π¬ MySensors NRF5 Platform
So after running through all the sensors in the mockmysensors sketch there are quite a few that have the same problem.
I have done the same tests on my standard setup ATmega328 and all compile ok.
I also tried some of my own small sketches on both platforms and had problems on the nrf5 platform with the same error.
So is this a mySensors problem or is it something deeper?.
Why should it not work on both as far as the syntax is concerned.
Who if anybody do i report the problem too?I took the plunge and ordered a jlink/v2 programmer and a waveshare BLE400 motherboard and core module (I know it is nrf51822 but it is a start) but i hope the above problem can be sorted out.
@rmtucker said in MySensors NRF5 Platform:
Yes, the ones I noticed that seem to have the problem are: motion, smoke, dimmer, cover, scene controller, and, of course, multimeter. The rest compiled.
I don't know the answers to your other good questions, but AFAIK @d00616 appears to be the point man. Perhaps @d00616 can comment?
Also, if you're not already aware of it, @rmtucker I invite you to join in on the constantly evolving discussion at: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/498
After trawling through posts on the forum the following changes compile ok.
Altered int to uint16_t#ifdef ID_S_MULTIMETER void multimeter() { uint16_t impedance=map(randNumber,1,100,0,15000); uint16_t volt=map(randNumber,1,100,0,380); uint16_t amps=map(randNumber,1,100,0,16); Serial.print("Impedance is: " ); Serial.println(impedance); send(msg_S_MULTIMETER_V_IMPEDANCE.set(impedance)); Serial.print("Voltage is: " ); Serial.println(volt); send(msg_S_MULTIMETER_V_VOLTAGE.set(volt)); Serial.print("Current is: " ); Serial.println(amps); send(msg_S_MULTIMETER_V_CURRENT.set(amps)); } #endif```
After adding a Few uint16_t the whole sketch now compiles with all the sensors turned on and only uses 19% of available memory space ,could never have done that on the ATmega platform.
Just wish we could work out why it had to be changed/* * MockMySensors * * This skecth is intended to crate fake sensors which register and respond to the controller * *** * Barduino 2015, GizMoCuz 2015 */ // Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached //#define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #define MY_RADIO_NRF5_ESB #define MY_NODE_ID 254 #include <MySensors.h> #define RADIO_ERROR_LED_PIN 4 // Error led pin #define RADIO_RX_LED_PIN 6 // Receive led pin #define RADIO_TX_LED_PIN 5 // the PCB, on board LED // Wait times #define LONG_WAIT 500 #define SHORT_WAIT 50 #define SKETCH_NAME "MockMySensors " #define SKETCH_VERSION "v0.5" // Define Sensors ids /* S_DOOR, S_MOTION, S_SMOKE, S_LIGHT, S_DIMMER, S_COVER, S_TEMP, S_HUM, S_BARO, S_WIND, S_RAIN, S_UV, S_WEIGHT, S_POWER, S_HEATER, S_DISTANCE, S_LIGHT_LEVEL, S_ARDUINO_NODE, S_ARDUINO_REPEATER_NODE, S_LOCK, S_IR, S_WATER, S_AIR_QUALITY, S_CUSTOM, S_DUST, S_SCENE_CONTROLLER */ ////#define ID_S_ARDUINO_NODE //auto defined in initialization ////#define ID_S_ARDUINO_REPEATER_NODE //auto defined in initialization // Some of these ID's have not been updated for v1.5. Uncommenting too many of them // will make the sketch too large for a pro mini's memory so it's probably best to try // one at a time. #define ID_S_ARMED 0 // dummy to controll armed stated for several sensors #define ID_S_DOOR 1 #define ID_S_MOTION 2 #define ID_S_SMOKE 3 #define ID_S_LIGHT 4 #define ID_S_DIMMER 5 #define ID_S_COVER 6 #define ID_S_TEMP 7 #define ID_S_HUM 8 #define ID_S_BARO 9 #define ID_S_WIND 10 #define ID_S_RAIN 11 #define ID_S_UV 12 #define ID_S_WEIGHT 13 #define ID_S_POWER 14 #define ID_S_HEATER 15 #define ID_S_DISTANCE 16 #define ID_S_LIGHT_LEVEL 17 #define ID_S_LOCK 18 #define ID_S_IR 19 #define ID_S_WATER 20 #define ID_S_AIR_QUALITY 21 #define ID_S_DUST 22 #define ID_S_SCENE_CONTROLLER 23 //// Lib 1.5 sensors #define ID_S_RGB_LIGHT 24 #define ID_S_RGBW_LIGHT 25 #define ID_S_COLOR_SENSOR 26 #define ID_S_HVAC 27 #define ID_S_MULTIMETER 28 #define ID_S_SPRINKLER 29 #define ID_S_WATER_LEAK 30 #define ID_S_SOUND 31 #define ID_S_VIBRATION 32 #define ID_S_MOISTURE 33 // #define ID_S_CUSTOM 99 // Global Vars unsigned long SLEEP_TIME = 900000; // Sleep time between reads (in milliseconds) bool metric = true; long randNumber; //Instanciate Messages objects #ifdef ID_S_ARMED bool isArmed; #endif #ifdef ID_S_DOOR // V_TRIPPED, V_ARMED MyMessage msg_S_DOOR_T(ID_S_DOOR,V_TRIPPED); MyMessage msg_S_DOOR_A(ID_S_DOOR,V_ARMED); #endif #ifdef ID_S_MOTION // V_TRIPPED, V_ARMED MyMessage msg_S_MOTION_A(ID_S_MOTION,V_ARMED); MyMessage msg_S_MOTION_T(ID_S_MOTION,V_TRIPPED); #endif #ifdef ID_S_SMOKE // V_TRIPPED, V_ARMED MyMessage msg_S_SMOKE_T(ID_S_SMOKE,V_TRIPPED); MyMessage msg_S_SMOKE_A(ID_S_SMOKE,V_ARMED); #endif #ifdef ID_S_LIGHT MyMessage msg_S_LIGHT(ID_S_LIGHT,V_LIGHT); bool isLightOn=0; #endif #ifdef ID_S_DIMMER MyMessage msg_S_DIMMER(ID_S_DIMMER,V_DIMMER); uint16_t dimmerVal=100; #endif #ifdef ID_S_COVER MyMessage msg_S_COVER_U(ID_S_COVER,V_UP); MyMessage msg_S_COVER_D(ID_S_COVER,V_DOWN); MyMessage msg_S_COVER_S(ID_S_COVER,V_STOP); MyMessage msg_S_COVER_V(ID_S_COVER,V_VAR1); int coverState=0; //0=Stop; 1=up; -1=down #endif #ifdef ID_S_TEMP MyMessage msg_S_TEMP(ID_S_TEMP,V_TEMP); #endif #ifdef ID_S_HUM MyMessage msg_S_HUM(ID_S_HUM,V_HUM); #endif #ifdef ID_S_BARO MyMessage msg_S_BARO_P(ID_S_BARO,V_PRESSURE); MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST); #endif #ifdef ID_S_WIND MyMessage msg_S_WIND_S(ID_S_WIND,V_WIND); MyMessage msg_S_WIND_G(ID_S_WIND,V_GUST); MyMessage msg_S_WIND_D(ID_S_WIND,V_DIRECTION); #endif #ifdef ID_S_RAIN MyMessage msg_S_RAIN_A(ID_S_RAIN,V_RAIN); MyMessage msg_S_RAIN_R(ID_S_RAIN,V_RAINRATE); #endif #ifdef ID_S_UV MyMessage msg_S_UV(ID_S_UV,V_UV); #endif #ifdef ID_S_WEIGHT MyMessage msg_S_WEIGHT(ID_S_WEIGHT,V_WEIGHT); #endif #ifdef ID_S_POWER MyMessage msg_S_POWER_W(ID_S_POWER,V_WATT); MyMessage msg_S_POWER_K(ID_S_POWER,V_KWH); #endif #ifdef ID_S_HEATER //////// REVIEW IMPLEMENTATION //////////// MyMessage msg_S_HEATER_SET_POINT(ID_S_HEATER, V_HVAC_SETPOINT_HEAT); // HVAC/Heater setpoint (Integer between 0-100). S_HEATER, S_HVAC MyMessage msg_S_HEATER_FLOW_STATE(ID_S_HEATER, V_HVAC_FLOW_STATE); // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver" // S_HVAC, S_HEATER //MyMessage msg_S_HEATER_STATUS(ID_S_HEATER,V_STATUS); //MyMessage msg_S_HEATER_TEMP(ID_S_HEATER,V_TEMP); float heater_setpoint=21.5; String heater_flow_state="Off"; // float heater_temp=23.5; // bool heater_status=false; // V_TEMP // Temperature // V_STATUS // Binary status. 