    @Woeka There is (on Arduino Gateway) a function named "DEFINE INVERSE BLINK". Try to search for same for PI....
  • Can we use the "debug ota log" features with the raspberryPi gateway ??
    My node is not accessible and runs MYSBootloader.
    My gateway is raspberryPI.
    Now, I need to update the firmware on my node. Via MYSController, no problems, upload runs like a charm.
    But how to do for debugging my sketch ? Some bugs appear...... , I need to take a look on some vars values.
    Usually, I use the serial port with serial.print(some vars).
    Which alternative I have to use without serial port, only OTA features ?
    Thanks for the great work !!
    Unless you are using an esp8266, I don't think you can remote debug a pro mini. @sundberg84 is working on a serial logger to microsd card, maybe it could help you in some way
  • In fact, I do not need to log, but need to look what's happen in my sketch.
    The new "OTALog" function, MY_OTA_LOG_SENDER_FEATURE or MY_DEBUG_OTA seems to be the good way.
    From the docs, it allows to send a debug message to another node or gateway via OTA.
    But how to got the debug message from OTA node, on the gateway side (RaspberryPi) ?
    @romeo01 said in 💬 Building a Raspberry Pi Gateway:
    MY_DEBUG_OTA
    I'd start reading from here https://www.mysensors.org/apidocs-beta/group__SerialDebugGrpPub.html#ga6bd5956352d3a184a0cb02783b8d35ff
    Well, you found the starting point !
    MY_OTA_LOG_SENDER_FEATURE & MY_DEBUG_OTA are enabled on my OTA node.
    Again the same question: What I have to do on the gateway side ?
    Is it possible with the raspberry Gateway ?
    I'm still looking for debugging my sketch in remote. I need to have a look on the debug messages. I reminder, the node is not accessible and runs MYSbootloader.
    If I understood well, you need to set a target node ID that will receive the debug and then make a node with that ID in order to get the debug messages
  • Exactly, but I would like to use the gateway (raspberry) as target.
    Is that possible ?
    If yes, how to display the debug message on the gateway.
    I have an access to my gateway only via SSH.
    I have no idea if can do it, but you could just have a node connected to USB port of the rpi and do a "cat" on the USB port and you can read the debug from the node
  • Is it possible to build a gateway that is MQTT, but also listens on port 5003? I want to send my data up to AWS IoT, but I also need port 5003 for Vera integration.
    You can use node-red to bridge the ethernet gateway and the aws service. Are you sure vera plug in doesn't support mqtt?
  • @gohan, there are two MQTT plugins for the Vera with varying capabilities. But, the mysensors plugin for Vera doesn't appear to support MQTT at all. I could probably get one of those MQTT plugins working, but I'm not sure how stable they are. I hate installing unstable plugins and having them crash LUUP. I need to maintain a positive WAF (Wife Acceptance Factor), and broken HA doesn't help with that. 🙂
    I guess node-red is the best option for you
  • Hi
    I start build MySensors Gateway on my Rpi3. I use radio RFM69HW and connected it as show on page to GPIO.
    https://www.mysensors.org/build/raspberry
    I build it by command:
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB1
    Then make. But in Domoticz when i run and add to hardware i have error:
    2017-12-27 17:05:09.419 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:05:09.419 MySensors: Gateway Version: 2.2.0-rc.2
    2017-12-27 17:05:09.420 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:05:10.419 MySensors: retrying in 30 seconds...
    2017-12-27 17:05:39.422 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:05:39.422 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:05:40.422 MySensors: retrying in 30 seconds...
    2017-12-27 17:06:09.425 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:06:09.425 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:06:10.425 MySensors: retrying in 30 seconds...
    2017-12-27 17:06:39.427 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:06:39.428 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:06:40.428 MySensors: retrying in 30 seconds...
    2017-12-27 17:07:09.430 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:07:09.430 Error: Serial Port closed!... Error: End of file
    port ttyUSB1 is empty as i check.
    Please help me where is the problem...
    @pepson what output did you get when you tested the gateway?
  • mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-rc2
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-rc2
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    @pepson thanks. Nothing strange there. Anything i teresting in var/log/syslog after enabling debug output?
  • Dec 27 21:11:48 domoticz systemd[1]: Stopping User Manager for UID 1000...
    Dec 27 21:11:48 domoticz systemd[715]: Stopped target Default.
    Dec 27 21:11:48 domoticz systemd[715]: Stopped target Basic System.
    Dec 27 21:11:48 domoticz systemd[715]: Stopped target Sockets.
    Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent (access for web browsers).
    Dec 27 21:11:48 domoticz systemd[715]: Stopped target Paths.
    Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
    Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent and passphrase cache.
    Dec 27 21:11:48 domoticz systemd[715]: Stopped target Timers.
    Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent (ssh-agent emulation).
    Dec 27 21:11:48 domoticz systemd[715]: Reached target Shutdown.
    Dec 27 21:11:48 domoticz systemd[715]: Starting Exit the Session...
    Dec 27 21:11:48 domoticz systemd[715]: Received SIGRTMIN+24 from PID 800 (kill).
    Dec 27 21:11:48 domoticz systemd[1]: Stopped User Manager for UID 1000.
    Dec 27 21:11:48 domoticz systemd[1]: Removed slice User Slice of pi.
    Dec 27 21:11:54 domoticz systemd[1]: Stopping Save/Restore Sound Card State...
    Dec 27 21:11:54 domoticz systemd[1]: Unmounting RPC Pipe File System...
    Dec 27 21:11:54 domoticz systemd[1]: Stopped target Graphical Interface.
    Dec 27 21:12:27 domoticz systemd-modules-load[125]: Inserted module 'i2c_dev'
    Dec 27 21:12:27 domoticz fake-hwclock[115]: Wed 27 Dec 20:12:25 UTC 2017
    Dec 27 21:12:27 domoticz systemd[1]: Mounted Configuration File System.
    Dec 27 21:12:27 domoticz systemd[1]: Started Apply Kernel Variables.
    Dec 27 21:12:27 domoticz systemd-fsck[127]: e2fsck 1.43.4 (31-Jan-2017)
    Dec 27 21:12:27 domoticz systemd[1]: Started Create Static Device Nodes in /dev.
    Dec 27 21:12:27 domoticz systemd[1]: Starting udev Kernel Device Manager...
    Dec 27 21:12:27 domoticz systemd-fsck[127]: rootfs: clean, 54121/474240 files, 431837/1933824 blocks
    Dec 27 21:12:27 domoticz systemd[1]: Started File System Check on Root Device.
    Dec 27 21:12:27 domoticz systemd[1]: Starting Remount Root and Kernel File Systems...
    Dec 27 21:12:27 domoticz systemd[1]: Started Remount Root and Kernel File Systems.
    Dec 27 21:12:27 domoticz systemd[1]: Starting Load/Save Random Seed...
    Dec 27 21:12:27 domoticz systemd[1]: Starting udev Coldplug all Devices...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Flush Journal to Persistent Storage...
    Dec 27 21:12:27 domoticz systemd[1]: Started Flush Journal to Persistent Storage.
    Dec 27 21:12:27 domoticz systemd[1]: Started Load/Save Random Seed.
    Dec 27 21:12:27 domoticz systemd[1]: Started udev Kernel Device Manager.
    Dec 27 21:12:27 domoticz systemd[1]: Started Set the console keyboard layout.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Local File Systems (Pre).
    Dec 27 21:12:27 domoticz systemd[1]: Started udev Coldplug all Devices.
    Dec 27 21:12:27 domoticz systemd[1]: Starting Show Plymouth Boot Screen...
    Dec 27 21:12:27 domoticz systemd[1]: Received SIGRTMIN+20 from PID 190 (plymouthd).
