    I am running 2 gateway instances, one nrf24 and one rfm69 so I guess you can run other things
    @gohan: but you had to do a lot of black magic to get there right?
    not at all, I just followed the guide in the forum
    @masmat I got the Pi Zero W working fine with other things using the GPIO.
    • A fresh install helped
    • It could be that I now use the PiGPIO library for the project.
    • It could be the switch to another powersupply. I was using the official pi powersupply, but I suspect something was wrong with it. A cheap 3A chinese adapter is working fine.
    Either way: it all works now.
    I have a few n00bish questions about enabling encryption (without signing, so save space and ram):
    • Is putting an AES key in MyConfig.h really all I have to do? Don't I also have to put that in all the sensor nodes? And is that proces complicated, using a signing sketch and whatnot?
    • Can I have an 'opportunistic' network, where I have some encrypted nodes, and some unencrypted ones? If I could mix them this would make switching to encryption less stressful. I can't easily change two of my nodes.
    • If I change the network, I'd like to move the NRF to channel 100 (juist outside of the normal WiFi frequencies). Do I also have to set that in all nodes, or is setting it in the gateway enough?
    @alowhum encryption is all or nothing. You can't leave one node without encryption if your gateway encrypts the messages it send.
    And you will need to personalize your nodes to get the AES key into them. The documentation on security describes that process.
    @alowhum if you put it in myconfig.h also on the arduino library you can just recompile the nodes and you are good.
    @gohan not anymore. Only for pre 2.2.0 releases.
    It is still working on mine 😅
    @gohan in other words, you use an old release 😉
    I can assure you I am using 2.2 from development as I am also running new driver. So unless you changed something in the last 3 weeks on the development branch it still works, unless the nodes are keeping the key saved.
    @gohan have you verified your communications are actually encrypted?
    @gohan If you see here, you will find that unless you use the simple password option, AES key is fetched from EEPROM: https://github.com/mysensors/MySensors/blob/28c4f3f19e7026f56fd9bbc61d566f770fd7a9d2/hal/transport/MyTransportRF24.cpp#L68
    So either you are using the simple flag, nothing at all, or not using the key you think you use.
    I ll have to check, but I put the key in the gateway myconfig.h
    @gohan Perhaps on a rpi GW where there is no EEPROM, but I am talking about the nodes.
    Well, if I have communication working it means the node should be encrypting data. I'll have to try with clear eeprom and try flashing sketch again
    @gohan not if there is no encryption at all. You could try to use simple password option on a node with various passwords and see if it is detected by your gw at all.
    @anticimex I guess you were right... the gw and node aren't using the AES key. So where am I supposed to add it in the gateway?
    @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
    @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
    @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
  • @macvictor
    I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
    import RPi.GPIO as GPIO
    from lib_nrf24 import NRF24
    import time
    import spidev
    GPIO.setmode(GPIO.BCM)
    pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
    radio = NRF24(GPIO, spidev.SpiDev())
    radio.begin(0,8)
    radio.setPayloadSize(32)
    radio.setChannel(0x76)
    radio.setDataRate(NRF24.BR_1MBPS)
    radio.setPALevel (NRF24.PA_MAX)
    radio.setAutoAck(True)
    radio.enableDynamicPayloads()
    radio.enableAckPayload()
    radio.openReadingPipe(1 ,pipes[1])
    radio.printDetails()
    radio.startListening()
    radio.GPIO.cleanup()
    Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
    @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
  • To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
    @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
  • @macvictor
    Hi
    Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
    @pepson signing is radio agnostic. It has nothing to do with the radio.
    @anticimex @wes Can I please ask how to update? I mean, the right command to type.
    I have the folder "MySensors" on documents of my user in Pi:
    /home/sineverba/MySensors
    Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
    I need also to relaunch the ./config command?
    Thank you to both and all!
  • Code Contributor
    #define MY_NODE_ID X
    Hi to all,
    1 - Disable the daemon with
    sudo rm -r MySensors
    # -*- coding: utf-8 -*-
    LOOKFOR = u"mysgw"
        if proc.name() == "mysgw":
            #print(proc)
            #print(cpu)
            #print(proc.cpu_times())
            if cpu > 50:
            else:
    Cheers,
    Pula
  • @Nick-Willis:
    from
    to
    sudo systemctl daemon-reload
    followed by
    to enable the change.
    Cheers,
    Otto
  • Code Contributor
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL (82)
    Maybe this helps.
    Cheers,
    Otto
  • Code Contributor
    Cheers,
    Otto
    thanks for the (hopeful) fix
  • @marceloaqno :
    and so on....
    Thanks again and cheers,
    Otto
  • Code Contributor
    My uptime is at 4 days now. so far still working with your patch. CPU is at 2% and sensor network still working correctly. will report if that changes.
  • I've been using your restarting method and its been working ok and has done one restart in 5 days.
    However I now see something else where altho cpu use is fine, none of my nodes can communicate to the gateway. My controller can connect to the gateway no problem but there are no messages received. Restarting nodes does not help. Only a manual restart of the gateway gets things going again - at least for a while anyway.