0=off 1=on // V_HVAC_FLOW_STATE // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver" // V_HVAC_SPEED // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto") // V_HVAC_SETPOINT_HEAT // HVAC/Heater setpoint #endif #ifdef ID_S_DISTANCE MyMessage msg_S_DISTANCE(ID_S_DISTANCE,V_DISTANCE); #endif #ifdef ID_S_LIGHT_LEVEL MyMessage msg_S_LIGHT_LEVEL(ID_S_LIGHT_LEVEL,V_LIGHT_LEVEL); #endif #ifdef ID_S_LOCK MyMessage msg_S_LOCK(ID_S_LOCK,V_LOCK_STATUS); bool isLocked = 0; #endif #ifdef ID_S_IR MyMessage msg_S_IR_S(ID_S_IR,V_IR_SEND); MyMessage msg_S_IR_R(ID_S_IR,V_IR_RECEIVE); long irVal = 0; #endif #ifdef ID_S_WATER MyMessage msg_S_WATER_F(ID_S_WATER,V_FLOW); MyMessage msg_S_WATER_V(ID_S_WATER,V_VOLUME); #endif #ifdef ID_S_AIR_QUALITY MyMessage msg_S_AIR_QUALITY(ID_S_AIR_QUALITY,V_LEVEL); #endif #ifdef ID_S_DUST MyMessage msg_S_DUST(ID_S_DUST,V_LEVEL); #endif #ifdef ID_S_SCENE_CONTROLLER MyMessage msg_S_SCENE_CONTROLLER_ON(ID_S_SCENE_CONTROLLER,V_SCENE_ON); MyMessage msg_S_SCENE_CONTROLLER_OF(ID_S_SCENE_CONTROLLER,V_SCENE_OFF); // not sure if scene controller sends int or chars // betting on ints as Touch Display Scen by Hek // compiler warnings char *scenes[] = { (char *)"Good Morning", (char *)"Clean Up!", (char *)"All Lights Off", (char *)"Music On/Off" }; int sceneVal=0; int sceneValPrevious=0; #endif #ifdef ID_S_RGB_LIGHT MyMessage msg_S_RGB_LIGHT_V_RGB(ID_S_RGB_LIGHT,V_RGB); MyMessage msg_S_RGB_LIGHT_V_WATT(ID_S_RGB_LIGHT,V_WATT); String rgbState="000000"; //RGB light V_RGB, V_WATT //RGB value transmitted as ASCII hex string (I.e "ff0000" for red) #endif #ifdef ID_S_RGBW_LIGHT MyMessage msg_S_RGBW_LIGHT_V_RGBW(ID_S_RGBW_LIGHT,V_RGBW); MyMessage msg_S_RGBW_LIGHT_V_WATT(ID_S_RGBW_LIGHT,V_WATT); String rgbwState="00000000"; //RGBW light (with separate white component) V_RGBW, V_WATT //RGBW value transmitted as ASCII hex string (I.e "ff0000ff" for red + full white) S_RGBW_LIGHT #endif #ifdef ID_S_COLOR_SENSOR MyMessage msg_S_COLOR_SENSOR_V_RGB(ID_S_COLOR_SENSOR,V_RGB); //Color sensor V_RGB //RGB value transmitted as ASCII hex string (I.e "ff0000" for red) S_RGB_LIGHT, S_COLOR_SENSOR #endif #ifdef ID_S_HVAC MyMessage msg_S_HVAC_V_HVAC_SETPOINT_HEAT(ID_S_HVAC,V_HVAC_SETPOINT_HEAT); MyMessage msg_S_HVAC_V_HVAC_SETPOINT_COOL(ID_S_HVAC,V_HVAC_SETPOINT_COOL); MyMessage msg_S_HVAC_V_HVAC_FLOW_STATET(ID_S_HVAC,V_HVAC_FLOW_STATE); MyMessage msg_S_HVAC_V_HVAC_FLOW_MODE(ID_S_HVAC,V_HVAC_FLOW_MODE); MyMessage msg_S_HVAC_V_HVAC_SPEED(ID_S_HVAC,V_HVAC_SPEED); float hvac_SetPointHeat = 16.5; float hvac_SetPointCool = 25.5; String hvac_FlowState = "AutoChangeOver"; String hvac_FlowMode = "Auto"; String hvac_Speed = "Normal"; //Thermostat/HVAC device //V_HVAC_SETPOINT_HEAT, // HVAC/Heater setpoint //V_HVAC_SETPOINT_COOL, // HVAC cold setpoint //V_HVAC_FLOW_STATE, // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver" //V_HVAC_FLOW_MODE, // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn") //V_HVAC_SPEED // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto") // NOT IMPLEMENTED YET //V_TEMP // Temperature //V_STATUS // Binary status. 0=off 1=on #endif #ifdef ID_S_MULTIMETER MyMessage msg_S_MULTIMETER_V_IMPEDANCE(ID_S_MULTIMETER,V_IMPEDANCE); MyMessage msg_S_MULTIMETER_V_VOLTAGE(ID_S_MULTIMETER,V_VOLTAGE); MyMessage msg_S_MULTIMETER_V_CURRENT(ID_S_MULTIMETER,V_CURRENT); // Multimeter device V_VOLTAGE, V_CURRENT, V_IMPEDANCE // V_IMPEDANCE 14 Impedance value // V_VOLTAGE 38 Voltage level // V_CURRENT 39 Current level #endif #ifdef ID_S_SPRINKLER // S_SPRINKLER 31 Sprinkler device V_STATUS (turn on/off), V_TRIPPED (if fire detecting device) // V_STATUS 2 Binary status. 0=off 1=on // V_ARMED 15 Armed status of a security sensor. 1=Armed, 0=Bypassed // V_TRIPPED 16 Tripped status of a security sensor. 1=Tripped, 0=Untripped #endif #ifdef ID_S_WATER_LEAK #endif #ifdef ID_S_SOUND #endif #ifdef ID_S_VIBRATION #endif #ifdef ID_S_MOISTURE #endif #ifdef ID_S_MOISTURE MyMessage msg_S_MOISTURE(ID_S_MOISTURE,V_LEVEL); #endif #ifdef ID_S_CUSTOM MyMessage msg_S_CUSTOM_1(ID_S_CUSTOM,V_VAR1); MyMessage msg_S_CUSTOM_2(ID_S_CUSTOM,V_VAR2); MyMessage msg_S_CUSTOM_3(ID_S_CUSTOM,V_VAR3); MyMessage msg_S_CUSTOM_4(ID_S_CUSTOM,V_VAR4); MyMessage msg_S_CUSTOM_5(ID_S_CUSTOM,V_VAR5); #endif void setup() { // Random SEED randomSeed(analogRead(0)); wait(LONG_WAIT); Serial.println("GW Started"); } void presentation() { // Send the Sketch Version Information to the Gateway Serial.print("Send Sketch Info: "); sendSketchInfo(SKETCH_NAME, SKETCH_VERSION); Serial.print(SKETCH_NAME); Serial.println(SKETCH_VERSION); wait(LONG_WAIT); // Get controller configuration Serial.print("Get Config: "); metric = getControllerConfig().isMetric; Serial.println(metric ? "Metric":"Imperial"); wait(LONG_WAIT); // Init Armed #ifdef ID_S_ARMED isArmed = true; #endif // Register all sensors to gw (they will be created as child devices) Serial.println("Presenting Nodes"); Serial.println("________________"); #ifdef ID_S_DOOR Serial.println(" S_DOOR"); present(ID_S_DOOR,S_DOOR,"Outside Door"); wait(SHORT_WAIT); #endif #ifdef ID_S_MOTION Serial.println(" S_MOTION"); present(ID_S_MOTION,S_MOTION,"Outside Motion"); wait(SHORT_WAIT); #endif #ifdef ID_S_SMOKE Serial.println(" S_SMOKE"); present(ID_S_SMOKE,S_SMOKE,"Kitchen Smoke"); wait(SHORT_WAIT); #endif #ifdef ID_S_LIGHT Serial.println(" S_LIGHT"); present(ID_S_LIGHT,S_LIGHT,"Hall Light"); wait(SHORT_WAIT); #endif #ifdef ID_S_DIMMER Serial.println(" S_DIMMER"); present(ID_S_DIMMER,S_DIMMER,"Living room dimmer"); wait(SHORT_WAIT); #endif #ifdef ID_S_COVER Serial.println(" S_COVER"); present(ID_S_COVER,S_COVER,"Window cover"); wait(SHORT_WAIT); #endif #ifdef ID_S_TEMP Serial.println(" S_TEMP"); present(ID_S_TEMP,S_TEMP,"House Temperarue"); wait(SHORT_WAIT); #endif #ifdef ID_S_HUM Serial.println(" S_HUM"); present(ID_S_HUM,S_HUM,"Current Humidity"); wait(SHORT_WAIT); #endif #ifdef ID_S_BARO Serial.println(" S_BARO"); present(ID_S_BARO,S_BARO," Air pressure"); wait(SHORT_WAIT); #endif #ifdef ID_S_WIND Serial.println(" S_WIND"); present(ID_S_WIND,S_WIND,"Wind Station"); wait(SHORT_WAIT); #endif #ifdef ID_S_RAIN Serial.println(" S_RAIN"); present(ID_S_RAIN,S_RAIN,"Rain Station"); wait(SHORT_WAIT); #endif #ifdef ID_S_UV Serial.println(" S_UV"); present(ID_S_UV,S_UV,"Ultra Violet"); wait(SHORT_WAIT); #endif #ifdef ID_S_WEIGHT Serial.println(" S_WEIGHT"); present(ID_S_WEIGHT,S_WEIGHT,"Outdoor Scale"); wait(SHORT_WAIT); #endif #ifdef ID_S_POWER Serial.println(" S_POWER"); present(ID_S_POWER,S_POWER,"Power Metric"); wait(SHORT_WAIT); #endif #ifdef ID_S_HEATER Serial.println(" S_HEATER"); present(ID_S_HEATER,S_HEATER,"Garage Heater"); wait(SHORT_WAIT); #endif #ifdef ID_S_DISTANCE Serial.println(" S_DISTANCE"); present(ID_S_DISTANCE,S_DISTANCE,"Distance Measure"); wait(SHORT_WAIT); #endif #ifdef ID_S_LIGHT_LEVEL Serial.println(" S_LIGHT_LEVEL"); present(ID_S_LIGHT_LEVEL,S_LIGHT_LEVEL,"Outside Light Level"); wait(SHORT_WAIT); #endif #ifdef ID_S_LOCK Serial.println(" S_LOCK"); present(ID_S_LOCK,S_LOCK,"Front Door Lock"); wait(SHORT_WAIT); #endif #ifdef ID_S_IR Serial.println(" S_IR"); present(ID_S_IR,S_IR,"Univeral Command"); wait(SHORT_WAIT); #endif #ifdef ID_S_WATER