  3. RFM69HW & ATC not working
rfm69
10 Posts 2 Posters 1.4k Views 1 Watching
  • K
    K
    KevinT
    I'm hoping someone can help me with ATC mode on my RFM69HW/Arduino Pro Mini nodes.
    I've enabled it per the example sketch RFM69_RFM95_ATC_SignalReport.ino.
    I've updated the node & gateway to use the new RFM69 driver.
    It doesn't seem to adjust the transmit power on my node and I get a TSF error as well.
    A couple example debug outputs:
    BME280 - Sending the new humidity to the gateway.
    55791 TSF:MSG:SEND,4-4-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:53.11
    Uplink Qlty: 0, Xmit Level (dBm): 107, Xmit Level (%): 140
    Xmit RSSI: -46, Recv RSSI: -54, Xmit SNR: -256, Recv SNR: -256
    55805 TSF:MSG:READ,92-1-4,s=2,c=1,t=4,pt=0,l=6,sg=0:102.05
    55816 !TSF:MSG:LEN=26,EXP=13
    State: ST_SLEEP
    Uplink Qlty: 0, Xmit Level (dBm): 11, Xmit Level (%): 108
    Xmit RSSI: -46, Recv RSSI: -53, Xmit SNR: -256, Recv SNR: -256
    56082 TSF:MSG:READ,92-2-4,s=2,c=1,t=4,pt=0,l=6,sg=0:102.05
    56094 !TSF:MSG:LEN=32,EXP=13
    56096 TSF:MSG:READ,92-2-4,s=2,c=1,t=4,pt=0,l=6,sg=0:102.05
    56102 !TSF:MSG:LEN=26,EXP=13
    State: ST_SLEEP
    You can see that the Xmit levels don't make sense.
    The Xmit RSSI should be moving towards -70 dBm but never really changes.
    Here's the macros in the node's code:
    // if you uncomment this, you can get test and debug updates about everything the sensor is doing by using the serial monitor tool.
    //#define MY_RADIO_RF24                            // A 2.4Ghz transmitter and receiver, often used with MySensors.
    // #define MY_RF24_PA_LEVEL RF24_PA_MIN              // This sets a low-power mode for the radio. Useful if you use the version with the bigger antenna, but don't want to power that from a separate power source. It can also fix problems with fake Chinese versions of the radio.
    #define MY_RADIO_RFM69                        // possible 434, 868, 915Mhz transmitter and reveiver.
    #define MY_RFM69_NEW_DRIVER                   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
    #define MY_IS_RFM69HW                         // high power version of radio
    #define MY_RFM69_FREQUENCY  RFM69_915MHZ
    #define MY_RFM69_ATC_TARGET_RSSI_DBM (-70)    // target RSSI -70dBm
    #define MY_RFM69_MAX_POWER_LEVEL_DBM 10       // max. TX power 10dBm = 10mW
    // Do you want this sensor to also be a repeater?
    // #define MY_REPEATER_FEATURE                    // Just remove the two slashes at the beginning of this line to also enable this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this.
    // Are you using this sensor on battery power?
    #define BATTERY_POWERED
    // Would you like to report humidity?
    #define REPORT_HUMIDITY
    // LIBRARIES
    #include <SPI.h>                                  // A communication backbone, the Serial Peripheral Interface.
    #include <MySensors.h>                            // The MySensors library. Hurray!
    #include <Wire.h>                                 // Enables the Wire communication protocol.
    #include <BME280_MOD-1022.h>                      // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code, written originally by Embedded Adventures. https://github.com/embeddedadventures/BME280
    and later, in the loop()
    #ifdef REPORT_HUMIDITY
          // Send humidity
          if (COMPARE_HUM == 1 && fabs(humidity - lastHumidity) < humThreshold) { // is the humidity difference bigger than the threshold?
    //        Serial.print(humidity - lastHumidity);
    //        Serial.println("- BME280 - Humidity difference too small, so not sending the new measurement to the gateway.");
            Serial.println("BME280 - Sending the new humidity to the gateway.");
            send(humidityMsg.set(humidity, 2));
            lastHumidity = humidity; // Save new humidity to be able to compare in the next round.
          // Send pressure
          if (COMPARE_PRES == 1 && fabs(pressure - lastPressure) < presThreshold) { // is the pressure difference bigger than the threshold?
    //        Serial.print(pressure - lastPressure);
    //        Serial.println("- BME280 - Pressure difference too small, so not sending the new measurement to the gateway.");
            Serial.println("BME280 - Sending the new pressure to the gateway.");
            send(pressureMsg.set(pressure, 2));
            lastPressure = pressure; // Save new pressure to be able to compare in the next round.
          ReportRfPower();
          state = ST_SLEEP;
    and the report of ATC values:
    void ReportRfPower()
      Serial.print("Uplink Qlty: ");  Serial.print(transportGetSignalReport(SR_UPLINK_QUALITY));
      Serial.print(", Xmit Level (dBm): ");  Serial.print(transportGetSignalReport(SR_TX_POWER_LEVEL));
      Serial.print(", Xmit Level (%): ");  Serial.println(transportGetSignalReport(SR_TX_POWER_PERCENT));
      Serial.print("Xmit RSSI: ");  Serial.print(transportGetSignalReport(SR_TX_RSSI));
      Serial.print(", Recv RSSI: ");  Serial.print(transportGetSignalReport(SR_RX_RSSI));
      Serial.print(", Xmit SNR: ");  Serial.print(transportGetSignalReport(SR_TX_SNR));
      Serial.print(", Recv SNR: ");  Serial.println(transportGetSignalReport(SR_RX_SNR));
    Any ideas?
