My Slim 2AA Battery Node
  • each one goes around a corner and so one wall is partly between the nodes and the gateway and it´s not even concrete. I have one node in my basement attached to an arduino nano and I have no range problems...
    edit:
    Node sktech:
    // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
    // Define Node ID
    #define MY_NODE_ID 4
    //Batterysensor
    int oldBatteryPcnt = 0;
    #define CHILD_ID_BATT 7
    //Kontaktschalter
    //#include <Bounce2.h>
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //Tempsensor
    #include <SparkFunHTU21D.h>
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //tempsensor
    HTU21D myHumidity;
    float lastTemp;
    float lastHum;
    //boolean metric = true;
    //Messages
    //Battery
    // Kontaktschalter
    //TempMessage
    void presentation(){
      sendSketchInfo("Küche Messstation", "2.0", true);
      present(CHILD1_ID, S_DOOR);
      present(CHILD2_ID, S_DOOR);
      //Tempsensor
      present(CHILD_ID_HUM, S_HUM);
      //Battery
    //Setup
      //Serial.begin(9600);
      Serial.println("Hello!");
      //Batterysensor
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
    //Tempsensor
      myHumidity.begin();
      Serial.println("...done!");
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
    //Starte den Loop
      //Batterysensor
      // get the battery Voltage
      delay(1000);
       #ifdef DEBUG
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      //Kontakstschalter 1
      sleep(10);
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temp)) {
        lastTemp = temp;
        Serial.print("T: ");
        Serial.println(temp);
      if (isnan(humd)) {
      } else if (humd != lastHum) {
          lastHum = humd;
          Serial.print("H: ");
          Serial.println(humd);
     Serial.println("Sleep...");
    Gateway sketch:
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    MyConfig.h
     * @file MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    *  Serial and debug options
    // I_DEBUG requests are:
    // V: CPU voltage
    // F: CPU frequency
    // M: free memory
    //#define MY_SPECIAL_DEBUG
    //#define MY_DISABLED_SERIAL
    //#define MY_CORE_ONLY
    #ifdef MY_DISABLED_SERIAL
    #undef MY_DEBUG
     * @def MY_BAUD_RATE
    #ifndef MY_BAUD_RATE
    #define MY_BAUD_RATE 115200
    //#define MY_RADIO_NRF24
    //#define MY_RS485
     * @def MY_NODE_ID
    #ifndef MY_NODE_ID
    #define MY_NODE_ID AUTO
     * @def MY_PARENT_NODE_ID
    #ifndef MY_PARENT_NODE_ID
     * @def MY_OTA_FLASH_SS
    #ifndef MY_OTA_FLASH_SS
    #define MY_OTA_FLASH_SS 8
     * @def MY_OTA_FLASH_JDECID
     * @brief Flash jdecid.
    #ifndef MY_OTA_FLASH_JDECID
    *  Gateway config
     * @def MY_GATEWAY_MAX_CLIENTS
    *  Information LEDs blinking
    // disabled in the gateway.
    // off when blinking
    *  Message Signing Settings
     * @def MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204
     * @def MY_SIGNING_SOFT
    //#define MY_SIGNING_SOFT
    *  RS485 Driver Defaults
     * @def MY_RS485_BAUD_RATE
     * @brief The RS485 BAUD rate.
    #ifndef MY_RS485_BAUD_RATE
    *  NRF24L01P Driver Defaults
     * @def MY_DEBUG_VERBOSE_RF24
     * @def MY_RF24_SPI_MAX_SPEED
     * @def MY_RF24_CE_PIN
    		#define MY_RF24_CE_PIN 4
    		#define MY_RF24_CE_PIN 27
    		#define MY_RF24_CE_PIN 9
     * @def MY_RF24_CS_PIN
    		#define MY_RF24_CS_PIN 15
    		#define MY_RF24_CS_PIN 3
    		#define MY_RF24_CS_PIN 10
     * @def MY_RF24_PA_LEVEL
    #ifndef MY_RF24_PA_LEVEL
     * @def MY_RF24_CHANNEL
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL	76
     * @def MY_RF24_DATARATE
    #ifndef MY_RF24_DATARATE
     * @def MY_RF24_BASE_RADIO_ID
    #ifndef MY_RF24_BASE_RADIO_ID
     * @def MY_RF24_ADDR_WIDTH
     * @brief RF24 address width.
    #ifndef MY_RF24_ADDR_WIDTH
    #define MY_RF24_ADDR_WIDTH 5
     * @def MY_RF24_SANITY_CHECK
    #define MY_RF24_SANITY_CHECK
    //#define MY_SOFTSPI
     * @def MY_SOFT_SPI_SCK_PIN
     * @brief Soft SPI SCK pin.
    #ifndef MY_SOFT_SPI_SCK_PIN
     * @def MY_SOFT_SPI_MISO_PIN
     * @brief Soft SPI MISO pin.
    #ifndef MY_SOFT_SPI_MISO_PIN
     * @def MY_SOFT_SPI_MOSI_PIN
     * @brief Soft SPI MOSI pin.
    #ifndef MY_SOFT_SPI_MOSI_PIN
    *  RFM69 Driver Defaults
     * @def MY_RFM69_FREQUENCY
    #ifndef MY_RFM69_FREQUENCY
     * @def MY_IS_RFM69HW
    //#define MY_IS_RFM69HW
     * @def MY_RFM69HW
    #ifdef MY_IS_RFM69HW
    	#define MY_RFM69HW true
    	#define MY_RFM69HW false
     * @def MY_RFM69_NETWORKID
    #ifndef MY_RFM69_NETWORKID
     * @def MY_RF69_IRQ_PIN
     * @brief RF69 IRQ pin.
