  3. SI7021 Multisensor - first try
multisensorsi7021
26 Posts 9 Posters 23.9k Views 6 Watching
  • n3roN
    n3roN
    n3ro
    Thx for the comment. Could you explain it a little bit more please? I have seen the the sensorblend sketch
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    • m26872M
      m26872M
      m26872
      Here's my interpretation of sensbender's si7021 implementation (thx @tbowmo). Maybe you can get some inspiration.
      by m26872, 20151109
      #include <SI7021.h>
      #include <RunningAverage.h>
      //#define DEBUG
      #ifdef DEBUG
      #define NODE_ID 131             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
      #define CHILD_ID_TEMP 0
      #define CHILD_ID_HUM 1
      // #define SLEEP_TIME 15000 // 15s for DEBUG
      #define SLEEP_TIME 300000   // 5 min
      #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
      #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
      #define VMIN 1900
      #define VMAX 3300
      #define AVERAGES 2
      int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
      int measureCount = 0;
      float lastTemperature = -100;
      int lastHumidity = -100;
      SI7021 humiditySensor;
        DEBUG_SERIAL(115200);
        DEBUG_PRINT("Voltage: ");
        DEBUG_PRINT(readVcc());
        DEBUG_PRINTLN(" mV");
        delay(500);
        DEBUG_PRINTLN(" *C");
        gw.begin(NULL,NODE_ID);
        gw.sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
        gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
        raHum.clear();
        measureCount ++;
        batteryReportCounter ++;
        bool forceTransmit = false;
        if (measureCount > FORCE_TRANSMIT_CYCLE) {
      	forceTransmit = true;
        // Read and print internal temp
        float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
        DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
        // Check battery
        if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
      	long batteryVolt = readVcc();
      	DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
      	uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
      	DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
      	batteryReportCounter = 0;
        gw.sleep(SLEEP_TIME);
      // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
      // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
      long readVcc() {
      // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
      double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
        unsigned int wADC;
        double t;
        // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
        ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
        ADCSRA |= _BV(ADEN);  // enable the ADC
        delay(20);            // wait for voltages to become stable.
        ADCSRA |= _BV(ADSC);  // Start the ADC
        while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
        wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
        t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
        return (t);   // The returned temperature in degrees Celcius.
       * Parameters
        bool tx = force;
        float temperature = data.celsiusHundredths / 100.0;
        if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
      	gw.send(msgTemp.set(temperature,1));
      	measureCount = 0;
      	DEBUG_PRINTLN("T sent!");
        raHum.addValue(humidity);
        if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
      	gw.send(msgHum.set(humidity));
      	lastHumidity = humidity;
      	measureCount = 0;
      	DEBUG_PRINTLN("H sent!");
      • n3roN
        n3roN
        n3ro
        Big THX,
        now i have understand how to use the si7021 :)
        Reading works great!
        But the sleeping current is very high ~1500uA
        m26872M R 2 Replies Last reply
        • n3roN
          n3roN
          n3ro
          @m26872 said:
          #define DEBUG
          btw. this #define DEBUG is a very cool idea!!!
          But i get a serial output if DEBUG is not definded :-/
          • n3roN n3ro
            Big THX,
            m26872M
            m26872M
            m26872
            Mine sleeps at 11uA.
            I think I stole it from @BulldogLowell. Credit to him if so.
            You also have the "define DEBUG" in the mysensors config-file. Is it that serial output you're referring to?
            • n3roN
              n3roN
              n3ro
              Yes the serial output. whats to do to put it in the mysensors config?
              • n3roN
                n3roN
                n3ro
                wrote on last edited by n3ro
                Yeah. now the new node works and the sleep current is about ~240aA.
                But i still not understand why i get debug outout on serial if debug isn definded^^
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @n3ro
                  Sorry didn't come around to answer you, but it seems that others picked up on my hint :)
                  Have you uncommented #define DEBUG line in MyConfig.h? If not, then that's why there is still debug..
                  n3roN 1 Reply Last reply
                  • n3roN
                    n3roN
                    n3ro
                    Perfect =)
                    //#define DEBUG
                    • tbowmoT tbowmo
                      @n3ro
                      n3roN
                      n3roN
                      n3ro
                      @tbowmo
                      why i cant see the debug information "ratio failed" or sending commands if debug is only enabled in the sketch? :)
                      • korttomaK
                        korttomaK
                        korttoma
                        Speaking of the Si021, has anyone tried to use 2 Si7021 sensors on the same node?
