nRF5 action!
    Thanks! By being "merged," does that mean it is now in the regular MySensors development release, and so I should reload a fresh copy of the MySensors development library?
    The Board definition is independed from MySensors core living at https://github.com/mysensors/ArduinoBoards You have to follow the instructions, then you can install the MySensors nRF5 Boards via Arduino Board Manager.
    Also, is this the way I should enable P0.21 as nReset (to enable hardware resets on P0.21), or should I instead be writing 0xFFFF directly to both the PSELRESET[0] and PSELRESET[1] registers to enable that?
    Look into the Tools menu. For nRF52 MCU is a "Reset" menu. Switch it to "Enable"
    @d00616
    I got the pin mapping to work, but setting reset enable through the tool menu seems to have no effect. I subsequently drive P0.21 low (all the way to GND even), but no reset happens. Am I doing it wrong? Anyone gotten it to work?
    I also tried adding a 10K pullup resistor, and no change.
    At the moment I'm unfamiliar with the nRF52 API. What would the code be to set both those reset registers to 0xFFFF? That by itself should enable the reset on P0.21. I could try inserting it into the demo script and see if reset then works.
    I guess it wouldn't be that simple, because I just now read that it requires a system reset after writing to those registers: https://devzone.nordicsemi.com/question/157603/can-i-enable-and-disable-nrf52832-reset-pin-when-code-is-running/ for it to take effect.
    By switching to a Windows 10 computer, I was able to get J-link working over USB from windows.
    Can you explain the steps you used for that ?
    Did you use a jlink clone or the version included in the DK ?
    Well you can forget about my questions.
    I tried to use the JLink tools to make the mass erase but it didn't want to connect to the module.
    But then I have replaced the driver with Zadig and configured Arduino for NRF5 and it uploaded the LightSensor sketch, I can see it in the log of the controller. No mass erase needed, nor any unlock or related command.
    Just plug and program for me 😄
    I have some strange error messages but I guess they come from (very) dated firmware on my Segger clone
    ** Programming Started **
    auto erase enabled
    Info : nRF51822-QFN48(build code: B00) 512kB Flash
    Warn : not enough working area available(requested 32)
    Warn : no working area available, falling back to slow memory writes
    wrote 28672 bytes from file C:\Users\Nicolas\AppData\Local\Temp\arduino_build_723618/LightSensor.ino.hex in 6.715397s (4.170 KiB/s)
    ** Programming Finished **
    ** Verify Started **
    Warn : not enough working area available(requested 52)
    verified 27432 bytes in 0.279278s (95.923 KiB/s)
    ** Verified OK **
    ** Resetting Target **
    shutdown command invoked
    I used the j-link Segger clone to do the mass erase, and then I switched to the DK to do the programming. However, today I was able to do the programming from the Segger clone on the Windows 10 computer, and the setup is less arduous than for programming an external chip using the DK (because with the Segger I didn't have to power the target chip independently during the programming).
    So, I guess the way the code would read is:
    1. First check if the reset registers are already properly set.
    2. If so, then just move on to whatever is next.
      If not, then properly set the reset registers and invoke the system reset.
    Apparently a system reset doesn't change the values in the reset registers.
    Of course, none of this would be needed if the reset enable from the tools menu worked, so I'd still prefer to do it that way if at all possible.
    As I indicated earlier, the pin mapping on Rx and Tx did work using @d00616 new technique, so hurray for that. That much was an important victory in itself that's worth celebrating. 🙂
    First nrf51822 module arrived already.
    It's really small, here between an nrf24 SMD and the cdebyte 52832.
    Soldering quality looks better than the pictures on AliExpress.
    The "Reset" menu was from my first approach creating user manageable boards for arduino-nrf5. I haven' tested it. With the reset menu I set the "-DCONFIG_GPIO_AS_PINRESET" option. This option should be processed in "cores/nRF5/SDK/components/toolchain/system_nrf52.c". If not the SystemInit() function is not processed in the startup code. This is a problem handling the chip errata. I have not time to check this at the moment.
    Here is a PR which want to enable reset as default: https://github.com/sandeepmistry/arduino-nRF5/pull/91
    Maybe the reset pin problem is hardware related? I say that because if I program the Ebyte module as a Nordic nRF52832 DK board, it still has the same issue. In contrast, the reset button on the actual nRF52832 DK board does work as expected.