    Dec 27 21:12:27 domoticz systemd[1]: Started Show Plymouth Boot Screen.
    Dec 27 21:12:27 domoticz systemd[1]: Found device /dev/disk/by-partuuid/e80766f2-01.
    Dec 27 21:12:27 domoticz systemd[1]: Starting File System Check on /dev/disk/by-partuuid/e80766f2-01...
    Dec 27 21:12:27 domoticz systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Encrypted Volumes.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Paths.
    Dec 27 21:12:27 domoticz mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
    Dec 27 21:12:27 domoticz mtp-probe: bus: 1, device: 3 was not an MTP device
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Sound Card.
    Dec 27 21:12:27 domoticz systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Dec 27 21:12:27 domoticz systemd[1]: Starting Load/Save RF Kill Switch Status...
    Dec 27 21:12:27 domoticz systemd-fsck[227]: fsck.fat 4.1 (2017-01-24)
    Dec 27 21:12:27 domoticz systemd-fsck[227]: /dev/mmcblk0p1: 150 files, 42691/83705 clusters
    Dec 27 21:12:27 domoticz systemd[1]: Started File System Check on /dev/disk/by-partuuid/e80766f2-01.
    Dec 27 21:12:27 domoticz systemd[1]: Mounting /boot...
    Dec 27 21:12:27 domoticz systemd[1]: Started Load/Save RF Kill Switch Status.
    Dec 27 21:12:27 domoticz systemd[1]: Mounted /boot.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Local File Systems.
    Dec 27 21:12:27 domoticz systemd[1]: Starting Preprocess NFS configuration...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Set console font and keymap...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Raise network interfaces...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Create Volatile Files and Directories...
    Dec 27 21:12:27 domoticz systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
    Dec 27 21:12:27 domoticz systemd[1]: Started Preprocess NFS configuration.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target NFS client services.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Remote File Systems (Pre).
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Remote File Systems.
    Dec 27 21:12:27 domoticz systemd[1]: Started Set console font and keymap.
    Dec 27 21:12:27 domoticz systemd[1]: Started Create Volatile Files and Directories.
    Dec 27 21:12:27 domoticz systemd[1]: Starting Network Time Synchronization...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Update UTMP about System Boot/Shutdown...
    Dec 27 21:12:27 domoticz systemd[1]: Started Update UTMP about System Boot/Shutdown.
    Dec 27 21:12:27 domoticz systemd[1]: Started Raise network interfaces.
    Dec 27 21:12:27 domoticz systemd[1]: Started Network Time Synchronization.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target System Initialization.
    Dec 27 21:12:27 domoticz systemd[1]: Started Daily Cleanup of Temporary Directories.
    Dec 27 21:12:27 domoticz systemd[1]: Listening on D-Bus System Message Bus Socket.
    Dec 27 21:12:27 domoticz systemd[1]: Listening on triggerhappy.socket.
    Dec 27 21:12:27 domoticz systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Sockets.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Basic System.
    Dec 27 21:12:27 domoticz systemd[1]: Starting LSB: Start OWFS at boot time...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Login Service...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
    Dec 27 21:12:27 domoticz systemd[1]: Started Regular background program processing daemon.
    Dec 27 21:12:27 domoticz systemd[1]: Starting LSB: Autogenerate and use a swap file...
    Dec 27 21:12:27 domoticz systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
    Dec 27 21:12:27 domoticz systemd[1]: Starting triggerhappy global hotkey daemon...
    Dec 27 21:12:27 domoticz systemd[1]: Started MySensors Gateway daemon.
    Dec 27 21:12:27 domoticz systemd[1]: Starting System Logging Service...
    Dec 27 21:12:27 domoticz systemd[1]: Starting Save/Restore Sound Card State...
    Dec 27 21:12:27 domoticz systemd[1]: Starting dhcpcd on all interfaces...
    Dec 27 21:12:27 domoticz systemd[1]: Started D-Bus System Message Bus.
    Dec 27 21:12:27 domoticz cron[328]: (CRON) INFO (pidfile fd = 3)
    Dec 27 21:12:27 domoticz cron[328]: (CRON) INFO (Running @reboot jobs)
    Dec 27 21:12:27 domoticz thd[331]: Found socket passed from systemd
    Dec 27 21:12:27 domoticz dhcpcd[339]: dev: loaded udev
    Dec 27 21:12:27 domoticz mysgw: Starting gateway...
    Dec 27 21:12:27 domoticz mysgw: Protocol version - 2.2.0-rc.2
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully dropped root privileges.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: avahi-daemon 0.6.32 starting up.
    Dec 27 21:12:27 domoticz liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="334" x-info="http://www.rsyslog.com"] start
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Booting Linux on physical CPU 0x0
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Linux version 4.9.70-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1068 SMP Mon Dec 18 22:12:55 GMT 2017
    Dec 27 21:12:27 domoticz kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    Dec 27 21:12:27 domoticz kernel: [    0.000000] CPU: div instructions available: patching division code
    Dec 27 21:12:27 domoticz kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Dec 27 21:12:27 domoticz kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
    Dec 27 21:12:27 domoticz kernel: [    0.000000] cma: Reserved 8 MiB at 0x3dc00000
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Memory policy: Data cache writealloc
    Dec 27 21:12:27 domoticz kernel: [    0.000000] On node 0 totalpages: 255488
    Dec 27 21:12:27 domoticz kernel: [    0.000000] free_area_init_node: node 0, pgdat 80c6f400, node_mem_map bd336000
    Dec 27 21:12:27 domoticz kernel: [    0.000000]   Normal zone: 2246 pages used for memmap
    Dec 27 21:12:27 domoticz kernel: [    0.000000]   Normal zone: 0 pages reserved
    Dec 27 21:12:27 domoticz kernel: [    0.000000]   Normal zone: 255488 pages, LIFO batch:31
    Dec 27 21:12:27 domoticz kernel: [    0.000000] percpu: Embedded 14 pages/cpu @be5b0000 s25600 r8192 d23552 u57344
    Dec 27 21:12:27 domoticz kernel: [    0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
    Dec 27 21:12:27 domoticz kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 253242
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e80766f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    Dec 27 21:12:27 domoticz kernel: [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Memory: 991096K/1021952K available (7168K kernel code, 486K rwdata, 2012K rodata, 1024K init, 770K bss, 22664K reserved, 8192K cma-reserved)
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Virtual kernel memory layout:
    Dec 27 21:12:27 domoticz kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]     vmalloc : 0xbe800000 - 0xff800000   (1040 MB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbe600000   ( 998 MB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]       .data : 0x80c00000 - 0x80c798bc   ( 487 kB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000]        .bss : 0x80c7b000 - 0x80d3b9a4   ( 771 kB)
    Dec 27 21:12:27 domoticz kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    Dec 27 21:12:27 domoticz kernel: [    0.000000] Hierarchical RCU implementation.
    Dec 27 21:12:27 domoticz kernel: [    0.000000] 	Build-time adjustment of leaf fanout to 32.
