  • Hi Everyone !
    Big thumb up for the amount of work supplied !!!
    After being more or less successful with openHAB1 I had a go with openHAB2 today, via a online install....
    But no success with the "mysGateway" install : should i go back to serial gateway with an arduino ?
    Thanks a lot for your help
  • @ben999 try again, because it works great. I assume by online install you mean apt-get; I too had trouble when trying this. However, I tried again following @TimO instructions here:
    wiki, then everything came up nicely. I feel it is some permission issue that I have not tried to figure out yet.
  • Code Contributor
    @ericvdb when running as a service, debug messages are masked and aren't shown in the system logs, but it would be a good idea to have a way to connect to gateway perhaps using telnet and watch the logs. I'll work on something.
  • @carlyler
    Thanks a lot for your message, hope is back on my side 🙂
    Actually I had a go with openHABian (i didn't make it clear in my previous message, sorry)
    The install itself couldn't be easier : OS+openHAB installed in one go, just by formatting SD Card with a tiny img file. One hour later and voilà !
    So that could be the source of my trouble?
    I will go with the link you supplied tonight and let you know (lookslike it is a manual install... scary!!)
    Thank you again for your support
  • @ben999 if you have not already, read through the MySensors OH2 thread. I noticed a recent post by @TimO that talks about setting some permissions and that might be the issue. Otherwise, the manual install is not bad as he gives you step-by-step; I am a new to all this and managed to get it to work...
  • @carlyler
    Smashing
    Thanks a lot for that hint... I remember reading that...
    Linux is so damn rigid 😆
    Thank you again for your help
  • Either its not stated or I cannot see it, but i was wondering... Is this version 2 voor de rPi?
    At the moment I am using MySensors version 1.5 with Pimatic as controller. And I would like to use v2.
  • @ben999 Yes, version 2
  • I feel a bit sorry to come back here for my own little troubles...
    1- So i installed openhab2 on RPi3 with a fresh SDCard
    2- I followed tobof 's excellent step-by-step howto
    3- I installed mysGateway
    4- With pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that my motion sensor and my RPi gateway get on well... they do speak to each other, right ?
    mysGateway: Starting gateway...
    mysGateway: Protocol version - 2.0.1-beta
    mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
    mysGateway: TSF:LRT:OK
    mysGateway: TSM:INIT
    mysGateway: TSM:INIT:TSP OK
    mysGateway: TSM:INIT:GW MODE
    mysGateway: TSM:READY
    mysGateway: MCO:REG:NOT NEEDED
    mysGateway: MCO:BGN:STP
    mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
    mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
    5-in things/demo.things" I put this.
    Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {  }
    Right away, it worked (king of the world!) and i could see that bridge in paperUI !!!
    But i got that after a reboot of RPi
    openhab> Failed to connect on port: /dev/pts/2 exception:
    gnu.io.NoSuchPortException
            at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
            at gnu.io.NRSerialPort.connect(NRSerialPort.java:48)
            at org.openhab.binding.mysensors.protocol.serial.MySensorsSerialConnection.<init>(MySensorsSerialConnection.java:52)
            at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:63)
            at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
            at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
            at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
            at java.util.concurrent.FutureTask.run(FutureTask.java:266)
            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
            at java.lang.Thread.run(Thread.java:745)
    Wrong serial port ?
    Juste to make it clear : mysGateway bit of software is the magic that makes RPi believe that there's an arduino acting as a gateway on USB and collects the NRF24 info through GPio ?
    @ben999 said:
    Wrong serial port ?
    Likely 😉
    /dev/pts/x are pseudo-terminals , not serial ports.
    On my (old) Pi running Raspbian the serial port is /dev/ttyAMA0
    You could run something like
    dmesg |grep -i tty
    to get an idea of serial ports on your Pi.
  • @Yveaux thanks a lot for your answer. Understanding linux is a slow and painful process 😆
    Here is the output from your command : dmesg |grep -i tty
    pi@raspberrypi:~ $ dmesg |grep -i tty
    [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xcc3e67e3 smsc95xx.macaddr=B8:27:EB:3E:67:E3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.001337] console [tty1] enabled
    [    1.772114] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
    What a mess...
    ttyAMA0 is the one !!!
