  • Code Contributor
  • Code Contributor
    You can download from:
    Here is a step-by-step:
    cd MySensors
  • @gohan
    I will try this...
  • @marceloaqno :
    Fortunately I can restart the gw now using a button and this udp-scripts 🙂
    cheers,
    Otto
    ..keeps repeating...
    ...and sudo ./bin/mysgw -d:
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0
    mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: GWT:RMQ:MQTT RECONNECT
    mysgw: connected to 127.0.0.1
  • @gohan I configured:
    ./bin/mysgw -d:
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: failed to connect
    mysgw: GWT:TIN:ETH OK
    mysgw: GWT:TPS:ETH OK
  • Code Contributor
      No LSB modules are available.
      Distributor ID: Raspbian
      Release:        9.1
      Codename:       stretch
      persistence true
      allow_anonymous false
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: GWT:RMQ:MQTT CONNECTED
    mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    I'm not using mqtt.
    Cheers,
    Otto
    So is this normal?
  • @MasMat : what does your mysgw.log show?
  • @mfalkvidd Thanks fer info, now I can see the serial protocol as well in the syslog. Next step should be to have a logfile dedicated to mysgw.
  • @otto001
    Syslog:
    Mar 21 20:06:05 DietPi systemd[1]: Started MySensors Gateway daemon.
    Mar 21 20:06:05 DietPi mysgw: Starting gateway...
    Mar 21 20:06:05 DietPi mysgw: Protocol version - 2.2.0
    Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0
    Mar 21 20:06:05 DietPi mysgw: TSF:LRT:OK
    Mar 21 20:06:05 DietPi mysgw: TSM:INIT
    Mar 21 20:06:05 DietPi mysgw: TSF:WUR:MS=0
    Mar 21 20:06:05 DietPi mysgw: TSM:INIT:TSP OK
    Mar 21 20:06:05 DietPi mysgw: TSM:INIT:GW MODE
    Mar 21 20:06:05 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
    Mar 21 20:06:05 DietPi mysgw: MCO:REG:NOT NEEDED
    Mar 21 20:06:05 DietPi mysgw: MCO:BGN:STP
    Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
    Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
    Mar 21 20:06:05 DietPi mysgw: connected to 127.0.0.1
    Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
    Mar 21 20:06:05 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Where is mysgw.log?
  • @MasMat : I just forgot, that I reconfigured rsyslogd to log mysgw to a different file. syslog is correct.
    I do not use mqtt for mysensors yet, but the syslog seems good?
  • Was pointed here from another post, having serious issues with high CPU utilization op the gateway, is there any workaround and the moment?
    top:
    asks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.5 us, 23.0 sy,  0.0 ni, 74.3 id,  0.1 wa,  0.0 hi,  0.0 si,  0.0 st
    KiB Mem :   949580 total,   448732 free,   146912 used,   353936 buff/cache
    KiB Swap:   102396 total,   102396 free,        0 used.   737656 avail Mem
      337 root      20   0   20492   1060    932 R 100.0  0.1  28:54.55 mysgw
     3947 pi        20   0    8248   3324   2736 R   1.6  0.4   0:00.82 top
      447 homeass+  20   0  340112  63684   9916 S   1.0  6.7   3:28.71 hass
        7 root      20   0       0      0      0 S   0.3  0.0   0:04.18 rcu_sched
      767 root      20   0  126572   8628   6544 S   0.3  0.9   0:00.95 piplight-daemon
    PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="9"
    VERSION="9 (stretch)"
    Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
    Rebooting the pi sometimes helps, sometimes freezes the pi
    seeing nothing strange in the mysensors log what so ever
    running MySensors Version 2.2.0
    and Home Assistant Version 0.64.0
    Anyone can point me in the direction where to troubleshoot this further ?
    its not a high traffic gateway (around 10 sensors connected of which 5 updating every 15 minutes)
    @richard-van-der-plas the best workaround so far is in the post I linked to.
  • Code Contributor
    @mvader The gateway will respond with an I_VERSION every time a controller connected to port 5003 sends an I_VERSION request.
  • Code Contributor
    @gohan Sorry to hear that, mysgw doesn't change any system files, a simple reboot and rebuild of the gateway should be enough to resume communication in a case of more serious error.
  • Code Contributor
    @masmat This is my mosquitto.log
    1521680648: mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) starting
    1521680648: Config loaded from /etc/mosquitto/mosquitto.conf.
    1521680648: Opening ipv4 listen socket on port 1883.