    Dec 27 21:12:27 domoticz kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
    Dec 27 21:12:27 domoticz kernel: [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
    Dec 27 21:12:27 domoticz kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    Dec 27 21:12:27 domoticz kernel: [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    Dec 27 21:12:27 domoticz kernel: [    0.000022] Switching to timer-based delay loop, resolution 52ns
    Dec 27 21:12:27 domoticz kernel: [    0.000304] Console: colour dummy device 80x30
    Dec 27 21:12:27 domoticz kernel: [    0.001203] console [tty1] enabled
    Dec 27 21:12:27 domoticz kernel: [    0.001250] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    Dec 27 21:12:27 domoticz kernel: [    0.001318] pid_max: default: 32768 minimum: 301
    Dec 27 21:12:27 domoticz kernel: [    0.001653] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.001696] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.002734] Disabling memory control group subsystem
    Dec 27 21:12:27 domoticz kernel: [    0.002838] CPU: Testing write buffer coherency: ok
    Dec 27 21:12:27 domoticz kernel: [    0.002901] ftrace: allocating 22400 entries in 66 pages
    Dec 27 21:12:27 domoticz kernel: [    0.049380] CPU0: update cpu_capacity 1024
    Dec 27 21:12:27 domoticz kernel: [    0.049432] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Dec 27 21:12:27 domoticz kernel: [    0.049493] Setting up static identity map for 0x100000 - 0x100034
    Dec 27 21:12:27 domoticz kernel: [    0.051403] CPU1: update cpu_capacity 1024
    Dec 27 21:12:27 domoticz kernel: [    0.051410] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    Dec 27 21:12:27 domoticz kernel: [    0.052106] CPU2: update cpu_capacity 1024
    Dec 27 21:12:27 domoticz kernel: [    0.052113] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    Dec 27 21:12:27 domoticz kernel: [    0.052791] CPU3: update cpu_capacity 1024
    Dec 27 21:12:27 domoticz kernel: [    0.052798] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    Dec 27 21:12:27 domoticz kernel: [    0.052887] Brought up 4 CPUs
    Dec 27 21:12:27 domoticz kernel: [    0.053059] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    Dec 27 21:12:27 domoticz kernel: [    0.053089] CPU: All CPU(s) started in HYP mode.
    Dec 27 21:12:27 domoticz kernel: [    0.053115] CPU: Virtualization extensions available.
    Dec 27 21:12:27 domoticz kernel: [    0.053944] devtmpfs: initialized
    Dec 27 21:12:27 domoticz kernel: [    0.065214] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    Dec 27 21:12:27 domoticz kernel: [    0.065538] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    Dec 27 21:12:27 domoticz kernel: [    0.065601] futex hash table entries: 1024 (order: 4, 65536 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.066163] pinctrl core: initialized pinctrl subsystem
    Dec 27 21:12:27 domoticz kernel: [    0.067095] NET: Registered protocol family 16
    Dec 27 21:12:27 domoticz kernel: [    0.069334] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    Dec 27 21:12:27 domoticz kernel: [    0.078209] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    Dec 27 21:12:27 domoticz kernel: [    0.078258] hw-breakpoint: maximum watchpoint size is 8 bytes.
    Dec 27 21:12:27 domoticz kernel: [    0.078436] Serial: AMBA PL011 UART driver
    Dec 27 21:12:27 domoticz kernel: [    0.080361] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    Dec 27 21:12:27 domoticz kernel: [    0.080925] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
    Dec 27 21:12:27 domoticz kernel: [    0.150223] bcm2835-dma 3f007000.dma: DMA legacy API manager at be80f000, dmachans=0x1
    Dec 27 21:12:27 domoticz kernel: [    0.152120] SCSI subsystem initialized
    Dec 27 21:12:27 domoticz kernel: [    0.152301] usbcore: registered new interface driver usbfs
    Dec 27 21:12:27 domoticz kernel: [    0.152411] usbcore: registered new interface driver hub
    Dec 27 21:12:27 domoticz kernel: [    0.152527] usbcore: registered new device driver usb
    Dec 27 21:12:27 domoticz kernel: [    0.159194] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-12-01 16:17
    Dec 27 21:12:27 domoticz kernel: [    0.160594] clocksource: Switched to clocksource arch_sys_counter
    Dec 27 21:12:27 domoticz kernel: [    0.207210] VFS: Disk quotas dquot_6.6.0
    Dec 27 21:12:27 domoticz kernel: [    0.207324] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.207555] FS-Cache: Loaded
    Dec 27 21:12:27 domoticz kernel: [    0.207822] CacheFiles: Loaded
    Dec 27 21:12:27 domoticz kernel: [    0.220056] NET: Registered protocol family 2
    Dec 27 21:12:27 domoticz kernel: [    0.220996] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.221133] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.221344] TCP: Hash tables configured (established 8192 bind 8192)
    Dec 27 21:12:27 domoticz kernel: [    0.221457] UDP hash table entries: 512 (order: 2, 16384 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.221525] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    Dec 27 21:12:27 domoticz kernel: [    0.221756] NET: Registered protocol family 1
    Dec 27 21:12:27 domoticz kernel: [    0.222236] RPC: Registered named UNIX socket transport module.
    Dec 27 21:12:27 domoticz kernel: [    0.222269] RPC: Registered udp transport module.
    Dec 27 21:12:27 domoticz kernel: [    0.222297] RPC: Registered tcp transport module.
    Dec 27 21:12:27 domoticz kernel: [    0.222324] RPC: Registered tcp NFSv4.1 backchannel transport module.
    Dec 27 21:12:27 domoticz kernel: [    0.223276] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    Dec 27 21:12:27 domoticz kernel: [    0.225612] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    Dec 27 21:12:27 domoticz kernel: [    0.241781] FS-Cache: Netfs 'nfs' registered for caching
    Dec 27 21:12:27 domoticz kernel: [    0.242797] NFS: Registering the id_resolver key type
    Dec 27 21:12:27 domoticz kernel: [    0.242860] Key type id_resolver registered
    Dec 27 21:12:27 domoticz kernel: [    0.242888] Key type id_legacy registered
    Dec 27 21:12:27 domoticz kernel: [    0.245340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
    Dec 27 21:12:27 domoticz kernel: [    0.245505] io scheduler noop registered
    Dec 27 21:12:27 domoticz kernel: [    0.245535] io scheduler deadline registered (default)
    Dec 27 21:12:27 domoticz kernel: [    0.245816] io scheduler cfq registered
    Dec 27 21:12:27 domoticz kernel: [    0.251562] BCM2708FB: allocated DMA memory fdd10000
    Dec 27 21:12:27 domoticz kernel: [    0.251615] BCM2708FB: allocated DMA channel 0 @ be80f000
    Dec 27 21:12:27 domoticz kernel: [    0.256725] Console: switching to colour frame buffer device 82x26
    Dec 27 21:12:27 domoticz kernel: [    0.261582] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    Dec 27 21:12:27 domoticz kernel: [    0.264453] bcm2835-rng 3f104000.rng: hwrng registered
    Dec 27 21:12:27 domoticz kernel: [    0.265902] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
    Dec 27 21:12:27 domoticz kernel: [    0.269187] vc-sm: Videocore shared memory driver
    Dec 27 21:12:27 domoticz kernel: [    0.285964] brd: module loaded
    Dec 27 21:12:27 domoticz kernel: [    0.296350] loop: module loaded
    Dec 27 21:12:27 domoticz kernel: [    0.297737] Loading iSCSI transport class v2.0-870.