Serial.println(" S_WATER"); present(ID_S_WATER,S_WATER,"Water Level"); wait(SHORT_WAIT); #endif #ifdef ID_S_AIR_QUALITY Serial.println(" S_AIR_QUALITY"); present(ID_S_AIR_QUALITY,S_AIR_QUALITY,"Air Station"); wait(SHORT_WAIT); #endif #ifdef ID_S_DUST Serial.println(" S_DUST"); present(ID_S_DUST,S_DUST,"Dust Level"); wait(SHORT_WAIT); #endif #ifdef ID_S_SCENE_CONTROLLER Serial.println(" S_SCENE_CONTROLLER"); present(ID_S_SCENE_CONTROLLER,S_SCENE_CONTROLLER,"Scene Controller"); wait(SHORT_WAIT); #endif #ifdef ID_S_RGB_LIGHT Serial.println(" RGB_LIGHT"); present(ID_S_RGB_LIGHT,S_RGB_LIGHT,"Mood Light"); wait(SHORT_WAIT); #endif #ifdef ID_S_RGBW_LIGHT Serial.println(" RGBW_LIGHT"); present(ID_S_RGBW_LIGHT,S_RGBW_LIGHT,"Mood Light 2"); wait(SHORT_WAIT); #endif #ifdef ID_S_COLOR_SENSOR Serial.println(" COLOR_SENSOR"); present(ID_S_COLOR_SENSOR,S_COLOR_SENSOR,"Hall Painting"); wait(SHORT_WAIT); #endif #ifdef ID_S_HVAC Serial.println(" HVAC"); present(ID_S_HVAC,S_HVAC,"HVAC"); wait(SHORT_WAIT); #endif #ifdef ID_S_MULTIMETER Serial.println(" MULTIMETER"); present(ID_S_MULTIMETER,S_MULTIMETER,"Electric Staion"); wait(SHORT_WAIT); #endif #ifdef ID_S_SPRINKLER #endif #ifdef ID_S_WATER_LEAK #endif #ifdef ID_S_SOUND #endif #ifdef ID_S_VIBRATION #endif #ifdef ID_S_MOISTURE #endif #ifdef ID_S_MOISTURE Serial.println(" S_MOISTURE"); present(ID_S_MOISTURE,S_MOISTURE,"Basement Sensor"); wait(SHORT_WAIT); #endif #ifdef ID_S_CUSTOM Serial.println(" S_CUSTOM"); present(ID_S_CUSTOM,S_CUSTOM,"Other Stuff"); wait(SHORT_WAIT); #endif Serial.println("________________"); } void loop() { Serial.println(""); Serial.println(""); Serial.println(""); Serial.println("#########################"); randNumber=random(0,101); Serial.print("RandomNumber:"); Serial.println(randNumber); // Send fake battery level Serial.println("Send Battery Level"); sendBatteryLevel(randNumber); wait(LONG_WAIT); // Request time Serial.println("Request Time"); requestTime(); wait(LONG_WAIT); //Read Sensors #ifdef ID_S_DOOR door(); #endif #ifdef ID_S_MOTION motion(); #endif #ifdef ID_S_SMOKE smoke(); #endif #ifdef ID_S_LIGHT light(); #endif #ifdef ID_S_DIMMER dimmer(); #endif #ifdef ID_S_COVER cover(); #endif #ifdef ID_S_TEMP temp(); #endif #ifdef ID_S_HUM hum(); #endif #ifdef ID_S_BARO baro(); #endif #ifdef ID_S_WIND wind(); #endif #ifdef ID_S_RAIN rain(); #endif #ifdef ID_S_UV uv(); #endif #ifdef ID_S_WEIGHT weight(); #endif #ifdef ID_S_POWER power(); #endif #ifdef ID_S_HEATER heater(); #endif #ifdef ID_S_DISTANCE distance(); #endif #ifdef ID_S_LIGHT_LEVEL light_level(); #endif #ifdef ID_S_LOCK lock(); #endif #ifdef ID_S_IR ir(); #endif #ifdef ID_S_WATER water(); #endif #ifdef ID_S_AIR_QUALITY air(); #endif #ifdef ID_S_DUST dust(); #endif #ifdef ID_S_SCENE_CONTROLLER scene(); #endif #ifdef ID_S_RGB_LIGHT rgbLight(); #endif #ifdef ID_S_RGBW_LIGHT rgbwLight(); #endif #ifdef ID_S_COLOR_SENSOR color(); #endif #ifdef ID_S_HVAC hvac(); #endif #ifdef ID_S_MULTIMETER multimeter(); #endif #ifdef ID_S_SPRINKLER #endif #ifdef ID_S_WATER_LEAK #endif #ifdef ID_S_SOUND #endif #ifdef ID_S_VIBRATION #endif #ifdef ID_S_MOISTURE #endif #ifdef ID_S_MOISTURE moisture(); #endif #ifdef ID_S_CUSTOM custom(); #endif sendBatteryLevel(randNumber); wait(SHORT_WAIT); Serial.println("#########################"); wait(SLEEP_TIME); //sleep a bit } // This is called when a new time value was received void receiveTime(unsigned long controllerTime) { Serial.print("Time value received: "); Serial.println(controllerTime); } //void door(){} #ifdef ID_S_DOOR void door() { Serial.print("Door is: " ); if (randNumber <= 50) { Serial.println("Open"); send(msg_S_DOOR_T.set((int16_t)1)); } else { Serial.println("Closed"); send(msg_S_DOOR_T.set((int16_t)0)); } #ifdef ID_S_ARMED Serial.print("System is: " ); Serial.println((isArmed ? "Armed":"Disarmed")); send(msg_S_DOOR_A.set(isArmed)); #endif } #endif #ifdef ID_S_MOTION void motion() { Serial.print("Motion is: " ); if (randNumber <= 50) { Serial.println("Active"); send(msg_S_MOTION_T.set((uint16_t) 1)); } else { Serial.println("Quiet"); send(msg_S_MOTION_T.set((uint16_t) 0)); } #ifdef ID_S_ARMED Serial.print("System is: " ); Serial.println((isArmed ? "Armed":"Disarmed")); send(msg_S_MOTION_A.set(isArmed)); #endif } #endif #ifdef ID_S_SMOKE void smoke() { Serial.print("Smoke is: " ); if (randNumber <= 50) { Serial.println("Active"); send(msg_S_SMOKE_T.set((uint16_t) 1)); } else { Serial.println("Quiet"); send(msg_S_SMOKE_T.set((uint16_t) 0)); } #ifdef ID_S_ARMED Serial.print("System is: " ); Serial.println((isArmed ? "Armed":"Disarmed")); send(msg_S_SMOKE_A.set(isArmed)); #endif } #endif #ifdef ID_S_LIGHT void light() { Serial.print("Light is: " ); Serial.println((isLightOn ? "On":"Off")); send(msg_S_LIGHT.set(isLightOn)); } #endif #ifdef ID_S_DIMMER void dimmer() { Serial.print("Dimmer is set to: " ); Serial.println(dimmerVal); send(msg_S_DIMMER.set(dimmerVal)); } #endif #ifdef ID_S_COVER void cover() { Serial.print("Cover is : " ); if (coverState == 1) { Serial.println("Opening"); send(msg_S_COVER_U.set((uint16_t) 1)); } else if (coverState == -1) { Serial.println("Closing"); send(msg_S_COVER_D.set((uint16_t) 0)); } else { Serial.println("Idle"); send(msg_S_COVER_S.set((uint16_t) -1)); } send(msg_S_COVER_V.set((uint16_t) coverState)); } #endif #ifdef ID_S_TEMP void temp() { Serial.print("Temperature is: " ); Serial.println(map(randNumber,1,100,0,45)); send(msg_S_TEMP.set(map(randNumber,1,100,0,45))); } #endif #ifdef ID_S_HUM void hum() { Serial.print("Humitidty is: " ); Serial.println(randNumber); send(msg_S_HUM.set(randNumber)); } #endif #ifdef ID_S_BARO void baro() { const char *weather[] = {"stable","sunny","cloudy","unstable","thunderstorm","unknown"}; long pressure = map(randNumber,1,100,870,1086);// hPa? int forecast = map(randNumber,1,100,0,5); Serial.print("Atmosferic Pressure is: " ); Serial.println(pressure); send(msg_S_BARO_P.set(pressure)); Serial.print("Weather forecast: " ); Serial.println(weather[forecast]); send(msg_S_BARO_F.set(weather[forecast])); } #endif #ifdef ID_S_WIND void wind() { Serial.print("Wind Speed is: " ); Serial.println(randNumber); send(msg_S_WIND_S.set(randNumber)); Serial.print("Wind Gust is: " ); Serial.println(randNumber+10); send(msg_S_WIND_G.set(randNumber+10)); Serial.print("Wind Direction is: " ); Serial.println(map(randNumber,1,100,0,360)); send(msg_S_WIND_D.set(map(randNumber,1,100,0,360))); } #endif #ifdef ID_S_RAIN void rain() { Serial.print("Rain ammount is: " ); Serial.println(randNumber); send(msg_S_RAIN_A.set(randNumber)); Serial.print("Rain rate is: " ); Serial.println(randNumber/60); send(msg_S_RAIN_R.set(randNumber/60,1)); } #endif #ifdef ID_S_UV void uv() { Serial.print("Ultra Violet level is: " ); Serial.println(map(randNumber,1,100,0,15)); send(msg_S_UV.set(map(randNumber,1,100,0,15))); } #endif #ifdef ID_S_WEIGHT void weight() { Serial.print("Weight is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_WEIGHT.