    Thanks @Yveaux you got me on the right path !!! Goto next step! 😄
  • I just did a fresh install of pimatic and MsGateway on the pi. But pimatic does not seem to get de messages. i started the gateway via the daemon method, is there a way to see if the sensor is reaching the gateway?
  • @b0rmann
    Do you still using the rs485 usb "dongle" to connect the rs485 nodes to the rpi? Do you attached some more nodes to your rs485 rpi Gateway?
    Is it stable?
    How do you do the configuration for it?
  • Code Contributor
    @JahFyahh To view messages being exchanged with the sensors, run the gateway in debug mode:
    mysGateway -d
  • @marceloaqno thank you for the reply, I tried that and I receive "mysGateway: acce[t: Bad file descriptor" Any idea what this means?
  • Code Contributor
    @JahFyahh Could you provide the full debug log?
  • Hi team,
    First of all, thanks for this amazing project and this doc.
    I'm trying to use arduino nanos with Raspberry Pi 2 as a gateway: I can get it working when I configure the Raspberry Pi using serial gateway, however, it does not work using MQTT with latest version from git.
    The error message is:
    "mysGateway: accept: Bad file descriptor"
    I followed all explanations given on this page.
    Any idea?
    Thanks again
  • Code Contributor
    @manul Which MQTT broker are you using? Did you try to update it?
  • I wanted to use the mysGateway with a USB/RS485 converter.
    Here is my config: ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 my-rs485-baudrate=57600
    make does it's job, but after i start the gateway it says:
    mysGateway: Starting gateway....
    mysGateway: MCO:BGN:INIT GW,CP=RSNG---,VER=2.0.1-beta
    mysGateway: TSM:INIT: GW Mode
    after that it stopped to work.
    Whats wrong in my configuration?
  • Code Contributor
    @hausinger Have you checked if /dev/ttyUSB0 is receiving any data?
  • Code Contributor
    The RPi port has just received a new update that changes some important things related to the location and name of the gateway binary and services:
    mysGateway was renamed to mysgw
    mysgateway service was renamed to mysgw
    Now, after successfully running the make command, you will find the gateway file under ./bin/mygw
    Also, before installing the new version you need to manually remove the old one:
    If you are using systemd
    sudo systemctl disable mysgateway.service
    sudo rm /etc/systemd/system/mysgateway.service
    sudo rm /usr/local/bin/mysGateway
    If you are using sysvinit
    sudo update-rc.d -f mysgateway remove
    sudo rm /etc/init.d/mysgateway
    Thank you for your answer. I don't know, how to check that? The wiring to my nodes is correct, the serial port is correct (dmesg says that).
    Could you confirm, that my configuration from my last post is correct?
  • Code Contributor
    @hausinger Your configuration is correct. To check the serial, install the screen package (if you haven't already done so) and run:
    screen /dev/ttyUSB0 57600
    You should see some strange characters being printed.
    I did a quick test here with your setup and found out that there is a bug with the gateway when the rs485 baud rate is set to 57600. With 9600 it works fine. I'll try to fix this.
  • Code Contributor
    @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
    It should be:
    ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
    It should be:
    Hi @marceloaqno
    Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
    Did this configuration work on your System?
    Are you sure, that my configuration is ok? (with the "--")
    Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
    I'm now not at home (Business trip), if I get home, i will try your "Screen" command
  • I followed the instruction above to make a mysgw file, but no file was generated.
    @jmmorgan83 do you think there is any information you can share might help us help you?
  • I reset everything and ran it again. It did generate the file this time. Thanks, - Now to test it.
  • Has anyone gotten the raspberry pi gateway to work with Openhab on the same raspberry pi? I have both the virtual and mqtt gateways working, but I can get either one to communicate with Openhab.
  • @hausinger said:
    It should be:
    Hi @marceloaqno
    So I'm at home today and make some Test.
    The screen comand gives me some strange characters, thats ok I think.
    But if i start the Gateway, I only get the same messages as shown in my other post.
    Here are 2 Pics that show you, how it look like.
    I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
  • Has anyone been able to get this to successfully work with a Vera?