    Dec 27 21:12:27 domoticz kernel: [    0.299603] usbcore: registered new interface driver smsc95xx
    Dec 27 21:12:27 domoticz kernel: [    0.300990] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    Dec 27 21:12:27 domoticz kernel: [    0.530382] Core Release: 2.80a
    Dec 27 21:12:27 domoticz kernel: [    0.531748] Setting default values for core params
    Dec 27 21:12:27 domoticz kernel: [    0.533143] Finished setting default values for core params
    Dec 27 21:12:27 domoticz kernel: [    0.734883] Using Buffer DMA mode
    Dec 27 21:12:27 domoticz kernel: [    0.736187] Periodic Transfer Interrupt Enhancement - disabled
    Dec 27 21:12:27 domoticz kernel: [    0.737532] Multiprocessor Interrupt Enhancement - disabled
    Dec 27 21:12:27 domoticz kernel: [    0.738902] OTG VER PARAM: 0, OTG VER FLAG: 0
    Dec 27 21:12:27 domoticz kernel: [    0.740281] Dedicated Tx FIFOs mode
    Dec 27 21:12:27 domoticz kernel: [    0.742000] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbdd04000 dma = 0xfdd04000 len=9024
    Dec 27 21:12:27 domoticz kernel: [    0.744889] FIQ FSM acceleration enabled for :
    Dec 27 21:12:27 domoticz kernel: [    0.744889] Non-periodic Split Transactions
    Dec 27 21:12:27 domoticz kernel: [    0.744889] Periodic Split Transactions
    Dec 27 21:12:27 domoticz kernel: [    0.744889] High-Speed Isochronous Endpoints
    Dec 27 21:12:27 domoticz kernel: [    0.744889] Interrupt/Control Split Transaction hack enabled
    Dec 27 21:12:27 domoticz kernel: [    0.751657] dwc_otg: Microframe scheduler enabled
    Dec 27 21:12:27 domoticz kernel: [    0.751707] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80590aa0
    Dec 27 21:12:27 domoticz kernel: [    0.753058] WARN::hcd_init_fiq:460: FIQ ASM at 0x80590e10 length 36
    Dec 27 21:12:27 domoticz kernel: [    0.754417] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbe87a000
    Dec 27 21:12:27 domoticz kernel: [    0.755813] dwc_otg 3f980000.usb: DWC OTG Controller
    Dec 27 21:12:27 domoticz kernel: [    0.757179] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    Dec 27 21:12:27 domoticz kernel: [    0.758567] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
    Dec 27 21:12:27 domoticz kernel: [    0.759940] Init: Port Power? op_state=1
    Dec 27 21:12:27 domoticz kernel: [    0.761277] Init: Power Port (0)
    Dec 27 21:12:27 domoticz kernel: [    0.762752] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    Dec 27 21:12:27 domoticz kernel: [    0.764101] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Dec 27 21:12:27 domoticz kernel: [    0.765440] usb usb1: Product: DWC OTG Controller
    Dec 27 21:12:27 domoticz kernel: [    0.766751] usb usb1: Manufacturer: Linux 4.9.70-v7+ dwc_otg_hcd
    Dec 27 21:12:27 domoticz kernel: [    0.768074] usb usb1: SerialNumber: 3f980000.usb
    Dec 27 21:12:27 domoticz kernel: [    0.770222] hub 1-0:1.0: USB hub found
    Dec 27 21:12:27 domoticz kernel: [    0.771542] hub 1-0:1.0: 1 port detected
    Dec 27 21:12:27 domoticz kernel: [    0.773419] dwc_otg: FIQ enabled
    Dec 27 21:12:27 domoticz kernel: [    0.773423] dwc_otg: NAK holdoff enabled
    Dec 27 21:12:27 domoticz kernel: [    0.773427] dwc_otg: FIQ split-transaction FSM enabled
    Dec 27 21:12:27 domoticz kernel: [    0.773440] Module dwc_common_port init
    Dec 27 21:12:27 domoticz kernel: [    0.773654] usbcore: registered new interface driver usb-storage
    Dec 27 21:12:27 domoticz kernel: [    0.775105] mousedev: PS/2 mouse device common for all mice
    Dec 27 21:12:27 domoticz kernel: [    0.777302] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
    Dec 27 21:12:27 domoticz kernel: [    0.778894] bcm2835-cpufreq: min=600000 max=1200000
    Dec 27 21:12:27 domoticz kernel: [    0.780631] sdhci: Secure Digital Host Controller Interface driver
    Dec 27 21:12:27 domoticz kernel: [    0.781980] sdhci: Copyright(c) Pierre Ossman
    Dec 27 21:12:27 domoticz kernel: [    0.783559] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
    Dec 27 21:12:27 domoticz kernel: [    0.787123] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
    Dec 27 21:12:27 domoticz kernel: [    0.788642] sdhci-pltfm: SDHCI platform and OF driver helper
    Dec 27 21:12:27 domoticz kernel: [    0.792679] ledtrig-cpu: registered to indicate activity on CPUs
    Dec 27 21:12:27 domoticz kernel: [    0.794296] hidraw: raw HID events driver (C) Jiri Kosina
    Dec 27 21:12:27 domoticz kernel: [    0.795907] usbcore: registered new interface driver usbhid
    Dec 27 21:12:27 domoticz kernel: [    0.797338] usbhid: USB HID core driver
    Dec 27 21:12:27 domoticz kernel: [    0.799562] vchiq: vchiq_init_state: slot_zero = 0xbdd80000, is_master = 0
    Dec 27 21:12:27 domoticz kernel: [    0.802307] [vc_sm_connected_init]: start
    Dec 27 21:12:27 domoticz kernel: [    0.805755] vc_vchi_sm_init: failed to open VCHI service (-1)
    Dec 27 21:12:27 domoticz kernel: [    0.805854] [vc_sm_connected_init]: failed to initialize shared memory service
    Dec 27 21:12:27 domoticz kernel: [    0.808797] [vc_sm_connected_init]: end - returning -1
    Dec 27 21:12:27 domoticz kernel: [    0.810708] Initializing XFRM netlink socket
    Dec 27 21:12:27 domoticz kernel: [    0.812256] NET: Registered protocol family 17
    Dec 27 21:12:27 domoticz kernel: [    0.813912] Key type dns_resolver registered
    Dec 27 21:12:27 domoticz kernel: [    0.815800] Registering SWP/SWPB emulation handler
    Dec 27 21:12:27 domoticz kernel: [    0.818025] registered taskstats version 1
    Dec 27 21:12:27 domoticz kernel: [    0.824815] uart-pl011 3f201000.serial: cts_event_workaround enabled
    Dec 27 21:12:27 domoticz kernel: [    0.826406] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
    Dec 27 21:12:27 domoticz kernel: [    0.831073] sdhost: log_buf @ bdd07000 (fdd07000)
    Dec 27 21:12:27 domoticz kernel: [    0.910624] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    Dec 27 21:12:27 domoticz kernel: [    0.914335] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
    Dec 27 21:12:27 domoticz kernel: [    0.915839] mmc-bcm2835 3f300000.mmc: DMA channel allocated
    Dec 27 21:12:27 domoticz kernel: [    0.987418] mmc0: host does not support reading read-only switch, assuming write-enable
    Dec 27 21:12:27 domoticz kernel: [    0.990719] of_cfs_init
    Dec 27 21:12:27 domoticz kernel: [    0.990779] Indeed it is in host mode hprt0 = 00021501
    Dec 27 21:12:27 domoticz kernel: [    0.993836] of_cfs_init: OK
    Dec 27 21:12:27 domoticz kernel: [    0.995709] Waiting for root device PARTUUID=e80766f2-02...
