  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • fdojuradoF
    fdojuradoF
    fdojurado
    I would like to ask about ack. Does the library have a specific timeout? Does the library resends the message when ack is not received? Thank you.
    • Puneit ThukralP
      Puneit ThukralP
      Puneit Thukral
      Cam I use an arduino pro mini 3.3V 8 Mhz to trigger the relay - or do I need a 5v arduino?
      • Puneit ThukralP Puneit Thukral
        sundberg84S
        sundberg84S
        @Puneit-Thukral - it depends on the relay.
        If you read the datasheet for intended relay you will see what is needed. Most relays i have seen requiers 5v and a good current (which Arduino sometimes fail to deliver).
        Puneit ThukralP 1 Reply Last reply
        • sundberg84S sundberg84
          Puneit ThukralP
          Puneit ThukralP
          Puneit Thukral
          @sundberg84 I used a 3904 transistor between the relay and arduino and it works just fine with 3.3 V Arduino pro mini 8 HMz.
          (2N2222 also works, but I have many pieces of 3904 and just a few 2N2222, hence using 3904)
          • Javier RubioJ
            Javier RubioJ
            Javier Rubio
            I have my gateway and my relay, I believe is working fine, I just want to know what set of caracters do I need to send in the serial monitor to turn on the relay? I will like to use the info in order to use a controller like Vantage or C4, is that possible? Regards
            • Javier RubioJ Javier Rubio
              Puneit ThukralP
              Puneit ThukralP
              Puneit Thukral
              @Javier-Rubio I m not an expert- a complete novice.
              I would suggest one of the following - trigger the relay through a controller or use one the the arduino relay example sketch in which relay is programmed to turn on and off every 1 second. This would help you validate if your wiring is correct or not.
              • GizmohG
                GizmohG
                Gizmoh
                I tried the relay sketch on my arduino mini pro (5v), step down converter for the NRF module and a two channel relay. It's conecte to a Raspi GW wirh the 2.0.0 beta and FHEM as controller. The switching works as expexted. but the relay switches continuisly on and off on its own after a certain time. I tried removing the loop-block but with no effort. Is there anything i can do to get a stable state? Thanks
                korttomaK 1 Reply Last reply
                • GizmohG Gizmoh
                  korttomaK
                  korttomaK
                  korttoma
                  @Gizmoh sounds like the relays are not receiving enough power to remain on. How are you powering all this?
                  • Tomas
                  GizmohG 1 Reply Last reply
                  • korttomaK korttoma
                    GizmohG
                    GizmohG
                    Gizmoh
                    @korttoma
                    I'm powering this with 6 x AA Batteries into the RAW Input from the Arduino and the 5v output from Arduino to the Relay.
                    • GizmohG Gizmoh
                      @korttoma
                      korttomaK
                      korttomaK
                      korttoma
                      @Gizmoh ok so it seems like the voltage regulator on the arduino cannot handle the load the relays produce when activated. You need to power the relay board directly from your batteries either trough another 5V regulator or if your relay board already can handle a higher voltage you can connect it directly.
                      • Tomas
                        GizmohG
                        GizmohG
                        Gizmoh
                        @korttoma Ah, okay, thank you. I'll give it a try.
                        Maybe connecting a Decoupling-Capacitor could also fix this problem?
                        • Rodolfo VieiraR
                          Rodolfo VieiraR
                          Rodolfo Vieira
                          hello one doubt
                          if a use this sketch: /mysensors/MySensorsArduinoExamples/examples/RelayWithButtonActuator/RelayWithButtonActuator.ino
                          when i press the button home assistant knows if switch was turned or off? its change the stat?
                          • riochickenR
                            riochickenR
                            riochicken
                            First of all Merry Xmas to all of you!
                            I want to use this sketch with three LEDs to present the status of the alarm at home, so with a multicolored LED I have a green status, a red and a blue status, but I just want one color at a time, is there a way to alter the code a little to make sure that is a color is activated, the other one is turned off?
                            • riochickenR riochicken
                              @riochicken yes, but I wouldn't recommend relays for controlling a led. It can be controlled directly from the Arduino pins.
                              Look at the code for these:
                              https://www.openhardware.io/view/21/RGBW-LED-Controller#tabs-source
                              https://www.openhardware.io/view/74/OH-MySensors-RGBW-Controller#tabs-source
                              • riochickenR
                                riochickenR
                                riochicken
                                @mfalkvidd : I have directly soldered the LED's to the board, would be a waste of relays.. :) Thanks I will look into the examples you just gave...
                                • riochickenR
                                  riochickenR
                                  riochicken
                                  @mfalkvidd I have no clue how to decode the examples you gave, normally in vb or powershell I would check if a pin would be active if another color was requested so I could turn off the other color but I am a bit lost with the code....