  • Have been running MySensors for some time now with a EthernetGW running on Arduino. To clean-up the installation, I'm trying to get the Gateway running on my Raspberry instead but something stops the make process.
    pi@raspberrypi ~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24                       [SECTION] Detecting target machine.
    [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
    [OK] init system detected: sysvinit
    [OK] Finished.
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -c drivers/Linux/log.c -o build/drivers/Linux/log.o
    cc1: error: bad value (cortex-a7) for -mtune switch
    Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
    Any hints what I have done wrong ?
  • Issue solved, manual update of compiler from 4.6,3 -> 4.7.2 enables the make process. Similar problem also reported in post.
    Using
    • sudo apt-get update
    • sudo apt-get upgrade
    does not upgrade compiler. I used instruction according to How to upgrade GCC to 4.7+.
  • @RogerB68 I had the same situation. I have removed the mtune parameter from the config file and compilation went fine. I don't know what it affects though. 🙂
  • I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
  • Code Contributor
    @hausinger After the command:
    sudo ./bin/mysgw -d
    It wasn't supposed to go back to bash, the gateway would wait for new messages.
    I'm not sure what's going on with your setup because I tested your configuration options here and it worked.
  • Code Contributor
    @jmmorgan83 You may need another name for the port, such as
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
  • @marceloaqno
    Unfortunately, no luck:(.
    sudo ./bin/mysgw -d
    Thank you for your answer. What can I do now? Can I check, that this port is unused? And how can I check this?
    Or is there another problem?
  • FYI: I do not think the Rpi gateway works with Openhab on the same unit. I have tried both the virtual serial port and mqtt, and neither will work with Openhab 1.83.
  • Hi all,
    So I built this and all seems to be well. But.....how do I test it properly?
    I also installed pidome and have that able to 'see' the MSYGW, but it advises to only add it if it is working.
    So how to know if mysgw is working OK? Is there somewhere a step-by-step way to do this?
  • @skywatch try to run it with "mysgw -d" .
    Enabling debug mode you can see on console every message and diagnostics...
  • @gtortone
    sudo ./bin/mysgw -d and sudo ./bin/mysgw -h now both give 'command not found' - which is odd as they were both working eariler ???
    A reboot makes no difference. Although after reboot I see mysgw running in 'top' but even stopping that service and trying sudo mysgw -d again doesn't seem to work.
    Any idea whats wrong? Any suggestions to get this going?
  • @skywatch
    if you did
    make install
    the mysgw executable is in /usr/local/bin directory then you have to launch it with:
    /usr/local/bin/mysgw -d
  • @gtortone
    That doesn't appear anywhere on this tutorial, so maybe it needs adding for completion?
    Anyway the output is now......
    pi@PiDomePi:~ $ sudo /usr/local/bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.0.1-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: TSM:READY
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    When i did build install I missed out bit for the leds, can I just re-run the ./config and 'make' then 'make install' again? Or will that cause problems??
    I just think that the lights will be useful in the early stages of getting this running...
    Thanks for the help, no way would I have got that without you! 🙂
  • @skywatch
    You're welcome !
    you can (re)run configure, make, make install when you want,
    but I suggest to stop the mysgw executable before launch "make install"
  • Thank you! 🙂
  • Can I just check that this is OK? .....
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    Can you see any problems here, it seemed to work but I hope to test fully this week, maybe tomorrow.....
  • @skywatch
    Hi, options for "configure" are ok, I suggest you to double check your cabling !
  • What makes you think that the cabling is wrong? - I checked and can't see any problem....can you be less cryptic please? 🙂
  • @skywatch
    I meaning that often is also useful to check cable two (or three) times !
    but if you already did it... ok !
  • Ah, OK then 🙂 - I thought there was something in the console data I posted that meant there was a problem! - Tomorrow to build a sensor and get that going.... Thanks again!
  • hi
    yesterday i tried to build a rpi-gateway but i had trouble to access, after changeing the rights on the port to 777 and group to dialout i could access via
    fhem. and i didn't use the symlink, i used the port directly /dev/pts/0@115200 andthen it works perfectly!
    thanks...
    p.s.: i uses always sudo while make and the other installation commands.
    greets mike
  • Get this error from the gateway installed on Raspberry Pi2 with RFM69 Radio.