    Where is the log output from the gateway to be found? I know it can be run from the bash prompt to write the output to screen but how about logging the installed service output?
    @nick-willis the log is sent to syslog by default. See https://www.mysensors.org/build/raspberry#troubleshooting for details.
  • @marceloaqno : This is strange. I am using a RPi 1 on this gateway with raspbian Jessie. Beside the GW-service there is only a small python programm which listens on an UPD-Port and plays an mp3 if it receives suitable data (for doorbell). Since March 4, 20:15 there were several restarts due to high cpu usage (after dis-applying your patch):
    2018-03-04 23:01:03 cpu (99.7) very high! --> restarting service
    2018-03-05 07:31:03 cpu (99.7) very high! --> restarting service
    2018-03-05 11:01:03 cpu (98.7) very high! --> restarting service
    2018-03-05 13:31:04 cpu (94.7) very high! --> restarting service
    2018-03-06 11:31:03 cpu (99.7) very high! --> restarting service
    2018-03-06 12:31:03 cpu (98.7) very high! --> restarting service
    2018-03-07 06:01:03 cpu (94.8) very high! --> restarting service
    2018-03-07 22:31:03 cpu (99.8) very high! --> restarting service
    With this "auto-restarts" the sensors are working fine, I did not notice any problems.
    However, I just upgraded to the recent Stretch (what takes a LONG time on RPi 1 and made me struggle a little bit with the new network names). I also rebuilt the GW of course and will report here what will happen....
    @Nick-Willis : did you apply the patch of marceloaqno or not? Did you enable debugging? (see here )
    Cheers,
    Otto
  • Code Contributor
    @otto001 In a new attempt to trigger this problem, I am using a script that will force the fhem controller to reconnect every 30s to the gateway (built with mysensors master branch, unpatched), and sends me a note in case of high CPU usage:
    I'll leave it running for a few days to see what happens.
    Here is the script, if anyone is interested:
    #!/bin/sh
    while true; do
      (echo "set mysgw disconnect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
      sleep 1
      (echo "set mysgw connect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
      sleep 1
      cpu_percent=$(ps -C "mysgw" -o %cpu=)
      cpu_percent=${cpu_percent%%.*}
      if [ "$cpu_percent" -ge 90 ]
      then
        echo "ALERT: HIGH CPU USAGE"
        # pushbullet script from https://gist.github.com/outadoc/189bd3ccbf5d6e0f39e4
        /home/pi/pushbullet.sh "RPi1: HIGH CPU USAGE"
        exit
      fi
      sleep 30
    done
  • @marceloaqno : Thank you!
    Just a notice: I do NOT disconnect, I just connect every 30 minutes. Has been working for me since more than 2 years (ancient ms-gw version on RPi).
    Yesterday I did a dist-upgrade to stretch on the "problematic" gw (as mentioned above) - without your patch but with my monitoring-script running. It is a little bit to early I presume, but no high cpu problems so far. I will report back here in a few days. Maybe this problem is really related to old libraries or something?! If this is running stable for a few days I will apply your patch and see what happens.
    Thanks again!
    Cheers,
    Pula
  • Code Contributor
    @otto001 After a few hours running the reconnect script, I noticed several error messages in my gateway log:
    accept(): Too many open files
    The problem was that the gateway wasn't releasing the socket descriptor after each disconnection of the controller. After reaching the limit (mine was 1036) the controller can't connect.
    I'm not entirely sure that this problem is related to what you're having. You can check how many file descriptors currently opened by the gateway with the command below
    sudo lsof -u root |grep mysgw |wc -l
    The fix:
    https://github.com/marceloaqno/MySensors/commit/a40d4441b7460225100398ff6f2581c2b0df36ea
  • How do I update from master branch to development branch?
    Why do you want to do that? Development version is still work in progress
  • I'm using a raspberry pi gateway in home-assistant.
    Sometimes my gateway doesn't work anymore, and when I restart the service, it is running good
    I used ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
    Read the article again, there is the instruction on how to download the development version, but before you have to uninstall the mysgw service and rename the current mysensors folder to keep as backup.
  • Code Contributor
    @gieljnssns The fixes I mentioned above haven't yet been applied to the development branch. Eventually they will be, but I'm still doing some testing.
  • @marceloaqno :
    Thank you!!! Should this patch be applied together with your first patch?
    Interesting:
    After some days without problems on the newest raspbian packages the gw hung again, but WITHOUT high cpu usage (and WITHOUT your first patch applied). There were just no more reads from the sensors in the log, only the re-connects of fhem. After restarting the service, everything is fine again.
    Unfortunately I did see your post after that 😞
    But I checked the log and could not find the words "too" or "Too" in the log (running service with -d).
    Some minutes after restarting I checked how many open files there were with the command you supplied: 21
    In the meantime I have created a small udp listening service which restarts the service if a certain string is received, so I can restart the service by double-clicking one of my switches without the need of login to the gw (also for the wife)....