                        • Tomas
                        AWIA R 2 Replies Last reply
                        • korttomaK korttoma
                          AWIA
                          AWIA
                          AWI
                          @korttoma I would expect it does not work because these use the same I2C address...
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @n3ro
                            It's the way that the libraries are build.. They don't care about how your defines are in your sketch (unless you are on dev branch of the mysensors library.. We are bending arduino build system in that one)
                            @korttoma
                            Si7021 has a fixed i2c bus address, so only one can exists on each i2c bus. You could of course use bitbanging to create a second one. But why do you want to have multiple Si7021 on one node?
                            korttomaK 1 Reply Last reply
                            • tbowmoT tbowmo
                              @n3ro
                              @korttoma
                              korttomaK
                              korttomaK
                              korttoma
                              I was going to use a sensbender node in a location where I would have needed to use an external sensor and instead of attempting to remove the Si7021 from the sensbender I would have just added another (external) one if it was possible. Is there any other temperature sensor that is as good as the Si7021 in battery applications that I could use instead?
                              • Tomas
                              • n3roN n3ro
                                Big THX,
                                R
                                R
                                riataman
                                wrote on last edited by riataman
                                @n3ro said:
                                Big THX,
                                If you got this breakout: http://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32340228487.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_5,searchweb201560_1 it includes a 3.3v regulator and level shifting so you can actually use the sensor with a 5v arduino but it consumes quite a bit of current (60uA in the ones I got) even when idling.
                                What I did was desolder the regulator and solder a small wire to bypass it (sorry for potato quality pic).
                                Then I ordered this breakout for future nodes: http://www.aliexpress.com/item/New-HTU21D-Temperature-and-Humidity-Sensor-Module/1970355069.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_5,searchweb201560_1 that one doesn't seem to include any additional circuits (other than the pull up resistor and safety? resistor).
                                n3roN M 2 Replies Last reply
                                  R
                                  R
                                  riataman
                                  Since the i2c address is hardcoded I see two ways of doing this:
                                  1. Power the two sensors from gpio pins (instead of connecting them to vcc, connect each to a separate gpio pin), when you want to read one sensor you put one high and the other low. I'm not really sure if this will work at all.
                                  2. Use a soft i2c library like this one: https://github.com/todbot/SoftI2CMaster that way you have two sets of i2c pins. I'm pretty sure this one should work.
                                  • R riataman
                                    @n3ro said:
                                    Big THX,
                                    n3roN
                                    n3roN
                                    n3ro
                                    @riataman said:
                                    with a 5v arduino
                                    Hey =)
                                    the operating voltage of this component is 1.9 to 3,6 v. not 5v =)
                                    But the idea to remove the regulator to save a little bit energy is cool. i will try it =)
                                    R 1 Reply Last reply
                                    • n3roN n3ro
                                      @riataman said:
                                      with a 5v arduino
                                      Hey =)
                                      R
                                      R
                                      riataman
                                      @n3ro said:
                                      @riataman said:
                                      with a 5v arduino
                                      Hey =)
                                      That's true for the individual SI7021 IC, but in the breakout the regulator steps down the voltage to 5v and additional circuitry does 3.3<->5v level shifting. I have tested that particular breakout with a 5v arduino and it works just fine.
                                      • dakkyD
                                        dakkyD
                                        dakky
                                        does the sleeping current come down to an acceptable level when removing the regulator? 1500uA is quite much for a battery powered node.
                                        Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                                        Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                                        Software: MySensors 2.0development
                                        • n3roN
                                          n3roN
                                          n3ro
                                          #22
                                          @dakky said:
                                          1500uA
                                          The sleeping current is ~240uA.
                                          But it's possible to tune it a little bit more.
