  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 249.9k Views 53 Watching
  • AnticimexA Anticimex
    @Magnus-Pernemark why do you need the special flag? I just wrote that you only need that if you DON'T want your gw to require signatures from everyone. It works just like @alexsh1 wrote. And it will work like that on both bets and release after release so if you can't get it to work on beta now, it won't work on release later either.
    I suggest you start posting some logs so I can see if you really have signing enabled and that all required handshaking takes place. But don't post it in this thread please.
    magpernM
    magpernM
    magpern
    @Anticimex @alexsh1 It's working now! In one of you replies (@Anticimex ), you misspelled the flag name, and I copy / pasted what you wrote. So all this time, signing was never activated. Now it is and gateway works as expected!
    AnticimexA 1 Reply Last reply
    • magpernM magpern
      AnticimexA
      AnticimexA
      Anticimex
      #303
      @Magnus-Pernemark oh, sorry about that. But I do hope the ones in the docs are correct. Good that it works now :+1:
        2rDK
        wrote on last edited by 2rDK
        #304
        This may be a beginner-misunderstanding, but i hope you can assist me.
        I had to move one of my repeaters to improve the WAF of my sensor installation.
        In this process i may have messed a bit too much with the routing as i think the nodes responds directly to the gateway, but the gateway answers through the repeater. The repeater is moved, and the signal does no longer reach the node, resulting in a head ache (FPAR fails).
        I read the debug-section and I think i need to clear my eeprom to allow for a new routing to happen.
        This proved more difficult than I had anticipated. below is my software stack/process:
        • Downloaded Arduino 1.8.3 for non admin install
        • Downloaded Mysensors Library v2.1.1 using Library manager
        • Downloaded Arduino SAMD Boards (32-bits ARM cortex-M0+) version 1.6.11 using Boards manager
        • Downloaded Mysensors SAMD Boards version 1.0.4 using Boards manager
        I then rebooted my machine for good measure and uploaded the ClearEepromConfig-example to the gateway. No output in the serial monitor.
        I then searched a bit on the forum and added:
            while (!Serial) {}
        In the setup()-part. This enabled me to get some output from the gateway. Unfortunatly it only returns Started clearing. Please wait...
        I then did some more digging, and apperantly i2c_eeprom_read_byte() fails. So i searched some more on the forum and found I2C eeprom write fix for SAMD. So i tried the above once again but this time with Mysensors Library v2.2.0-beta (dev branch) just to see if anything changed. It didnt.
        What did i miss ?
        • F
          F
          Fabien
          After weeks of tests, it doesn't work well with ethernet and RFM69HW. Every 2 days, I need to power off and on the gateway. Controller can't connect (OH2).
          for some reasons, serial doesn't work on my odroid C1 with openhabian.
          • korttomaK
            korttomaK
            korttoma
            Ever since lightning took out my original RFM69 W5100 GW I have been having trouble with the replacement GW I built so now I want to use my Sensebender GW for this instead. On the GW I have allso 4 buttons and 4 relays so my question to @Anticimex is:
            Witch pins on the MYSX connector do you recommend for the buttons and relays?
            I was thinkin:
            Buttons:
            MYSX_D1_DFM
            MYSX_D2_DTM
            MYSX_D3_INT
            MYSX_D4_INT
            Relays:
            MYSX_D5_PWM
            MYSX_D6_PWM
            MYSX_D9_A3
            MYSX_D10_A4
            Can I assign the pins like this in my sketch:
            const int relayPin[] = {MYSX_D5_PWM, MYSX_D6_PWM, MYSX_D9_A3, MYSX_D10_A4};       //  switch around pins to your desire
            const int buttonPin[] = {MYSX_D1_DFM, MYSX_D2_DTM, MYSX_D3_INT, MYSX_D4_INT};   //  switch around pins to your desire
            Here is the complete sketch, please comment if something can be improved:
             * Version 1.0 - Henrik EKblad
             * LED purposes:
            #define SN "EthGW/RFM69 Rele Button"
            #define SV "1.5"
            //#define MY_RADIO_NRF24
            //#define MY_RADIO_NRF5_ESB
            #define MY_RADIO_RFM69
            #define MY_IS_RFM69HW
            //#define MY_RADIO_RFM95
            #define MY_GATEWAY_W5100
            //#define MY_W5100_SPI_EN 4
            // radio on the same spi bus.