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    wrote on last edited by pepson
                                    #28
                                    Hi all
                                    I use this sketch for controlling 2 x relays. Can anybody change me this sketch to controliling only 1 x relay ?
                                    Next problem....
                                    Anybody know how edit sketch for relays to add itrms to send repeate update status to gateway? I want eliminate problem when node start and change status , but gateway is disabled. And after gateway will be enable show in my Domoticz old status/last memory before disable gateway. But after this node has changed status and this status is not show in Domoticz after run. I want to work it as Z-Wave. Z-wave has always actual status. Is any chance to also MySensors Gateway and not has always actual status ?
                                       DESCRIPTION
                                       Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
                                    //#define MY_RADIO_NRF24
                                    #define MY_RADIO_RFM69
                                    #define MY_RFM69_FREQUENCY RF69_868MHZ
                                    #define MY_IS_RFM69HW
                                    #define MY_REPEATER_FEATURE
                                    // Node id defaults to AUTO (tries to fetch id from controller)
                                    #define MY_NODE_ID AUTO
                                    // Define Relays
                                    #define RELAY_OFF 0  // GPIO value to write to turn off attached relay
                                    // Define Sensor ID's
                                    #define SSR_A_ID 1   // Id of the sensor child
                                    #define SSR_B_ID 2   // Id of the sensor child
                                    // Define buttons and relays
                                    const int buttonPinA = 3;
                                    const int buttonPinB = 4;
                                    const int relayPinA = 5;
                                    const int relayPinB = 6;
                                    // Define Variables
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                    bool stateA = false;
                                    bool stateB = false;
                                    int trigger = 0;
                                    Bounce debouncerA = Bounce();
                                    Bounce debouncerB = Bounce();
                                    MyMessage msgA(SSR_A_ID, V_STATUS);
                                    MyMessage msgB(SSR_B_ID, V_STATUS);
                                      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                                      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
                                      // After setting up the buttons, setup debouncer
                                      debouncerA.attach(buttonPinA);
                                      debouncerA.interval(5);
                                      debouncerB.attach(buttonPinB);
                                      debouncerB.interval(5);
                                      digitalWrite(relayPinA, RELAY_OFF);
                                      digitalWrite(relayPinB, RELAY_OFF);
                                      pinMode(relayPinA, OUTPUT);
                                      pinMode(relayPinB, OUTPUT);
                                    void presentation()  {
                                      sendSketchInfo("2xRelay with monostable", "2.1");
                                      present(SSR_A_ID, S_LIGHT);
                                      present(SSR_B_ID, S_LIGHT);
                                    if (trigger == 0){
                                      send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                                      send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                                      trigger = 1;
                                      debouncerA.update();
                                      // Get the update value
                                      int valueA = debouncerA.read();
                                      if (valueA != oldValueA && valueA == 0) {
                                        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                                      oldValueA = valueA;
                                      debouncerB.update();
                                      int valueB = debouncerB.read();
                                      if (valueB != oldValueB && valueB == 0) {
                                        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                                      oldValueB = valueB;
                                        switch (message.sensor) {
                                          case 1:
                                            stateA = message.getBool();
                                            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                                          case 2:
                                            stateB = message.getBool();
                                            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                                        Serial.print("from node:");
                                        Serial.println(message.sender);
                                    • oufmanO
                                      oufmanO
                                      oufman
                                      I would like to do an auto off after 2 sec directly in the sketch, however I do not understand how to write the code? I do not want to make a loop, but on pressing the ON button from my box the relay is activated is deactivated after 2 sec.
                                      Thank you for your help.
                                      • EfflonE
                                        EfflonE
                                        Efflon
                                        I'm trying to wrap my head around the button example and don't understand what the loop() really does. To me it only alters the "state" but how does it affect the relay?
                                        Is the button physically connected to the relay or should the controller send the new state back and let the receive() function handle the actual relay switching?
                                        Also, after presentation, shouldn't there be a send() to the controller?
                                        korttomaK Boots33B 2 Replies Last reply
                                        • EfflonE Efflon
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @Efflon you are right about the loop() function it seems like the part where it should change the relay state is missing. Did you try to use this example code?
                                          The button should be wired between PIN 3 and GND so that when you push the button PIN 3 is Grounded.
                                          PIN 3 is connected to a "Debouncer" in the "setup()" ( so that when you push the button the code detects only one push and not several ).
                                          loop() monitors the debouncer and when it detects that you have pushed the button it will send the new state to the controller. I think it should also change the state so if it does not do that you could add the following line
                                          digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); //write new state to relay output
                                          Before this line in the loop() function:
                                          send(msg.set(state?false:true), true); // Send new state and request ack back
                                          You could also add the line:
                                          saveState(CHILD_ID, state); // Store state in eeprom
                                          To the same part of the code so that the state change is written to eeprom so that the previous state can be returned after a power failure.
                                          • Tomas
                                          EfflonE 1 Reply Last reply