    Dec 27 21:12:27 domoticz kernel: [    1.051010] mmc0: new high speed SDHC card at address 0001
    Dec 27 21:12:27 domoticz kernel: [    1.056145] mmcblk0: mmc0:0001 00000 14.9 GiB
    Dec 27 21:12:27 domoticz kernel: [    1.058962]  mmcblk0: p1 p2
    Dec 27 21:12:27 domoticz kernel: [    1.069058] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    Dec 27 21:12:27 domoticz kernel: [    1.072012] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Dec 27 21:12:27 domoticz kernel: [    1.072437] random: fast init done
    Dec 27 21:12:27 domoticz kernel: [    1.076238] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Dec 27 21:12:27 domoticz kernel: [    1.080392] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    Dec 27 21:12:27 domoticz kernel: [    1.121517] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    Dec 27 21:12:27 domoticz kernel: [    1.124187] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    Dec 27 21:12:27 domoticz kernel: [    1.133254] devtmpfs: mounted
    Dec 27 21:12:27 domoticz kernel: [    1.136413] Freeing unused kernel memory: 1024K
    Dec 27 21:12:27 domoticz kernel: [    1.173457] mmc1: new high speed SDIO card at address 0001
    Dec 27 21:12:27 domoticz kernel: [    1.190641] usb 1-1: new high-speed USB device number 2 using dwc_otg
    Dec 27 21:12:27 domoticz kernel: [    1.192168] Indeed it is in host mode hprt0 = 00001101
    Dec 27 21:12:27 domoticz kernel: [    1.420944] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
    Dec 27 21:12:27 domoticz kernel: [    1.422402] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    Dec 27 21:12:27 domoticz kernel: [    1.424675] hub 1-1:1.0: USB hub found
    Dec 27 21:12:27 domoticz kernel: [    1.426166] hub 1-1:1.0: 5 ports detected
    Dec 27 21:12:27 domoticz kernel: [    1.694677] NET: Registered protocol family 10
    Dec 27 21:12:27 domoticz kernel: [    1.706057] ip_tables: (C) 2000-2006 Netfilter Core Team
    Dec 27 21:12:27 domoticz kernel: [    1.750624] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    Dec 27 21:12:27 domoticz kernel: [    1.881013] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
    Dec 27 21:12:27 domoticz kernel: [    1.882603] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    Dec 27 21:12:27 domoticz kernel: [    1.886946] smsc95xx v1.0.5
    Dec 27 21:12:27 domoticz kernel: [    1.984610] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d4:81:2a
    Dec 27 21:12:27 domoticz kernel: [    2.353008] i2c /dev entries driver
  • Dec 27 21:12:27 domoticz kernel: [    2.675918] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Dec 27 21:12:27 domoticz kernel: [    3.109172] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    Dec 27 21:12:27 domoticz kernel: [    3.407342] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    Dec 27 21:12:27 domoticz kernel: [    3.413382] usbcore: registered new interface driver brcmfmac
    Dec 27 21:12:27 domoticz kernel: [    3.601930] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
    Dec 27 21:12:27 domoticz kernel: [    3.602685] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully called chroot().
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully dropped remaining capabilities.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: No service file found in /etc/avahi/services.
    Dec 27 21:12:27 domoticz systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target System Time Synchronized.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Network interface enumeration completed.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Server startup complete. Host name is domoticz.local. Local service cookie is 87145466.
    Dec 27 21:12:27 domoticz systemd[1]: apt-daily.timer: Adding 5h 31min 57.980339s random time.
    Dec 27 21:12:27 domoticz systemd[1]: Started Daily apt download activities.
    Dec 27 21:12:27 domoticz systemd[1]: apt-daily-upgrade.timer: Adding 2min 40.737204s random time.
    Dec 27 21:12:27 domoticz systemd[1]: Started Daily apt upgrade and clean activities.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Timers.
    Dec 27 21:12:27 domoticz systemd[1]: Started triggerhappy global hotkey daemon.
    Dec 27 21:12:27 domoticz systemd[1]: Started System Logging Service.
    Dec 27 21:12:27 domoticz systemd[1]: Started Save/Restore Sound Card State.
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: starting wpa_supplicant
    Dec 27 21:12:27 domoticz dhcpcd-run-hooks[374]: wlan0: starting wpa_supplicant
    Dec 27 21:12:27 domoticz systemd[1]: Started Login Service.
    Dec 27 21:12:27 domoticz dphys-swapfile[329]: Starting dphys-swapfile swapfile setup ...
    Dec 27 21:12:27 domoticz raspi-config[330]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
    Dec 27 21:12:27 domoticz raspi-config[330]:  No. Switching to ondemand scaling governor.
    Dec 27 21:12:27 domoticz systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
    Dec 27 21:12:27 domoticz OWFS[375]: DEFAULT: owlib.c:(208) Cannot open USB bus master
    Dec 27 21:12:27 domoticz OWFS[375]: DEFAULT: owlib.c:(52) No valid 1-wire buses found
    Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Control process exited, code=exited status=1
    Dec 27 21:12:27 domoticz systemd[1]: Failed to start LSB: Start OWFS at boot time.
    Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Unit entered failed state.
    Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Failed with result 'exit-code'.
    Dec 27 21:12:27 domoticz dphys-swapfile[329]: want /var/swap=100MByte, checking existing: keeping it
    Dec 27 21:12:27 domoticz kernel: [    4.979888] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    Dec 27 21:12:27 domoticz kernel: [    4.979897] brcmfmac: power management disabled
    Dec 27 21:12:27 domoticz kernel: [    4.987898] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
    Dec 27 21:12:27 domoticz dphys-swapfile[329]: done.
    Dec 27 21:12:27 domoticz systemd[1]: Started LSB: Autogenerate and use a swap file.
    Dec 27 21:12:27 domoticz dhcpcd[339]: eth0: waiting for carrier
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: waiting for carrier
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: carrier acquired
    Dec 27 21:12:27 domoticz kernel: [    5.321930] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    Dec 27 21:12:27 domoticz kernel: [    5.322223] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Dec 27 21:12:27 domoticz dhcpcd[339]: DUID 00:01:00:01:21:b0:d9:d9:b8:27:eb:81:d4:7f
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: IAID eb:81:d4:7f
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: adding address fe80::6bd:3cc7:2b64:c842
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: carrier lost
    Dec 27 21:12:28 domoticz dhcpcd[339]: wlan0: deleting address fe80::6bd:3cc7:2b64:c842
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: carrier acquired
    Dec 27 21:12:29 domoticz kernel: [    6.725223] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Dec 27 21:12:29 domoticz kernel: [    6.726375] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: IAID eb:d4:81:2a
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: adding address fe80::7a80:6e8f:27f0:4005
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: probing address 192.168.13.5/24
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: soliciting an IPv6 router
    Dec 27 21:12:30 domoticz avahi-daemon[327]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::7a80:6e8f:27f0:4005.
    Dec 27 21:12:30 domoticz avahi-daemon[327]: New relevant interface eth0.IPv6 for mDNS.
    Dec 27 21:12:30 domoticz avahi-daemon[327]: Registering new address record for fe80::7a80:6e8f:27f0:4005 on eth0.*.
    Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: using static address 192.168.13.5/24
    Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: adding route to 192.168.13.0/24
    Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: adding default route via 192.168.13.1
    Dec 27 21:12:34 domoticz avahi-daemon[327]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.13.5.
    Dec 27 21:12:34 domoticz avahi-daemon[327]: New relevant interface eth0.IPv4 for mDNS.
    Dec 27 21:12:34 domoticz avahi-daemon[327]: Registering new address record for 192.168.13.5 on eth0.IPv4.
    Dec 27 21:12:34 domoticz dhcpcd[339]: forked to background, child pid 470
    Dec 27 21:12:34 domoticz systemd[1]: Started dhcpcd on all interfaces.
    Dec 27 21:12:34 domoticz systemd[1]: Reached target Network.
    Dec 27 21:12:34 domoticz systemd[1]: Reached target Network is Online.
    Dec 27 21:12:34 domoticz systemd[1]: Starting LSB: Home Automation System...
    Dec 27 21:12:34 domoticz systemd[1]: Starting /etc/rc.local Compatibility...
    Dec 27 21:12:34 domoticz systemd[1]: Starting Permit User Sessions...