            #define MY_SOFTSPI
            #ifndef MY_RF24_CE_PIN
            #define MY_RF24_CE_PIN 5
            #ifndef MY_RF24_CS_PIN
            #define MY_RF24_CS_PIN 6
            // Enable UDP communication
            //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
            #define MY_IP_ADDRESS 192,168,1,100
            #define MY_PORT 5003
            #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xED, 0xED
            // Enable inclusion mode
            // Set blinking period
            // Flash leds on rx/tx/err
            #if defined(MY_USE_UDP)
            #include <EthernetUdp.h>
            #include <Ethernet.h>
            #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
            #define RELAY_OFF 1
            #define noRelays 4                     //2-4
            class Relay             // relay class, store all relevant data (equivalent to struct)
              public:
                int buttonPin;                   // physical pin number of button
                int relayPin;             // physical pin number of relay
                boolean relayState;               // relay status (also stored in EEPROM)
            Relay Relays[noRelays];
            Bounce debouncer[noRelays];
            MyMessage msg[noRelays];
              wait(100);
              for (int i = 0; i < noRelays; i++) {
                Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                msg[i].type = V_LIGHT;
                wait(100);
                Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                wait(50);
                debouncer[i].interval(30);
                wait(50);
              sendSketchInfo(SN, SV);
              wait(100);
                present(i, S_LIGHT);                               // present sensor to gateway
              wait(100);
              for (byte i = 0; i < noRelays; i++) {
                if (debouncer[i].update()) {
                  if ( value == LOW) {
                    // save sensor state in EEPROM (location == sensor number)
                    saveState( i, Relays[i].relayState );
              //wait(20);
              if (message.sender == 0) {
                  if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                    digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                    saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
              wait(20);
            • Tomas
            • korttomaK korttoma
              I was thinkin:
              Buttons:
              MYSX_D1_DFM
              MYSX_D2_DTM
              MYSX_D3_INT
              MYSX_D4_INT
              Relays:
              MYSX_D5_PWM
              MYSX_D6_PWM
              MYSX_D9_A3
              MYSX_D10_A4
               * LED purposes:
              #define SV "1.5"
              #define MY_SOFTSPI
              #define RELAY_OFF 1
                public:
                wait(100);
                  wait(100);
                  wait(50);
                  wait(50);
                wait(100);
                wait(100);
                //wait(20);
                wait(20);
              AnticimexA
              AnticimexA
              Anticimex
              @korttoma you can use any pin that can provide the type of functionality you need (for example, don't expect that using an analog pin for digital data to work). Just keep in mind that by using certain pins, you might have to give up features you might like to use later on (like in this case you take the dfm and dtm pins, so you have "taken" the UART pins if you ever plan to use that for your board).
              As for the definitions, I am not sure. @tbowmo made the mappings for that port. I believe it looks good.
              • tbowmoT
                tbowmoT
                tbowmo
                @korttoma
                Like @anticimex said, you will loose possibility of using the serial port if you use the dtm/dfm lines.
                But besides that, you are free to use all the ports as digital input/output, except the i2c pins as we have an i2c eeprom that is connected to the same pins.
                • korttomaK
                  korttomaK
                  korttoma
                  Thanks @Anticimex and @tbowmo I have the GW up and running with one external sensor now. I just need to connect the buttons and relays to test those.
                  I'm not sure if I will ever need the UART pins but I will make the hardware so that I can easily change the pins used for buttons and relays.
                  btw, what is the use cases for UART pins?
