💬 Relay
  • @mfalkvidd smartsleep was not supported by domoticz at the begining of the year ... but there was a domoticz upgrade in july ... do you know if it's now supported ?
    @Boots33 said in 💬 Relay:
    @fhenryco If you are trying to keep your power use down then you could also consider using either a Latching Relay or even a MOSFET.
    Agreed, if you want to save power you need to use a latching relay. Also another regulator would be fine to power the arduino.
  • @gohan can you explain the benefit (for a low power app) of a relay switching on electrical pulse rather something else ?
    i mean, even the regular relay has both an open by default circuit output and close by default circuit ouput so it could remain on the desired state even when not powered up ...
    I am referring that when relay is on it is drawing power to stay on, while a latching relay it only draws power during the switch on and only during the switch off.
  • @gohan not sure this is going to be an easy way: need find arduino code for latch relay, dont know if domoticz is supporting this device ?, ...
    Domoticz will just see the same relay node, it is the code that need to be a little different as the relay is switched with a pulse and you need a pin to verify the relay status (if you get the ones that have a monitoring contact)
  • Hi Everyone,
    maybe the below will help people facing random incorrect behaviors.
    In sample from december 2016 /mysensors/MySensors/examples/RelayActuator/RelayActuator.ino, there is something which could be seen as a bug.
    In my case, I have used that sample to control a lot of relais. I noticed some rare but really annoying errors. From time to time a relay got switched incorrectly.
    Annoying and strange as coding was pretty straightforward. All relais are coded to act in pulse mode.
              digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
              wait(1000);
              digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
    And this is the reason of the bug.
    Explanation.
    During that second of wait, a lot of things may occurs. Due to the 'message' declaration, it is possible that the 'message' is getting changed.
    Typically a ping may come and as result the 'message' is not anymore the same.
    For that reason I would suggest the code to be changed a little bit.
    void receive(const MyMessage &message_orig)
      MyMessage message;
      message = message_orig;
    This way, the function works with a local copy and you are sure nothing can change during the processing.
    Anyway, thanks for the sample it was nevertheless very helpful
    @amemo06
    Because of the const keyword this is a const reference or said another way, a reference to a constant. The const keyword guarantees that the function may not change the object.
    So, I wonder what your real issue is....
  • @BulldogLowell No This is not the coding of the function which changes it. It is most likely the event which triggers it which may changes it.
    I can show the coding with trace and trace result.
    //void receive(const MyMessage &message_orig)
    //  MyMessage message;
    //  message = message_orig;
      Serial.println("receive_in:");
    Serial.print("1st read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
      if (message.type==V_STATUS) {
        // Change relay state
        if (message.getBool() == RELAY_ON){
    Serial.print("2nd read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
          wait(1000);
    Serial.print("3rd read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
    Serial.println("receive_out:");
    Below is a normal trace
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;Eth: 0;1;1;0;2;1
    receive_in:
    1st read:Sensor=1, getBool=1
    2nd read:Sensor=1, getBool=1
    3rd read:Sensor=1, getBool=1
    receive_out
    So you see the ping which occured before the message I'm interested in
    Now, because of the wait in the middle of the code, it may occurs the ping arrive in that period. Then the issue occurs.
    See the trace with error.
    receive_in:
    3rd read:Sensor=0, getBool=0
    receive_out
    In the 3rd read, sensor value has changed and getBool returns also a different value.
    Removing the wait or ensuring the function modules performs faster could reduce the risk. Still it will never be reliable.
    Better is to have either a local copy of the message like I wrote in the original post. Or make immediately copies of the information from the message I'm interested in.
    @amemo06 said in 💬 Relay:
    wait(1000);
    where did you find that? I wasn't able to find it
  • @gohan This is not in the original coding. I needed something like a wait in order to make a relay pulse.
    The wait increases the risk or the frequency of the trouble. Removing it does not solves the issue.
    Processing of the function will always take time. And the message can still changes before reaching the end like it is show in the second trace.
    @amemo06
    You should treat the message like an ISR... get in and out so that you don't have another message colliding while you are in the function.