    From the IDE it works fine:
    0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    mysgw: Protocol version - 2.1.0-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    From the gateway on the Pi this is the error:
    ./bin/mysgw -d
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=3
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=4
    mysgw: TSM:FAIL:PDT
    Any ideas where I might start looking at?
    Martin
  • Code Contributor
    @martins RFM69 is not yet supported in RPi.
  • @marceloaqno
    OK let me explain better. I've build an arduino serial gateway and connecting it on the uart of the pi. If I do tail -f /dev/ttyAMA0 I can see the messages comming in on the serial interface. However if I run ./bin/mysgw -d I get this error:
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:FAIL:PDT
    This is the configure I used to build it:
    ./configure --my-gateway=serial --my-serial-port=/dev/ttyAMA0 --my-serial-baudrate=38400
    So the RFM69 Radio in not directly on the PI but on the arduino and is used as the serial gateway.
    Hope this clarify it more.
    Regards,
    Martin
  • @marceloaqno
    Issue solved. Domoticz read directly the serial inputs from the arduino that's connected on the PI. I was under the impression that you need a gateway (software) running on the PI to interface with Domoticz.
    Martin
  • Hi there,
    I'm trying to make a gateway on my pi and since the begining i'm stuck!
    Using this: git clone https://github.com/mysensors/MySensors.git
    i get: fatal: unable to access 'https://github.com/mysensors/MySensors.git/': Could not resolve host: github.com
    I tried with sudo too! am i the only one getting this?
    @ewgor "Could not resolve host" means dns is not working on your raspberry pi. Is the network working properly (can you access other web sites from the pi?) http://www.suntimebox.com/raspberry-pi-tutorial-course/week-3/day-5/ seems to have a guide if you need help configuring network settings.
  • (sorry, I hit reply on mfalkvidd's post)
    I have a strange problem:
    I tried to be smart (haha) and updated my Raspberry2 with
    sudo apt-get update
    sudo apt-get dist-upgrade
    This took quite a while and looked successful to me.
    Unfortunately the MySensors Gateway and/or controller setup is not working correctly anymore. For troubleshooting I disabled my controller (MyController running on the Pi and for sniffing also MYSController available on my Windows machine). I stopped the gateway service and manually ran the gateway with -d debug information and get this:
    mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
    mysGateway: Listening for connections on 0.0.0.0:5003
    mysGateway: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:BC
    mysGateway: TSF:MSG:FPAR REQ,ID=7
    mysGateway: TSF:PNG:SEND,TO=0
    mysGateway: TSF:CKU:OK
    mysGateway: TSF:MSG:GWL OK
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysGateway: TSF:MSG:PINGED,ID=7,HP=1
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=11,pt=0,l=17,sg=0:Ernie Giess-O-Mat
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=12,pt=0,l=4,sg=0:0.17
    mysGateway: TSF:MSG:READ,7-7-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=3,c=0,t=30,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=4,c=0,t=21,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:8219.0
    mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:29.66
    mysGateway: TSF:MSG:READ,7-7-0,s=3,c=1,t=38,pt=7,l=5,sg=0:9.0
    mysGateway: TSF:MSG:READ,7-7-0,s=4,c=1,t=34,pt=1,l=1,sg=0:0
    mysGateway: TSF:MSG:READ,17-17-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:FPAR REQ,ID=17
    mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysGateway: TSF:MSG:PINGED,ID=17,HP=1
    mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:10834.0
    mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:3.96
    mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=0,pt=1,l=1,sg=0:67
    mysGateway: TSF:MSG:READ,17-17-0,s=1,c=1,t=0,pt=7,l=5,sg=0:18.8
    mysGateway: TSM:READY:NWD REQ
    mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    mysGateway: TSF:SRT:OK
    Which looks okay to me (2 sensor nodes are sending data here). But after this NWD REQ...STR:OK block nothing more happens, only more of these 3 lines blocks repeat over and over with about 15 minutes or so inbetween.
    "of course" I also re-compiled the gateway source with re-setting the configuration, which is
    sudo ./configure --my-rf24-channel=124 --my-rf24-irq-pin=11  --my-debug=enable
    sudo make install
    any ideas what I can try to make it work again? 😞
    In any case, happy weekend to everyone,
    greetings from Germany!
