nRF5 action!
    //#define MY_RADIO_NRF24
    #define MY_RADIO_NRF5_ESB
    //#include <MySensors.h>
    int oldBatteryPcnt = 0;
    uint16_t counter=0;
    uint16_t volts=0;
    uint16_t theHwCPUVoltage()
    #if defined(NRF_ADC)
      // NRF51:
      // 20uS@260uA
      NRF_LPCOMP->ENABLE = 0;
      // Enable and configure ADC
      NRF_ADC->ENABLE = 1;
      NRF_ADC->EVENTS_END = 0;
      NRF_ADC->TASKS_START = 1;
      while(!NRF_ADC->EVENTS_END);
      NRF_ADC->TASKS_STOP = 1;
      NRF_ADC->ENABLE = 0;
      // Restore LPCOMP state
      return (sample*3600)/255;
    #elif defined(NRF_SAADC)
      // NRF52:
      // Sampling time 3uS@700uA
      int32_t sample;
      NRF_SAADC->RESULT.MAXCNT = 1;
      NRF_SAADC->TASKS_START = 1;
      NRF_SAADC->EVENTS_END = 0;
      NRF_SAADC->TASKS_SAMPLE = 1;
      NRF_SAADC->TASKS_STOP = 1;
      // unknown MCU
      return 0;
      while (true) {
        volts=theHwCPUVoltage();
        Serial.print("counter=");
        Serial.print(counter++);
        Serial.println(volts);
    //#else
    //	analogReference(INTERNAL);
    //#endif
    I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage.
    Sorry, you'll need two.
    @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint ๐Ÿ˜‰
    @Nca78
    Thanks! Good to know.
    Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
    @Nca78
    Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.
    @Nca78
    They are on the pinout, so you only have 4 I/Os available.
  • From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
  • Does anybody know why the function tone() doesn't work for the nrf52?
  • @mfalkvidd said in nRF5 Bluetooth action!:
    BUZZER_PIN = 26
    BUZZER_TONE = 3000
    ATmega8
    ATmega168/328
    ATmega1280
    ATmega8
    ATmega168/328
    ATmega1280
    How is it possible to make it copatible with the NRF52?
    @Mike_Lemo it (the tone library) would need to be ported
    @Mike_Lemo it would need to be ported
    No idea what you are talking about.
    Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5๐Ÿ˜ž
  • Someone managed to get NFC to work with this IC on the arduino IDE?
  • Some Nordic guidance might help.
    results in a loss of control by the sketch itself to something within MySensors that wants to establish communication between the node and the gateway. Not even sure how that is happening. In any case, it is just overcomplicating the debugging, and I really don't want that right now because it is effectively hanging what I'm trying to do. ๐Ÿ˜
    You have to install the "MySensors nRF5 Boards" package. In the examples section for this package, you can find two files (MyNRF5Board.h + MyNRF5Board.cpp). Add these files to your sketch and compile it using "MyNRF5Board nRF52822" as you board.
    The registers are documented in the Infocenter and the bitfields.
    To access the registers, you have to add '#include <nrf.h>' to your code. Mostly the hardware is accesses by NRF_HWNAME->REGISTER
    Doing PWM is a little bit complex. The code is different for nRF51 and nRF52. Look into wiring_analog_nRF51.c and (wiring_analog_nRF51.c)[https://github.com/sandeepmistry/arduino-nRF5/blob/c98a190eb34c0247eb8e0764a6367c7f9e51d2fc/cores/nRF5/wiring_analog_nRF52.c#L214]
    If you clone this code, for nRF52 you have to use another timer, like TIMER2, because you can't define the interrupt routine twice.
    So I'm trying to program the S4AT modules and I have the ugly message
    ** Programming Started **
    auto erase enabled
    Info : nRF51822-QFAA(build code: H0) 256kB Flash
    Error: failed erasing sectors 0 to 13
    I tried to use JLink programs but it says it cannot connect to the module, so I cannot unlock (ends with timeout message) and I cannot erase (fails with -1 return value)...
