    @gonzalonal Assuming that you have the Nano 3.0, you should be good to go with "ATMega328 16Mhz MYSBootloader"...
  • Ok, thanks for that.
    I finally found my problem.
    The Node was sleeping most of the time. In spite of waking up twice per second, it was not enough to enter the uploading mode in the mysbootloader, so the node wasn't answering back to the gateway, nor MYSController.
    Now I have a questions
    How can I OTA update/upload the firmware of a sleeping node? Should the gateway, or a relay node, send the upload message to the sleeping node as soon as it wakes up for transmiting its data?
    I guess that in order to do that, the sleeping node should always wait for an aknowledge or some kind of message after waking up. I mean:
    Sleeping node wakes up
    Then, it send its data to controller or to relay node
    Afterwards, it wait for the controller to acknoledge the data just send, and to tell him (sleeping node) if there is a firmware upgrade for it.
    If there's not, go back to sleep. If there is, go to OTA upgrade routine.
    Thanks, regards.
    @gonzalonal
    OTA updates for sleeping nodes with MYSBootloader:
    • add gw.wait(200) after the gw.send() (=node processes incoming messages for 200ms after sending a message)
    • In MYSController, right-click on the node, select "Battery-powered / sleeping", then assign FW, confirm to reboot node (reboot request is now queued)
    MYSController will now wait until it receives a message from that node, send the reboot command and hence, initiate OTA update.
  • @tekka Great Tekka, thanks again. I will try that.
    Regards.
    I am trying to debug a mysensors temp. sensor using this tool (it is not detected by Domoticz). I connected the serial gateway to your program and when I turn the temperature sensor, I see that there is traffic back and forth between the gateway and the sensor. But my knowledge stops there.... any pointers? I can upload a screenshot of the log if it helps.
    Z.
    @zuru screenshots and/or log files are always good starting points 😉
  • I found my problem.... so everything is fine now.
    Z.
  • Hey guys,
    maybe anyone can help. I tried to debug my sensors, but didn't got MYSController to talk with my gateway.
    I have the NRF24L01+ directly connected to my rPi and can use the Gateway with Pimatic plugin. Then I tried different ways to give MYSController access:
    1. redirecting the serial gateway to tcp port (tried ser2net and socat) to use ethernet option, but didn't got this to work.
    2. creating a new gateway using a spare nano with NRF24L01+ at my PC. This one worked, but the gateway didn't noticed my nodes. Are they somehow coded to only talk with the gateway they know? I waited serveral minuters (sensors reporting each minute), but didn't got any readings. I assume this programm has an auto update to show now nodes, right?
    Hope someone can help, I would realy love the option to debug using my windows PC and in future upload new sketches OTA (with new bootloader).
    Regards,
    Anduril
  • I have followed the procedure listed and that mentioned in post 77. Pro Mini 3.3v 8mhz Arduino.
    I keep getting the following message in the debug window every few minutes. Have repeated the process in post 77 several times however get the same results.
    [2015-09-01 18:09:17.276 Info] DEBUG Undefined firmware/type for node=2
    [2015-09-01 18:09:17.323 Info] INFO BL version=257
    [2015-09-01 18:09:17.354 Info] INFO Send FW info to node 2: type=A, version=1, blocks=0x0048, CRC=0xD098
    [2015-09-01 18:09:17.386 Info] TX 2;0;4;0;1;0A000100480098D0
    [2015-09-01 18:09:17.417 Info] RX 2;255;4;0;0;FFFFFFFFFFFFFFFF0101
    Any pointers??
    @allysmith please provide more information about the setup and upload the MYSController log for further troubleshooting
  • @tekka What kind of SPI flash is needed for this OTA stuff? Can you provide part numbers?
    @ericvdb MYSBootloader works without external flash, in contrary to the sensebender board and dualoptiboot bootloader
  • @tekka Thanks for getting back to me. This is my my first go at this bootloader. Hope I am not doing something daft!
    I have Arduino IDE 1.6.5, MySensors 1.5, MYSBootloader 1.1, MYSController_0_1_2_282 running on Windows 8, USBasp to urn bootloader.
    Arduino Pro Mini 3.3v 8mhz board. I am using the standard settings in your write up for the boards.txt
    Log file hopefully attached.
    MySensors_20150901-185920.log
    @allysmith Try clearing EEPROM via MYSBootloader command, assign blink FW and upload the entire log again....
  • @tekka As requested, cleared EEPROM via MYSBootloader, assigned blink FW.
    Attached is the log.
    Device shows up in the nodes window as Booting: 65535:65535 (BL1.1)
    MySensors_20150902-055736.log
  • @tekka Have made a change to how I was powering the NRF and now straight from battery.
    Looks like it was a power issue. Sufficient for transmit from the node ut not for receiving the updates.
    See attached log.
    Now got a different issue when I tried to reassign the FW from link to Timereporter.
    I think I am moving in the right direction now.
    Thanks for your help so far.
    Keep up this great work.Deug.txt
  • WOOOHOOO, i got OTA working 👯
    This is awesome guys
    BTW, I guess OTA will not work if there's a repeater in the middle?
    congrats! 🙂
    OTA updates will also work with repeating nodes in between...
  • @tekka i guess OTA is not available when using a MQTT gateway?
    I would like to switch my whole setup to MQTT, but don't wanna loose the super fantastic OTA feature.
    @ericvdb in theory possible, but AFAIK not supported by any controller...at the moment 🙂
  • @tekka would you mind describing in detail the process (on the controller side) how the OTA works?
