💬 Button size radionode
The download only contains photos. Where are the board and schematic files?
Do not worry, I will upload all files soon
Cute little thing.
I've updated board (see updated section). Still waiting for suggestions
I really hope that this board will be possible to buy soon assembled. Is the price for the new rfm69 the same as the old? (~3-4$)?
Since you asked, here are some suggestions: 1. drop the resonator. It can run on the 8Mhz internal resonator just fine. 2. Drop the voltage converters. It's more power efficient to run direct from battery. 3. Keep the part count as low as possible. Less assembly means more users.
Yes, price is the same.
Thanks! I'l think about every point.
May be it will be worth leaving LDO footprint on the board without soldering it? In this case we can run board directly from battery. But if you want to use unregulated DC source you can cut thin jumper (jumper will no covered by solder mask) and solder LDO.
Soldered board will be as cheap as possible, I promise. So theere will be no need to assemble board
Well, if you're going for pre-assembly, there seems to be a much smaller atmega328p available from China. I recently received an very inexpensive pro mini with one on it. Not sure, but this photo may also show it: http://www.varesano.net/files/Image426.jpg However, on the pro mini I received it looks as though it may have been wire bonded directly to the PCB.
Here's a better photo of it, where you can actually read the markings: https://d3s5r33r268y59.cloudfront.net/0424/products/thumbs/IMG_20131014_145751.JPG.2560x2560_q85.jpg
I love it! More boards like this!
I would concur with using a TQFP atmega if you're not doing manual assembly anyway.
As for other requests / suggestions .... perhaps you could make a separate version which has less pins broken out and instead has room for a flash memory. Also I am still very much in favor of more extreme step-up ICs, that can take say 0.6-0.7V from a single AA/AAA and boost it to 3.3V. For some reason no one is going that route on the forum anymore and I don''t know why? Has everyone switched to lithium batteries?
@bjornhallberg
AFAIK, it's because available current (i.e. mah capacity) is the primary constraint, and there seems consensus that a booster on a single cell burns through that capacity a lot more quickly than, say, two cells and no buck or boost regulator. If constrained space is what's driving you to a single AA/AAA cell, then perhaps you could use a single 3.3V CR123 and still come out ahead? I haven't seen a direct head-to-head comparison, but I wouldn't be surprised if the CR123 were to win on both the volume/size and the battery life metrics.
@NeverDie Yeah you're probably right, but a CR123 is damn expensive from where I'm standing, compared to a single AA cell. I'm perfectly fine with changing batteries more frequently if it comes to that. The only thing that would sway me would be sub zero temperature performance. I'd sooner try a coin cell and see how far I'd get. I'm looking for compact solutions for mailbox alarms and the like where the sensor would need to be almost paper thin to stick to the lid of the box.
@bjornhallberg
It sounds a little crazy but... we have enough space for eeprom in sot23-5 package (with decoupling capacitor!).
I've placed 24LC64 temporarily
@bjornhallberg
You're right: a coincell would seem be a good match for a mailbox application.
@Koresh what is your guess of the price for 1-10 pre-assembled sensors?
Does RFM69 really need to be connected to D2? Does Mysensors lib use it ?
RFM69 uses interrupts, yes.
for batt/powering choice, I don't see a consensus lol! I think it really depends on goals and requirements. sometimes sensors can require some voltage, or you want less maintenance+cheaper batt etc.
- lithium AA/AAA (or alkaline but less good), cheap in packs, easy to find and great seldischarge rate. It's 2500-3000mah. Put them in // and you can double your lifetime... if no problem with footprint, you can find cheap LR14, 8000mah, not tried, but wow
- Coincell, lower mah, and very variable lifteime if noname...
And booster is interesting if you control the power consumption of your system, and use an ultra efficient during very light loads.
Then, not sure if cr123 win so easily. CR123 have good selfdicharge rate in primary batt form, and it's something like 1200mah.About the overall size of the device vs batt size etc..because booster takes more component..but when you make a device you don't use only an atmel+radio only.., you need more things, so at the end it's bigger. near the size of an AA/AAA. or use shield board style, but then it's not thin, less nice when using coincell. But I like the format of coincell, that's just not the same league...
Why I say this..because I made some experiments, and have some boards with boosters (not released yet..) and I like the TPS61098x..crazy thing, but very tiny
I don't want to debate..just my thought.for rfm69, +1 for interrupts
and if you want to optimize the power consumption in future with listenmode
Can anyone confirm microchip 24LC64 as eeprom (pinout is standard for sot23 eprom, so it is possible to change chip in future)? Is standard library compartible with it? Thanks!
@Koresh I think this eeprom has libs for arduino. but if this is for using ota with dualoptiboot and mysensors, as far as I know, it's not compatible. only jedec spi eeprom for the moment..If it's only for datastorage, I don't see problems.
I'm revising my earlier comment. Based on new experience, I wouldn't recommend using the smaller atmega328p.
@Koresh Where do you get the rfm69(h)w rev 3.0 from? Or is it the hc model? I can only seem to find rev 2 (?) on Ali?
You can find these modules as "rfm69hc" on Ali. Do not forget about haggling
I've received new version of these little boards
Will show new soldered boards asap.
