My Slim 2AA Battery Node
  • I just installed the NRF module at it´s desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
    edit: I´ve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
    Do I have to burn the bootloader using 1MHz or 8 MHz? I don´t get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
  • @Tom71
  • ok guys, I finally set up my first sensor and it´s communicating well. I´ve attached two reed switch which work fine, only my temp snesor DHT11 doesn´t work. Are there any known issues with this sensor?
    // Define Node ID
    #define MY_NODE_ID 1
    //Kontaktschalter
    //Tempsensor
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //Kontaktschalter
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //tempsensor
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Messages
    // Kontaktschalter
    //TempMessage
      //Tempsensor
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
      debouncer1.interval(5);
      debouncer2.interval(5);
      //Tempsensor
      //Kontakstschalter 1
      debouncer1.update();
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
      debouncer2.update();
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    edit2: I measured 0,02 Ampere consumption, isn´t that too much?
  • @siod
    Greets Eddie
    I just think the next time I encounter problems is, when I try to setup a new sensor node with attached pir motion sensor... I will read the data sheet of it first and look out for power consumption 🙂
  • @m26872 yeah I know you have a topic but actually was concerned with door and window sensors that time and forgot to check it again when I needed it 🙂
    But it can't find the node.
    it doesn't recognise the avr.
    This is the error i get:
    this check.
    avrdude done. Thank you.
    #include <Vcc.h>
    Vcc vcc(VccCorrection);
    DHT dht;
    //Store last values
    float lastTemp = 0 ;
    float lastHum = 0 ;
    float batteryV=0;
    int oldBatteryPcnt = 0;
    boolean lastTripped = false ;
      gw.begin(NULL,node_id,false);
      // get the battery Voltage
       batteryV  = vcc.Read_Volts();
         // Power up radio after sleep
         gwsend=true;
         oldBatteryPcnt = batteryPcnt;
      if (isnan(temp1)) {
        lastTemp = temp1;
        if (!metric) {
        gwsend=true;
          lastHum = humidity;
          gwsend=true;
      if (sleepcycle>gwsendtimout){
        gwsend=true;
    if (gwsend){
        gwsend=false;
        sleepcycle=1;
      sleepcycle++;
    @wergeld congratulations 👍
    Thank you all
  • I ordered a proto pack on 15th of April and received it on 30th of April. Pretty fast, I think. 🙂
    Greetings
    @m26872
    @rollercontainer
    @rollercontainer
    I use the 2.0 beta
    @rollercontainer
    @Bobcat
  • @GertSanders
    @Bobcat
  • Hello all
    I´m Henrik, first post here and sort of beginner at this ( use to do some embedded stuff some 15 years ago and picked it up again recently )
    I just did a shopping list for this project, Version 2.0 if I got it correct 😃
    straight pins
    Only thing extra needed I think would be some additional cable and a arduino UNO or some other way to program the single chips. But I assume you already have a UNO if you read this 🙂
    //Henrik
    I never ordered any pcb´s like this before so I don´t want to get it wrong =D.
    thanks for any help
    @badmannen
    I don't want to ruin them! 🙂
  • Thanks, it worked!
    Thanks in advance,
    hugo
    • R1
    • C1
    • C2
    • C3
    • Atmega socket
    • NRF24 radio
    • 6 pin angled connector
  • C4 in your picture looks correct to me. You could put C4 up on the edge under where the radio would be as well. You have VCC up on the edge. I think the pins adjacent to that are ground too. EDIT: I think I replied before you edited your picture 🙂
  • @siod
  • each one goes around a corner and so one wall is partly between the nodes and the gateway and it´s not even concrete. I have one node in my basement attached to an arduino nano and I have no range problems...