  • Code Contributor
    @Velo17 It might be related to the nrf24 irq pin. Could you try to build the gateway without the my-rf24-irq-pin option and check if the gateway still behaves this way?
  • @marceloaqno Thanks for the hint! This actually solves the lock up. But shouldnt the interrupt offer a superior connectivity and thus be desireable? Until yesterday (before I did the RPi upgrading) this worked - or at least it appeared to work (I dont know if the interrupt was actually used)
  • Code Contributor
    @Velo17 I had the same problem in the past but I thought it was because of my nrf24 module wasn't properly shielded or my cables was too long, causing some kind of interference to the irq pin.
    I end up disabling the interrupt options until I replace my nrf24 module or rearrange the cables, which I haven't done yet.
    Could you give more details on what kind of nrf module you are using and how it is connected to rpi?
  • Hi everyone.
    I´m trying to build a new homeController with the following parts / software.
    Raspberry Pi 3
    Home Assistant
    MySensors
    Tellstick
    Mosquitto MQTT Broker
    I got everything working beside the MySensors. I´m trying to connect the NRF 24L01+ chip directly to the RPI with help from https://www.mysensors.org/build/raspberry.
    I want to use MQTT between MySensors and HomeAssistant
    The MQTT broker is working when i´m testing it.
    The Mosquitto is configurated with username and Password in the config of Mosquitto.
    The config i´m using when Make Mysensors is the following:
    ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24 --my-rf24-irq-pin=15
    I also changed in the file /examples_linux/mysgw.cpp
    #define MY_MQTT_USER "My User"
    #define MY_MQTT_PASSWORD "My Password"
    When i´m running the command: sudo systemctl status mysgw I got following result.
    ● mysgw.service - MySensors Gateway daemon
    Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
    Active: active (running) since tis 2016-12-27 18:52:34 CET; 25min ago
    Main PID: 1405 (mysgw)
    CGroup: /system.slice/mysgw.service
    └─1405 /usr/local/bin/mysgw
    dec 27 19:18:10 HomeAssistant mysgw[1405]: failed to connect
    dec 27 19:18:10 HomeAssistant mysgw[1405]: socket: Too many open files
    When trying to run command sudo mysgw -d it shows following info in a endless loop:
    mysgw: connected to 127.0.0.1
    Please help figure this out.
    //PeTi
  • Hello
    The past two days I've been trying to setup the gateway on my RPi 2 with domoticz.
    Here's what I did.
    I installed domoticz onto my raspi, then I tried the install the gateway.
    cd MySensors
    Afterwards I did the following
    make
    sudo ./bin/mysgw -d
    Then it seems to start normally onto the point where it refuses to connect to anything.
    Does anyone have a clue what's going wrong?
    I can't seem to figure it out. I've tried it several times over, and always go similar results.
    I was using GertSanders's connector for the RPi Hub and I've tried it with normal wiring too.
    As far as I can see it shouldn't be a wiring problem...
    0_1482936624899_upload-edfa86af-fd0c-4e63-be7b-5393e20f27eb
    EDIT:
    !UPDATE!
    I think I just fixed it. I reconfigured it to include the IRQ Pin and now it's just listening for throughput
    pi@raspberrypi:~/MySensors $  sudo ./bin/mysgw -d
    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
  • I got the previous problem out of the way for now...
    Now onto the next one.
    I started a node and now I can clearly see data being sent and received on my serial log and ssh. (See picture)
    0_1482941358792_upload-08fe5f75-3536-4fb5-a0f4-2ee7d0edbc6a
    So I tried adding the gateway to domoticz using following settings:
    0_1482941417649_upload-ce92a80a-a5aa-4713-bfe8-227c71b8ce72
    Yet if I check hardware setup I can see no nodes being presented.
    0_1482941455435_upload-e36e2fbf-ac80-4381-895d-293e6e638ead
    Are there settings or steps I missed?
    Greetings
    Flor
  • @Flor-Sanders I think you maybe should choose not USB but Ethernet gateway in domoticz.
  • @Tigroenot
    That fixed it indeed XD
    Thanks for helping me out
  • Code Contributor
    @pettib Could it be that you are using an old version of Mosquitto?
    mosquitto -h
  • @marceloaqno
    How so?