    Get rid of that wait(). I couldn't find the source for that function but you could try to just use delay() to block while you hold the relay.
    otherwise just set a flag to handle the relay event in loop() or use a Timer/callback like the MsTimer2 Library
    example:
    #include <MsTimer2.h>
    const byte onButton = 5;
      Serial.begin(9600);
      pinMode(13, OUTPUT);
      pinMode(onButton, INPUT_PULLUP);
      if(onButtonPressed())
       flashLedThirteen(5000);
    bool onButtonPressed(void)
      static unsigned long lastMillis = 0;
      static byte lastPress = HIGH;
      byte currentPress = digitalRead(onButton);
      if(currentPress != lastPress)
        if(millis() - lastMillis < 200) return false;
        lastPress = currentPress;
        if(currentPress == LOW)
          Serial.println(" button press detected!");
          lastMillis = millis();
          return true;
      return false;
    void flashLedThirteen(int ledTime)
      digitalWrite(13, HIGH);
      Serial.println("LED ON");
      // sets a new timer callback function
      MsTimer2::set(ledTime, [] {  // the square brackets define the start of the anonymous callback function which is executed after 5000 milliseconds in this example
        digitalWrite(13, LOW);
        Serial.println("Timer expired...");
        Serial.println("LED OFF");
        MsTimer2::stop();
      }); // the curly brace defines the end of the anonymous callback function
      MsTimer2::start();
  • @BulldogLowell said in 💬 Relay:
    MsTimer2::
    Thanks for the MSTimer, I was not aware of it.
    And yes, definitively, having a wait() is probably the worst I could have written. Active wait cannot stay.
    My intention, in the stuff I develop, was to remove it asap and probably by handling the wait time in the loop with flags.
    Maybe I was not clear enough about my intention when I opened this thread. I have no issue with what I develop. I already had several ways to solves this. And now, I have a new one with MSTimer. Again thanks.
    I only wanted to raise the fact void receive(const MyMessage &message) may lead to trouble as 'message' content may change during processing of that function.
    And if, like many, you are not skilled enough to code/debug.., you will face erratic issues and real difficulty to understand what is going wrong.
    @amemo06
    As I already explained... message cannot change during the function, because of constness.
    The message handler is being called again from within itself (i.e. from wait()). You would then processing any new messages on that call. It looks as if the function may not be designed to perform recursively as you are trying to do in your code, so that would explain your unexpected/undefined results.
    So yes, block during the relay's holding state or use another non-blocking method (i.e. flag or timer/callback) as you mentioned. Fully process each message before allowing the library to handle subsequent message calls.
  • I was looking for a solution for a low consumption relay and i was adviced in this thread to use a latching relay.
    However since i just need to switch on or off a 12V Vcc (from Li ion battery) to trigger a solenoid valve, i'm wondering whether i need a relay for that :
    looking at the schematic from post #2 in https://forum.arduino.cc/index.php?topic=436555.0 may be i coud just have my solenoid valve directly in place of the relay in the schematic. In other words , i just need a transistor and not a real relay ... just because my application is a low voltage (12V to apply directly to the Vcc in the schematic) rather than 230V one: can someone confirm ? There is a diode in the schematic : what is it needed for ?
    @fhenryco
    Since an inductor (im many cases a relay coil) cannot change it's current instantly, the flyback diode provides a path for the current when the coil is switched off. Otherwise, a voltage spike will occur causing arcing on switch contacts or possibly destroying switching transistors.
    https://electronics.stackexchange.com/questions/100134/why-is-there-a-diode-connected-in-parallel-to-a-relay-coil
  • treat yor solenoid as it was a relay, the difference is that relay switches flow of current, and solenoid valve switches flow of water. so You have to use the same schematic, but put your valve where the relay is. But if You want power it from a battery, choose a latching solenoid valve instead of regular solenoid valve - and that requeires different schematic.
  • @rozpruwacz
    thanks, but do you mean that the schematic simply would not work for the regular valve or that it would work but not be low power cinsumption design anymore ?
    I have a regular solenoid valve but in my application the valve is normally closed and it will be only exceptionnally opened and for a short time when the 12V is applied, so i guess that i can live with it ...
    As for the transistor in the schematic, except it seems to be a NPN , i don't know if i need a particular one for it . probably i can just buy a 2N3904 , or is there a better choice?