    Thank you it works ! โค โค โค
    That's probably when trying to use this function that I managed to unlock&erase the EByte module "by mistake" ๐Ÿ™‚
    The only problem now is the range seems to be very bad ๐Ÿ˜ž
    Less than 10m with just a brick wall and it fails to completely send the presentation messages.
    EBytes nrf52832 module works well in the same conditions, same for their nrf24 modules.
    [Edit] in fact not that bad, it works ok when changing the orientation of the module. Could be due to the funky wiring but my bet is it on the tiny antenna design. My gateway is an old through hole nrf24 clone so range should not be a problem in an appartment with a PA/LNA gateway.
    In this case I'm going to try a different Ebyte module. Maybe the one I'm using is defective or somehow became damaged.
    I'm happy to report this also worked when, just now, I programmed a new Ebyte module. Like d00616 said earlier, it's a much faster way to do a mass erase. ๐Ÿ™‚
    Unfortunately, and in contrast with the nRF52 DK, the new Ebyte module I just programmed is behaving the same as the Ebyte I've been experimenting with. No change.
    Thanks for the caring replay.
    @Mike_Lemo it is here :
    That would be great! ๐Ÿ™‚ Please try the BatteryPoweredSensor sketch when you do. I'm very curious if you will have the same or different result as what I'm getting.
    Are you talking about the MyNRF5Board example? Arduino IDE compiles it for me without any complaints.
  • @NeverDie When choosing "MyNRF5Board nrf52832"?
    Yup.
    At some point, I had to re-arrange the libraries though (don't remember which files or which ones) to get all this stuff working. Before that, it wasn't finding the files. Actually, I think this would be a good topic for discussion, to make sure we're all doing it the same way. If we're doing it differently, it might make cross-checking each others attempts more difficult. Also, maybe there's a better way than the brute-force way that I did it.
    If anyone has interest, I can post how my libraries are currently structured. If nothing else, it would be a starting point for discussion on what to do (or not to do).
    Dunno that whole arduino BRF52832 programming thing seems too complicated just started to learn how to use the nordic SDK with eclipse until a proper solution is found.
    It hasn't been easy, I'll grant you that. I get the impression d00616 probably does most of his work in Linux, and so some of the disconnect with the Windows IDE probably stems from that. Once we get the basics ironed out, though, I expect things will go more smoothly. In fact, I think we're almost there. A lot of the work for sleeping, measuring source voltage, etc., has already been done, which is far better than starting from scratch. And there's even example code, which helps tremendously.
    Good news! Interestingly enough, the MockMySensors sketch seems to work fine when I load it onto the Ebyte. What a relief! So, I may try hijacking that sketch to convey voltage measurements instead of the BatteryPoweredSensor sketch that mysteriously hasn't been working on my Ebyte modules.
    The Nordic SDK is more complete than Arduino-nrf5 at the moment, but there is no compatibility with MySensors.
    The good news, with SDK 13 the 'Nordic Semiconductor ASA' License was changed. The old ASA was the reason for me to rewrite the complete ESB protocol. Now the license is much less restrictive. I think now the way is open to integrate SDK code into arduino-nrf5 or provide SDK based arduino-libraries.
    I can't change the way of Windows driver handling, but when there are Windows specific issues then they bust be fixed.
    You mean way more complete every thing is accesable there and there is an example for everything and I didn't use my sensors anyways
    No. I mean if you want to use the Nordic MCU with BLE and you want to access the whole hardware without developing drivers, then the Nordic SDK is an option. For special requirements like tone() you have to develop your own routine for Arduino or SDK.
    If you want write code which is compatible with other Vendors or want use MySensors then the SDK isn't the best choice.
    The arduino-nrf5 targets to provide the Arduino language. I think this is mostly complete. MySensors brings additional support for enhanced pin output modes and the random number generator (no SoftDevice support here).
    Accessing the internal MCU hardware must be added via Arduino libraries. With the new SDK license I think it's possible to put parts of the SDK into libraries supporting Hardware which is not specified in the Arduino reference.