    #ifndef MY_RF69_IRQ_PIN
     * @def MY_RF69_SPI_CS
    #ifndef MY_RF69_SPI_CS
     * @def MY_RF69_IRQ_NUM
     * @brief RF69 IRQ pin number.
    #ifndef MY_RF69_IRQ_NUM
    //#define MY_GATEWAY_W5100
    //#define MY_GATEWAY_ENC28J60
    //#define MY_GATEWAY_ESP8266
     * @def MY_PORT
    #ifndef MY_PORT
    #define MY_PORT 5003
    //#define MY_USE_UDP
     * @def MY_IP_RENEWAL_INTERVAL
     * @def MY_MAC_ADDRESS
    #ifndef MY_MAC_ADDRESS
     * @ingroup internals
     * under some form of attack.
     * - LDB (Locked During Boot)
     * @def MY_NODE_LOCK_FEATURE
     * @def MY_NODE_UNLOCK_PIN
    #ifndef MY_NODE_UNLOCK_PIN
    #define MY_NODE_UNLOCK_PIN 14
    /** @}*/ // Node lock group
    #if DOXYGEN
    edit2:
    Now I get this this from the node on my gateway´s serial monitor:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:SANCHK:OK
    and so on...
  • I have ordered the 2.0 boards, they are on their way to my home 🙂
    I'm plannign to use them as :
    • temperature node
    • door sensor
    Am I right ?
    @carmelo42
  • @m26872 said:
    @carmelo42
    Thanks to you for providing us theses files 🙂
    Ok, my mistake (I juste received my 10 MOhm resistor 😉
    Perfect, I just have to wait now for the little yellow packet 😉
  • I have received yesterday my little packet from DirtyPCB 🙂
    11 PCBs, so 33 sensors 🙂
  • @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
  • @carmelo42 yes
  • @jeti said:
    @carmelo42 yes
    I have this serial/usb adapter :
    https://img1.picload.org/image/ldrrddg/deekrobot-isp.png
    Can you tell me how I connect it to my node ? (noob question I guess ... but I don't want to burn my node 😞 )
  • @carmelo42 said:
    @jeti said:
    @carmelo42 yes
    I have found the answer myself with the schematic 😉
    Have you ever tried to power the node with 1 x CR2032 battery ?
    I have tried, but the node doesn't send anything further than 5 meters ...
  • I would like to know if your nodes are working all fine. I have the problem that my nodes freeze after a day or sometimes after a week.
  • @siod my temperature nodes work good, but my relay one doesn't work 😢
    Do you have any logs when it freezes ?
  • @carmelo42 no, unfortunately I don´t have any logs, any idea how to create logs?
    maybe if you keep your node connected to your computer with USB to serial adapter ?
  • mmh, no, that would mean I would have to run my computer for maybe 2 weeks 24/7...
    I guess it has somehting to do with the sleep function, the device seems to nat wake up after a while for some reason
  • So i got the boards and build them and they work perfect.
    One thing i couldn't figure out is why do i get relatively high current consumption, when the node is sleeping i get 1.5mA and not 5.8uA as in mentioned in this post.
    I use 8MHz internal clock and the sleep function and nothing is connected to the node.
    Can someone help?
    @dpressle Can you post the sketch?
  • Thanks, i see its 6.8 uA now, i had something wrong with my measurements 😞
  • It took me a while, but I just figured out how to get a bootloader burned onto the chip and I'm ready to make my slim nodes! Which board type in Arduino IDE do I use to program the chip once I'm using the 6 pin header after it's installed in the PCB?
    @JonnyDev13 Make a new board type by editing "boards.txt". There's an example in the first post.
  • Hi there! I need to buy some PCBs on Dirty PCBs but the URL http://dirtypcbs.com/view.php?share=13847&accesskey= seems broken. Any ideas? Thanks!
    @รอเรือ Apparently they've moved to a new site. Perhaps you can try this link: http://dev.dirtypcbs.com/store/designer/details/m26872/663/myslim2aabatterynodepcbv2-0panelized
    I think you must have a user account and login first. Please report back if it's working or not.
    Edit: Wrong link the first time.
  • Thanks @m26872
    That link didn't work either. However, by browsing all the shared PCBs I found this URL That link is accessible without logging in first.
    @รอเรือ Thanks a lot! All links are now changed.
  • Hey im building my first slim node and i wonder if someone has a sketch for 2 reed switches? i have found the sketch for only 1 reed switch in this thread. Im going to use it for my mailbox. How long do u think it can run on 2x aa batteries?
    Do i have to add 2x 10M resistors? or doesnt it work with external resistors then using more then 1 reed switch?
    @Eawo The example sketch should fit your needs. link Change the pull-ups activation to Low if you use external ones.
    I'd expect battery life 5-10 years depending on things such mailbox opening frequency, use of heartbeat signal, battery self discharge and climate.
    @Eawo Using internal resistors will only give you a few months battery time. One external pull-up for each switch will work and 1M resistors or any arbitrary "high" value is just as good.
  • Thanks
    ok now my problem is uploading the sketch it wont work on 1mhz bootloader i tried both a and b hex and the 2 diffrent Board.txt.
    I get it to work with the 8Mhz breadboard bootloader.
    But then using 1mhz bootloaders it always timesout
  • after a few hours frustration i went donwstars grabbed 2x new atmega328p breadboards and wolla everything works :). I Think i burned my first to putting them in the socket wrong.
  • i have wired everything but it wont work for me 😞 i have solder the 2 reed switch from gnd to d2 and gnd to d3. and ive done the same 2 1m resistors. I can see the node in domotics but no activity then i open and close.
    @Eawo
    The reed switches need to sit between GND and D2 or D3 as you have connected.
