  • @mfalkvidd I'm trying today, but to compile correctly the Docker image I'll have to clone to my github account 😞 or at least locally. My Dockerfile for the "Alpine edition" for Hass.io is simply:
    ARG BUILD_FROM
    ARG BUILD_ARCH
    ARG BUILD_DATE
    ARG BUILD_REF
    ARG BUILD_VERSION
    FROM ${BUILD_FROM}
    ENV CONFIG_PATH=/data/options.json
    ENV APPDIR=/opt/MySensors
    RUN apt-get update && apt-get install -y --force-yes \
        make \
    	 g++ \
    	 git \
    	 && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ~/.cache \
    	 && git clone https://github.com/mysensors/MySensors.git --branch development $APPDIR
    # Copy root filesystem
    COPY rootfs /
    #CMD [ "/run.sh" ]
    I deleted the LABELS 'cause... the data is still too rawly "buried" from others. 👅
    The Configure and Make is in run.sh.
    BTW, I still need to figure out how to start mysgw as service... Mainlyt I'd like to redirect the log: how can I do this safely?
    And... can I use the rx/tx/err led feature on Raspi too (aside being in a Docker) ?
    EDIT: the code add works!
    Another question: I'm not getting far from this... what is it trying to do?
    : Starting gateway...
    : Protocol version - 2.2.0-rc.2
    : MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
    : TSF:LRT:OK
    : TSM:INIT
    : TSF:WUR:MS=0
    @ghiglie Thank you, I did see that was for 2.1.1. Just playing with them!
    Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
    @alowhum If you want to just encrypt data, just add the encryption key in the myconfig.h file and compile it
  • @gohan N00b question, but which steps from the step-by-step need to be redone to "compile it" after altering myconfig.h? Or can you just post the command lines? 😳
    As soon as you do the changes in myconfig.h before the MAKE, you are fine
  • Anyone tried using the new Pi Zero WH as a Raspberry Pi Gateway. Presumably by MQTT and using NRF24 radio?
    @alowhum Have you been able to setup a gateway with your Raspberry Pi Zero?
  • @sentur That's what I'm doing now. Except mine is Zero W. Soldered the pins on myself.
  • Code Contributor
    @alowhum yes, to use MY_SIGNING_SIMPLE_PASSWD feature, add the following to your list of configure options:
    ... --my-signing=password --my-signing-password=<PASSWORD>
  • Is there anyway where i can see if i have IRQ configured ?
    ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
    look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
  • @gohanm, as it seems not ?, can i rebuild it easily? ```
    SOC=BCM2837
    CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
    LDFLAGS=-pthread
    PREFIX=/usr/local
    CC=gcc
    CXX=g++
    BUILDDIR=build
    BINDIR=bin
    GATEWAY_DIR=/usr/local/bin
    INIT_SYSTEM=systemd
    SPI_DRIVER=BCM```
    make a copy of it and make a ./configure with the IRQ enabled and see what you get
  • @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
    ill try it tomorrow, too afraid to break things late in the evening 😉
    as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
  • but ill have to do it sometime , just ./configure with all the options, build , test and install ?
    if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
  • @gohan ty
  • Moved to normal troubleshooting forum
    @MasMat Yes I was able to build it on a Pi Zero. I did a fresh install on Dietpi. It worked fine when I didn't give any configuration options.
    Now, however, I am still trying to run something on the PGIO pins in paralel to MySensors again, and this is not working. As I speak the Pi reboots every 5 minutes.. Not sure what to blame yet. Domoticz, PiGPIO, or MySensors.
    Latest DietPi Stretch, latest Domoticz beta, latest MySensors beta.
    PiGPIO
    what are you using that for?
  • @alowhum I'm not using the GPIO for anything else.
    I had everything working (mysgw-MQTT, Mosquitto, Node-Red and OH2) for almost 6h. Then I moved the set-up and everything went south: cant get mosquitto to start, cant get mysgw to connect to that or another Mosquitto broker, OH2 seems to ignore everything...
    Spent the last 24h trying to resurrect Mosquitto but it's beyond me what's wrong.
    I remember reading that mysgw renders rest of the gpio unusable. Maybe that's giving you problems.
    I am running 2 gateway instances, one nrf24 and one rfm69 so I guess you can run other things
    @gohan: but you had to do a lot of black magic to get there right?
    not at all, I just followed the guide in the forum
    @masmat I got the Pi Zero W working fine with other things using the GPIO.
    • A fresh install helped
    • It could be that I now use the PiGPIO library for the project.
    • It could be the switch to another powersupply. I was using the official pi powersupply, but I suspect something was wrong with it. A cheap 3A chinese adapter is working fine.
    Either way: it all works now.
    I have a few n00bish questions about enabling encryption (without signing, so save space and ram):
    • Is putting an AES key in MyConfig.h really all I have to do? Don't I also have to put that in all the sensor nodes? And is that proces complicated, using a signing sketch and whatnot?
