":"else"}],"checkall":"true","outputs":2,"x":476,"y":127,"wires":[["5e7ebd41.a18144"],["78766dd2.878994"]]},{"id":"5e7ebd41.a18144","type":"function","z":"8f98bd26.70674","name":"Invert payload","func":"if (msg.payload == 1)\n    msg.payload = 0;\nelse\n    msg.payload = 1;\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":113,"wires":[["78766dd2.878994"]]},{"id":"6f018651.90fe78","type":"subflow","name":"DOM preprocessor","info":"Processes Domoticz specific input","in":[{"x":31,"y":188,"wires":[{"id":"b03550b3.4fcab"}]}],"out":[{"x":894,"y":197,"wires":[{"id":"38029d29.c7fd62","port":0}]}]},{"id":"c7e52cc0.381ad","type":"mysdecenc","z":"6f018651.90fe78","name":"Decode","x":311,"y":230,"wires":[["c88ee733.377118"]]},{"id":"c88ee733.377118","type":"switch","z":"6f018651.90fe78","name":"Type is SET?","property":"messageType","rules":[{"t":"eq","v":"1"},{"t":"else"}],"checkall":"true","outputs":2,"x":446,"y":190,"wires":[["d409083c.2bf6f8"],["38029d29.c7fd62"]]},{"id":"38029d29.c7fd62","type":"mysdecenc","z":"6f018651.90fe78","name":"Encode","x":785,"y":197,"wires":[[]]},{"id":"d409083c.2bf6f8","type":"switch","z":"6f018651.90fe78","name":"Is V_LOCK_STATUS?","property":"subType","rules":[{"t":"eq","v":"36"},{"t":"else"}],"checkall":"true","outputs":2,"x":544,"y":122,"wires":[["a1467944.5eb988"],["38029d29.c7fd62"]]},{"id":"a1467944.5eb988","type":"function","z":"6f018651.90fe78","name":"Invert payload","func":"if (msg.payload == 1)\n    msg.payload = 0;\nelse\n    msg.payload = 1;\nreturn msg;","outputs":1,"noerr":0,"x":663,"y":57,"wires":[["38029d29.c7fd62"]]},{"id":"b03550b3.4fcab","type":"change","z":"6f018651.90fe78","name":"Topic=Domoticz","rules":[{"t":"set","p":"topic","to":"Domoticz"}],"action":"","property":"","from":"","to":"","reg":false,"x":157,"y":188,"wires":[["c7e52cc0.381ad"]]},{"id":"5454541d.ababac","type":"subflow","name":"Fake sensors","in":[{"x":35,"y":30,"wires":[{"id":"ff04f8fa.00fb08"}]}],"out":[{"x":666,"y":30,"wires":[{"id":"30e6a3cb.cf195c","port":0}]}]},{"id":"666dc361.99923c","type":"mysencap","z":"5454541d.ababac","name":"Temp","nodeid":"1","childid":0,"subtype":0,"internal":0,"ack":false,"msgtype":"1","presentation":true,"presentationtype":"6","presentationtext":"FakeTempSensor","fullpresentation":true,"firmwarename":"FakeTemp","firmwareversion":"0.0","x":350,"y":30,"wires":[["30e6a3cb.cf195c"]]},{"id":"ff04f8fa.00fb08","type":"function","z":"5454541d.ababac","name":"Generate temp","func":"msg.payload = \"25\"\nreturn msg;","outputs":1,"noerr":0,"x":185,"y":30,"wires":[["666dc361.99923c"]]},{"id":"30e6a3cb.cf195c","type":"mysdecenc","z":"5454541d.ababac","name":"MySensors encode","x":515,"y":30,"wires":[[]]},{"id":"6580173d.9a7fe8","type":"serial-port","serialport":"/dev/ttyMyController","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"65355d72.9acaa4","type":"serial-port","serialport":"/dev/ttyDomoticz","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"13cc7d6f.ec3383","type":"serial-port","serialport":"/dev/ttyMysC","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"5af61127.a509f","type":"serial-port","z":"","serialport":"/dev/ttyUSB0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"29d1b211.d62e4e","type":"serial-port","serialport":"/dev/ttyVera","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"56e6890.fa91978","type":"debug","z":"faef2a18.0510d8","name":"CTRLR debug","active":true,"console":"false","complete":"payload","x":748,"y":465,"wires":[]},{"id":"933030f1.6ccfd","type":"serial out","z":"faef2a18.0510d8","name":"Vera","serial":"29d1b211.d62e4e","x":821,"y":196,"wires":[]},{"id":"54370c66.abc8f4","type":"serial in","z":"faef2a18.0510d8","name":"MySensorsGW","serial":"5af61127.a509f","x":77.5,"y":146,"wires":[["396eb79f.c69148"]]},{"id":"6dae78cf.925188","type":"serial out","z":"faef2a18.0510d8","name":"MySensorsGW","serial":"5af61127.a509f","x":750,"y":533,"wires":[]},{"id":"cbef03e5.3411","type":"serial in","z":"faef2a18.0510d8","name":"MYSController","serial":"13cc7d6f.ec3383","x":76,"y":527,"wires":[["992c7345.66d39"]]},{"id":"9b7faefd.64805","type":"serial out","z":"faef2a18.0510d8","name":"MYSController","serial":"13cc7d6f.ec3383","x":844,"y":243,"wires":[]},{"id":"91697766.6e9688","type":"inject","z":"faef2a18.0510d8","name":"Send