    The 1M pull up resistors need to connect between Vcc and D2 or D3.
    This way D2 or D3 are electrically connected to Vcc when the switches are open (pulled high). When the switches close, D2 and D3 get connected to GND.
  • I only come down to 12µA with one reed switch, 1MOhm pullup, 1Mhz bootloader and the binarySwitchSleepSketch. Measured with two different multimeters. This is nearly ten times higher than in the first posting. Changing all internal pullups to LOW doesn't change anything.
    Is there a way to optimize the power consumption or is it "good enough" ?
    @rollercontainer For sub 8uA consumption you need to go to "deep sleep" where the internal timers of the processor are disabled. Only wake up on interrupt. sleep( interrupt1, FALLING, 0);
    @rollercontainer - I just build a slimnode and 13uA is without anything connected what i can reach as well.
    For comparison i aim below 100uA when i do this with pro mini and they last around a year with 2xAA so my guess is 13uA is good enough.
  • @sundberg84: Thanks, so I will stick to my 12µA 🙂
    @AWI: I am using sleep with Interrupt as in this example:
    sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    https://github.com/mysensors/MySensors/blob/development/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino#L120
    @rollercontainer Your sleep looks good. Did you remove this piece of code?
    // Activate internal pull-ups
    Take a look at this thread for a < 1 uA consumption...
  • Since a few months I am very interested in Mysensors and this PCB. I have ordered the PCB and components to build some sensors as for a home security system. For experimental purpose I build one on a breadboard and that is working fine.
    A few days ago I started to solder the components on the PCB. The firs one is working fine, but the next sensors have an issue with the transceiver. After 3 boards failing I soldered one without the transceiver. Then I tested it by holding the transceiver at the board and it was working fine. After soldering the transceiver again a not working board.
    I tested one board by pressing another transceiver on top of the soldered one and I saw some communication in MYSController. The ATMega is still working on the breadboard. The PCB and Breadboard are powered by the same batterypack.
    Before soldering I tested all the transceivers with my breadboard and they are working fine. I am also using an anti-static bracelet.
    What am I doing wrong??
    Have you desoldered one radio to see if it's back alive again? What's your distance to Gateway? Maybe some filtering or antenna effect by your fingers and breadboard? What if you leave a working radio on the breadboard then just connect it with wires to PCB?
  • @m26872
    Distance is about 50cm. They are both on my desk. If testing then I do not tough the sensor. Just when trien pressing a radio an a non function radio.
    I tried to de-solder the radio but did not succeed. Cut the pins, removed them and soldered wires to it. Connected to a new radio. Strange part is that the on very irregular basis message are received in MYSController. Also with a radio which is functioning well on the breadboard
    @aneco - 50cm is a big problem for me! Its to close and the node - gw is having a hard time communicating for some reason. I wish I didnt set my gw up in the workplace where i build because every time im testing some node I have to go to the next room. Maybe you could try this?
    @m26872 - I made this (but with the big motiondec, because my small ones didnt work so well due to clone/copy). Thanks for PCB, instructions and tutorials. Great work!
    Node is running at 13uA without motiondetector attached and 90-95uA with the motion dec attached. Im happy with that and ill see how long the batteries last. When my small motion dec arrive I can just switch over.
  • @sundberg84
    The node on the breadboard is on the same desk and same distance to gateway. The same for my first sensor. And both are working well. Only issue with 4 sensors a soldered afterwords.
    Just remember now that I used for the first sensor other solder. But do not think that this is causing the issue or .....
  • Hello i wonder how you do then you put sensors outside mine stop work after a few hours i guess its becouse its cold here and maybe humitiy? then i take them inside for while it start working again. i think i need a waterprofe case or something
    Well, batteries and components have working temperatures so it depends how cold it gets over there
  • Its one in the garage it is never below 0- C this one was alive the longest the other one was dead in 2-3days and maybe as coldest it was 10- C. I'm starting to think it's something wrong with the gateway
    If you reset either node or gateway, does it go back to work or what?
  • No it doesn't only sometimes
    If it was the gateway you should stop receiving data from other sensors too, right?
  • @AWI said in My Slim 2AA Battery Node:
    Hmm, I noticed, that I have to disable the internal pullups. But instead of removing the lines, I set them to LOW. I will test it without the lines and come back. Thank you @AWI.
  • Ok, just want to give you an update:
    I have 3 sensors running in the moment, initially I planned to run a lot more, but I still have problems with freezing of the sensors. The Sensors ran 2 months now until they were not coummunicating anymore, 1 is still working. I restarted 1 of the freezed sensors and it just came back up and works fine again, I leave the other one "freezed" just to see if it would come up again...
    It´s sad that they are not very reliable but I don´t get what makes them freeze after working quiet good for such a long time (they are reporting every 15 minutes 24/7 and whenever a window is opened/closed).
    I don´t think it´s a temp thing, also power should be no problem, batteries are still about 80 % loaded...
  • Maybe there is something like a counter (variable++) which causes a overflow after two month?