    If you want to develop BLE applications with portable code, there are open source implementations like http://mynewt.apache.org/ which are designed to be portable.
    Good news! The hwCPUVoltage() function measures the Vcc voltage on the Ebyte module in millivolts. I'm able to send that as a barometer reading using the mocksensors sketch, and it arrives all the way into Domoticz, where it is logged and graphed. So, obviously I need to streamline that a bit, but the proof of concept works. ๐Ÿ™‚
    Quantization error on the hwCpuVoltage() function appears to about 14 millivolts, which is a nice little improvement over the atmega328p. Measurement accuracy appears to be well within those bounds.
    Next step is to measure voltage on an analog pin using an AnalogRead. Not sure if the reference voltage is Vcc (as it typically is with the atmega328p) or something else for those measurements.
  • Given new Arduino Primo contains a buzzer connected to nrf52, we might expect tone() function to be compatible with nrf52 very soon
    https://www.arduino.cc/en/uploads/Main/ARDUINO_PRIMO-V022_SCH.pdf
    Strangely, if I do, say, analogRead(A4) on the nRF52832, all I get back is a 10-bit number, not a 12-bit number. i.e. the number never exceeds 1023. That can't be right. Should I be using a different function call to get the full 12 bits on the nRF52832?
    @NeverDie looks like you need to call analogReadResolution first https://github.com/sandeepmistry/arduino-nRF5/blob/425e719af8d85b543def01e49a6ef4048525dc59/cores/nRF5/wiring_analog.h#L74
    Thanks! That did the trick. Calling analogReadResolution(12) once in Setup() routine, I now get back a 12-bit number (i.e. up to 4095) thereafter when I do an analogRead(...). ๐Ÿ™‚
    So, just did the experiment, and here are the results. Supplying 3.3v to the Ebyte Module, a voltage of 3.0 volts on A4 yields an analogRead(A4) of 4095. Less voltage on A4 yields a lower number.
    So, generalizing, I suspect that the reference voltage for analogRead() is Vcc-0.3.
    So, you either know Vcc, because of a voltage regulator or something, or else you must call hwCpuVoltage() to get what it is. Then, subtract 0.3v from that, and that's the reference voltage which corresponds to an analogRead() return value of 4095.
    ๐Ÿ™‚
    I just did a quick and dirty measurement on the current consumption of the nRF52832 Ebyte module during sleep, and it measured 10 milliamps. I measured it using a uCurrent Gold. That's very high current for most battery powered applications. Can someone else here please measure it also and either confirm or refute?
    I invoked sleep with this from the mocksensors sketch:
    Perhaps there's a way to invoke a deeper sleep than that where less current is drawn?
  • @NeverDie
    Try
    sleep(60000); // Sleeps for a minute in deep sleep
    Thanks! That's a big improvement. I'm now reading 51uA. I did the measurements on the Ebyte nRF52832 module, powering it at 3.3v.
    However, to be frank, that's still rather high compared to, say, an atmega328p with a RFM69 radio, which can have a combined sleep current of less than 1uA.
    Is there anything more that can be done to lower the sleep current further?
  • @NeverDie
    Is that a bare board with nothing connected (Not even serial)?
    Yes. It's the bare Ebyte nRF52832 module. The only connections are Vcc and GND.
  • @NeverDie
    Theoretically it should be around 1.9uA
    Interestingly, I just now tried the same measurement with one of these nRF52832 modules instead of the Ebyte module:
    https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=a2g0s.9042311.0.0.KKA3PF
    and during sleep it measured 6uA. Quite a bit lower!
    Anyone know of a module which tests even lower than that?
    Did you use the same board definition in the IDE and the same script ?
    Yes.
  • @NeverDie
    Have you tried sleep and wait for an external interrupt instead of sleep and wake on timer?
    Just in case it is the lfxtl that is causing the problem.
    Haven't tried that yet. Is there a library functional call for that, or do I need to start addressing the registers directly? With this new mpu, I feel like I'm learning to walk all over again.