  • the schematic you posted is not using latching relay/valve. it doesn't matter if it is relay or valve. both works the same and consume power when in ON state. If you plan to use it in a way that the valve will be ON for very short periods than it is not important if it is latching or not.
    when choosing a transistor for such use, You have to look at its datasheet into "absolute maximum ratings" section and check if it will handle the voltages you will apply to it. 2N3904 looks like it will handle 12V without a problem.
  • @rozpruwacz
    thanks , i will use 2N2222 because the valve needs between 200 and 400 mA.
    I'v read the 2N3904 is OK for < 100 mA
  • It works very well with the transistor and schematic posted above. I think the valve is a latching valve because it only discharges the battery when there is a transition. The only remaining problem is that the 5V arduino alone is too much power consuming. So i'm wondering if the transistor could as well work with a 3.3V arduino, that is when the signal level on the transistor Base is 3.3V rather than 5 V ... then i also could remove the arduino led but i'll need to keep the arduino regulator because my 3.7V cell voltage is too much greater than 3.3V
  • @fhenryco Actually the internal resistor of the solenoid is 27 Ohm while the resistance between C and E of the transistor in the passing state is 35 Ohm ... so it remains less than Vcc/2 for my solenoid which needs 12V ... so i need to tune my boost module at the max ==> more than 30V ... that does not seem ideal, may be i shoud choose another transistor with less internal resistor, but i have little experience with transistors : studied them a long time ago , so if someone can suggest something smart, ready to buy it ...
  • Can I suggest a change to this page?
    As it stands the wiring diagram only applies to sketch 1 (without switch). It could get confusing as the 2 sketches use different pins for the relay and there is no need for this.
    I propose that the wiring diagram be changed for the relay to be attached to pin 4.
    The first sketch needs the relay pin to change from pin 3 to pin 4.
    That's it. Then the diagram and sketches will work whichever way the builder wants to do it.
    Good idea @skywatch
    When doing the update, we should also rename RELAY_1 to RELAY_PIN to be consistent with sketch 2.
    https://www.mysensors.org/build/relay has been updated with new wiring instructions (picture + table)
  • That looks good, only the sketchs to go....On that note I wonder if Relay_1 might not be better choice as it gives a clue to people that if they want to add a second relay then that would be Relay_2.... Just a thought and maybe not needed.... 😉
  • @mfalkvidd when updating the example sketch you could maybe consider my version of the relay sketch which offers some nice additions: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
    @HenryWhite my mind is divided when it comes to that type of sketch. Yes, it has a lot of functionality. Yes, it is probably what people need anyway. But the examples are meant to be used by someone who is just getting into diy home automation. Someone new should be able to understand as much of the sketch as possible. There should be as little as possible to trubleshoot. If the sketch is complex, most people's initial reaction will be that there is something wrong with the code, when in reality almost all newbie problems are power or wiring-related. Keeping the sketch simple helps, at lest a bit.
  • @mfalkvidd You are right but may be should there be for each sensor or actuator first the most basic sketch but also at the end of the page a complete version with all functionalities and granted to work by the mysensors team.
    Of course for the complicated sketch version a big warning in red letters that this is not recommended for newbies would help...
  • After testing some functionalities of nodemanager, i was wondering if already somebody was working on making a GUI for nodemanager which would allow to build one's sketch completely from a graphical interface (at least the most common and basic functionalities) : i thing the great work that resulted in Nodemanager has so well structured the various functions needed that it has already paved the way for creating such a graphical interface.
    There was a user some time ago that was trying to make a web GUI
  • I would agree that more advanced sketches 'should' be included on the same page. Keep all the info in one resource place. Provided it is clearly marked as an advanced project it might help people looking for similar functionality or just interested in learning more about programming....
  • wow! fantastic! ... the github link readme warns that it's not yet fully ready but the interface is already impressive!
    I still have the same question i had for nodemanager though : for measuring another battery than the one that feeds Vcc obviously another pin is needed, however why not propose as well the option of measuring such pin voltage but with Vcc as the reference rather than the internal 1.1V which most of the time makes necessary a voltage divider ? Actually i did the modification in nodemanager.cpp to use DEFAULT (~3.3V) rather than INTERNAL (1.1V) reference for a 3.3 pro mini and i can get the expected battery level without any voltage divider.