    I've tried running the command you've supplied, but it doesn't work... Do I have to install mosquitto?
    I didn't see it anywhere in the guide.
    Everything is working at the moment, you think it can pose a problem later?
  • Hello everyone,
    I've been working gateway on RPi, but I don't know how to configure MY_SIGNING_SOFT .
    File mysgw.cpp contains MY_SIGNING_SOFT definition and I can uncomment it, but I don't know where and how I should define: SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY ?
    Could you give more details how to configure soft signing on RPi?
    thanks
    //Robert
  • Has anyone successfully built on an Orange Pi One running armbian? RPi running raspbinan is supported, but on my Orange Pi One running armbian I get
    ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
    I already have TMRh20's RF24 code running on this system, so I know it's capable.
  • @aand
    working on the same setup, unfortunately was not able to compile the mysensors gateway...
    this is the error i get:
    root@orangepizero:~/MySensors# make
    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DMY_IS_SERIAL_PTY -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
    from ./MySensors.h:294,
    compilation terminated.
    seems spi is missing...
    however it seems to be available in the system:
    root@orangepizero:~/MySensors# ll /dev/spidev0.0
    crw------- 1 root root 153, 0 Dec 30 16:26 /dev/spidev0.0
    root@orangepizero:~/MySensors# dmesg | grep -i spi
    [ 0.814155] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
    [ 0.814185] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
    [ 0.815261] spi spi0: master is unqueued, this is deprecated
    setup:
    Orangepi zero
    Armbian
    hope that we get native OPI support soon, any way all help is appreciated!!
    kind regards,
    Tag
  • @aand said:
    Orange Pi One
    @aand
    I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?
    Seems ready state of the nrf24 board is needed in the moment to build/make the compilation of that module for the myGateway.
    We have any chance to run any Raspbian version (not armbian) on OPI ?
    Sure have so much differences about raspbian and armbian to aply same softw installation methods on both without adaptat in each case.
    Im so interesed too for use OPI One like my HA Controller and MQTT Gateway, so will be really good if you can post here any evolution and impressions about using OPI for that.
  • jirm daid "I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?"
    nrf24l01 radios WORK FINE on the Orange Pi One running armbian.
    I downloaded TMRh20's RF24 GitHub files and successfully tested the Linux example code "gettingstarted" in which an Orange Pi One (tx) sent data to another Orange Pi One (rx).
  • @aand.
    No dubt that NRF24 is detected and working on Armbian, but seems not properly detected on the build module process for the gateway installation process made for Raspbian. Sure because OS diferences from Raspbian and Armbian, raise this issue.
    Why not directly use Raspbian on OPI to avoid that and sure other issues that will by found because all software are mainly build for Raspberry (Raspbian OS) and that is the only well tested?
    I see Raspbian is available and updated for OPI trough his manufacturer.
    http://www.orangepi.org/downloadresources/orangepipc/oragepipc_e930546e866b23585721e5d2a6.html
    Regards
  • @jirm Thanks for the suggestion. I've downloaded the raspian image. To duplicate the path I used with armbian, I downloaded TMRh20's RF24 code so I can test the radio with code I've already had up and running on the hardware.. However, this version of raspbian is really bad. So far nothing compiles. Regular raspbian, and armbian on the orange pi one do not have this kind of problem out of the box; they compile a wide range of packages. I'll spend some more time on it to be diligent, but this distro looks like it needs to be put on the abandon pile.
    I tried compiling mysensors gateway too but no luck with that yet either. This is what I get:
    ./configure
    [OK] Finished.
    make
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
    DIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log
    cc1: error: bad value (armv8-a) for -march switch
    cc1: error: bad value (cortex-a53) for -mtune switch
  • @aand
    Ok. Arrrggg ! .
    So sad ear that OPI Raspbian fork is too not working out the box and but its not surprise because the poor software support form manufacturer. Maybe this is another no way road.
    So seems only keep fighting with both OS (arm and rasp) to make it working.
    Some sugestions ...
    Will be fine if can post this issue but in software section here on mysensors forums. Maybe some mysensors gateway developers or any linux hack can help to trace the error you have on armbian or raspbian.