  • Can somebody explain to me how the "Reassing ID" function works in MYScontroller? I haven't been able to change a ID remotely.
    ID's keep the same after reboots or power cycles, with or without the AutoID option on.
    @cdr IDs are assigned the first time the node starts up and then stored in the Arduino EEPROM. To get a new ID, you would have to clear (that portion of) the EEPROM, or you can upload a copy of the sketch with the ID hard-coded.
    Al
  • It's possible to reassign ID if you use MYSBootloader.
  • I use MYSbootloader, but can neither get "reassign ID", nor "clear eeprom" functions to work.
    I guess I could make a cleareeprom hex, but that feels like a workaround.
  • I just try (never before) and it doens't work for me too.
  • quite a few post. so apologies if this has been asked before.
    I'm trying to upload a sketch(hex) to one of my nano's
    it's going but froze at 70%
    i had to reboot the gateway.
    this time it got to 87% and seems froze again.
    any thoughts/suggestions on why the gateway is freezing up?
    edit: i can't seem to get a sketch to upload. it gets to some random % and then the gateway freezes.
    a push of the gateway reset button seems to start it over. but then freezes at random.
    edit 2: must have been a distance thing.. i put the bridge right next to the gateway and the code uploaded quickly without freezing.
    however, i still am curious as to why the gateway fails to respond/freezes if the firmware is not able to be uploaded.
    Reassign ID & clear EEPROM are commands implemented in MYSBootloader 1.1: A special ST_FIRMWARE_CONFIG_RESPONSE sequence (see the source code for detail) will instruct the bootloader to either change the ID in EEPROM or clear the EEPROM. The reassign ID command will only have effect, if the firmware has does not have static a ID setting. In order to use the bootloader commands the controller should be able to reboot the node.
  • Hi @tekka,
    Thanks for the reply, I created a "clear eeprom" hex and after uploading it is working as expected, the ID resets.
    Using the function in Mycontroller however, does not work. Not sure if this is a bug, or perhaps an error caused by an Arduino clone, but the "reassign ID" function is not working as intended here.
    Anyone here that got it working as intended?
    @cdr please post the MYScontroller log to figure out what's going on. Thanks
  • @Tekka Same "bug" here" with MYSBootloader 1.1 (hex from github) on arduino nano. Try to change ID of node N°1, Log :
     [2015-09-21 21:52:57.053 Info] INFO	*** Logging START ***
     [2015-09-21 21:52:57.053 Info] VERSION	MYSController 0.1.2.282
     [2015-09-21 21:52:57.053 Info] STARTUP	INI file loaded
     [2015-09-21 21:52:57.053 Info] STARTUP	Loading FW repository...
     [2015-09-21 21:52:57.054 Info] REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
     [2015-09-21 21:52:57.064 Info] REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
     [2015-09-21 21:52:57.076 Info] REPO	FW "Motion" loaded. t=30, v=1, blocks=1024, crc=0xD1BF
     [2015-09-21 21:52:57.092 Info] REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
     [2015-09-21 21:52:57.108 Info] REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
     [2015-09-21 21:52:57.108 Info] REPO	FW repository loaded. Items=5
     [2015-09-21 21:52:57.111 Info] STARTUP	Initialize message types
     [2015-09-21 21:52:57.111 Info] NODE	New node discovered, node id=0
     [2015-09-21 21:52:57.111 Info] NODE	New node discovered, node id=255
     [2015-09-21 21:52:59.606 Info] INFO	Connected to 192.168.1.90:5003
     [2015-09-21 21:53:04.373 Info] NODE	New node discovered, node id=1
     [2015-09-21 21:53:04.376 Info] CHILD	New child discovered, node id=1, child id=internal
     [2015-09-21 21:53:04.379 Info] INFO	BL version=257
     [2015-09-21 21:53:04.380 Info] INFO	No FW assigned
     [2015-09-21 21:53:04.383 Info] RX	1;255;4;0;0;1E0001000004BFD10101
     [2015-09-21 21:53:04.681 Info] NODE	New node discovered, node id=4
     [2015-09-21 21:53:04.685 Info] CHILD	New child discovered, node id=4, child id=1
     [2015-09-21 21:53:04.688 Info] RX	4;1;1;0;0;21.6
     [2015-09-21 21:53:04.691 Info] CHILD	New child discovered, node id=4, child id=2
     [2015-09-21 21:53:04.694 Info] RX	4;2;1;0;1;71
     [2015-09-21 21:53:06.421 Info] INFO	BL version=257
     [2015-09-21 21:53:06.424 Info] INFO	No FW assigned
     [2015-09-21 21:53:06.427 Info] RX	1;255;4;0;0;1E0001000004BFD10101
     [2015-09-21 21:53:08.470 Info] INFO	BL version=257
     [2015-09-21 21:53:08.472 Info] INFO	No FW assigned
     [2015-09-21 21:53:08.476 Info] RX	1;255;4;0;0;1E0001000004BFD10101
     [2015-09-21 21:53:14.903 Info] UPDATE	4295098650
     [2015-09-21 21:53:14.906 Info] INFO	BL version=257
     [2015-09-21 21:53:14.909 Info] INFO	No FW assigned
     [2015-09-21 21:53:14.913 Info] RX	1;255;4;0;0;1E0001000004BFD10101
     [2015-09-21 21:53:14.916 Info] INFO	BL version=257
     [2015-09-21 21:53:14.918 Info] INFO	No FW assigned
     [2015-09-21 21:53:14.922 Info] RX	1;255;4;0;0;1E0001000004BFD10101
     [2015-09-21 21:53:14.925 Info] DEBUG	Update child id=255, type=ARDUINO_NODE
     [2015-09-21 21:53:14.929 Info] RX	1;255;0;0;17;1.5
     [2015-09-21 21:53:14.933 Info] TX	1;255;3;0;6;M
     [2015-09-21 21:53:14.937 Info] RX	1;255;3;0;6;0
     [2015-09-21 21:53:14.945 Info] CHILD	New child discovered, node id=0, child id=0
     [2015-09-21 21:53:14.950 Info] RX	0;0;3;0;14;Gateway startup complete.