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_POWER void power() { Serial.print("Watt is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_POWER_W.set(map(randNumber,1,100,0,150))); Serial.print("KWH is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_POWER_K.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_HEATER void heater() { // float heater_setpoint=21.5; // float heater_temp=23.5; // bool heater_status=false; // String heatState="Off"; Serial.print("Heater flow state is: " ); Serial.println(heater_flow_state); send(msg_S_HEATER_FLOW_STATE.set(heater_flow_state.c_str())); // Serial.print("Heater on/off is: " ); // Serial.println((heater_status==true)?"On":"Off"); // send(msg_S_HEATER_STATUS.set(heater_status)); // Serial.print("Heater Temperature is: " ); // Serial.println(heater_temp,1); // send(msg_S_HEATER_TEMP.set(heater_temp,1)); Serial.print("Heater Setpoint: " ); Serial.println(heater_setpoint,1); send(msg_S_HEATER_SET_POINT.set(heater_setpoint,1)); } #endif #ifdef ID_S_DISTANCE void distance() { Serial.print("Distance is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_DISTANCE.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_LIGHT_LEVEL void light_level() { Serial.print("Light is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_LIGHT_LEVEL.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_LOCK void lock() { Serial.print("Lock is: " ); Serial.println((isLocked ? "Locked":"Unlocked")); send(msg_S_LOCK.set(isLocked)); } #endif #ifdef ID_S_IR void ir() { Serial.print("Infrared is: " ); Serial.println(irVal); send(msg_S_IR_S.set(irVal)); send(msg_S_IR_R.set(irVal)); } #endif #ifdef ID_S_WATER void water() { Serial.print("Water flow is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_WATER_F.set(map(randNumber,1,100,0,150))); Serial.print("Water volume is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_WATER_V.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_AIR_QUALITY void air() { Serial.print("Air Quality is: " ); Serial.println(randNumber); send(msg_S_AIR_QUALITY.set(randNumber)); } #endif #ifdef ID_S_DUST void dust() { Serial.print("Dust level is: " ); Serial.println(randNumber); send(msg_S_DUST.set(randNumber)); } #endif #ifdef ID_S_SCENE_CONTROLLER void scene() { Serial.print("Scene is: " ); Serial.println(scenes[sceneVal]); if(sceneValPrevious != sceneVal) { send(msg_S_SCENE_CONTROLLER_OF.set((uint16_t) sceneValPrevious)); send(msg_S_SCENE_CONTROLLER_ON.set((uint16_t) sceneVal)); sceneValPrevious=sceneVal; } } #endif #ifdef ID_S_RGB_LIGHT void rgbLight() { Serial.print("RGB Light state is: " ); Serial.println(rgbState); send(msg_S_RGB_LIGHT_V_RGB.set(rgbState.c_str())); Serial.print("RGB Light Watt is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_RGB_LIGHT_V_WATT.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_RGBW_LIGHT void rgbwLight() { Serial.print("RGBW Light state is: " ); Serial.println(rgbwState); send(msg_S_RGBW_LIGHT_V_RGBW.set(rgbwState.c_str())); Serial.print("RGBW Light Watt is: " ); Serial.println(map(randNumber,1,100,0,150)); send(msg_S_RGBW_LIGHT_V_WATT.set(map(randNumber,1,100,0,150))); } #endif #ifdef ID_S_COLOR_SENSOR void color() { String colorState; String red = String(random(0,256),HEX); String green = String(random(0,256),HEX); String blue = String(random(0,256),HEX); colorState=String(red + green + blue); Serial.print("Color state is: " ); Serial.println(colorState); send(msg_S_COLOR_SENSOR_V_RGB.set(colorState.c_str())); } #endif #ifdef ID_S_HVAC void hvac() { // float hvac_SetPointHeat = 16.5; // float hvac_SetPointCool = 25.5; // String hvac_FlowState = "AutoChangeOver"; // String hvac_FlowMode = "Auto"; // String hvac_Speed = "Normal"; Serial.print("HVAC Set Point Heat is: " ); Serial.println(hvac_SetPointHeat); send(msg_S_HVAC_V_HVAC_SETPOINT_HEAT.set(hvac_SetPointHeat,1)); Serial.print("HVAC Set Point Cool is: " ); Serial.println(hvac_SetPointCool); send(msg_S_HVAC_V_HVAC_SETPOINT_COOL.set(hvac_SetPointCool,1)); Serial.print("HVAC Flow State is: " ); Serial.println(hvac_FlowState); send(msg_S_HVAC_V_HVAC_FLOW_STATET.set(hvac_FlowState.c_str())); Serial.print("HVAC Flow Mode is: " ); Serial.println(hvac_FlowMode); send(msg_S_HVAC_V_HVAC_FLOW_MODE.set(hvac_FlowMode.c_str())); Serial.print("HVAC Speed is: " ); Serial.println(hvac_Speed); send(msg_S_HVAC_V_HVAC_SPEED.set(hvac_Speed.c_str())); } #endif #ifdef ID_S_MULTIMETER void multimeter() { uint16_t impedance=map(randNumber,1,100,0,15000); uint16_t volt=map(randNumber,1,100,0,380); uint16_t amps=map(randNumber,1,100,0,16); Serial.print("Impedance is: " ); Serial.println(impedance); send(msg_S_MULTIMETER_V_IMPEDANCE.set(impedance)); Serial.print("Voltage is: " ); Serial.println(volt); send(msg_S_MULTIMETER_V_VOLTAGE.set(volt)); Serial.print("Current is: " ); Serial.println(amps); send(msg_S_MULTIMETER_V_CURRENT.set(amps)); } #endif #ifdef ID_S_SPRINKLER #endif #ifdef ID_S_WATER_LEAK #endif #ifdef ID_S_SOUND #endif #ifdef ID_S_VIBRATION #endif #ifdef ID_S_MOISTURE #endif #ifdef ID_S_MOISTURE void moisture() { Serial.print("Moisture level is: " ); Serial.println(randNumber); send(msg_S_MOISTURE.set(randNumber)); } #endif #ifdef ID_S_CUSTOM void custom() { Serial.print("Custom value is: " ); Serial.println(randNumber); send(msg_S_CUSTOM_1.set(randNumber)); send(msg_S_CUSTOM_2.set(randNumber)); send(msg_S_CUSTOM_3.set(randNumber)); send(msg_S_CUSTOM_4.set(randNumber)); send(msg_S_CUSTOM_5.set(randNumber)); } #endif void receive(const MyMessage &message) { switch (message.type) { #ifdef ID_S_ARMED case V_ARMED: isArmed = message.getBool(); Serial.print("Incoming change for ID_S_ARMED:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println((isArmed ? "Armed":"Disarmed" )); #ifdef ID_S_DOOR door();//temp ack for door #endif #ifdef ID_S_MOTION motion();//temp ack #endif #ifdef ID_S_SMOKE smoke();//temp ack #endif break; #endif case V_STATUS: // V_LIGHT: #ifdef ID_S_LIGHT if(message.sensor==ID_S_LIGHT) { isLightOn = message.getBool(); Serial.print("Incoming change for ID_S_LIGHT:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println((isLightOn ? "On":"Off")); light(); // temp ack } #endif // #ifdef ID_S_HEATER // if(message.sensor == ID_S_HEATER){ // heater_status = message.getBool(); // Serial.print("Incoming change for ID_S_HEATER:"); // Serial.print(message.sensor); // Serial.print(", New status: "); // Serial.println(heater_status); // heater();//temp ack // } // #endif break; #ifdef ID_S_DIMMER case V_DIMMER: if ((message.getInt()<0)||(message.getInt()>100)) { Serial.println( "V_DIMMER data invalid (should be 0..100)" ); break; } dimmerVal= message.getInt(); Serial.print("Incoming change for ID_S_DIMMER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getInt()); dimmer();// temp ack break; #endif #ifdef ID_S_COVER case V_UP: coverState=1; Serial.print("Incoming change