    Maybe can find another "no official" OPI Raspbian fork that compile better to mygateway. Maybe post this issue in OPI forums will be good and someone there can help or provide other better Raspbian fork.
    Sadly in this days I dont have time to try install on my OPI´s to help more. 👎
    Regards
  • @aand
    The las error you posted...is not on Raspbian but in Armbian ????
    "gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
    cc1: error: bad value (cortex-a53) for -mtune switch"
    In any case seems this is a gcc compiler error maybe because "wrong" version for that processor...so maybe trying to update gcc compiler can help to avoid that error?
  • @jirm The compiler error was from the raspbian image running on the orange pi one hardware. I installed the image, ran apt-get update and apt-get upgrade, then tried the mysensors installation. The error was unusual enough to stop me in my tracks ... it didn't look like a simple dependency error.
    armbian is not as well known as raspbian, but it is a very good distribution with an active and friendly development team. I like raspbian because it is a mature distro, and that's why I wanted to give it a try when you pointed out it's availability, but armbian is a very good alternative. I like armbian a lot and I hope we can get mysensors to work on it. Armbian also supports some of the newest and exciting hardware like the Nano Pi Neo and the Orange Pi Zero, each with a lot of IoT possibilities (they are very small form factors and low cost).
    As you can tell, I think it's a big win if we can get it working on armbian. I will look for the place you mentioned on the forum that might be a good place to post this issue -- please let me know if you have a suggestion on where it's best to post. And I'd like to thank you for your consideration of this problem.
  • I´m in the same boat as you, because for the moment I choose OPI hardware for my HA (Home Automation) system.
    Agree with you that Armbian is much better OS than Raspbian in general terms and preferably the path to walk through for OPI, but in that case always we walk on a parallel side because Raspbian is today the most prefered OS for IoT on developments because Raspberry is the predominant hardware. So that means in future we need fight each installation.
    In that case, Armbian forums sure is necesary place that can help to solve that problem too, but I think first better post here on mysensors software forums to try to get some more light about that specific error about mysensors gateway install process, and then at least have more info to report to someone that can help in Armbian.
    I'm trying to find some help more about the issues you raise and if you maintain posting updates here will be so good for me and sure for others that can use OPI too now or on future.
    OPI´s I´m sure is in near future a very good hardware (because they're so good relation cost-performance and quality) that mucho more people would choose for next coming IoT projects.
    Regards
  • @aand
    The error you post seems because gcc compiler is not well supporting the processor, so maybe need substitute all gcc compiler version in the OS to solve the issue (that's I wanted say before with update).
    apt-get update/upgrade cannot substituting "any" software to other because doing this only can push to last version the existing installed branch on the yet installed software on the OS.
    So It's not any dependence error it's a gcc compiler error raised for some weird version incompatibility with the hardware installed. Strange error but this is seems means message error you posted. So seems needed reinstall all gcc compiler to avoid that.
    Hope I explain enough...sorry about my bad english 😉
    See you...
  • Can I install mysensors on a openhab installed RPi ?
  • Code Contributor
    @Robinek70
    $ sudo mysgw -h
    Usage: mysgw [options]
    Options:
    To generate a soft hmac key, run:
    sudo mysgw --gen-soft-hmac-key
    and set it using:
    sudo mysgw  --set-soft-hmac-key=KEY
    For example:
    $ sudo mysgw --gen-soft-hmac-key
    SOFT_HMAC_KEY | 7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
    The next line is intended to be used in SecurityPersonalizer.ino:
    #define MY_SOFT_HMAC_KEY 0X7F,0X3F,0X1A,0X1C,0X1E,0XA3,0X2B,0X72,0XBF,0X4B,0XED,0XE2,0XD1,0X65,0X43,0X97,0X1C,0X26,0X44,0X2F,0X69,0X57,0X21,0X77,0XD9,0XCC,0XDE,0X39,0X3B,0XFB,0X81,0X26
    To use this key, run mysgw with:
     --set-soft-hmac-key=7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
    $ sudo mysgw --set-soft-hmac-key=7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
    The same process applies to generate/set the other key types.