     [2015-09-21 21:53:16.680 Info] RX	1;255;3;0;11;Motion Sensor
     [2015-09-21 21:53:16.691 Info] RX	1;255;3;0;12;1.0
     [2015-09-21 21:53:16.695 Info] CHILD	New child discovered, node id=1, child id=1
     [2015-09-21 21:53:16.701 Info] DEBUG	Update child id=1, type=MOTION
     [2015-09-21 21:53:16.714 Info] RX	1;1;0;0;1;
     [2015-09-21 21:53:16.718 Info] RX	1;1;1;0;16;0
     [2015-09-21 21:53:38.779 Info] INFO	Node trigger set, node=1, trigger=1
     [2015-09-21 21:53:39.793 Info] INFO	Retained message triggered for release, node=1
     [2015-09-21 21:53:39.796 Info] CHILD	New child discovered, node id=1, child id=1
     [2015-09-21 21:53:39.800 Info] TX	1;0;3;0;13;0
     [2015-09-21 21:53:39.805 Info] RX	1;1;1;0;16;1
     [2015-09-21 21:53:39.808 Info] CHILD	New child discovered, node id=1, child id=internal
     [2015-09-21 21:53:39.811 Info] DEBUG	Update child id=255, type=ARDUINO_NODE
     [2015-09-21 21:53:39.815 Info] RX	1;255;0;0;17;1.5
     [2015-09-21 21:53:56.729 Info] INFO	Disconnected
     [2015-09-21 21:53:58.924 Info] INFO	*** Logging STOP ***```
    @Fabien I have an idea what is going wrong here: To confirm please enable DEBUG in the gateway and kindly re-post the full log again. The issue is related to signing...
  • @tekka, I can't enable debug if I'm right. Not enouch space for the sketch.
    Issue is signing-related and fixed in the new version. MYSBootloader 1.5. release pending. Thanks to @Fabien for testing.
    @tekka Is it possible to upgrade MYSbootloader from 1.1 to 1.5 via OTA?
    @jkandasa Technically possible but tricky...
    @tekka Could you please explain the steps. Otherwise on next upgrade I have open all the boxes and play with soldering iron 😞
    @jkandasa Please read about NRWW and RWW flash memory sections of Atmel MCUs. The trick is (in summary) to have RWW section code calling NRWW flash updating procedures in order to same-section code...
    I have decided it is time for me to finally learn how to do OTA uploading so I read though all the posts to learn how to do it. As I was reading through the posts I was thinking how this tool would be also be useful for troubleshooting. I'm not at home so I can't do any testing right now but I was wondering if it's possible to have the MYSController accessing my Ethernet gateway at the same time my controller (Vera) is? It seems like there could be problems with ACK messages but maybe I'm not fully understanding something? What I'd like to do is have this controller running to watch messagew but not have it interfere with normal communications with Vera. Is that possible? Thanks in advance!
    @petewill , I have Vera (lite) + Ethernet GW, and eventually I fire the MYSController in my computer in order to debug / update FW etc. They all live together and in peace 😉 Thanks to @tekka for producing such great tool!
  • @petewill yeah i 2nd that.
    i keep it up to make sure the sensors are sending and then watch the change in vera.
    so no problems running both at the same time for however long you want.
    @rvendrame & @mvader Great, thanks!
    @tekka Do you have any plan of supporting DualOptiboot in the MYSController (not a request, just an inquiry). I believe (at least for myself) that your excellent tool is the best option to instrument OTA and since I have included external flash in my boards I would like to use DualOptiboot for OTA since it provides some "safety" in case RF transmission is shaky.
    I am not saying MYSBootloader is bad in any way, but since it does not need an external flash (which is a good thing), it is more sensitive to RF interference and sometimes I suppose boards will be "soft bricked" in that case.
    @petewill I can also confirm that MYSController can coexist with Vera.
    I use node-red to abstract things. In my case, I want the Vera (and MYSController) to be left in the dark on how my controller is actually implemented and node-red is the ideal tool to do this.
    This is my "flow"
    upload-15f178c5-b7e4-4216-b469-301b48dcc060
    Using it, I can have either a serial or an ethernet gw without the controllers knowing.
    Instead, I create network serial pipes using socat that the controllers connect to.
    I can also filter out the debug prints from the gw if I want to examine something and also prevent them from "disturbing" the controllers (if they do not explicitly support the debug messages or gets bogged down by them).
    I still need to see if the node-red nodes support OTA since they key packets on '\n' currently which is not really "binary friendly" though, but for normal MySensors operation not involving binary streams, it works just fine 🙂
    @Anticimex The latest MYSController release supports DualOptiboot, simply check the sensebender board option (node tree, right click). Besides that, MYSBootloader will not leave you with a "soft-bricked" node but rather with a slower OTA update time in the case of RF interferences. If the OTA update fails for whatever reasons (loss of connection, power issues, etc.) MYSBootloader will re-request the FW during the next power-up. Since many community members do not have an external flash option, a slightly longer down-time for the direct update should not cause any problems. Importantly, a faulty sketch with the DualOptiboot update (e.g. no regular gw.process() calls) will result in a real "soft-bricked" node. In the end, both OTA update options have their (dis)advantages, a hardware configuration w/o external flash will only work with offline OTA updates.