@koresh When are you planning to release the Eagle files for the board please?
After all tests are completed
@Koresh Could you give us a rough estimate of the assembled price for the different nodes?
I will try to estimate rough prices for all boards today.
So I am ready to present estimated prices to all my new boards.
The estimate is too rough because I am not sure about size of the production batch. But it's better than nothing. Prices include pcb's, components and assembly. Configurations are not fully accepted yet.---WALL SOCKET INSERTABLE NODE
BASIC (ac/dc, atmega, rfm69, 10a relay) - 9.5$
ADVANCED (ac/dc, atmega, rfm69, 10a relay, current sensor, rgb led) - 10.8$
MAX (ac/dc, atmega, rfm69, 10a relay, currrent sensor, atsha204, watchdog, rgb led) - 12.2$---WALL SWITCH INSERTABLE NODE
BASIC (atmega, rfm69, buttons controller, JST wires) - 6.5$
MAX (atmega, rfm69, buttons controller, JST wires, atsha204) - 7.5$--BUTTON SIZE RADIO NODE
BASIC (atmega, rfm69) - 6$
MAX (atmega, rfm69, atsha204) - 7$--SECRET TTL-USB
BASIC - 1.4$
Ahh Great, I will be ordering a lot of boards when they are available. Just one question, do you have any sensor-boards planned? like PIR/temp/hum/Lux -multisensor ?
I would buy 10 of the little stamp Sized Nodes without atsha if the price for Germany is good
...and also 2 secret TTL Devices.Hope release is soon
Koresh,
Great work, I must say that I would be also interested in getting a couple of your boards as soon as they are ready !
@scalz Challenge accepted
Now with OTA!
@frencho said:
Koresh,
Great work, I must say that I would be also interested in getting a couple of your boards as soon as they are ready !Thanks!
@Koresh hehe great
Have you planned to release some kind of general sensor too? Like temp/hum /light/pir?
Unfortunately I have no time. Now i'm focusing on preparing three boards for mass production. Do not forget, I have job and I design those boarsd in my free time. May be I will design sensors boards after
@Koresh not really for me as I have enough boards
but i was just thinking.. it's a button size node, so is it a for a button
or a coincell node? If it's a button size, so which batt do you use? I guess a coincell, or I don't see other advantage of the size except price. If it's a coincell node, do you have few capa at input to buffer and prevent internal res?
Ideas only
@Cliff-Karlsson don't worry i will release my multisensors stuff, with pcba. Not my job too, and lot of other boards so.. But sure that won't be a 7 euros board. You can't have so much sensors for this price with radios etc..or maybe @Koresh has some magics
LOL
@Koresh
What's your estimate as to when you'll have it manufactured and ready to ship?
@NeverDie said:
@Koresh
What's your estimate as to when you'll have it manufactured and ready to ship?This week will collect components. Next week PCB production and PCBA. After that another week to ship few samples for testing. If All goes well after 3-4 weeks from now- ready to ship them from China.
Any update to the ETA?
I became a father yesterday
My pcb contractor gave us very many fails with my last orders... So we have a little delay. I will try to say ETA asap.
congrats!
Congrats!
(new free time) = (old free time)/3
But,
(new happiness) = 2 * (old happiness)
Congrats!
@koresh, first of all congrats with you being a father. I really like your projects. Looking forward to hear when and where to order
Baby should be sleeping the night now
- Congrats!
Any ETA here? Thanks.
Looks amazing. You got some eagle files with this?
Any news on this? I would be interested in the design
@chbla Thank you for your attention to this project. The project button size node with extension is improved version of these project. So those project implements all of features. Moreover last week I ordered improved version of those pcb. If you do not need extention you can just cut it. I plan to place order in the local factory in a week. So if you want I can make some boards without battery holder and extra sensors.
@Koresh said in
Button size radionode:
Thanks! I found it meanwhile
great work
Hello.
Are these modules still in operation?
As it is already an old project I would like to know the reliability and energy consumption?Thanks
💬 simple MySensors MultiSensor Board
OpenHardware.io • 2 Mar 2018, 16:50 • openhardware.io 7 Dec 2018, 09:04 -
Mother/daughter board system
OpenHardware.io • 6 Feb 2016, 23:07 • openhardware.io 6 Feb 2016, 23:33 -
Wall Mount Sensor
OpenHardware.io • 14 Jan 2016, 03:48 • openhardware.io 14 Jan 2016, 06:40 -
💬 Secure 5-button Keyfob
OpenHardware.io • 2 May 2017, 09:55 • openhardware.io 8 May 2017, 00:40 -
💬 NRF52 In Wall-Dimmer
OpenHardware.io • 5 Oct 2019, 07:10 • openhardware.io 5 Oct 2019, 07:10 -
💬 RFM69 - 8 Dimmer output
OpenHardware.io • 24 Jan 2017, 13:30 • openhardware.io 24 Jan 2017, 19:58 -
💬 Piglets - IOT Development Board
OpenHardware.io • 22 Jan 2017, 19:56 • openhardware.io 7 Oct 2017, 12:59 -
Adafruit RFM69HCW and Arduino Nano
Troubleshooting • 27 Jul 2020, 13:21 • keithJ 29 Jul 2020, 10:37
