My Slim 2AA Battery Node
    @AWI said:
    panelized design
    @AWI Sorry, can't help you with that. All Eagle here ๐Ÿ˜…
    @ahmedadelhosni apparently not ๐Ÿ˜Š
  • @Yveaux aha. I thought that this means multiple (same) design not different. Thanks ๐Ÿ™‚
    Thanks @m26872
  • Hi
    1 x PDB board
    1 x ATMega328p 28pin PDIP
    1 x NRF24L01+ radio module
    2 x AA batteries
    Battery connector
    1 x senor of choice
    Extras needed
  • @Soloam
    and a flash module for OTA Sketch Uploads ๐Ÿ™‚
    @Matt-Pitts
    The bootloader I have successfull burned with an raspberry pi and gpio (http://www.lxccu.com/hb-raspberry-bootloader-update๐Ÿ˜ž
    avrdude: safemode: Fuses OK
    How can I got it working?
    Thank you
    Thomas
  • @Tom71
    I did two things:
  • @Tom71
  • @Matt-Pitts
  • @Tom71
  • @wergeld
  • Hello, I ordered it too yesterday ๐Ÿ™‚ Can't wait to step forward from my breadboards with a lot wires to PCB without wires ๐Ÿ˜„
  • now I finally set up my first sensor board, and, as expected, I donยดt receive any data from it on my gateway :suspect:
    The sketch should run, but it doesnยดt. Any ideas how to troubleshoot now?
    @siod
    • Uno fuses and bootloader?
  • I just installed the NRF module at itยดs desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
    edit: Iยดve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
    Do I have to burn the bootloader using 1MHz or 8 MHz? I donยดt get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
  • @Tom71
  • ok guys, I finally set up my first sensor and itยดs communicating well. Iยดve attached two reed switch which work fine, only my temp snesor DHT11 doesnยดt work. Are there any known issues with this sensor?
    // Define Node ID
    #define MY_NODE_ID 1
    //Kontaktschalter
    //Tempsensor
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //Kontaktschalter
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //tempsensor
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Messages
    // Kontaktschalter
    //TempMessage
      //Tempsensor
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
      debouncer1.interval(5);
      debouncer2.interval(5);
      //Tempsensor
      //Kontakstschalter 1
      debouncer1.update();
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
      debouncer2.update();
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    edit2: I measured 0,02 Ampere consumption, isnยดt that too much?
  • @siod
    Greets Eddie
    Edit : ah ok, the arduino is going to regulate down to 3.3v... Then I cant use 3AAs ๐Ÿ˜ž
    I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption ๐Ÿ™‚
  • @m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it ๐Ÿ™‚
    But it can't find the node.
    it doesn't recognise the avr.
    This is the error i get:
    this check.
    avrdude done. Thank you.
    #include <Vcc.h>
    Vcc vcc(VccCorrection);
    DHT dht;
    //Store last values
    float lastTemp = 0 ;
    float lastHum = 0 ;
    float batteryV=0;
    int oldBatteryPcnt = 0;
    boolean lastTripped = false ;
      gw.begin(NULL,node_id,false);
      // get the battery Voltage
       batteryV  = vcc.Read_Volts();
         // Power up radio after sleep
         gwsend=true;
         oldBatteryPcnt = batteryPcnt;
      if (isnan(temp1)) {
        lastTemp = temp1;
        if (!metric) {
        gwsend=true;
          lastHum = humidity;
          gwsend=true;
      if (sleepcycle>gwsendtimout){
        gwsend=true;
    if (gwsend){
        gwsend=false;
        sleepcycle=1;
      sleepcycle++;
    @wergeld congratulations ๐Ÿ‘
    Thank you all
  • I ordered a proto pack on 15th of April and received it on 30th of April. Pretty fast, I think. ๐Ÿ™‚
    Greetings
    @m26872
    @rollercontainer
    @rollercontainer
    I use the 2.0 beta
    @rollercontainer
    @Bobcat
  • @GertSanders
    @Bobcat
  • Hello all
    Iยดm Henrik, first post here and sort of beginner at this ( use to do some embedded stuff some 15 years ago and picked it up again recently )
    I just did a shopping list for this project, Version 2.0 if I got it correct ๐Ÿ˜ƒ
    straight pins
    Only thing extra needed I think would be some additional cable and a arduino UNO or some other way to program the single chips. But I assume you already have a UNO if you read this ๐Ÿ™‚
    //Henrik
    I never ordered any pcbยดs like this before so I donยดt want to get it wrong =D.
    thanks for any help
    @badmannen
    I don't want to ruin them! ๐Ÿ™‚
  • Thanks, it worked!
    Thanks in advance,
    hugo