    • Can I have an 'opportunistic' network, where I have some encrypted nodes, and some unencrypted ones? If I could mix them this would make switching to encryption less stressful. I can't easily change two of my nodes.
    • If I change the network, I'd like to move the NRF to channel 100 (juist outside of the normal WiFi frequencies). Do I also have to set that in all nodes, or is setting it in the gateway enough?
    @alowhum encryption is all or nothing. You can't leave one node without encryption if your gateway encrypts the messages it send.
    And you will need to personalize your nodes to get the AES key into them. The documentation on security describes that process.
    @alowhum if you put it in myconfig.h also on the arduino library you can just recompile the nodes and you are good.
    @gohan not anymore. Only for pre 2.2.0 releases.
    It is still working on mine 😅
    @gohan in other words, you use an old release 😉
    I can assure you I am using 2.2 from development as I am also running new driver. So unless you changed something in the last 3 weeks on the development branch it still works, unless the nodes are keeping the key saved.
    @gohan have you verified your communications are actually encrypted?
    @gohan If you see here, you will find that unless you use the simple password option, AES key is fetched from EEPROM: https://github.com/mysensors/MySensors/blob/28c4f3f19e7026f56fd9bbc61d566f770fd7a9d2/hal/transport/MyTransportRF24.cpp#L68
    So either you are using the simple flag, nothing at all, or not using the key you think you use.
    I ll have to check, but I put the key in the gateway myconfig.h
    @gohan Perhaps on a rpi GW where there is no EEPROM, but I am talking about the nodes.
    Well, if I have communication working it means the node should be encrypting data. I'll have to try with clear eeprom and try flashing sketch again
    @gohan not if there is no encryption at all. You could try to use simple password option on a node with various passwords and see if it is detected by your gw at all.
    @anticimex I guess you were right... the gw and node aren't using the AES key. So where am I supposed to add it in the gateway?
    @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
    @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
    @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
  • @macvictor
    I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
    import RPi.GPIO as GPIO
    from lib_nrf24 import NRF24
    import time
    import spidev
    GPIO.setmode(GPIO.BCM)
    pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
    radio = NRF24(GPIO, spidev.SpiDev())
    radio.begin(0,8)
    radio.setPayloadSize(32)
    radio.setChannel(0x76)
    radio.setDataRate(NRF24.BR_1MBPS)
    radio.setPALevel (NRF24.PA_MAX)
    radio.setAutoAck(True)
    radio.enableDynamicPayloads()
    radio.enableAckPayload()
    radio.openReadingPipe(1 ,pipes[1])
    radio.printDetails()
    radio.startListening()
    radio.GPIO.cleanup()
    Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
    @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
  • To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
    @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
  • @macvictor
    Hi
    Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
    @pepson signing is radio agnostic. It has nothing to do with the radio.
    @anticimex @wes Can I please ask how to update? I mean, the right command to type.
    I have the folder "MySensors" on documents of my user in Pi:
    /home/sineverba/MySensors
    Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
    I need also to relaunch the ./config command?
    Thank you to both and all!
  • Code Contributor
    #define MY_NODE_ID X
    Hi to all,
    1 - Disable the daemon with
    sudo rm -r MySensors
    # -*- coding: utf-8 -*-
    LOOKFOR = u"mysgw"
        if proc.name() == "mysgw":
            #print(proc)
            #print(cpu)
            #print(proc.cpu_times())
            if cpu > 50:
            else:
    Cheers,
    Pula
  • @Nick-Willis:
    from
    to
    sudo systemctl daemon-reload
    followed by
    to enable the change.
    Cheers,
    Otto
  • Code Contributor
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL (82)
    Maybe this helps.
    Cheers,
    Otto
  • Code Contributor
    Cheers,
    Otto
    thanks for the (hopeful) fix
  • @marceloaqno :
    and so on....
    Thanks again and cheers,
    Otto
  • Code Contributor
    My uptime is at 4 days now. so far still working with your patch. CPU is at 2% and sensor network still working correctly. will report if that changes.
  • I've been using your restarting method and its been working ok and has done one restart in 5 days.
    However I now see something else where altho cpu use is fine, none of my nodes can communicate to the gateway. My controller can connect to the gateway no problem but there are no messages received. Restarting nodes does not help. Only a manual restart of the gateway gets things going again - at least for a while anyway.
    Where is the log output from the gateway to be found? I know it can be run from the bash prompt to write the output to screen but how about logging the installed service output?
    @nick-willis the log is sent to syslog by default. See https://www.mysensors.org/build/raspberry#troubleshooting for details.