    edit:
    Node sktech:
    // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
    // Define Node ID
    #define MY_NODE_ID 4
    //Batterysensor
    #define CHILD_ID_BATT 7
    //Kontaktschalter
    //#include <Bounce2.h>
    //Tempsensor
    #include <SparkFunHTU21D.h>
    //tempsensor
    HTU21D myHumidity;
    float lastTemp;
    float lastHum;
    //boolean metric = true;
    //Messages
    //Battery
    // Kontaktschalter
    //TempMessage
    void presentation(){
      sendSketchInfo("Küche Messstation", "2.0", true);
      //Tempsensor
      //Battery
    //Setup
      //Serial.begin(9600);
      Serial.println("Hello!");
      //Batterysensor
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
    //Tempsensor
      myHumidity.begin();
      Serial.println("...done!");
    //Starte den Loop
      //Batterysensor
      delay(1000);
       #ifdef DEBUG
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
      sleep(10);
     //Tempsensor
      if (isnan(temp)) {
        lastTemp = temp;
        Serial.println(temp);
      if (isnan(humd)) {
      } else if (humd != lastHum) {
          lastHum = humd;
          Serial.println(humd);
     Serial.println("Sleep...");
    Gateway sketch:
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    MyConfig.h
     * @file MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    *  Serial and debug options
    // I_DEBUG requests are:
    // V: CPU voltage
    // F: CPU frequency
    // M: free memory
    //#define MY_SPECIAL_DEBUG
    //#define MY_DISABLED_SERIAL
    //#define MY_CORE_ONLY
    #ifdef MY_DISABLED_SERIAL
    #undef MY_DEBUG
     * @def MY_BAUD_RATE
    #ifndef MY_BAUD_RATE
    #define MY_BAUD_RATE 115200
    //#define MY_RADIO_NRF24
    //#define MY_RS485
     * @def MY_NODE_ID
    #ifndef MY_NODE_ID
    #define MY_NODE_ID AUTO
     * @def MY_PARENT_NODE_ID
    #ifndef MY_PARENT_NODE_ID
     * @def MY_OTA_FLASH_SS
    #ifndef MY_OTA_FLASH_SS
    #define MY_OTA_FLASH_SS 8
     * @def MY_OTA_FLASH_JDECID
     * @brief Flash jdecid.
    #ifndef MY_OTA_FLASH_JDECID
    *  Gateway config
     * @def MY_GATEWAY_MAX_CLIENTS
    *  Information LEDs blinking
    // disabled in the gateway.
    // off when blinking
    *  Message Signing Settings
     * @def MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204
     * @def MY_SIGNING_SOFT
    //#define MY_SIGNING_SOFT
    *  RS485 Driver Defaults
     * @def MY_RS485_BAUD_RATE
     * @brief The RS485 BAUD rate.
    #ifndef MY_RS485_BAUD_RATE
    *  NRF24L01P Driver Defaults
     * @def MY_DEBUG_VERBOSE_RF24
     * @def MY_RF24_SPI_MAX_SPEED
     * @def MY_RF24_CE_PIN
    		#define MY_RF24_CE_PIN 4
    		#define MY_RF24_CE_PIN 27
    		#define MY_RF24_CE_PIN 9
     * @def MY_RF24_CS_PIN
    		#define MY_RF24_CS_PIN 15
    		#define MY_RF24_CS_PIN 3
    		#define MY_RF24_CS_PIN 10
     * @def MY_RF24_PA_LEVEL
    #ifndef MY_RF24_PA_LEVEL
     * @def MY_RF24_CHANNEL
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL	76
     * @def MY_RF24_DATARATE
    #ifndef MY_RF24_DATARATE
     * @def MY_RF24_BASE_RADIO_ID
    #ifndef MY_RF24_BASE_RADIO_ID
     * @def MY_RF24_ADDR_WIDTH
     * @brief RF24 address width.
    #ifndef MY_RF24_ADDR_WIDTH
    #define MY_RF24_ADDR_WIDTH 5
     * @def MY_RF24_SANITY_CHECK
    #define MY_RF24_SANITY_CHECK
    //#define MY_SOFTSPI
     * @def MY_SOFT_SPI_SCK_PIN
     * @brief Soft SPI SCK pin.
    #ifndef MY_SOFT_SPI_SCK_PIN
     * @def MY_SOFT_SPI_MISO_PIN
     * @brief Soft SPI MISO pin.
    #ifndef MY_SOFT_SPI_MISO_PIN
     * @def MY_SOFT_SPI_MOSI_PIN
     * @brief Soft SPI MOSI pin.