  • @NeverDie
    Try
    Try
    Unexpected result: using that as the sleep invocation, the infor-link module measures at 14ua while sleeping. i.e. worse, not better, compared to the 6ua measured earlier.
    Looks as though the infor-link is using an A620N crystal:
    I tried to see if I could find a datasheet for it, in the hope of learning what its current consumption is (or, at least, should be). Unfortunately, though, I couldn't find a datasheet for an A620N.
    Maybe it doesn't matter, because in looking at the actual module I received, it appears to use a different XTAL anyway: A649N.
    Maybe from a current consumption standpoint, not using an external XTAL crystal, but rather relying on the nRF52832's internal resonator would draw less current? I know that's true for the atmega328p. If so, then that's a trade-off worth examining more carefully.
  • @NeverDie
    Sorry i have been a little distracted because my waveshare BLE400 and jlink just turned up.
    Took a little time to get it running but i loaded up the mockmysensors sketch with all the sensors un commented and pow all 30 odd sensors showed up in domoticz which made me chuckle.
    Anyway post your sketch for the consumption testing and i will put it in and see if it works on my board.
    The only problem is i can not unplug it from the Ble400 because i have no way of connecting wires to the core board because of the smaller pitch pins.
    @rmtucker
    Here's the sketch I tested with:
    * MockMySensors
    //#define MY_RADIO_RFM95
    #define MY_NODE_ID 254
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    #define SKETCH_VERSION "v0.5"
    // Define Sensors ids
    	S_SCENE_CONTROLLER
    // one at a time.
    //#define ID_S_TEMP              7
    //// Lib 1.5 sensors
    //#define ID_S_SPRINKLER         29
    // Global Vars
    unsigned long SLEEP_TIME = 3600000; // Sleep time between reads (in milliseconds)
    bool metric = true;
    long randNumber;
    #ifdef ID_S_ARMED
    bool isArmed;
    #ifdef ID_S_LIGHT
    bool isLightOn=0;
    #ifdef ID_S_DIMMER
    int dimmerVal=100;
    #ifdef ID_S_COVER
    #ifdef ID_S_TEMP
    #ifdef ID_S_HUM
    #ifdef ID_S_BARO
    //MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
    #ifdef ID_S_WIND
    #ifdef ID_S_RAIN
    #ifdef ID_S_UV
    #ifdef ID_S_WEIGHT
    #ifdef ID_S_POWER
    #ifdef ID_S_HEATER
    float heater_setpoint=21.5;
    //  float heater_temp=23.5;
    //  bool heater_status=false;
    #ifdef ID_S_DISTANCE
    #ifdef ID_S_LIGHT_LEVEL
    #ifdef ID_S_LOCK
    bool isLocked = 0;
    #ifdef ID_S_IR
    long irVal = 0;
    #ifdef ID_S_WATER
    #ifdef ID_S_AIR_QUALITY
    #ifdef ID_S_DUST
    #ifdef ID_S_SCENE_CONTROLLER
    char *scenes[] = {
    	(char *)"Good Morning",
    	(char *)"Clean Up!",
    	(char *)"All Lights Off",
    	(char *)"Music On/Off"
    int sceneVal=0;
    int sceneValPrevious=0;
    #ifdef ID_S_RGB_LIGHT
    String rgbState="000000";
    //RGB light V_RGB, V_WATT
    #ifdef ID_S_RGBW_LIGHT
    String rgbwState="00000000";
    #ifdef ID_S_COLOR_SENSOR
    //Color sensor	V_RGB
    #ifdef ID_S_HVAC