    1521680648: Opening ipv6 listen socket on port 1883.
    1521762617: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
    1521763549: New connection from 127.0.0.1 on port 1883.
    1521763549: New client connected from 127.0.0.1 as mygateway1 (c1, k15, u'rpi').
    A socket error message:
    1521764339: Socket error on client mygateway1, disconnecting.
    shows only if I stop/exit mysgw.
  • @marceloaqno OK, I will look into that once I have an extra sensor feeding my gw (the one I built is a little complex and could be buggy).
    Another question: I configured mysgw without "simple password" to sort out problems.
    Now to reconfigure mysgw I have to run the "./configure --blah --blahblah..." command and "make", but do I also have to do "make install"? And do I have to re-start & enable the service? Should I stop it first also? Anybody got a step-by-step for this?
    You could also make a simple node running mock mysensors sketch that can simulate a working sensor, if you need some data running through the gateway. When I recompile the gateway I usually stop the service, uninstall the mysgw service and do the make and make install. I don't really know if it is actually required but I like to keep things clean
  • Code Contributor
    The two patches to fix ethernet stability have been merger into the development branch, and also some changes to the gateway logging. I updated the build instructions to reflect the changes.
  • @gohan I made a sensor that sends DHT11 temp+hum. This is the output (some of it..) from mosquitto_sub to topic mysensors-out. So I appear to have a something working. OpenHab2 is not finding any items still...
    pi@DietPi:~ $ mosquitto_sub  -u XXXXXX -P YYYYYY -v -t 'mysensors-out/#'
    mysensors-out/99/1/1/0/0 14.0
    mysensors-out/99/0/1/0/1 46.0
    mysensors-out/99/1/1/0/0 15.0
    mysensors-out/99/0/1/0/1 45.0
    mysensors-out/99/0/1/0/1 44.0
    Once I changed the config to include simple password, it's not showing anything anymore in mosquitto_sub
    It would appear that something is missing from my setup or there's a bug in the configure-line. Can someone tell if there's a bug here somewhere:
    sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXXXX --my-mqtt-password=YYYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    Look also in node log, that's the first place to look at
  • @gohan I did, I will post it (but it appears to send normally). But the only things I changed was:
    1. Rpi configure added: --my-signing=password --my-signing-password=ZZZZZZ
    2. In the nodes code: #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
    I use also these parameters with the normal signing
    --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug
    of course the debug parameter is there only for debug reasons
    @masmat check that the version you are using (release or beta) match your use of the simple flags, as they differ at the moment.
  • @anticimex Both Arduino IDE is 2.2 and Rpi is compiled with 2.2 stable.
    I'm seeing !TSF:MSG:SIGN FAIL in the serial monitor so something is not compatible... I will try making password >8 characters next (currently 6).
    I will also add those parameters to see if that makes a difference before reuploading arduino code
    @masmat if you add the signing debug flag and use the log parser on the homepage it should become clear what the problem is. You can also use the troubleshooting guide in the signing documentation.
  • @anticimex This is what's happening in the gw:
    TSF:MSG:READ,36-192-15,s=69,c=0,t=81,pt=1,l=21,sg=0:221
    !TSF:MSG:LEN,16!=28
    TSF:MSG:READ,75-68-77,s=48,c=1,t=110,pt=1,l=25,sg=1:249
    !TSF:MSG:LEN,16!=32
    The parser didn't really help much: more baffled than before....and I came away from the troubleshooting guide feeling really stupid 🙂
    @masmat looks to me that your gateway is not set up for signing
    @anticimex I think he didn't use all the parameters for the configure, right?
    @gohan the simple flags should not need more args, but I don't use a rPi as gw so I honestly am not sure exactly the args to use. The beta documentation has clear instructions for rPi signing, but those are specifically for beta branch and probably don't map exactly to the release yet.
  • @gohan The whole configure-line:
    sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    If anyone can tell what's missing or if there's a typo?
    @masmat you have redundant flags. The password option require no other signing flags. Only if you select software as signing backend you need other options (and none of the simple flags)
    And remember that if you use software signing and not password signing, you need to personalize the GW and/or node.
  • @anticimex I thought so too, but I'm grasping at straws to get the signing to work.
    To clarify, is the following enough for simple signing: --my-signing-debug --my-signing=password --my-signing-password=ZZZZZZ
    And the arduino code #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
    Any difference where it's placed in the code? Anything else to check for?
