  3. 💬 Capacitive Soil Moisture Sensor
mysensorssoil moisturecapacitive soil moisturenrf24l01+atmega328p
12 Posts 7 Posters 2.8k Views 5 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Beautiful work 👍
    • Puneit ThukralP
      Puneit ThukralP
      Puneit Thukral
      Hi great design... If I can suggest one improvement, it would be to burn a minicore bootloader and set BOD to 1.8V so that the batteries can last longer.
      RonR AnticimexA 2 Replies Last reply
      • Puneit ThukralP Puneit Thukral
        RonR
        RonR
        Ron
        @Puneit-Thukral Thanks. I am not quite sure, so correct me please if I am wrong, but I think I am already using the MiniCore bootloader with platformIO. Or do I need to configure to explicitly use the MiniCore bootloaders? Also I have set BOD to disabled as I read somewhere that no BOD can also save battery.
          AnticimexA
          AnticimexA
          Anticimex
          @Puneit-Thukral but will the peripherals still work at that level? No use to lower the BOD if radio/security/sensors stop working at a higher voltage.
          RonR 1 Reply Last reply
          • AnticimexA Anticimex
            RonR
            RonR
            Ron
            @Anticimex That was also my thinking behind that. According to the datasheet the ATmega328P works reliably down to 2.4V when using 8MHz.
            Puneit ThukralP 1 Reply Last reply
            • RonR Ron
              Puneit ThukralP
              Puneit ThukralP
              Puneit Thukral
              @Ron @Anticimex The radio stops at 1.9V.. so I think its fair to do a BOD of 1.8V.
              I used arduinoAsISP to burn bootloader and this is my platformio.ini
              [env:program_via_ArduinoISP]
              platform = atmelavr
              framework = arduino
              ;  Serial bootloader protocol
              upload_protocol = custom
              ; Serial upload port
              upload_port = /dev/cu.*
              ; Get upload baud rate defined in the fuses_bootloader environment
              upload_speed = 19200
              board_build.f_cpu = 8000000L
              board_hardware.oscillator = internal
              board_hardware.uart = uart0
              board_hardware.bod = 1.8v
              board_hardware.eesave = yes
              board_hardware.ckout = no
              upload_flags =
                  -C
                  ; use "tool-avrdude-megaavr" for the atmelmegaavr platform
                  /Users/puneit/Nextcloud/PlatformIO/bootloader/tool-avrdude/avrdude2.conf
                  -p
                  $BOARD_MCU
                  -P
                  $UPLOAD_PORT
                  -b
                  $UPLOAD_SPEED
                  -c
                  stk500
              upload_command = avrdude $UPLOAD_FLAGS -U flash:w:$SOURCE:i
              AnticimexA skywatchS 2 Replies Last reply
                platform = atmelavr
                framework = arduino
                upload_flags =
                    -C
                    -p
                    $BOARD_MCU
                    -P
                    $UPLOAD_PORT
                    -b
                    $UPLOAD_SPEED
                    -c
                    stk500
                AnticimexA
                AnticimexA
                Anticimex
                @Puneit-Thukral yes but for full/specified function, atsha, atmega and any sensor circuitry also need to be operational at that level.
                  platform = atmelavr
                  framework = arduino
                  upload_flags =
                      -C
                      -p
                      $BOARD_MCU
                      -P
                      $UPLOAD_PORT
                      -b
                      $UPLOAD_SPEED
                      -c
                      stk500
                  skywatchS
                  skywatchS
                  skywatch
                  @Puneit-Thukral When I tested a recent node the radio was presenting to the GW all the way down to 1.64V - so it is always worth trying to see if it works for you or not (ebyte red module).
                  • sundberg84S
                    sundberg84S
                    Nice work @Ron . Thinking about getting some of these for my plants.
                    Any experienced issues, or the PCB and components works good?
                    • sundberg84S sundberg84
                      RonR
                      RonR
                      Ron
                      wrote on last edited by Ron
                      @sundberg84 said in 💬 Capacitive Soil Moisture Sensor:
                      I had the first prototype running for about 2-3 months and did not experience any issues. The next thing on my todo list is to get an estimation on the total battery lifetime. I would assume that it will be quite good as I did not notice any significant drop in battery voltage over that time. I will post my measurements in the corresponding GitHub question as soon as I have some time. :)
                      • don alexD
                        don alexD
                        don alex
                        @Ron said in 💬 Capacitive Soil Moisture Sensor:
                        hi
                        I'm not sure, but I believe I'm already using the MiniCore bootloader with platformIO. Please tell me if I'm incorrect. Is it necessary to set the MiniCore bootloaders explicitly?