    //Thermostat/HVAC device
    // NOT IMPLEMENTED YET
    #ifdef ID_S_MULTIMETER
    // V_VOLTAGE	38	Voltage level
    // V_CURRENT	39	Current level
    #ifdef ID_S_SPRINKLER
    #ifdef ID_S_WATER_LEAK
    #ifdef ID_S_SOUND
    #ifdef ID_S_VIBRATION
    #ifdef ID_S_MOISTURE
    #ifdef ID_S_CUSTOM
    	// Random SEED
    	randomSeed(analogRead(0));
    	wait(LONG_WAIT);
    	Serial.println("GW Started");
    	Serial.print(SKETCH_NAME);
    	wait(LONG_WAIT);
    	Serial.print("Get Config: ");
    	wait(LONG_WAIT);
    	// Init Armed
    #ifdef ID_S_ARMED
    	isArmed = true;
    #ifdef ID_S_DOOR
    	Serial.println("  S_DOOR");
    	wait(SHORT_WAIT);
    #ifdef ID_S_MOTION
    	Serial.println("  S_MOTION");
    	wait(SHORT_WAIT);
    #ifdef ID_S_SMOKE
    	Serial.println("  S_SMOKE");
    	wait(SHORT_WAIT);
    #ifdef ID_S_LIGHT
    	Serial.println("  S_LIGHT");
    	wait(SHORT_WAIT);
    #ifdef ID_S_DIMMER
    	Serial.println("  S_DIMMER");
    	wait(SHORT_WAIT);
    #ifdef ID_S_COVER
    	Serial.println("  S_COVER");
    	wait(SHORT_WAIT);
    #ifdef ID_S_TEMP
    	Serial.println("  S_TEMP");
    	wait(SHORT_WAIT);
    #ifdef ID_S_HUM
    	Serial.println("  S_HUM");
    	wait(SHORT_WAIT);
    #ifdef ID_S_BARO
    	Serial.println("  S_BARO");
    	present(ID_S_BARO,S_BARO," Voltage");
    	wait(SHORT_WAIT);
    #ifdef ID_S_WIND
    	Serial.println("  S_WIND");
    	wait(SHORT_WAIT);
    #ifdef ID_S_RAIN
    	Serial.println("  S_RAIN");
    	wait(SHORT_WAIT);
    #ifdef ID_S_UV
    	Serial.println("  S_UV");
    	wait(SHORT_WAIT);
    #ifdef ID_S_WEIGHT
    	Serial.println("  S_WEIGHT");
    	wait(SHORT_WAIT);
    #ifdef ID_S_POWER
    	Serial.println("  S_POWER");
    	wait(SHORT_WAIT);
    #ifdef ID_S_HEATER
    	Serial.println("  S_HEATER");
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    #ifdef ID_S_LOCK
    	Serial.println("  S_LOCK");
    	wait(SHORT_WAIT);
    #ifdef ID_S_IR
    	Serial.println("  S_IR");
    	wait(SHORT_WAIT);
    #ifdef ID_S_WATER
    	Serial.println("  S_WATER");
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    #ifdef ID_S_DUST
    	Serial.println("  S_DUST");
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    #ifdef ID_S_HVAC
    	Serial.println("  HVAC");
    	wait(SHORT_WAIT);
    	wait(SHORT_WAIT);
    #ifdef ID_S_SOUND
    	wait(SHORT_WAIT);
    #ifdef ID_S_CUSTOM
    	Serial.println("  S_CUSTOM");
    	wait(SHORT_WAIT);
    	Serial.println("");
    	Serial.println("");
    	Serial.println("");
    	randNumber=random(0,101);
    	Serial.println(randNumber);
    	// Send fake battery level
    	sendBatteryLevel(randNumber);
    	wait(LONG_WAIT);
    	// Request time
    	requestTime();
    	wait(LONG_WAIT);
    	//Read Sensors
    #ifdef ID_S_DOOR
    	door();
    #ifdef ID_S_MOTION
    	motion();
    #ifdef ID_S_SMOKE
    	smoke();
    #ifdef ID_S_LIGHT
    	light();
    #ifdef ID_S_DIMMER
    	dimmer();
    #ifdef ID_S_COVER
    	cover();
    #ifdef ID_S_TEMP
    	temp();
    #ifdef ID_S_HUM
    	hum();
    #ifdef ID_S_BARO
    	baro();
    #ifdef ID_S_WIND
    	wind();
    #ifdef ID_S_RAIN
    	rain();