    Dec 27 21:12:34 domoticz systemd[1]: Starting OpenBSD Secure Shell server...
    Dec 27 21:12:34 domoticz systemd[1]: Started /etc/rc.local Compatibility.
    Dec 27 21:12:34 domoticz systemd[1]: Started Permit User Sessions.
    Dec 27 21:12:34 domoticz systemd[1]: Starting Hold until boot process finishes up...
    Dec 27 21:12:34 domoticz systemd[1]: Starting Terminate Plymouth Boot Screen...
    Dec 27 21:12:34 domoticz systemd[1]: Received SIGRTMIN+21 from PID 190 (plymouthd).
    Dec 27 21:12:34 domoticz systemd[1]: Started Hold until boot process finishes up.
    Dec 27 21:12:34 domoticz systemd[1]: Started Terminate Plymouth Boot Screen.
    Dec 27 21:12:34 domoticz systemd[1]: Started Getty on tty1.
    Dec 27 21:12:34 domoticz systemd[1]: Reached target Login Prompts.
    Dec 27 21:12:34 domoticz systemd[1]: Started OpenBSD Secure Shell server.
    Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.467  Domoticz V3.8796 (c)2012-2017 GizMoCuz
    Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.467  Build Hash: 2d99bbbc, Date: 2017-12-24 07:06:53
    Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.468  Startup Path: /home/pi/domoticz/
    Dec 27 21:12:35 domoticz domoticz.sh[471]: domoticz: Domoticz is starting up....
    Dec 27 21:12:35 domoticz domoticz: Domoticz is starting up....
    Dec 27 21:12:35 domoticz domoticz: Domoticz running...
    Dec 27 21:12:35 domoticz systemd[1]: Started LSB: Home Automation System.
    Dec 27 21:12:35 domoticz systemd[1]: Reached target Multi-User System.
    Dec 27 21:12:35 domoticz systemd[1]: Reached target Graphical Interface.
    Dec 27 21:12:35 domoticz systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Dec 27 21:12:35 domoticz systemd[1]: Started Update UTMP about System Runlevel Changes.
    Dec 27 21:12:35 domoticz systemd[1]: Startup finished in 1.510s (kernel) + 11.498s (userspace) = 13.009s.
    Dec 27 21:12:38 domoticz kernel: [   15.710546] uart-pl011 3f201000.serial: no DMA platform data
    Dec 27 21:12:42 domoticz dhcpcd[470]: eth0: no IPv6 Routers available
    Dec 27 21:12:53 domoticz systemd[1]: Created slice User Slice of pi.
    Dec 27 21:12:53 domoticz systemd[1]: Starting User Manager for UID 1000...
    Dec 27 21:12:53 domoticz systemd[1]: Started Session c1 of user pi.
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent and passphrase cache.
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent (access for web browsers).
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Paths.
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Sockets.
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Timers.
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Basic System.
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Default.
    Dec 27 21:12:53 domoticz systemd[535]: Startup finished in 48ms.
    Dec 27 21:12:53 domoticz systemd[1]: Started User Manager for UID 1000.
    Dec 27 21:13:03 domoticz systemd[535]: Time has been changed
    Dec 27 21:13:03 domoticz systemd[1]: Time has been changed
    Dec 27 21:13:03 domoticz systemd-timesyncd[285]: Synchronized to time server 195.189.85.132:123 (2.debian.pool.ntp.org).
    Dec 27 21:13:03 domoticz systemd[1]: apt-daily.timer: Adding 8h 6min 59.681187s random time.
    Dec 27 21:13:03 domoticz systemd[1]: apt-daily-upgrade.timer: Adding 32min 42.364143s random time.```
    @pepson ok, so mysgw does at least log to syslog, as seen here
    but nothing else. I expected there to be more information, but maybe I'm just not familiar enough with the raspberry pi gateway.
  • Yes but only one time read and then start the problem.
    Can you try building the ethernet gateway instead?
  • Ethernet work ok. But i better want serial and found bug and solution why not working serial...
    I just wanted to make sure at least it was working OK as ethernet.
  • Problem is only on serial...
  • Please help...
  • @pepson Just a suggestion, but are you sure the Pi3 is looking at ttyUSB1, ie have you confirmed this is the Gateway serial connection ?
    I am using direct serial connection to the pi3 GPIO as ttySO with Domoticz, but when I tried a USB Gateway at one point, the connection was NOT working using the expected ttyUSB quoted. I had to check the tty connections via Putty to establish the actual link...
  • But can you give me commend to build it as you use ttySO ?
  • I build it as ttySO
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttySO
    and i have and info:
    2017-12-28 15:40:21.822 MySensors: Using serial port: /dev/ttyS0
    2017-12-28 15:40:21.832 Error: MySensors: Error opening serial port!
  • Then build as /dev/serial0 and the same problem. This is show in log Domoticz. One read version and port closed.
    2017-12-28 15:48:14.418 MySensors: Using serial port: /dev/serial0
    2017-12-28 15:48:14.418 MySensors: Gateway Version: 2.2.0-rc.2
    2017-12-28 15:48:14.418 Error: Serial Port closed!... Error: End of file
    2017-12-28 15:48:15.418 MySensors: retrying in 30 seconds...
    @pepson could you post your hardware settings in Domoticz? This is what works for me:
    Could you also try building the gateway without rfm69 support, to check if the problem is generic or related to rfm69. Use this:
    ./configure --my-transport=none --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB42
    make && sudo ./bin/mysgw -d
  • Hello
    Thanks for your help. I start from beginning build DOmoticz on my RPi3 with clean latest image. After run in Sudo raspi-config i enable SPI and Serial , then install DOmoticz and now all works OK. Then build Mysensor Gateway and all is ok with no error in Domoticz. Works on /dev/ttyUSB42
  • But how i can build MySensors Gateway on serial with radio RFM69HW but on old version 2.1.1 ?
  • And have next problem... i build sketch on version 2.2.0-rc2 but after write to Arduino Mini Pro he is not connected to my Gateway on RPI3.
    This is sketch. What is wrong ?
       Relay with button sketch
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY 868
    #define MY_IS_RFM69HW
    #define MY_RFM69_NEW_DRIVER
    //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long oldTime = 0;
    unsigned long newTime = 0;
    void setup(){
      debouncer.interval(5);
    void presentation()  {
      sendSketchInfo("1xRelay & Button", "2.2.0-rc2");
      present(CHILD_ID, S_BINARY);
    void loop(){
          uplinkCheckTime = millis();
         else{
          Serial.println(requestState);
      debouncer.update();
        requestTime();
          oldTime = newTime;
      oldValue = value;
    void uplinkCheck() {
        requestTime();
          oldTime = newTime;
      if (firstStart){
        oldTime = time;
        newTime = time;
      else{
      newTime = time;
      Serial.println(time);
  • @pepson Try walking in little steps trying each stage rather than running into new walls then expressing surprise at broken nose, no offence intended 😉
    Gateway and nodes, same platform, same version..... Otherwise they are speaking Chinese and Swedish hoping for somebody to explain the meaning of fubar...
  • I use the same version now 2.2.0-rc2 but when i programmed sketch to node it not connection to Gateway... That i want come back to version 2.1.1 gateway but i dont know how ? Or resolved problem Node 2.2.0-rc2 i stay on this.
    But when run debug gateway show this:
    pi@domoticz:~/MySensors $ sudo ./bin/mysgw -d
    mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: !TSF:SAN:FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:DIS
    mysgw: TSF:TDI:TSL
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    This is sketch 2.2.0-rc2
    #define RFM69_868MHZ
    #define RELAY_ON 1
    #define RELAY_OFF 0
    int oldValue = 0;
    bool state = false;
    bool requestState;
    void setup(){
    void loop(){
         else{
      debouncer.update();
        requestTime();
          oldTime = newTime;
      oldValue = value;
        requestTime();
          oldTime = newTime;
      if (firstStart){
        oldTime = time;
        newTime = time;
      else{
      newTime = time;
  • @pepson Let's try the baby steps I referred to earlier.