    Another unrelated question i have is : could there be any way to adapt the idea of the readVcc method (which is to measure the internal 1.1V against the Vcc reference to get Vcc) but using any voltage applied to a pin as the reference to again measure the internal 1.1 against it ? This would allow the masurement of any voltage greater than 1.1 without voltage divider while the usual method would be applied for measuring any voltage lower than 1.1 ... what did i miss that makes this impossible ?
    We need to use the internal reference since it is the only stable voltage source and you need the voltage divider to lower the measured voltage between 0 and 1.1v. There are not many options to choose from
  • i also just realized that there is a special AREF pin intended for what i was thinking about ... but it's not available on the mini pro.
    My measurements using Vcc as Ref have been indeed very fluctuating, however what i get was highly sufficient to monitor the battery feeding a 3.3v step up regulator to the arduino and help anticipate failure
  • I just noticed another thing that should be changed in the 'relay with button' sketch....
    S_LIGHT should be S_BINARY
    V_LIGHT shoud be V_STATUS
  • I would like to clarify operation of the sketch, where more than 1 sensors input are used along with more than 1 relay actuator. in one node
    1. Does node need unique child ID for each sensor input AND relay output?
    2. If that is the case how child ID is assigned to relay actuators in the above examples?
  • This is a nice sketch and it is very universal for relays. Now m looking for a similar sketch for digital inputs such as buttons i.e.. I would like to join both. The problem: I want to use a mega for reading status of a lot of digital outputs (min.20) of another ISP. It is only High or Low. Only when the level changes, I want the mega send a message to the gateway. I tried this "for" loop, but it didnt help. There are too many informations sent to the gateway. I imagine a solution, where only a change at the pin will create an information, that is sent to the gateway.
    Here my test, which didnt run:
    for (int sensor=16, pin=BIN_1; sensor<=NUMBER_OF_BIN; sensor++, pin++)
    int BUTT;
    int BUTTOLD;
    BUTT =digitalRead(pin);
    if (BUTT != BUTTOLD && BUTT !=0){
    MyMessage msg(sensor, V_TRIPPED);
    send(msg.set(BUTT ? "1" : "0"));
    BUTTOLD = BUTT;
    wait (900);
    Has anybody an idea or a hint for me?
    I believe there is a logic error in the sketch as you would need to declare global variables BUTTOLD_XX unique for each button, otherwise how can you keep track of the variable between each loop and FOR iteraction?
  • Thank You for Your quick answer.
    Do I understand You correctly: I must index the BUTTOLD?
    As BUTTOLD[pin) for example or how? Where?
    You need to create the single variables one by one, unless somebody else has a better way to do it
  • why i can't compile for arduino pro mini on other boards i can upload
    @mitja-blazinsek the error messages are usually essential to figuring out. Did you get any?
  • Arduino: 1.8.1 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega168 (5V, 16 MHz)"
    In file included from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\io.h:99:0,
                 from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\pgmspace.h:90,
                 from C:\Users\mitja\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino/Arduino.h:28,
                 from sketch\button_relay.ino.cpp:1:
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'bool hwUniqueID(uint8_t (*)[16])':
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:246:26: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID) = boot_signature_byte_get(0x00);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:247:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 1) = boot_signature_byte_get(0x02);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:248:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 2) = boot_signature_byte_get(0x04);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:249:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 3) = boot_signature_byte_get(0x01); //OSCCAL
    Multiple libraries were found for "Bounce2.h"
    Used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2
    Not used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2-master
    exit status 1
    Error compiling for board Arduino Pro or Pro Mini.
  • OK it's probaly because ia have mini with 168 chip i have to buys 328 😞 again wait 1month to arive from china
  • hello.
    I am building a node with several kind of sensors and two relays.
    My sensors use CHILD ID from 0 to 3. I would like to start child ID of relay from 4.
    How I can't do that with this sketch?
    I guess I have to change this part of sketch :
    "for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    present(sensor, S_BINARY);"
    correct?
    thanks
  • @lekeb
    You may do something like this:
    In Header:
    uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus
    an then in presentation():
    for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        present(i + DS_First_Child_ID, S_TEMP);
    But afaik, it's not recommended to shift the ChildID's for relays but always start with 1. Imo it's better to change the ChildID's of the other attached sensors. You may also take care (in case of shifting ID's) about a consistent mapping from ID to the PINs where the relays are attached.