    #ifdef ID_S_UV
    	uv();
    #ifdef ID_S_WEIGHT
    	weight();
    #ifdef ID_S_POWER
    	power();
    #ifdef ID_S_HEATER
    	heater();
    	distance();
    	light_level();
    #ifdef ID_S_LOCK
    	lock();
    #ifdef ID_S_IR
    	ir();
    #ifdef ID_S_WATER
    	water();
    	air();
    #ifdef ID_S_DUST
    	dust();
    	scene();
    	rgbLight();
    	rgbwLight();
    	color();
    #ifdef ID_S_HVAC
    	hvac();
    	multimeter();
    #ifdef ID_S_SOUND
    	moisture();
    #ifdef ID_S_CUSTOM
    	custom();
    	wait(SHORT_WAIT);
    	//wait(SLEEP_TIME); //sleep a bit
      //sleep(60000); // Sleeps for a minute in deep sleep
      //sleep(6000000); // Sleeps for 100 minutes in deep sleep
    //void door(){}
    #ifdef ID_S_DOOR
    void door()
    	Serial.print("Door is: " );
    	if (randNumber <= 50) {
    		Serial.println("Open");
    		Serial.println("Closed");
    #ifdef ID_S_ARMED
    	Serial.print("System is: " );
    #ifdef ID_S_MOTION
    void motion()
    	Serial.print("Motion is: " );
    		Serial.println("Active");
    		send(msg_S_MOTION_T.set(1));
    		Serial.println("Quiet");
    		send(msg_S_MOTION_T.set(0));
    #ifdef ID_S_ARMED
    #ifdef ID_S_SMOKE
    void smoke()
    	Serial.print("Smoke is: " );
    		send(msg_S_SMOKE_T.set(1));
    		send(msg_S_SMOKE_T.set(0));
    #ifdef ID_S_ARMED
    #ifdef ID_S_LIGHT
    void light()
    	Serial.print("Light is: " );
    #ifdef ID_S_DIMMER
    void dimmer()
    	Serial.println(dimmerVal);
    #ifdef ID_S_COVER
    void cover()
    	Serial.print("Cover is : " );
    	if (coverState == 1) {
    		Serial.println("Opening");
    		send(msg_S_COVER_U.set(1));
    		Serial.println("Closing");
    		send(msg_S_COVER_D.set(0));
    		Serial.println("Idle");
    		send(msg_S_COVER_S.set(-1));
    #ifdef ID_S_TEMP
    void temp()
    #ifdef ID_S_HUM
    void hum()
    #ifdef ID_S_BARO
    void baro()
    	//long pressure = map(randNumber,1,100,870,1086);// hPa?
    	//int forecast = map(randNumber,1,100,0,5);
       long voltage =  hwCPUVoltage();
    	Serial.print("Power source voltage is: " );
    	Serial.println(voltage);
    	send(msg_S_BARO_P.set(voltage));
    	//Serial.print("Weather forecast: " );
    	//send(msg_S_BARO_F.set(weather[forecast]));
    #ifdef ID_S_WIND
    void wind()
    #ifdef ID_S_RAIN
    void rain()
    #ifdef ID_S_UV
    void uv()
    #ifdef ID_S_WEIGHT
    void weight()
    	Serial.print("Weight is: " );
    #ifdef ID_S_POWER
    void power()
    	Serial.print("Watt is: " );
    	Serial.print("KWH is: " );
    #ifdef ID_S_HEATER
    void heater()
    	//  String heatState="Off";
    void distance()
    void light_level()
    #ifdef ID_S_LOCK
    void lock()
    	Serial.print("Lock is: " );
    #ifdef ID_S_IR
    void ir()
    	Serial.println(irVal);
    	send(msg_S_IR_S.set(irVal));
    	send(msg_S_IR_R.set(irVal));
    #ifdef ID_S_WATER
    void water()
    void air()
    #ifdef ID_S_DUST
    void dust()
    void scene()
    	Serial.print("Scene is: " );
    		sceneValPrevious=sceneVal;
    void rgbLight()
    	Serial.println(rgbState);
    void rgbwLight()
    	Serial.println(rgbwState);