                  • Tomas
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @korttoma if you have peripherals on your daughter board that communicate using a serial protocol it makes sense to leverage any hw UART capable blocks on the main board. The MYSX standard just indicate that if the main board has such capability, the interface is available on those two pins. You can of course bit bang it on any digital io (depending on core clock) if you need several interfaces.
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @korttoma that said, note that the dtm and dfm pins also serves as general digital io, so you can use them like any Dx pin.
                      • korttomaK
                        korttomaK
                        korttoma
                        #312
                        Button and relay pins I assigned seem to work correctly but now I managed to release some magic smoke from the Sensebender GW board :( shorted something by mistake and at least FB1 is tost. Can I just shor FB1 to see if the board is stil alive or do I have to replace FB1? Seems like nothing else was damaged (at least I hope so) since it was GND and Vraw that was shorted.
                        Edit: Just confirmed that it is only FB1 that was destroyed the rest seems to work :D just cant power it from the USB anymore. Hope I can stil write to it.
                        • Tomas
                        tbowmoT 1 Reply Last reply
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @korttoma said in 💬 Sensebender Gateway:
                          FB1 is just a filter to suppress spurious RF (if any) on the gnd wire exiting the board. So it can be shorted. The gateway should function fine without it.
                          • Mr6510M
                            Mr6510M
                            Mr6510
                            Hi All,
                            I have purchased a SenseBender Gateway, tested the MySensors MQTT code etc on it and thats all good.
                            Now I want to experiment with my own code on it. I notice that in the example code there are some references to the onboard LEDs, such as;
                            static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                            which is great, I will use those to manage the LEDs in my sketch.
                            What I'd like to know is where are LED_BLUE, LED_RED etc actually defined? What file? The reason I ask is that I also want to know which pin is connected to the RFM69 RESET pin. On the schematic for the SenseBender it is labelled RESET_RFM on the SAMD21 chip, and is physical chip pin 23 and also PB10. I don't know how to use that in my sketch, so if I had a macro like there is for the LEDs then I could just call that.
                            I'm assuming that if I find where LED_BLUE is defined I may find info about the other pins I also want to use :)
                            Paul
                            hekH 1 Reply Last reply
                            • Mr6510M Mr6510
                              Hi All,
                              Paul
                              @Mr6510
                              https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
                              Mr6510M 1 Reply Last reply
                                @Mr6510
                                Mr6510M
                                Mr6510M
                                Mr6510
                                @hek thanks, Now I understand.
                                I was poking around near that file before, but could not figure it out.
                                Thanks again,
                                Paul
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  Received a new ferrite bead and soldered it to my device. The bead showed 0 ohm with a multimeter so I don't know if it is the real deal but it seems to work even if it is not pretty:
                                  • Tomas
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    at DC it should be close to 0 ohm, but on higher frequencies it should act as a resistor.
                                    btw. it seems like the old one had exploded? :)
                                    korttomaK 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      korttomaK
                                      korttomaK
                                      korttoma
                                      #319
                                      @tbowmo said in 💬 Sensebender Gateway:
                                      That's what happens when you short Vraw to GND on the MYSX connector in one of those facepalm moments :D (we need an :facepalm emoji!).
                                      • Tomas
                                      • F
                                        F
                                        Fabien
                                        I have a lot of problem with this gateway. First I think it was caused by network module but with serial sketch I have a lot of issues. After 2 or 3 days, gateway crash. If I remove some sensors reporting every 30 seconds it crash but later.
                                        This morning, all leds are off on the board. After powering off and on it was ok.
                                        I'im using RFM69 with Openhab2 as controller.
                                        Is someone experience same issue ? I will fall back to my old Jeelink gateway (ATmega328 based).
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          I have used my sensebender gateway for more than a year now, only difference is that I use NRF24 radio.. Haven't had any hickups yet..
                                          Which version of mysensors are you using?
