  2. Announcements
  3. 💬 Air Humidity Sensor - Si7021
temperaturehumiditysi7021
28 Posts 13 Posters 6.3k Views 12 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Air Humidity Sensor - Si7021" posted on MySensors.org.
    • T
      texnic
      The link to the 3.3 V module on AliExpress actually leads to the 5 V module.
      YveauxY 1 Reply Last reply
      • T texnic
        YveauxY
        YveauxY
        @texnic the seller must have changed the items. I will look into it. Thanks for the hint!
          Mark Hansen
          Vice-versa, the link to the 5V module leads to a 3V (well, 1.9V to 3.6V) sensor unit
          • L
            L
            Latest Mailing List
            Banned
            This post is deleted!
            • M Mark Hansen
              YveauxY
              YveauxY
              @mark-hansen I checked all links (Ebay & Ali) and they all link to the correct modules.
              The sensor might support 1.9-3.6V, but the modules are for 3.3 and 5.0V IO levels respectively. The blue modules have a component marked 662K at the bottom, which is a XC6206P332MR voltage regulator. The 6-pin component next to it is a level shifter so the module operates at 5V levels on the outside, and 3.3V to the SI7021.
              So please, explain why you think the links are wrong.
              • K
                K
                kiesel
                I had the problem that the code wouldn't return when calling sensor.getCelsiusHundredths() while using the linked library. It works with this library:
                https://github.com/LowPowerLab/SI7021
                • SebexS
                  SebexS
                  Sebex
                  Hi, when making this sensor battery powered (and thus enabling "#define REPORT_BATTERY_LEVEL"), I get the verification error of "Vcc.h: No such file or directory". How can I solve this?
                  BearWithBeardB 1 Reply Last reply
                  • SebexS Sebex
                    BearWithBeardB
                    BearWithBeardB
                    BearWithBeard
                    @Sebex The Si7021 guide mentions that you have to install the Arduino VCC library (link to GitHub) if you want to use this feature:
                    Example
                    This example uses the Si7021 library, which is included in the MySensors external examples. If you choose to report battery level to the gateway (by defining REPORT_BATTERY_LEVEL at the top of the sketch) the Vcc library is also required. Please install the librarie(s) and restart the Arduino IDE before trying to compile.
                    It might be a good idea to add a link to the library in the article itself, since it doesn't make clear which library is required for this.
                    • BearWithBeardB BearWithBeard
                      Example
                      @BearWithBeard the Vcc library is present in MySensorsArduinoExamples, so if MySensorsArduinoExamples is installed, Vcc will be available.
                      Dependencies is a mess, which is why MySensorsArduinoExamples is in a separate repo. We (the community) has not yet found a good way to handle dependencies.
                      • SebexS
                        SebexS
                        Sebex
                        Yea that solved it, I copied the file in the library. Thanks!
                        • B
                          B
                          bebr
                          Hi there,
                          I've a pro mini 3.3V with a si7021 and a Li-ion 3.7V battery.
                          I'm using the VCC library, but the reported values are weird: the remaining battery value drops a lot, and if I reset the board, it jumps back to a more normal value.
                          The battery is connected to the VCC pin on the arduino.
                          A regulator (LM2936) powers the si7021 and the nrf24.
                          Here is a graph of the battery level. Pikes appear when I reset the arduino.
                          Isn't the 2 resistors method more accurate?
                          Thanks!
                          • B bebr
                            Hi there,
                            Thanks!
                            YveauxY
                            YveauxY
                            @bebr well, it can depend on a number of things: where in the sketch do you read the vcc level (eg before or after sending), what voltage levels did you configure in your sketch, did you remove the voltage regulator from the pro mini?
                            • B
                              B
                              bebr
                              @Yveaux thanks for your answer.
                              I used the sketch on the Mysensors'si7021 page, so the vcc level is read at the end of the loop, before going to sleep and after sending the temp/hum values.
                              The only modification I made are setting up the voltage values.
                              As my 3.7V Li-Ion battery is at 4.2V when fully charged and at 3V when almost completed discharged, this how I configured it in the sketch:
                              #ifdef REPORT_BATTERY_LEVEL
                              #include <Vcc.h>
                              static uint8_t oldBatteryPcnt = 200;  // Initialize to 200 to assure first time value will be sent.
                              const float VccMin        = 3.0;      // Minimum expected Vcc level, in Volts: Brownout at 1.8V    -> 0%
                              const float VccMax        = 4.2;  // Maximum expected Vcc level, in Volts: 2xAA fresh Alkaline -> 100%
                              const float VccCorrection = 1.0;      // Measured Vcc by multimeter divided by reported Vcc
                              static Vcc vcc(VccCorrection);
                              I didn't apply any correction because read and reported VCC was very close, and I'm just testing this for now.
                              I didn't removed the onboard regulator nor the power led for now. Isn't the regulator only used when applying voltage to the RAW pin?
                              • B bebr
                                #include <Vcc.h>
                                YveauxY
                                YveauxY
                                @bebr said in 💬 Air Humidity Sensor - Si7021:
                                Your setup looks allright.
                                Yes it is, but I'm not sure what will happen if you source 3v3 via its output pin.
                                Anyway, I doubt if this could cause the effect you're seeing.
                                • B
                                  B
                                  bebr
                                  Ok, do you need my schematic, to make it clearer?
                                  I've planned to removed the onboard regulator (and power led) on my production board. But this one is for testing so I leave it untouched.
                                  So currently the regulator, is obiously external.
                                  Thanks again, any help appreciated, otherwise I'll use the 2 resistors method.
                                  • B
                                    B
                                    bebr
                                    And now, without resetting, the battery level has jumped from 23% to 47%. This last seems to be correct according to the measure of 3.673V, directly taken on the battery.
                                    • B bebr
                                      @bebr could it be temperature related? I have noticed that the voltage in my nodes increase when the sun is shining on them.
                                        B
                                        B
                                        bebr
                                        wrote on last edited by bebr
                                        @mfalkvidd I thought of this too, but I opened the windows this morning, 11°C here this morning, and the battery level stayed around 50%.
                                        Here are some graphs showing it's not temperature related:
                                        • B
                                          B
                                          bebr
                                          I noticed I used a 10uF/50V capacitor instead of a 0.1uF/5V for LM2936 regulator.
                                          Could it be the source of my problem?
                                          I change it last evening, and now the reported battery level seems ok.
                                          Sorry, I'm noob in electronics :)
                                          skywatchS 1 Reply Last reply