    void color()
    	String colorState;
    	Serial.println(colorState);
    #ifdef ID_S_HVAC
    void hvac()
    	Serial.println(hvac_Speed);
    void multimeter()
    	Serial.println(impedance);
    	Serial.println(volt);
    	Serial.println(amps);
    #ifdef ID_S_SOUND
    void moisture()
    #ifdef ID_S_CUSTOM
    void custom()
    	switch (message.type) {
    #ifdef ID_S_ARMED
    	case V_ARMED:
    		isArmed = message.getBool();
    #ifdef ID_S_DOOR
    		door();//temp ack for door
    #ifdef ID_S_MOTION
    		motion();//temp ack
    #ifdef ID_S_SMOKE
    		smoke();//temp ack
    	case V_STATUS: // V_LIGHT:
    #ifdef ID_S_LIGHT
    			light(); // temp ack
    		//    #ifdef ID_S_HEATER
    		//    #endif
    #ifdef ID_S_DIMMER
    	case V_DIMMER:
    		dimmerVal= message.getInt();
    		dimmer();// temp ack
    #ifdef ID_S_COVER
    	case V_UP:
    		coverState=1;
    		Serial.println("V_UP");
    		cover(); // temp ack
    	case V_DOWN:
    		coverState=-1;
    		Serial.println("V_DOWN");
    		cover(); //temp ack
    	case V_STOP:
    		coverState=0;
    		Serial.println("V_STOP");
    		cover(); //temp ack
    	case V_HVAC_SETPOINT_HEAT:
    #ifdef ID_S_HEATER
    			heater();//temp ack
    #ifdef ID_S_HVAC
    			hvac();//temp ack
    	case V_HVAC_FLOW_STATE:
    #ifdef ID_S_HEATER
    			heater();//temp ack
    #ifdef ID_S_HVAC
    			hvac();//temp ack
    #ifdef ID_S_LOCK
    	case V_LOCK_STATUS:
    		lock(); //temp ack
    #ifdef ID_S_IR
    	case V_IR_SEND:
    		irVal = message.getLong();
    		ir(); // temp ack
    	case V_IR_RECEIVE:
    		ir(); // temp ack
    	case V_SCENE_ON:
    		sceneVal = message.getInt();
    		Serial.println(" On");
    		scene();// temp ack
    	case V_SCENE_OFF:
    		Serial.println(" Off");
    		scene();// temp ack
    	case V_RGB:
    		rgbState=message.getString();
    		rgbLight(); // temp ack
    	case V_RGBW:
    		rgbwLight();
    #ifdef ID_S_HVAC
    	//  hvac_SetPointHeat
    	//  hvac_SetPointCool
    	//  hvac_FlowState
    	//  hvac_FlowMode
    	//  hvac_Speed
    	case V_HVAC_SETPOINT_COOL:
    		hvac();//temp ack
    	case V_HVAC_FLOW_MODE:
    		hvac();//temp ack
    	case V_HVAC_SPEED:
    		hvac();//temp ack
    	default:
    		Serial.println(message.type);
    I selected the board "Nordic nRF52832 DK" in the board manager.
    You'll need a separate serial gateway running for it to communicate with, or else it will never get to the section where it sleeps.
    For the current measurement, just program it with the above sketch on your Waveshare, then unplug your module from the BLE400 board and power it using a GND dupont wire and a Vcc dupont wire connected through your uCurrent Gold, or whatever it is that you're using to measure current. I should think that would work, wouldn't it?
    Or do you only have the main board without the smaller plug-in module?
    It actually looks like a nice setup.
  • @NeverDie
    When you unplug the little board it only has 1.27mm spaced pins and they are not standard dupont size so shy soldering to them which would mean i could not plug it back in to the BLE.