  • No, not really, but if you want to you can check my code:
    // Define Node ID
    #define MY_NODE_ID 1
    #define MY_PARENT_NODE_ID 0
    //Batterysensor
    //Kontaktschalter
    //Tempsensor
    //tempsensor
    HTU21D myHumidity;
    float lastTemp;
    float lastHum;
    //Messages
    //Battery
    // Kontaktschalter
    //TempMessage
      sendSketchInfo("Schlafzimmer Messstation", "2.0");
      //Tempsensor
      //Battery
    //Setup
      //Batterysensor
    //Tempsensor
      myHumidity.begin();
    //Starte den Loop
      //Batterysensor
      delay(1000);
       #ifdef DEBUG
       #ifdef DEBUG
         send(msgbatt.set(batteryPcnt));
      wait(10);
         send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
         send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
     //Tempsensor
      if (isnan(temp)) {
        lastTemp = temp;
        send(msgTemp.set(temp, 1));
      if (isnan(humd)) {
          lastHum = humd;
          send(msgHum.set(humd, 1));
  • @AWI: I am down to 1,3 µA 👍
    my code:
    #define MY_NODE_ID 66
    #include "Vcc.h"
    #define SKETCH_NAME "MySlim2aaBatteryNode"
    #define PRIMARY_CHILD_ID 3
    #define PRIMARY_BUTTON_PIN 3
    const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
    const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
    const float VccCorrection = 3.496 / 3.572;  // Measured Vcc by multimeter divided by reported Vcc
    const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
    Vcc vcc(VccCorrection);
    #ifdef MY_DEBUG
    void before(){
        Serial.begin(9600);
        sendSketchInfo(SKETCH_NAME, __DATE__);
        present(PRIMARY_CHILD_ID, S_DOOR, "Reed Contact");
        int32_t timestamp = millis();
        uint8_t reedState;
        static uint8_t lastReedState = 2;
        static int32_t lastBatteryReport = -report_interval; // for inital report
        sleep(5); // Short delay to allow buttons to properly settle
        reedState = digitalRead(PRIMARY_BUTTON_PIN);
        if ( (timestamp-lastBatteryReport) >= report_interval ) {
          uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
          lastBatteryReport = timestamp;
        if (reedState != lastReedState) {
            // Value has changed from last transmission, send the updated reedState
            send(msg.set(reedState==HIGH));
            lastReedState = reedState;
        sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
    @siod
    Gateway issue? Other sensors working or all down at same time? Do you have a sniffer or listen-only gateway, or heartbeat LED attached to each sensor?
    What's the purpose of the delay(1000)? It usually safer to use wait() or sleep() and perhaps also to deal with the interrupt results first. You could also try level interrupt instead of "change". You're not using indefinite sleep so it shouldn't be a problem, but try anyway..
    @Tim-Abels 👍 that is how you do it
    Be aware that the timer (millis()) is not running during sleep.
    @Tim-Abels
    1.3uA is nice!
    A question about your sketch: Is millis() working because it's an interrupt-only sleep() or have I missed something else? As I recall it millis() stops working when using sleep().
    Edit: Haha. @AWI got it before me! 😄
  • @AWI one step forward, two steps back... Thanks for the hint.
    I guess, I should send battery percentage every 10 interrupts or so. Even if the contact doesn't trigger for a while, I can force it by showing my neighbours my ocd on doors ^^ (knock, knock, knock - Penny!)
    What do you think?
  • Just noticed, that I use another login at home. So, the Tim-Abels is the rollercontainer... Sorry for that.
    @rollercontainer alias @Tim-Abels 😉 Sounds good, although with 1.3uA the battery won't show much variation..
    This is a similar on running on a coin cell (not calibrated). The voltage drop is caused mainly by the bad radio connection (many retries for sending > 10 mA)
    0_1487319381911_upload-02a06ce9-126d-49f2-bbcb-dd01c3cea3d4
  • Maybe its better to measure the voltage every 10 or 100 loops and only send one custom message/alert when its dropped below a threshold. I am using the MQTTClientGateway and Node-Red. In case of a battery-low message, node-red could send me an email with the node name. I will give it a try...
    From https://www.mysensors.org/download/serial_api_20:
    V_TEXT          47 	Text message to display on LCD or controller device 	S_INFO
    V_CUSTOM 	48 	Custom messages used for controller/inter node specific commands, preferably using S_CUSTOM device type. 	S_CUSTOM```
  • Did you considered a tiny solar cell like enocean does?
    https://www.enocean.com/en/enocean_modules/stm-320/
    That would be perfect...
  • searched a bit and found that @ceech already made a harvester with a coin cell.
    http://www.ebay.de/itm/BQ25570-thermal-solar-energy-harvester-/332071662285
    still too big and too expensive in comparison with dozens of alkaline batteries which will run for years, but that is the way to go sometime.
  • @m26872 said in My Slim 2AA Battery Node:
    @siod
    @m26872
    Gateway seems to work fine as the 3rd and still working sensor is still communicating. Also the freezed sensors start communicating after I restarted the sensor, not the GW. So I don´t see a problem with the GW.
    "Do you have a sniffer or listen-only gateway" -sorry, don´t know what this is o0 !?
    I have not attached a heartbeat LED yet, but that´s sth. I could do as a next step...
    The delay (1000) was initially planned to settle the sensors a bit and gie me abetter Battery reading, but as it is not working as it was intended I will delete it in a future update...
    You could also try level interrupt instead of "change" -again, I don´t know what you are talking about here, hope you can help me out.
    Thanks so far!!
    @siod said in My Slim 2AA Battery Node:
    I meant the https://www.mysensors.org/controller/sniffer, but I think it's easier to equip sensors with Radio Traffic LEDs and/or your own heartbeat/error LEDs.
    I suggest you start with deleting or replacing this delay. It could be it.
    I think you had pull-up inputs. Then it's just to replace the CHANGE with LOW in your call to sleep().
    Thanks so far!!
    My personal troubleshooting method in cases like these (and too many others) is just exhaustive use of the good old substitution method. Hw, Sw, entire systems or whatever you can do. 😬
  • deleted - it´s working now, I must have made a mistake... 😊
    edit:
    one strange thing: The sensor should report every 15 minutes (900000 milisecs), but it reports only every 18 minutes. Don´t know why.
  • Hello everybody,
    I´m struggeling with getting the https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
    to work.