  • Code Contributor
    @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
  • @marceloaqno
    You mean the error posted @aand is because that?
    You mean mysgw use own NRF24 drivers that is not supported on OPI although he have running Raspbian version?.
    In any case, if so will be really fine if mysgw software allowed (or provide information about how to do it) to use any NRF24 driver (ex. TMRh20 fork that is working fine on OPI) and maybe too Hope RFMXX (I´m most interested in this last transceivers) because I think that generally speaking make a rigidly link with a type of hardware is not the best thing that can be done to really give the best functionality to any application.
    Still keep waiting for anyone here than can help to install mysgw softw on OPI.
    Thanks for your information
    Best regards
  • @marceloaqno, Thanks a lot
  • Ditto, @Robinek70 !
    'nuff said.
    Luiz Roberto
  • Code Contributor
    @jirm If you try to use the nrf24h radio you will get the same error as the @Tag post:
    For @aand error, it's what you mention in your early post, a gcc compiler issue.
    MySensors nrf24 drivers uses the SPI interface to drive the module, it's the same driver for all supported platforms (RPi, esp8266, atmega328p, ...), this way it is easier to maintain.
    I understand that it must have been frustrating to find out that it does not work for the OPi but there isn't much I can do to help you. I bought one too, still waiting to arrive.
  • Code Contributor
    @musthafa I'll give it a try. What version of openhab are you using?
  • @marceloaqno
    Thank you for your help here!! would be great to have mysgw on the OPI!
    I am using armbian on a OPI zero, so let me know if you need any further info.
    (Also using an RPI, which runs mysgw with direct connected radio like a charm!)
    Kind regards,
    Tag
  • @marceloaqno said "MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future."
    I wish it worked now, but I don't mind waiting. Just to clarify where I'm coming from -- Orange Pi One hardware running Armbian. Thanks!
    I'll be keeping watching the updates!
  • @marceloaqno
    OpenHab 2
  • @marceloaqno
    Really thanks a lot for your work and very much appreciate you try to help us on our "fight" with the OPI board.
    Sadly in this moment I cannot work because I'm out of time to try install all softw stuff on my OPI and try help much more to push it working with mysgw and so on.
    I don't understand so much why is not working out of the box and the driver issue found and/what hardware communication issue are only on OPI with that similar derived Raspbian OS like Raspberry, and too not understand why cannot work on OPI because that SPI bus issue you say.
    @aand reported nrf24 module work very well with TMRh20 driver, so seems hardware are OK on OPI for the module and I suppose still only discover and hopefully make it work avoiding the driver issue you say to compile properly mysgw softw.
    Anyway, I only hope that anyone can help mainly here to make work mysgw on OPI too, and adapt it to work on Armbian, because OPI is a really good choice for HA controller board and sure in near future much people use it.
    Is there any chance to substitute own nfr24 driver mysgw with the TMR20h, at least for testing purposes on OPI?
    If any mysgw "code" people are reading this maybe can try to help us with some idea to try workaround the compilation issue on OPI.
    Best regards and again many thanks!
    PD: Only for test SPI purposses on armbian this can help (post 248) :
    https://forum.armbian.com/index.php/topic/617-wip-orange-pi-one-support-for-the-upcoming-orange-pi-one/page-9#entry5747
    Only for info, other interesting post about how to make work nrf24l01 module on OPI and armbian:
    https://forum.armbian.com/index.php/topic/3161-orange-pi-one-with-nrf24l01/
    Another one interesting post OPI One with armbian using NRF24 module:
  • Code Contributor
    @musthafa Openhab2 works using mysgw configured as an ethernet gateway. This is the guide I used: https://github.com/tobof/openhab2-addons/wiki
  • Hello.
    I'm also using a orangepi one and wanted to build the gateway on it. But i didn't want to use the nrf24 but a usb to rs485 converter. But if i want to compile it, i get also the same error with the nrf24 and that it is not supporting platform. Why?
    Also if i want to build a serial gateway with a connected arduino on usb port, i got the same error with the nrf24
  • @marceloaqno thank you.
    I have already installed OpenHAB 2 on my RPi. Can I install mysgw on to the same RPi ?
  • @hausinger -- are you running armbian on your orange pi one?
  • 584
  • 110