    I've confirmed that connecting P0.21 to GND and then removing it again on the Nordic nRF52832 DK does act as a reset. So, at the moment I have no idea why doing so on the Ebyte nRF52832 that's been programmed to think it's an Nordic nRF52832 DK doesn't do the same. There must be some hardware difference, right?
    I've confirmed that on both the Ebyte Module and on the Nordic nRF52832 DK, there is continuity between the P0.21 pin on the chip and the P0.21 pin on the board pinout. So, there must be some other factor that accounts for the difference.
    Making no headway on the reset topic, so for now I'm going to punt and move on to other things.
    Success! I received some of these modules:
    https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=2114.search0104.3.10.osbQHP&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10307_10082_10081_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_10056_10055_10054_10310_10312_10059_100031_10099_10078_10079_10103_10073_10102_10120_10052_10053_10142_10107_10050_10051-10120,searchweb201603_2,ppcSwitch_5&btsid=b9a0c3cb-cc2a-4254-b24f-94136c73def6&algo_expid=2a71f70b-4929-43a5-887a-2f7263250568-1&algo_pvid=2a71f70b-4929-43a5-887a-2f7263250568
    which I immediately programmed using the nRF52832 DK. This time, there was no need to first mass erase. Furthermore, this time P0.21 does indeed reset the module after it is pulled to ground and then released.
    So, from this I conclude there must be something peculiar to the Ebyte modules which prevents their resetting using P0.21.
    It's nice to have different modules to compare amongst. 🙂
    @NeverDie gotta catch them all 🙂
    Anyone have a good sketch for measuring the battery supplied voltage on an nRF52? Some of the concepts from the old atmega328p may apply, but the specifics are going to be different, I'm sure.
  • Check on adafruits feather reference they use two resistors as a voltage divider for that simple and effective.
    I'm not finding it. Do you have a link?
  • @NeverDie https://learn.adafruit.com/assets/39913
    Top right corner of the schematic.
  • @NeverDie but a much better but more expensive solution would be a lipo fuel guage from spark fun they use a Max chip for that.
    If supplied with less than 3.6V you can do it with ADC, 1.2V voltage reference and 1/3 prescaling.
    But I've only looked at the theory yet.
    Rules are Vdd+0.3V max at the pin, and max 2.4V as input of ADC (after prescaling)
    Well, as you all know, on the atmega328p you can read the 1.1v gap voltage using the battery voltage as the reference voltage, by doing analogRead(A0), and from just that one measurement then calculate the battery voltage by doing a little bit of math. So, I'm just wondering what the code is to do the equivalent of that (using 1.2v instead of 1.1v) on the nRF52832.
    For this, you can use the implemented hwCPUVoltage() function. Reading the voltage costs nRF51: 260µA/20µs | nRF52: 700µA/3µs
    hwCPUVoltage()
    I'm finally installing Visual Micro, because I hope it will help me quickly find where all these functions are defined. With all these new layers, the Arduino IDE is just no longer cutting it.
    LOL. Well, Visual Micro found it alright, but just in the wrong place. It found it in MyHwAVR.cpp
    hwCPUVoltage()
    good choice 👍
    for nrf5, the function is located in MyHwNRF5.cpp
    I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
    Actually, something different may be going on. Here's the function definition:
    uint16_t hwCPUVoltage()
    #if defined(NRF_ADC)
    	// NRF51:
    	// 20uS@260uA
    	NRF_LPCOMP->ENABLE = 0;
    	// Enable and configure ADC
    	NRF_ADC->ENABLE = 1;
    	NRF_ADC->EVENTS_END = 0;
    	NRF_ADC->TASKS_START = 1;
    	while(!NRF_ADC->EVENTS_END);
    	NRF_ADC->TASKS_STOP = 1;
    	NRF_ADC->ENABLE = 0;
    	// Restore LPCOMP state
    	return (sample*3600)/255;
    #elif defined(NRF_SAADC)
    	// NRF52:
    	// Sampling time 3uS@700uA
    	int32_t sample;
    	NRF_SAADC->RESULT.MAXCNT = 1;
    	NRF_SAADC->TASKS_START = 1;
    	NRF_SAADC->EVENTS_END = 0;
    	NRF_SAADC->TASKS_SAMPLE = 1;
    	NRF_SAADC->TASKS_STOP = 1;
    	// unknown MCU
    	return 0;
