  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • rozpruwaczR
    rozpruwaczR
    rozpruwacz
    wrote on last edited by rozpruwacz
    #72
    treat yor solenoid as it was a relay, the difference is that relay switches flow of current, and solenoid valve switches flow of water. so You have to use the same schematic, but put your valve where the relay is. But if You want power it from a battery, choose a latching solenoid valve instead of regular solenoid valve - and that requeires different schematic.
    fhenrycoF 1 Reply Last reply
    • rozpruwaczR rozpruwacz
      fhenrycoF
      fhenrycoF
      fhenryco
      @rozpruwacz
      thanks, but do you mean that the schematic simply would not work for the regular valve or that it would work but not be low power cinsumption design anymore ?
      I have a regular solenoid valve but in my application the valve is normally closed and it will be only exceptionnally opened and for a short time when the 12V is applied, so i guess that i can live with it ...
      As for the transistor in the schematic, except it seems to be a NPN , i don't know if i need a particular one for it . probably i can just buy a 2N3904 , or is there a better choice?
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        #74
        the schematic you posted is not using latching relay/valve. it doesn't matter if it is relay or valve. both works the same and consume power when in ON state. If you plan to use it in a way that the valve will be ON for very short periods than it is not important if it is latching or not.
        when choosing a transistor for such use, You have to look at its datasheet into "absolute maximum ratings" section and check if it will handle the voltages you will apply to it. 2N3904 looks like it will handle 12V without a problem.
          fhenrycoF
          fhenrycoF
          fhenryco
          wrote on last edited by fhenryco
          #75
          @rozpruwacz
          thanks , i will use 2N2222 because the valve needs between 200 and 400 mA.
          I'v read the 2N3904 is OK for < 100 mA
          • fhenrycoF
            fhenrycoF
            fhenryco
            #76
            It works very well with the transistor and schematic posted above. I think the valve is a latching valve because it only discharges the battery when there is a transition. The only remaining problem is that the 5V arduino alone is too much power consuming. So i'm wondering if the transistor could as well work with a 3.3V arduino, that is when the signal level on the transistor Base is 3.3V rather than 5 V ... then i also could remove the arduino led but i'll need to keep the arduino regulator because my 3.7V cell voltage is too much greater than 3.3V
            • fhenrycoF fhenryco
              fhenrycoF
              fhenrycoF
              fhenryco
              @fhenryco Actually the internal resistor of the solenoid is 27 Ohm while the resistance between C and E of the transistor in the passing state is 35 Ohm ... so it remains less than Vcc/2 for my solenoid which needs 12V ... so i need to tune my boost module at the max ==> more than 30V ... that does not seem ideal, may be i shoud choose another transistor with less internal resistor, but i have little experience with transistors : studied them a long time ago , so if someone can suggest something smart, ready to buy it ...
              • skywatchS
                skywatchS
                skywatch
                Can I suggest a change to this page?
                As it stands the wiring diagram only applies to sketch 1 (without switch). It could get confusing as the 2 sketches use different pins for the relay and there is no need for this.
                I propose that the wiring diagram be changed for the relay to be attached to pin 4.
                The first sketch needs the relay pin to change from pin 3 to pin 4.
                That's it. Then the diagram and sketches will work whichever way the builder wants to do it.
                • skywatchS skywatch
                  Good idea @skywatch
                  When doing the update, we should also rename RELAY_1 to RELAY_PIN to be consistent with sketch 2.
                  • mfalkviddM
                    https://github.com/mysensors/MySensors/pull/973
                    • mfalkviddM
                      https://www.mysensors.org/build/relay has been updated with new wiring instructions (picture + table)
                      • skywatchS
                        skywatchS
                        skywatch
                        That looks good, only the sketchs to go....On that note I wonder if Relay_1 might not be better choice as it gives a clue to people that if they want to add a second relay then that would be Relay_2.... Just a thought and maybe not needed.... ;)
                        • HenryWhiteH
                          HenryWhiteH
                          HenryWhite
                          @mfalkvidd when updating the example sketch you could maybe consider my version of the relay sketch which offers some nice additions: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
                          • HenryWhiteH HenryWhite
                            @HenryWhite my mind is divided when it comes to that type of sketch. Yes, it has a lot of functionality. Yes, it is probably what people need anyway. But the examples are meant to be used by someone who is just getting into diy home automation. Someone new should be able to understand as much of the sketch as possible. There should be as little as possible to trubleshoot. If the sketch is complex, most people's initial reaction will be that there is something wrong with the code, when in reality almost all newbie problems are power or wiring-related. Keeping the sketch simple helps, at lest a bit.
                              fhenrycoF
                              fhenrycoF
                              fhenryco
                              @mfalkvidd You are right but may be should there be for each sensor or actuator first the most basic sketch but also at the end of the page a complete version with all functionalities and granted to work by the mysensors team.
                              Of course for the complicated sketch version a big warning in red letters that this is not recommended for newbies would help...
                                fhenrycoF
                                fhenrycoF
                                fhenryco
                                After testing some functionalities of nodemanager, i was wondering if already somebody was working on making a GUI for nodemanager which would allow to build one's sketch completely from a graphical interface (at least the most common and basic functionalities) : i thing the great work that resulted in Nodemanager has so well structured the various functions needed that it has already paved the way for creating such a graphical interface.
                                  There was a user some time ago that was trying to make a web GUI
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    I would agree that more advanced sketches 'should' be included on the same page. Keep all the info in one resource place. Provided it is clearly marked as an advanced project it might help people looking for similar functionality or just interested in learning more about programming....
                                      @fhenryco
                                      https://rakeshpai.github.io/mysensors-network-manager/networks/
                                      https://github.com/rakeshpai/mysensors-network-manager
                                      • fhenrycoF
                                        fhenrycoF
                                        fhenryco
                                        wow! fantastic! ... the github link readme warns that it's not yet fully ready but the interface is already impressive!
                                        I still have the same question i had for nodemanager though : for measuring another battery than the one that feeds Vcc obviously another pin is needed, however why not propose as well the option of measuring such pin voltage but with Vcc as the reference rather than the internal 1.1V which most of the time makes necessary a voltage divider ? Actually i did the modification in nodemanager.cpp to use DEFAULT (~3.3V) rather than INTERNAL (1.1V) reference for a 3.3 pro mini and i can get the expected battery level without any voltage divider.
                                        Another unrelated question i have is : could there be any way to adapt the idea of the readVcc method (which is to measure the internal 1.1V against the Vcc reference to get Vcc) but using any voltage applied to a pin as the reference to again measure the internal 1.1 against it ? This would allow the masurement of any voltage greater than 1.1 without voltage divider while the usual method would be applied for measuring any voltage lower than 1.1 ... what did i miss that makes this impossible ?
                                          We need to use the internal reference since it is the only stable voltage source and you need the voltage divider to lower the measured voltage between 0 and 1.1v. There are not many options to choose from