    • K
      K
      KevinT
      I've more information to share.
      Seems I was running out of memory, when I turned off debug, which freed up some room, I started to get more reasonable results.
      Uplink Qlty: 0, Xmit Level (dBm): -2, Xmit Level (%): 0
      Xmit RSSI: -45, Recv RSSI: -39
      Wondering if this is as low as it can go?
      Looking at the datasheet,
      PA1 and PA2 combined on pin PA_BOOST: +2 to +17 dBm
      and
      PA1+PA2 on PA_BOOST with high output power +20dBm settings (see 3.3.7): +5 to +20 dBm
      I don't know what power level is selected when we enable #define MY_IS_RFM69HW
      Can we simply run it as a low power RFM69 by commenting out the #define?
      • K
        K
        KevinT
        Documenting what I've found in the library code for the community.
        When using #define MY_IS_RFM69HW:
        The driver enables PA1 and PA2 and disables PA0 power amps. It automatically selects the right combination of PA1 and PA2 to achieve the target power level.
        Power range is -2 to +20 dBm
        When NOT using #define MY_IS_RFM69HW:
        Then only PA0 is enabled.
        PA0 is identical between the RFM69W and RFM69HW.
        Power range is -18 to +13 dBm
        Basically, your RFM69HW operates as an RFM69W.
        Also, when using the new RFM69 driver, ATC mode is on by default, unless you explicitly turn it off using macro #define MY_RFM69_ATC_MODE_DISABLED
        The default ATC target RSSI level is -80 dBm which you can change using #define MY_RFM69_ATC_TARGET_RSSI_DBM
          @KevinT
          afaik you cannot use RFM69H without enabling MY_IS_RFM69HW, else there will be no rf output. So you can't use RFM69HW as a W module.
          • K
            K
            KevinT
            wrote on last edited by KevinT
            Hi @scalz,
            I don't know, I've tried it, it worked for me.
            Just to be clear, I'm still using #define MY_RADIO_RFM69
            What in the library would stop it?
              @KevinT
              well, that's strange. Because lot of people experienced communication issues when missing the MY_IS_RFM69HW with RFM69H, very weak range or no comm. It's not about the library, it's about the module itself and its hardware implementation.
              of course MY_RADIO_RFM69 is mandatory :)
              do you get a usable range when using RFM69H as a RFM69W? As good as a RFM69W??
              Here you can see PA0 is connected to RFIO pin which also handles the LNA, and PA1/2 to PA_BOOST pin
              Here is how RFM69W works, it's just connected to RFIO, for PA0 and LNA
              And, this is how RFM69H works. There is a RF Switch, which is controlled by the rxtx pin. So, in TX mode it uses PA_BOOST (PA1/2), and in RX mode it uses RFIO for LNA.
              Note: all the tuning passives on both modules, on TX path, for tuning filtering etc.
              So if you don't use the MY_IS_RFM69HW with a RFM69H, to only use PA0, then I doubt you can get same range as RFM69W.
              Finally, I woud usually recommand to use MY_IS_RFM69HW if using RFM69HW/HCW and let ATC feature handles power level, or use a RFM69W/CW (with ATC too of course)
              Here a few links which also explain this, but you can find more infos aboutthis on internet:
              https://andrehessling.de/2015/02/07/figuring-out-the-power-level-settings-of-hoperfs-rfm69-hwhcw-modules/
              https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/standardise-mote-configuration-using-rfm69hw-only/
              K 1 Reply Last reply
              • scalzS scalz
                @KevinT
                K
                K
                KevinT
                @scalz
                This is my first attempt at using the lower power PA0. I am getting an RSSI of -75 with the radios about 5m apart and the radio using 10 dBm to achieve this. Quite disappointing. I was expecting the transmit power to be much lower, since in High Power mode I was getting an RSSI of -45 with transmit power of -2 dBm.
                I thought that perhaps the radio was reporting the wrong transmit power, or that the library was not interpreting it correctly. I expected results similar to the data sheet.
                But you say this is a common problem!
                I was planning on standardising on the high power radio for all my nodes, but now I see I will have to switch to the RFM69W for many of them.
                Thanks very much for taking the time to bring me up to speed, its greatly appreciated.
                  @KevinT
                  Indeed, that's not very good range.
                  As a rough comparison (because it can depend on others factors), with rfm69cw and a short range of 10-12m, with 2 bricks walls obstacles, I set ATC RSSI target= -87, and power level is autoadjusted to -11
                  So, regarding RFM69, for shorter ranges, RFM69W/CW can save power, and for others distances, RFM69H is better choice
                  I'm glad if I helped you :)
                  • K
                    K
                    KevinT
                    @scalz
                    That was going to be my next question, the expected range/power for RFM69W, if they are good, reasonable radios.
                    I also noticed in the forums a lot of complaints about bad NRF24L01 clones. It seems that RFM radios are a better choice?
                      @KevinT
                      yes in general subghz radios have better range than 2.4ghz.
                      I might have farther nodes but for example, I have one rfm69cw at 55m from the GW and it's ok, with many obstacles on the path (7x rock walls, a part of the roof is metallic, metallic doors etc).
                      This depends on many factors of course