    One, perhaps likely, theory would be that it doesn't recognize the MCU, which would explain why it returns the value of zero. Well, to debug that, I added the Serial.println(...) statements into the library code (see above) in an attempt to see which of the if-else branches is being taken, but none of the Serial.println(...)'s were printed! Here's a sample of the output from the Ebyte Module:
    332641 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    332968 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    332973 TSF:MSG:FPAR OK,ID=0,D=1
    334649 TSM:FPAR:OK
    334650 TSM:ID
    334651 TSM:ID:REQ
    334654 TSF:MSG:SEND,255-255-0-0,s=59,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    336662 TSM:ID
    336663 TSM:ID:REQ
    336665 TSF:MSG:SEND,255-255-0-0,s=23,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    338673 TSM:ID
    338674 TSM:ID:REQ
    338676 TSF:MSG:SEND,255-255-0-0,s=242,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    340684 TSM:ID
    340685 TSM:ID:REQ
    340687 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    342695 !TSM:ID:FAIL
    342696 TSM:FAIL:CNT=7
    342698 TSM:FAIL:DIS
    342700 TSF:TDI:TSL
    402703 TSM:FAIL:RE-INIT
    402705 TSM:INIT
    402706 TSM:INIT:TSP OK
    402708 TSM:FPAR
    402711 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    403472 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    403478 TSF:MSG:FPAR OK,ID=0,D=1
    404719 TSM:FPAR:OK
    404720 TSM:ID
    404721 TSM:ID:REQ
    404724 TSF:MSG:SEND,255-255-0-0,s=241,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    406732 TSM:ID
    406733 TSM:ID:REQ
    406735 TSF:MSG:SEND,255-255-0-0,s=205,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    408743 TSM:ID
    408744 TSM:ID:REQ
    408747 TSF:MSG:SEND,255-255-0-0,s=168,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    410754 TSM:ID
    410755 TSM:ID:REQ
    410757 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    412765 !TSM:ID:FAIL
    412766 TSM:FAIL:CNT=7
    412768 TSM:FAIL:DIS
    412770 TSF:TDI:TSL
    472773 TSM:FAIL:RE-INIT
    472775 TSM:INIT
    472776 TSM:INIT:TSP OK
    472778 TSM:FPAR
    472781 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    472955 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    472960 TSF:MSG:FPAR OK,ID=0,D=1
    474789 TSM:FPAR:OK
    474790 TSM:ID
    474791 TSM:ID:REQ
    474794 TSF:MSG:SEND,255-255-0-0,s=167,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    476802 TSM:ID
    476803 TSM:ID:REQ
    476805 TSF:MSG:SEND,255-255-0-0,s=131,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    478813 TSM:ID
    478814 TSM:ID:REQ
    478816 TSF:MSG:SEND,255-255-0-0,s=94,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    480824 TSM:ID
    480825 TSM:ID:REQ
    480827 TSF:MSG:SEND,255-255-0-0,s=57,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    482835 !TSM:ID:FAIL
    482836 TSM:FAIL:CNT=7
    482838 TSM:FAIL:DIS
    482840 TSF:TDI:TSL
    I'm not quite sure how to interpret that, but pretty clearly it doesn't contain the println's that I was expecting.
    Any theories as to what's going on?
    Bracketing that and setting it aside, I do now notice this line in the BatteryPoweredSensor demo sketch:
    So, if I map that A0 in the sketch to the A0 of the Ebyte Module, then maybe (hopefully) the voltage measurement will work on the Ebyte Module. I'll give it a try.
    Unfortunately, after I add:
    #include <mySensors.h>
    the locus of control goes somewhere else (I guess the gateway or something?). Anyhow, it makes this very hard to debug.
    For instance, the pin of interest is PIN_AIN0. I can't find where it's defined, and I can't print out its value either, because of this locus of control issue.
    Anyhow, I think I may wait for others to get up and running with their modules, and start facing the same issues. Maybe then we can help each other figure this stuff out.
    @NeverDie I don't know why the println() doesn't work. There is an "DEBUG_OUTPUT(x, ##VA_ARGS)" macro, you can use when debug is enabled.
    NRF_ADC is the nRF51 ADC and NRF_SAADC is the ADC of the nRF52. They are defined when "nrf.h" is included.
    The nRF52832 Ebyte Module.