    @Anticimex Thanks! Looks like I have some more reading to add to the list. Node-Red looks cool but well beyond my current knowledge...
    I thought this may have been a fluke or something. but tonight i tried to OTA a mysensors sensebender board and ran into the same issue basically.
    i get to some random point 60 or 70 % and then it just stops.
    i moved my sensor right next to the gateway and reset it.
    took off again.. but then stopped at a certain point.
    and i see "firmware 130" a few times but nothing else about firmware.
    the board and gateway continue to function, the sensor sends back temp and humidity etc. but nothing else about firmware. on the left in the gui, it says FW updating. but that never changes.
    i won't post the entire debug log, but just the last part of it so you can see what i'm talking about
    9/29/2015 21:34:44	RX	3;255;4;0;2;82000100DA04
    9/29/2015 21:34:44	TX	3;255;4;0;3;82000100D90421503109410951095695479537952795
    9/29/2015 21:34:44	RX	3;255;4;0;2;82000100D904
    9/29/2015 21:34:44	TX	3;255;4;0;3;82000100D80460E874E88EE190E0A70196010E945F2C
    9/29/2015 21:34:44	RX	3;255;4;0;2;82000100D804
    9/29/2015 21:34:44	TX	3;255;4;0;3;82000100D704EF92FF92CF93DF93EC016A017B01B22E
    9/29/2015 21:34:44	RX	3;255;4;0;2;82000100D704
    9/29/2015 21:34:44	TX	3;255;4;0;3;82000100D6040F91FF90DF90CF900895BF92CF92DF92
    9/29/2015 21:34:44	RX	3;255;4;0;2;82000100D604
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100D5048064808381E090E00F90DF91CF911F91
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100D504
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100D404FC91579760835096ED91FC9151978081
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100D404
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100D304FC915397808180620CC0D6015696ED91
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100D304
    9/29/2015 21:34:45	RX	3;1;1;0;0;75.5
    9/29/2015 21:34:45	RX	3;2;1;0;1;56
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100D204FF4F6083D6015B960C935B975296ED91
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100D204
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100D1040E940D266981EBCF838DE80FF11DE35A
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100D104
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100D004ED91FC915197808185FFF1CFC6016983
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100D004
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100CF04848DF81211C00FB607FCF9CFD6015096
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100CF04
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100CE04038D10E00F5F1F4F0F731127F02EF601
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100CE04
    9/29/2015 21:34:45	TX	3;255;4;0;3;82000100CD045096ED91FC915197808185FD2EC0F601
    9/29/2015 21:34:45	RX	3;255;4;0;2;82000100CD04
    9/29/2015 21:34:46	TX	3;255;4;0;3;82000100CC045B969C915B975C968C915C97981307C0
    9/29/2015 21:34:46	RX	3;255;4;0;2;82000100CC04
    9/29/2015 21:34:46	TX	3;255;4;0;3;82000100CB04CDB7DEB76C0181E0D60158968C935897
    9/29/2015 21:34:46	RX	3;255;4;0;2;82000100CB04
    9/29/2015 21:34:46	TX	3;255;4;0;3;82000100CA04CF92DF92FF920F931F93CF93DF931F92
    9/29/2015 21:34:46	RX	3;255;4;0;2;82000100CA04
    9/29/2015 21:34:46	RX	3;255;3;0;0;59
    9/29/2015 21:34:46	TX	3;255;4;0;3;82000100C904EDCFCE010E940D26E7CFDF91CF910895
    9/29/2015 21:34:46	RX	3;255;4;0;2;82000100C904
    9/29/2015 21:34:46	TX	3;255;4;0;3;82000100C804F5CF808185FFF2CFA889B9898C9185FF
    9/29/2015 21:34:46	RX	3;255;4;0;2;82000100C804
    9/29/2015 21:34:46	TX	3;255;4;0;3;82000100C70405C0A889B9898C9186FD0FC00FB607FC
    9/29/2015 21:34:46	RX	3;255;4;0;2;82000100C704
    9/29/2015 21:34:47	TX	3;255;4;0;3;82000100C604EC01888D8823C9F0EA89FB89808185FD
    9/29/2015 21:34:47	RX	3;255;4;0;2;82000100C604
    9/29/2015 21:34:47	TX	3;255;4;0;3;82000100C504F389E02D80818F7D80830895CF93DF93
    9/29/2015 21:34:47	RX	3;255;4;0;2;82000100C504
    9/29/2015 21:34:47	TX	3;255;4;0;3;82000100C4048C9180648C93938D848D981306C00288