    The node registers with the GW, but doesnt submit the tripped reading.
    Not even a permanent on or something. Just nothing. So i dont know how to troubleshoot here.
    The PIR HC-SR505 is functional. I tested it with a testscript on a UNO.
    And the 2AA Slimnode is functional as well. When using the node as a binary switch it works perfectly fine,
    Just the combination 2AA Slimnode and HC-SR505 doesnt work.
    Anybody has an idea ?
    Thanks in advance Komaandy
    Did you check the serial output if you get debug messages?
    @Komaandy please don't double post. Please continue in the other thread
  • Does anybody has a idea why my nodes keep freezing ?
    I build like 5 identical nodes with a PIR and after working fine for a couple of hours at least half of them freeze.
    There is one particular node that is working for 4 days now straight, but all the others are frozen meanwhile.
    I have no idea where to start troubleshooting, as they are all the same ( capacitory, resistors,radios,Atmega328p,batteries,solder,radio,sketch)
    and are all basically within the same radius placed around the gateway. I have other "not battery Slim Nodes" and they never freeze, though running the same sketch.
    Please i need some tips
    Regards
    Komaandy
    @Komaandy - did you try the hardware without the PIR?
  • Do you mean running the node without the PIR ?
    I thought about, I guess i will test it.
    You think the PIR freezes the node ?
    @Komaandy - Yes and Yes 🙂
    Its a good way to debug, remove not crucial stuff to see if it works... one by one and you will figure it out.
    The PIR (depending on which one and what kind of power you are using) might be the problem but hard to say without knowing your setup.
    @Komaandy and @sundberg84 Once again; Please continue in the other thread! Especially since @Komaandy now confirmed that it is this far NOT a generic Slim Node issue. Also, I haven't got any feedback on my reply there, but I assume it didn't work?
  • Hi @Komaandy ,
    unfortunately I must report that I made the same expiriences you made. I am running 5 "My SLim 2AA Battery Node" Sensors from which only 2 really work. The others keep freezing after an hour, a day, are sometimes after a few days. I have still no idea why this is happening, but because of this I stopped building more of the "My SLim 2AA Battery Node" sensors, which is very sad, because it´s an ingeniuous design.
    I am using MQTT and therefore I installed NRF24L01 modules. Some of them are really weak, so I thought that´s the problem: The node does not freeze, it´s just the NRF24L01 that is not sending any info anymore. So I attached a LED to my node to see if it is still alive. Whenever I opened a window the LED must lid. So when I did not got any info from the node I checked if the node is still operational by opening a window and there I noticed when the LED did not lid, that the node was completely frozen. So It was not a wireless connection problem, but the NRF24L01 of course could still be the problem.
    A lot of my investigastions was about figuring out what is happening when entering the sleep mode, because I thought (and still believe) the node is just not waking up from sleep anymore. Unluckily I still did not find a solution.
    Anywhere you said that the none battery driven nodes are working flawlessly, that´s another point I was thinking about. I have one MQTT Arduino Nano device in the basement which is directly powered over USB and I never had problems with it, also the MQTT / NRF24L01 range is awesome.
    But I have no oscillator or anything to check if it a power problem with the "My Slim 2AA Battery Node".
    Maybe you´ll find a solution for your problems which could help me, too. I´m looking forward hearing from you.
    @siod Thanks for your report. Could you please share some more info. Hw/sw versions, nRF-batches, sensors, configs/settings, sketches etc. @Komaandy could only confirm issues with a PIR eqiupped node, but you have a door-switch so I guess it's a potential generic problem then. Let's hope for other reports as to help us narrow down the search.
    I have not yet migrated to MySensors 2.x 😳 , but it's hopefully coming soon. My Slim Nodes from the start of this thread (~ 10 pcs) are still in flawless production.
    @m26872 - I made myself a slim node with a light sensor and a uv-sensor last weekend. Its running latest dev branch and has been working flawless atleast 1 week now.
  • @m26872 First of all: I already got so much help and I am very grateful for that, awesome community!
    I don´t think I will ever find the problem with those sensors and because of the lack of time I have (familiy, work...) I think looking for the problem would take longer than just build a new sensor. And that´s what I will do next: I will just build another node, one step after the other and so I can validate if it maybe is a hardware problem or a code problem. BTW my whole sketch is just a few posts above this one...
    So I will come back after I started over...
  • @m26872
    Hi there,
    im still into troubleshooting, and what i did last was create a "mock up temperatursensor slim node " with this sketch
    , so its really only the node and batteries. But it still freezes 😞
    Hardware i use is :
    -Atmega328p 1Mhz bootloader. // Burnt the bootloader with one Arduino UNO as master and another Arduino UNO on which I replaced the Atmega328p as slave // Arduino as ISP // with the latest Arduino IDE (1.8.2)
    • after burning the bootloader on the bare ATMEGA´s i assemble them on the node and transfer the sketch via FTDI232
    Furthermore i use
    -generic Capacitors and restistors ( specs from your BOM)
    • Kuman nRF24L01 batches ( bought like 30 in a bulk once, but other "nonslimnodes" are working)
      -fresh batteries
    Any help is very aprreciated 🙂 🙂
    * MockMySensors
    #define MY_NODE_ID 123
    #define RADIO_TX_LED_PIN    13  // the PCB, on board LED
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    #define SKETCH_VERSION "v0.5"
    // Define Sensors ids
       S_SCENE_CONTROLLER
    // one at a time.