    Anyway i am only using a crappy multimeter and with it plugged in and running your sketch i am getting 140uA but i will find a way of unplugging it so hang fire.
    @rmtucker you could try to just solder 2 tiny wires on top of the board for vcc and gnd pins so you don't mess with the connectors for plugin it back on the main board ?
    @Nca78
    Agreed. It sounds as though the bigger problem is going to be his crappy multimeter, if that's all he has. Maybe a good time for an upgrade?
  • @NeverDie
    Ok with my crappy multimeter i am getting 4-5uA with just Vcc and Ground connected.
    I'll try removing the 32.768Khz crystal from an infor-link module and then re-run the sketch that relies on an external interrupt to wake from sleep. Maybe that will get us closer to the theoretical minimum current of just the nRF52832 chip by itself.
  • @NeverDie
    Just a little thought on this and a bit of googling.
    Just the system on consumption is 1-2uA without the rtc that is needed for wakeup so i don,t think the figures we are getting are that far away from the spec sheet?
    Agreed. We're in the ballpark.
  • @NeverDie
    400,000 hours on 2xAA if we let it sleep.๐Ÿ˜„
    That will do for me!.
    Now a little playtime and maybe some range testing.
    Yeah, I guess I won't amputate the xtal just yet. It can run for quite a while at 6ua. ๐Ÿ™‚
    The internal reference is 0.6V the nRF5 MCU's have an internal programmable divider. With Arduino this divider is programmed to 1/5. If you switch to the external reference the "gain" is 1/4.
    I measure with my CDEByte 11-15ยตA for sleep without interrupt waiting. With a RedBear BLE Nano 2 I have measured 15ยตA. Both compiled as BLE Nano 2. I have used the VC165 multimeter.
  • @NeverDie
    I2c is not working properly either.
    Here is a test on a HTU21D sensor.
    HTU21D-F test
    Temp: -46.57		Hum: 84.10
    Temp: 81.10		Hum: 59.68
    Temp: 81.10		Hum: 26.48
    Temp: -2.64		Hum: 26.48
    Temp: 51.58		Hum: 26.48
    Temp: 4.91		Hum: 25.02
    Temp: 33.74		Hum: 25.02
    Temp: 93.45		Hum: 25.02
    Temp: 4.22		Hum: 26.48
    Temp: 95.51		Hum: 116.81
    Temp: -39.02		Hum: 116.81
    Temp: 94.14		Hum: 25.02
    Temp: 94.14		Hum: 116.81
    Temp: 120.22		Hum: 116.81
    Temp: -8.82		Hum: 111.44
    Temp: 120.22		Hum: 19.64
    Temp: 94.14		Hum: 111.44
    Temp: -8.82		Hum: 116.81
    Temp: 120.22		Hum: 111.44
    Temp: -8.82		Hum: 19.64
    Temp: 33.05		Hum: 111.44
    Temp: 94.14		Hum: 19.64
    Temp: 4.22		Hum: 19.64
    Temp: 2.84		Hum: 111.44
    Temp: 3.53		Hum: 111.44
    Temp: -10.20		Hum: 19.64
    Seems like there's more than one library named "Wire" that's floating around at the same time. I wonder if perhaps the compiler is finding the proper Wire library inside Arduino-nRF5? Or maybe it's linking with an unrelated Wire library? To answer that, you could try inserting a Serial.println() into the proper library and see if it fires off when you run your code.
  • @NeverDie
    Yes checked that and it is using the correct wire.h.
    @rmtucker
    Is there a mysensors demo sketch that involves i2c? I could try it on my end, though I expect I'd probably get the same as you.
    I see that Amazon is selling the Arduino Primo now: https://www.amazon.com/Arduino-A000138-low-power-coin-sized-wearables/dp/B073JN7XXR/ref=sr_1_12?ie=UTF8&qid=1501982634&sr=8-12&keywords=nrf52832
    First time I've seen it for sale anywhere.
  • 44