    Agreed, set you sensors to higher ID numbers like 20 or 30 and you are good to go .
  • ok thanks a lot I will try this night
  • perfect it works great. I started my temperature sensor at CHILD ID 4 and let relays from 1 to 2. I had to add also "DS_First_Child_ID" in the sent message to gateway.
    thanks
  • Hi
    Please put to this topic code your sketch....
  • Sur,
    my node controls two relays, one water pressure sensor and three DS18b20
     code pour controle cave a vin, temp et pression
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 15
    #include <OneWire.h>
    #define BARO_CHILD 0 //Child ID for pressure sensor
    #define BAR_SENSOR_ANALOG_PIN 0 // pin for pressure sensor
    #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
    #define RELAY_PIN 3 //pin for first relay
    #define NUMBER_OF_RELAYS 2
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    float lastpression;
    uint8_t DS_First_Child_ID = 4; //First Child-ID to be used by Dallas Bus
    MyMessage msg(0,V_TEMP);
    void before()
            pinMode(pin, OUTPUT);
      sensors.begin();
        sendSketchInfo("Buanderie node", "1.0");
        //present pressure sensor
        present(BARO_CHILD, S_BARO);
      //read water pressure
    int lecture_adc = analogRead(BAR_SENSOR_ANALOG_PIN);
      float pression = ((lecture_adc*5/1024.0)-0.50)/1.7;
      if(pression != lastpression) {
          send(pressureMsg.set(pression, 2));
      lastpression = pression;
      sleep(conversionTime);
        #if COMPARE_TEMP == 1
          send(msg.setSensor(i + DS_First_Child_ID).set(temperature,1));
            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
    @lekeb said in 💬 Relay:
    Why are you using the same child ID (since you set #define BARO_CHILD 0)?
  • @gohan Effectively, he will never report any temp reading under ChildID 0. Within presentation() and the send() commands, the "0" is replaced by "i + DS_First_Child_ID".
    But you are partly right, to avoid any misunderstandings wrt. that the statement could also be written as follows:
    MyMessage msg(DS_First_Child_ID,V_TEMP);
  • correct, it makes sense. I will correct this error.
    However Domoticz reads correctly the temperature and links correctly the CHILD ID's, so...
  • Hello everybody !
    I would like to creat a sensor with two relays and two buttons to command this relay direct from the sensor (with actualisation of their stat in domoticz)
    Someone know the code to do this ? I'm a complete newbie on mysensor !
    Thank's a lot !
  • @jonathan-pucel Have a look at the code in this post.
  • Excellent ! It's perfect, thank's a lot rejoe2 !
  • Hi
    Using Home assistant, and Optimistic set to false in the mysensors config, the switch in homeassistant would turn the relay on, but in the view in homeassistant the flip switch jumped off straight after switching on. It was solved by adding the following line to the sketch, ensuring that hassio knows that the actuator actually have received the command. Not sure if this is a good way of doing it, but it seems to work for me.
    send(msg.set(state)); // Send new state and request ack back
    in:
    if (message.isAck()) {
    state = message.getBool();
    saveState(CHILD_ID, state);
  • Hi!
    I would like to control some 230VAC equipment (for now roller shutters), based on inputs from my mysensors sensors (temperature and light). For controller I use domoticz.
    I would like a safe, robust and preferably authorized/lawful solution (I'm in EU/Denmark).
    I came across the following solutions:
    https://aeotec.com/z-wave-plug-in-switch
    https://sonoff.itead.cc/en/products/sonoff/sonoff-basic
    https://dlidirect.com/products/iot-power-relay
    I think the first one and maybe the second one will be authorized/lawful...? However, I have experience only with mysensors and neither z wave nor sonoff...
    Anyone has some experience/thoughts/suggestions to share?
    There are also roller shutters nodes running via zwave if you are looking at a retail solution
  • Thank you @gohan! Retail solution is not the keyword here. What I am searching for is an authorized/lawful (safe) solution.