version request","topic":"MySensors test","payload":"0;255;3;0;2;","payloadType":"string","repeat":"","crontab":"","once":false,"x":122,"y":434,"wires":[["5feb3ddb.a014c4"]]},{"id":"5be5bb8c.a41a44","type":"serial in","z":"faef2a18.0510d8","name":"Domoticz","serial":"65355d72.9acaa4","x":59.5,"y":631,"wires":[["1b7cf599.e4830a","80399396.7fc67"]]},{"id":"cb8a2201.3475e","type":"serial out","z":"faef2a18.0510d8","name":"Domoticz","serial":"65355d72.9acaa4","x":828,"y":343,"wires":[]},{"id":"439009ab.bc6ff8","type":"serial in","z":"faef2a18.0510d8","name":"MyController","serial":"6580173d.9a7fe8","x":70.5,"y":581,"wires":[["47f782c.fb8087c"]]},{"id":"be681116.4197f","type":"serial out","z":"faef2a18.0510d8","name":"MyController","serial":"6580173d.9a7fe8","x":838,"y":293,"wires":[]},{"id":"6cab82ec.93547c","type":"subflow:5454541d.ababac","z":"faef2a18.0510d8","name":"","x":237,"y":193,"wires":[["396eb79f.c69148","26c64377.d939bc"]]},{"id":"a7dc7c6f.58238","type":"inject","z":"faef2a18.0510d8","name":"Trig fakes","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":92,"y":193,"wires":[["6cab82ec.93547c"]]},{"id":"1b7cf599.e4830a","type":"subflow:6f018651.90fe78","z":"faef2a18.0510d8","name":"","x":315,"y":631,"wires":[["1c964876.e369b8"]]},{"id":"e62acc9e.19d53","type":"subflow:8f98bd26.70674","z":"faef2a18.0510d8","name":"","x":664,"y":343,"wires":[["cb8a2201.3475e","d994688d.266b98"]]},{"id":"10218729.efde79","type":"subflow:8160ff88.7e9f","z":"faef2a18.0510d8","name":"","x":881,"y":153,"wires":[]},{"id":"396eb79f.c69148","type":"subflow:87ad6845.785298","z":"faef2a18.0510d8","name":"","x":429,"y":146,"wires":[["fe9c2881.0163d8","1ed4947e.e12b6c"],["e62acc9e.19d53","28097d6b.d7f682","6b5d7d4b.94a284","ebe581f9.141a8","10218729.efde79"]]},{"id":"fe9c2881.0163d8","type":"debug","z":"faef2a18.0510d8","name":"MYS debug","active":true,"console":"false","complete":"payload","x":638,"y":84,"wires":[]},{"id":"1ed4947e.e12b6c","type":"file","z":"faef2a18.0510d8","name":"","filename":"/home/pi/MySensors/gw_out.log","appendNewline":true,"createDir":true,"overwriteFile":"false","x":702,"y":118,"wires":[]},{"id":"28461cae.d7b9e4","type":"subflow:fb0fe50f.04f018","z":"faef2a18.0510d8","name":"","x":316,"y":475,"wires":[["1c964876.e369b8"]]},{"id":"20753984.df8ac6","type":"serial in","z":"faef2a18.0510d8","name":"Vera","serial":"29d1b211.d62e4e","x":55,"y":475,"wires":[["28461cae.d7b9e4"]]},{"id":"992c7345.66d39","type":"subflow:9a01ec1d.65fe1","z":"faef2a18.0510d8","name":"","x":315,"y":527,"wires":[["1c964876.e369b8"]]},{"id":"47f782c.fb8087c","type":"subflow:6bb8370.f9447c8","z":"faef2a18.0510d8","name":"","x":313,"y":581,"wires":[["1c964876.e369b8"]]},{"id":"1c964876.e369b8","type":"subflow:87ad6845.785298","z":"faef2a18.0510d8","name":"","x":553,"y":527,"wires":[["56e6890.fa91978","eeac51f0.1153b"],["6dae78cf.925188"]]},{"id":"28097d6b.d7f682","type":"subflow:56bd1bfc.a942e4","z":"faef2a18.0510d8","name":"","x":659,"y":293,"wires":[["be681116.4197f"]]},{"id":"6b5d7d4b.94a284","type":"subflow:c1bbb0ac.3e445","z":"faef2a18.0510d8","name":"","x":660,"y":243,"wires":[["9b7faefd.64805"]]},{"id":"ebe581f9.141a8","type":"subflow:c542f76c.3abd08","z":"faef2a18.0510d8","name":"","x":660,"y":196,"wires":[["933030f1.6ccfd"]]},{"id":"eeac51f0.1153b","type":"file","z":"faef2a18.0510d8","name":"","filename":"/home/pi/MySensors/gw_in.log","appendNewline":true,"createDir":true,"overwriteFile":"false","x":799,"y":498,"wires":[]},{"id":"5feb3ddb.a014c4","type":"subflow:c1f1131a.3e0ef","z":"faef2a18.0510d8","name":"","x":321,"y":434,"wires":[["1c964876.e369b8"]]},{"id":"26c64377.d939bc","type":"debug","z":"faef2a18.0510d8","name":"","active":true,"console":"false","complete":"false","x":419,"y":229,"wires":[]},{"id":"80399396.7fc67","type":"debug","z":"faef2a18.0510d8","name":"Domoticz out","active":true,"console":"false","complete":"payload","x":289,"y":676,"wires":[]},{"id":"d994688d.266b98","type":"debug","z":"faef2a18.0510d8","name":"Domoticz in","active":true,"console":"false","complete":"payload","x":850,"y":406,"wires":[]}]
    You will need @tbowmo's mysensors node-red plugin for this flow. And be aware that the debug log management in this flow is NOT working as it is really supposed to.