    @masmat it needs to be defined prior to the inclusion of mysensors.h. That should be it. (on the arduino node that is).
    While on the subject: what would be the flags needed for setting the gateway to only use the simple encryption but not the (simple) signing feature?
    I looked in the documentation and the node commands aren't mirrored for the gateway. I was hoping for something like:
    --MY_SIGNING_SIMPLE_PASSWD=flowerpot77
    --MY_ENCRYPTION_SIMPLE_PASSWD=spiderman41
    It's actually not needed since you can still set signing as optional on gateway
    @alowhum that feature is still only available for beta and is documented here: https://www.mysensors.org/apidocs-beta/group__SecuritySettingGrpPub.html
    EDIT: not yet for rPi
    Pull requests are welcome. I don't have time for this at the moment.
    Right. So is this correct?
    NODES (arduino nano)
    On all my nodes I will update them to have this code at the top:
    #define MY_ENCRYPTION_SIMPLE_PASSWD spiderman41 // unfortunately Nano hardware doesn't really have enough memory for signing.
    #define MY_RF24_CHANNEL 100 // in EU the default channel 76 overlaps with wifi.
    #define MY_RF24_DATARATE RF24_1MBPS // slower datarate makes the network more stable?
    GATEWAY (Raspberry Pi Zero W)
    On my gateway I will use this configure code:
    --my-security-password=spiderman41
    --my-rf24-encryption-enabled
    --my-rf24-channel=100
    --extra-cxxflags="-DMY_RF24_DATARATE=(RF24_1MBPS)"
    @alowhum you will need to enable weak security as well as that will enable both signing and encryption with signature requirements from all nodes on the gw
    @Anticimex thanks!
    But I don't want signing? Or do you mean that it will remove that requirement?
    I only need to set that on the gateway, right?
    I've also added a slower datarate, thinking that will also create a more stable connection. I am in a busy urban environment with lots of RF noise. Is that smart?
    @alowhum I thought you did not want signing: "but not the (simple) signing feature?"
    Yes, I don't want signing. But what you wrote said that it wil ENABLE signing. Check your sentence. Probably a typo, but I wanted to make sure 🙂
    @alowhum the simple security flag enables signing yes.
    But does the "--my-signing-weak_security" enable signing?
    I want to disable signing completely. What flags do I need to use when building a gateway that only uses encryption?
    @alowhum just don't use any flags mentioning signing, personalize the gw according to the documentation and pick the appropriate encryption flag.
  • @anticimex I've built a new node, DHT11 that sends temp&hum data. I reconfigured Rpi with this:
    sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-signing-password=XXXXXX --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=YYYY --my-mqtt-password=ZZZZZ --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    This is what I get in gw syslog:
    Apr  2 22:53:11 DietPi mysgw: Starting gateway...
    Apr  2 22:53:11 DietPi mysgw: Protocol version - 2.2.0
    Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
    Apr  2 22:53:11 DietPi mysgw: !SGN:BND:PWD<8
    Apr  2 22:53:11 DietPi mysgw: !SGN:INI:BND FAIL
    Apr  2 22:53:11 DietPi mysgw: TSF:LRT:OK
    Apr  2 22:53:11 DietPi mysgw: TSM:INIT
    Apr  2 22:53:11 DietPi mysgw: TSF:WUR:MS=0
    Apr  2 22:53:11 DietPi mysgw: TSM:INIT:TSP OK
    Apr  2 22:53:11 DietPi mysgw: TSM:INIT:GW MODE
    Apr  2 22:53:11 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
    Apr  2 22:53:11 DietPi mysgw: MCO:REG:NOT NEEDED
    Apr  2 22:53:11 DietPi mysgw: MCO:BGN:STP
    Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
    Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
    Apr  2 22:53:11 DietPi mysgw: connected to 127.0.0.1
    Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
    Apr  2 22:53:11 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:READ,99-99-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:BC
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:FPAR REQ,ID=99
    Apr  2 22:53:23 DietPi mysgw: TSF:PNG:SEND,TO=0
    Apr  2 22:53:23 DietPi mysgw: TSF:CKU:OK
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:GWL OK
    Apr  2 22:53:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=8
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    Apr  2 22:53:25 DietPi mysgw: TSF:MSG:READ,99-99-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=24
    Apr  2 22:53:25 DietPi mysgw: TSF:MSG:PINGED,ID=99,HP=1
    Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=25
    Apr  2 22:53:25 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    Apr  2 22:54:18 DietPi mysgw: TSF:MSG:READ,99-99-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
    Apr  2 22:54:18 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
    Apr  2 22:54:18 DietPi mysgw: !SGN:NCE:GEN
    Apr  2 22:54:23 DietPi mysgw: TSF:MSG:READ,99-99-0,s=0,c=3,t=16,pt=0,l=0,sg=0:
    Apr  2 22:54:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
    Apr  2 22:54:23 DietPi mysgw: !SGN:NCE:GEN
    This is kicking my butt... I cant understand that last part about the nonce 😞
    I will add the code from the node as soon as possible.