    9/29/2015 21:34:47	RX	3;255;4;0;2;82000100C404
    9/29/2015 21:34:47	RX	3;1;1;0;0;75.5
    9/29/2015 21:34:47	RX	3;2;1;0;1;56
    9/29/2015 21:34:47	TX	3;255;4;0;3;82000100C3048F739927848FA689B7892C93A089B189
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100C304
    9/29/2015 21:34:48	TX	3;255;4;0;3;82000100C204A80FB11DA35ABF4F2C91848D90E00196
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100C204
    9/29/2015 21:34:48	TX	3;255;4;0;3;82000100C104692781110C9400000895FC01848DDF01
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100C104
    9/29/2015 21:34:48	RX	3;1;1;0;0;75.5
    9/29/2015 21:34:48	RX	3;2;1;0;1;56
    9/29/2015 21:34:48	TX	3;255;4;0;3;82000100C00497E2892B49F080E090E0892B29F00E94
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100C004
    9/29/2015 21:34:48	TX	3;255;4;0;3;82000100BF049F73928F90E008958FEF9FEF089589E6
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100BF04
    9/29/2015 21:34:48	TX	3;255;4;0;3;82000100BE04828DDF01A80FB11D5D968C91928D9F5F
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100BE04
    9/29/2015 21:34:48	TX	3;255;4;0;3;82000100BD048FEF9FEF0895FC01918D828D981761F0
    9/29/2015 21:34:48	RX	3;255;4;0;2;82000100BD04
    9/29/2015 21:34:49	RX	3;255;3;0;0;60
    9/29/2015 21:34:49	RX	3;255;4;0;2;130
    9/29/2015 21:34:49	RX	3;1;1;0;0;75.6
    9/29/2015 21:34:49	RX	3;2;1;0;1;56
    9/29/2015 21:34:49	RX	3;1;1;0;0;75.5
    9/29/2015 21:34:50	RX	3;255;4;0;2;130
    9/29/2015 21:34:50	RX	3;1;1;0;0;75.6
    9/29/2015 21:34:50	RX	3;2;1;0;1;56
    9/29/2015 21:34:51	RX	3;1;1;0;0;75.5
    9/29/2015 21:34:51	RX	3;2;1;0;1;56
    9/29/2015 21:34:51	RX	3;255;4;0;2;130
    9/29/2015 21:34:58	RX	1;1;1;0;0;72.8
    9/29/2015 21:34:58	RX	1;2;1;0;1;58
    9/29/2015 21:35:55	RX	3;1;1;0;0;75.3
    9/29/2015 21:35:55	RX	3;2;1;0;1;56
    9/29/2015 21:36:02	RX	1;1;1;0;0;72.8
    9/29/2015 21:36:02	RX	1;2;1;0;1;58
    9/29/2015 21:37:06	RX	1;1;1;0;0;72.9
    9/29/2015 21:37:06	RX	1;2;1;0;1;58
    9/29/2015 21:38:03	RX	3;1;1;0;0;75.0
    9/29/2015 21:38:03	RX	3;2;1;0;1;57
    9/29/2015 21:38:10	RX	1;1;1;0;0;72.9
    9/29/2015 21:38:10	RX	1;2;1;0;1;58
    9/29/2015 21:38:58	RX	2;1;1;0;0;72.1
    9/29/2015 21:39:07	RX	3;1;1;0;0;74.9
    9/29/2015 21:39:07	RX	3;2;1;0;1;57
    9/29/2015 21:39:14	RX	1;1;1;0;0;72.9
    9/29/2015 21:39:14	RX	1;2;1;0;1;58
    9/29/2015 21:40:03	RX	2;1;1;0;0;72.2
    9/29/2015 21:40:03	RX	2;2;1;0;1;55
    9/29/2015 21:40:11	RX	3;1;1;0;0;74.8
    9/29/2015 21:40:11	RX	3;2;1;0;1;58
    9/29/2015 21:40:17	RX	1;1;1;0;0;72.9
    9/29/2015 21:40:17	RX	1;2;1;0;1;58
    9/29/2015 21:41:15	RX	3;1;1;0;0;74.7
    9/29/2015 21:41:15	RX	3;2;1;0;1;58
    9/29/2015 21:41:21	RX	1;1;1;0;0;72.8
    9/29/2015 21:41:21	RX	1;2;1;0;1;58
    9/29/2015 21:42:18	RX	3;1;1;0;0;74.6
    9/29/2015 21:42:19	RX	3;2;1;0;1;58
    9/29/2015 21:42:25	RX	1;1;1;0;0;72.9
    9/29/2015 21:42:25	RX	1;2;1;0;1;58
    9/29/2015 21:43:22	RX	3;1;1;0;0;74.6
    9/29/2015 21:43:22	RX	3;2;1;0;1;58
    9/29/2015 21:43:29	RX	1;1;1;0;0;72.9
    9/29/2015 21:43:29	RX	1;2;1;0;1;58
    9/29/2015 21:44:26	RX	3;1;1;0;0;74.4
    9/29/2015 21:44:26	RX	3;2;1;0;1;56
    9/29/2015 21:44:33	RX	1;1;1;0;0;72.9
    9/29/2015 21:44:33	RX	1;2;1;0;1;58
    9/29/2015 21:45:23	RX	2;1;1;0;0;72.1
    9/29/2015 21:45:23	RX	2;2;1;0;1;54
    9/29/2015 21:45:30	RX	3;1;1;0;0;74.2
    9/29/2015 21:45:30	RX	3;2;1;0;1;54
    9/29/2015 21:45:37	RX	1;1;1;0;0;72.9
    9/29/2015 21:45:37	RX	1;2;1;0;1;58
    9/29/2015 21:46:27	RX	2;1;1;0;0;72.2
    9/29/2015 21:46:28	RX	2;2;1;0;1;54
    9/29/2015 21:46:41	RX	1;1;1;0;0;72.9
    9/29/2015 21:46:41	RX	1;2;1;0;1;58
    9/29/2015 21:47:38	RX	3;1;1;0;0;73.9
    9/29/2015 21:47:38	RX	3;2;1;0;1;53
    9/29/2015 21:47:45	RX	1;1;1;0;0;72.9
    9/29/2015 21:47:45	RX	1;2;1;0;1;58
    @tekka ok, cool! But I installed from the link in the top post last night and I could not find DualOptiboot mentioned anywhere. Is it only by picking a Sensbender board type that option appears? Are there other settings also affected by that? My board(s) are not Sensbenders per se although they should have the same hw features.