for ID_S_COVER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println("V_UP"); cover(); // temp ack break; case V_DOWN: coverState=-1; Serial.print("Incoming change for ID_S_COVER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println("V_DOWN"); cover(); //temp ack break; case V_STOP: coverState=0; Serial.print("Incoming change for ID_S_COVER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println("V_STOP"); cover(); //temp ack break; #endif case V_HVAC_SETPOINT_HEAT: #ifdef ID_S_HEATER if(message.sensor == ID_S_HEATER) { heater_setpoint=message.getFloat(); Serial.print("Incoming set point for ID_S_HEATER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(heater_setpoint,1); heater();//temp ack } #endif #ifdef ID_S_HVAC if(message.sensor == ID_S_HVAC) { hvac_SetPointHeat=message.getFloat(); Serial.print("Incoming set point for ID_S_HVAC:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(hvac_SetPointHeat,1); hvac();//temp ack } #endif break; case V_HVAC_FLOW_STATE: #ifdef ID_S_HEATER if(message.sensor == ID_S_HEATER) { heater_flow_state=message.getString(); Serial.print("Incoming flow state change for ID_S_HEATER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(heater_flow_state); heater();//temp ack } #endif #ifdef ID_S_HVAC if(message.sensor == ID_S_HVAC) { hvac_FlowState=message.getString(); Serial.print("Incoming set point for ID_S_HVAC:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(hvac_FlowState); hvac();//temp ack } #endif break; #ifdef ID_S_LOCK case V_LOCK_STATUS: isLocked = message.getBool(); Serial.print("Incoming change for ID_S_LOCK:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getBool()?"Locked":"Unlocked"); lock(); //temp ack break; #endif #ifdef ID_S_IR case V_IR_SEND: irVal = message.getLong(); Serial.print("Incoming change for ID_S_IR:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(irVal); ir(); // temp ack break; case V_IR_RECEIVE: irVal = message.getLong(); Serial.print("Incoming change for ID_S_IR:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(irVal); ir(); // temp ack break; #endif #ifdef ID_S_SCENE_CONTROLLER case V_SCENE_ON: sceneVal = message.getInt(); Serial.print("Incoming change for ID_S_SCENE_CONTROLLER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.print(scenes[sceneVal]); Serial.println(" On"); scene();// temp ack break; case V_SCENE_OFF: sceneVal = message.getInt(); Serial.print("Incoming change for ID_S_SCENE_CONTROLLER:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.print(scenes[sceneVal]); Serial.println(" Off"); scene();// temp ack break; #endif #ifdef ID_S_RGB_LIGHT case V_RGB: rgbState=message.getString(); Serial.print("Incoming flow state change for ID_S_RGB_LIGHT:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(rgbState); rgbLight(); // temp ack break; #endif #ifdef ID_S_RGBW_LIGHT case V_RGBW: rgbwState=message.getString(); Serial.print("Incoming flow state change for ID_S_RGBW_LIGHT:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(rgbwState); rgbwLight(); break; #endif #ifdef ID_S_HVAC // hvac_SetPointHeat // hvac_SetPointCool // hvac_FlowState // hvac_FlowMode // hvac_Speed case V_HVAC_SETPOINT_COOL: hvac_SetPointCool=message.getFloat(); Serial.print("Incoming set point for ID_S_HVAC:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(hvac_SetPointCool,1); hvac();//temp ack break; case V_HVAC_FLOW_MODE: hvac_Speed=message.getString(); Serial.print("Incoming set point for ID_S_HVAC:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(hvac_Speed); hvac();//temp ack break; case V_HVAC_SPEED: hvac_FlowMode=message.getString(); Serial.print("Incoming set point for ID_S_HVAC:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(hvac_FlowMode); hvac();//temp ack break; #endif default: Serial.print("Unknown/UnImplemented message type: "); Serial.println(message.type); } }```
Altered int to uint16_tThis issue seems to be an 32 bit platform issue. With SAMD I see equal error messages. This needs fixing at message level.
@d00616
So is this a mysensors issue and will you rase this issue please.
I have ask the other members of the core team if someone can take a look at this issue. I have time to do this not earlier than Sunday.
Just wondering about mysensors debug.
If you have the jlink plugged in for programming but you also want to see the mysensors debug.
Where is the ftdi adapter plugged in to for tx and rx ?
And also i suspect that the vcc is not connected on the ftdi adapter because the jlink is supplying the board?
Oh so many questions??
That's determined by the "board" that you tell the compiler you are using. For example, on the nRF52 DK, the Rx pin is on P0.06. Presently, for simplicity, when I compile for the Ebyte module, I tell the Arduino IDE that it's an nRF52 DK, so then Rx is also on P0.06 and Tx is on P0.08.
A more advanced way of doing it is to tell the Arduino IDE that the board is a "MyNrf5Board nRF52832", and then you can use d00616's method of pin mapping to make the Rx pin whichever of the mappable pins you want. That's a bit more involved though.And also i suspect that the vcc is not connected on the ftdi adapter because the jlink is supplying the board?
Right. For old fashioned debugging using serial.println(), just Rx and GND is all I use.
Disappointed so far with the NRF51822.
Basically it can not connect to any i2c sensors which mysensors relies on heavily.
So not a lot can be done with it.
It does integrate with mysensors well though,proved that with mockmysensors sketch.
I dare not even try the spi interface.
I would advise not trying this till the i2c problems are sorted out.
At the moment it is running Blinky and thats it.
@rmtucker can't you just bit bang the I2C sensors? Should not be any mcu incapable of that. There should be plenty drivers available that implement a bit banged I2C driver.
@Anticimex
I managed to get a nokia 5110 display connected and working using the u8glib and softspi.
I can not get the easier to use adafruit library to compile though.
Nor have i been able to find a Soft i2c library that will compile without errors.
So i am afraid i2c is still a non starter.
maybe try this one https://github.com/felias-fogg/SlowSoftWire
I don't use it, but it compiles fine for nrf52. I already tested it a while ago, and it worked for me.
@scalz
my head is battered with this.
tried the library you mentioned and it compiled fine but still gave spurious readings.
so i plugged the htu21d back in to a nano and used the sparkfun library demo.
the readings were perfect.
so frustrated with this because all my nodes use i2c sensors.
@rmtucker
Stupid question, but are your i2c sensors getting all the voltage that they need? After all, a nano runs at 5v, right? I know that some of the TH i2c sensors include voltage regulators, which would drop the voltage even further. If necessary, those could be removed. That's what I generally do.