    @masmat according to the log parser
    means the password is too short.
    @masmat and this
    !SGN:INI:BND FAIL
    Means the signing backend failed to initialize. So you need to make the password longer.
  • @mfalkvidd Made the password 10 characters. From looks of the logs, it's working now.
    I cant believe I skipped the step of making the password longer... Just got too fixated on the password I came up with.
    @masmat the nonce failures is because the backend never initialized so basically any call to the backend that can fail will fail.
    I just discovered these USB-to-NRF24 devices. Would it be possible to use that instead of connecting to the GPIO pins?
    https://www.aliexpress.com/item/USB-wireless-serial-module-serial-to-nRF24L01-digital-communication-remote-control-acquisition-module-nRF2401/32722937957.html
    @alowhum not with the existing code. Is there a datasheet that describes how these modules work?
    One of the reviews says "have no idea wath software to use with this" so documentation might be hard to come by.
    Background: I use signing software on some nodes + whitelisting on a node (of course only PI serial is on the whitelist).
    With current --development branch (I think 2.3.0alpha) I cannot anymore set my previous personalized flags on gateway RPI3.
    In detail, with current master (2.2.0) I can do:
    sudo mysgw --set-soft-hmac-key=F618D4[...]848992B
    sudo mysgw --set-soft-serial-key=26[...]9
    sudo mysgw --set-aes-key=EC7[...]CEB4
    WIth development I did see only the --get[...] flags and cannot set anymore. Can you confirm?
    How can I set my previous values for signing?
    @sineverba I believe this change alters how rPi port handles signing related personalisation: https://github.com/mysensors/MySensors/commit/3c0b2727a56907277d4d04c985fd72b14e4a483c
    And, as usual, the documentation is a good place to start 😉 https://www.mysensors.org/apidocs-beta/group__MySigninggrpPub.html#MySigninggrphowuse
  • I'm currently compiling the code for connecting the NRF24l01+ directly to the Raspberry PI. Since I'm running the controller (on this case OpenHab) on the same Raspberry PI, would it be recommended the Ethernet or the serial flavor of it?
    In the case of ethernet, can I place the own machine IP (127.0.0.1)? This way, if I need to change the IP address of the PI it wouldn't affect the communication between the controller and the MySensors code, right?
    --my-gateway=ethernet --my-controller-url-address=127.0.0.1
    And by the way, for the signing configuration, it is mentioned in the documentation "Update the gateway config file with the generated keys/valeus", what file is that (name, path)?
    I should be able to re-use the keys I have defined before, right? So I just go to step 2 (no need to generate new keys).
    I'm refering to this link.
    --my-controller-url-address=127.0.0.1 is not needed for ethernet
  • I found that the configuration file is /etc/mysensors.conf but " The first time you start the gateway the configuration file will be created if it does not already exist.", so that's why I wasn't finding it.
    Anyway, the file states that:
    "Note: The gateway must have been built with signing support to use the options below."
    What flags should I include to have signing support?
    OK, found it: just run ./configure -h and there is a list of options. Leaving it here just for future reference
    @joaoabs said in 💬 Building a Raspberry Pi Gateway:
    it is already written in the article
  • Thanks for the replies.
    I've changed the PI from a PI1 to a PI3 and was able to make it working with signing. Its running smoothly, I guess the GW is chosen :).
    I'll now focus on the nodes, specially the SenseBender micros that are 2xAA battery powered and are consuming ~3% bat per day, but that will be for another post...
    Joaoabs
  • Hi, is there any way to check the current gateway operating parameters? My purpose is to check the radio channel and power level set before compilation but I would be glad if I could check other configurable parameters. I looked at Makefile.inc and found some flags set, but not the information I was looking for (does it mean that the default values are set)? Debug logs neither provide these informations.
    What radio are you using?
  • @gohan nrf24, one deployment pa+lna version with external antenna and the other standard with build-in "zig-zag" antenna.