    @Anticimex Yes, use Sensebender board for the DualOptiboot option. MYSController will simply initiate the FW upload (assuming that OTA update is uncommented...)
    @mvader please upload the entire log file to check a few things. Also, if the node is next to (or too close) you will get RF interferences (this has been observed for the large antenna and max tx power).
    EDIT: before I forget, also upload the log from the node - this will help to elicit the problem...
  • @tekka I tried from the basement.
    moved up to the fireplace mantel and then finally put it about 1 foot away from the gateway. still the same thing.
    tonight after work i will pull the complete logs and post for your review.
    thanks!
    @tekka I think I might have found a bug (or perhaps this is considered a feature request):
    The GW "version" (1.5) is not shown in the node info although it has sent a response to a version request as shown here:
    upload-59d5fea8-52ae-4f8c-8bfa-bdb9ebac82a2
    upload-fbd28c37-06f4-46d5-bba4-be8e6f6ad412
    Also, I am not sure what the "signing" field is intended for. Showing signing request status? It says "Unknown" for both my GW and my "secure" node. The node require signing and the gw is signing messages sent to it. Perhaps reserved for future functionality?
    Still a great and very useful tool!
  • @mvader said:
    i'm not sure how to grab the log from the node, please advise.
    here is the MYSController debug log in full.
    MySensors_20150930-203313.log
    @tekka MYSBootloader is a great gift for us. With zero touch we can upgrade our firmware in to target board.
    In some cases I want to recompile the source code for 8 MHz or lesser frequency or different boards. As this is not a Arduino code, I do not know how to recompile this software. I hope many people facing issue with recompiling. Could you please add some document how to recompile this source code under https://github.com/mysensors/Arduino/tree/master/MYSBootloader
    Also can you post source code of MYSBootloader 1.5 version?
    Thank you!
    @jkandasa The source code for 1.5 will be available upon release (mid-end October if time allows).
    @mvader For the node log: simply connect a serial adapter to the sensebender node and retrieve the serial output.
    @Anticimex No, not a bug and in the feature request list (I_VERSION handling). The signing field is updated once the node sends its signing preferences.
    @tekka Ok, but then I believe I found a bug, because I have reset my node and it did send its presentation messages, but the field did not update. I'm not at home right now so I can't get you the logs but I will see if I can replicate the steps and send you later on.
    @tekka Thanks for this great tool! I have been using it to monitor my nodes successfully for over a day. It's great. I do have a couple of questions.
    Is there a way to see Variables that are sent from my controller (Vera)? I see the request sent from the node but not the response from Vera. Here is a screenshot. I would expect to see numbers sent back from Vera but maybe I'm missing something.
    Is there a way to send a message to a node that hasn't checked in with the controller yet? I tried to manually type in a Node and Sensor but was unable to. I'd like to be able to send commands to nodes that haven't checked in if possible. For example, if the controller wasn't running for a while but I want to start it up to send a reboot command to a node that is no longer communicating. Or, if I have a relay node that doesn't check in often but I need to change the state.
    Thanks again!!
    No, not to my knowledge - anybody?
    You can manually add a node, but not a sensor: in the node tree view: right click | Add node | enter ID.
    I will add the manual sensor adding to the feature requests.
    @Anticimex Just had a quick look at the library code: if signing is enabled (in the GW), the I_REQUEST_SIGNING message is not published. This field is only updated if signing is disabled (in the GW). However, MYSController will reply with a "signing not supported" message.
    @tekka right. Signing exchange is currently only done in the rf protocol, not to the controller. So are there currently any ways for the controller to populate that field?
    A future addition of a I_CONFIG message is under discussion where node properties such as signing and other things can be published to a controller, so I suppose that field in the ui is for future use then 🙂
    @Anticimex ~yup 🙂
    Great, thanks!
    As for the variables, I don't think I was clear in what I was asking. The variable is a MySensors variable. It just doesn't look like it's picked up by the MYSController. I am doing a horrible job describing this but here is that I see in the log file:
    50	10/02/15 7:30:16.689	luup_log:27: Arduino: Request: 1;2;2;0;24;Front Yard <0x308de680>
    50	10/02/15 7:30:16.689	luup_log:27: Arduino: Requesting status for: 1;2 <0x308de680>
    50	10/02/15 7:30:16.690	luup_log:27: Arduino: Request status for Variable1 <0x308de680>
    50	10/02/15 7:30:16.690	luup_log:27: Arduino: Sending: 1;2;1;0;24;8 <0x308de680>
    I'm not seeing the '8' in the MYSController though. Hopefully that makes a little more sense.
    Thanks again for all the hard work!
    I have to do more testing over the weekend, but i updated my gateway to 1.5, as my nodes where 1.5 but gate was 1.4, the 1st one i tried, worked without issue.
    dont know if it was a fluke/lucky or updating to 1.5 on the gateway solved my issue.. i'll post more as i test more nodes
    The controller receives messages from the GW but does not intercept messages sent from other controllers (due to the architecture). Similarly, messages sent with MYSController won't appear in Vera.
    But this leads me to an interesting idea...let's see 🙂
  • looking for some help with OTA and a sensebender board.
    if i manually reset the board, then it will take the OTA and that works fine.
    however, that's the only way i can get it to work.
    it doesn't respond to a reboot command (I assume this is because it's sleeping)
    and even if i select the battery/sleeping option, when a transmission does come in, it doesn't reset or start an OTA.
    the only way so far is to physically PF the device and then the OTA works.
    what am i missing?
    thanks!