    #define ID_S_TEMP              7
    //#define ID_S_BARO              9
    //// Lib 1.5 sensors
    //#define ID_S_SPRINKLER         29
    // Global Vars
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    bool metric = true;
    long randNumber;
    #ifdef ID_S_ARMED
    bool isArmed;
    #ifdef ID_S_LIGHT
    bool isLightOn=0;
    #ifdef ID_S_DIMMER
    int dimmerVal=100;
    #ifdef ID_S_COVER
    #ifdef ID_S_TEMP
    #ifdef ID_S_HUM
    #ifdef ID_S_BARO
    MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
    #ifdef ID_S_WIND
    #ifdef ID_S_RAIN
    #ifdef ID_S_UV
    #ifdef ID_S_WEIGHT
    #ifdef ID_S_POWER
    #ifdef ID_S_HEATER
    float heater_setpoint=21.5;
    //  float heater_temp=23.5;
    //  bool heater_status=false;
    #ifdef ID_S_DISTANCE
    #ifdef ID_S_LIGHT_LEVEL
    #ifdef ID_S_LOCK
    bool isLocked = 0;
    #ifdef ID_S_IR
    long irVal = 0;
    #ifdef ID_S_WATER
    #ifdef ID_S_AIR_QUALITY
    #ifdef ID_S_DUST
    #ifdef ID_S_SCENE_CONTROLLER
    char *scenes[] = {
       (char *)"Good Morning",
       (char *)"Clean Up!",
       (char *)"All Lights Off",
       (char *)"Music On/Off"
    int sceneVal=0;
    int sceneValPrevious=0;
    #ifdef ID_S_RGB_LIGHT
    String rgbState="000000";
    //RGB light V_RGB, V_WATT
    #ifdef ID_S_RGBW_LIGHT
    String rgbwState="00000000";
    #ifdef ID_S_COLOR_SENSOR
    //Color sensor	V_RGB
    #ifdef ID_S_HVAC
    //Thermostat/HVAC device
    // NOT IMPLEMENTED YET
    #ifdef ID_S_MULTIMETER
    // V_VOLTAGE	38	Voltage level
    // V_CURRENT	39	Current level
    #ifdef ID_S_SPRINKLER
    #ifdef ID_S_WATER_LEAK
    #ifdef ID_S_SOUND
    #ifdef ID_S_VIBRATION
    #ifdef ID_S_MOISTURE
    #ifdef ID_S_CUSTOM
       // Random SEED
       randomSeed(analogRead(0));
       wait(LONG_WAIT);
       Serial.println("GW Started");
       Serial.print(SKETCH_NAME);
       wait(LONG_WAIT);
       Serial.print("Get Config: ");
       wait(LONG_WAIT);
       // Init Armed
    #ifdef ID_S_ARMED
       isArmed = true;
    #ifdef ID_S_DOOR
       Serial.println("  S_DOOR");
       wait(SHORT_WAIT);
    #ifdef ID_S_MOTION
       Serial.println("  S_MOTION");
       wait(SHORT_WAIT);
    #ifdef ID_S_SMOKE
       Serial.println("  S_SMOKE");
       wait(SHORT_WAIT);
    #ifdef ID_S_LIGHT
       Serial.println("  S_LIGHT");
       wait(SHORT_WAIT);
    #ifdef ID_S_DIMMER
       Serial.println("  S_DIMMER");
       wait(SHORT_WAIT);
    #ifdef ID_S_COVER
       Serial.println("  S_COVER");
       wait(SHORT_WAIT);
    #ifdef ID_S_TEMP
       Serial.println("  S_TEMP");
       wait(SHORT_WAIT);
    #ifdef ID_S_HUM
       Serial.println("  S_HUM");
       wait(SHORT_WAIT);
    #ifdef ID_S_BARO
       Serial.println("  S_BARO");
       present(ID_S_BARO,S_BARO," Air pressure");
       wait(SHORT_WAIT);
    #ifdef ID_S_WIND
       Serial.println("  S_WIND");
       wait(SHORT_WAIT);
    #ifdef ID_S_RAIN
       Serial.println("  S_RAIN");
       wait(SHORT_WAIT);
    #ifdef ID_S_UV
       Serial.println("  S_UV");
       wait(SHORT_WAIT);
    #ifdef ID_S_WEIGHT
       Serial.println("  S_WEIGHT");
       wait(SHORT_WAIT);
    #ifdef ID_S_POWER
       Serial.println("  S_POWER");
       wait(SHORT_WAIT);
    #ifdef ID_S_HEATER
       Serial.println("  S_HEATER");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_LOCK
       Serial.println("  S_LOCK");
       wait(SHORT_WAIT);
    #ifdef ID_S_IR
       Serial.println("  S_IR");
       wait(SHORT_WAIT);
    #ifdef ID_S_WATER
       Serial.println("  S_WATER");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_DUST
       Serial.println("  S_DUST");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_HVAC
       Serial.println("  HVAC");
       wait(SHORT_WAIT);
       wait(SHORT_WAIT);
    #ifdef ID_S_SOUND
       wait(SHORT_WAIT);
    #ifdef ID_S_CUSTOM
       Serial.println("  S_CUSTOM");
       wait(SHORT_WAIT);
       Serial.println("");
       Serial.println("");
       Serial.println("");
       randNumber=random(0,101);
       Serial.println(randNumber);
       // Send fake battery level
       sendBatteryLevel(randNumber);
       wait(LONG_WAIT);
       // Request time
       requestTime();
       wait(LONG_WAIT);
       //Read Sensors
    #ifdef ID_S_DOOR
       door();
    #ifdef ID_S_MOTION
       motion();
    #ifdef ID_S_SMOKE
       smoke();
    #ifdef ID_S_LIGHT
       light();
    #ifdef ID_S_DIMMER
       dimmer();
    #ifdef ID_S_COVER
       cover();
    #ifdef ID_S_TEMP
       temp();
    #ifdef ID_S_HUM
       hum();
    #ifdef ID_S_BARO
       baro();
    #ifdef ID_S_WIND
       wind();
    #ifdef ID_S_RAIN
       rain();
    #ifdef ID_S_UV
       uv();
    #ifdef ID_S_WEIGHT
       weight();
    #ifdef ID_S_POWER
       power();
    #ifdef ID_S_HEATER
       heater();
       distance();
       light_level();
    #ifdef ID_S_LOCK
       lock();
    #ifdef ID_S_IR
       ir();
    #ifdef ID_S_WATER
       water();
       air();
    #ifdef ID_S_DUST
       dust();
       scene();
       rgbLight();
       rgbwLight();
       color();
    #ifdef ID_S_HVAC
       hvac();
       multimeter();
    #ifdef ID_S_SOUND
       moisture();
    #ifdef ID_S_CUSTOM