Yes They are 3.3v sensors.
What we need is someone else using nrf51822 and i2c sensors that can shine some light.
What we need is someone else using nrf51822 and i2c sensors that can shine some light.I'll try soon, hopefully I'll have time tomorrow, my nrf51 module is soldered on a breadboard. I need to make the promised tests on the nrf52 too ...
@Nca78
Just an observation after many hours of tinkering.
There is no problem reading one byte back from i2c,like when doing an i2c scan.
It comes back with the address of the htu21d no problem.
But if you try to read 3 bytes which is what you do when reading the temp etc,it goes T*TS up.
Well guys after all that
I had not installed the development version from git.
After installling the development version the i2c is working fine.
Suprised no one else has done this??From git (for core development) Follow steps from Board Manager section above cd <SKETCHBOOK>, where <SKETCHBOOK> is your Arduino Sketch folder: OS X: ~/Documents/Arduino Linux: ~/Arduino Windows: ~/Documents/Arduino Create a folder named hardware, if it does not exist, and change directories to it Clone this repo: git clone https://github.com/sandeepmistry/arduino-nRF5.git sandeepmistry/nRF5 Restart the Arduino IDE```
Please can someone update the instructions below to mention installing the development version
Preparing Arduino Arduino doesn't support the nRF5 platform in a standard setup. You have to add the arduino-nRF5 platform via Arduino's Board Manager like described in https://github.com/sandeepmistry/arduino-nRF5/#installing
@d00616 maybe ?
If there are multiple libraries with the same name (as there seem to be), then how does the compiler know which one to pick? Is it just the first one whose name matches in whatever pathway it follows? Since it obviously compiled even though rmtucker was missing the proper libraries... this just sounds like a heartache waiting to happen unless everything is setup just-so. rmtucker's case seems to prove there won't be any warnings if it picks the wrong one.
looking at d00616 howto it's explained to use Mysensors development branch (or maybe he added it today ). but that makes sense as this port is newer than master branch.
it uses the core libraries depending on the board used in Arduino.
@scalz: I think @rmtucker was discussing using the development version of the sandeepmistry nrf5 Arduino library, it was not related to the MySensors library.
@mfalkvidd
Sorry i should have made it more understandable.
When you follow the instructions below as per sandeeps site it does not install the latest NR5 libraries that you see on github.Installing Board Manager Download and install the Arduino IDE (At least v1.6.12) Start the Arduino IDE Go into Preferences Add https://sandeepmistry.github.io/arduino-nRF5/package_nRF5_boards_index.json as an "Additional Board Manager URL" Open the Boards Manager from the Tools -> Board menu and install "Nordic Semiconductor nRF5 Boards" Select your nRF5 board from the Tools -> Board menu
Following this you must install the development version aswell which is what you see on github by doing this.
Otherwise you run into all kinds of problems using the old library.
I have added a note at the end of the installation documentation. To make things easier, I have opened an issue to update the Arduino-nRF5 release.
I2C should be fixed now. Version 0.4.0 is released!
@d00616
So should i be able to delete the hardware folder that the development version created from github and just update from boards manager?.
If this don't work, remove all folder created by hardware and boards manager, close Arduino IDE and reinstall it via Boards Manager.
Hi, I don't us nrf52 yet but as i'm a platformio supporter, There is a new release for nrf52 platform with initial arduino framework support ! Good news, i think I will test nrf52 in few weeks.
https://github.com/platformio/platform-nordicnrf52/releases/tag/v1.2.0
@d00616 said in MySensors NRF5 Platform:
To help clarify for others who are reading this: the Arduino IDE board manager let me upgrade to 0.4.0 from 0.3.0 by just clicking on the board entry "Nordic Semiconductor NRF5 Boards by Sandeep Mistry", selecting the 0.4.0 version, and then clicking Install.
- I have updated the radio driver with fixes for some hardware errata.
- I have updated the https://github.com/mysensors/ArduinoHwNRF5 with an enhanced definition format. File name and contents are changed! The board description is compatible with the NRF5 variant provided by Arduino, but it's not possible to use this variant at the moment.
Where do we find the update? i.e. is it baked into the regular MySensors development code thread, or is it elsewhere?
I'm guessing it's this one? https://github.com/mysensors/ArduinoHwNRF5
I refreshed all the libraries. I'm able to compile and upload my sketches, but now it complains a lot about "invalid libraries."
WARNING: Spurious .ci folder in 'MySensors' library WARNING: Spurious .mystools folder in 'MySensors' library Sketch uses 3836 bytes (0%) of program storage space. Maximum is 524288 bytes. Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-10-10:13) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html debug_level: 0 0 adapter speed: 10000 kHz cortex_m reset_config sysresetreq nrf52.cpu: target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x000006e8 msp: 0x20010000 ** Programming Started ** auto erase enabled wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_255419/Interrupt_button_test_v005.ino.hex in 0.800001s (5.000 KiB/s) ** Programming Finished ** ** Verify Started ** verified 3964 bytes in 0.060000s (64.518 KiB/s) ** Verified OK ** ** Resetting Target ** shutdown command invoked Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5 Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5 Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5 Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5
@NeverDie said in MySensors NRF5 Platform:
At the moment, I cannot reproduce this with Linux and Arduino 1.8.2. I try to find out what's wrong.
Can you try to remove the .ci and .mystools folders?
Done. So, here it is now:
Archiving built core (caching) in: C:\Users\David\AppData\Local\Temp\arduino_cache_16539\core\core_MySensors_nRF5_MyBoard_nRF52832_bootcode_none,lfclk_lfxo,reset_notenable_2d457965a40837233e636c052c58b359.a Sketch uses 3872 bytes (0%) of program storage space. Maximum is 524288 bytes. Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-10-10:13) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html debug_level: 0 0 adapter speed: 10000 kHz cortex_m reset_config sysresetreq nrf52.cpu: target state: halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x0000070c msp: 0x20010000 ** Programming Started ** auto erase enabled wrote 4096 bytes from file C:\Users\David\AppData\Local\Temp\arduino_build_610023/Interrupt_button_test_v006.ino.hex in 0.800001s (5.000 KiB/s) ** Programming Finished ** ** Verify Started ** verified 4000 bytes in 0.060000s (65.104 KiB/s) ** Verified OK ** ** Resetting Target ** shutdown command invoked Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5 Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5 Invalid library found in C:\Users\David\Documents\Arduino\libraries\arduino-nRF5: C:\Users\David\Documents\Arduino\libraries\arduino-nRF5 Invalid library found in C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5: C:\Users\David\Documents\Arduino\libraries\ArduinoHwNRF5
BTW, I'm using the Windows version of Arduino IDE 1.8.5, which is the most current.
I don't know the correct path on an Windows system. On my system the Sketches are in the ~/Arduino folder in my home directory (~). The arduino-nrf5 is in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.4.0 and the ArduinoHwNRF5 files are in ~/.arduino15/packages/MySensors/hardware/nRF5/0.2.1
on my Windows machine, all boards are located in c:\Users<username>\AppData\Local\Arduino15\packages
Strange that they've been installed to C:\Users\David\Documents\Arduino\libraries\ on your machine.Maybe just delete the folders and re-install using the board manager?
@mfalkvidd All I know is that if I put a library in the folder: C:\Users\David\Documents\Arduino\libraries
it always gets detected and used. It also means you can completely uninstall/re-install the arduino IDE, and nothing gets lost. I'm not sure about other locations.Am I the only one doing it this way?
@NeverDie for libraries, doing what you do should result in the same behavior as when using the Library Manager.
But I'm not sure it works with boards (especially given that the Arduino IDE complains when you put boards in the libraries folder).
I use the board manager to manage the boards. I believe it connects directly into github.
Anyhow, I stripped out all the non-library stuff, and now Windows IDE works without complaining.
Has anyone here yet figured out how to have more than one type of interrupt at a time wake-up the MCU from sleep? Based on the examples so far, it seems as though only one type at a time can be active. I'm sure there must be some way to do it. For instance, it would be desirable if the MCU could wake up not just from a timer event every, say, 5 minutes, to take a temperature reading, but also immediately if there is a leak detected. Right now it's just one or the other.
So we can not use the normal statement
int8_t sleep(int interrupt, int mode, unsigned long ms=0);
I did not realize that was the case as i have never tried it.
I believe hwSleep(..) is the preferred incantation, but beyond that I'm not sure of anything. Maybe @d00616 can comment?
I should be receiving a number of different PCB projects tomorrow for final assembly and test, and if I can't resolve this soon, I'm simply going to release them without full demo code.
In MySensors, the regular way to use sleep mode is by using the sleep() functions:
https://www.mysensors.org/download/sensor_api_20#sleepingBut like you said, you can also use the raw hwSleep() from the hw abstraction layer. Or you could also rewrite it!