    The current stable version of MySensors is 2.1. Those using 2.2 tend to be experienced people versed in programming and experimenting and problem solving, hence it is not an official release.... yet you are using it and asking for solutions... Hello ?
    I am and have been for the last few months using a Pro-Mini with RFM69 as nodes and gateway using 2.1 attached to a Pi3 running Domoticz.... No problems, but slowly coming to understand most of what I am doing...
    I am still on baby steps, I don't mind at all, it works.....
  • Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
  • @pepson As in this page? 2.1.1 - Latest Release ?
    https://www.mysensors.org/download
  • I found bug in Domoticz BETA 8796. No reconized version gateway in HARDWARE. On stable 8153 works with no problem and correct reconized version gateway 2.2.0-rc2...
    And again problem with this:
    CODE: SELECT ALL
    2017-12-28 20:01:32.587 MySensors: retrying in 30 seconds...
    2017-12-28 20:02:08.752 MySensors: Using serial port: /dev/serial0
    2017-12-28 20:02:08.752 MySensors: Gateway Version: 2.2.0-rc.2
    2017-12-28 20:02:08.752 Error: Serial Port closed!... Error: End of file
    2017-12-28 20:02:09.752 MySensors: retrying in 30 seconds...
    2017-12-28 20:02:38.755 MySensors: Using serial port: /dev/serial0
    2017-12-28 20:02:38.755 Error: Serial Port closed!... Error: End of file
    2017-12-28 20:02:39.755 MySensors: retrying in 30 seconds...
    2017-12-28 20:03:08.757 MySensors: Using serial port: /dev/serial0
    2017-12-28 20:03:08.761 Error: Serial Port closed!... Error: End of file
    2017-12-28 20:03:09.758 MySensors: retrying in 30 seconds...
    On beta is problem.
    On stable works correct.
  • @macvictor said in 💬 Building a Raspberry Pi Gateway:
    @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
    Gateway:
    2. make
    3. sudo make install
    10. sudo mysgw --gen-aes-key
    Node:
    #define USE_SOFT_SIGNING
    #define STORE_SOFT_KEY
    #define USER_SOFT_KEY
    #define STORE_SOFT_SERIAL
    #define STORE_AES_KEY
    #define USER_AES_KEY
    EEPROM configuration:
    // Enable NRF24L01 radio type
    // Select soft signing
    #define MY_SIGNING_SOFT
    // Enable node whitelisting
    #define RELAY_ON 1
    #define RELAY_OFF 0
    int oldValue = 0;
    bool state;
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      state = loadState(CHILD_ID);
      debouncer.update();
    //  oldValue = value;
      delay(5000);
      if (message.isAck()) {
        // Change relay state
        // Store state in eeprom
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=105
    15 TSM:FPAR
    2065 !TSM:FPAR:NO REPLY
    2067 TSM:FPAR
    4117 !TSM:FPAR:NO REPLY
    4119 TSM:FPAR
    6169 !TSM:FPAR:NO REPLY
    6171 TSM:FPAR
    8221 !TSM:FPAR:FAIL
    8222 TSM:FAIL:CNT=1
    8224 TSM:FAIL:PDT
    and in gateway i see:
    sudo mysgw -d
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: connected to 127.0.0.1
    mysgw: MQTT connected
    mysgw: !TSF:MSG:PVER,3=2
    mysgw: !TSF:MSG:PVER,1=2
    mysgw: TSF:MSG:REL MSG
    mysgw: !TSF:RTE:240 UNKNOWN
    mysgw: !TSF:MSG:PVER,0=2
    mysgw: !TSF:RTE:233 UNKNOWN
    mysgw: !TSF:RTE:51 UNKNOWN
    Where is problem?
    @macvictor
    But how use itn on RFM69HW ? I dont see to be available #define MY_RFM69_ENABLE_ENCRYPTION... Only for #define MY_RF24_ENABLE_ENCRYPTION...
    @pepson are you asking how to enable encryption on rfm69? (it is a bit unclear what you mean by "itn")
    In that case, see https://www.mysensors.org/apidocs-beta/group__RFM69SettingGrpPub.html#ga17a7a919994e569f078e3787c2c4ecd2
  • @mfalkvidd
    Yes 🙂 Thanks
    BTW
    MySensors gateway as you see is problem with latest beta domoticz.
    @pepson yes I saw that. Thanks for checking. Have you reported the problem to the Domoticz team?
  • @mfalkvidd
    Yes write on forum Domoticz in section BUG
    @pepson great!
    The report is at https://www.domoticz.com/forum/viewtopic.php?f=6&t=21125&sid=e414507bb1ca4596e93cf885047275a9 in case someone needs to find it in the future.
  • Hello!
    I'm trying to "make" on Alpine Linux in a Docker (ok, maybe it's useless, but way interesting!).
    With a Debian image it's ok, but I'd like to use Alpine.
    I get this error:
    g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DSPI_SPIDEV_DEVICE=\"/dev/spidev0.0\"  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
    In file included from /usr/include/sys/ioctl.h:7:0,
                     from drivers/Linux/SPIDEV.cpp:27:
    drivers/Linux/SPIDEV.cpp: In static member function 'static uint8_t SPIDEVClass::transfer(uint8_t)':
    drivers/Linux/SPIDEV.cpp:153:18: error: '_IOC_SIZEBITS' was not declared in this scope
      ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
    drivers/Linux/SPIDEV.cpp: In static member function 'static void SPIDEVClass::transfernb(char*, char*, uint32_t)':
    drivers/Linux/SPIDEV.cpp:175:18: error: '_IOC_SIZEBITS' was not declared in this scope
    make: *** [Makefile:99: build/drivers/Linux/SPIDEV.o] Error 1
    root@local-mysgw-alpine:/opt/MySensors3$ make
    eIn file included from /usr/include/sys/ioctl.h:7:0,
    I'm surely missing a package... but can't state one. Any help?
    @macvictor thanks for your post, it will help me a lot, I'm trying the same way.
    @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
    #include <asm/ioctl.h>
    would solve the problem. Could you try that?
    Was my fault!
    **When copy and past command from word, for example, pay attention that software doesn't substitute the single "-" with a "-" longer. 😵
    I have a word with all commands, to replicate installation very fast. Was my fault (errr... Word fault.... but you understand). Have a nice day!
    I cannot go over the initialization of command.
    RPI3 + Amplified antenna by GertSander (https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01). Power from 5v/3A and power for antenna taken from both 5V via the 3.3v stepper down.
    RPI3 is new, has about 12h (got yesterday).
    Yesterday it did work at first attempt. Today I would replicate so I did delete the uSD and restart over. No way to get the gateway on work.
    I did try 3 amplified antenna + 2 normal. No way.
    I did enable from raspi-config the SPI (and only it).
    It hangs on second line of output.
    These are the logs:
    sineverba@raspberrypi:~/MySensors $ ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
      [OK] SPI driver detected:BCM.
    [OK] Finished.
    sineverba@raspberrypi:~/MySensors $ make
    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
    g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
    g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
    g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
    gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
    g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
    g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
    g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
    g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
    g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
    sineverba@raspberrypi:~/MySensors $ sudo ./bin/mysgw –d
    [sudo] password for sineverba:
    Hi to all,
    I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
    I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
    I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
    Cannot find in documentation how do it on PI3. Thank you very much!