       custom();
       wait(SHORT_WAIT);
    //void door(){}
    #ifdef ID_S_DOOR
    void door()
       Serial.print("Door is: " );
       if (randNumber <= 50) {
       	Serial.println("Open");
       	Serial.println("Closed");
    #ifdef ID_S_ARMED
       Serial.print("System is: " );
    #ifdef ID_S_MOTION
    void motion()
       Serial.print("Motion is: " );
       	Serial.println("Active");
       	send(msg_S_MOTION_T.set(1));
       	Serial.println("Quiet");
       	send(msg_S_MOTION_T.set(0));
    #ifdef ID_S_ARMED
    #ifdef ID_S_SMOKE
    void smoke()
       Serial.print("Smoke is: " );
       	send(msg_S_SMOKE_T.set(1));
       	send(msg_S_SMOKE_T.set(0));
    #ifdef ID_S_ARMED
    #ifdef ID_S_LIGHT
    void light()
       Serial.print("Light is: " );
    #ifdef ID_S_DIMMER
    void dimmer()
       Serial.println(dimmerVal);
    #ifdef ID_S_COVER
    void cover()
       Serial.print("Cover is : " );
       if (coverState == 1) {
       	Serial.println("Opening");
       	send(msg_S_COVER_U.set(1));
       	Serial.println("Closing");
       	send(msg_S_COVER_D.set(0));
       	Serial.println("Idle");
       	send(msg_S_COVER_S.set(-1));
    #ifdef ID_S_TEMP
    void temp()
    #ifdef ID_S_HUM
    void hum()
    #ifdef ID_S_BARO
    void baro()
       long pressure = map(randNumber,1,100,870,1086);// hPa?
       int forecast = map(randNumber,1,100,0,5);
       Serial.print("Atmosferic Pressure is: " );
       Serial.println(pressure);
       send(msg_S_BARO_P.set(pressure));
       Serial.print("Weather forecast: " );
       send(msg_S_BARO_F.set(weather[forecast]));
    #ifdef ID_S_WIND
    void wind()
    #ifdef ID_S_RAIN
    void rain()
    #ifdef ID_S_UV
    void uv()
    #ifdef ID_S_WEIGHT
    void weight()
       Serial.print("Weight is: " );
    #ifdef ID_S_POWER
    void power()
       Serial.print("Watt is: " );
       Serial.print("KWH is: " );
    #ifdef ID_S_HEATER
    void heater()
       //  String heatState="Off";
    void distance()
    void light_level()
    #ifdef ID_S_LOCK
    void lock()
       Serial.print("Lock is: " );
    #ifdef ID_S_IR
    void ir()
       Serial.println(irVal);
       send(msg_S_IR_S.set(irVal));
       send(msg_S_IR_R.set(irVal));
    #ifdef ID_S_WATER
    void water()
    void air()
    #ifdef ID_S_DUST
    void dust()
    void scene()
       Serial.print("Scene is: " );
       	sceneValPrevious=sceneVal;
    void rgbLight()
       Serial.println(rgbState);
    void rgbwLight()
       Serial.println(rgbwState);
    void color()
       String colorState;
       Serial.println(colorState);
    #ifdef ID_S_HVAC
    void hvac()
       Serial.println(hvac_Speed);
    void multimeter()
       Serial.println(impedance);
       Serial.println(volt);
       Serial.println(amps);
    #ifdef ID_S_SOUND
    void moisture()
    #ifdef ID_S_CUSTOM
    void custom()
       switch (message.type) {
    #ifdef ID_S_ARMED
       case V_ARMED:
       	isArmed = message.getBool();
    #ifdef ID_S_DOOR
       	door();//temp ack for door
    #ifdef ID_S_MOTION
       	motion();//temp ack
    #ifdef ID_S_SMOKE
       	smoke();//temp ack
       case V_STATUS: // V_LIGHT:
    #ifdef ID_S_LIGHT
       		light(); // temp ack
       	//    #ifdef ID_S_HEATER
       	//    #endif
    #ifdef ID_S_DIMMER
       case V_DIMMER:
       	dimmerVal= message.getInt();
       	dimmer();// temp ack
    #ifdef ID_S_COVER
       case V_UP:
       	coverState=1;
       	Serial.println("V_UP");
       	cover(); // temp ack
       case V_DOWN:
       	coverState=-1;
       	Serial.println("V_DOWN");
       	cover(); //temp ack
       case V_STOP:
       	coverState=0;
       	Serial.println("V_STOP");
       	cover(); //temp ack
       case V_HVAC_SETPOINT_HEAT:
    #ifdef ID_S_HEATER
       		heater();//temp ack
    #ifdef ID_S_HVAC
       		hvac();//temp ack
       case V_HVAC_FLOW_STATE:
    #ifdef ID_S_HEATER
       		heater();//temp ack
    #ifdef ID_S_HVAC
       		hvac();//temp ack
    #ifdef ID_S_LOCK
       case V_LOCK_STATUS:
       	lock(); //temp ack
    #ifdef ID_S_IR
       case V_IR_SEND:
       	irVal = message.getLong();
       	ir(); // temp ack
       case V_IR_RECEIVE:
       	ir(); // temp ack
       case V_SCENE_ON:
       	sceneVal = message.getInt();
       	Serial.println(" On");
       	scene();// temp ack
       case V_SCENE_OFF:
       	Serial.println(" Off");
       	scene();// temp ack
       case V_RGB:
       	rgbState=message.getString();
       	rgbLight(); // temp ack
       case V_RGBW:
       	rgbwLight();
    #ifdef ID_S_HVAC
       //  hvac_SetPointHeat
       //  hvac_SetPointCool
       //  hvac_FlowState
       //  hvac_FlowMode
       //  hvac_Speed
       case V_HVAC_SETPOINT_COOL:
       	hvac();//temp ack
       case V_HVAC_FLOW_MODE:
       	hvac();//temp ack
       case V_HVAC_SPEED:
       	hvac();//temp ack
       default:
       	Serial.println(message.type);
    can you try to add the watchdog timers and see what happens? Try using a different bootloader? Different power source or using a small booster or an additional AA battery and a LDO. I am just throwing ideas and see what you can do with the stuff you may have at home.