    EDIT: so this does seems to work.. i spent all morning trying to come up with hack-y ways to get this to work.
    using the default sensebender sketch the OTA wait time is set to 300 milli seconds. which is like .3 seconds.
    i changed that 3000 (3 seconds) set the FW and waited for the next transmission..boom off it went (the OTA).
    so for anyone running into this issue. try this solution.
    I cant imagine 3 seconds vs .3 seconds is going to make a huge difference in battery life.
  • Looking for help to interpret log data after an OTA update. I am just learning, and successfully OTA'ed a simple DS18B temperature sketch to a node using MysController. Now I am trying to OTA an DHT22 node (the example sketch in 1.5 version, no changes to it.) The firmware OTA seems to go fine, but the Pro Mini never seems to start. Below is the log, I have bolded the log entries I don't understand. As shown, the first bold section comes right after the OTA. The second 16 minutes later is because I pushed the reset button on the pro mini. Any help understanding the log entry is appreciated.
    10/5/2015 7:04:01 RX 2;255;4;0;2;820001000200
    10/5/2015 7:04:01 TX 2;255;4;0;3;8200010001000C94AE010C94AE010C94ED020C94AE01
    10/5/2015 7:04:01 RX 2;255;4;0;2;820001000100
    10/5/2015 7:04:01 TX 2;255;4;0;3;8200010000000C9486010C94D11A0C94FE1A0C94AE01
    10/5/2015 7:04:01 RX 2;255;4;0;2;820001000000
    10/5/2015 7:04:01 INFO BL version=257
    10/5/2015 7:04:01 INFO Send FW info to node 2: type=82, version=1, blocks=0x0570, CRC=0x9AEC
    10/5/2015 7:04:01 TX 2;0;4;0;1;820001007005EC9A
    10/5/2015 7:04:01 RX 2;255;4;0;0;820001007005EC9A0101
    10/5/2015 7:07:23 RX 24;1;1;0;0;60.5
    10/5/2015 7:07:23 RX 24;2;1;0;1;59
    10/5/2015 7:11:41 RX 24;1;1;0;0;60.5
    10/5/2015 7:11:41 RX 24;2;1;0;1;59
    10/5/2015 7:13:24 RX 23;0;1;0;1;55.7
    10/5/2015 7:15:59 RX 24;1;1;0;0;60.5
    10/5/2015 7:15:59 RX 24;2;1;0;1;59
    10/5/2015 7:18:27 CHILD New child discovered, node id=23, child id=1
    10/5/2015 7:18:27 RX 23;1;1;0;0;63.0
    10/5/2015 7:18:27 RX 23;0;1;0;1;55.9
    10/5/2015 7:20:14 INFO BL version=257
    10/5/2015 7:20:14 INFO Send FW info to node 2: type=82, version=1, blocks=0x0570, CRC=0x9AEC
    10/5/2015 7:20:14 TX 2;0;4;0;1;820001007005EC9A
    10/5/2015 7:20:14 RX 2;255;4;0;0;820001007005EC9A0101
    10/5/2015 7:21:50 TX 2;0;3;0;13;0
    10/5/2015 7:23:32 RX 23;0;1;0;1;56.0
    10/5/2015 7:24:26 RX 24;3;1;0;24;78
    Oh, sorry. I thought it did. I can see my light (relays) messages when turning on/off with my Vera but maybe that's the ACKs?
    @novicit The bold section is the bootloader sending/requesting the current node configuration. Did you set a static node ID in your sketch?
  • @tekka Thank you for your response. The sketch does not have a static ID - the line is "gw.begin();" So it should receive a node ID. I had MysController set to "AutoID" and it successfully issued the next free ID, which was 2. How would I test further to see why it does not begin execution. (I am using ethernet gateway with authentication, but the configuration is set to 'false', so a node not asking for Atsha response does not get one. Other non-atsha nodes work fine-as shown in the log. Don't know if this would make a difference.)
  • @tekka, In thinking about your question .... As the sketch begins execution after OTA'ing, it then asks for a node id to be issued (even though it has received one from the MysController) - and since I am using an ethernet gateway (& Domoticz) which does not automatically issue a node ID, the pro mini just sits there and waits for a node id? Would it then work if I put in a static node ID, even if it is different than the one issued by Myscontroller? And the node then adopts the static ID. ??
  • @tekka I tried 2 new nodes with static id assigned [gw.begin(incomingMessage, 21, false);] and [gw.begin(NULL, 23, false);] ---- still same frozen response.
    10/5/2015 17:18:46 TX 3;255;4;0;3;1400010000000C9486010C94D81A0C94051B0C94AE01
    10/5/2015 17:18:46 RX 3;255;4;0;2;140001000000
    10/5/2015 17:18:47 INFO BL version=257
    10/5/2015 17:18:47 INFO Send FW info to node 3: type=14, version=1, blocks=0x0570, CRC=0xE30B
    10/5/2015 17:18:47 TX 3;0;4;0;1;1400010070050BE3
    10/5/2015 17:18:47 RX 3;255;4;0;0;1400010070050BE30101
    10/5/2015 17:20:32 RX 1;0;1;0;0;19.5
    and:
    10/5/2015 16:59:29 TX 2;255;4;0;3;1400010000000C9486010C94D11A0C94FE1A0C94AE01
    10/5/2015 16:59:29 RX 2;255;4;0;2;140001000000
    10/5/2015 16:59:29 INFO BL version=257
    10/5/2015 16:59:29 INFO Send FW info to node 2: type=14, version=1, blocks=0x0570, CRC=0x2E9E
    10/5/2015 16:59:29 TX 2;0;4;0;1;1400010070059E2E
    10/5/2015 16:59:29 RX 2;255;4;0;0;1400010070059E2E0101
    10/5/2015 17:00:59 RX 24;1;1;0;0;62.8
    Any idea what the nodes are waiting for?