    I decided to do my own node (mysensors) with a cheap relay module for the arduino. Once I achieve the desired functionality I will change to some more robust hardware. Following your suggestion this could be a z wave roller shutter (e.g. fibaro or qubino).
  • @arrawx said in 💬 Relay:
    Sorry to comment negative, but your wording doesn't make sense. either you will go for a DIY solution, cheap and illegal (but not necessary a bad solution), or you will purchase a retail solution.
    Retail solution must have the required certificates to allow you to sell. Those are not cheap to get, which also provide the reason for a retail solution to
    be usually fairly expensive
    https://arbejdstilsynet.dk/da/regler/bekendtgorelser/i/sam-indretning-af-tekniske-hjaelpemidler-612
    And also you need Notified Body
    https://en.wikipedia.org/wiki/Notified_Body
    And I know that Cetekom can create certificate for Country Approvals
    https://www.cetecom.com/en/certification/country-appoval/
  • There is a problem with the example code for RelayActuator.ino It is not checking for ACK messages. See the other example called SecureActuator.ino that does this. Without checking for ACK messages my relay gets an ON signal and turns on then immediately thereafter gets an ACK signal for V_STATUS command which is assumed in this example to be a control and the value is "0" so it turns off the relay.
    @slt1 I'm not sure I'm following. RelayActuator.ino does not send any messages, so it should never receive any ack messages. Compare with RelayWithButtonActuator.ino which does send messages, and therefore also checks for ack.
    Could you elaborate on the problem?
  • @mfalkvidd
    For some reason I am now unable to reproduce the issue on the standard RelayActuator.ino example. It was definitely sending ACK requests when I was testing a few days ago. I have subsequently updated MySensors library and also MyController to their latest Snapshot - so perhaps the issue comes up under one of those scenarios.
    The issue around this though is that the example does not report the current status of the relay in the loop. My own sketch was doing so. I guess many people take an example and modify it like I do. Therefore copying the example and adding in the code to send the current relay status periodically means the receive function will not work properly due to the Ack messages received,
    I would then suggest adding a note to the receive function of the relay example sketch to say that "if your node sends messages then you need to check for Ack and discard those messages" - or something along those lines. This will help !
    @slt1 thanks for explaining.
    I'll think about it for a bit but I hope to submit a pull request soon. I'll post here when it is ready.
    @slt1 sending current status won't generate an ack/echo message. So there should not be a need to handle the ack/echo flag. Hardware acks (which are enabled by default) do not trigger the receive function.
    The only case when an ack/echo message will be sent is if the sketch developer explicitly requests an ack/echo by setting the ack parameter in send() to true. If the sketch developer does that, they need to handle the ack/echo message inside the receive function, according to however they plan to handle the ack/echo message.
    My guess is that people set the ack flag to true without understanding what they are doing. I hope to make the documentation slightly less confusing by doing https://github.com/mysensors/MySensors/issues/1103
  • @mfalkvidd Thanks - and yes - I did make the assumption that send with ack = true means do a hardware ack. I was unaware that a "software ack" also exists. I read your comment here : https://forum.mysensors.org/topic/3346/discussion-reliable-delivery/17 and what you mention there needs to be made loud and clear in the docs - perhaps some mention in both the message send function and message receive function,
    @slt1 I agree. Made the same mistake and it took me 40 hours of reading documentation and troubleshooting before I realized there was a difference between the two acks.
  • The script for 'Example with button' works perfectly! Thanks for that.
    Has someone a script for multiple Relays with buttons ready to use for me?
    I want to use it in my garden to switch the lights with physical buttons and also control them with Domoticz.
  • I am having this particular switch to be recognized in "Mozilla WEBTHINGS".
    IS there some issue with having a repeater node and sensors/switches etc attaches to it? .. it sends in the data as it should when I check with MYSController and I can switch it from there with sending "V_STATUS" messages. but no luck so far of getting the sensors appear in WEBTHINGS , every other sensor works fine.