    To create the socat pipes I use a number of shell scripts of this form executed as root:
    #!/bin/bash
    while sleep 1; do
            socat PTY,link=/dev/ttyVera,mode=666,group=dialout,raw TCP-LISTEN:5003,reuseaddr
    done
    Typically, you can invoke such a script using
    sudo ./socat_vera.sh &
    which would let the script execute in the background. The while loop make sure the pipe stays available even if there is nothing connected to it.
    For sure there are a lot of different things about this that can be improved and optimized, but that is what I am currently using in my testing environment.
  • Ditto on the "very very cool" I looking for a app I could actually see what my sensor builds were doing. Prefect!
  • hi again, I noticed that domoticz would lose connection to the Gateway when I would ask one of the nodes to restart. Is that expected behavior?
    For example when I want to introduce a new node/code to domoticz, the moment I hit reboot on some node domoticz would report that it has lost TCP connection with the gateway and it would wait 30s or something and then reconnect to the gateway, which is ok to restart but it will then miss the introduction/presentation data sent by the sensor. This is one of the coolest features of MysController, to update and reset remote nodes, without the need to reopen all the nodes and hitting reset or removing the battery etc.
    Anyone noticing this, is there some workaround for this?
  • @tekka
    Hi tekka,
    I have tested MYSController, and it was a massive success ! thanks a lot for your work.
    I have just one question, in the csv file there is a type.
    According to my reading this is to tag a node type, but where are the already known types ?
    Type 1 => only temperature
    Type 2 => only humidity
    Type 3 => temp & hum
    etc
    Is there another config file where to specify user types ?
    10,Blink,1,Blink.hex,blinking example
    20,TimeReporter,1,TimeReporter.hex,TimeReporter
    100,Sensebender Micro,1,SensebenderMicro.cpp.hex,Sensebender Micro
    110,Sensebender Blink,1,SensebenderBlink.cpp.hex,Sensebender Blink
  • @hek - would it be possible to get a subforum for MYSController stood up in the Controllers forum? This thread is getting pretty long and off topic (also, the RSS feed stops at the 27th post)
    I'll have a talk with @tekka about it. But you always have the optaion to start a new thread.
    @DomoJimbo No, you are free to choose the node types. This information is used for OTA FW updates.
    for Linux, it works with wine, with TCP and serial.
    regards
    Thomas
  • @tekka
    I'Ve done the steps witch you describe but it doesn't show up in the ArduinoIDE.
    Step 1, added the lines to boards.txt
    Step 2, made a directory \MySensors under
    D:\Program Files\Arduino\hardware\arduino\avr\bootloaders
    Step 3, copied the .hex file into D:\Program Files\Arduino\hardware\arduino\avr\bootloaders\MySensors
    What did i do wrong???
  • @MarkV you might want to check your "AppData" folder, I noticed the same behaviour and had to change boards.txt in this location.
    C:\Users{{user}}\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.10
    GL
  • Guys,
    I'm trying to get this working with my nano clone but am having no luck.
    When I flash the boot loader the nano doesn't send the request (the light on the nano comes on red and stays on).
    I'm presuming it's because I haven't updated the fuse settings etc for the nano? Would someone be so kind as to offer some help with regards what I need to change?
    Edit: I'm up and running!
  • Did anyone figure out how to get MySensors debug messages to show? My sketch has debug uncommented and I can see them via serial, but not in the app?
    @Mark-Swift The MySensors debug tab only shows gateway debug messages (not sensor debug).
  • @tekka Yeah, I get that, that's what I'm struggling with. I have the debug line uncommented on my ESP8266 gateway, but see nothing in the mysensors debug tab? I'm using the latest beta build as I run 2.0.0.
    Also, I've asked a couple of times, is the default firmware pre release 1.3 bootloader (16mhz) suitable in its default state for both my Uno's and Nano's?
    Thanks in advance,
    Mark
    @Mark-Swift the ESP8266 GW is not sending debug msgs over TCP/IP - only over the serial console.
    And yes, MYSBootloader 1.3pre/16Mhz is suitable for Uno and Nano V3 (both share the same atmega328p mcu)
  • 73
  • 6
  • 37
  • 13