  • @gohan said in My Slim 2AA Battery Node:
    LDO
    @gohan
    Hi, i added a WDT now into the MotionSensorSketch.
    Well at least i guess i did. I just read about it , never used it before. Does the 1Mhz Optiboot boatloaders support this ?
    Unfortunalty I didnt recieve my 3,3V boosters yet and i dont have LDO´s around.
    Concerning the bootloaders. Do you have a suggestion which one to use ? As I read that sticking to 1Mhz is important when using only 2AA batteries because of instability when voltage goes belowe certian values.
    Obviously i could use more batteries, but then i cant supply the nRF2401 from the board right ?
    // Enable debug prints
    #define MY_NODE_ID 40
    #include <avr/wdt.h>
    // Initialize motion message
    	wdt_enable(WDTO_2S);
    	sendSketchInfo("Motion Sensor", "AndyWasHere");
    	present(CHILD_ID, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    	Serial.println(tripped);
     wdt_reset();
    Actually you would have to put wdt_enable(WDTO_8S); right after Loop() and wdt_disable(); before calling the sleep (this is what I copied from another sketch). The wdt_reset you cold use in the middle of the loop in case you have a function that could take long time to execute and it may trigger the WD timer so you can reset the timer (you can play with the length of the timer according to your needs)
  • @gohan
    maybe like this ?
    wdt_disable();
    that's what I found. You could also use wdt_enable(WDTO_2S) I think. I haven't done any test yet on this.
    @Komaandy Try to remove all your Serial.print.
    1. Has anyone used NRF24L01+ + PA + LNA on these modules ?
    2. Any reason why it shouldnt work out of the box ( does AA batteries give enough power to drive them on LOW settings? )
    3. What type of battery monitoring is recommended on these ones? The resistance or the library way?
    I just got 90 PCBs, beautiful, fast shipping ( i think under 2 weeks to Norway ) and looks well made.
    I'll drop one in each beehive I have ( 7 ) and see how long they last
  • So, it seems i made some progress.
    After changing to the @GertSanders bootloader ( https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62) all the PIR nodes seem to be stable.
    Wish me luck 🙂
    @Komaandy Yes, using 8MHz instead of 1MHz is perhaps a good idea. Stable enough at room temperature, well proven and will e.g. solve a "Serial.print()" interrupt loop issue. Just remember that you'll lose ~25uA if you'll leave BOD enabled.
    No, on ATMega328 MySensors disables BOD before going to sleep.
    So extra consumption from BOD will only exist when node is active and in that case it's negligible.
    @Nca78 Ok. Thanks. Since ever, or only from 2.x ?
    @m26872 no idea I started MySensors with 2.x 😛
  • Update : Day 3 and still all PIR nodes are working 😉
    I´m using the given sketch here.
  • Still up and running stable.
    8Mhz Bootloader did the trick for me 🙂
    @Komaandy Nice! Thumbs up for 8MHz (and your "dark-style Fhem" - same as I use) 👍
  • @m26872
    thanks again for this great idea and that you developed these fine boards !
    And by the way...
    As you are using fhem as well...
    How do you manage to reset the tripped "1" in Fhem ?
    I just added a delay and a gw.send"0" to your sketch :), but using fhem would be more sophisticated actually ...
    @Komaandy said in My Slim 2AA Battery Node:
    I don't. I just use the last trip time as it's state and then notify (e.g. light or push message) on trip. I think it should be very simple to make a notify with a timer "at" to reset it after a while, if you wish.
  • just want to mention that I am using successfully the same Bootloader @Komaandy is using for about 2 weeks now. So it seems like my problems with freezing nodes are depending on a bad or too slow bootloader...
  • All of the ducting near me is a bit too slim to fit sensors based on this, so I decided to design and print a case instead.
    Does the trick nicely, and I also chose to use proper AA battery clips to retain a good connection, as the cable-tie battery assembly wasn't holding well for me!
    On the Thingiverse page I have a link to the original OnShape doc.
    https://www.thingiverse.com/thing:2418194
    Thoughts, suggestions, etc will be much appreciated!
  • Hi
    Did anyone make DHT 22 slim node with MySensors 2.0? I created one Node from modified MySenors 2 example...But I get a feeling that it is freezing sometimes (but then again comes back to life).
  • 90
  • 29
  • 44