  • // Enable debug prints to serial monitor
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "SSID"
    #define MY_WIFI_PASSWORD "PSW"
    // Enable UDP communication
    //#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_GW"
    //#define MY_IP_ADDRESS 192,168,0,0
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
    #define LWIP_OPEN_SRC whatever
    #define TCP_MSS whatever
    #define LWIP_IPV6 whatever
    #define LWIP_FEATURES whatever
    //DHT with autodetection
    #include <dhtnew.h>
    DHTNEW mySensor(5); // ESP 16 UNO 6
    uint32_t count = 0;
    uint32_t start, stop;
    uint32_t errors[10] = { 0,0, 0,0, 0,0, 0,0, 0,0 };
    //Domoticz
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    sendSketchInfo("TemperatureAndHumidity", "1.1");
    present(CHILD_ID_HUM, S_HUM);
    Serial.println("DHT_endless.ino");
    Serial.print("LIBRARY VERSION: ");
    Serial.println(DHTNEW_LIB_VERSION);
    Serial.println();
    count++;
    // show counters for OK and errors.
    if (count % 50 == 0)
    Serial.println();
    Serial.println("OK \tCRC \tTOA \tTOB \tTOC \tTOD \tSNR \tBS \tUNK");
    for (uint8_t i = 0; i < 9; i++)
    Serial.print(errors[i]);
    Serial.print('\t');
    Serial.println();
    Serial.println();
    if (count % 10 == 0)
    Serial.println();
    Serial.println("TIM\tCNT\tSTAT\tHUMI\tTEMP\tTIME\tTYPE");
    Serial.print(millis());
    Serial.print("\t");
    Serial.print(count);
    Serial.print("\t");
    start = micros();
    int chk = mySensor.read();
    stop = micros();
    switch (chk)
    case DHTLIB_OK:
    Serial.print("OK,\t");
    errors[0]++;
    case DHTLIB_ERROR_CHECKSUM:
    Serial.print("CRC,\t");
    errors[1]++;
    case DHTLIB_ERROR_TIMEOUT_A:
    Serial.print("TOA,\t");
    errors[2]++;
    case DHTLIB_ERROR_TIMEOUT_B:
    Serial.print("TOB,\t");
    errors[3]++;
    case DHTLIB_ERROR_TIMEOUT_C:
    Serial.print("TOC,\t");
    errors[4]++;
    case DHTLIB_ERROR_TIMEOUT_D:
    Serial.print("TOD,\t");
    errors[5]++;
    case DHTLIB_ERROR_SENSOR_NOT_READY:
    Serial.print("SNR,\t");
    errors[6]++;
    case DHTLIB_ERROR_BIT_SHIFT:
    Serial.print("BS,\t");
    errors[7]++;
    default:
    Serial.print("U");
    Serial.print(chk);
    Serial.print(",\t");
    errors[8]++;
    // DISPLAY DATA
    #ifdef MY_DEBUG
    Serial.print(mySensor.getHumidity(), 1);
    Serial.print(mySensor.getTemperature(), 1);
    Serial.print(stop - start);
    Serial.println(mySensor.getType());
    //send to gateway
    float humidity = mySensor.getHumidity();
    float temperature = mySensor.getTemperature();
    delay(3000);
    // -- END OF FILE --
  • I was so happy to have finaly a fonctionnal sketch for my esp8266 gateway whith the DHT22 that i post directly my code.
    I hope that it will help some people.
    based on: https://github.com/RobTillaart/DHTNew/blob/master/examples/dhtnew_endless/dhtnew_endless.ino
    Trying to go deep on the API and come this this doubt: The second example (with button) the child seems to be declared as "S_LIGHT" and the receiving messages are "V_LIGHT", while the first example seems better suitable for a relay (child as "S_BINNARY" and requests as "V_STATUS").
    I haven't found any "S_LIGHT" or "V_LIGHT" in the API, only "S_LIGHT_LEVEL" and "V_LIGHT_LEVEL". What is the most suitable type for a relay node with a local button?
  • @joaoabs A realy usually has only 2 states, on and off. So I would use S-BINARY and V_STATUS every time.
    A changeover realy also has 2 states so again I would go for binary and status.
    Light_Level is more suited to getting light levels from a sensor or sending a light level to a dimmable light.
    Not sure if it ever has mentioned before, but the first example contains
    Which results in a compile error
    MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    It should be:
    And then it compiles and works 🙂
    @mfalkvidd I'm in an older version I discovered. Ran across more small differences.
  • @TheoL Sound like a good time to update to the latest version. it is the best yet and very stable.
  • 347
  • 110