    //#define MY_RADIO_NRF24
    #define MY_RADIO_NRF5_ESB
    //#include <MySensors.h>
    int oldBatteryPcnt = 0;
    uint16_t counter=0;
    uint16_t volts=0;
    uint16_t theHwCPUVoltage()
      // NRF51:
      // 20uS@260uA
      // NRF52:
      int32_t sample;
      // unknown MCU
      return 0;
      while (true) {
        volts=theHwCPUVoltage();
        Serial.print("counter=");
        Serial.print(counter++);
        Serial.println(volts);
    //#else
    //	analogReference(INTERNAL);
    //#endif
    Sorry, you'll need two.
    @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint 😉
    @Nca78
    Thanks! Good to know.
    Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
    @Nca78
    Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.
    @Nca78
    They are on the pinout, so you only have 4 I/Os available.
  • From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
  • Does anybody know why the function tone() doesn't work for the nrf52?
  • @mfalkvidd said in nRF5 Bluetooth action!:
    BUZZER_PIN = 26
    BUZZER_TONE = 3000
    ATmega8
    ATmega168/328
    ATmega1280
    ATmega8
    ATmega168/328
    ATmega1280
    How is it possible to make it copatible with the NRF52?
    @Mike_Lemo it (the tone library) would need to be ported
    @Mike_Lemo it would need to be ported
    No idea what you are talking about.
    Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5😞
  • Someone managed to get NFC to work with this IC on the arduino IDE?
  • Some Nordic guidance might help.
    results in a loss of control by the sketch itself to something within MySensors that wants to establish communication between the node and the gateway. Not even sure how that is happening. In any case, it is just overcomplicating the debugging, and I really don't want that right now because it is effectively hanging what I'm trying to do. 😠
    You have to install the "MySensors nRF5 Boards" package. In the examples section for this package, you can find two files (MyNRF5Board.h + MyNRF5Board.cpp). Add these files to your sketch and compile it using "MyNRF5Board nRF52822" as you board.
    The registers are documented in the Infocenter and the bitfields.
    To access the registers, you have to add '#include <nrf.h>' to your code. Mostly the hardware is accesses by NRF_HWNAME->REGISTER
    Doing PWM is a little bit complex. The code is different for nRF51 and nRF52. Look into wiring_analog_nRF51.c and (wiring_analog_nRF51.c)[https://github.com/sandeepmistry/arduino-nRF5/blob/c98a190eb34c0247eb8e0764a6367c7f9e51d2fc/cores/nRF5/wiring_analog_nRF52.c#L214]
    If you clone this code, for nRF52 you have to use another timer, like TIMER2, because you can't define the interrupt routine twice.
    So I'm trying to program the S4AT modules and I have the ugly message
    auto erase enabled
    Info : nRF51822-QFAA(build code: H0) 256kB Flash
    Error: failed erasing sectors 0 to 13
    I tried to use JLink programs but it says it cannot connect to the module, so I cannot unlock (ends with timeout message) and I cannot erase (fails with -1 return value)...
    Thank you it works ! ❤ ❤ ❤
    That's probably when trying to use this function that I managed to unlock&erase the EByte module "by mistake" 🙂
    The only problem now is the range seems to be very bad 😞
    Less than 10m with just a brick wall and it fails to completely send the presentation messages.
    EBytes nrf52832 module works well in the same conditions, same for their nrf24 modules.
    [Edit] in fact not that bad, it works ok when changing the orientation of the module. Could be due to the funky wiring but my bet is it on the tiny antenna design. My gateway is an old through hole nrf24 clone so range should not be a problem in an appartment with a PA/LNA gateway.
    In this case I'm going to try a different Ebyte module. Maybe the one I'm using is defective or somehow became damaged.
    I'm happy to report this also worked when, just now, I programmed a new Ebyte module. Like d00616 said earlier, it's a much faster way to do a mass erase. 🙂
    Unfortunately, and in contrast with the nRF52 DK, the new Ebyte module I just programmed is behaving the same as the Ebyte I've been experimenting with. No change.
    Thanks for the caring replay.
    @Mike_Lemo it is here :
    That would be great! 🙂 Please try the BatteryPoweredSensor sketch when you do. I'm very curious if you will have the same or different result as what I'm getting.
    Are you talking about the MyNRF5Board example? Arduino IDE compiles it for me without any complaints.
  • @NeverDie When choosing "MyNRF5Board nrf52832"?
    Yup.
    At some point, I had to re-arrange the libraries though (don't remember which files or which ones) to get all this stuff working. Before that, it wasn't finding the files. Actually, I think this would be a good topic for discussion, to make sure we're all doing it the same way. If we're doing it differently, it might make cross-checking each others attempts more difficult. Also, maybe there's a better way than the brute-force way that I did it.