  • @sineverba said in 💬 Building a Raspberry Pi Gateway:
    Hi to all,
    Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
  • @mfalkvidd I'm trying today, but to compile correctly the Docker image I'll have to clone to my github account 😞 or at least locally. My Dockerfile for the "Alpine edition" for Hass.io is simply:
    ARG BUILD_FROM
    ARG BUILD_ARCH
    ARG BUILD_DATE
    ARG BUILD_REF
    ARG BUILD_VERSION
    FROM ${BUILD_FROM}
    ENV CONFIG_PATH=/data/options.json
    ENV APPDIR=/opt/MySensors
    RUN apt-get update && apt-get install -y --force-yes \
        make \
    	 g++ \
    	 git \
    	 && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ~/.cache \
    	 && git clone https://github.com/mysensors/MySensors.git --branch development $APPDIR
    # Copy root filesystem
    COPY rootfs /
    #CMD [ "/run.sh" ]
    I deleted the LABELS 'cause... the data is still too rawly "buried" from others. 👅
    The Configure and Make is in run.sh.
    BTW, I still need to figure out how to start mysgw as service... Mainlyt I'd like to redirect the log: how can I do this safely?
    And... can I use the rx/tx/err led feature on Raspi too (aside being in a Docker) ?
    EDIT: the code add works!
    Another question: I'm not getting far from this... what is it trying to do?
    : Starting gateway...
    : Protocol version - 2.2.0-rc.2
    : MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
    : TSF:LRT:OK
    : TSM:INIT
    : TSF:WUR:MS=0
    @ghiglie Thank you, I did see that was for 2.1.1. Just playing with them!
    Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
    @alowhum If you want to just encrypt data, just add the encryption key in the myconfig.h file and compile it
  • @gohan N00b question, but which steps from the step-by-step need to be redone to "compile it" after altering myconfig.h? Or can you just post the command lines? 😳
    As soon as you do the changes in myconfig.h before the MAKE, you are fine
  • Anyone tried using the new Pi Zero WH as a Raspberry Pi Gateway. Presumably by MQTT and using NRF24 radio?
    @alowhum Have you been able to setup a gateway with your Raspberry Pi Zero?
  • @sentur That's what I'm doing now. Except mine is Zero W. Soldered the pins on myself.
  • Code Contributor
    @alowhum yes, to use MY_SIGNING_SIMPLE_PASSWD feature, add the following to your list of configure options:
    ... --my-signing=password --my-signing-password=<PASSWORD>
  • Is there anyway where i can see if i have IRQ configured ?
    ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
    look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
  • @gohanm, as it seems not ?, can i rebuild it easily? ```
    SOC=BCM2837
    CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
    LDFLAGS=-pthread
    PREFIX=/usr/local
    CC=gcc
    CXX=g++
    BUILDDIR=build
    BINDIR=bin
    GATEWAY_DIR=/usr/local/bin
    INIT_SYSTEM=systemd
    SPI_DRIVER=BCM```
    make a copy of it and make a ./configure with the IRQ enabled and see what you get
  • @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
    ill try it tomorrow, too afraid to break things late in the evening 😉
    as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
  • but ill have to do it sometime , just ./configure with all the options, build , test and install ?
    if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
  • @gohan ty
  • Moved to normal troubleshooting forum
    @MasMat Yes I was able to build it on a Pi Zero. I did a fresh install on Dietpi. It worked fine when I didn't give any configuration options.
    Now, however, I am still trying to run something on the PGIO pins in paralel to MySensors again, and this is not working. As I speak the Pi reboots every 5 minutes.. Not sure what to blame yet. Domoticz, PiGPIO, or MySensors.
    Latest DietPi Stretch, latest Domoticz beta, latest MySensors beta.
    PiGPIO
    what are you using that for?
  • @alowhum I'm not using the GPIO for anything else.
    I had everything working (mysgw-MQTT, Mosquitto, Node-Red and OH2) for almost 6h. Then I moved the set-up and everything went south: cant get mosquitto to start, cant get mysgw to connect to that or another Mosquitto broker, OH2 seems to ignore everything...
    Spent the last 24h trying to resurrect Mosquitto but it's beyond me what's wrong.
    I remember reading that mysgw renders rest of the gpio unusable. Maybe that's giving you problems.
    I am running 2 gateway instances, one nrf24 and one rfm69 so I guess you can run other things
    @gohan: but you had to do a lot of black magic to get there right?
    not at all, I just followed the guide in the forum
    @masmat I got the Pi Zero W working fine with other things using the GPIO.
    • A fresh install helped
    • It could be that I now use the PiGPIO library for the project.
    • It could be the switch to another powersupply. I was using the official pi powersupply, but I suspect something was wrong with it. A cheap 3A chinese adapter is working fine.
    Either way: it all works now.
    I have a few n00bish questions about enabling encryption (without signing, so save space and ram):
    • Is putting an AES key in MyConfig.h really all I have to do? Don't I also have to put that in all the sensor nodes? And is that proces complicated, using a signing sketch and whatnot?
    • Can I have an 'opportunistic' network, where I have some encrypted nodes, and some unencrypted ones? If I could mix them this would make switching to encryption less stressful. I can't easily change two of my nodes.
    • If I change the network, I'd like to move the NRF to channel 100 (juist outside of the normal WiFi frequencies). Do I also have to set that in all nodes, or is setting it in the gateway enough?
    @alowhum encryption is all or nothing. You can't leave one node without encryption if your gateway encrypts the messages it send.
    And you will need to personalize your nodes to get the AES key into them. The documentation on security describes that process.
    @alowhum if you put it in myconfig.h also on the arduino library you can just recompile the nodes and you are good.
    @gohan not anymore. Only for pre 2.2.0 releases.
    It is still working on mine 😅
    @gohan in other words, you use an old release 😉
    I can assure you I am using 2.2 from development as I am also running new driver. So unless you changed something in the last 3 weeks on the development branch it still works, unless the nodes are keeping the key saved.
    @gohan have you verified your communications are actually encrypted?
    @gohan If you see here, you will find that unless you use the simple password option, AES key is fetched from EEPROM: https://github.com/mysensors/MySensors/blob/28c4f3f19e7026f56fd9bbc61d566f770fd7a9d2/hal/transport/MyTransportRF24.cpp#L68
    So either you are using the simple flag, nothing at all, or not using the key you think you use.
    I ll have to check, but I put the key in the gateway myconfig.h
    @gohan Perhaps on a rpi GW where there is no EEPROM, but I am talking about the nodes.
    Well, if I have communication working it means the node should be encrypting data. I'll have to try with clear eeprom and try flashing sketch again
    @gohan not if there is no encryption at all. You could try to use simple password option on a node with various passwords and see if it is detected by your gw at all.
    @anticimex I guess you were right... the gw and node aren't using the AES key. So where am I supposed to add it in the gateway?
    @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
    @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
    @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
  • @macvictor
    I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
    import RPi.GPIO as GPIO
    from lib_nrf24 import NRF24
    import time
    import spidev
    GPIO.setmode(GPIO.BCM)
    pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
    radio = NRF24(GPIO, spidev.SpiDev())
    radio.begin(0,8)
    radio.setPayloadSize(32)
    radio.setChannel(0x76)
    radio.setDataRate(NRF24.BR_1MBPS)
    radio.setPALevel (NRF24.PA_MAX)
    radio.setAutoAck(True)
    radio.enableDynamicPayloads()
    radio.enableAckPayload()
    radio.openReadingPipe(1 ,pipes[1])
    radio.printDetails()
    radio.startListening()
    radio.GPIO.cleanup()
    Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
    @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
  • To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
    @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
  • 110
  • 163
  • 347