    #ifndef MY_SOFT_SPI_MOSI_PIN
    *  RFM69 Driver Defaults
     * @def MY_RFM69_FREQUENCY
    #ifndef MY_RFM69_FREQUENCY
     * @def MY_IS_RFM69HW
    //#define MY_IS_RFM69HW
     * @def MY_RFM69HW
    #ifdef MY_IS_RFM69HW
    	#define MY_RFM69HW true
    	#define MY_RFM69HW false
     * @def MY_RFM69_NETWORKID
    #ifndef MY_RFM69_NETWORKID
     * @def MY_RF69_IRQ_PIN
     * @brief RF69 IRQ pin.
    #ifndef MY_RF69_IRQ_PIN
     * @def MY_RF69_SPI_CS
    #ifndef MY_RF69_SPI_CS
     * @def MY_RF69_IRQ_NUM
     * @brief RF69 IRQ pin number.
    #ifndef MY_RF69_IRQ_NUM
    //#define MY_GATEWAY_W5100
    //#define MY_GATEWAY_ENC28J60
    //#define MY_GATEWAY_ESP8266
     * @def MY_PORT
    #ifndef MY_PORT
    #define MY_PORT 5003
    //#define MY_USE_UDP
     * @def MY_IP_RENEWAL_INTERVAL
     * @def MY_MAC_ADDRESS
    #ifndef MY_MAC_ADDRESS
     * @ingroup internals
     * under some form of attack.
     * - LDB (Locked During Boot)
     * @def MY_NODE_LOCK_FEATURE
     * @def MY_NODE_UNLOCK_PIN
    #ifndef MY_NODE_UNLOCK_PIN
    #define MY_NODE_UNLOCK_PIN 14
    /** @}*/ // Node lock group
    #if DOXYGEN
    edit2:
    Now I get this this from the node on my gateway´s serial monitor:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:SANCHK:OK
    and so on...
  • I have ordered the 2.0 boards, they are on their way to my home 🙂
    I'm plannign to use them as :
    • temperature node
    • door sensor
    Am I right ?
    @carmelo42
  • @m26872 said:
    @carmelo42
    Thanks to you for providing us theses files 🙂
    Ok, my mistake (I juste received my 10 MOhm resistor 😉
    Perfect, I just have to wait now for the little yellow packet 😉
  • I have received yesterday my little packet from DirtyPCB 🙂
    11 PCBs, so 33 sensors 🙂
  • @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
  • @carmelo42 yes
  • @jeti said:
    @carmelo42 yes
    I have this serial/usb adapter :
    https://img1.picload.org/image/ldrrddg/deekrobot-isp.png
    Can you tell me how I connect it to my node ? (noob question I guess ... but I don't want to burn my node 😞 )
  • @carmelo42 said:
    @jeti said:
    @carmelo42 yes
    I have found the answer myself with the schematic 😉
    Have you ever tried to power the node with 1 x CR2032 battery ?
    I have tried, but the node doesn't send anything further than 5 meters ...
  • I would like to know if your nodes are working all fine. I have the problem that my nodes freeze after a day or sometimes after a week.
  • @siod my temperature nodes work good, but my relay one doesn't work 😢
    Do you have any logs when it freezes ?
  • @carmelo42 no, unfortunately I don´t have any logs, any idea how to create logs?
    maybe if you keep your node connected to your computer with USB to serial adapter ?
  • mmh, no, that would mean I would have to run my computer for maybe 2 weeks 24/7...
    I guess it has somehting to do with the sleep function, the device seems to nat wake up after a while for some reason
  • So i got the boards and build them and they work perfect.
    One thing i couldn't figure out is why do i get relatively high current consumption, when the node is sleeping i get 1.5mA and not 5.8uA as in mentioned in this post.
    I use 8MHz internal clock and the sleep function and nothing is connected to the node.
    Can someone help?
    @dpressle Can you post the sketch?
  • Thanks, i see its 6.8 uA now, i had something wrong with my measurements 😞
  • It took me a while, but I just figured out how to get a bootloader burned onto the chip and I'm ready to make my slim nodes! Which board type in Arduino IDE do I use to program the chip once I'm using the 6 pin header after it's installed in the PCB?
    @JonnyDev13 Make a new board type by editing "boards.txt". There's an example in the first post.