    If anyone has interest, I can post how my libraries are currently structured. If nothing else, it would be a starting point for discussion on what to do (or not to do).
    Dunno that whole arduino BRF52832 programming thing seems too complicated just started to learn how to use the nordic SDK with eclipse until a proper solution is found.
    It hasn't been easy, I'll grant you that. I get the impression d00616 probably does most of his work in Linux, and so some of the disconnect with the Windows IDE probably stems from that. Once we get the basics ironed out, though, I expect things will go more smoothly. In fact, I think we're almost there. A lot of the work for sleeping, measuring source voltage, etc., has already been done, which is far better than starting from scratch. And there's even example code, which helps tremendously.
    Good news! Interestingly enough, the MockMySensors sketch seems to work fine when I load it onto the Ebyte. What a relief! So, I may try hijacking that sketch to convey voltage measurements instead of the BatteryPoweredSensor sketch that mysteriously hasn't been working on my Ebyte modules.
    The Nordic SDK is more complete than Arduino-nrf5 at the moment, but there is no compatibility with MySensors.
    The good news, with SDK 13 the 'Nordic Semiconductor ASA' License was changed. The old ASA was the reason for me to rewrite the complete ESB protocol. Now the license is much less restrictive. I think now the way is open to integrate SDK code into arduino-nrf5 or provide SDK based arduino-libraries.
    I can't change the way of Windows driver handling, but when there are Windows specific issues then they bust be fixed.
    You mean way more complete every thing is accesable there and there is an example for everything and I didn't use my sensors anyways
    No. I mean if you want to use the Nordic MCU with BLE and you want to access the whole hardware without developing drivers, then the Nordic SDK is an option. For special requirements like tone() you have to develop your own routine for Arduino or SDK.
    If you want write code which is compatible with other Vendors or want use MySensors then the SDK isn't the best choice.
    The arduino-nrf5 targets to provide the Arduino language. I think this is mostly complete. MySensors brings additional support for enhanced pin output modes and the random number generator (no SoftDevice support here).
    Accessing the internal MCU hardware must be added via Arduino libraries. With the new SDK license I think it's possible to put parts of the SDK into libraries supporting Hardware which is not specified in the Arduino reference.
    If you want to develop BLE applications with portable code, there are open source implementations like http://mynewt.apache.org/ which are designed to be portable.
    Good news! The hwCPUVoltage() function measures the Vcc voltage on the Ebyte module in millivolts. I'm able to send that as a barometer reading using the mocksensors sketch, and it arrives all the way into Domoticz, where it is logged and graphed. So, obviously I need to streamline that a bit, but the proof of concept works. 🙂
    Quantization error on the hwCpuVoltage() function appears to about 14 millivolts, which is a nice little improvement over the atmega328p. Measurement accuracy appears to be well within those bounds.
    Next step is to measure voltage on an analog pin using an AnalogRead. Not sure if the reference voltage is Vcc (as it typically is with the atmega328p) or something else for those measurements.
  • Given new Arduino Primo contains a buzzer connected to nrf52, we might expect tone() function to be compatible with nrf52 very soon
    https://www.arduino.cc/en/uploads/Main/ARDUINO_PRIMO-V022_SCH.pdf
    Strangely, if I do, say, analogRead(A4) on the nRF52832, all I get back is a 10-bit number, not a 12-bit number. i.e. the number never exceeds 1023. That can't be right. Should I be using a different function call to get the full 12 bits on the nRF52832?
    @NeverDie looks like you need to call analogReadResolution first https://github.com/sandeepmistry/arduino-nRF5/blob/425e719af8d85b543def01e49a6ef4048525dc59/cores/nRF5/wiring_analog.h#L74
    Thanks! That did the trick. Calling analogReadResolution(12) once in Setup() routine, I now get back a 12-bit number (i.e. up to 4095) thereafter when I do an analogRead(...). 🙂
    So, just did the experiment, and here are the results. Supplying 3.3v to the Ebyte Module, a voltage of 3.0 volts on A4 yields an analogRead(A4) of 4095. Less voltage on A4 yields a lower number.
    So, generalizing, I suspect that the reference voltage for analogRead() is Vcc-0.3.
    So, you either know Vcc, because of a voltage regulator or something, or else you must call hwCpuVoltage() to get what it is. Then, subtract 0.3v from that, and that's the reference voltage which corresponds to an analogRead() return value of 4095.