    @gieljnssns : I think you are experiencing exactly the same problem we are discussing 🙂
    Thanks again!
    Cheers,
    Otto
    I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
  • Code Contributor
    @otto001 The second patch can be applied without the first one.
  • @gohan :
  • @marceloaqno :
    Cheers,
    Otto
      Mosquitto-log:
    syslog:
    GW configure-line:
  • Code Contributor
  • Code Contributor
    You can download from:
    Here is a step-by-step:
    cd MySensors
  • @gohan
    I will try this...
  • @marceloaqno :
    Fortunately I can restart the gw now using a button and this udp-scripts 🙂
    cheers,
    Otto
    ..keeps repeating...
    ...and sudo ./bin/mysgw -d:
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
  • @gohan I configured:
    ./bin/mysgw -d:
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: failed to connect
    mysgw: GWT:TIN:ETH OK
    mysgw: GWT:TPS:ETH OK
  • Code Contributor
      No LSB modules are available.
      Distributor ID: Raspbian
      Release:        9.1
      Codename:       stretch
      persistence true
      allow_anonymous false
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    I'm not using mqtt.
    Cheers,
    Otto
    So is this normal?
  • @MasMat : what does your mysgw.log show?
  • @mfalkvidd Thanks fer info, now I can see the serial protocol as well in the syslog. Next step should be to have a logfile dedicated to mysgw.
  • @otto001
    Syslog:
    Mar 21 20:06:05 DietPi systemd[1]: Started MySensors Gateway daemon.
    Mar 21 20:06:05 DietPi mysgw: Starting gateway...
    Mar 21 20:06:05 DietPi mysgw: Protocol version - 2.2.0
    Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0
    Mar 21 20:06:05 DietPi mysgw: TSF:LRT:OK
    Mar 21 20:06:05 DietPi mysgw: TSM:INIT
    Mar 21 20:06:05 DietPi mysgw: TSF:WUR:MS=0
    Mar 21 20:06:05 DietPi mysgw: TSM:INIT:TSP OK
    Mar 21 20:06:05 DietPi mysgw: TSM:INIT:GW MODE
    Mar 21 20:06:05 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
    Mar 21 20:06:05 DietPi mysgw: MCO:REG:NOT NEEDED
    Mar 21 20:06:05 DietPi mysgw: MCO:BGN:STP
    Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
    Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
    Mar 21 20:06:05 DietPi mysgw: connected to 127.0.0.1
    Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
    Mar 21 20:06:05 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Where is mysgw.log?
  • @MasMat : I just forgot, that I reconfigured rsyslogd to log mysgw to a different file. syslog is correct.
    I do not use mqtt for mysensors yet, but the syslog seems good?
  • Was pointed here from another post, having serious issues with high CPU utilization op the gateway, is there any workaround and the moment?
    top:
    asks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.5 us, 23.0 sy,  0.0 ni, 74.3 id,  0.1 wa,  0.0 hi,  0.0 si,  0.0 st
    KiB Mem :   949580 total,   448732 free,   146912 used,   353936 buff/cache
    KiB Swap:   102396 total,   102396 free,        0 used.   737656 avail Mem
      337 root      20   0   20492   1060    932 R 100.0  0.1  28:54.55 mysgw
     3947 pi        20   0    8248   3324   2736 R   1.6  0.4   0:00.82 top
      447 homeass+  20   0  340112  63684   9916 S   1.0  6.7   3:28.71 hass
        7 root      20   0       0      0      0 S   0.3  0.0   0:04.18 rcu_sched
      767 root      20   0  126572   8628   6544 S   0.3  0.9   0:00.95 piplight-daemon
    PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="9"
    VERSION="9 (stretch)"
    Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
    Rebooting the pi sometimes helps, sometimes freezes the pi
    seeing nothing strange in the mysensors log what so ever
    running MySensors Version 2.2.0
    and Home Assistant Version 0.64.0
    Anyone can point me in the direction where to troubleshoot this further ?
    its not a high traffic gateway (around 10 sensors connected of which 5 updating every 15 minutes)
    @richard-van-der-plas the best workaround so far is in the post I linked to.
  • Code Contributor
    @mvader The gateway will respond with an I_VERSION every time a controller connected to port 5003 sends an I_VERSION request.
  • Code Contributor
    @gohan Sorry to hear that, mysgw doesn't change any system files, a simple reboot and rebuild of the gateway should be enough to resume communication in a case of more serious error.
  • Code Contributor
    @masmat This is my mosquitto.log
    1521680648: mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) starting
    1521680648: Config loaded from /etc/mosquitto/mosquitto.conf.
    1521680648: Opening ipv4 listen socket on port 1883.
    1521680648: Opening ipv6 listen socket on port 1883.
    1521762617: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
    1521763549: New connection from 127.0.0.1 on port 1883.
    1521763549: New client connected from 127.0.0.1 as mygateway1 (c1, k15, u'rpi').
    A socket error message:
    1521764339: Socket error on client mygateway1, disconnecting.
    shows only if I stop/exit mysgw.
  • 347
  • 584
  • 110