  • Hi there! I need to buy some PCBs on Dirty PCBs but the URL http://dirtypcbs.com/view.php?share=13847&accesskey= seems broken. Any ideas? Thanks!
    @รอเรือ Apparently they've moved to a new site. Perhaps you can try this link: http://dev.dirtypcbs.com/store/designer/details/m26872/663/myslim2aabatterynodepcbv2-0panelized
    I think you must have a user account and login first. Please report back if it's working or not.
    Edit: Wrong link the first time.
  • Thanks @m26872
    That link didn't work either. However, by browsing all the shared PCBs I found this URL That link is accessible without logging in first.
    @รอเรือ Thanks a lot! All links are now changed.
  • Hey im building my first slim node and i wonder if someone has a sketch for 2 reed switches? i have found the sketch for only 1 reed switch in this thread. Im going to use it for my mailbox. How long do u think it can run on 2x aa batteries?
    Do i have to add 2x 10M resistors? or doesnt it work with external resistors then using more then 1 reed switch?
    @Eawo The example sketch should fit your needs. link Change the pull-ups activation to Low if you use external ones.
    I'd expect battery life 5-10 years depending on things such mailbox opening frequency, use of heartbeat signal, battery self discharge and climate.
    @Eawo Using internal resistors will only give you a few months battery time. One external pull-up for each switch will work and 1M resistors or any arbitrary "high" value is just as good.
  • Thanks
    ok now my problem is uploading the sketch it wont work on 1mhz bootloader i tried both a and b hex and the 2 diffrent Board.txt.
    I get it to work with the 8Mhz breadboard bootloader.
    But then using 1mhz bootloaders it always timesout
  • after a few hours frustration i went donwstars grabbed 2x new atmega328p breadboards and wolla everything works :). I Think i burned my first to putting them in the socket wrong.
  • i have wired everything but it wont work for me 😞 i have solder the 2 reed switch from gnd to d2 and gnd to d3. and ive done the same 2 1m resistors. I can see the node in domotics but no activity then i open and close.
    @Eawo
    The reed switches need to sit between GND and D2 or D3 as you have connected.
    The 1M pull up resistors need to connect between Vcc and D2 or D3.
    This way D2 or D3 are electrically connected to Vcc when the switches are open (pulled high). When the switches close, D2 and D3 get connected to GND.
  • I only come down to 12µA with one reed switch, 1MOhm pullup, 1Mhz bootloader and the binarySwitchSleepSketch. Measured with two different multimeters. This is nearly ten times higher than in the first posting. Changing all internal pullups to LOW doesn't change anything.
    Is there a way to optimize the power consumption or is it "good enough" ?
    @rollercontainer For sub 8uA consumption you need to go to "deep sleep" where the internal timers of the processor are disabled. Only wake up on interrupt. sleep( interrupt1, FALLING, 0);
    @rollercontainer - I just build a slimnode and 13uA is without anything connected what i can reach as well.
    For comparison i aim below 100uA when i do this with pro mini and they last around a year with 2xAA so my guess is 13uA is good enough.
  • @sundberg84: Thanks, so I will stick to my 12µA 🙂
    @AWI: I am using sleep with Interrupt as in this example:
    sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    https://github.com/mysensors/MySensors/blob/development/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino#L120
    @rollercontainer Your sleep looks good. Did you remove this piece of code?
    // Activate internal pull-ups
    Take a look at this thread for a < 1 uA consumption...
  • Since a few months I am very interested in Mysensors and this PCB. I have ordered the PCB and components to build some sensors as for a home security system. For experimental purpose I build one on a breadboard and that is working fine.
    A few days ago I started to solder the components on the PCB. The firs one is working fine, but the next sensors have an issue with the transceiver. After 3 boards failing I soldered one without the transceiver. Then I tested it by holding the transceiver at the board and it was working fine. After soldering the transceiver again a not working board.
    I tested one board by pressing another transceiver on top of the soldered one and I saw some communication in MYSController. The ATMega is still working on the breadboard. The PCB and Breadboard are powered by the same batterypack.
    Before soldering I tested all the transceivers with my breadboard and they are working fine. I am also using an anti-static bracelet.
    What am I doing wrong??
  • 29
  • 90