  • @marceloaqno : This is strange. I am using a RPi 1 on this gateway with raspbian Jessie. Beside the GW-service there is only a small python programm which listens on an UPD-Port and plays an mp3 if it receives suitable data (for doorbell). Since March 4, 20:15 there were several restarts due to high cpu usage (after dis-applying your patch):
    2018-03-04 23:01:03 cpu (99.7) very high! --> restarting service
    2018-03-05 07:31:03 cpu (99.7) very high! --> restarting service
    2018-03-05 11:01:03 cpu (98.7) very high! --> restarting service
    2018-03-05 13:31:04 cpu (94.7) very high! --> restarting service
    2018-03-06 11:31:03 cpu (99.7) very high! --> restarting service
    2018-03-06 12:31:03 cpu (98.7) very high! --> restarting service
    2018-03-07 06:01:03 cpu (94.8) very high! --> restarting service
    2018-03-07 22:31:03 cpu (99.8) very high! --> restarting service
    With this "auto-restarts" the sensors are working fine, I did not notice any problems.
    However, I just upgraded to the recent Stretch (what takes a LONG time on RPi 1 and made me struggle a little bit with the new network names). I also rebuilt the GW of course and will report here what will happen....
    @Nick-Willis : did you apply the patch of marceloaqno or not? Did you enable debugging? (see here )
    Cheers,
    Otto
  • Code Contributor
    @otto001 In a new attempt to trigger this problem, I am using a script that will force the fhem controller to reconnect every 30s to the gateway (built with mysensors master branch, unpatched), and sends me a note in case of high CPU usage:
    I'll leave it running for a few days to see what happens.
    Here is the script, if anyone is interested:
    #!/bin/sh
    while true; do
      (echo "set mysgw disconnect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
      sleep 1
      (echo "set mysgw connect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
      sleep 1
      cpu_percent=$(ps -C "mysgw" -o %cpu=)
      cpu_percent=${cpu_percent%%.*}
      if [ "$cpu_percent" -ge 90 ]
      then
        echo "ALERT: HIGH CPU USAGE"
        # pushbullet script from https://gist.github.com/outadoc/189bd3ccbf5d6e0f39e4
        /home/pi/pushbullet.sh "RPi1: HIGH CPU USAGE"
        exit
      fi
      sleep 30
    done
  • @marceloaqno : Thank you!
    Just a notice: I do NOT disconnect, I just connect every 30 minutes. Has been working for me since more than 2 years (ancient ms-gw version on RPi).
    Yesterday I did a dist-upgrade to stretch on the "problematic" gw (as mentioned above) - without your patch but with my monitoring-script running. It is a little bit to early I presume, but no high cpu problems so far. I will report back here in a few days. Maybe this problem is really related to old libraries or something?! If this is running stable for a few days I will apply your patch and see what happens.
    Thanks again!
    Cheers,
    Pula
  • Code Contributor
    @otto001 After a few hours running the reconnect script, I noticed several error messages in my gateway log:
    accept(): Too many open files
    The problem was that the gateway wasn't releasing the socket descriptor after each disconnection of the controller. After reaching the limit (mine was 1036) the controller can't connect.
    I'm not entirely sure that this problem is related to what you're having. You can check how many file descriptors currently opened by the gateway with the command below
    sudo lsof -u root |grep mysgw |wc -l
    The fix:
    https://github.com/marceloaqno/MySensors/commit/a40d4441b7460225100398ff6f2581c2b0df36ea
  • How do I update from master branch to development branch?
    Why do you want to do that? Development version is still work in progress
  • I'm using a raspberry pi gateway in home-assistant.
    Sometimes my gateway doesn't work anymore, and when I restart the service, it is running good
    I used ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
    Read the article again, there is the instruction on how to download the development version, but before you have to uninstall the mysgw service and rename the current mysensors folder to keep as backup.
  • Code Contributor
    @gieljnssns The fixes I mentioned above haven't yet been applied to the development branch. Eventually they will be, but I'm still doing some testing.
  • @marceloaqno :
    Thank you!!! Should this patch be applied together with your first patch?
    Interesting:
    After some days without problems on the newest raspbian packages the gw hung again, but WITHOUT high cpu usage (and WITHOUT your first patch applied). There were just no more reads from the sensors in the log, only the re-connects of fhem. After restarting the service, everything is fine again.
    Unfortunately I did see your post after that 😞
    But I checked the log and could not find the words "too" or "Too" in the log (running service with -d).
    Some minutes after restarting I checked how many open files there were with the command you supplied: 21
    In the meantime I have created a small udp listening service which restarts the service if a certain string is received, so I can restart the service by double-clicking one of my switches without the need of login to the gw (also for the wife)....
    @gieljnssns : I think you are experiencing exactly the same problem we are discussing 🙂
    Thanks again!
    Cheers,
    Otto
    I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
  • Code Contributor
    @otto001 The second patch can be applied without the first one.
  • @gohan :
  • @marceloaqno :
    Cheers,
    Otto
      Mosquitto-log:
    syslog:
    GW configure-line:
  • Code Contributor
  • Code Contributor
    You can download from:
    Here is a step-by-step:
    cd MySensors
  • @gohan
    I will try this...
  • @marceloaqno :
    Fortunately I can restart the gw now using a button and this udp-scripts 🙂
    cheers,
    Otto
  • 347
  • 584
23