Which means at each abstraction layer, there are additional logics. sleep() functions have more logics (regarding MySensors states and features) than the raw hwSleep for example (like testing if there is an ongoing ota, smartsleep, heartbeat etc..). I have nodes where i use raw or not, but it's good to know what's behind.
@scalz
So the statement
Can be used for timer and pin interrupt at he same time on the NRF5 platform just like the arduino?
I'll try it, but I have strong doubts that it's going to work.
FWIW, here's the pin mapping currently being supplied by digitalPinToInterrupt(..) for the nRF5:
Digital pin 0 = interrupt pin 0
Digital pin 1 = interrupt pin 1
Digital pin 2 = interrupt pin 2
Digital pin 3 = interrupt pin 3
Digital pin 4 = interrupt pin 4
Digital pin 5 = interrupt pin 5
Digital pin 6 = interrupt pin 6
Digital pin 7 = interrupt pin 7
Digital pin 8 = interrupt pin 8
Digital pin 9 = interrupt pin 9
Digital pin 10 = interrupt pin 10
Digital pin 11 = interrupt pin 11
Digital pin 12 = interrupt pin 12
Digital pin 13 = interrupt pin 13
Digital pin 14 = interrupt pin 14
Digital pin 15 = interrupt pin 15
Digital pin 16 = interrupt pin 16
Digital pin 17 = interrupt pin 17
Digital pin 18 = interrupt pin 18
Digital pin 19 = interrupt pin 19
Digital pin 20 = interrupt pin 20
Digital pin 21 = interrupt pin 21
Digital pin 22 = interrupt pin 22
Digital pin 23 = interrupt pin 23
Digital pin 24 = interrupt pin 24
Digital pin 25 = interrupt pin 25
Digital pin 26 = interrupt pin 26
Digital pin 27 = interrupt pin 27
Digital pin 28 = interrupt pin 28
Digital pin 29 = interrupt pin 29
Digital pin 30 = interrupt pin 30
The last I heard, from @d00616 , we had to supply code such as:
// Enable interrupt NVIC_SetPriority(RTC0_IRQn, 15); NVIC_ClearPendingIRQ(RTC0_IRQn); NVIC_EnableIRQ(RTC0_IRQn);
and
// This must be in one line extern "C" { void RTC0_IRQHandler(void) {rtcInterruptCounter++; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_OVRFLW); NRF_RTC0->EVENTS_OVRFLW=0; }}
to get interrupts to work. Even with that approach, though, I haven't gotten it to support any interrupts in addition to a timed sleeping, though I have gotten it to support one interrupt that's separate from a timed sleeping (basically, sleeps indefinitely until the interrupt happens).
OK, I just now tried:
sleep(3,CHANGE,3000);
and, as I suspected, it does nothing but sleep for 3 seconds. It's not responsive to any changes on pin P03 on an nRF52.
@scalz Are you getting a different result? It seems like there's a strong disconnect somewhere between what you're recommending and what I am experiencing.
I didn't give any recommandation, you misread. I just said the regular way to use sleep feature in mysensors, for users, is with sleep(..). But I agree, I misread you too! when you were asking for the specific nrf52 case I guess
That said, I got this working when I made my recessed node for door (accelerometer and hall effect sensor with sleeping). Maybe things have changed in the lib?? or not. I'm struggling between different version of the lib, and some are different from the dev branch.. I'll recheck this asap (not sure for this evening).
I tried toying around with it a bit, and I got a useful result:
#define MY_CORE_ONLY #include <nrf.h> #include <MySensors.h> const byte ledPin = LED_BUILTIN; const byte interruptPin = 3; volatile byte state = LOW; void blinkityBlink(uint8_t pulses, uint8_t repetitions) { for (int x=0;x<repetitions;x++) { for (int i=0;i<pulses;i++) { digitalWrite(LED_BUILTIN,HIGH); wait(20); digitalWrite(LED_BUILTIN,LOW); wait(100); } wait(500); } } void setup() { hwPinMode(LED_BUILTIN,OUTPUT_D0H1); hwPinMode(interruptPin, INPUT); attachInterrupt(digitalPinToInterrupt(interruptPin), blink, RISING); blinkityBlink(2,1); //signify power-on and start of main loop } volatile bool buttonPressed=false; void loop() { state = !state; digitalWrite(ledPin, state); sleep(digitalPinToInterrupt(interruptPin), RISING, 3000); wait(20); //wait 20 milliseconds for button to debounce if it was pressed if (digitalRead(interruptPin)) { //if button is pressed blinkityBlink(2,1); } if (buttonPressed) { buttonPressed=false; blinkityBlink(20,1); } } void blink() { buttonPressed=true; }
So, with this approach, pushing the button on pin 3 does wake up the nRF52 from sleep, whereupon the button press can still be detected and serviced, but it also demonstrates that the ISR per se isn't working.
Anyhow, with this I'm able to get the PIR or leak sensor or magnet sensor or light sensor doing useful things in a timely manner, even if it isn't ideal. That puts me further ahead than I was before.
This is a test program that wakes up from either that i was using some time ago./** The MySensors Arduino library handles the wireless radio link and protocol between your home built sensors/actuators and HA controller of choice. The sensors forms a self healing radio network with optional repeaters. Each repeater and gateway builds a routing tables in EEPROM which keeps track of the network topology allowing messages to be routed to nodes. Created by Henrik Ekblad <henrik.ekblad@mysensors.org> Copyright (C) 2013-2015 Sensnology AB Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors Documentation: http://www.mysensors.org Support Forum: http://forum.mysensors.org This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License version 2 as published by the Free Software Foundation. ******************************* REVISION HISTORY Version 1.0 - Henrik EKblad DESCRIPTION This sketch provides an example how to implement a distance sensor using HC-SR04 Use this sensor to measure KWH and Watt of your house meeter You need to set the correct pulsefactor of your meeter (blinks per KWH). The sensor starts by fetching current KWH value from gateway. Reports both KWH and Watt back to gateway. Unfortunately millis() won't increment when the Arduino is in sleepmode. So we cannot make this sensor sleep if we also want to calculate/report watt-number. http://www.mysensors.org/build/pulse_power */ // Enable debug prints #define MY_DEBUG // Enable and select radio type attached //#define MY_RADIO_NRF24 #define MY_RADIO_NRF5_ESB //#define MY_RADIO_RFM69 //#define MY_RADIO_RFM95 #include <MySensors.h> #include <Wire.h> // must be included here so that Arduino library object file references work #include <RtcDS3231.h> RtcDS3231<TwoWire> Rtc(Wire); #define DIGITAL_INPUT_SENSOR 2 // The digital input you attached your light sensor. (Only 2 and 3 generates interrupt!) #define PULSE_FACTOR 1000 // Nummber of blinks per KWH of your meeter //#define SLEEP_MODE false // Watt-value can only be reported when sleep mode is false. #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers. #define CHILD_ID 1 // Id of the sensor child unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway. double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour //bool pcReceived = false; volatile unsigned long pulseCount = 0; volatile unsigned long lastBlink = 0; volatile unsigned long watt = 0; volatile unsigned long kwh = 0; unsigned long oldWatt = 0; double oldKwh; unsigned long lastSend; MyMessage wattMsg(CHILD_ID, V_WATT); MyMessage kwhMsg(CHILD_ID, V_KWH); void setup() { Serial.begin(115200); Rtc.Begin(); Rtc.Enable32kHzPin(false); Rtc.SetSquareWavePinClockFrequency(DS3231SquareWaveClock_1Hz); Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeClock); // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output // If no pullup is used, the reported usage will be too high because of the floating pin hwPinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP); attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING); //pcReceived = true; lastSend = millis(); } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Energy Meter", "1.0"); // Register this device as power sensor present(CHILD_ID, S_POWER); } void loop() { unsigned long now = millis(); // Only send values at a maximum frequency or woken up from sleep bool sendTime = now - lastSend > SEND_FREQUENCY; if (sendTime) { // New watt value has been calculated if (watt != oldWatt) { // Check that we dont get unresonable large watt value. // could hapen when long wraps or false interrupt triggered if (watt < ((unsigned long)MAX_WATT)) { send(wattMsg.set(watt)); // Send watt value to gw } Serial.print("Watt:"); Serial.println(watt); oldWatt = watt; } // Pulse count has changed //kwh = pulseCount; //double kwh = ((double)pulseCount / ((double)PULSE_FACTOR)); send(kwhMsg.set(pulseCount)); // Send kwh value to gw Serial.print("Wh = "); Serial.println(pulseCount); pulseCount = 0; lastSend = now; } sleep(SEND_FREQUENCY); } void receive(const MyMessage &message) { } void onPulse() { unsigned long newBlink = micros(); unsigned long interval = newBlink - lastBlink; if (interval < 50000L) { // Sometimes we get interrupt on RISING return; } watt = (3600000000.0 / interval) / ppwh; lastBlink = newBlink; pulseCount++; }
Well, that's interesting. In the sketch I posted, I invoked sleep with:
which caused the mcu to wake up immediately after I press the button, but it didn't process the ISR.