    I also reset the gateway to see if it sent anything that cleared the freeze, but no response. Hmmm.
    @novicit Can you temporarily use a serial gateway with debug enabled and upload a debug-enabled sketch to see what's going on on both sides? Please post the node and gateway log for further hints.
  • Can I set up Hydroponic Greenhouse automation with MYSController???
  • @tekka just wondering.. is there anywhere a documentation how the OTA works?
    I'm currently trying to write a little perl-script with OTA support and had a hard time misreading the source code of the MYSController and OTABootloader.
  • @tekka, problem solved! I took a debug log from the node per your suggestion and was surprised to get:
    radio init fail
    radio init fail
    radio init fail
    This of course surprised me after it just finished downloading 20kb+. Turns out after I made the first test of OTA which worked fine, my home network automatically synchronized my laptops & desktop. This brought over a copy of myconfig.h which had softspi enabled! (I had been setting up the gateway on a different computer). So when I went to OTA on the second and third nodes it picked up the synched myconfig.h. Ugh, such little strange things that take so much time to find.
    @tekka, my apologies for using some of your time. And my Thanks for your great work and sharing with the community!! Hopefully others will avoid similar mistakes by reading this.
    Hi @tekka , I'm trying to create a simple thermostat device and I'm usually using your fantastic controller for prototype testing and debugging. Now I would need the possibility to send setpoint values from the controller and the current version of MYSController does not seem to support the following:
    V_HVAC_SETPOINT_COOL 44 HVAC cold setpoint S_HVAC
    V_HVAC_SETPOINT_HEAT 45 HVAC/Heater setpoint S_HVAC, S_HEATER
    V_HVAC_FLOW_MODE 46 Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn") S_HVAC
    I would greatly appreciate it is these features were implemented to your fantastic controller also.
    Best regards,
    Tomas
  • sorry if this has been asked before.
    but I have a nano with mySbootloader installed and when i look at it in the serial monitor its just all gibberish.
    i tried different speeds, but still the same.
    is it not possible if you have that bootloader installed? or do i need to do something else.?
    thx
    @korttoma is implemented in 0.1.2.284 - release pending
    @mvader this is not related to MYSBootloader. Try doubling the baud rate setting, i.e. 230400....
    @tekka Would it be possible in a future version to have the controller save the detected network nodes? Right know, I have to re-present the nodes in order for them to appear properly in the tree every time MYSController is restarted since it starts up with an empty tree.
  • Hi @tekka , I've gone through the steps in your guide using MQTTGateway as gw sketch.
    When I start my new node (burned with mysbootloader) I only see the repeating message "FIND_PARENT" in MySensor Debug window and "RX 0;0;3;0;9;read: 0-0-255 s=255,c=3,t=7,pt=0,l=0,sg=0:" in the MYSController Debug window.
    The message appears every time the led is blinking on the node (approx every 2 seconds).
    Any idea why it doesn't request node id? Have also tried with AutoID without success.
    Thx!
    @Anticimex is implemented in the upcoming release 🙂
    @rubal MYSController does not support MQTT gw. Please use a different controller or change to a serial/tcp gw.
    @tekka sweet! Any ETA on the next release?
    @Anticimex wanna beta-test? 😉
    @tekka for sure 🙂
  • @tekka - i do 🙂 i use it every day
    @cdr said:
    I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
    I think I am running into the same thing. How did you fix this? I have many nodes so switching back to 76 is not a good option for me.
    You can edit myconfig.h and have te recompile after change.
    @cdr I've never recompiled a bootloader before but when I did some searching it seems that I need the .c file to do this. Maybe I'm missing something and I can recompile the .hex? How did you end up doing it? Thanks!
    I did some more testing and my issue definitely appears to be a result of changing the channel in MyConfig.h. I just built a serial gateway with channel 76 selected and everything worked perfectly. The only problem is I have over 20 nodes located throughout my house so re-uploading the code so they use that channel is not something I'd like to do if I can avoid it. Does anyone know how I can recompile the bootloader so I can change the channel?
    I tried the files @siklosi posted here http://forum.mysensors.org/topic/2319/how-to-make-complie-mysbootloader/7 but it did not work.
  • in firmware_config.csv file what is the first column "type" for? And where do I get "type" codes?
    @niccodemi type can be any numeric value used to identify a specific firmware type - this value (together with FW version and the FW CRC) is used to automatically update the nodes.
  • @petewill did you have any success finding out how to change default channel?
  • I recently switch to RFM69 and I know it's not yet compatible with MYSBootloader. But I can't find information about RFM69 and dualoptiboot support for OTA in MYSController (without a sensebender). Is it possible ? I have to make special config ? Thank !
    @Fabien DualOptiboot is completely radio agnostic. You should not need any custom config to use OTA with DualOptiboot and rfm69. You do need an external flash on your board though.
  • @Anticimex ok but in MYSController is there a way in the GUI for setting the bootloader (DualOptiboot or MYSBootloader) or is ti automatic. I ask this because you have to tell MYSBootloader your are running SenseBender (DualOptiboot).
  • 6
  • 6
  • 198
  • 13