    I always set gw to max power if the radio is shielded
    Is it normal to have frequently these errors in the RPI GW?
    May 11 00:43:54 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
    May 11 00:43:56 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
    May 11 00:43:58 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
    May 11 00:44:00 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
  • @gohan Well, that is not an answer to my question apparently 🙂 I suppose that max power lever is the default setting according to the configure script's help.
    also look for a channel outside the WiFi range
  • Openhab2 on pi3b+ using nrf24 radios and mqtt. I can follow the wiring diagram, but the commands are a bit confusing and seem to jump around randomly. Do I put all the --my-blah-blah together after the ./configure to build a file? Should I do development version? Do the nfr improvements go together with everything else?
    @kberck3 said in 💬 Building a Raspberry Pi Gateway:
    From the article "Note: All options must be added to the same line, after ./configure"
    Leave the development version for now, the stable works fine.
    @gohan to be fair, I added that note this morning so kberck3 might not have seen it 🙂
  • Appreciate the reply mfalkvidd and gohan! Service is running, will report back if I run into other issues.
  • Hi Guys,
    Is anyone here using the Pi with OTA updates? I'm finding them painfully slow (1-2 stream messages every few seconds). It's taking 1 hour per OTA update compared with 2-3 minutes when using the Arduino gateway!
    I did some tests on pi3 and I found slow ota too. Tekka has an open issue on github about this.
  • Hey guys,
    I tried to setup my Raspberry running Node-RED and serial gateway but I got stuck halfway. I followed the serial gateway compilation above and got it up and running, however using the serial nodes an Node-RED I could not manage to get them to connect tho the gateway.
    First I tried to connect to /dev/ttyMySensorsGateway which did not work due to permissions (owned by root). When checking out /dev/ttyMySensorsGateway I found it links to /dev/pts/1
    which belongs to root and the tty group. But I could not connect to this as the tty group only has write privileges. I think I miss some crucial point connecting those two together so I hope somebody can save the day by pointing me in the right direction.
    Thanks in advance,
    mirodin
    @mirodin
    So you run a separate arduino board as a mysensors gateway, connected with serial (USB) to your raspberry pi? Or do you mean that you are using the rpi directly with radio, and then run the rpi variant of the mysensors gateway code?
  • @tbowmo I run the gateway on my Pi directly with the radio is connected to the Pi's GPIOs. Compilation and gateway do just fine I, if only I could convince my Pi to let Node-RED talk to the device 😄
    EDIT:
    This is my output:
    dietpi@buddy:~ $ ll /dev/ttMySensorsGateway
    lrwxrwxrwx 1 root root 10 Jun 18 14:38 /dev/ttMySensorsGateway -> /dev/pts/2
    dietpi@buddy:~ $ ll /dev/pts/
    total 0
    crw--w---- 1 dietpi tty  136, 0 Jun 18 14:38 0
    crw--w---- 1 dietpi tty  136, 1 Jun 18 14:38 1
    crw--w---- 1 root   tty  136, 2 Jun 18 14:38 2
    crw--w---- 1 dietpi tty  136, 3 Jun 18 14:38 3
    c--------- 1 root   root   5, 2 Nov  3  2016 ptmx
    wasn't it the problem of the missing permission on the dialup group?
  • Unfortunately adding my nodered user to dialout did not bring the hoped success. I still get premission denied messages after a reboot of my raspberry.
    As my console print above shows the /dev/pts device belongs to tty but adding nodered to tty did not work out either (since the group only has write privileg). I have no idea how to fix this other then chowning the port to nodered but that feels wrong for me after years using linux based systems.
    it is not a solution, but you could switch to ethernet GW and you will avoid all the permissions problems.
    My 5 cents:
    Run it as a MQTT gateway, if possible. It makes things so much easier, when you interact with the data in node-red. Even integrating other controllers is easier, as you have the MQTT as standard backbone bus between everything.
    You need to have a MQTT broker (mosquitto) running as well.. But it's worth it..
  • Yes I came to the conclusion that this might be my only option even if it sucks as I have to subscribe to all events from MySensors, process them with Node-RED and republish again which screws my logging a bit. Right now I have another flow subscribed to "#" and write every event into my DB.
    Since I have everything talking to mosquitto setup to follow Homie Convention I was hoping for only having my MQTT broker bombarded with compliant messages and have Node-RED convert everything (assign device names, etc. using a SQLite DB) from serial so the rather cryptic MySensors topics do not show up there.
  • 347
  • 584
  • 110
18