Using an invocation like yours in the sketch you just posted above:
sleep(3000);
the ISR executes and then terminates when I press the button, but the MCU doesn't wake and continue with the loop as it did with the prior incantation. Instead, it has to wait for the timer cycle to finish.
What I want is for it to wake up, do the ISR, and continue with the loop where it left off until it is explicitly put back to sleep again. How do I do that?
@NeverDie I have checked the sleep routine in all three variants. It's working with my setup.
There is no API stopping the sleep() by another ISR. Sleep only ends at one of the given conditions.
When you use the MY_CORE_ONLY define, please add "hwInit();" into the setup() routine.
Would you please post the three demo code examples that you tested?
OK, I just now did that, but I'm not getting any difference in the results.
In any case, I'm sure the question will ultimately turn from "How do I wake up based on a pin change?" to "How do I wake up based on the LPCOMP output, which has that pin as its input?" The reason: as covered earlier in this thread, much lower current consumption while sleeping if doing it via LPCOMP rather than the more straightforward pin monitoring.
It's a good question about, how to design the API to do this. I have no good idea.
Until an API, you can set MY_HW_RTC->CC[0] to (MY_HW_RTC->COUNTER+2). This ends sleep with some latency.
Is it just me, or does the myBoardNrf5 cause I2c to fail during initialization? I have code which worked fine on mNrf5Board but which now hangs during initialization when using myBoardNrf5. Is it working for anyone else?
I've re-installed everything and am still getting no joy using I2C currently. The non-I2C stuff seems to be working fine though.
So, before I spin more cycles trying to figure it out, is i2c working for anyone else right now using the latest builds and myBoardNrf5? Or, is I2C currently broken?
It appears that the place where it hangs is this line here in Wire_nRF52.cpp:
while(!_p_twim->EVENTS_LASTTX && !_p_twim->EVENTS_ERROR);
This is too bad, as I2C seemed to work fine prior to around a couple weeks ago. I think maybe (?) the latest update somehow broke it.
Please advise.
Well, since I'm dead in the water as things stand, I moved the code over to run on an nRF52 DK. Then, usingy Sandeep's code and none of the mysensors code, I was able to get the nRF52 DK to read an attached Si7021 temperature-humidity sensor. i.e. that worked without hanging.
So, it would appear that there's something about the mysensors code that is causing the problems. @d00616 Can we please get it fixed?
I have no I2C Hardware for testing, but I take a look into the I2C and MySensors code soon.
The sooner the better. I'm pretty much stuck until it gets fixed.
@neverdie
I have been using The NRF5 with mysensors for a number of weeks with the si7021.
So it must be just a recent problem with the mysensors code?
@neverdie
So it must be just a recent problem with the mysensors code?I think so. Are you running the most current version? si7021 was working for me too on earlier versions. The latest update seems to have broken it. It's the one that uses myBoardNrf5 instead of myNrf5Board.
@neverdie
So it must be just a recent problem with the mysensors code?Would you mind trying the most recent version also to see if it breaks on you too? That would at least confirm it.
Right now my only alternative is to roll-back to the earlier version and just never upgrade again.
@neverdie
Where is myBoardNrf5 so i can check?
@neverdie
@neverdie
That explains it i am not using code from d00616.
I am only using the mysensors library and sandeeps stuff.
Sorry mate.
Well, in general, it's very handy for handling the pin mappings. Up until the latest release, it has worked fine. It still works fine now, except for the I2C pin mappings.
@neverdie
Hmmm at what cost?
Maybe i will stick with what i have got as it just works.
@d00616 Maybe you can just make it like it was before, where there was only one pair of I2c pins, not two as in your upgraded version? Maybe then it would work again.
Sorry mate.If you're using mysensors, then you're using d00616 code (i'm kidding)
@NeverDie I can only confirm, it is related to the ArduinoHwNRF5 code as I have not the problem (I'm not using this part yet. I'm still using my own custom board definitions for the moment).
This should be fixed soon (december can be a busy month..)
This is the better repository: https://github.com/mysensors/ArduinoHwNRF5
@neverdie said in MySensors NRF5 Platform:
Please give me some time. After an debug session with @scalz and @Yveaux, I think this is a tool chain (GCC 5.3) problem. The pin mapping array is part of the binary, but the Wire constructor gets an array with 0 while the Wire instance has pin mapping information.
Yesterday, I had a try to port ArduinoHwNRF5 back to the same tool chain (GCC 4.8) used by Arduino Primo and SAMD boards. I think for compatibility, this is the best option.
If I have no luck, I either remove the option of the pin remapping table or I go back to the old version. I think going back is no good idea, because the NRF52840 has more than one 32 GPIO, which requires advanced parameters.
Back from the compiler hell. There is no chance getting the GCC 4.8 to work without forking the arduino-nrf5 code. Compiling with GCC 4.8 has the same result.I have changed the templates a little bit and moved the code for pin mapping generation. Now it works for me. Please give me some time to clear the code and create a new package (0.3.0). With the new package, you have to add '#include <compat_pin_mapping.h>' before '#end" in MyBoardNRF5.cpp. You have to rename the '#ifdefs' and '#define' in both board files to match MYBOARDNRF5 instead of MYNRF5BOARD.
Now, there is a new Version 0.3.0 for MyBoardNRF5 available. It can be installed via the Board Manager. Please change the templates like described above. I think, now the board definition is stable and ready to support other Arduino variants without changing the board definition.
I think I made the changes you recommended, but now I'm getting:
Board MyBoard_nRF51822 (platform nRF5, package MySensors) is unknown Error compiling for board MyBoardNRF5 nRF51822.
Board MyBoard_nRF51822 (platform nRF5, package MySensors) is unknownError compiling for board MyBoardNRF5 nRF51822.
I had the same message. In my case, I have uninstalled arduino-nrf5, cleared files, which are not removed from packages directory (the 0.2.1 MyBoard files) and reinstalled arduino-nrf5. After restarting Arduino it was fine.
@d00616
I'm still getting the error. I tried deleting arduino-nrf5 library and re-installing it fresh, but I don't know how, on Windows, to clear files and remove them from the packages directory. I'm not even aware of their being a "packages directory." Sorry.
@d00616 You mentioned that it works only with a particular version of GCC. Does that mean I need to have a particular version of the Arduino IDE installed? I'm currently running the latest version of Windows Arduino IDE, which is 1.8.5.
The irony of it all is that the earlier setup from 3 or so weeks ago seemed to work just fine. Unfortunately, I no longer have any idea how to get back to that.
C:\Users...\AppData\Local\Arduino15\packages\MySensors\
@scalz said in MySensors NRF5 Platform:
C:\Users...\AppData\Local\Arduino15\packages\MySensors\Thanks!
The good news is that it compiles now. Also, the pin mapping for an LED is working. However, the bad news is that pin mapping for Serial Rx and Tx doesn't seem to be working, so I can't read any serial debug messages. Therefore, not sure if I2C is working or not.
I did another purge and reinsatall of the boards, and now serial is working.
Unfortunately, it does not appear that I2C is working.
Curiously, I2c does seem to work on a nRF52 DK using the myboard board definition.
However, it doesn't seem to be working on the nrf51.
The GCC version is part of the arduino-nrf5 distribution.
I have I2C and serial running with a NRF52832.
You can try to remove the compat_pin_mapping line and add the 0.1.0 pin map at this place. Then the board definition is nearly the 0.1.0 version.@neverdie said in MySensors NRF5 Platform:
I check the NRF51 board. What do you mean with no working?
I hope that narrows down the likely cause of the problem. The fact that it's working on the nRF52 gives me some hope it can be made to work on the nRF51.
The nRF51 can't find the si7021 device, even though it's connected.
Yes, it does seem to work on the nRF52832. Just not presently on the nRF51822.
I'm running the sparkfun si7021 code. When I run it on the nrf52832, it yields:
Si7021 Found Temp:70.51F, Humidity:40.71%
which is correct, but when I run it on the nRF51822, the result is:
No Devices Detected Temp:-51.85F, Humidity:-5.81%
which is incorrect.
Can you check, if the device works with the "Generic NRF51822" board? You can edit the variant files in the arduino-nrf5\variants directory.
C:\Users...\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.4.0\variants\Generic
C:\Users...\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.4.0\variants\GenericI tried, but I guess I'm not doing it right. I couldn't even get it to blink an LED that way.
